[GRASS-SVN] r58462 - grass/branches/develbranch_6/db/base
Sat Dec 14 14:38:25 PST 2013
Author: neteler
Date: 2013-12-14 14:38:24 -0800 (Sat, 14 Dec 2013)
New Revision: 58462
   grass/branches/develbranch_6/db/base/db.connect.html
db.connect.html: cosmetics (partial sync with trunk)
Modified: grass/branches/develbranch_6/db/base/db.connect.html
--- grass/branches/develbranch_6/db/base/db.connect.html	2013-12-14 22:36:02 UTC (rev 58461)
+++ grass/branches/develbranch_6/db/base/db.connect.html	2013-12-14 22:38:24 UTC (rev 58462)
@@ -3,8 +3,9 @@
 <em>db.connect</em> allows the user to set database connection parameters.
 These parameters are then taken as default values by modules so that the
 user does not need to enter the parameters each time.
+<p>
+The default database backend in GRASS 6 is DBF.
 <h2>NOTES</h2>
 Values are stored in the mapset's <tt>VAR</tt> file;
@@ -43,15 +44,16 @@
 db.tables -p
 </pre></div>
 <p>
-The SQLite database is created automatically when used the first time.
+The SQLite database file is created automatically when used the first time.
 <h3>ODBC</h3>
-Network storage: (may require the use of <a href=db.login.html>db.login</a>):
+Network storage, database tables stored in database "mydb"
+(may require the use of <em><a href=db.login.html>db.login</a></em>):
 <br>
 <div class="code"><pre>
-db.connect driver=odbc database=gtest
+db.connect driver=odbc database=mydb
 db.login user=myname [pass=secret]
 db.connect -p
 db.tables -p
@@ -61,7 +63,7 @@
 <h3>PostgreSQL</h3>
-(may require the use of <a href=db.login.html>db.login</a>):
 <br>
 db.connect driver=pg database="host=myserver.itc.it,dbname=mydb"
@@ -74,7 +76,7 @@
 <h3>PostgreSQL with different port</h3>
 <br>
 db.connect driver=pg database="host=myserver.itc.it,dbname=mydb,port=6666"
@@ -86,7 +88,7 @@
 <h3>MySQL (local)</h3>
-Local storage (<a href=db.login.html>db.login</a> may not be needed):
+Local storage (<em><a href=db.login.html>db.login</a></em> may not be needed):
 <br>
 db.connect driver=mysql database=mydb
@@ -99,7 +101,7 @@
 <h3>MySQL (external server)</h3>
 <br>
 db.connect driver=mysql database="host=myserver.itc.it,dbname=mydb"
@@ -113,14 +115,18 @@
 <em>
 <a href="db.columns.html">db.columns</a>,
+<a href="db.copy.html">db.copy</a>,
 <a href="db.drivers.html">db.drivers</a>,
 <a href="db.login.html">db.login</a>,
 <a href="db.tables.html">db.tables</a>,
 <a href="v.db.addtable.html">v.db.addtable</a>,
-<a href="v.db.connect.html">v.db.connect</a>,
-<a href="sql.html">GRASS SQL interface</a></em>
+<a href="v.db.connect.html">v.db.connect</a>
+</em>
+<p>
+<a href="sql.html">GRASS SQL interface</a>
 <h2>AUTHOR</h2>
 Radim Blazek, ITC-Irst, Trento, Italy
