[GRASS-SVN] r54975 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Thu Feb 7 08:13:21 PST 2013
Author: lucadelu
Date: 2013-02-07 08:13:20 -0800 (Thu, 07 Feb 2013)
New Revision: 54975
grass/trunk/lib/python/pygrass/vector/sql.py
grass/trunk/lib/python/pygrass/vector/table.py
modify some doctest, add method to drop table
Modified: grass/trunk/lib/python/pygrass/vector/sql.py
--- grass/trunk/lib/python/pygrass/vector/sql.py 2013-02-07 16:11:49 UTC (rev 54974)
+++ grass/trunk/lib/python/pygrass/vector/sql.py 2013-02-07 16:13:20 UTC (rev 54975)
@@ -18,7 +18,7 @@
# SQL
CREATE_TAB = "CREATE TABLE {tname}({coldef})"
+DROP_TAB = "DROP TABLE {tname}"
#ALTER TABLE
ADD_COL = "ALTER TABLE {tname} ADD COLUMN {cname} {ctype};"
DROP_COL = "ALTER TABLE {tname} DROP COLUMN {cname};"
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2013-02-07 16:11:49 UTC (rev 54974)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2013-02-07 16:13:20 UTC (rev 54975)
@@ -25,6 +25,18 @@
def get_path(path):
+ """Return the full path to the database; replacing environment variable
+ with real values ::
+ >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
+ >>> new_path = get_path(path)
+ >>> from grass.script.core import gisenv
+ >>> import os
+ >>> new_path2 = os.path.join(gisenv()['GISDBASE'], gisenv()['LOCATION_NAME'],
+ ... gisenv()['MAPSET'], 'sqlite', sqlite.db)
+ >>> new_path == new_path2
+ True
if "$" not in path:
return path
else:
@@ -61,22 +73,26 @@
return "Filters(%r)" % self.get_sql()
def select(self, *args):
+ """Create the select query"""
cols = ', '.join(args) if args else '*'
select = sql.SELECT[:-1]
self._select = select.format(cols=cols, tname=self.tname)
return self
def where(self, condition):
+ """Create the where condition"""
self._where = 'WHERE {condition}'.format(condition=condition)
return self
def order_by(self, orderby):
+ """Create the order by condition"""
if not isinstance(orderby, str):
orderby = ', '.join(orderby)
self._orderby = 'ORDER BY {orderby}'.format(orderby=orderby)
return self
def limit(self, number):
+ """Create the limit condition"""
if not isinstance(number, int):
raise ValueError("Must be an integer.")
else:
@@ -84,6 +100,7 @@
return self
def get_sql(self):
+ """Return the SQL query"""
sql_list = list()
if self._select is None:
self.select()
@@ -98,6 +115,7 @@
return "%s;" % ' '.join(sql_list)
def reset(self):
+ """Clean internal variables"""
self._select = None
self._where = None
self._orderby = None
@@ -113,19 +131,19 @@
For a sqlite table: ::
>>> import sqlite3
- >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
- >>> cols_sqlite = Columns('boundary_municp_sqlite',
+ >>> cols_sqlite = Columns('census',
... sqlite3.connect(get_path(path)))
>>> cols_sqlite.tname
- 'boundary_municp_sqlite'
+ 'census'
For a postgreSQL table: ::
- >>> import psycopg2 as pg
- >>> cols_pg = Columns('boundary_municp_pg',
- ... pg.connect('host=localhost dbname=grassdb'))
- >>> cols_pg.tname
- 'boundary_municp_pg'
+ >>> import psycopg2 as pg #doctest: +SKIP
+ >>> cols_pg = Columns('boundary_municp_pg',
+ ... pg.connect('host=localhost dbname=grassdb')) #doctest: +SKIP
+ >>> cols_pg.tname #doctest: +SKIP
+ 'boundary_municp_pg' #doctest: +SKIP
@@ -162,15 +180,15 @@
"""Return True if is a psycopg connection. ::
>>> import sqlite3
>>> cols_sqlite.is_pg()
False
- >>> cols_pg.is_pg()
+ >>> cols_pg.is_pg() #doctest: +SKIP
True
@@ -219,8 +237,8 @@
Remove it is used to remove a columns.::
>>> import sqlite3
>>> cols_sqlite.sql_descr() # doctest: +ELLIPSIS
u'cat integer, OBJECTID integer, AREA double precision, ...'
