[GRASS-SVN] r54881 - in grass/trunk/gui/wxpython: core lmgr mapdisp nviz
svn_grass at osgeo.org
Sun Feb 3 12:05:54 PST 2013
Author: wenzeslaus
Date: 2013-02-03 12:05:54 -0800 (Sun, 03 Feb 2013)
New Revision: 54881
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/main.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
wxGUI/mapdisp: querying uses giface to ask for layers (layer representation not finished), querying in d.mon works
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2013-02-03 19:54:55 UTC (rev 54880)
+++ grass/trunk/gui/wxpython/core/giface.py 2013-02-03 20:05:54 UTC (rev 54881)
@@ -88,9 +88,9 @@
function(text)
os.environ["GRASS_MESSAGE_FORMAT"] = orig
- def GetLayerTree(self):
+ def GetLayerList(self):
return None
def GetMapDisplay(self):
"""!Get current map display.
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2013-02-03 19:54:55 UTC (rev 54880)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2013-02-03 20:05:54 UTC (rev 54881)
@@ -15,6 +15,35 @@
@author Vaclav Petras <wenzeslaus gmail.com>
+class Layer(object):
+ def __init__(self, pydata):
+ self._pydata = pydata
+ def __getattr__(self, name):
+ return self._pydata[0][name]
+class LayerList(object):
+ def __init__(self, tree):
+ self._tree = tree
+# def __iter__(self):
+# for in :
+# yield
+ def GetSelectedLayers(self, checkedOnly = True):
+ items = self._tree.GetSelectedLayer(multi = True, checkedOnly = True)
+ layers = []
+ for item in items:
+ layer = Layer(self._tree.GetPyData(item))
+ layers.append(layer)
+ return layers
+ def GetLayerInfo(self, layer):
+ return Layer(self._tree.GetPyData(layer))
class LayerManagerGrassInterface:
def __init__(self, lmgr):
self.lmgr = lmgr
@@ -41,8 +70,11 @@
self.lmgr._gconsole.WriteError(line = line)
- return self.lmgr.GetLayerTree()
+ return LayerList(self.lmgr.GetLayerTree())
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-02-03 19:54:55 UTC (rev 54880)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-02-03 20:05:54 UTC (rev 54881)
@@ -638,7 +638,7 @@
if pgnum > -1:
self.layerbook.DeletePage(pgnum)
- def Query(self, x, y, layers):
+ def Query(self, x, y):
"""!Query selected layers.
Calls QueryMap in case of raster or more vectors,
@@ -647,9 +647,10 @@
@param x,y coordinates
@param layers selected tree item layers
+ layers = self._giface.GetLayerList().GetSelectedLayers(checkedOnly = True)
filteredLayers = []
for layer in layers:
- ltype = self.tree.GetLayerInfo(layer, key = 'maplayer').GetType()
+ ltype = layer.maplayer.GetType()
if ltype in ('raster', 'rgb', 'his',
'vector', 'thememap', 'themechart'):
filteredLayers.append(layer)
@@ -662,8 +663,13 @@
layers = filteredLayers
# set query snap distance for v.what at map unit equivalent of 10 pixels
qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
- east, north = self.MapWindow.Pixel2Cell((x, y))
+ # TODO: replace returning None by exception or so
+ try:
+ east, north = self.MapWindow.Pixel2Cell((x, y))
+ except TypeError:
+ return
posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
y + self.MapWindow.dialogOffset))
@@ -671,7 +677,7 @@
nVectors = 0
isDbConnection = False
for l in layers:
- maplayer = self.tree.GetLayerInfo(l, key = 'maplayer')
+ maplayer = l.maplayer
if maplayer.GetType() == 'raster':
isRaster = True
break
@@ -705,8 +711,8 @@
vcmd = ['v.what', '--v']
- dcmd = self.tree.GetLayerInfo(layer, key = 'cmd')
+ dcmd = layer.cmd
name, found = GetLayerNameFromCmd(dcmd)
if not found:
@@ -784,9 +790,9 @@
Attribute data of selected vector object are displayed in GUI dialog.
