[GRASS-SVN] r55036 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Wed Feb 13 08:46:21 PST 2013
Author: lucadelu
Date: 2013-02-13 08:46:21 -0800 (Wed, 13 Feb 2013)
New Revision: 55036
grass/trunk/lib/python/pygrass/vector/table.py
fix doctest vector table
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2013-02-13 15:46:54 UTC (rev 55035)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2013-02-13 16:46:21 UTC (rev 55036)
@@ -33,7 +33,7 @@
>>> from grass.script.core import gisenv
>>> import os
>>> new_path2 = os.path.join(gisenv()['GISDBASE'], gisenv()['LOCATION_NAME'],
- ... gisenv()['MAPSET'], 'sqlite', sqlite.db)
+ ... gisenv()['MAPSET'], 'sqlite', 'sqlite.db')
>>> new_path == new_path2
True
@@ -131,7 +131,7 @@
For a sqlite table: ::
>>> import sqlite3
- >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
+ >>> path = '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
>>> cols_sqlite = Columns('census',
... sqlite3.connect(get_path(path)))
>>> cols_sqlite.tname
@@ -180,7 +180,7 @@
"""Return True if is a psycopg connection. ::
>>> import sqlite3
>>> cols_sqlite.is_pg()
@@ -237,15 +237,15 @@
Remove it is used to remove a columns.::
>>> import sqlite3
>>> cols_sqlite.sql_descr() # doctest: +ELLIPSIS
- u'cat integer, OBJECTID integer, AREA double precision, ...'
- >>> import psycopg2 as pg
+ u'cat INTEGER, OBJECTID INTEGER, AREA DOUBLE PRECISION, ...'
+ >>> import psycopg2 as pg # doctest: +SKIP
>>> cols_pg = Columns('boundary_municp_pg',
- ... pg.connect('host=localhost dbname=grassdb'))
- >>> cols_pg.sql_descr() # doctest: +ELLIPSIS
+ ... pg.connect('host=localhost dbname=grassdb')) # doctest: +SKIP
+ >>> cols_pg.sql_descr() # doctest: +ELLIPSIS +SKIP
'cat int4, objectid int4, area float8, perimeter float8, ...'
if remove:
@@ -259,15 +259,15 @@
"""Return a list with the column types. ::
>>> import sqlite3
>>> cols_sqlite.types() # doctest: +ELLIPSIS
- [u'integer', u'integer', ...]
+ [u'INTEGER', u'INTEGER', ...]
- >>> cols_pg.types() # doctest: +ELLIPSIS
+ >>> cols_pg.types() # doctest: +ELLIPSIS +SKIP
['int4', 'int4', 'float8', 'float8', 'float8', ...]
@@ -280,15 +280,15 @@
>>> import sqlite3
>>> cols_sqlite.names() # doctest: +ELLIPSIS
[u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ...]
- >>> cols_pg = Columns('boundary_municp_pg',
+ >>> cols_pg = Columns('boundary_municp_pg', # doctest: +SKIP
- >>> cols_pg.names() # doctest: +ELLIPSIS
+ >>> cols_pg.names() # doctest: +ELLIPSIS +SKIP
['cat', 'objectid', 'area', 'perimeter', ...]
@@ -308,15 +308,15 @@
"""Return a list of tuple with column name and column type. ::
>>> import sqlite3
>>> cols_sqlite.items() # doctest: +ELLIPSIS
- [(u'cat', u'integer'), ...]
+ [(u'cat', u'INTEGER'), ...]
- >>> cols_pg.items() # doctest: +ELLIPSIS
+ >>> cols_pg.items() # doctest: +ELLIPSIS +SKIP
[('cat', 'int4'), ('objectid', 'int4'), ('area', 'float8'), ...]
