[GRASS-SVN] r54844 - grass/branches/releasebranch_6_4/imagery/i.landsat.toar
svn_grass at osgeo.org
Sat Feb 2 10:37:42 PST 2013
Author: neteler
Date: 2013-02-02 10:37:42 -0800 (Sat, 02 Feb 2013)
New Revision: 54844
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/description.html
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat.h
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_set.c
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/local_proto.h
grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c
Jorge Tizado: better management of metadata file
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/description.html
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/description.html 2013-02-02 18:36:15 UTC (rev 54843)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/description.html 2013-02-02 18:37:42 UTC (rev 54844)
@@ -15,7 +15,7 @@
Optionally (recommended), the data can be read from metadata file (.met or MTL.txt) for all
Landsat MSS, TM and ETM+. However, if the solar elevation or the
product creation date are given the values of the metadata file are
-overwriten (only with .met files). This is necessary when the data in the .met file is
+overwriten. This is necessary when the data in the .met file is
incorrect or not accurate.
<p>
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat.h
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat.h 2013-02-02 18:36:15 UTC (rev 54843)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat.h 2013-02-02 18:37:42 UTC (rev 54844)
@@ -21,7 +21,7 @@
* Esun in W / (m^2 * µm) -> Irradiance
-#define MAX_BANDS 9
+#define MAX_BANDS 11
typedef struct
@@ -51,7 +51,7 @@
double dist_es; /* Distance Earth-Sun */
double sun_elev; /* Solar elevation */
- char sensor[5]; /* Type of sensor: MSS, TM, ETM+ */
+ char sensor[10]; /* Type of sensor: MSS, TM, ETM+, OLI/TIRS */
int bands; /* Total number of bands */
band_data band[MAX_BANDS]; /* Data for each band */
} lsat_data;
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c 2013-02-02 18:36:15 UTC (rev 54843)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c 2013-02-02 18:37:42 UTC (rev 54844)
@@ -16,175 +16,110 @@
inline void chrncpy(char *dest, char src[], int n)
- if (src == NULL)
- dest[0] = '\0';
- else
- int i;
- for (i = 0; i < n && src[i] != '\0' && src[i] != '\"'; i++) dest[i] = src[i];
- dest[i] = '\0';
+ int i;
+ for( i = 0 ; i < n && src[i] != '\0' && src[i] != '\"'; i++) dest[i] = src[i];
+ dest[i] = '\0';
- * PURPOSE: Read values of Landsat MSS/TM from header (.met) file
-void get_metdata(const char mettext[], char *text, char value[])
+void get_oldformat( const char metadata[], char * key, char value[] )
- char *ptr;
- ptr = strstr(mettext, text);
- if (ptr == NULL)
+ int i = 0;
+ char * ptr = strstr(metadata, key);
+ if (ptr != NULL)
- value[0] = 0;
- return;
+ ptr = strstr(ptr, " VALUE ");
+ if (ptr != NULL)
+ while (*ptr++ != '=') ;
+ while (*ptr <= ' ' || *ptr == '\"') *ptr++;
+ while (i < MAX_STR && *ptr != '\"' && *ptr >= ' ') value[i++] = *ptr++;
- ptr = strstr(ptr, " VALUE ");
- if (ptr == NULL) return;
- while (*ptr++ != '\"') ;
- int i = 0;
- while (*ptr != '\"' && i < MAX_STR) value[i++] = *ptr++;
value[i] = '\0';
- return;
-void lsat_metdata(char *metfile, lsat_data * lsat)
+void get_newformat( const char metadata[], char * key, char value[] )
- FILE *f;
- char mettext[TM5_MET_SIZE];
