[GRASS-SVN] r58536 - in grass-addons/grass6/raster: . r.convergence_angle
svn_grass at osgeo.org
Thu Dec 26 23:49:47 PST 2013
Author: hamish
Date: 2013-12-26 23:49:47 -0800 (Thu, 26 Dec 2013)
New Revision: 58536
Added:
grass-addons/grass6/raster/r.convergence_angle/
grass-addons/grass6/raster/r.convergence_angle/Makefile
grass-addons/grass6/raster/r.convergence_angle/r.convergence_angle
+ module to create a raster map containing the convergence angle at all cells
Copied: grass-addons/grass6/raster/r.convergence_angle/Makefile (from rev 57519, grass-addons/grass6/raster/r.cog/Makefile)
--- grass-addons/grass6/raster/r.convergence_angle/Makefile (rev 0)
+++ grass-addons/grass6/raster/r.convergence_angle/Makefile 2013-12-27 07:49:47 UTC (rev 58536)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.convergence_angle
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/raster/r.convergence_angle/r.convergence_angle
--- grass-addons/grass6/raster/r.convergence_angle/r.convergence_angle (rev 0)
+++ grass-addons/grass6/raster/r.convergence_angle/r.convergence_angle 2013-12-27 07:49:47 UTC (rev 58536)
@@ -0,0 +1,81 @@
+#!/bin/sh
+# MODULE: r.convergence_angle
+# AUTHOR: M. Hamish Bowman, Dept. Geology Dept., Otago Univeristy,
+# New Zealand
+# PURPOSE: Creates a raster map containing the convergence angle at
+# each grid cell.
+# COPYRIGHT: (c) 2013 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Creates a raster map containing the convergence angle at each grid cell.
+#% keywords: raster, projection
+#%End
+#%option
+#% key: output
+#% gisprompt: new,cell,raster
+#% type: string
+#% description: Output raster map
+#% required : no
+#%end
+#%flag
+#% key: m
+#% description: Also create u,v multiplier maps
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
+ g.message -e "Unable to create temporary files"
+ exit 1
+fi
+#GRASS_VERBOSE=0; export GRASS_VERBOSE
+TMPMAP="tmp.rconvrg.$$"
+r.mapcalc "$TMPMAP = 0"
+r.out.xyz "$TMPMAP" fs=tab | cut -f1,2 > "$TEMPFILE.xyz"
+m.proj -od in="$TEMPFILE.xyz" | cut -f1 -d' ' | \
+ proj -V `g.proj -jf` | grep Convergence | awk '{print $4}' \
+ > "$TEMPFILE.cnv"
+paste "$TEMPFILE.xyz" "$TEMPFILE.cnv" > "$TEMPFILE"
+r.in.xyz in="$TEMPFILE" out="$GIS_OPT_OUTPUT" fs=tab
+# cleanup
+rm "$TEMPFILE" "$TEMPFILE.xyz" "$TEMPFILE.cnv"
+g.remove rast="$TMPMAP"
+if [ "$GIS_FLAG_M" -eq 1 ] ; then
+ r.mapcalc "$GIS_OPT_OUTPUT.sinalpha = sin($GIS_OPT_OUTPUT)"
+ r.mapcalc "$GIS_OPT_OUTPUT.cosalpha = cos($GIS_OPT_OUTPUT)"
+fi
+# rotate u,v relative to grid north to be relative to true north
+#r.mapcalc "u_earth = sin(rot)*v_grid + cos(rot)*u_grid"
+#r.mapcalc "v_earth = cos(rot)*v_grid - sin(rot)*u_grid"
Property changes on: grass-addons/grass6/raster/r.convergence_angle/r.convergence_angle
___________________________________________________________________
Added: svn:executable
