[GRASS-SVN] r54862 - grass/branches/releasebranch_6_4/raster3d/r3.in.ascii
svn_grass at osgeo.org
Sun Feb 3 02:38:10 PST 2013
Author: mmetz
Date: 2013-02-03 02:38:10 -0800 (Sun, 03 Feb 2013)
New Revision: 54862
grass/branches/releasebranch_6_4/raster3d/r3.in.ascii/main.c
r3.in.ascii: fix #1801
Modified: grass/branches/releasebranch_6_4/raster3d/r3.in.ascii/main.c
--- grass/branches/releasebranch_6_4/raster3d/r3.in.ascii/main.c 2013-02-03 10:36:00 UTC (rev 54861)
+++ grass/branches/releasebranch_6_4/raster3d/r3.in.ascii/main.c 2013-02-03 10:38:10 UTC (rev 54862)
@@ -30,7 +30,7 @@
/*Puts the userdefined parameters into easier handable variables */
static void getParams(char **input, char **output, int *convertNull,
- double *nullValu);
+ char *nullValu);
/*reads a g3d ascii-file headerfile-string */
static void readHeaderString(FILE * fp, char *valueString, double *value);
@@ -40,7 +40,7 @@
/*This function does all the work, it reads the values from the g3d ascii-file and put
it into an g3d-map */
static void asciiToG3d(FILE * fp, G3D_Region * region, int convertNull,
- double nullValue);
+ char *nullValue);
@@ -85,7 +85,7 @@
param.nv->type = TYPE_STRING;
param.nv->required = NO;
param.nv->multiple = NO;
- param.nv->answer = "none";
+ param.nv->answer = "*";
param.nv->description =
_("String representing NULL value data cell (use 'none' if no such value)");
@@ -93,13 +93,13 @@
static void
-getParams(char **input, char **output, int *convertNull, double *nullValue)
+getParams(char **input, char **output, int *convertNull, char *nullValue)
*input = param.input->answer;
*output = param.output->answer;
*convertNull = (strcmp(param.nv->answer, "none") != 0);
if (*convertNull)
- if (sscanf(param.nv->answer, "%lf", nullValue) != 1)
+ if (sscanf(param.nv->answer, "%s", nullValue) != 1)
fatalError("getParams: NULL-value value invalid");
G_debug(3, "getParams: input: %s, output: %s", *input, *output);
@@ -159,10 +159,11 @@
#define MAX(a,b) (a > b ? a : b)
static void
-asciiToG3d(FILE * fp, G3D_Region * region, int convertNull, double nullValue)
+asciiToG3d(FILE * fp, G3D_Region * region, int convertNull, char *nullValue)
int x, y, z;
double value;
+ char buff[256];
int tileX, tileY, tileZ;
@@ -185,16 +186,28 @@
for (y = region->rows - 1; y >= 0; y--) /* go south to north */
for (x = 0; x < region->cols; x++) {
- if (fscanf(fp, "%lf", &value) != 1) {
- if (feof(fp))
- G_warning(_("End of file reached while still loading data."));
+ if (fscanf(fp, "%s", buff) != 1) {
+ if (feof(fp))
+ G_warning(_("End of file reached while still loading data."));
G_debug(3,
"missing data at col=%d row=%d depth=%d last_value=[%.4f]",
x + 1, region->rows - y, z + 1, value);
fatalError("asciiToG3d: read failed");
- if (convertNull && (value == nullValue))
+ /* Check for null value */
+ if (convertNull && strncmp(buff, nullValue, strlen(nullValue)) == 0) {
G3d_setNullValue(&value, 1, DCELL_TYPE);
+ else {
+ if (sscanf(buff, "%lf", &value) != 1) {
+ G_warning(_("Invalid value detected"));
+ G_debug(1, "invalid value at col=%d row=%d depth=%d last_value=[%s]",
+ x + 1, region->rows - y, z + 1, buff);
+ fatalError("asciiToG3d: read failed");
G3d_putDouble(map, x, y, z, value);
@@ -224,7 +237,7 @@
char *input, *output;
int convertNull;
- double nullValue;
+ char nullValue[256];
int useTypeDefault, type, useLzwDefault, doLzw, useRleDefault, doRle;
int usePrecisionDefault, precision, useDimensionDefault, tileX, tileY,
tileZ;
@@ -247,7 +260,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- getParams(&input, &output, &convertNull, &nullValue);
+ getParams(&input, &output, &convertNull, nullValue);
if (!G3d_getStandard3dParams(&useTypeDefault, &type,
&useLzwDefault, &doLzw,
&useRleDefault, &doRle,