@@ -328,18 +328,20 @@
>>> import sqlite3
- >>> cols_sqlite = Columns('census',
+ >>> from grass.pygrass.functions import copy, remove
+ >>> copy('census','mycensus','vect')
+ >>> cols_sqlite = Columns('mycensus',
- >>> cols_sqlite.add('n_pizza', 'int4')
+ >>> cols_sqlite.add('n_pizza', 'INT')
>>> 'n_pizza' in cols_sqlite
True
- >>> cols_pg.add('n_pizza', 'int4')
- >>> 'n_pizza' in cols_pg
+ ... pg.connect('host=localhost dbname=grassdb')) #doctest: +SKIP
+ >>> cols_pg.add('n_pizza', 'INT') # doctest: +SKIP
+ >>> 'n_pizza' in cols_pg # doctest: +SKIP
True
+ >>> remove('mycensus', 'vect')
@@ -360,22 +362,28 @@
>>> import sqlite3
+ >>> 'n_pizza' in cols_sqlite
+ True
>>> cols_sqlite.rename('n_pizza', 'n_pizzas') # doctest: +ELLIPSIS
False
>>> 'n_pizzas' in cols_sqlite
True
- >>> cols_pg.rename('n_pizza', 'n_pizzas')
+ >>> cols_pg.rename('n_pizza', 'n_pizzas') # doctest: +SKIP
False
- >>> 'n_pizzas' in cols_pg
+ >>> 'n_pizzas' in cols_pg # doctest: +SKIP
True
@@ -404,23 +412,27 @@
>>> import sqlite3
+ >>> cols_sqlite.add('n_pizzas', 'INT')
>>> cols_sqlite.cast('n_pizzas', 'float8') # doctest: +ELLIPSIS
DBError: 'SQLite does not support to cast columns.'
- >>> cols_pg.cast('n_pizzas', 'float8')
- >>> cols_pg['n_pizzas']
+ >>> cols_pg.cast('n_pizzas', 'float8') # doctest: +SKIP
+ >>> cols_pg['n_pizzas'] # doctest: +SKIP
'float8'
- .. warning ::
+ .. warning ::
- It is not possible to cast a column with sqlite
+ It is not possible to cast a column with sqlite
if self.is_pg():
cur = self.conn.cursor()
@@ -438,20 +450,23 @@
>>> import sqlite3
- >>> cols_sqlite.drop('n_pizzas') # doctest: +ELLIPSIS
- >>> 'n_pizzas' in cols_sqlite
+ >>> cols_sqlite.drop('CHILD') # doctest: +ELLIPSIS
+ >>> 'CHILD' in cols_sqlite
False
- >>> cols_pg.drop('n_pizzas')
+ >>> cols_pg.drop('CHILD') # doctest: +SKIP
+ >>> 'CHILD' in cols_pg # doctest: +SKIP
False
+ >>> remove('mycensus','vect')
if self.is_pg():
@@ -478,8 +493,8 @@
(layer, name, table name, key, database, driver): ::
>>> link = Link(1, 'link0', 'census', 'cat',
- ... '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db', 'sqlite')
- >>> link.number
+ ... '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db', 'sqlite')
+ >>> link.number # doctest: +SKIP
1
>>> link.name
'link0'
@@ -488,7 +503,7 @@
>>> link.key
'cat'
>>> link.database
- '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
+ '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
>>> link.driver
'sqlite'
>>> link
@@ -497,16 +512,16 @@
It is possible to change parameters with: ::
- >>> link.driver = 'pg'
- >>> link.driver
+ >>> link.driver = 'pg' # doctest: +SKIP
+ >>> link.driver # doctest: +SKIP
'pg'
- >>> link.driver = 'postgres' # doctest: +ELLIPSIS
+ >>> link.driver = 'postgres' # doctest: +ELLIPSIS +SKIP
TypeError: Driver not supported, use: sqlite, pg.
- >>> link.driver
'pg'
- >>> link.number = 0 # doctest: +ELLIPSIS
+ >>> link.number = 0 # doctest: +ELLIPSIS +SKIP
TypeError: Number must be positive and greater than 0.
