[GRASS-SVN] r55052 - grass/trunk/lib/python/pygrass/modules
Thu Feb 14 07:30:07 PST 2013
Author: zarch
Date: 2013-02-14 07:30:07 -0800 (Thu, 14 Feb 2013)
New Revision: 55052
   grass/trunk/lib/python/pygrass/modules/__init__.py
Add support for modules with key with more than one values and that are not multiple
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py	2013-02-14 15:29:58 UTC (rev 55051)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py	2013-02-14 15:30:07 UTC (rev 55052)
@@ -22,6 +22,14 @@
 from grass.pygrass.errors import GrassError, ParameterError
+def _read_keydesc(par):
+    name = par.text.strip()
+    items = [e.text.strip() for e in par.findall('item')]
+    #import ipdb; ipdb.set_trace()
+    return name, tuple(items) if len(items) > 1 else None
 # this dictionary is used to extract the value of interest from the xml
 # the lambda experssion is used to define small simple functions,
@@ -34,7 +42,7 @@
 _GETFROMTAG = {
     'description': lambda p: p.text.strip(),
-    'keydesc': lambda p: p.text.strip(),
+    'keydesc': _read_keydesc,
     'gisprompt': lambda p: dict(p.items()),
     'default': lambda p: p.text.strip(),
     'values': lambda p: [e.text.strip() for e in p.findall('value/name')],
@@ -53,7 +61,6 @@
     'all': lambda x: x,
 def _element2dict(xparameter):
     diz = dict(xparameter.items())
     for p in xparameter:
@@ -76,7 +83,7 @@
     # param
     'param': """{name}: {default}{required}{multi}{ptype}
-    {description}{values}""",
+    {description}{values}{keydescvalues}""",
     # flag_head
     'flag_head': """
@@ -125,7 +132,7 @@
             raise TypeError('New type: %s, ignored' % diz['type'])
         self.description = diz.get('description', None)
-        self.keydesc = diz.get('keydesc', None)
+        self.keydesc, self.keydescvalues = diz.get('keydesc', (None, None))
         # values
@@ -170,7 +177,7 @@
     def _set_value(self, value):
         if isinstance(value, list) or isinstance(value, tuple):
-            if self.multiple:
+            if self.multiple or self.keydescvalues:
                 # check each value
                 self._value = [self._type(val) for val in value]
             else:
@@ -233,12 +240,14 @@
                 vals = ', '.join([repr(val) for val in self.values])
         else:
             vals = False
+        keydescvals = "\n    (%s)" % ', '.join(self.keydescvalues)
         return _DOC['param'].format(name=self.name,
                 default=repr(self.default) + ', ' if self.default else '',
                 required='required, ' if self.required else 'optional, ',
                 multi='multi' if self.multiple else '',
                 ptype=self.typedesc, description=self.description,
-                values='\n    Values: {0}'.format(vals)  if vals else '')
+                values='\n    Values: {0}'.format(vals)  if vals else '',
+                keydescvalues= keydescvals if self.keydescvalues else '')
 class TypeDict(OrderedDict):
@@ -591,7 +600,7 @@
 class MetaModule(object):
     """Example how to use MetaModule
        >>> g = MetaModule('g')
        >>> g_mlist = g.mlist
        >>> g_mlist.name
