[GRASS-SVN] r54838 - in grass/trunk/gui/wxpython: . gmodeler gui_core iclass mapswipe
svn_grass at osgeo.org
Sat Feb 2 07:33:25 PST 2013
Author: annakrat
Date: 2013-02-02 07:33:25 -0800 (Sat, 02 Feb 2013)
New Revision: 54838
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/iclass/dialogs.py
grass/trunk/gui/wxpython/mapswipe/dialogs.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI: refactor ElementDialog; include validator
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2013-02-02 15:33:25 UTC (rev 54838)
@@ -32,34 +32,37 @@
from core import globalvar
from core import utils
from core.modulesdata import ModulesData
-from gui_core.widgets import SearchModuleWidget, EVT_MODULE_SELECTED
+from gui_core.widgets import SearchModuleWidget, EVT_MODULE_SELECTED, SimpleValidator
from core.gcmd import GError, EncodeString
-from gui_core.dialogs import ElementDialog, MapLayersDialogForModeler
+from gui_core.dialogs import SimpleDialog, MapLayersDialogForModeler
from gui_core.prompt import GPromptSTC, EVT_GPROMPT_RUN_CMD
from gui_core.forms import CmdPanel
-from gui_core.gselect import Select
+from gui_core.gselect import Select, ElementSelect
from gmodeler.model import *
from grass.script import task as gtask
-class ModelDataDialog(ElementDialog):
+class ModelDataDialog(SimpleDialog):
"""!Data item properties dialog"""
- def __init__(self, parent, shape, id = wx.ID_ANY, title = _("Data properties"),
- style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ def __init__(self, parent, shape, title = _("Data properties")):
self.parent = parent
self.shape = shape
label, etype = self._getLabel()
- ElementDialog.__init__(self, parent, title, label = label, etype = etype)
+ self.etype = etype
+ SimpleDialog.__init__(self, parent, title)
- self.element = Select(parent = self.panel)
+ self.element = Select(parent = self.panel,
+ validator = SimpleValidator(callback = self.ValidatorCallback))
self.element.SetValue(shape.GetValue())
self.Bind(wx.EVT_BUTTON, self.OnOK, self.btnOK)
self.Bind(wx.EVT_BUTTON, self.OnCancel, self.btnCancel)
+ if self.etype:
+ self.typeSelect = ElementSelect(parent = self.panel,
+ size = globalvar.DIALOG_GSELECT_SIZE)
+ self.typeSelect.Bind(wx.EVT_CHOICE, self.OnType)
- self.PostInit()
if shape.GetValue():
self.btnOK.Enable()
@@ -81,15 +84,35 @@
def _layout(self):
"""!Do layout"""
+ if self.etype:
+ self.dataSizer.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+ label = _("Type of element:")),
+ proportion = 0, flag = wx.ALL, border = 1)
+ self.dataSizer.Add(item = self.typeSelect,
+ label = _("Name of element:")),
self.dataSizer.Add(self.element, proportion=0,
flag=wx.EXPAND | wx.ALL, border=1)
self.panel.SetSizer(self.sizer)
self.sizer.Fit(self)
+ def GetType(self):
+ """!Get element type"""
+ if not self.etype:
+ return
+ return self.element.tcp.GetType()
+ def OnType(self, event):
+ """!Select element type"""
+ evalue = self.typeSelect.GetValue(event.GetString())
+ self.element.SetType(evalue)
def OnOK(self, event):
"""!Ok pressed"""
- self.shape.SetValue(self.GetElement())
+ self.shape.SetValue(self.element.GetValue())
if self.etype:
elem = self.GetType()
if elem == 'rast':
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-02-02 15:33:25 UTC (rev 54838)
@@ -4,7 +4,7 @@
@brief Various dialogs used in wxGUI.
