[GRASS-SVN] r58538 - grass/branches/develbranch_6/vector/v.extract
svn_grass at osgeo.org
Fri Dec 27 08:50:39 PST 2013
Author: neteler
Date: 2013-12-27 08:50:39 -0800 (Fri, 27 Dec 2013)
New Revision: 58538
grass/branches/develbranch_6/vector/v.extract/description.html
Milena Nowotarska: update examples to NC dataset
Modified: grass/branches/develbranch_6/vector/v.extract/description.html
--- grass/branches/develbranch_6/vector/v.extract/description.html 2013-12-27 16:45:42 UTC (rev 58537)
+++ grass/branches/develbranch_6/vector/v.extract/description.html 2013-12-27 16:50:39 UTC (rev 58538)
@@ -21,9 +21,11 @@
<h2>EXAMPLES</h2>
+The examples are intended for the North Carolina sample dataset:
<h3>Extract areas by category number with dissolving #1:</h3>
<div class="code"><pre>
-v.extract -d list=1,2,3,4 input=soils output=soil_groupa type=area new=0
+v.extract -d list=1,2,3,4 input=soils_wake output=soil_groupa type=area new=0
</pre></div>
<p>
@@ -33,7 +35,7 @@
<h3>Extract areas by category number with dissolving #2:</h3>
-v.extract -d list=1-4 input=soils output=soil_groupa type=area new=-1
+v.extract -d list=1-4 input=soils_wake output=soil_groupa type=area new=-1
</pre></div>
<p>
produces a new vector map <b>soil_groupa</b> containing the areas from vector
@@ -43,7 +45,7 @@
<h3>Extract all areas and assign the same category to all:</h3>
-v.extract input=soils output=soil_groupa type=area new=1
+v.extract input=soils_wake output=soil_groupa type=area new=1
</pre></div>
<p>
@@ -62,46 +64,46 @@
<h3>Extract vector features which have the given field empty:</h3>
-v.extract input=forest output=forest_gaps where="CANOPY is NULL"
+v.extract input=lakes output=lakes_gaps where="FTYPE is NULL"
</pre></div>
<h3>Extract vector features which have the given field not empty:</h3>
-v.extract input=forest output=forest_canopy where="CANOPY not NULL"
+v.extract input=lakes output=lakes_ftype where="FTYPE not NULL"
</pre></div>
<h3>Reverse extracting (behaves like selective vector objects deleting):</h3>
-Remove unreferenced stations from the GlobalSOD database:
+Remove meteorological stations from map which are located above 1000m:
# check what to delete:
-v.db.select gsod_stationlist where="latitude < -91"
+v.db.select precip_30ynormals where="elev > 1000"
# perform reverse selection
-v.extract -r gsod_stationlist out=gsod_stationlist_clean where="latitude < -91"
+v.extract -r precip_30ynormals out=precip_30ynormals_lowland where="elev > 1000"
-v.db.select gsod_stationlist_clean
+# verify
+v.db.select precip_30ynormals_lowland
</pre></div>
<h3>Dissolving based on column attributes:</h3>
# check column names:
-v.info -c polbnda_italy
+v.info -c zipcodes_wake
# reclass based on desired column:
-v.reclass polbnda_italy out=polbnda_italy_recl_nam col=vmap_nam
+v.reclass zipcodes_wake out=zipcodes_wake_recl_nam col=ZIPNAME
# verify:
-v.info -c polbnda_italy_recl_nam
-v.db.select polbnda_italy_recl_nam
+v.info -c zipcodes_wake_recl_nam
+v.db.select zipcodes_wake_recl_nam
# dissolve:
-v.extract -d polbnda_italy_recl_nam out=pol_italy_regions
+v.extract -d zipcodes_wake_recl_nam out=zipcodes_wake_regions
</pre></div>
<p>
-produces a new vector map with common boundaries dissolved where the reclassed
+This produces a new vector map with common boundaries dissolved where the reclassed
attributes of adjacent (left/right) areas are identical.
<h3>Remove islands from polygon map</h3>
@@ -116,7 +118,7 @@
v.extract input=geology output=random_geology type=area random=3
</pre></div>
-will create new map with three random categories matching areas.
+This creates a new map with three random categories matching areas.
Note that there may be more than one feature with the same category.
<h2>SEE ALSO</h2>
