[GRASS-SVN] r58496 - grass/trunk/raster/r.topmodel
svn_grass at osgeo.org
Fri Dec 20 08:35:40 PST 2013
Author: hcho
Date: 2013-12-20 08:35:40 -0800 (Fri, 20 Dec 2013)
New Revision: 58496
grass/trunk/raster/r.topmodel/file_io.c
grass/trunk/raster/r.topmodel/r.topmodel.html
Changed the format of the parameters and input files.
ntimesteps removed from the input file and automatically determined.
Modified: grass/trunk/raster/r.topmodel/file_io.c
--- grass/trunk/raster/r.topmodel/file_io.c 2013-12-19 23:46:32 UTC (rev 58495)
+++ grass/trunk/raster/r.topmodel/file_io.c 2013-12-20 16:35:40 UTC (rev 58496)
@@ -10,7 +10,6 @@
char *str;
buffer[0] = 0;
fscanf(fp, "%[^\n]", buffer);
getc(fp);
@@ -28,7 +27,6 @@
int i, j;
double x;
/* Read topographic index statistics file */
if ((fp = fopen(file.topidxstats, "r")) == NULL)
G_fatal_error(_("Unable to open input file <%s>"), file.topidxstats);
@@ -42,7 +40,6 @@
double Aatb_r;
get_line(fp, buf);
if (sscanf(buf, "%lf %lf", &atb, &Aatb_r) == 2) {
topidxstats.atb = (double *)G_realloc(topidxstats.atb,
(i + 1) * sizeof(double));
@@ -55,7 +52,6 @@
misc.ntopidxclasses = i;
fclose(fp);
for (i = 0; i < misc.ntopidxclasses; i++)
@@ -74,14 +70,12 @@
/* Read parameters file */
if ((fp = fopen(file.params, "r")) == NULL)
G_fatal_error(_("Unable to open input file <%s>"), file.params);
for (; !feof(fp);) {
get_line(fp, buf);
i = strlen(buf) - 1;
for (; i >= 0; i--) {
if (buf[i] != ' ' && buf[i] != '\t') {
@@ -96,36 +90,74 @@
get_line(fp, buf);
if (sscanf(buf, "%lf", &(params.A)) == 1)
break;
get_line(fp, buf);
- if (sscanf(buf, "%lf %lf %lf %lf %lf %lf %lf %lf",
- &(params.qs0), &(params.lnTe),
- &(params.m), &(params.Sr0),
- &(params.Srmax), &(params.td),
- &(params.vch), &(params.vr)) == 8)
+ if (sscanf(buf, "%lf", &(params.qs0)) == 1)
break;
if (params.qs0 == 0.0) {
fclose(fp);
- G_fatal_error("parameters.qs0 can not be 0.0");
+ G_fatal_error("parameters.qs0 cannot be 0.0");
exit(EXIT_FAILURE);
get_line(fp, buf);
- if (sscanf(buf, "%d %lf %lf %lf",
- &(params.infex), &(params.K0),
- &(params.psi), &(params.dtheta)) == 4)
+ if (sscanf(buf, "%lf", &(params.lnTe)) == 1)
break;
+ for (; !feof(fp);) {
+ get_line(fp, buf);
+ if (sscanf(buf, "%lf", &(params.m)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.Sr0)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.Srmax)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.td)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.vch)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.vr)) == 1)
+ break;
+ if (sscanf(buf, "%d", &(params.infex)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.K0)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.psi)) == 1)
+ break;
+ if (sscanf(buf, "%lf", &(params.dtheta)) == 1)
+ break;
params.d = NULL;
params.Ad_r = NULL;
@@ -135,10 +167,8 @@
double Ad_r;
get_line(fp, buf);
if (sscanf(buf, "%lf %lf", &d, &Ad_r) == 2) {
- params.d = (double *)G_realloc(params.d,
- (i + 1) * sizeof(double));
+ params.d = (double *)G_realloc(params.d, (i + 1) * sizeof(double));
params.Ad_r = (double *)G_realloc(params.Ad_r,
params.d[i] = d;
@@ -149,26 +179,30 @@
params.nch = i;
fclose(fp);
/* Read input file */
if ((fp = fopen(file.input, "r")) == NULL)
G_fatal_error(_("Unable to open input file <%s>"), file.input);
get_line(fp, buf);
- if (sscanf(buf, "%d %lf", &(input.ntimesteps), &(input.dt)) == 2)
+ if (sscanf(buf, "%lf", &(input.dt)) == 1)
break;
- input.R = (double *)G_malloc(input.ntimesteps * sizeof(double));
- input.Ep = (double *)G_malloc(input.ntimesteps * sizeof(double));
+ input.R = NULL;
+ input.Ep = NULL;
- for (i = 0; i < input.ntimesteps && !feof(fp);) {
+ for (i = 0; !feof(fp);) {
+ double R;
+ double Ep;
get_line(fp, buf);
- if (sscanf(buf, "%lf %lf", &(input.R[i]), &(input.Ep[i])) == 2)
- i++;
+ if (sscanf(buf, "%lf %lf", &R, &Ep) == 2) {
+ input.R = (double *)G_realloc(input.R, (i + 1) * sizeof(double));
+ input.Ep = (double *)G_realloc(input.Ep, (i + 1) * sizeof(double));