List of classes:
- - dialogs::ElementDialog
+ - dialogs::SimpleDialog
- dialogs::LocationDialog
- dialogs::MapsetDialog
- dialogs::NewVectorDialog
@@ -47,9 +47,9 @@
from core.gcmd import GError, RunCommand, GMessage
-from gui_core.gselect import ElementSelect, LocationSelect, MapsetSelect, Select, OgrTypeSelect, GdalSelect, MapsetSelect
+from gui_core.gselect import LocationSelect, MapsetSelect, Select, OgrTypeSelect, GdalSelect, MapsetSelect
from gui_core.forms import GUI
-from gui_core.widgets import SingleSymbolPanel, EVT_SYMBOL_SELECTION_CHANGED, GListCtrl
+from gui_core.widgets import SingleSymbolPanel, EVT_SYMBOL_SELECTION_CHANGED, GListCtrl, SimpleValidator
from core.utils import GetLayerNameFromCmd, GetValidLayerName
from core.settings import UserSettings, GetDisplayVectSettings
from core.debug import Debug
@@ -57,74 +57,32 @@
wxApplyMapLayers, EVT_APPLY_MAP_LAYERS = NewEvent()
wxApplyOpacity, EVT_APPLY_OPACITY = NewEvent()
-class ElementDialog(wx.Dialog):
- def __init__(self, parent, title, label, id = wx.ID_ANY,
- etype = False, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+class SimpleDialog(wx.Dialog):
+ def __init__(self, parent, title, id = wx.ID_ANY,
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
**kwargs):
"""!General dialog to choose given element (location, mapset, vector map, etc.)
@param parent window
@param title window title
- @param label element label
- @param etype show also ElementSelect
wx.Dialog.__init__(self, parent, id, title, style = style, **kwargs)
- self.etype = etype
- self.label = label
+ self.SetExtraStyle(wx.WS_EX_VALIDATE_RECURSIVELY)
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
self.btnOK = wx.Button(parent = self.panel, id = wx.ID_OK)
self.btnOK.SetDefault()
- if self.etype:
- self.typeSelect = ElementSelect(parent = self.panel,
- size = globalvar.DIALOG_GSELECT_SIZE)
- self.typeSelect.Bind(wx.EVT_CHOICE, self.OnType)
- self.element = None # must be defined
self.__layout()
- def PostInit(self):
- self.element.SetFocus()
- self.element.Bind(wx.EVT_TEXT, self.OnElement)
- if not self.element.GetValue():
- self.btnOK.Disable()
- def OnType(self, event):
- """!Select element type"""
- if not self.etype:
- return
- evalue = self.typeSelect.GetValue(event.GetString())
- self.element.SetType(evalue)
- def OnElement(self, event):
- """!Name for vector map layer given"""
- if len(event.GetString()) > 0:
- self.btnOK.Enable(True)
- else:
- self.btnOK.Enable(False)
+ self.warning = _("Required item is not set.")
def __layout(self):
"""!Do layout"""
self.sizer = wx.BoxSizer(wx.VERTICAL)
self.dataSizer = wx.BoxSizer(wx.VERTICAL)
- if self.etype:
- self.dataSizer.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = _("Type of element:")),
- proportion = 0, flag = wx.ALL, border = 1)
- self.dataSizer.Add(item = self.typeSelect,
- label = self.label),
+ # self.informLabel = wx.StaticText(self.panel, id = wx.ID_ANY)
# buttons
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(self.btnCancel)
@@ -134,119 +92,119 @@
self.sizer.Add(item = self.dataSizer, proportion = 1,
flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
+ # self.sizer.Add(item = self.informLabel, proportion = 0, flag = wx.ALL, border = 5)
self.sizer.Add(item = btnSizer, proportion = 0,
- def GetElement(self):
- """!Return (mapName, overwrite)"""
- return self.element.GetValue()
- def GetType(self):
- """!Get element type"""
- return self.element.tcp.GetType()
-class LocationDialog(ElementDialog):
+ def ValidatorCallback(self, win):
+ GMessage(parent = self, message = self.warning)
+ # self.informLabel.SetForegroundColour(wx.Color(255, 0, 0))
+ # self.informLabel.SetLabel(self.warning)
+class LocationDialog(SimpleDialog):
"""!Dialog used to select location"""
- def __init__(self, parent, title = _("Select GRASS location and mapset"), id = wx.ID_ANY):
- ElementDialog.__init__(self, parent, title, label = _("Name of GRASS location:"))
+ def __init__(self, parent, title = _("Select GRASS location and mapset")):
- self.element = LocationSelect(parent = self.panel, id = wx.ID_ANY,
- self.element1 = MapsetSelect(parent = self.panel, id = wx.ID_ANY,
+ self.element1 = LocationSelect(parent = self.panel, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ self.element1.Bind(wx.EVT_TEXT, self.OnLocation)
+ self.element2 = MapsetSelect(parent = self.panel, id = wx.ID_ANY,
- setItems = False, skipCurrent = True)
- self.PostInit()
+ setItems = False, skipCurrent = True,
+ self.element1.SetFocus()
+ self.warning = _("Location or mapset is missing.")