@@ -241,8 +259,8 @@
"""Return a list with the column types. ::
>>> import sqlite3
>>> cols_sqlite.types() # doctest: +ELLIPSIS
[u'integer', u'integer', ...]
@@ -262,8 +280,8 @@
>>> import sqlite3
>>> cols_sqlite.names() # doctest: +ELLIPSIS
[u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ...]
@@ -290,8 +308,8 @@
"""Return a list of tuple with column name and column type. ::
>>> import sqlite3
>>> cols_sqlite.items() # doctest: +ELLIPSIS
[(u'cat', u'integer'), ...]
@@ -305,21 +323,12 @@
return self.odict.items()
- def create(self, cols):
- cur = self.conn.cursor()
- coldef = ',\n'.join(['%s %s' % col for col in cols])
- cur.execute(sql.CREATE_TAB.format(tname=self.tname, coldef=coldef))
- self.conn.commit()
- cur.close()
- self.update_odict()
def add(self, col_name, col_type):
"""Add a new column to the table. ::
>>> import sqlite3
>>> cols_sqlite.add('n_pizza', 'int4')
>>> 'n_pizza' in cols_sqlite
@@ -350,8 +359,8 @@
"""Rename a column of the table. ::
>>> import sqlite3
>>> cols_sqlite.rename('n_pizza', 'n_pizzas') # doctest: +ELLIPSIS
@@ -394,8 +403,8 @@
"""Change the column type. ::
>>> import sqlite3
>>> cols_sqlite.cast('n_pizzas', 'float8') # doctest: +ELLIPSIS
@@ -428,8 +437,8 @@
"""Drop a column from the table. ::
>>> import sqlite3
>>> cols_sqlite.drop('n_pizzas') # doctest: +ELLIPSIS
>>> 'n_pizzas' in cols_sqlite
@@ -468,18 +477,18 @@
It is possible to define a Link object or given all the information
(layer, name, table name, key, database, driver): ::
- >>> link = Link(1, 'link0', 'boundary_municp_sqlite', 'cat',
- ... '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db', 'sqlite')
+ >>> link = Link(1, 'link0', 'census', 'cat',
+ ... '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db', 'sqlite')
>>> link.number
1
>>> link.name
'link0'
>>> link.table_name
+ 'census'
>>> link.key
'cat'
>>> link.database
- '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
+ '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
>>> link.driver
'sqlite'
>>> link
@@ -583,8 +592,8 @@
def connection(self):
"""Return a connection object. ::
... 'sqlite')
>>> conn = link.connection()
>>> cur = conn.cursor()
@@ -616,12 +625,12 @@
def table(self):
"""Return a Table object. ::
... 'sqlite')
>>> table = link.table()
>>> table.filters.select('cat', 'COUNTY', 'PERIMETER')
- Filters('SELECT cat, COUNTY, PERIMETER FROM boundary_municp_sqlite;')
+ Filters('SELECT cat, COUNTY, PERIMETER FROM census;')
>>> cur = table.execute()
>>> cur.fetchone()
(1, u'SURRY', 1415.331)
@@ -634,15 +643,15 @@
def info(self):
"""Print information of the link. ::
... 'sqlite')
>>> link.info()
layer: 1
- table: boundary_municp_sqlite
+ table: census
key: cat
- database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
+ database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
driver: sqlite
@@ -659,19 +668,15 @@
"""Interface containing link to the table DB. ::
>>> from grass.pygrass.vector import VectorTopo
- >>> municip = VectorTopo('boundary_municp_sqlite')
- >>> municip.open()
- >>> dblinks = DBlinks(municip.c_mapinfo)
+ >>> cens = VectorTopo('census')
+ >>> cens.open()
+ >>> dblinks = DBlinks(cens.c_mapinfo)
>>> dblinks
- DBlinks([Link(1, boundary_municp, sqlite)])
- >>> dblinks[1]
- Link(1, boundary_municp, sqlite)
- >>> dblinks[0] # doctest: +ELLIPSIS
- Traceback (most recent call last):
- TypeError: The index must be != 0.
