[GRASS-SVN] r54923 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Feb 5 05:09:55 PST 2013
Author: lucadelu
Date: 2013-02-05 05:09:54 -0800 (Tue, 05 Feb 2013)
New Revision: 54923
grass/trunk/lib/python/pygrass/vector/abstract.py
fix doctest and documentation
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2013-02-05 13:01:58 UTC (rev 54922)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2013-02-05 13:09:54 UTC (rev 54923)
@@ -22,54 +22,51 @@
"""Basic vector info.
To get access to the vector info the map must be opened. ::
- >>> municip = Info('boundary_municp', 'PERMANENT')
- >>> municip.full_name
- You must open the map.
+ >>> cens = Info('census')
+ >>> cens.open()
- >>> municip.open()
Then it is possible to read and write the following map attributes: ::
- >>> municip.organization
+ >>> cens.organization
'NC OneMap'
- >>> municip.person
- 'helena'
- >>> municip.title
- 'North Carolina municipality boundaries (polygon map)'
- >>> municip.map_date
- datetime.datetime(2006, 11, 7, 0, 1, 27)
- >>> municip.date
+ >>> cens.person
+ 'hmitaso'
+ >>> cens.title
+ 'Wake County census blocks with attributes, clipped (polygon map)'
+ >>> cens.map_date
+ datetime.datetime(2007, 3, 19, 22, 1, 37)
+ >>> cens.date
- >>> municip.scale
+ >>> cens.scale
1
- >>> municip.comment
+ >>> cens.comment
- >>> municip.comment = "One useful comment!"
+ >>> cens.comment = "One useful comment!"
+ >>> cens.comment
'One useful comment!'
- >>> municip.zone
+ >>> cens.zone
0
- >>> municip.proj
+ >>> cens.proj
99
There are some read only attributes: ::
- 'boundary_municp at PERMANENT'
- >>> municip.proj_name
+ >>> cens.full_name
+ 'census at PERMANENT'
+ >>> cens.proj_name
'Lambert Conformal Conic'
- >>> municip.maptype
+ >>> cens.maptype
'native'
And some basic methods: ::
- >>> municip.is_3D()
+ >>> cens.is_3D()
False
- >>> municip.exist()
+ >>> cens.exist()
True
- >>> municip.is_open()
+ >>> cens.is_open()
True
- >>> municip.close()
+ >>> cens.close()
def __init__(self, name, mapset='', layer=None):
@@ -84,13 +81,14 @@
self.layer = layer
def _get_name(self):
+ """Private method to obtain the Vector name"""
if self.exist() and self.is_open():
return libvect.Vect_get_name(self.c_mapinfo)
else:
return self._name
def _set_name(self, newname):
- """Private method to change the Raster name"""
+ """Private method to change the Vector name"""
if not functions.is_clean_name(newname):
str_err = _("Map name {0} not valid")
raise ValueError(str_err.format(newname))
@@ -105,83 +103,103 @@
# return libvect.Vect_get_mapset(self.c_mapinfo)
def _get_organization(self):
+ """Private method to obtain the Vector organization"""
return libvect.Vect_get_organization(self.c_mapinfo)
def _set_organization(self, org):
+ """Private method to change the Vector organization"""
libvect.Vect_get_organization(self.c_mapinfo, ctypes.c_char_p(org))
organization = property(fget=_get_organization, fset=_set_organization)
def _get_date(self):
+ """Private method to obtain the Vector date"""
return libvect.Vect_get_date(self.c_mapinfo)
def _set_date(self, date):
+ """Private method to change the Vector date"""
return libvect.Vect_set_date(self.c_mapinfo, ctypes.c_char_p(date))
date = property(fget=_get_date, fset=_set_date)
def _get_person(self):
+ """Private method to obtain the Vector person"""
return libvect.Vect_get_person(self.c_mapinfo)
def _set_person(self, person):
+ """Private method to change the Vector person"""
libvect.Vect_set_person(self.c_mapinfo, ctypes.c_char_p(person))
person = property(fget=_get_person, fset=_set_person)
def _get_title(self):
+ """Private method to obtain the Vector title"""
return libvect.Vect_get_map_name(self.c_mapinfo)
def _set_title(self, title):
+ """Private method to change the Vector title"""
libvect.Vect_set_map_name(self.c_mapinfo, ctypes.c_char_p(title))
title = property(fget=_get_title, fset=_set_title)
def _get_map_date(self):