@@ -593,15 +608,15 @@
"""Return a connection object. ::
... 'sqlite')
>>> conn = link.connection()
>>> cur = conn.cursor()
- >>> cur.execute("SELECT cat,COUNTY,PERIMETER FROM %s" %
+ >>> cur.execute("SELECT cat,TOTAL_POP,PERIMETER FROM %s" %
... link.table_name) # doctest: +ELLIPSIS
<sqlite3.Cursor object at ...>
>>> cur.fetchone()
- (1, u'SURRY', 1415.331)
+ (1, 44, 757.669)
>>> cur.close()
>>> conn.close()
@@ -626,14 +641,14 @@
"""Return a Table object. ::
... 'sqlite')
>>> table = link.table()
- >>> table.filters.select('cat', 'COUNTY', 'PERIMETER')
- Filters('SELECT cat, COUNTY, PERIMETER FROM census;')
+ >>> table.filters.select('cat', 'TOTAL_POP', 'PERIMETER')
+ Filters('SELECT cat, TOTAL_POP, PERIMETER FROM census;')
>>> cur = table.execute()
>>> cur.fetchone()
+ (1, 44, 757.669)
>>> cur.close()
@@ -644,14 +659,14 @@
"""Print information of the link. ::
... 'sqlite')
>>> link.info()
layer: 1
table: census
key: cat
- database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
+ database: $GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db
driver: sqlite
@@ -718,18 +733,19 @@
return libvect.Vect_get_num_dblinks(self.c_mapinfo)
def add(self, link):
- """Add a new link. ::
+ """Add a new link.
+ Need to open vector map in write mode::
>>> from grass.pygrass.vector import VectorTopo
>>> municip = VectorTopo('census')
>>> municip.open()
>>> dblinks = DBlinks(municip.c_mapinfo)
>>> dblinks
- DBlinks([Link(1, boundary_municp, sqlite)])
+ DBlinks([Link(1, census, sqlite)])
>>> link = Link(2, 'pg_link', 'boundary_municp_pg', 'cat',
- ... 'host=localhost dbname=grassdb', 'pg')
- >>> dblinks.add(link)
- >>> dblinks # need to open vector map in write mode
+ ... 'host=localhost dbname=grassdb', 'pg') # doctest: +SKIP
+ >>> dblinks.add(link) # doctest: +SKIP
+ >>> dblinks # doctest: +SKIP
@@ -747,10 +763,10 @@
>>> municip.open()
>>> dblinks
- >>> dblinks.remove('pg_link')
+ >>> dblinks.remove('pg_link') # doctest: +SKIP
@@ -773,16 +789,16 @@
>>> import sqlite3
>>> tab_sqlite = Table(name='census',
... connection=sqlite3.connect(get_path(path)))
>>> tab_sqlite.name
'census'
+ >>> import psycopg2 # doctest: +SKIP
>>> tab_pg = Table('boundary_municp_pg',
... psycopg2.connect('host=localhost dbname=grassdb',
- ... 'pg'))
- >>> tab_pg.columns # doctest: +ELLIPSIS
+ ... 'pg')) # doctest: +SKIP
+ >>> tab_pg.columns # doctest: +ELLIPSIS +SKIP
Columns([('cat', 'int4'), ...])
@@ -815,7 +831,7 @@
>>> import sqlite3
>>> tab_sqlite
@@ -846,7 +862,7 @@
"""Return the number of rows
>>> import sqlite3
>>> tab_sqlite.n_rows()
@@ -863,14 +879,14 @@
return a cursor object. ::
>>> import sqlite3
- >>> tab_sqlite.filters.select('cat', 'COUNTY').order_by('AREA')
- Filters('SELECT cat, COUNTY FROM census ORDER BY AREA;')
+ >>> tab_sqlite.filters.select('cat', 'TOTAL_POP').order_by('AREA')
+ Filters('SELECT cat, TOTAL_POP FROM census ORDER BY AREA;')
>>> cur = tab_sqlite.execute()
>>> cur.fetchone()
- (1, u'SURRY')
+ (1856, 0)
@@ -891,7 +907,7 @@
return cur.execute(self.columns.insert_str, values)
def update(self, key, values):
- """Update a """
+ """Update a column for each row"""
vals = list(values)
vals.append(key)
