[GRASS-SVN] r55029 - in grass/trunk: man vector/v.vol.rst
svn_grass at osgeo.org
Wed Feb 13 01:14:56 PST 2013
Author: martinl
Date: 2013-02-13 01:14:56 -0800 (Wed, 13 Feb 2013)
New Revision: 55029
grass/trunk/man/grassdocs.css
grass/trunk/vector/v.vol.rst/main.c
update css: collapse table only for class 'border'
Modified: grass/trunk/man/grassdocs.css
--- grass/trunk/man/grassdocs.css 2013-02-13 09:06:20 UTC (rev 55028)
+++ grass/trunk/man/grassdocs.css 2013-02-13 09:14:56 UTC (rev 55029)
@@ -76,7 +76,7 @@
-moz-border-radius: 6px ;
-table {
+table.border {
border-collapse:collapse;
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2013-02-13 09:06:20 UTC (rev 55028)
+++ grass/trunk/vector/v.vol.rst/main.c 2013-02-13 09:14:56 UTC (rev 55029)
@@ -36,18 +36,16 @@
#include <grass/raster.h>
#include <grass/site.h>
#include <grass/vector.h>
-#include "userglobs.h"
-/* include G3d defs */
+#include <grass/bitmap.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
#include <grass/raster3d.h>
+#include "userglobs.h"
#include "oct.h"
#include "surf.h"
#include "dataoct.h"
#include "user.h"
-#include <grass/bitmap.h>
-#include <grass/dbmi.h>
-#include <grass/glocale.h>
double /* pargr */ xmin, xmax, ymin, ymax, zmin, zmax, wmin, wmax;
double /* norm */ xmin0, xmax0, ymin0, ymax0, zmin0, zmax0, wmin0, wmax0,
@@ -207,7 +205,7 @@
double amin1(double, double);
int max1();
int min1();
- int per, npmin;
+ int npmin;
int ii, i, n_rows, n_cols, n_levs;
double x_orig, y_orig, z_orig;
char dminchar[64];
@@ -246,29 +244,23 @@
_("Interpolates point data to a 3D raster map using "
"regularized spline with tension (RST) algorithm.");
- parm.input = G_define_option();
- parm.input->key = "input";
- parm.input->type = TYPE_STRING;
+ parm.input = G_define_standard_option(G_OPT_V_INPUT);
parm.input->required = YES;
- parm.input->gisprompt = "old,vector,vector";
- parm.input->description = _("Name of the vector map with input x,y,z,w");
- parm.cellinp = G_define_option();
+ parm.input->label = _("Name of input 3D vector points map");
+ parm.input->description = NULL; /* no OGR support */
+ parm.cellinp = G_define_standard_option(G_OPT_R_INPUT);
parm.cellinp->key = "cellinp";
- parm.cellinp->type = TYPE_STRING;
parm.cellinp->required = NO;
- parm.cellinp->gisprompt = "old,cell,raster";
parm.cellinp->description =
- _("Name of the surface raster map for cross-section");
+ _("Name of input surface raster map for cross-section");
- parm.colnum = G_define_option();
+ parm.colnum = G_define_standard_option(G_OPT_DB_COLUMN);
parm.colnum->key = "wcolumn";
- parm.colnum->type = TYPE_STRING;
parm.colnum->required = NO;
parm.colnum->description =
- _("Name of the column containing w attribute to interpolate");
- parm.colnum->answer = "flt1";
+ _("Name of column containing w attribute to interpolate");
parm.fi = G_define_option();
parm.fi->key = "tension";
parm.fi->type = TYPE_DOUBLE;
@@ -285,38 +277,31 @@
parm.rsm->description = _("Smoothing parameter");
parm.rsm->guisection = _("Settings");
- parm.scol = G_define_option();
+ parm.scol = G_define_standard_option(G_OPT_DB_COLUMN);
parm.scol->key = "scolumn";
- parm.scol->type = TYPE_STRING;
parm.scol->required = NO;
parm.scol->description =
- _("Name of the column with smoothing parameters");
+ _("Name of column with smoothing parameters");
parm.scol->guisection = _("Settings");
parm.wheresql = G_define_standard_option(G_OPT_DB_WHERE);
- parm.devi = G_define_option();
+ parm.devi = G_define_standard_option(G_OPT_V_OUTPUT);
parm.devi->key = "devi";
- parm.devi->type = TYPE_STRING;
parm.devi->required = NO;
- parm.devi->gisprompt = "new,vector,vector";
- parm.devi->description = _("Output deviations vector point file");
- parm.devi->guisection = _("Analysis");