Data can be modified (On Submit)
- mapName = self.tree.GetLayerInfo(layer, key = 'maplayer').name
+ mapName = layer.maplayer.name
- if self.tree.GetLayerInfo(layer, key = 'maplayer').GetMapset() != \
+ if layer.maplayer.GetMapset() != \
grass.gisenv()['MAPSET']:
mode = 'display'
else:
@@ -832,7 +838,7 @@
qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId = False)
# set opacity based on queried layer
- opacity = self.tree.GetLayerInfo(layer, key = 'maplayer').GetOpacity(float = True)
+ opacity = layer.maplayer.GetOpacity(float = True)
qlayer.SetOpacity(opacity)
self.MapWindow.UpdateMap(render = False, renderVector = False)
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2013-02-03 19:54:55 UTC (rev 54880)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2013-02-03 20:05:54 UTC (rev 54881)
@@ -226,6 +226,54 @@
return self._renderCmdFile(force, windres)
+ def __init__(self, maplayer):
+ self._maplayer = maplayer
+ if name == 'cmd':
+ return utils.CmdTupleToList(self._maplayer.GetCmd())
+ elif hasattr(self._maplayer, name):
+ return getattr(self._maplayer, name)
+ elif name == 'maplayer':
+ return self._maplayer
+ elif name == 'type':
+ return self._maplayer.GetType()
+ #elif name == 'ctrl':
+ elif name == 'label':
+ return self._maplayer.GetName()
+ #elif name == 'maplayer' : None,
+ #elif name == 'propwin':
+ def __init__(self, map):
+ self._map = map
+# for in :
+# yield
+ def GetSelectedLayers(self, checkedOnly=True):
+ # hidden and selected vs checked and selected
+ items = self._map.GetListOfLayers()
+ layers = []
+ layer = Layer(item)
+ return layers
+class DMonGrassInterface(StandaloneGrassInterface):
+ def __init__(self, mapframe):
+ StandaloneGrassInterface.__init__(self)
+ self._mapframe = mapframe
+ return LayerList(self._mapframe.GetMap())
class DMonFrame(MapFrame):
def OnZoomToMap(self, event):
layers = self.MapWindow.GetMap().GetListOfLayers()
@@ -244,9 +292,11 @@
# actual use of StandaloneGrassInterface not yet tested
# needed for adding functionality in future
+ giface = DMonGrassInterface(None)
self.mapFrm = DMonFrame(parent = None, id = wx.ID_ANY, Map = self.Map,
- giface = StandaloneGrassInterface(),
- size = monSize)
+ giface = giface, size = monSize)
+ # FIXME: hack to solve dependency
+ giface._mapframe = self.mapFrm
# self.SetTopWindow(Map)
self.mapFrm.GetMapWindow().SetAlwaysRenderEnabled(True)
self.mapFrm.Show()
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-02-03 19:54:55 UTC (rev 54880)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-02-03 20:05:54 UTC (rev 54881)
@@ -1175,15 +1175,7 @@
self.frame.StatusbarUpdate()
elif self.mouse["use"] == "query":
- # querying
- if self.frame.IsStandalone():
- GMessage(parent = self.frame,
- message = _("Querying is not implemented in standalone mode of Map Display"))
- return
- layers = self.tree.GetSelectedLayer(multi = True, checkedOnly = True)
- self.frame.Query(self.mouse['begin'][0],self.mouse['begin'][1], layers)
+ self.frame.Query(self.mouse['begin'][0],self.mouse['begin'][1])
elif self.mouse["use"] in ["measure", "profile"]:
# measure or profile
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2013-02-03 19:54:55 UTC (rev 54880)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2013-02-03 20:05:54 UTC (rev 54881)
@@ -769,10 +769,8 @@
return
elif self.mouse["use"] in ('arrow', 'scalebar'):
self.lmgr.nviz.FindWindowById(
self.lmgr.nviz.win['decoration'][self.mouse["use"]]['place']).SetValue(False)
