[GRASS-SVN] r55091 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Sun Feb 17 15:06:13 PST 2013
Author: mic
Date: 2013-02-17 15:06:13 -0800 (Sun, 17 Feb 2013)
New Revision: 55091
grass-addons/grass7/raster/r.agent/libagent/aco.py
grass-addons/grass7/raster/r.agent/tests/test_aco.py
start implementing aco
Modified: grass-addons/grass7/raster/r.agent/libagent/aco.py
--- grass-addons/grass7/raster/r.agent/libagent/aco.py 2013-02-17 22:48:39 UTC (rev 55090)
+++ grass-addons/grass7/raster/r.agent/libagent/aco.py 2013-02-17 23:06:13 UTC (rev 55091)
@@ -19,8 +19,15 @@
from random import randint
class ACO(world.World):
- """World class for using the Ant Colony Optimization Algorithm for
- modelling Agent Based worlds."""
+ World class for using the Ant Colony Optimization Algorithm for
+ modelling Agent Based worlds.
+ # constant names for the layers
+ SITE = "sitemap"
+ COST = "penaltymap"
+ RESULT = "pheromap"
def __init__(self):
Create a world based on the natural laws of the Ant Colony Optimization
@@ -30,17 +37,17 @@
super(ACO, self).__init__(ant.Ant)
# add the main layers
## one containing the points of interest
- self.addlayertopg("sitemap")
+ self.addlayertopg(ACO.SITE)
## one containing the time cost for traversing cells
- self.addlayertopg("penaltymap")
+ self.addlayertopg(ACO.COST)
## allow overwriting the cost map
self.overwritepenalty = False
## and finally the markings from the agents
- self.addlayertopg("pheromap")
+ self.addlayertopg(ACO.RESULT)
## allow overwriting the main map (if it exists)
self.overwritepheormone = False
# list of the points of origin / sites
- self.holes = []
+ self.sites = []
# default values
## how many rounds to go
self.rounds = 0
@@ -76,13 +83,44 @@
Organize the agents and the pheromone on the playground.
- pass
+ if 0 < self.outrounds < self.rounds:
+ # calculate when to write output
+ mainloops = self.rounds / self.outrounds
+ nextwrite = self.outrounds
+ else:
+ # produce output only at the end
+ mainloops = 1
+ nextwrite = self.rounds
+ while mainloops > 0:
+ # loop and write out the contents at the end
+ loops = nextwrite
+ while loops > 0:
+ # loop without producing output
+ if len(self.agents) < self.maxants:
+ # as there is still space on the pg, produce another ant
+ # at a random site..
+ position = self.sites[randint(0, len(self.sites)-1)]
+ self.bear(self.antslife, position)
+ for ant in self.agents:
+ # let all the ants take action
+ ant.walk()
+ # let the pheromone evaporate
+ self.volatilize()
+ # count down inner
+ loops -= 1
+ # export the value maps
+ self.writeout()
+# print "nrofpaths:", self.nrop
+ # count down outer
+ mainloops -= 1
+# print "nrofrounds", nrofrounds
def volatilize(self):
Let the pheromone evaporate over time.
- pass
+ self.playground.decaycellvalues(ACO.RESULT, self.volatilizationtime,
+ self.minpheromone)
def writeout(self):
Modified: grass-addons/grass7/raster/r.agent/tests/test_aco.py
--- grass-addons/grass7/raster/r.agent/tests/test_aco.py 2013-02-17 22:48:39 UTC (rev 55090)
+++ grass-addons/grass7/raster/r.agent/tests/test_aco.py 2013-02-17 23:06:13 UTC (rev 55091)
@@ -9,30 +9,35 @@
self.world = aco.ACO()
def test_addlayertopg(self):
+ # gets tested in World
pass
def test_removelayerfrompg(self):
pass
def test_getlayer(self):
pass
def findposition(self):
pass
def test_bear(self):
pass
def test_move(self):
pass
- def test_getposition(self):
- pass
def test_getneighbourpositions(self):
pass
def test_kill(self):
pass
def letantsdance(self):
