[GRASS-SVN] r58569 - in grass-addons/grass7/raster: . r.hypso
svn_grass at osgeo.org
Tue Dec 31 11:12:49 PST 2013
Author: madi
Date: 2013-12-31 11:12:49 -0800 (Tue, 31 Dec 2013)
New Revision: 58569
Added:
grass-addons/grass7/raster/r.hypso/
grass-addons/grass7/raster/r.hypso/Makefile
grass-addons/grass7/raster/r.hypso/r.hypso
grass-addons/grass7/raster/r.hypso/r.hypso.html
replacing r.ipso
Added: grass-addons/grass7/raster/r.hypso/Makefile
--- grass-addons/grass7/raster/r.hypso/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.hypso/Makefile 2013-12-31 19:12:49 UTC (rev 58569)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.hypso
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.hypso/r.hypso
--- grass-addons/grass7/raster/r.hypso/r.hypso (rev 0)
+++ grass-addons/grass7/raster/r.hypso/r.hypso 2013-12-31 19:12:49 UTC (rev 58569)
@@ -0,0 +1,140 @@
+#!/usr/bin/env python
+# MODULE: r.ipso.py
+# AUTHOR(S): Margherita Di Leo, Massimo Di Stefano, Francesco Di Stefano
+# PURPOSE: Output a Ipsometric and ipsographic graph
+# COPYRIGHT: (c) 2010 Margherita Di Leo, Massimo Di Stefano, Francesco Di Stefano
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# REQUIRES: Matplotlib
+# http://matplotlib.sourceforge.net/
+#%module
+#% description: Outputs a ipsometric and ipsographic graph.
+#% keywords: raster
+#%end
+#%option G_OPT_R_ELEV
+#% key: map
+#% required: yes
+#%end
+#%option G_OPT_F_OUTPUT
+#% key: image
+#% key_desc: image
+#% description: Name for output graph file (png)
+#% required: yes
+#%end
+#%flag
+#% key: a
+#% description: Generate ipsometric curve
+#%end
+#%flag
+#% key: b
+#% description: Generate ipsographic curve
+#%end
+import sys
+import os
+import matplotlib #required by windows
+matplotlib.use('wx') #required by windows
+import matplotlib.pyplot as plt
+import grass.script as grass
+import numpy as np
+def main():
+ stats = grass.read_command('r.stats', input = options['map'], sep = 'space', nv = '*', nsteps = '255', flags = 'inc').split('\n')[:-1]
+ # res = cellsize
+ res = float(grass.read_command('g.region', rast = options['map'], flags = 'm').strip().split('\n')[4].split('=')[1])
+ zn = np.zeros((len(stats),6),float)
+ kl = np.zeros((len(stats),2),float)
+ prc = np.zeros((9,2),float)
+ for i in range(len(stats)):
+ if i == 0:
+ zn[i,0], zn[i, 1] = map(float, stats[i].split(' '))
+ zn[i,2] = zn[i,1]
+ else:
+ zn[i,2] = zn[i,1] + zn[i-1,2]
+ totcell = sum(zn[:,1])
+ print "Tot. cells", totcell
+ zn[i,3] = 1 - (zn[i,2] / sum(zn[:,1]))
+ zn[i,4] = zn[i,3] * (((res**2)/1000000)*sum(zn[:,1]))
+ zn[i,5] = ((zn[i,0] - min(zn[:,0])) / (max(zn[:,0]) - min(zn[:,0])) )
+ kl[i,0] = zn[i,0]
+ kl[i,1] = 1 - (zn[i,2] / totcell)
+ # quantiles
+ prc[0,0] , prc[0,1] = findint(kl,0.025) , 0.025
+ prc[1,0] , prc[1,1] = findint(kl,0.05) , 0.05
+ prc[2,0] , prc[2,1] = findint(kl,0.1) , 0.1
+ prc[3,0] , prc[3,1] = findint(kl,0.25) , 0.25
+ prc[4,0] , prc[4,1] = findint(kl,0.5) , 0.5
+ prc[5,0] , prc[5,1] = findint(kl,0.75) , 0.75
+ prc[6,0] , prc[6,1] = findint(kl,0.9) , 0.9
+ prc[7,0] , prc[7,1] = findint(kl,0.95) , 0.95
+ prc[8,0] , prc[8,1] = findint(kl,0.975) , 0.975
+ # Managing flag & plot
+ if flags['a']:
+ plotImage(zn[:,3], zn[:,5],options['image']+'_Ipsometric.png','-','A(i) / A','Z(i) / Zmax','Ipsometric Curve')
+ if flags['b']:
+ plotImage(zn[:,4], zn[:,0],options['image']+'_Ipsographic.png','-','A [km^2]','Z [m.slm]','Ipsographic Curve')
+ print "==========================="
+ print "Ipsometric | quantiles"
+ print '%.0f' %findint(kl,0.025) , "|", 0.025
+ print '%.0f' %findint(kl,0.05) , "|", 0.05
+ print '%.0f' %findint(kl,0.1) , "|", 0.1
+ print '%.0f' %findint(kl,0.25) , "|", 0.25
+ print '%.0f' %findint(kl,0.5) , "|", 0.5
+ print '%.0f' %findint(kl,0.75) , "|", 0.75
+ print '%.0f' %findint(kl,0.7) , "|", 0.7
+ print '%.0f' %findint(kl,0.9) , "|", 0.9
+ print '%.0f' %findint(kl,0.975) , "|", 0.975
+ print '\n'
+ print 'Done!'