self._layout()
self.SetMinSize(self.GetSize())
def _layout(self):
"""!Do layout"""
- self.dataSizer.Add(self.element, proportion = 0,
+ label = _("Name of GRASS location:")),
+ self.dataSizer.Add(self.element1, proportion = 0,
flag = wx.EXPAND | wx.ALL, border = 1)
self.dataSizer.Add(wx.StaticText(parent = self.panel, id = wx.ID_ANY,
label = _("Name of mapset:")), proportion = 0,
- self.dataSizer.Add(self.element1, proportion = 0,
+ self.dataSizer.Add(self.element2, proportion = 0,
+ def OnLocation(self, event):
"""!Select mapset given location name"""
location = event.GetString()
if location:
dbase = grass.gisenv()['GISDBASE']
- self.element1.UpdateItems(dbase = dbase, location = location)
- self.element1.SetSelection(0)
- mapset = self.element1.GetStringSelection()
- if location and mapset:
- else:
+ self.element2.UpdateItems(dbase = dbase, location = location)
+ self.element2.SetSelection(0)
+ mapset = self.element2.GetStringSelection()
def GetValues(self):
"""!Get location, mapset"""
- return (self.GetElement(), self.element1.GetStringSelection())
+ return (self.element1.GetValue(), self.element2.GetValue())
-class MapsetDialog(ElementDialog):
+class MapsetDialog(SimpleDialog):
"""!Dialog used to select mapset"""
def __init__(self, parent, title = _("Select mapset in GRASS location"),
- location = None, id = wx.ID_ANY):
- ElementDialog.__init__(self, parent, title, label = _("Name of mapset:"))
+ location = None):
if location:
self.SetTitle(self.GetTitle() + ' <%s>' % location)
else:
self.SetTitle(self.GetTitle() + ' <%s>' % grass.gisenv()['LOCATION_NAME'])
self.element = MapsetSelect(parent = self.panel, id = wx.ID_ANY, skipCurrent = True,
- self.PostInit()
+ self.element.SetFocus()
+ self.warning = _("Name of mapset is missing.")
- self.__Layout()
+ self._layout()
- def __Layout(self):
+ def _layout(self):
"""!Do layout"""
+ label = _("Name of mapset:")),
- flag = wx.EXPAND | wx.ALL, border = 1)
+ flag = wx.EXPAND | wx.ALL, border = 1)
def GetMapset(self):
- return self.GetElement()
+ return self.element.GetValue()
-class NewVectorDialog(ElementDialog):
- def __init__(self, parent, id = wx.ID_ANY, title = _('Create new vector map'),
- disableAdd = False, disableTable = False, showType = False,
- style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, *kwargs):
+class NewVectorDialog(SimpleDialog):
+ def __init__(self, parent, title = _("Create new vector map"),
+ disableAdd = False, disableTable = False, showType = False):
"""!Dialog for creating new vector map
@param parent parent window
- @param id window id
@param disableAdd disable 'add layer' checkbox
@param disableTable disable 'create table' checkbox
@param showType True to show feature type selector (used for creating new empty OGR layers)
- @param style window style
- @param kwargs other argumentes for ElementDialog
- @return dialog instance
+ @return dialog instance
- ElementDialog.__init__(self, parent, title, label = _("Name for new vector map:"))
self.element = Select(parent = self.panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
- type = 'vector', mapsets = [grass.gisenv()['MAPSET'],])
+ type = 'vector', mapsets = [grass.gisenv()['MAPSET'],],
# determine output format
if showType:
self.ftype = OgrTypeSelect(parent = self, panel = self.panel)
@@ -278,21 +236,19 @@
self.table.Bind(wx.EVT_CHECKBOX, self.OnTable)
- self.PostInit()
+ self.warning = _("Name of new vector map is missing.")