+ parm.devi->description = _("Name for output deviations vector map");
+ parm.devi->guisection = _("Outputs");
- parm.cvdev = G_define_option();
+ parm.cvdev = G_define_standard_option(G_OPT_V_OUTPUT);
parm.cvdev->key = "cvdev";
- parm.cvdev->type = TYPE_STRING;
parm.cvdev->required = NO;
- parm.cvdev->gisprompt = "new,vector,vector";
- parm.cvdev->description = _("Output cross-validation vector map");
- parm.cvdev->guisection = _("Analysis");
+ parm.cvdev->description = _("Name for output cross-validation vector map");
+ parm.cvdev->guisection = _("Outputs");
- parm.maskmap = G_define_option();
+ parm.maskmap = G_define_standard_option(G_OPT_R_INPUT);
parm.maskmap->key = "maskmap";
- parm.maskmap->type = TYPE_STRING;
parm.maskmap->required = NO;
- parm.maskmap->gisprompt = "old,cell,raster";
- parm.maskmap->description = _("Name of the raster map used as mask");
+ parm.maskmap->description = _("Name of input raster map used as mask");
parm.segmax = G_define_option();
parm.segmax->key = "segmax";
@@ -369,76 +354,53 @@
parm.zmult->description = _("Conversion factor for z-values");
parm.zmult->guisection = _("Settings");
- parm.cellout = G_define_option();
+ parm.cellout = G_define_standard_option(G_OPT_R_OUTPUT);
parm.cellout->key = "cellout";
- parm.cellout->type = TYPE_STRING;
parm.cellout->required = NO;
- parm.cellout->gisprompt = "new,cell,raster";
- parm.cellout->description = _("Output cross-section raster map");
- parm.cellout->guisection = _("Output_options");
+ parm.cellout->description = _("Name for output cross-section raster map");
+ parm.cellout->guisection = _("Outputs");
- parm.outz = G_define_option();
+ parm.outz = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.outz->key = "elev";
- parm.outz->type = TYPE_STRING;
parm.outz->required = NO;
- parm.outz->multiple = NO;
- parm.outz->gisprompt = "new,grid3,3d raster";
- parm.outz->description = _("Output elevation g3d-file");
+ parm.outz->description = _("Name for output elevation 3D raster map");
- parm.gradient = G_define_option();
+ parm.gradient = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.gradient->key = "gradient";
- parm.gradient->type = TYPE_STRING;
parm.gradient->required = NO;
- parm.gradient->multiple = NO;
- parm.gradient->gisprompt = "new,grid3,3d raster";
- parm.gradient->description = _("Output gradient magnitude g3d-file");
- parm.gradient->guisection = _("Output_options");
+ parm.gradient->description = _("Name for output gradient magnitude 3D raster map");
+ parm.gradient->guisection = _("Outputs");
- parm.aspect1 = G_define_option();
+ parm.aspect1 = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.aspect1->key = "aspect1";
- parm.aspect1->type = TYPE_STRING;
parm.aspect1->required = NO;
- parm.aspect1->multiple = NO;
- parm.aspect1->gisprompt = "new,grid3,3d raster";
parm.aspect1->description =
- _("Output gradient horizontal angle g3d-file");
- parm.aspect1->guisection = _("Output_options");
+ _("Name for output gradient horizontal angle 3D raster map");
+ parm.aspect1->guisection = _("Outputs");
- parm.aspect2 = G_define_option();
+ parm.aspect2 = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.aspect2->key = "aspect2";
- parm.aspect2->type = TYPE_STRING;
parm.aspect2->required = NO;
- parm.aspect2->multiple = NO;
- parm.aspect2->gisprompt = "new,grid3,3d raster";
- parm.aspect2->description = _("Output gradient vertical angle g3d-file");
- parm.aspect2->guisection = _("Output_options");
+ parm.aspect2->description = _("Name for output gradient vertical angle 3D raster map");
+ parm.aspect2->guisection = _("Outputs");
- parm.ncurv = G_define_option();
+ parm.ncurv = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.ncurv->key = "ncurv";
- parm.ncurv->type = TYPE_STRING;
