[GRASS-SVN] r54942 - in grass/trunk/gui/wxpython: core lmgr
svn_grass at osgeo.org
Tue Feb 5 10:22:07 PST 2013
Author: wenzeslaus
Date: 2013-02-05 10:22:07 -0800 (Tue, 05 Feb 2013)
New Revision: 54942
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/lmgr/giface.py
wxGUI/giface: documentation, creating interface class for doc reasons, small fix of argument, ws changes
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2013-02-05 18:14:29 UTC (rev 54941)
+++ grass/trunk/gui/wxpython/core/giface.py 2013-02-05 18:22:07 UTC (rev 54942)
@@ -22,28 +22,136 @@
import grass.script as grass
+# to disable Abstract class not referenced
+#pylint: disable=R0921
+class Layer(object):
+ """!Layer is generaly usable layer object.
+ @note Currently without specifying the interface.
+ Current implementations only provides all attributes of existing layer
+ as used in lmgr.
+class LayerList(object):
+ def GetSelectedLayers(self, checkedOnly=True):
+ """!Returns list of selected layers.
+ @note Usage of checked and selected is still subject to change.
+ Checked layers should be showed. Selected are for analyses.
+ However, this may be the same for some implementations
+ (e.g. it d.mon has all layers checked and selected).
+ raise NotImplementedError()
+class GrassInterface:
+ """!GrassInterface provides the functionality which should be available
+ to every GUI component.
+ @note The GrassInterface process is not finished.
+ def RunCmd(self, *args, **kwargs):
+ """!Executes a command.
+ def Help(self, entry):
+ """Shows a manual page for a given entry.
+ def WriteLog(self, text, wrap=None, switchPage=False, priority=1):
+ """!Writes log message.
+ @note It is not clear how the switchPage and priority should work.
+ @note Use priority rather than switchPage, switchPage will be removed.
+ def WriteCmdLog(self, line, pid=None, switchPage=True):
+ """!Writes message related to start or end of the command.
+ def WriteWarning(self, line):
+ """!Writes warning message for the user.
+ Currently used also for important messages for user.
+ Overlaps with log message with high priority.
+ def WriteError(self, line):
+ """!Writes error message for the user."""
+ def GetLayerTree(self):
+ """!Returns LayerManager's tree GUI object.
+ @note Will be removed from the interface.
+ def GetLayerList(self):
+ """!Returns a layer management object.
+ def GetMapDisplay(self):
+ """!Returns current map display.
+ @note For layer related tasks use GetLayerList().
+ @return MapFrame instance
+ @return None when no mapdisplay open
+ def GetAllMapDisplays(self):
+ """!Get list of all map displays.
+ @note Might be removed from the interface.
+ @return list of MapFrame instances
+ def GetMapWindow(self):
+ """!Returns current map window.
+ def GetProgress(self):
+ """!Returns object which shows the progress.
+ @note Some implementations may not implement this method.
class StandaloneGrassInterface():
+ """!@implements GrassInterface"""
def __init__(self):
self._gconsole = GConsole()
self._gconsole.Bind(EVT_CMD_PROGRESS, self._onCmdProgress)
self._gconsole.Bind(EVT_CMD_OUTPUT, self._onCmdOutput)
self._gconsole.Bind(EVT_WRITE_LOG,
- lambda event:
- self.WriteLog(text = event.text))
+ lambda event: self.WriteLog(text=event.text))
self._gconsole.Bind(EVT_WRITE_CMD_LOG,
- lambda event:
- self.WriteCmdLog(line = event.line))
+ lambda event: self.WriteCmdLog(line=event.line))
self._gconsole.Bind(EVT_WRITE_WARNING,
- lambda event:
- self.WriteWarning(line = event.line))
+ lambda event: self.WriteWarning(line=event.line))
self._gconsole.Bind(EVT_WRITE_ERROR,
- lambda event:
- self.WriteError(line = event.line))
+ lambda event: self.WriteError(line=event.line))
def _onCmdOutput(self, event):
"""!Print command output"""
message = event.text
- style = event.type
+ style = event.type
if style == 'warning':
self.WriteWarning(message)
@@ -67,11 +175,11 @@
self._gconsole.RunCmd(['g.manual', 'entry=%s' % entry])
- def WriteLog(self, text, wrap = None,
- switchPage = False, priority = 1):
+ switchPage=False, priority=1):
self._write(grass.message, text)
- def WriteCmdLog(self, line, pid = None, switchPage = True):
if pid:
line = '(' + str(pid) + ') ' + line
self._write(grass.message, line)
@@ -90,7 +198,7 @@
return None
"""!Get current map display.
@@ -105,4 +213,4 @@
return None
- raise NotImplementedError
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2013-02-05 18:14:29 UTC (rev 54941)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2013-02-05 18:22:07 UTC (rev 54942)
@@ -17,6 +17,11 @@
+ """!@implements core::giface::Layer
+ @note Currently implemented without specifying the interface.
+ It only provides all attributes of existing layer as used in lmgr.
def __init__(self, pydata):
self._pydata = pydata
@@ -25,15 +30,18 @@
+ """!@implements core.giface.Layer"""
def __init__(self, tree):
self._tree = tree
# def __iter__(self):
+# """!Iterates over the contents of the list."""
# for in :
-# yield
+# yield
- def GetSelectedLayers(self, checkedOnly = True):
- items = self._tree.GetSelectedLayer(multi = True, checkedOnly = True)
+ items = self._tree.GetSelectedLayer(multi=True,
+ checkedOnly=checkedOnly)
layers = []
for item in items:
layer = Layer(self._tree.GetPyData(item))
@@ -41,11 +49,19 @@
return layers
def GetLayerInfo(self, layer):
+ """!For compatibility only, will be removed."""
return Layer(self._tree.GetPyData(layer))
-class LayerManagerGrassInterface:
+class LayerManagerGrassInterface(object):
def __init__(self, lmgr):
+ """!Costructor is specific to the current implementation.
+ Uses Layer Manager object including its private attributes.
+ (It encapsulates existing Layer Manager so access to private members
+ is intention.)
self.lmgr = lmgr
@@ -70,24 +86,15 @@
self.lmgr._gconsole.WriteError(line = line)
- return LayerList(self.lmgr.GetLayerTree())
+ return self.lmgr.GetLayerTree()
- """!Get current map display.
- @return MapFrame instance
- @return None no mapdisplay open
return self.lmgr.GetMapDisplay(onlyCurrent=True)
- """!Get list of all map displays.
- @return list of MapFrame instances
return self.lmgr.GetMapDisplay(onlyCurrent=False)