- >>> dblinks['boundary_municp']
+ DBlinks([Link(1, census, sqlite)])
+ >>> dblinks[0]
+ Link(1, census, sqlite)
+ >>> dblinks['census']
@@ -716,7 +721,7 @@
"""Add a new link. ::
+ >>> municip = VectorTopo('census')
>>> municip.open()
>>> dblinks
@@ -734,11 +739,11 @@
link.layer, link.name, link.table_name,
link.key, link.database, link.driver)
- def remove(self, key):
- """Remove a link. ::
+ def remove(self, key, force=False):
+ """Remove a link. If force set to true remove also the table ::
>>> municip.open()
>>> dblinks
@@ -749,6 +754,10 @@
+ if force:
+ link = self.by_name(key)
+ table = link.table()
+ table._drop()
if isinstance(key, str):
key = self.from_name_to_num(key)
libvect.Vect_map_del_dblink(self.c_mapinfo, key)
@@ -764,11 +773,11 @@
>>> import sqlite3
- >>> tab_sqlite = Table(name='boundary_municp_sqlite',
+ >>> tab_sqlite = Table(name='census',
... connection=sqlite3.connect(get_path(path)))
>>> tab_sqlite.name
+ 'census'
>>> import psycopg2
>>> tab_pg = Table('boundary_municp_pg',
... psycopg2.connect('host=localhost dbname=grassdb',
@@ -779,9 +788,11 @@
def _get_name(self):
+ """Private method to return the name of table"""
return self._name
def _set_name(self, new_name):
+ """Private method to set the name of table"""
old_name = self._name
cur.execute(sql.RENAME_TAB.format(old_name=old_name,
@@ -804,11 +815,11 @@
>>> import sqlite3
>>> tab_sqlite
- Table('boundary_municp_sqlite')
+ Table('census')
@@ -819,10 +830,28 @@
return (cur.fetchone() for _ in xrange(self.__len__()))
def __len__(self):
- """Return the nuber of rows"""
+ """Return the number of rows"""
return self.n_rows()
+ def _drop(self, name=None):
+ """Private method to drop table from database"""
+ if name:
+ name = name
+ else:
+ name = self.name
+ cur = self.conn.cursor()
+ cur.execute(sql.DROP_TAB.format(tname=name))
def n_rows(self):
+ >>> import sqlite3
+ ... connection=sqlite3.connect(get_path(path)))
+ >>> tab_sqlite.n_rows()
+ 2537
cur.execute(sql.SELECT.format(cols='Count(*)', tname=self.name))
number = cur.fetchone()[0]
@@ -834,11 +863,11 @@
return a cursor object. ::
>>> import sqlite3
>>> tab_sqlite.filters.select('cat', 'COUNTY').order_by('AREA')
- Filters('SELECT cat, COUNTY FROM boundary_municp_sqlite ORDER BY AREA;')
+ Filters('SELECT cat, COUNTY FROM census ORDER BY AREA;')
>>> cur = tab_sqlite.execute()
>>> cur.fetchone()
(1, u'SURRY')
@@ -855,13 +884,28 @@
raise ValueError("The SQL is not correct:\n%r" % sqlc)
def insert(self, values, many=False):
+ """Insert a new row"""
if many:
return cur.executemany(self.columns.insert_str, values)
return cur.execute(self.columns.insert_str, values)
def update(self, key, values):
+ """Update a """
vals = list(values)
vals.append(key)
return cur.execute(self.columns.update_str, vals)
+ def create(self, cols, name=None):
+ """Create a new table"""
+ coldef = ',\n'.join(['%s %s' % col for col in cols])
+ if name:
+ newname = name
+ else:
+ newname = self.name
+ cur.execute(sql.CREATE_TAB.format(tname=newname, coldef=coldef))
+ self.conn.commit()
+ cur.close()
+ self.columns.update_odict()
