[GRASS-SVN] r54969 - grass/trunk/db/db.select
svn_grass at osgeo.org
Thu Feb 7 05:43:19 PST 2013
Author: martinl
Date: 2013-02-07 05:43:06 -0800 (Thu, 07 Feb 2013)
New Revision: 54969
grass/trunk/db/db.select/main.c
db.select: rename paramater `vs` to `vseparator`
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2013-02-07 12:20:48 UTC (rev 54968)
+++ grass/trunk/db/db.select/main.c 2013-02-07 13:43:06 UTC (rev 54969)
@@ -218,8 +218,8 @@
fs->guisection = _("Format");
vs = G_define_standard_option(G_OPT_F_SEP);
- vs->key = "vs";
- vs->label = _("Output vertical record separator");
+ vs->key = "vseparator";
+ vs->label = _("Vertical record separator (requires -v flag)");
vs->answer = NULL;
vs->guisection = _("Format");
