[GRASS-SVN] r55047 - grass/trunk/lib/python/pygrass
svn_grass at osgeo.org
Thu Feb 14 06:56:15 PST 2013
Author: lucadelu
Date: 2013-02-14 06:56:14 -0800 (Thu, 14 Feb 2013)
New Revision: 55047
grass/trunk/lib/python/pygrass/functions.py
add more capabilities to the function to query raster from vector point
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py 2013-02-14 13:08:55 UTC (rev 55046)
+++ grass/trunk/lib/python/pygrass/functions.py 2013-02-14 14:56:14 UTC (rev 55047)
@@ -128,20 +128,62 @@
libraster.Rast_col_to_easting(col, region.c_region))
-def get_raster_for_points(point, raster):
+def get_raster_for_points(poi_vector, raster, column=None):
"""Query a raster map for each point feature of a vector
+ Example ::
+ >>> from grass.pygrass.vector import VectorTopo
+ >>> from grass.pygrass.raster import RasterRow
+ >>> ele = RasterRow('elevation')
+ >>> copy('schools','myschools','vect')
+ >>> sch = VectorTopo('myschools')
+ >>> get_raster_for_points(sch, ele) # doctest: +ELLIPSIS
+ [(1, 633649.2856743174, 221412.94434781274, 145.06602)...
+ >>> sch.table.columns.add('elevation','double precision')
+ >>> 'elevation' in sch.table.columns
+ True
+ >>> get_raster_for_points(sch, ele, 'elevation')
+ True
+ >>> sch.table.filters.select('NAMESHORT','elevation')
+ Filters('SELECT NAMESHORT, elevation FROM myschools;')
+ >>> cur = sch.table.execute()
+ >>> cur.fetchall() # doctest: +ELLIPSIS
+ [(u'SWIFT CREEK', 145.06602), ... (u'9TH GRADE CTR', None)]
+ >>> remove('myschools','vect')
Parameters
point: point vector object
raster: raster object
+ column: column name to update
+ from math import isnan
+ if not column:
+ result = []
reg = Region()
- if not point.is_open():
- point.open()
- if point.num_primitive_of('point') == 0:
+ if not poi_vector.is_open():
+ poi_vector.open()
+ if not raster.is_open():
+ raster.open()
+ if poi_vector.num_primitive_of('point') == 0:
raise GrassError(_("Vector doesn't contain points"))
- values = [raster.get_value(poi.coords, reg) for poi in point.viter('point')]
- return values
+ for poi in poi_vector.viter('points'):
+ val = raster.get_value(poi, reg)
+ if column:
+ if val is not None and not isnan(val):
+ poi.attrs[column] = val
+ else:
+ result.append((poi.id, poi.x, poi.y, val))
+ else:
+ result.append((poi.id, poi.x, poi.y, None))
+ if not column:
+ return result
+ else:
+ poi.attrs.commit()
+ return True