+ #print prc
+def findint(kl,f):
+ Xf = np.abs(kl-f); Xf = np.where(Xf==Xf.min())
+ z1 , z2 , f1 , f2 = kl[float(Xf[0])][0] , kl[float(Xf[0]-1)][0] , kl[float(Xf[0])][1] , kl[float(Xf[0]-1)][1]
+ z = z1 + ((z2 - z1) / (f2 - f1)) * (f - f1)
+ return z
+def plotImage(x,y,image,type,xlabel,ylabel,title):
+ plt.plot(x, y, type)
+ plt.ylabel(ylabel)
+ plt.xlabel(xlabel)
+ plt.xlim( min(x), max(x) )
+ plt.ylim( min(y), max(y) )
+ plt.title(title)
+ plt.grid(True)
+ plt.savefig(image)
+ plt.close('all')
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.hypso/r.hypso
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/raster/r.hypso/r.hypso.html
--- grass-addons/grass7/raster/r.hypso/r.hypso.html (rev 0)
+++ grass-addons/grass7/raster/r.hypso/r.hypso.html 2013-12-31 19:12:49 UTC (rev 58569)
@@ -0,0 +1,55 @@
+<h2>DESCRIPTION</h2>
+<em>r.hypso</em> produces the hypsometric and hypsographic curve
+related to a digital elevation model and prints the percentiles.
+<h2>NOTES</h2>
+The <em>hypsographic curve</em> gives the distribution of surfaces in
+different altitude ranges. Each point on the function reports on the
+y-axis the elevation and on the x-axis the portion of the basin
+surface placed above such elevation value. The <em>hypsometric curve
+</em> uses adimensional axes.
+<h2>Flags:</h2>
+<p>-a: generates hypsometric curve
+<p>-b: generates hyposographic curve
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+r.hypso.py -b map=elevation.10m image=path/to/output/prefix
+</pre></div>
+generates hypsographic curve, and
+r.hypso.py -a map=elevation.10m image=path/to/output/prefix
+</pre></div>
+generates hypsometric curve.
+<h3>Dependencies</h3>
+<ul>
+<li>Matplotlib</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.basin.html">r.basin</a>,
+</em>
+<h2>REFERENCES</h2>
+<p><em>Rodriguez-Iturbe I., Rinaldo A. — Fractal River Basins,
+Chance and Self-Organization. Cambridge Press (2001)</em>
+<p><em>In Italian: Di Leo M., Di Stefano M., Claps P., Sole A.
+— Caratterizzazione morfometrica del bacino idrografico in
+GRASS GIS (Morphometric characterization of the catchment in GRASS
+GIS environment), <a href="http://geomatica.como.polimi.it/workbooks/">Geomatics Workbooks</a>,
+n. 9 (2010)</em>
+<h2>AUTHORS</h2>
+<p>Margherita Di Leo (dileomargherita AT gmail DOT com), Massimo Di Stefano, Francesco Di Stefano
+<p>
+<i>Last changed: $Date: 2013-07-13 16:20:35 +0200 (Sat, 13 Jul 2013) $</i>
