[GRASS-SVN] r58549 - in grass/trunk: display/d.vect lib/vector/vedit
svn_grass at osgeo.org
Sun Dec 29 14:30:51 PST 2013
Author: neteler
Date: 2013-12-29 14:30:51 -0800 (Sun, 29 Dec 2013)
New Revision: 58549
grass/trunk/display/d.vect/main.c
grass/trunk/display/d.vect/vert.c
grass/trunk/lib/vector/vedit/vertex.c
typo verteces -> vertices
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2013-12-29 21:47:32 UTC (rev 58548)
+++ grass/trunk/display/d.vect/main.c 2013-12-29 22:30:51 UTC (rev 58549)
@@ -94,7 +94,7 @@
_("Display geometry of features"),
_("Display category numbers of features"),
_("Display topology information (nodes, edges)"),
- _("Display verteces of features"),
+ _("Display vertices of features"),
_("Display direction of linear features"),
_("Display z-coordinate of features (only for 3D vector maps)"));
display_opt->descriptions = desc;
Modified: grass/trunk/display/d.vect/vert.c
--- grass/trunk/display/d.vect/vert.c 2013-12-29 21:47:32 UTC (rev 58548)
+++ grass/trunk/display/d.vect/vert.c 2013-12-29 22:30:51 UTC (rev 58549)
@@ -13,7 +13,7 @@
msize = dsize * (D_d_to_u_col(2.0) - D_d_to_u_col(1.0)); /* do it better */
- G_debug(1, "display verteces:");
+ G_debug(1, "display vertices:");
Points = Vect_new_line_struct();
D_RGB_color(lattr->color.R, lattr->color.G, lattr->color.B);
Modified: grass/trunk/lib/vector/vedit/vertex.c
--- grass/trunk/lib/vector/vedit/vertex.c 2013-12-29 21:47:32 UTC (rev 58548)
+++ grass/trunk/lib/vector/vedit/vertex.c 2013-12-29 22:30:51 UTC (rev 58549)
@@ -27,7 +27,7 @@
\param move_first move only first vertex found in the bounding box
\param snap snapping mode (see vedit.h)
- \return number of moved verteces
+ \return number of moved vertices
\return -1 on error
int Vedit_move_vertex(struct Map_info *Map, struct Map_info **BgMap,
@@ -188,7 +188,7 @@
\param coord points location
\param thresh find line in given threshold
- \return number of add verteces
+ \return number of add vertices
\return -1 on error
int Vedit_add_vertex(struct Map_info *Map, struct ilist *List,
