[GRASS-SVN] r58507 - in grass/trunk/raster/simwe: r.sim.water simlib
svn_grass at osgeo.org
Sun Dec 22 13:04:26 PST 2013
Author: annakrat
Date: 2013-12-22 13:04:25 -0800 (Sun, 22 Dec 2013)
New Revision: 58507
grass/trunk/raster/simwe/r.sim.water/main.c
grass/trunk/raster/simwe/simlib/hydro.c
grass/trunk/raster/simwe/simlib/output.c
simwe: write timestamps of output maps to simplify registering into temporal framework, use minutes instead of seconds as postfix of maps
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c 2013-12-22 08:35:19 UTC (rev 58506)
+++ grass/trunk/raster/simwe/r.sim.water/main.c 2013-12-22 21:04:25 UTC (rev 58507)
@@ -428,7 +428,7 @@
* to real timesec in seconds */
timesec = timesec * 60.0;
iterout = iterout * 60.0;
- if ((timesec / iterout) > 100.0)
+ if ((timesec / iterout) > 100.0 && ts == 1)
G_message(_("More than 100 files are going to be created !!!!!"));
/* compute how big the raster is and set this to appr 2 walkers per cell */
@@ -468,12 +468,6 @@
grad_check();
main_loop();
- if (ts == 0) {
- ii = output_data(0, 1.);
- if (ii != 1)
- G_fatal_error(_("Cannot write raster maps"));
/* Exit with Success */
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/simwe/simlib/hydro.c
--- grass/trunk/raster/simwe/simlib/hydro.c 2013-12-22 08:35:19 UTC (rev 58506)
+++ grass/trunk/raster/simwe/simlib/hydro.c 2013-12-22 21:04:25 UTC (rev 58507)
@@ -457,7 +457,15 @@
erod(gama);
/* ........ end of iblock loop */
+ /* Write final maps here because we know the last time stamp here */
+ if (ts == 0) {
+ conn = (double)nblock / (double)iblock;
+ itime = (int)(i * deltap * timec);
+ ii = output_data(itime, conn);
+ if (ii != 1)
+ G_fatal_error(_("Cannot write raster maps"));
/* Close the observation logfile */
if(points.is_open)
fclose(points.output);
Modified: grass/trunk/raster/simwe/simlib/output.c
--- grass/trunk/raster/simwe/simlib/output.c 2013-12-22 08:35:19 UTC (rev 58506)
+++ grass/trunk/raster/simwe/simlib/output.c 2013-12-22 21:04:25 UTC (rev 58507)
@@ -13,15 +13,15 @@
#include <grass/waterglobs.h>
-static void output_walker_as_vector(int tt, int ndigit);
+static void output_walker_as_vector(int tt_minutes, int ndigit, struct TimeStamp *timestamp);
/* This function was added by Soeren 8. Mar 2011 */
/* It replaces the site walker output implementation */
/* Only the 3d coordinates of the walker are stored. */
-void output_walker_as_vector(int tt, int ndigit)
+void output_walker_as_vector(int tt_minutes, int ndigit, struct TimeStamp *timestamp)
char buf[GNAME_MAX + 10];
- char *outwalk_time = NULL;
+ char *outwalk_time = NULL;
double x, y, z;
struct Map_info Out;
struct line_pnts *Points;
@@ -32,7 +32,7 @@
/* In case of time series we extent the output name with the time value */
if (ts == 1) {
- G_snprintf(buf, sizeof(buf), "%s_%.*d", outwalk, ndigit, tt);
+ G_snprintf(buf, sizeof(buf), "%s_%.*d", outwalk, ndigit, tt_minutes);
outwalk_time = G_store(buf);
Vect_open_new(&Out, outwalk_time, WITH_Z);
G_message("Writing %i walker into vector file %s", nstack, outwalk_time);
@@ -62,6 +62,10 @@
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
+ if (ts == 1)
+ G_write_vector_timestamp(outwalk_time, "1", timestamp);
+ else
+ G_write_vector_timestamp(outwalk, "1", timestamp);
return;
@@ -80,30 +84,40 @@
float gsmax = 0, dismax = 0., gmax = 0., ermax = -1.e+12, ermin = 1.e+12;
