[GRASS-SVN] r58571 - grass-addons/grass7/raster/r.basin
svn_grass at osgeo.org
Tue Dec 31 11:29:48 PST 2013
Author: madi
Date: 2013-12-31 11:29:48 -0800 (Tue, 31 Dec 2013)
New Revision: 58571
grass-addons/grass7/raster/r.basin/r.basin.html
grass-addons/grass7/raster/r.basin/r.basin.py
fixed bug generated by recent changes in r.volume; added G_OPT_M_COORDS; added option to set directory for output
Modified: grass-addons/grass7/raster/r.basin/r.basin.html
--- grass-addons/grass7/raster/r.basin/r.basin.html 2013-12-31 19:17:53 UTC (rev 58570)
+++ grass-addons/grass7/raster/r.basin/r.basin.html 2013-12-31 19:29:48 UTC (rev 58571)
@@ -100,9 +100,15 @@
different altitudes. Each point on the hypsographic curve has on the
y-axis the altitude and on the x-axis the percentage of basin
surface placed above that altitude.</li>
-<li>The ipsometric curve has the same shape but is dimensionless.</li>
-</ul>
+<li>The hypsometric curve has the same shape but is dimensionless.</li>
+</ul>
+<h3>Example</h3>
+<ul>
+r.basin map=elevation prefix=prefix coordinates=east,north threshold=th
+input=path/to/directory
+</ul>
<h3>Dependencies</h3>
<ul>
<li>Matplotlib</li>
@@ -111,8 +117,8 @@
<li>r.stream.stats</li>
<li>r.stream.distance</li>
<li>r.stream.order</li>
-<li>r.wf</li>
-<li>r.ipso</li>
+<li>r.width.funct</li>
+<li>r.hypso</li>
</ul>
<h2>SEE ALSO</h2>
@@ -123,8 +129,8 @@
<a href="r.stream.extract.html">r.stream.extract</a>,
<a href="r.stream.order.html">r.stream.order</a>,
<a href="r.stream.stats.html">r.stream.stats</a>,
-<a href="r.wf.html">r.wf</a>,
-<a href="r.ipso.html">r.ipso</a>,
+<a href="r.width.funct.html">r.width.funct</a>,
+<a href="r.hypso.html">r.hypso</a>,
<a href="r.watershed.html">r.watershed</a>
</em>
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py 2013-12-31 19:17:53 UTC (rev 58570)
+++ grass-addons/grass7/raster/r.basin/r.basin.py 2013-12-31 19:29:48 UTC (rev 58571)
@@ -20,11 +20,8 @@
#% keywords: raster
#%end
-#%option
+#%option G_OPT_R_ELEV
#% key: map
-#% type: string
-#% gisprompt: old,raster,raster
-#% key_desc: name
#% description: Name of elevation raster map
#% required: yes
#%end
@@ -37,19 +34,13 @@
#% required: yes
#%end
-#%option
-#% key: easting
-#% type: double
-#% key_desc: easting
-#% description: east coordinate of outlet point (must belong to river network)
+#%option G_OPT_M_COORDS
+#% description: coordinates of the outlet (east,north)
#% required : yes
#%end
-#%option
-#% key: northing
-#% type: double
-#% key_desc: northing
-#% description: north coordinate of outlet point (must belong to river network)
+#%option G_OPT_M_DIR
+#% description: Directory where the output will be found
#% required : yes
#%end
@@ -88,8 +79,8 @@
mapname = options['map'].replace("@"," ")
mapname = mapname.split()
mapname[0] = mapname[0].replace(".","_")
- east = float(options['easting'])
- north = float(options['northing'])
+ coordinates = options['coordinates']
+ directory = options['input']
autothreshold = flags['a']
nomap = flags['c']
prefix = options['prefix']+'_'+mapname[0]
@@ -125,6 +116,8 @@
v_ord_1 = prefix+'_ord_1'
global tmp
+ print directory
# Save current region
grass.read_command('g.region', flags = 'p', save = 'original', overwrite = True)
@@ -175,7 +168,7 @@
grass.run_command('r.stream.basins', dir = r_drainage,
basins = r_basin,
- coors = '%s,%s' % (east , north),
