[GRASS-SVN] r54940 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Feb 5 09:37:52 PST 2013
Author: zarch
Date: 2013-02-05 09:37:51 -0800 (Tue, 05 Feb 2013)
New Revision: 54940
grass/trunk/lib/python/pygrass/vector/geometry.py
Add intersaction and fix some docstring
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2013-02-05 17:29:28 UTC (rev 54939)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2013-02-05 17:37:51 UTC (rev 54940)
@@ -71,6 +71,21 @@
pass
+def intersects(lineA, lineB, with_z=False):
+ """Return a list of points ::
+ >>> lineA = Line([(0, 0), (4, 0)])
+ >>> lineB = Line([(2, 2), (2, -2)])
+ >>> intersects(lineA, lineB)
+ Line([Point(2.000000, 0.000000)])
+ line = Line()
+ if libvect.Vect_line_get_intersections(lineA.c_points, lineB.c_points,
+ line.c_points, int(with_z)):
+ return line
+ else:
+ return []
# GEOMETRY
@@ -121,11 +136,16 @@
def __getitem__(self, *args):
"""Return the value stored in the attribute table. ::
- >>> attrs = Attrs(v_id, table)
- >>> attrs['LABEL']
+ >>> from grass.pygrass.vector import VectorTopo
+ >>> schools = VectorTopo('schools')
+ >>> schools.open('r')
+ >>> school = schools[1]
+ >>> attrs = Attrs(school.line, schools.table)
+ >>> attrs['TAG']
+ u'568'
#SELECT {cols} FROM {tname} WHERE {condition};
cols = args if isinstance(args[0], str) else args[0]
cur = self.table.execute(sql.SELECT_WHERE.format(cols=','.join(cols),
@@ -137,10 +157,17 @@
def __setitem__(self, key, value):
"""Set value of a given column of a table attribute. ::
- >>> attrs['LABEL'] = 'New Label'
+ >>> from grass.pygrass.functions import copy
+ >>> copy('schools', 'schools', 'vect')
+ >>> attrs['TAG'] = 'New Label'
+ >>> attrs['TAG']
+ 'New Label'
if self.writable:
#UPDATE {tname} SET {new_col} = {old_col} WHERE {condition}
values = '%s=%r' % (key, value)
@@ -185,10 +212,12 @@
>>> geo1 = Geo(c_points=points, c_cats=cats)
def __init__(self, v_id=None, c_mapinfo=None, c_points=None, c_cats=None,
- table=None, writable=False):
+ table=None, writable=False, is2D=True):
self.id = v_id # vector id
self.line = self.id
self.c_mapinfo = c_mapinfo
+ self.is2D = is2D
+ self.gtype = None
# set c_points
if c_points is None:
@@ -220,7 +249,6 @@
self.c_cats, self.id)
class Point(Geo):
"""Instantiate a Point object that could be 2 or 3D, default
parameters are 0.
@@ -247,11 +275,10 @@
- def __init__(self, x=0, y=0, z=None, is2D=True, **kargs):
+ def __init__(self, x=0, y=0, z=None, **kargs):
super(Point, self).__init__(**kargs)
if self.id is not None:
self.read()
- self.is2D = is2D
else:
self.is2D = True if z is None else False
z = z if z is not None else 0
@@ -441,13 +468,12 @@
- def __init__(self, points=None, is2D=True, **kargs):
+ def __init__(self, points=None, **kargs):
super(Line, self).__init__(**kargs)
if points is not None:
for pnt in points:
self.append(pnt)
- self.is2D = is2D
# geometry type
self.gtype = libvect.GV_LINE
@@ -967,7 +993,6 @@
class Node(object):
pass
class Boundary(Line):
