[GRASS-SVN] r55093 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Sun Feb 17 15:41:43 PST 2013
Author: mic
Date: 2013-02-17 15:41:43 -0800 (Sun, 17 Feb 2013)
New Revision: 55093
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/tests/test_grassland.py
cleanup grassland, prepare read/write
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-02-17 23:08:11 UTC (rev 55092)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-02-17 23:41:43 UTC (rev 55093)
@@ -48,7 +48,7 @@
layer = garray.array()
if grassmapname:
self.grassmapnames[layername] = grassmapname
- self.setlayer(layername, layer)
+ self.setlayer(layername, layer, force)
def removelayer(self, layername):
@@ -67,10 +67,10 @@
@param string optional name of the GRASS map file to be created
@param boolean optional, whether an existing file may be overwritten
- #TODO implement
if self.layers.has_key(layername) and \
- self.grassmapnames.has_key(layername):
- grassmapname = self.grassmapnames[layername]
- layer = self.layers[layername]
- layer.write(grassmapname, overwrite=force)
+ self.grassmapnames.has_key(layername):
+ if force:
+ force="force"
+ self.layers[layername].write(self.grassmapnames[layername],
+ overwrite=force)
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-02-17 23:08:11 UTC (rev 55092)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-02-17 23:41:43 UTC (rev 55093)
@@ -7,7 +7,8 @@
from grass.script import array as garray
class TestGrassLand(unittest.TestCase):
- def setUp(self):
+ def setUp(self):
+ self.layername = "r.agent.testmap"
self.pg = grassland.GrassLand()
def test_getregion(self):
@@ -16,6 +17,7 @@
def test_setregion(self):
#TODO should not be required here.. maybe "resetregion()"?
+ # is set in constructor
pass
def test_getbound(self):
@@ -27,7 +29,7 @@
ew = self.pg.region["ewres"]
r = self.pg.region["rows"]
c = self.pg.region["cols"]
self.assertIsNotNone(n)
self.assertIsNotNone(s)
self.assertIsNotNone(w)
@@ -39,11 +41,28 @@
self.assertEqual((e-w)/ew, c)
def test_setlayer(self):
- # gets tested in createlayer and super()/Playground
+ # gets tested in createlayer and super()/Playground
pass
def test_setgrasslayer(self):
- #TODO better test manually?
+ # only do this test, if self.layername is set
+# if self.layername:
+# layer = garray.array()
+# retval = layer.write(self.layername)
+# if retval == 1:
+# print "We need a file to play with in this test, but it"
+# print "seems to exist already: '" + self.layername + "'"
+# self.assertTrue(False)
+# self.pg.setgrasslayer(self.layername, self.layername)
+# print "GRASS map layer is already set.."
+# print "GRASS map layer was set but no error occured"
+# if not ( self.layers.has_key(self.layername) and \
+# self.grassmapnames.has_key(self.layername) ):
+# print "GRASS map layer was set but seems missing"
+# self.pg.setgrasslayer(self.layername, self.layername, True)
+# cleanup..
pass
def test_createlayer(self):
@@ -61,12 +80,11 @@
self.pg.layers["foo"] = [0]
self.pg.grassmapnames["foo"] = "foo"
self.assertTrue(self.pg.layers.has_key("foo"))
- self.pg.removelayer("foo")
+ self.pg.removelayer("foo")
self.assertFalse(self.pg.layers.has_key("foo"))
self.assertFalse(self.pg.grassmapnames.has_key("foo"))
def test_writelayer(self):
pass
# def tearDown(self):