parm.ncurv->required = NO;
- parm.ncurv->multiple = NO;
- parm.ncurv->gisprompt = "new,grid3,3d raster";
- parm.ncurv->description = _("Output change of gradient g3d-file");
- parm.ncurv->guisection = _("Output_options");
+ parm.ncurv->description = _("Name for output change of gradient 3D raster map");
+ parm.ncurv->guisection = _("Outputs");
- parm.gcurv = G_define_option();
+ parm.gcurv = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.gcurv->key = "gcurv";
- parm.gcurv->type = TYPE_STRING;
parm.gcurv->required = NO;
- parm.gcurv->multiple = NO;
- parm.gcurv->gisprompt = "new,grid3,3d raster";
- parm.gcurv->description = _("Output gaussian curvature g3d-file");
- parm.gcurv->guisection = _("Output_options");
+ parm.gcurv->description = _("Name for output gaussian curvature 3D raster map");
+ parm.gcurv->guisection = _("Outputs");
- parm.mcurv = G_define_option();
+ parm.mcurv = G_define_standard_option(G_OPT_R3_OUTPUT);
parm.mcurv->key = "mcurv";
- parm.mcurv->type = TYPE_STRING;
parm.mcurv->required = NO;
- parm.mcurv->multiple = NO;
- parm.mcurv->gisprompt = "new,grid3,3d raster";
- parm.mcurv->description = _("Output mean curvature g3d-file");
- parm.mcurv->guisection = _("Output_options");
+ parm.mcurv->description = _("Name for output mean curvature 3D raster map");
+ parm.mcurv->guisection = _("Outputs");
flag.cv = G_define_flag();
flag.cv->key = 'c';
@@ -475,7 +437,6 @@
if (!parm.dmin1->answer)
parm.dmin1->answer = dminchar;
- per = 1; /*flag.per->answer; */
iw2 = 1;
sig1 = 0;
input = parm.input->answer;
@@ -513,9 +474,10 @@
rsm = -1; /* used in InterpLib to indicate variable smoothing */
if (cv != (cvdev != NULL))
- G_fatal_error(_("Both crossvalidation options (-c, cvdev) must be specified"));
+ G_fatal_error(_("Both crossvalidation options (-%c, %s) must be specified"),
+ flag.cv->key, parm.cvdev->key);
if (cv && devi != NULL)
- G_fatal_error(_("Both crossvalidation and deviations file specified"));
+ G_fatal_error(_("Both crossvalidation and deviations must be specified"));
if (cellinp == NULL && outz == NULL && cellout == NULL && gradient == NULL
&& aspect1 == NULL && aspect2 == NULL && ncurv == NULL &&
gcurv == NULL && mcurv == NULL) {
@@ -526,8 +488,8 @@
(cellinp != NULL || outz != NULL || cellout != NULL ||
gradient != NULL || aspect1 != NULL || aspect2 != NULL ||
ncurv != NULL || gcurv != NULL || mcurv != NULL || devi != NULL))
- G_fatal_error
- ("The crossvalidation cannot be computed simultanuously with output grids or devi file");
+ G_fatal_error("Crossvalidation cannot be computed simultanuously "
+ "with output grids or devi file");
z_orig_in = z_orig;
tb_res_in = tb_res;
@@ -574,14 +536,14 @@
if ((data =
data_new(x_orig, y_orig, z_orig, n_rows, n_cols, n_levs, 0)) == NULL)
- G_fatal_error("cannot create octdata");
+ G_fatal_error("Unable to create octdata");
if ((functions =
OT_functions_new(oct_compare, oct_divide_data, oct_add_data,
oct_intersect, oct_division_check,
oct_get_points)) == NULL)
- G_fatal_error("cannot create octfunc");
+ G_fatal_error("Unable to create octfunc");
if ((tree = OT_tree_new(data, NULL, NULL, functions, 0)) == NULL)
- G_fatal_error("cannot create octtree");
+ G_fatal_error("Unable to create octtree");
root = tree;
@@ -590,7 +552,7 @@
if (TESTOUT) {
if ((fd4 = fopen("testout", "w+")) == NULL)
- G_fatal_error("Cannot open testout");
+ G_fatal_error("Unable To open testout");
Vect_set_open_level(1);
@@ -637,7 +599,7 @@
if (db_execute_immediate(driver, &sql) != DB_OK) {
db_close_database(driver);
db_shutdown_driver(driver);
- G_fatal_error(_("Cannot create table: %s"), db_get_string(&sql));
+ G_fatal_error(_("Unable To create table: %s"), db_get_string(&sql));
count = 1;
@@ -665,14 +627,11 @@
if (!
