[GRASS-SVN] r55027 - grass/trunk/lib/db/sqlp
svn_grass at osgeo.org
Wed Feb 13 01:05:37 PST 2013
Author: martinl
Date: 2013-02-13 01:05:37 -0800 (Wed, 13 Feb 2013)
New Revision: 55027
grass/trunk/lib/db/sqlp/sql.html
sql.html: update manual (formatting issues)
Modified: grass/trunk/lib/db/sqlp/sql.html
--- grass/trunk/lib/db/sqlp/sql.html 2013-02-13 08:34:39 UTC (rev 55026)
+++ grass/trunk/lib/db/sqlp/sql.html 2013-02-13 09:05:37 UTC (rev 55027)
@@ -1,15 +1,19 @@
<!-- meta page description: SQL support in GRASS GIS -->
-GRASS can use various RDBMS and embedded databases. SQL queries are
-directly passed to the underlying database system. The set of
-supported SQL commands depends on the RDMBS and driver selected.
+GRASS can use various RDBMS
+(<a href="http://en.wikipedia.org/wiki/Relational_database_management_system">Relational
+database management system</a>) and embedded databases. SQL
+(<a href="http://en.wikipedia.org/wiki/Sql">Structured Query
+Language</a>) queries are directly passed to the underlying database
+system. The set of supported SQL commands depends on the RDMBS and
+database driver selected.
-<h2>Drivers</h2>
+<h2>Database drivers</h2>
-The list of available drivers can vary in various binary distributions
-of GRASS.
+The list of available database drivers can vary in various binary
+distributions of GRASS:<br><br>
-<table border=1 >
+<table class="border">
<tr><td><a href="grass-dbf.html">dbf</a></td><td>DBF files. Data are stored in DBF files.</td>
<td><a href="http://shapelib.maptools.org/dbf_api.html">http://shapelib.maptools.org/dbf_api.html</a></td></tr>
@@ -27,16 +31,14 @@
<tr><td><a href="grass-odbc.html">odbc</a></td><td>UnixODBC. (PostgreSQL, Oracle, etc.)</td>
<td><a href="http://www.unixodbc.org/">http://www.unixodbc.org/</a></td></tr>
</table>
<h2>NOTES</h2>
<ul>
<li> SQL does not support '.' (dots) in table names.
-<li> Supported table name characters are only:<br>
- [A-Za-z][A-Za-z0-9_]*
+<li> Supported table name characters are only: <br>
+<div class="code"><pre>[A-Za-z][A-Za-z0-9_]*</pre></div>
<li> A table name must start with a character, not a number.
<li> Text-string matching requires the text part to be 'single quoted'.
When run from the command line multiple queries should be contained
@@ -44,16 +46,19 @@
d.vect map where="individual='juvenile' and area='beach'"
</pre></div>
-<li> An error message such as "dbmi: Protocol error" either indicates an invalid column name
- or an unsupported column type (then the GRASS SQL parser needs to be extended).
+<li> An error message such as "<tt>dbmi: Protocol
+ error</tt>" either indicates an invalid column name or an
+ unsupported column type (then the GRASS SQL parser needs to be
+ extended).
<li> DBF column names are limited to 10 characters (DBF API definition)
</ul>
<h2>EXAMPLES</h2>
-Display all vector points except for LAMAR valley and <i>extensive
-trapping</i> (brackets are superfluous in this example):
+Display all vector points except for <i>LAMAR</i> valley
+and <i>extensive trapping</i> (brackets are superfluous in this
+example):
d.vect trapping_sites_points fcol=black icon=basic/diamond col=white size=13 \
@@ -61,7 +66,7 @@
</pre></div>
<p>
-Select all attributes from table where str1 column values are not 'No
+Select all attributes from table where <i>str1</i> column values are not 'No
Name':
@@ -69,17 +74,15 @@
</pre></div>
<p>
-<p><b>Example</b> of subquery expressions from a list (does not work
+<p>Example of subquery expressions from a list (does not work
for DBF driver):
v.db.select mysites where="id IN ('P04', 'P05')"
</pre></div>
+<p>Example of pattern matching:
-<p><b>Example</b> of pattern matching:
# field contains string:
@@ -95,7 +98,7 @@
v.db.select mysites where="id LIKE 'P%'"
</pre></div>
-<p><b>Example</b> of null handling:
+<p>Example of null handling:
v.db.addcolumn map=roads col="nulltest int"
@@ -104,8 +107,7 @@
v.db.update map=roads col=nulltest value=2 where="cat <= 2"
</pre></div>
-<p><b>Examples</b> of complex expressions in updates (using v.db.*
+<p>Examples of complex expressions in updates (using <tt>v.db.*</tt>
modules):
@@ -114,8 +116,7 @@
v.db.update map=roads col=exprtest value=cat/nulltest+cat where=cat=1
</pre></div>
-<p><b>Examples</b> of complex expressions in updates (using db.*
+<p>Examples of complex expressions in updates (using <tt>db.*</tt>
modules):
@@ -126,7 +127,6 @@
echo "UPDATE roads SET exprtest=cat/3*(cat+1) WHERE exprtest IS NULL" | db.execute"
</pre></div>
<p>
Instead of creating and updating new columns with an expression, you
can use the expression directly in a command:
@@ -136,8 +136,7 @@
d.vect roads where="cat>exprtest"
</pre></div>
-<p><b>Example</b> of changing a SQL type (type casting, does not work
+<p>Example of changing a SQL type (type casting, does not work
for DBF driver):
@@ -152,7 +151,7 @@
where="z_value <> 'N/A'"
</pre></div>
-<p><b>Example</b> of concatenating fields (does not work for DBF
+<p>Example of concatenating fields (does not work for DBF
driver):
@@ -162,6 +161,9 @@
<h2>SEE ALSO</h2>
<em>
+<a href="db.select.html">db.select</a>,
+<a href="db.execute.html">db.execute</a>,
+<a href="v.db.select.html">v.db.select</a>,
<a href="v.db.update.html">v.db.update</a>
</em>
