[GRASS-SVN] r58483 - grass/trunk/imagery/i.segment
svn_grass at osgeo.org
Tue Dec 17 13:29:08 PST 2013
Author: martinl
Date: 2013-12-17 13:29:07 -0800 (Tue, 17 Dec 2013)
New Revision: 58483
Added:
grass/trunk/imagery/i.segment/ortho_segs_final.jpg
grass/trunk/imagery/i.segment/ortho_segs_l1.jpg
grass/trunk/imagery/i.segment/ortho_segs_l2_l5.jpg
grass/trunk/imagery/i.segment/create_isegs.c
grass/trunk/imagery/i.segment/i.segment.html
grass/trunk/imagery/i.segment/open_files.c
grass/trunk/imagery/i.segment/write_output.c
i.segment: fix G_percent() usage
message cosmetics
update manual + add screenshots
Modified: grass/trunk/imagery/i.segment/create_isegs.c
--- grass/trunk/imagery/i.segment/create_isegs.c 2013-12-17 15:31:35 UTC (rev 58482)
+++ grass/trunk/imagery/i.segment/create_isegs.c 2013-12-17 21:29:07 UTC (rev 58483)
@@ -241,7 +241,7 @@
while (t < globals->end_t && n_merges > 1) {
- G_message(_("Pass %d:"), ++t);
+ G_message(_("Processing pass %d..."), ++t);
n_merges = 0;
globals->candidate_count = 0;
@@ -509,6 +509,7 @@
} /* end pathflag */
} /* next col */
} /* next row */
+ G_percent(1, 1, 1);
/* finished one pass for processing candidate pixels */
G_verbose_message("%d merges", n_merges);
@@ -520,7 +521,7 @@
if (n_merges > 1)
G_message(_("Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"), t);
else
- G_message(_("Segmentation converged after %d iterations."), t);
+ G_message(_("Segmentation converged after %d iterations"), t);
@@ -528,7 +529,7 @@
if (globals->min_segment_size > 1) {
- G_message(_("Merging segments smaller than %d cells"), globals->min_segment_size);
+ G_message(_("Merging segments smaller than %d cells..."), globals->min_segment_size);
threshold = globals->alpha * globals->alpha;
Modified: grass/trunk/imagery/i.segment/i.segment.html
--- grass/trunk/imagery/i.segment/i.segment.html 2013-12-17 15:31:35 UTC (rev 58482)
+++ grass/trunk/imagery/i.segment/i.segment.html 2013-12-17 21:29:07 UTC (rev 58483)
@@ -41,26 +41,27 @@
their most similar neighbor even if the similarity is greater than
the threshold.
<p>
-The threshold must be larger than 0.0 and smaller than 1.0. A threshold
+The <b>threshold</b> must be larger than 0.0 and smaller than 1.0. A threshold
of 0 would allow only identical valued pixels to be merged, while a
threshold of 1 would allow everything to be merged. Initial empirical
tests indicate threshold values of 0.01 to 0.05 are reasonable values
to start. It is recommended to start with a low value, e.g. 0.01, and
then perform hierachical segmentation by using the output of the last
-run as seeds for the next run.
+run as <b>seeds</b> for the next run.
<h4>Calculation Formulas</h4>
Both Euclidean and Manhattan distances use the normal definition,
considering each raster in the image group as a dimension.
-In future, the distance calculation will also take into account the
+In future, the distance calculation will also take into account the
shape characteristics of the segments. The normal distances are then
-multiplied by the input radiometric weight. Next an additional
-contribution is added: (1-radioweight) * {smoothness * smoothness
-weight + compactness * (1-smoothness weight)}, where compactness =
-Perimeter Length / sqrt( Area ) and smoothness = Perimeter
-Length / Bounding Box. The perimeter length is estimated as the
-number of pixel sides the segment has.
+multiplied by the input radiometric weight. Next an additional
+contribution is added: <tt>(1-radioweight) * {smoothness * smoothness
+weight + compactness * (1-smoothness weight)}</tt>,
+where <tt>compactness = Perimeter Length / sqrt( Area )</tt>
+and <tt>smoothness = Perimeter Length / Bounding Box</tt>. The
+perimeter length is estimated as the number of pixel sides the segment
+has.
<h3>Seeds</h3>
The seeds map can be used to provide either seed pixels (random or
@@ -103,47 +104,54 @@
the set size, thus forcing very small segments to merge with their
most similar neighbor.
-<h2>EXAMPLES</h2>
+<h2>EXAMPLE</h2>
This example uses the ortho photograph included in the NC Sample
Dataset. Set up an imagery group:
<div class="code"><pre>
i.group group=ortho_group input=ortho_2001_t792_1m at PERMANENT
</pre></div>
-<p>Set the region to a smaller test region.
+<p>Set the region to a smaller test region (resolution taken from
+input ortho photograph).
-g.region -p n=220446 s=220075 e=639151 w=638592
+g.region -p rast=ortho_2001_t792_1m n=220446 s=220075 e=639151 w=638592
</pre></div>
Try out a low threshold and check the results.
i.segment group=ortho_group output=ortho_segs_l1 threshold=0.02
</pre></div>
-<p></p>
+<center>
+<img src="ortho_segs_l1.jpg">
+</center>
+<p>
From a visual inspection, it seems this results in too many segments.