- char name[MAX_STR], value[MAX_STR];
- /* char metdate[MAX_STR]; */
- if ((f = fopen(metfile, "r")) == NULL)
- G_fatal_error(_("Metadata file <%s> not found"), metfile);
- fread(mettext, TM5_MET_SIZE, 1, f);
- get_metdata(mettext, "PLATFORMSHORTNAME", value);
- chrncpy(name, value + 8, 1);
- lsat->number = atoi(name);
- get_metdata(mettext, "SENSORSHORTNAME", value);
- chrncpy(lsat->sensor, value + 1, 4);
- get_metdata(mettext, "CALENDARDATE", value);
- chrncpy(lsat->date, value, 10);
- if (lsat->creation[0] == 0)
+ int i = 0;
+ if (ptr != NULL)
- get_metdata(mettext, "PRODUCTIONDATETIME", value);
- if (!value[0])
- G_fatal_error(_("Product creation date not in metadata file <%s>, input this data in the command line parameters"), metfile);
- chrncpy(lsat->creation, value, 10);
+ while (i < MAX_STR && *ptr != '\"' && *ptr > ' ') value[i++] = *ptr++;
- if (lsat->sun_elev == 0)
- get_metdata(mettext, "SolarElevation", value);
- if (!value[0])
- G_fatal_error(_("Unable to read solar elevation from metadata file in metadata file <%s>, input this data in the command line parameters"), metfile);
- lsat->sun_elev = atof(value);
- /* Fill data with the sensor_XXX functions */
- switch(lsat->number)
- case 1:
- set_MSS1(lsat);
- break;
- case 2:
- set_MSS2(lsat);
- break;
- case 3:
- set_MSS3(lsat);
- break;
- case 4:
- if (lsat->sensor[0] == 'M')
- set_MSS4(lsat);
- else
- set_TM4(lsat);
- break;
- case 5:
- set_MSS5(lsat);
- else
- set_TM5(lsat);
- break;
- default:
- G_warning("Unable to recognize satellite platform [%d]", lsat->number);
- break;
- (void)fclose(f);
- return;
+ value[i] = '\0';
- * PURPOSE: Read values of Landsat from MTL metadata (MTL.txt) file
+ * PURPOSE: Read parameters from Landsat metadata files
-void get_mtldata(const char mtltext[], char *text, char value[])
+void lsat_metadata( char * metafile, lsat_data * lsat)
- char *ptr;
- ptr = strstr(mtltext, text);
- if (ptr == NULL)
- value[0] = '\0';
- return;
- while (*ptr++ != '=') ;
- while (*ptr <= ' ' || *ptr == '\"') *ptr++;
- int i = 0;
- while (i < MAX_STR && *ptr != '\"' && *ptr > ' ') value[i++] = *ptr++;
- value[i] = '\0';
- return;
-void lsat_mtldata(char *mtlfile, lsat_data * lsat)
FILE *f;
char mtldata[METADATA_SIZE];
- int i;
+ char key[MAX_STR], value[MAX_STR];
+ void (*get_mtldata)( const char [], char *, char [] );
+ int i, j, version;
- if ((f = fopen(mtlfile, "r")) == NULL)
- G_fatal_error(_("Metadata file <%s> not found"), mtlfile);
+ if ((f = fopen(metafile, "r")) == NULL)
+ G_fatal_error(_("Metadata file <%s> not found"), metafile);
- fread(mtldata, METADATA_SIZE, 1, f);
+ i = fread(mtldata, METADATA_SIZE, 1, f);
+ get_mtldata = (strstr(mtldata, " VALUE ") != NULL) ? get_oldformat : get_newformat;
+ version = (strstr(mtldata, "QCALMAX_BAND") != NULL) ? 0 : 1;
+ /* Fill with product metadata */
get_mtldata(mtldata, "SPACECRAFT_ID", value);
- chrncpy(name, value + 7, 1);
+ if( value[0] == '\0' )
+ get_mtldata(mtldata, "PLATFORMSHORTNAME", value);
+ i = 0; while( value[i] && (value[i] < '0' || value[i] > '9') ) i++;
+ lsat->number = atoi(value + i);
get_mtldata(mtldata, "SENSOR_ID", value);
- chrncpy(lsat->sensor, value, 4);
+ get_mtldata(mtldata, "SENSORSHORTNAME", value);
+ chrncpy(lsat->sensor, value, 8);
- get_mtldata(mtldata, "ACQUISITION_DATE", value);
+ get_mtldata(mtldata, "DATE_ACQUIRED", value);
+ get_mtldata(mtldata, "ACQUISITION_DATE", value);
+ get_mtldata(mtldata, "CALENDARDATE", value);
