[GRASS-SVN] r58522 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Wed Dec 25 08:23:15 PST 2013
Author: martinl
Date: 2013-12-25 08:23:15 -0800 (Wed, 25 Dec 2013)
New Revision: 58522
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/model.py
wxGUI/modeler: implement comments #2148
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2013-12-25 09:31:18 UTC (rev 58521)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2013-12-25 16:23:15 UTC (rev 58522)
@@ -100,7 +100,7 @@
self.canvas = ModelCanvas(self)
self.canvas.SetBackgroundColour(wx.WHITE)
self.canvas.SetCursor(self.cursors["default"])
self.model = Model(self.canvas)
self.variablePanel = VariablePanel(parent = self)
@@ -121,7 +121,7 @@
self.Bind(EVT_CMD_RUN, self.OnCmdRun)
self.Bind(EVT_CMD_DONE, self.OnCmdDone)
self.Bind(EVT_CMD_PREPARE, self.OnCmdPrepare)
self.notebook.AddPage(page = self.canvas, text=_('Model'), name = 'model')
self.notebook.AddPage(page = self.itemPanel, text=_('Items'), name = 'items')
self.notebook.AddPage(page = self.variablePanel, text=_('Variables'), name = 'variables')
@@ -1001,7 +1001,7 @@
self.SetScrollbars(20, 20, 2000/20, 2000/20)
self.Bind(wx.EVT_CHAR, self.OnChar)
def OnChar(self, event):
"""!Key pressed"""
kc = event.GetKeyCode()
@@ -1201,7 +1201,8 @@
if not hasattr (self, "popupID"):
self.popupID = dict()
for key in ('remove', 'enable', 'addPoint',
- 'delPoint', 'intermediate', 'props', 'id'):
+ 'delPoint', 'intermediate', 'props', 'id',
+ 'label', 'comment'):
self.popupID[key] = wx.NewId()
# record coordinates
@@ -1222,7 +1223,12 @@
else:
popupMenu.Append(self.popupID['enable'], text=_('Enable'))
self.frame.Bind(wx.EVT_MENU, self.OnEnable, id = self.popupID['enable'])
+ popupMenu.AppendSeparator()
+ popupMenu.Append(self.popupID['label'], text=_('Set label'))
+ self.frame.Bind(wx.EVT_MENU, self.OnSetLabel, id = self.popupID['label'])
+ popupMenu.Append(self.popupID['comment'], text=_('Set comment'))
+ self.frame.Bind(wx.EVT_MENU, self.OnSetComment, id = self.popupID['comment'])
if isinstance(shape, ModelRelation):
popupMenu.Append(self.popupID['addPoint'], text=_('Add control point'))
@@ -1264,7 +1270,29 @@
shape.Enable(enable)
self.frame.ModelChanged()
self.frame.canvas.Refresh()
+ def OnSetLabel(self, event):
+ shape = self.GetShape()
+ dlg = wx.TextEntryDialog(parent = self.frame, message = _("Label:"), caption = _("Set label"),
+ defaultValue = shape.GetLabel())
+ if dlg.ShowModal() == wx.ID_OK:
+ label = dlg.GetValue()
+ shape.SetLabel(label)
+ self.frame.ModelChanged()
+ self.frame.itemPanel.Update()
+ self.frame.canvas.Refresh()
+ dlg.Destroy()
+ def OnSetComment(self, event):
+ dlg = wx.TextEntryDialog(parent = self.frame, message = _("Comment:"), caption = _("Set comment"),
+ defaultValue = shape.GetComment(), style = wx.OK | wx.CANCEL | wx.CENTRE | wx.TE_MULTILINE)
+ comment = dlg.GetValue()
+ shape.SetComment(comment)
+ dlg.Destroy()
def _onSelectShape(self, shape):
canvas = shape.GetCanvas()
dc = wx.ClientDC(canvas)
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2013-12-25 09:31:18 UTC (rev 58521)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2013-12-25 16:23:15 UTC (rev 58522)
@@ -305,7 +305,8 @@
height = action['size'][1],
task = action['task'],
id = action['id'],
- label = action['label'])
+ label = action['label'],
+ comment = action['comment'])
if action['disabled']:
actionItem.Enable(False)
@@ -895,12 +896,13 @@
class ModelAction(ModelObject, ogl.RectangleShape):
"""!Action class (GRASS module)"""
def __init__(self, parent, x, y, id = -1, cmd = None, task = None,
- width = None, height = None, label = None):
+ width = None, height = None, label = None, comment = ''):
ModelObject.__init__(self, id)
self.parent = parent
self.task = task
self.label = label
+ self.comment = comment
if not width:
width = UserSettings.Get(group='modeler', key='action', subkey=('size', 'width'))
@@ -985,7 +987,15 @@
self.ClearText()
self.AddText('(%d) %s' % (idx, label))
+ def SetComment(self, comment):
+ """!Set comment"""
+ def GetComment(self):
+ """!Get comment"""
+ return self.comment
def SetProperties(self, params, propwin):
"""!Record properties dialog"""
self.task.params = params['params']
@@ -1666,13 +1676,19 @@
aId = int(action.get('id', -1))
label = action.get('name')
+ comment = action.find('comment')
+ if comment is not None:
+ commentString = comment.text
+ else:
+ commentString = ''
self.actions.append({ 'pos' : pos,
'size' : size,
'task' : task,
'id' : aId,
'disabled' : disabled,
- 'label' : label})
+ 'label' : label,
+ 'comment' : commentString})
def _getDim(self, node):
"""!Get position and size of shape"""
@@ -1933,6 +1949,9 @@
(' ' * self.indent, action.GetId(), EncodeString(action.GetLabel()), action.GetX(), action.GetY(),
action.GetWidth(), action.GetHeight()))
self.indent += 4
+ comment = action.GetComment()
+ if comment:
+ self.fd.write('%s<comment>%s</comment>\n' % (' ' * self.indent, EncodeString(comment)))
self.fd.write('%s<task name="%s">\n' % (' ' * self.indent, action.GetLog(string = False)[0]))
self.indent += 4
if not action.IsEnabled():