self._layout()
- def OnMapName(self, event):
- self.OnElement(event)
def OnTable(self, event):
if self.keycol:
self.keycol.Enable(event.IsChecked())
def _layout(self):
"""!Do layout"""
+ label = _("Name for new vector map:")),
self.dataSizer.Add(item = self.element, proportion = 0,
if self.ftype:
@@ -327,7 +283,7 @@
@param full True to get fully qualified name
- name = self.GetElement()
+ name = self.element.GetValue()
if full:
if '@' in name:
return name
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2013-02-02 15:33:25 UTC (rev 54838)
@@ -68,7 +68,8 @@
def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
type = None, multiple = False, nmaps = 1,
mapsets = None, updateOnPopup = True, onPopup = None,
- fullyQualified = True, extraItems = {}):
+ fullyQualified = True, extraItems = {},
+ validator = wx.DefaultValidator):
"""!Custom control to create a ComboBox with a tree control to
display and select GIS elements within acessible mapsets.
Elements can be selected with mouse. Can allow multiple
@@ -83,8 +84,9 @@
@param onPopup function to be called on Popup
@param fullyQualified True to provide fully qualified names (map at mapset)
@param extraItems extra items to add (given as dictionary) - see gmodeler for usage
+ @param validator validator for TextCtrl
- wx.combo.ComboCtrl.__init__(self, parent=parent, id=id, size=size)
+ wx.combo.ComboCtrl.__init__(self, parent=parent, id=id, size=size, validator=validator)
self.GetChildren()[0].SetName("Select")
self.GetChildren()[0].type = type
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2013-02-02 15:33:25 UTC (rev 54838)
@@ -555,7 +555,52 @@
# Returning without calling even.Skip eats the event before it
# gets to the text control
return
+class SimpleValidator(wx.PyValidator):
+ """ This validator is used to ensure that the user has entered something
+ into the text object editor dialog's text field.
+ def __init__(self, callback):
+ """ Standard constructor.
+ wx.PyValidator.__init__(self)
+ self.callback = callback
+ def Clone(self):
+ """ Standard cloner.
+ Note that every validator must implement the Clone() method.
+ return SimpleValidator(self.callback)
+ def Validate(self, win):
+ """ Validate the contents of the given text control.
+ ctrl = self.GetWindow()
+ text = ctrl.GetValue()
+ if len(text) == 0:
+ self.callback(ctrl)
+ return False
+ else:
+ return True
+ def TransferToWindow(self):
+ """ Transfer data from validator to window.
+ The default implementation returns False, indicating that an error
+ occurred. We simply return True, as we don't do any data transfer.
+ return True # Prevent wxDialog from complaining.
+ def TransferFromWindow(self):
+ """ Transfer data from window to validator.
class ItemTree(CT.CustomTreeCtrl):
ctstyle = CT.TR_HIDE_ROOT | CT.TR_FULL_ROW_HIGHLIGHT | CT.TR_HAS_BUTTONS |
Modified: grass/trunk/gui/wxpython/iclass/dialogs.py
--- grass/trunk/gui/wxpython/iclass/dialogs.py 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/iclass/dialogs.py 2013-02-02 15:33:25 UTC (rev 54838)
@@ -28,13 +28,14 @@
from core.gcmd import GMessage
-from gui_core.dialogs import ElementDialog, GroupDialog
+from gui_core.dialogs import SimpleDialog, GroupDialog
from gui_core import gselect
+from gui_core.widgets import SimpleValidator
from iclass.statistics import Statistics, BandStatistics
import grass.script as grass
-class IClassGroupDialog(ElementDialog):
+class IClassGroupDialog(SimpleDialog):
"""!Dialog for imagery group selection"""
def __init__(self, parent, group = None, title = _("Select imagery group"), id = wx.ID_ANY):
@@ -44,23 +45,28 @@
@param title dialog window title
@param id wx id
- ElementDialog.__init__(self, parent, title, label = _("Name of imagery group:"))
self.element = gselect.Select(parent = self.panel, type = 'group',
- mapsets = [grass.gisenv()['MAPSET']],
+ mapsets = [grass.gisenv()['MAPSET']],
if group:
self.element.SetValue(group)
self.editGroup = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("Create/edit group..."))
self.editGroup.Bind(wx.EVT_BUTTON, self.OnEditGroup)
- self.PostInit()
- self.__Layout()
+ self.warning = _("Name of imagery group is missing.")