(fwrite
(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_cell)))
- clean_fatal_error
- ("Not enough disk space--cannot write temp files");
+ clean_fatal_error(_("Not enough disk space - cannot write temp files"));
ertot = 0.;
- if (per)
- fprintf(stderr, "Percent complete: ");
out_cond1 = (outz != NULL) || (gradient != NULL) || (aspect1 != NULL)
|| (aspect2 != NULL) || (gcurv != NULL) || (mcurv != NULL) ||
(ncurv != NULL);
@@ -681,133 +640,126 @@
/* allocating temp array for writing to corresponding temp file */
zero_array1 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array1)
- clean_fatal_error("Not enough memory for zero_array1\n");
+ clean_fatal_error(_("Not enough memory"));
for (i = 0; i < n_cols; i++)
zero_array1[i] = 0.;
Tmp_file_z = G_tempfile();
if (NULL == (Tmp_fd_z = fopen(Tmp_file_z, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_z);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_z);
clean_fatal_error(msg);
/* filling temp file with zeroes */
for (i = 0; i < n_levs * n_rows; i++) {
if (!(fwrite(zero_array1, sizeof(float), n_cols, Tmp_fd_z)))
- clean_fatal_error
- ("Not enough disk space -- cannot write temp files");
if (gradient != NULL) {
zero_array2 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array2)
- clean_fatal_error("Not enough memory for zero_array2\n");
zero_array2[i] = 0.;
Tmp_file_dx = G_tempfile();
if (NULL == (Tmp_fd_dx = fopen(Tmp_file_dx, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_dx);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_dx);
if (!(fwrite(zero_array2, sizeof(float), n_cols, Tmp_fd_dx)))
- clean_fatal_error
if (aspect1 != NULL) {
zero_array3 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array3)
- clean_fatal_error("Not enough memory for zero_array3\n");
zero_array3[i] = 0.;
Tmp_file_dy = G_tempfile();
if (NULL == (Tmp_fd_dy = fopen(Tmp_file_dy, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_dy);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_dy);
if (!(fwrite(zero_array3, sizeof(float), n_cols, Tmp_fd_dy)))
- clean_fatal_error
if (aspect2 != NULL) {
zero_array4 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array4)
- clean_fatal_error("Not enough memory for zero_array4\n");
zero_array4[i] = 0.;
Tmp_file_dz = G_tempfile();
if (NULL == (Tmp_fd_dz = fopen(Tmp_file_dz, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_dz);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_dz);
if (!(fwrite(zero_array4, sizeof(float), n_cols, Tmp_fd_dz)))
- clean_fatal_error
if (ncurv != NULL) {
zero_array5 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array5)
- clean_fatal_error("Not enough memory for zero_array5\n");
zero_array5[i] = 0.;
Tmp_file_xx = G_tempfile();
if (NULL == (Tmp_fd_xx = fopen(Tmp_file_xx, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_xx);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_xx);
if (!(fwrite(zero_array5, sizeof(float), n_cols, Tmp_fd_xx)))
- clean_fatal_error
if (gcurv != NULL) {
zero_array6 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array6)
- clean_fatal_error("Not enough memory for zero_array6\n");
zero_array6[i] = 0.;
Tmp_file_yy = G_tempfile();
if (NULL == (Tmp_fd_yy = fopen(Tmp_file_yy, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_yy);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_yy);
if (!(fwrite(zero_array6, sizeof(float), n_cols, Tmp_fd_yy)))
- clean_fatal_error
if (mcurv != NULL) {
zero_array7 = (float *)G_malloc(sizeof(float) * n_cols);
if (!zero_array7)
- clean_fatal_error("Not enough memory for zero_array7\n");
zero_array7[i] = 0.;
Tmp_file_xy = G_tempfile();
if (NULL == (Tmp_fd_xy = fopen(Tmp_file_xy, "w+"))) {
- sprintf(msg, "Can't open temp file [%s] ", Tmp_file_xy);
+ sprintf(msg, _("Unable to open temp file '%s'"), Tmp_file_xy);
if (!(fwrite(zero_array7, sizeof(float), n_cols, Tmp_fd_xy)))
- clean_fatal_error
cursegm = 0;
@@ -914,12 +866,12 @@
else
- clean_fatal_error("Interp_call failed!");
+ clean_fatal_error(_("Interpolation failed"));
else
- clean_fatal_error("input failed!");
+ clean_fatal_error(_("Input failed"));
if (fd4 != NULL)
fclose(fd4);
- return 0;
+ return EXIT_SUCCESS;
