[GRASS-SVN] r58552 - grass/trunk/raster/r.horizon
svn_grass at osgeo.org
Sun Dec 29 15:43:08 PST 2013
Author: neteler
Date: 2013-12-29 15:43:08 -0800 (Sun, 29 Dec 2013)
New Revision: 58552
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.horizon/r.horizon.html
r.horizon: added output parameter (CSV file) for single point mode
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2013-12-29 23:18:13 UTC (rev 58551)
+++ grass/trunk/raster/r.horizon/main.c 2013-12-29 23:43:08 UTC (rev 58552)
@@ -56,7 +56,7 @@
#define DISTANCE1(x1, x2, y1, y2) (sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2)))
-FILE *fw;
+FILE *fp;
const double pihalf = M_PI * 0.5;
const double twopi = M_PI * 2.;
@@ -70,6 +70,7 @@
const char *mapset = NULL;
const char *per;
char shad_filename[GNAME_MAX];
+char *outfile;
struct Cell_head cellhd;
struct Key_value *in_proj_info, *in_unit_info;
@@ -163,7 +164,7 @@
struct
struct Option *elevin, *dist, *coord, *direction, *horizon, *step,
- *bufferzone, *e_buff, *w_buff, *n_buff, *s_buff, *maxdistance;
+ *bufferzone, *e_buff, *w_buff, *n_buff, *s_buff, *maxdistance, *output;
} parm;
struct
@@ -289,6 +290,11 @@
parm.dist->description = _("Sampling distance step coefficient (0.5-1.5)");
parm.dist->guisection = _("Output options");
+ parm.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ parm.output->required = NO;
+ parm.output->answer = "-";
+ parm.output->description =
+ _("Name of file for output (use output=- for stdout)");
flag.degreeOutput = G_define_flag();
flag.degreeOutput->key = 'd';
@@ -350,6 +356,15 @@
xcoord = (int) ((xcoord-xmin)/stepx);
ycoord = (int) ((ycoord-ymin)/stepy);
+ /* Open ASCII file for output or stdout */
+ outfile = parm.output->answer;
+ if ((strcmp("-", outfile)) == 0) {
+ fp = stdout;
+ else if (NULL == (fp = fopen(outfile, "w")))
+ G_fatal_error(_("Unable to open file <%s>"), outfile);
if (parm.direction->answer != NULL)
@@ -765,8 +780,8 @@
angle = (single_direction * deg2rad) + pihalf;
maxlength = fixedMaxLength;
+ fprintf(fp, "azimuth,horizon_height\n");
for (i = 0; i < printCount; i++) {
@@ -814,10 +829,8 @@
stepsinangle = stepxy * delt_nor / delt_dist;
stepcosangle = stepxy * delt_east / delt_dist;
shadow_angle = horizon_height();
if (degreeOutput) {
shadow_angle *= rad2deg;
@@ -827,7 +840,7 @@
else if (printangle >= 360.)
printangle -= 360;
- G_message("%lf,%lf", printangle, shadow_angle);
+ fprintf(fp, "%lf,%lf\n", printangle, shadow_angle);
angle += dfr_rad;
@@ -1060,6 +1073,7 @@
z_orig = zp = z[yindex][xindex];
calculate_shadow();
+ fclose(fp);
else {
Modified: grass/trunk/raster/r.horizon/r.horizon.html
--- grass/trunk/raster/r.horizon/r.horizon.html 2013-12-29 23:18:13 UTC (rev 58551)
+++ grass/trunk/raster/r.horizon/r.horizon.html 2013-12-29 23:43:08 UTC (rev 58552)
@@ -93,6 +93,9 @@
upwards from 0 to total number of directions. If you use <b>r.horizon</b>
in the single point mode this option will be ignored.
+<p>The <i>output</i> parameter allows to save the resulting horizon
+angles in a comma separated ASCII file (single point mode only). If
+you use <b>r.horizon</b> in the raster mode this option will be ignored.
<p>At the moment the elevation and maximum distance must be measured in meters,
even if you use geographical coordinates (longitude/latitude). If your
@@ -119,7 +122,6 @@
cardinal directions caused by the projection (see above).
<h2>EXAMPLES</h2>
The examples are intended for the North Carolina sample dataset:
@@ -131,8 +133,9 @@
coordinate=638871.6,223384.4 maxdistance=5000
# determine horizon values starting at 90 deg (North), step size of 5 deg:
+# save result in CSV file
r.horizon elev_in=elevation direction=90 horizon_step=5 bufferzone=200 \
- coordinate=638871.6,223384.4 maxdistance=5000
+ coordinate=638871.6,223384.4 maxdistance=5000 output=horizon.csv
</pre></div>
