[GRASS-SVN] r55018 - grass/trunk/lib/db/sqlp
svn_grass at osgeo.org
Tue Feb 12 12:21:39 PST 2013
Author: neteler
Date: 2013-02-12 12:21:39 -0800 (Tue, 12 Feb 2013)
New Revision: 55018
grass/trunk/lib/db/sqlp/sql.html
+concatenate example; cosmetics
Modified: grass/trunk/lib/db/sqlp/sql.html
--- grass/trunk/lib/db/sqlp/sql.html 2013-02-12 16:43:22 UTC (rev 55017)
+++ grass/trunk/lib/db/sqlp/sql.html 2013-02-12 20:21:39 UTC (rev 55018)
@@ -30,7 +30,7 @@
<tr><td><a href="grass-dbf.html">dbf</a></td><td>DBF files. Data are stored in DBF files.</td>
<td><a href="http://shapelib.maptools.org/dbf_api.html">http://shapelib.maptools.org/dbf_api.html</a></td></tr>
-<tr><td><a href="grass-sqlite.html">sqlite</a></td><td>SQLite embedded database.</td>
+<tr><td><a href="grass-sqlite.html">sqlite</a></td><td>SQLite embedded database (GRASS 7 default DB backend).</td>
<td><a href="http://sqlite.org/">http://sqlite.org/</a></td></tr>
<tr><td><a href="grass-pg.html">pg</a></td><td>PostgreSQL RDBMS.</td>
@@ -154,9 +154,16 @@
where="z_value <> 'N/A'"
</pre></div>
+<p><b>Example</b> of concatenating fields (does not work for DBF driver):
+<div class="code"><pre>
+v.db.update vectormap column=column3 qcolumn="column1 || column2"
+</pre></div>
<h2>SEE ALSO</h2>
<em>
+<a href="v.db.update.html">v.db.update</a>
+<p>
<a href="databaseintro.html">Database management in GRASS GIS</a>,
<a href="database.html">Help pages for database modules</a>
</em>