+ self._layout()
"""!Do layout"""
+ self.dataSizer.Add(wx.StaticText(self.panel, id = wx.ID_ANY,
+ label = _("Name of imagery group:")),
+ proportion = 0, flag = wx.EXPAND | wx.ALL, border = 5)
self.dataSizer.Add(self.editGroup, proportion = 0,
@@ -70,7 +76,7 @@
def GetGroup(self):
"""!Returns selected group"""
def OnEditGroup(self, event):
"""!Launch edit group dialog"""
@@ -82,32 +88,37 @@
self.element.SetValue(gr)
dlg.Destroy()
-class IClassMapDialog(ElementDialog):
+class IClassMapDialog(SimpleDialog):
"""!Dialog for adding raster/vector map"""
def __init__(self, parent, title, element):
- Does post init and layout.
- @param gui parent
+ @param parent gui parent
+ @param title dialog title
@param element element type ('raster', 'vector')
- if element == 'raster':
- label = _("Name of raster map:")
- elif element == 'vector':
- label = _("Name of vector map:")
- ElementDialog.__init__(self, parent, title = title, label = label)
+ SimpleDialog.__init__(self, parent, title = title)
+ self.elementType = element
self.element = gselect.Select(parent = self.panel, type = element,
- self.PostInit()
- self.__Layout()
+ self.warning = _("Name of map is missing.")
+ self._layout()
"""!Do layout"""
+ if self.elementType == 'raster':
+ label = _("Name of raster map:")
+ elif self.elementType == 'vector':
+ label = _("Name of vector map:")
+ label = label),
@@ -116,9 +127,9 @@
def GetMap(self):
"""!Returns selected raster/vector map"""
class IClassCategoryManagerDialog(wx.Dialog):
"""!Dialog for managing categories (classes).
Modified: grass/trunk/gui/wxpython/mapswipe/dialogs.py
--- grass/trunk/gui/wxpython/mapswipe/dialogs.py 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/mapswipe/dialogs.py 2013-02-02 15:33:25 UTC (rev 54838)
@@ -17,24 +17,27 @@
import wx
+from core.gcmd import GMessage
-class SwipeMapDialog(ElementDialog):
+class SwipeMapDialog(SimpleDialog):
"""!Dialog used to select raster maps"""
- def __init__(self, parent, title = _("Select raster maps"), id = wx.ID_ANY, first = None, second = None):
- ElementDialog.__init__(self, parent, title, id = id, label = _("Name of top/left raster map:"))
+ def __init__(self, parent, title = _("Select raster maps"), first = None, second = None):
- self.element = gselect.Select(parent = self.panel, type = 'raster',
+ self.element1 = gselect.Select(parent = self.panel, type = 'raster',
self.element2 = gselect.Select(parent = self.panel, type = 'raster',
- self.PostInit()
if first:
- self.element.SetValue(first)
+ self.element1.SetValue(first)
if second:
self.element2.SetValue(second)
@@ -43,7 +46,10 @@
def _layout(self):
"""!Do layout"""
+ label = _("Name of top/left raster map:")),
@@ -56,7 +62,13 @@
+ if win == self.element1.GetTextCtrl():
+ GMessage(parent = self, message = _("Name of the first map is missing."))
+ else:
+ GMessage(parent = self, message = _("Name of the second map is missing."))
"""!Get raster maps"""
- return (self.GetElement(), self.element2.GetValue())
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2013-02-02 15:14:09 UTC (rev 54837)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2013-02-02 15:33:25 UTC (rev 54838)
@@ -94,7 +94,7 @@
\subsection gui_core GUI core modules
- gui_core::dialogs
@@ -166,6 +166,7 @@
- gui_core::widgets
- widgets::ScrolledPanel
- widgets::NTCValidator
+ - widgets::SimpleValidator
- widgets::NumTextCtrl
- widgets::FloatSlider
- widgets::SymbolButton
