[GRASS-SVN] r54898 - grass/trunk/imagery/i.landsat.toar
svn_grass at osgeo.org
Mon Feb 4 07:22:41 PST 2013
Author: ychemin
Date: 2013-02-04 07:22:41 -0800 (Mon, 04 Feb 2013)
New Revision: 54898
grass/trunk/imagery/i.landsat.toar/landsat.h
grass/trunk/imagery/i.landsat.toar/landsat_met.c
grass/trunk/imagery/i.landsat.toar/main.c
New function to call metadata file values one by one for external use
Modified: grass/trunk/imagery/i.landsat.toar/landsat.h
--- grass/trunk/imagery/i.landsat.toar/landsat.h 2013-02-04 15:06:44 UTC (rev 54897)
+++ grass/trunk/imagery/i.landsat.toar/landsat.h 2013-02-04 15:22:41 UTC (rev 54898)
@@ -50,6 +50,8 @@
char date[11]; /* Image acquisition date */
double dist_es; /* Distance Earth-Sun */
double sun_elev; /* Solar elevation */
+ double sunza; /* Solar Zenith Angle */
+ double time; /* Image Acquisition Time */
char sensor[10]; /* Type of sensor: MSS, TM, ETM+, OLI/TIRS */
int bands; /* Total number of bands */
Modified: grass/trunk/imagery/i.landsat.toar/landsat_met.c
--- grass/trunk/imagery/i.landsat.toar/landsat_met.c 2013-02-04 15:06:44 UTC (rev 54897)
+++ grass/trunk/imagery/i.landsat.toar/landsat_met.c 2013-02-04 15:22:41 UTC (rev 54898)
@@ -110,6 +110,11 @@
chrncpy(lsat->creation, value, 10);
+ get_mtldata(mtldata, "SUN_AZIMUTH", value);
+ lsat->sunza = atof(value);
+ if( lsat->sunza == 0. )
+ G_warning("Sun azimuth is %f", lsat->sunza);
get_mtldata(mtldata, "SUN_ELEVATION", value);
if( value[0] == '\0' )
@@ -119,6 +124,19 @@
if( lsat->sun_elev == 0. )
G_warning("Sun elevation is %f", lsat->sun_elev);
+ get_mtldata(mtldata, "SCENE_CENTER_TIME", value);
+ if( value[0] == '\0' )
+ get_mtldata(mtldata, "SCENE_CENTER_SCAN_TIME", value);
+ //Thanks Markus Metz !
+ //Remove trailing 'z'
+ value[strlen(value) - 1]='\0';
+ // Cast from hh:mm:ss into hh.hhh
+ G_llres_scan(value, &lsat->time);
+ if( lsat->time == 0. )
+ G_warning("Time is %f", lsat->time);
/* Fill data with the basic sensor parameters */
switch(lsat->number)
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c 2013-02-04 15:06:44 UTC (rev 54897)
+++ grass/trunk/imagery/i.landsat.toar/main.c 2013-02-04 15:22:41 UTC (rev 54898)
@@ -43,9 +43,9 @@
RASTER_MAP_TYPE in_data_type;
struct Option *input_prefix, *output_prefix, *metfn, *sensor, *adate, *pdate, *elev,
- *bgain, *metho, *perc, *dark, *atmo;
+ *bgain, *metho, *perc, *dark, *atmo, *lsatmet;
char *inputname, *met, *outputname, *sensorname;
- struct Flag *frad;
+ struct Flag *frad, *print_meta;
lsat_data lsat;
char band_in[GNAME_MAX], band_out[GNAME_MAX];
@@ -183,11 +183,37 @@
atmo->answer = "0.0";
atmo->guisection = _("Settings");
+ lsatmet = G_define_option();
+ lsatmet->key = "lsatmet";
+ lsatmet->type = TYPE_STRING;
+ lsatmet->required = NO;
+ lsatmet->label = _("return value stored for a given metadata");
+ lsatmet->description = _("Required only if 'metfile' and -p given");
+ lsatmet->options = "number,creation,date,sun_elev,sensor,bands,sunza,time";
+ desc = NULL;
+ G_asprintf(&desc,
+ "number;%s;creation;%s;date;%s;sun_elev;%s;sensor;%s;bands;%s;sunza;%s;time;%s",
+ _("Landsat Number"),
+ _("Creation timestamp"),
+ _("Date"),
+ _("Sun Elevation"),
+ _("Sensor"),
+ _("Bands count"),
+ _("Sun Zenith Angle"),
+ _("Time"));
+ lsatmet->descriptions = desc;
+ lsatmet->guisection = _("Settings");
/* define the different flags */
frad = G_define_flag();
frad->key = 'r';
frad->description = _("Output at-sensor radiance for all bands");
+ /* define the different flags */
+ print_meta = G_define_flag();
+ print_meta->key = 'p';
+ print_meta->description = _("Print output metadata info");
/* options and afters parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -234,6 +260,36 @@
lsat.flag = METADATAFILE;
lsat_metadata( met, &lsat );
+ if(print_meta) {
+ if (strcmp(lsatmet->answer, "number") == 0) {
+ fprintf(stdout,"%d\n",lsat.number);
+ else if (strcmp(lsatmet->answer, "creation") == 0) {
+ fprintf(stdout,"%s\n",lsat.creation);
+ else if (strcmp(lsatmet->answer, "date") == 0) {
+ fprintf(stdout,"%s\n",lsat.date);
+ else if (strcmp(lsatmet->answer, "sun_elev") == 0) {
+ fprintf(stdout,"%f\n",lsat.sun_elev);
+ else if (strcmp(lsatmet->answer, "sensor") == 0) {
+ fprintf(stdout,"%s\n",lsat.sensor);
+ else if (strcmp(lsatmet->answer, "bands") == 0) {
+ fprintf(stdout,"%d\n",lsat.bands);
+ else if (strcmp(lsatmet->answer, "sunza") == 0) {
+ fprintf(stdout,"%f\n",lsat.sunza);
+ else if (strcmp(lsatmet->answer, "time") == 0) {
+ fprintf(stdout,"%f\n",lsat.time);
+ else {
+ G_fatal_error(_("Please use a metadata keyword with -p"));
+ exit(EXIT_SUCCESS);
G_debug(1, "lsat.number = %d, lsat.sensor = [%s]", lsat.number, lsat.sensor);
if (!lsat.sensor || lsat.number > 7 || lsat.number < 1)