+ coors = '%s' % (coordinates),
overwrite = True)
grass.message( "Delineation of basin done" )
@@ -300,7 +293,8 @@
# Distance to outlet
grass.write_command('v.in.ascii', output = v_outlet,
input = "-",
- stdin = "%s|%s|9999" % (east, north),
+ sep = ",",
+ stdin = "%s,9999" % (coordinates),
overwrite = True)
grass.run_command('v.to.rast', input = v_outlet,
@@ -328,13 +322,13 @@
grass.message( "##################################" )
- #### check if we have the r.ipso addon
- if not grass.find_program('r.ipso', '--help'):
- grass.fatal(_("The 'r.ipso' module was not found, install it first:") +
+ #### check if we have the r.hypso addon
+ if not grass.find_program('r.hypso', '--help'):
+ grass.fatal(_("The 'r.hypso' module was not found, install it first:") +
"\n" +
- "g.extension r.ipso")
- grass.run_command('r.ipso', map = 'r_elevation_crop',
- image = prefix, flags = 'ab')
+ "g.extension r.hypso")
+ grass.run_command('r.hypso', map = 'r_elevation_crop',
+ image = os.path.join(directory,prefix), flags = 'ab')
@@ -342,13 +336,13 @@
- #### check if we have the r.wf addon
- if not grass.find_program('r.wf', '--help'):
- grass.fatal(_("The 'r.wf' module was not found, install it first:") +
+ #### check if we have the r.width.funct addon
+ if not grass.find_program('r.width.funct', '--help'):
+ grass.fatal(_("The 'r.width.funct' module was not found, install it first:") +
"\n" +
- "g.extension r.wf")
- grass.run_command('r.wf', map = r_distance,
- image = prefix)
+ "g.extension r.width.funct")
+ grass.run_command('r.width.funct', map = r_distance,
+ image = os.path.join(directory,prefix))
@@ -390,14 +384,19 @@
clump = r_basin,
centroids = v_centroid1,
overwrite = True)
+ print baricenter_slope_baricenter
grass.message("r.volume done")
baricenter_slope_baricenter = baricenter_slope_baricenter.split()
- mean_slope = baricenter_slope_baricenter[28]
+ mean_slope = baricenter_slope_baricenter[30]
+ print "mean_slope", mean_slope
# Rectangle containing basin
- basin_east = baricenter_slope_baricenter[31]
- basin_north = baricenter_slope_baricenter[32]
+ basin_east = baricenter_slope_baricenter[33]
+ print "basin east", basin_east
+ basin_north = baricenter_slope_baricenter[34]
+ print "basin north", basin_north
info_region_basin = grass.read_command("g.region",
vect = options['prefix']+'_'+mapname[0]+'_basin',
flags = 'm')
@@ -412,10 +411,23 @@
nw = dict_region_basin['w'], dict_region_basin['n']
se = dict_region_basin['e'], dict_region_basin['s']
grass.message("Rectangle containing basin done")
+ try:
+ print coordinates
+ east1,north1 = coordinates.split(',')
+ east = float(east1)
+ north = float(north1)
+ print east
+ print north
+ except:
+ print "error"
# Directing vector
delta_x = abs(float(basin_east) - east)
+ print delta_x
delta_y = abs(float(basin_north) - north)
+ print delta_y
L_orienting_vect = math.sqrt((delta_x**2)+(delta_y**2)) / 1000
grass.message("Directing vector done")
@@ -653,8 +665,11 @@
parametri_bacino["drainage_density"] = float(drainage_density)
parametri_bacino["FSF"] = float(FSF)
+ namefile = prefix + '_parameters.csv'
+ print namefile
# create .csv file
- with open(prefix+'_parameters.csv', 'w') as f:
+ with open(os.path.join( directory, prefix + '_parameters.csv'), 'w') as f:
writer = csv.writer(f)
writer.writerow(['Morphometric parameters of basin :'])
writer.writerow([' '])