struct Colors colors;
struct History hist, hist1; /* hist2, hist3, hist4, hist5 */
+ struct TimeStamp timestamp;
char *depth0 = NULL, *disch0 = NULL, *err0 = NULL;
char *conc0 = NULL, *flux0 = NULL;
char *erdep0 = NULL;
const char *mapst = NULL;
char *type;
+ char timestamp_buf[15];
int ndigit;
+ int timemin;
+ int tt_minutes;
FCELL dat1, dat2;
float a1, a2;
+ timemin = (int)(timesec / 60. + 0.5);
ndigit = 2;
/* more compact but harder to read:
ndigit = (int)floor(log10(timesec)) + 2 */
- if (timesec >= 10)
+ if (timemin >= 100)
ndigit = 3;
- if (timesec >= 100)
+ if (timemin >= 1000)
ndigit = 4;
- if (timesec >= 1000)
+ if (timemin >= 10000)
ndigit = 5;
- if (timesec >= 10000)
- ndigit = 6;
+ /* Convert to minutes */
+ tt_minutes = (int)(tt / 60. + 0.5);
+ /* Create timestamp */
+ sprintf(timestamp_buf, "%d minutes", tt_minutes);
+ G_scan_timestamp(×tamp, timestamp_buf);
/* Write the output walkers */
- output_walker_as_vector(tt, ndigit);
+ output_walker_as_vector(tt_minutes, ndigit, ×tamp);
Rast_set_window(&cellhd);
@@ -117,7 +131,7 @@
if (depth) {
depth_cell = Rast_allocate_f_buf();
if (ts == 1) {
- G_snprintf(buf, sizeof(buf), "%s.%.*d", depth, ndigit, tt);
+ G_snprintf(buf, sizeof(buf), "%s.%.*d", depth, ndigit, tt_minutes);
depth0 = G_store(buf);
depth_fd = Rast_open_fp_new(depth0);
@@ -128,7 +142,7 @@
if (disch) {
disch_cell = Rast_allocate_f_buf();
if (ts == 1) {
- G_snprintf(buf, sizeof(buf),"%s.%.*d", disch, ndigit, tt);
+ G_snprintf(buf, sizeof(buf),"%s.%.*d", disch, ndigit, tt_minutes);
disch0 = G_store(buf);
disch_fd = Rast_open_fp_new(disch0);
@@ -139,7 +153,7 @@
if (err) {
err_cell = Rast_allocate_f_buf();
if (ts == 1) {
- G_snprintf(buf, sizeof(buf), "%s.%.*d", err, ndigit, tt);
+ G_snprintf(buf, sizeof(buf), "%s.%.*d", err, ndigit, tt_minutes);
err0 = G_store(buf);
err_fd = Rast_open_fp_new(err0);
@@ -150,7 +164,7 @@
if (conc) {
conc_cell = Rast_allocate_f_buf();
if (ts == 1) {
- G_snprintf(buf, sizeof(buf), "%s.%.*d", conc, ndigit, tt);
+ G_snprintf(buf, sizeof(buf), "%s.%.*d", conc, ndigit, tt_minutes);
conc0 = G_store(buf);
conc_fd = Rast_open_fp_new(conc0);
@@ -161,7 +175,7 @@
if (flux) {
flux_cell = Rast_allocate_f_buf();
if (ts == 1) {
- G_snprintf(buf, sizeof(buf), "%s.%.*d", flux, ndigit, tt);
+ G_snprintf(buf, sizeof(buf), "%s.%.*d", flux, ndigit, tt_minutes);
flux0 = G_store(buf);
flux_fd = Rast_open_fp_new(flux0);
@@ -172,7 +186,7 @@
if (erdep) {
erdep_cell = Rast_allocate_f_buf();
if (ts == 1) {
- G_snprintf(buf, sizeof(buf), "%s.%.*d", erdep, ndigit, tt);
+ G_snprintf(buf, sizeof(buf), "%s.%.*d", erdep, ndigit, tt_minutes);
erdep0 = G_store(buf);
erdep_fd = Rast_open_fp_new(erdep0);
@@ -509,6 +523,11 @@
Rast_write_history(depth0, &hist);
else
Rast_write_history(depth, &hist);
+ if (ts == 1)
+ G_write_raster_timestamp(depth0, ×tamp);
+ else
+ G_write_raster_timestamp(depth, ×tamp);
if (disch) {
@@ -546,6 +565,11 @@
Rast_write_history(disch0, &hist);
else
Rast_write_history(disch, &hist);
+ if (ts == 1)
+ G_write_raster_timestamp(disch0, ×tamp);
+ else
+ G_write_raster_timestamp(disch, ×tamp);
if (flux) {
@@ -582,6 +606,11 @@
Rast_write_history(flux0, &hist);
else
Rast_write_history(flux, &hist);
+ if (ts == 1)
+ G_write_raster_timestamp(flux0, ×tamp);
+ else
+ G_write_raster_timestamp(flux, ×tamp);
return 1;