- get_mtldata(mtldata, "CREATION_TIME", value);
+ get_mtldata(mtldata, "FILE_DATE", value);
+ get_mtldata(mtldata, "CREATION_TIME", value);
+ get_mtldata(mtldata, "PRODUCTIONDATETIME", value);
get_mtldata(mtldata, "SUN_ELEVATION", value);
+ get_mtldata(mtldata, "SolarElevation", value);
+ if( lsat->sun_elev == 0. )
+ G_warning("Sun elevation is %f", lsat->sun_elev);
+ /* Fill data with the basic sensor parameters */
case 1:
@@ -209,41 +144,54 @@
set_TM5(lsat);
break;
case 7:
- get_mtldata(mtldata, "BAND1_GAIN", value);
- get_mtldata(mtldata, "BAND2_GAIN", value + 1);
- get_mtldata(mtldata, "BAND3_GAIN", value + 2);
- get_mtldata(mtldata, "BAND4_GAIN", value + 3);
- get_mtldata(mtldata, "BAND5_GAIN", value + 4);
- get_mtldata(mtldata, "BAND6_GAIN1", value + 5);
- get_mtldata(mtldata, "BAND6_GAIN2", value + 6);
- get_mtldata(mtldata, "BAND7_GAIN", value + 7);
- get_mtldata(mtldata, "BAND8_GAIN", value + 8);
- value[9] = '\0';
+ char * fmt_gain[] = { "BAND%d_GAIN%d ", " GAIN_BAND_%d_VCID_%d" };
+ for( i = 1, j = 0; i < 9; i++ )
+ sprintf(key, fmt_gain[version], i, 1);
+ if (i != 6) key[version == 0 ? 10 : 12] = '\0';
+ get_mtldata(mtldata, key, value + j++);
+ if (i == 6)
+ sprintf(key, fmt_gain[version], i, 2);
+ value[j] = '\0';
+ G_debug(1, "ETM+ gain = [%s]", value);
set_ETM(lsat, value);
break;
default:
break;
- /* Update the information from metadata file */
- for (i = 0; i < lsat->bands; i++) {
- snprintf(name, MAX_STR, "LMAX_BAND%d", lsat->band[i].code);
- get_mtldata(mtldata, name, value);
- lsat->band[i].lmax = atof(value);
- snprintf(name, MAX_STR, "LMIN_BAND%d", lsat->band[i].code);
- lsat->band[i].lmin = atof(value);
- snprintf(name, MAX_STR, "QCALMAX_BAND%d", lsat->band[i].code);
- lsat->band[i].qcalmax = atof(value);
- snprintf(name, MAX_STR, "QCALMIN_BAND%d", lsat->band[i].code);
- lsat->band[i].qcalmin = atof(value);
+ /* Update the information from metadata file, if infile */
+// if( format == NEW_FORMAT )
+ if( get_mtldata == get_newformat )
+ char * fmt_lmax[] = { "LMAX_BAND%d", "RADIANCE_MAXIMUM_BAND_%d" };
+ char * fmt_lmin[] = { "LMIN_BAND%d", "RADIANCE_MINIMUM_BAND_%d" };
+ char * fmt_qcalmax[] = { "QCALMAX_BAND%d", "QUANTIZE_CAL_MAX_BAND_%d" };
+ char * fmt_qcalmin[] = { "QCALMIN_BAND%d", "QUANTIZE_CAL_MIN_BAND_%d" };
+ for (i = 0; i < lsat->bands; i++) {
+ sprintf(key, fmt_lmax[version], lsat->band[i].code);
+ get_mtldata(mtldata, key, value);
+ lsat->band[i].lmax = atof(value);
+ sprintf(key, fmt_lmin[version], lsat->band[i].code);
+ lsat->band[i].lmin = atof(value);
+ sprintf(key, fmt_qcalmax[version], lsat->band[i].code);
+ lsat->band[i].qcalmax = atof(value);
+ sprintf(key, fmt_qcalmin[version], lsat->band[i].code);
+ lsat->band[i].qcalmin = atof(value);
(void)fclose(f);
return;
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_set.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_set.c 2013-02-02 18:36:15 UTC (rev 54843)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_set.c 2013-02-02 18:37:42 UTC (rev 54844)
@@ -16,9 +16,9 @@
/* green, red, near infrared, near infrared */
int band[] = { 1, 2, 3, 4 };
int code[] = { 4, 5, 6, 7 };
+ double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
- double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
- /* 68x83, 68x83, 68x83, 68x83 */
+ /* original: 79x57, now all 60 */
strcpy(lsat->sensor, "MSS");
@@ -41,9 +41,9 @@
/* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR */
int band[] = { 1, 2, 3, 4, 5, 6, 7 };
+ double wmin[] = { 0.45, 0.52, 0.63, 0.76, 1.55, 10.40, 2.08 };
double wmax[] = { 0.52, 0.60, 0.69, 0.90, 1.75, 12.50, 2.35 };
- double wmin[] = { 0.45, 0.52, 0.63, 0.76, 1.55, 10.40, 2.08 };
- /* 30, 30, 30, 30, 30, 120, 30 */
+ /* 30, 30, 30, 30, 30, 120 original, 60 resamples before Feb 25, 2010 and 30 after, 30 */
if (!lsat->sensor)
strcpy(lsat->sensor, "TM");
@@ -68,9 +68,9 @@
/* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR, panchromatic */
int band[] = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
int code[] = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
+ double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 2.35, 0.90 };
- double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
- /* 30, 30, 30, 30, 30, 60, 30, 15 */
+ /* 30, 30, 30, 30, 30, 60 (after Feb. 25, 2010: 30), 30, 15 */
strcpy(lsat->sensor, "ETM+");
@@ -87,7 +87,33 @@
return;
+void sensor_OLI(lsat_data * lsat)
+ int i;
+ /* coastal aerosol, blue, green, red, near infrared, shortwave IR (SWIR) 1, SWIR 2, panchromatic,
+ * cirrus, thermal infrared (TIR) 1, TIR 2 */
+ int band[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 };
+ int code[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 };
+ double wmin[] = { 0.433, 0.450, 0.525, 0.630, 0.845, 1.560, 2.100, 0.500, 1.360, 10.3, 11.5 };
+ double wmax[] = { 0.453, 0.515, 0.600, 0.680, 0.885, 1.660, 2.300, 0.680, 1.390, 11.3, 12.5 };
+ /* 30, 30, 30, 30, 30, 30, 30, 15, 30, 100, 100 */
+ strcpy(lsat->sensor, "OLI/TIRS");
+ lsat->bands = 11;
+ lsat->band[i].number = *(band + i);
+ lsat->band[i].code = *(code + i);
+ lsat->band[i].wavemax = *(wmax + i);
+ lsat->band[i].wavemin = *(wmin + i);
+ lsat->band[i].qcalmax = 255.;
+ lsat->band[i].qcalmin = 1.;
+ lsat->band[i].thermal = (lsat->band[i].number > 9 ? 1 : 0);
+ return;
** Before access to these functions ...
** store previously
@@ -154,9 +180,10 @@
julian = julian_char(lsat->creation);
if (julian < julian_char("1975-07-16"))
- i = 0;
+ i = 0;
else
- i = 1;
+ i = 1;
lmax = Lmax[i];
lmin = Lmin[i];
@@ -205,6 +232,7 @@
i = 0;
else
i = 1;
lmax = Lmax[i];
lmin = Lmin[i];
@@ -256,6 +284,7 @@
i = 1;
else
i = 2;
lmax = Lmax[i];
lmin = Lmin[i];
@@ -305,6 +334,7 @@
i = 1;
else
i = 2;
lmax = Lmax[i];
lmin = Lmin[i];
@@ -361,6 +391,7 @@
i = 1;
else
i = 2;
lmax = Lmax[i];
lmin = Lmin[i];
@@ -410,6 +441,7 @@
i = 1;
else
i = 2;
lmax = Lmax[i];
lmin = Lmin[i];
if (i == 2) { /* in Chander, Markham and Barsi 2007 */
@@ -515,3 +547,47 @@
G_debug(1, "Landsat-7 ETM+");
return;
+ * PURPOSE: Store values of Landsat-8 OLI/TIRS
+ * February 14, 2013
+void set_OLI(lsat_data * lsat)
+ int i, j;
+ double julian, *lmax, *lmin;
+ /* Spectral radiances at detector
+ double Lmax[][4] = {
+ {220., 175., 145., 147.},
+ {259., 179., 149., 128.}
+ double Lmin[][4] = {
+ {4., 3., 3., 1.},
+ {4., 3., 3., 1.}
+ * Solar exoatmospheric spectral irradiances
+ double esun[] = { 1824., 1570., 1249., 853.4 };
+ lmax = Lmax[i];
+ lmin = Lmin[i];
+ lsat->number = 3;
+ sensor_MSS(lsat);
+ lsat->dist_es = earth_sun(lsat->date);
+ j = lsat->band[i].number - 1;
+ lsat->band[i].esun = *(esun + j);
+ lsat->band[i].lmax = *(lmax + j);
+ lsat->band[i].lmin = *(lmin + j);
+ if (lsat->band[i].thermal) {
+ lsat->band[i].K1 = 0;
+ lsat->band[i].K2 = 0;
+ G_debug(1, "Landsat-8 LDCM");
+ return;