+ """Private method to obtain the Vector map date"""
date_str = libvect.Vect_get_map_date(self.c_mapinfo)
return datetime.datetime.strptime(date_str, self.date_fmt)
def _set_map_date(self, datetimeobj):
+ """Private method to change the Vector map date"""
date_str = datetimeobj.strftime(self.date_fmt)
libvect.Vect_set_map_date(self.c_mapinfo, ctypes.c_char_p(date_str))
map_date = property(fget=_get_map_date, fset=_set_map_date)
def _get_scale(self):
+ """Private method to obtain the Vector scale"""
return libvect.Vect_get_scale(self.c_mapinfo)
def _set_scale(self, scale):
+ """Private method to set the Vector scale"""
return libvect.Vect_set_scale(self.c_mapinfo, ctypes.c_int(scale))
scale = property(fget=_get_scale, fset=_set_scale)
def _get_comment(self):
+ """Private method to obtain the Vector comment"""
return libvect.Vect_get_comment(self.c_mapinfo)
def _set_comment(self, comm):
+ """Private method to set the Vector comment"""
return libvect.Vect_set_comment(self.c_mapinfo, ctypes.c_char_p(comm))
comment = property(fget=_get_comment, fset=_set_comment)
def _get_zone(self):
+ """Private method to obtain the Vector projection zone"""
return libvect.Vect_get_zone(self.c_mapinfo)
def _set_zone(self, zone):
+ """Private method to set the Vector projection zone"""
return libvect.Vect_set_zone(self.c_mapinfo, ctypes.c_int(zone))
zone = property(fget=_get_zone, fset=_set_zone)
def _get_proj(self):
+ """Private method to obtain the Vector projection code"""
return libvect.Vect_get_proj(self.c_mapinfo)
def _set_proj(self, proj):
+ """Private method to set the Vector projection code"""
libvect.Vect_set_proj(self.c_mapinfo, ctypes.c_int(proj))
proj = property(fget=_get_proj, fset=_set_proj)
def _get_thresh(self):
+ """Private method to obtain the Vector threshold"""
return libvect.Vect_get_thresh(self.c_mapinfo)
def _set_thresh(self, thresh):
+ """Private method to set the Vector threshold"""
return libvect.Vect_set_thresh(self.c_mapinfo, ctypes.c_double(thresh))
thresh = property(fget=_get_thresh, fset=_set_thresh)
@@ -189,31 +207,36 @@
@property
@must_be_open
def full_name(self):
+ """Return the full name of Vector"""
return libvect.Vect_get_full_name(self.c_mapinfo)
@property
@must_be_open
def maptype(self):
+ """Return the map type of Vector"""
return MAPTYPE[libvect.Vect_maptype(self.c_mapinfo)]
@property
@must_be_open
def proj_name(self):
+ """Return the project name of Vector"""
return libvect.Vect_get_proj_name(self.c_mapinfo)
def _write_header(self):
libvect.Vect_write_header(self.c_mapinfo)
def rename(self, newname):
- """Rename the map"""
+ """Method to rename the Vector map"""
if self.exist():
functions.rename(self.name, newname, 'vect')
self._name = newname
def is_3D(self):
+ """Return if the Vector is 3D"""
return bool(libvect.Vect_is_3d(self.c_mapinfo))
def exist(self):
+ """Return if the Vector exists or not"""
if self._name:
self.mapset = functions.get_mapset_vector(self._name, self.mapset)
else:
@@ -224,6 +247,7 @@
return False
def is_open(self):
+ """Return if the Vector is open"""
return (self.c_mapinfo.contents.open != 0 and
self.c_mapinfo.contents.open != libvect.VECT_CLOSED_CODE)
@@ -316,22 +340,13 @@
self.table = None
self.n_lines = 0
else:
- self.layer = self.dblinks[0].layer
- self.table = self.get_table(layer=self.layer)
+ self.layer = self.dblinks.by_layer(layer)
+ self.table = self.dblinks.by_layer(layer).table()
self.n_lines = self.table.n_rows()
self.writable = self.mapset == functions.getenv("MAPSET")
- def get_table(self, layer=None, name=None,):
- if layer is None and name is None and len(self.dblinks) == 0:
- return None
- if layer is not None:
- return self.dblinks.by_layer(layer).table()
- elif name is not None:
- return self.dblinks.by_name(name).table()
- else:
- return self.dblinks[0].table()
def close(self):
+ """Method to close the Vector"""
if hasattr(self, 'table') and self.table is not None:
self.table.conn.close()
if self.is_open():