Increasing the threshold, using the previous results as seeds,
and setting a minimum size of 2:
-i.segment group=ortho_group output=ortho_segs_l2 threshold=0.05 \
- seeds=ortho_segs_l1 min=2
+i.segment group=ortho_group output=ortho_segs_l2 threshold=0.05 seeds=ortho_segs_l1 min=2
-i.segment group=ortho_group output=ortho_segs_l3 threshold=0.1 \
- seeds=ortho_segs_l2
+i.segment group=ortho_group output=ortho_segs_l3 threshold=0.1 seeds=ortho_segs_l2
-i.segment group=ortho_group output=ortho_segs_l4 threshold=0.2 \
- seeds=ortho_segs_l3
+i.segment group=ortho_group output=ortho_segs_l4 threshold=0.2 seeds=ortho_segs_l3
-i.segment group=ortho_group output=ortho_segs_l5 threshold=0.3 \
- seeds=ortho_segs_l4
+i.segment group=ortho_group output=ortho_segs_l5 threshold=0.3 seeds=ortho_segs_l4
</pre></div>
+<center>
+<img src="ortho_segs_l2_l5.jpg">
+</center>
<p>
-The output ortho_segs_l4 with threshold=0.2 still has too many segments,
-but the output with threshold=0.3 has too few segments. A threshold
-value of 0.25 seems to be a good choice. There is also some noise in
-the image, lets next force all segments smaller than 10 pixels to be
-merged into their most similar neighbor (even if they are less similar
-than required by our threshold):
+The output <tt>ortho_segs_l4</tt> with <b>threshold</b>=0.2 still has
+too many segments, but the output with <b>threshold</b>=0.3 has too few
+segments. A threshold value of 0.25 seems to be a good choice. There
+is also some noise in the image, lets next force all segments smaller
+than 10 pixels to be merged into their most similar neighbor (even if
+they are less similar than required by our threshold):
<p>Set the region to match the entire map(s) in the group.
@@ -151,22 +159,26 @@
</pre></div>
<p>
-Run i.segment on the full map:
+Run <em>i.segment</em> on the full map:
-i.segment group=ortho_group output=ortho_segs_final \
- threshold=0.25 min=10
+i.segment group=ortho_group output=ortho_segs_final threshold=0.25 min=10
</pre></div>
+<center>
+<img src="ortho_segs_final.jpg">
+</center>
<p>
-Processing the entire ortho image with nearly 10 million pixels took
-about 20 minutes for the final run.
+Processing the entire ortho image with nearly 10 million pixels took
+about 450 times more then for the final run.
<h2>TODO</h2>
<h3>Functionality</h3>
<ul>
<li>Further testing of the shape characteristics (smoothness,
compactness), if it looks good it should be added.
-<b>in progress</b></li>
+(<b>in progress</b>)</li>
<li>Malahanobis distance for the similarity calculation.</li>
</ul>
<h3>Use of Segmentation Results</h3>
Modified: grass/trunk/imagery/i.segment/open_files.c
--- grass/trunk/imagery/i.segment/open_files.c 2013-12-17 15:31:35 UTC (rev 58482)
+++ grass/trunk/imagery/i.segment/open_files.c 2013-12-17 21:29:07 UTC (rev 58483)
@@ -202,6 +202,7 @@
G_debug(1, "nrows: %d, min row: %d, max row %d",
globals->nrows, globals->row_min, globals->row_max);
G_debug(1, "ncols: %d, min col: %d, max col %d",
Added: grass/trunk/imagery/i.segment/ortho_segs_final.jpg
(Binary files differ)
Property changes on: grass/trunk/imagery/i.segment/ortho_segs_final.jpg
___________________________________________________________________
Added: svn:mime-type
+ image/jpeg
Added: grass/trunk/imagery/i.segment/ortho_segs_l1.jpg
Property changes on: grass/trunk/imagery/i.segment/ortho_segs_l1.jpg
+ image/jpeg
Added: grass/trunk/imagery/i.segment/ortho_segs_l2_l5.jpg
Property changes on: grass/trunk/imagery/i.segment/ortho_segs_l2_l5.jpg
+ image/jpeg
Modified: grass/trunk/imagery/i.segment/write_output.c
--- grass/trunk/imagery/i.segment/write_output.c 2013-12-17 15:31:35 UTC (rev 58482)
+++ grass/trunk/imagery/i.segment/write_output.c 2013-12-17 21:29:07 UTC (rev 58483)
@@ -28,7 +28,7 @@
G_debug(1, "start data transfer from segmentation file to raster");
- G_message(_("Writing out segment IDs"));
+ G_message(_("Writing out segment IDs..."));
maxid = 0;
for (row = 0; row < globals->nrows; row++) {
@@ -49,7 +49,8 @@
Rast_put_row(out_fd, outbuf, CELL_TYPE);
/* close and save segment id file */
Rast_close(out_fd);
G_free(outbuf);
