[GRASS-SVN] r54964 - grass-addons/grass6/raster/r.basin
svn_grass at osgeo.org
Thu Feb 7 01:32:25 PST 2013
Author: madi
Date: 2013-02-07 01:32:25 -0800 (Thu, 07 Feb 2013)
New Revision: 54964
grass-addons/grass6/raster/r.basin/r.basin.py
switched from SFD to MFD algorithm
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py 2013-02-07 08:51:48 UTC (rev 54963)
+++ grass-addons/grass6/raster/r.basin/r.basin.py 2013-02-07 09:32:25 UTC (rev 54964)
@@ -19,6 +19,7 @@
#% description: Morphometric characterization of river basins
#% keywords: raster
#%end
#%option
#% key: map
#% type: string
@@ -27,6 +28,7 @@
#% description: Name of elevation raster map
#% required: yes
#%end
#%option
#% key: prefix
#% type: string
@@ -34,6 +36,7 @@
#% description: output prefix (must start with a letter)
#% required: yes
#%end
#%option
#% key: easting
#% type: double
@@ -41,6 +44,7 @@
#% description: east coordinate of outlet point (must belong to river network)
#% required : yes
#%end
#%option
#% key: northing
#% type: double
@@ -48,6 +52,7 @@
#% description: north coordinate of outlet point (must belong to river network)
#% required : yes
#%end
#%option
#% key: threshold
#% type: double
@@ -55,10 +60,12 @@
#% description: threshold
#% required : no
#%end
#%flag
#% key: a
#% description: Use default threshold (1km^2)
#%END
#%flag
#% key: c
#% description: No maps output
@@ -127,14 +134,15 @@
accumulation = r_accumulation,
drainage = r_drainage,
convergence = 5,
- flags = 'a',
+ flags = 'af',
overwrite = True)
# Managing flag
if autothreshold :
- info_region = grass.read_command('g.region', flags = 'p', rast = '%s' % (r_elevation))
- dict_region = grass.parse_key_val(info_region, ':')
- resolution = float(dict_region['nsres'])
+ # info_region = grass.read_command('g.region', flags = 'p', rast = '%s' % (r_elevation))
+ # dict_region = grass.parse_key_val(info_region, ':')
+ # resolution = float(dict_region['nsres'])
+ resolution = grass.region()['nsres']
th = 1000000 / (resolution**2)
grass.message( "threshold : %s" % th )
else :