+ input.R[i] = R;
+ input.Ep[i++] = Ep;
input.ntimesteps = i;
@@ -183,16 +217,14 @@
get_line(fp, buf);
if (sscanf(buf, "%lf", &(misc.Qobs[i])) == 1)
i++;
- input.ntimesteps = (input.ntimesteps < i ? input.ntimesteps : i);
+ input.ntimesteps = (i < input.ntimesteps ? i : input.ntimesteps);
fclose(fp);
if (!(misc.timestep > 0 && misc.timestep < input.ntimesteps + 1))
misc.timestep = 0;
if (!(misc.topidxclass > 0 && misc.topidxclass < misc.ntopidxclasses + 1))
@@ -209,14 +241,12 @@
int st, et, si, ei;
int i, j;
time(&tloc);
ltime = localtime(&tloc);
ltime->tm_year += 1900;
ltime->tm_mon++;
if ((fp = fopen(file.output, "w")) == NULL)
G_fatal_error(_("Unable to open output file <%s>"), file.output);
@@ -295,7 +325,6 @@
fprintf(fp, "# %-15s Excess flow from a fully saturated "
"area per unit area\n" "# %77s\n", "ex:", "[m/timestep]");
fprintf(fp, "\n");
if (file.obsflow) {
Modified: grass/trunk/raster/r.topmodel/r.topmodel.html
--- grass/trunk/raster/r.topmodel/r.topmodel.html 2013-12-19 23:46:32 UTC (rev 58495)
+++ grass/trunk/raster/r.topmodel/r.topmodel.html 2013-12-20 16:35:40 UTC (rev 58496)
@@ -19,40 +19,56 @@
3.31697E+07
-# qs0 [m/h]: Initial subsurface flow per unit area
-# "The first streamflow input is assumed to represent
-# only the subsurface flow contribution in the watershed."
+# qs0 [m/h]: Initial subsurface flow per unit area
+# "The first streamflow input is assumed to represent
+# only the subsurface flow contribution in the watershed."
# - Liaw (1988)
+0.000075
# lnTe [ln(m^2/h)]: Areal average of ln(T0) = ln(Te)
-# m [m]: Scaling parameter
-# Sr0 [m]: Initial root zone storage deficit
-# Srmax [m]: Maximum root zone storage deficit
-# td [h]: Unsaturated zone time delay per unit storage deficit
-# if greater than 0.
+4.
+# m [m]: Scaling parameter
+0.0125
+# Sr0 [m]: Initial root zone storage deficit
+0.0025
+# Srmax [m]: Maximum root zone storage deficit
+0.041
+# td [h]: Unsaturated zone time delay per unit storage deficit if greater than 0
# OR
-# -alpha: Effective vertical hydraulic gradient if not greater than 0.
-# For example, -10 means alpha = 10.
-# vch [m/h]: Main channel routing velocity
-# vr [m/h]: Internal subcatchment routing velocity
+# -alpha: Effective vertical hydraulic gradient if not greater than 0.
+# For example, -10 means alpha=10.
+60.
-# qs0 lnTe m Sr0 Srmax td/alpha vch vr
- 0.000075 4. 0.0125 0.0025 0.041 60. 20000. 10000.
+# vch [m/h]: Main channel routing velocity
+20000.
+# vr [m/h]: Internal subcatchment routing velocity
+10000.
-# infex: Calculate infiltration excess if not zero (integer)
-# K0 [m/h]: Surface hydraulic conductivity
-# psi [m]: Wetting front suction
-# dtheta: Water content change across the wetting front
+# infex: Calculate infiltration excess if not zero (integer)
+0
-# infex K psi dtheta
- 0 2. 0.1 0.1
+# K0 [m/h]: Surface hydraulic conductivity
+2.
+# psi [m]: Wetting front suction
+0.1
+# dtheta: Water content change across the wetting front
+0.1
-# d [m]: Distance from catchment
-# The first value should be the mainstream distance from
-# the subcatchment outlet to the catchment outlet.
-# Ad_r: Cumulative area ratio of subcatchment (0.0 to 1.0)
-# The first and last values should be 0 and 1, respectively.
+# d [m]: Distance from the catchment outlet
+# The first value should be the mainstream distance from
+# the subcatchment outlet to the catchment outlet.
+# Ad_r: Cumulative area ratio of subcatchment (0.0 to 1.0)
+# The first and last values should be 0 and 1, respectively.
# d Ad_r
0 0.0
@@ -68,15 +84,12 @@
<dd>
This file contains observed weather data.
<div class="code"><pre>
-# ntimesteps: Number of time steps
-# dt [h]: Time increment per time step
+# dt [h]: Time increment per time step
+24
-# ntimesteps dt
-365 24
-# R [m/dt]: Rainfall
-# Ep [m/dt]: Potential evapotranspiration
+# R [m/dt]: Rainfall
+# Ep [m/dt]: Potential evapotranspiration
# R Ep
0.000033 0.000000