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/local_proto.h
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/local_proto.h 2013-02-02 18:36:15 UTC (rev 54843)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/local_proto.h 2013-02-02 18:37:42 UTC (rev 54844)
@@ -4,8 +4,7 @@
#include <string.h>
#include "landsat.h"
-void lsat_mtldata(char *, lsat_data *);
-void lsat_metdata(char *, lsat_data *);
+void lsat_metadata(char *, lsat_data *);
void set_MSS1(lsat_data *);
void set_MSS2(lsat_data *);
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c 2013-02-02 18:36:15 UTC (rev 54843)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/main.c 2013-02-02 18:37:42 UTC (rev 54844)
@@ -200,10 +200,6 @@
G_fatal_error(_("Illegal date format: [%s] (yyyy-mm-dd)"),
lsat.date);
- /* Unnecessary because G_zero filled
- else
- lsat.date[0] = '\0';
if (pdate->answer != NULL) {
strncpy(lsat.creation, pdate->answer, 11);
@@ -212,36 +208,21 @@
lsat.creation);
- else
- lsat.creation[0] = '\0';
lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
percent = atof(perc->answer);
pixel = atoi(dark->answer);
rayleigh = atof(atmo->answer);
- lsat.flag = NOMETADATAFILE;
/* Data from metadata file */
+ /* Unnecessary because G_zero filled, but sanity */
+ lsat.flag = NOMETADATAFILE;
if (met != NULL)
lsat.flag = METADATAFILE;
- i = strlen(met);
- if (strcmp(met + i - 7, "MTL.txt") == 0)
- lsat_mtldata(met, &lsat);
- else if (strcmp(met + i - 4, ".met") == 0)
- if (strcmp(sensorname, "tm7") == 0)
- lsat_mtldata(met, &lsat); /* old .met of Landsat-7 = new MTL file */
- else
- lsat_metdata(met, &lsat);
+ lsat_metadata( met, &lsat );
G_debug(1, "lsat.number = %d, lsat.sensor = [%s]", lsat.number, lsat.sensor);
if (!lsat.sensor || lsat.number > 7 || lsat.number < 1)
G_fatal_error(_("Failed to identify satellite"));
@@ -257,17 +238,14 @@
adate->key, elev->key);
else {
- if (strcmp(sensorname, "tm7") == 0) { /* Need gain */
- if (bgain->answer != NULL && strlen(bgain->answer) == 9) {
+ /* Need gain */
+ if (strcmp(sensorname, "tm7") == 0) {
+ if (bgain->answer == NULL || strlen(bgain->answer) != 9)
+ G_fatal_error(_("Landsat-7 requires band gain with 9 (H/L) data"));
set_ETM(&lsat, bgain->answer);
- G_debug(1, "Landsat 7 ETM+");
- else {
- G_fatal_error(_("Landsat-7 requires band gain with 9 (H/L) data"));
- else { /* Not need gain */
- if (strcmp(sensorname, "tm5") == 0)
+ /* Not need gain */
+ else if (strcmp(sensorname, "tm5") == 0)
set_TM5(&lsat);
else if (strcmp(sensorname, "tm4") == 0)
set_TM4(&lsat);
@@ -283,23 +261,22 @@
set_MSS1(&lsat);
else
G_fatal_error(_("Unknown satellite type (defined by '%s')"), sensor->key);
* ------------ PREPARATION --------------
- if (G_strcasecmp(metho->answer, "corrected") == 0)
+ if (strcasecmp(metho->answer, "corrected") == 0)
method = CORRECTED;
- else if (G_strcasecmp(metho->answer, "dos1") == 0)
+ else if (strcasecmp(metho->answer, "dos1") == 0)
method = DOS1;
- else if (G_strcasecmp(metho->answer, "dos2") == 0)
+ else if (strcasecmp(metho->answer, "dos2") == 0)
method = DOS2;
- else if (G_strcasecmp(metho->answer, "dos2b") == 0)
+ else if (strcasecmp(metho->answer, "dos2b") == 0)
method = DOS2b;
- else if (G_strcasecmp(metho->answer, "dos3") == 0)
+ else if (strcasecmp(metho->answer, "dos3") == 0)
method = DOS3;
- else if (G_strcasecmp(metho->answer, "dos4") == 0)
+ else if (strcasecmp(metho->answer, "dos4") == 0)
method = DOS4;
else
method = UNCORRECTED;
