[GRASS-SVN] r55126 - grass/trunk/man
svn_grass at osgeo.org
Wed Feb 20 01:52:07 PST 2013
Author: neteler
Date: 2013-02-20 01:52:07 -0800 (Wed, 20 Feb 2013)
New Revision: 55126
grass/trunk/man/build_html.py
grass/trunk/man/build_rest.py
manual file name is module name
Modified: grass/trunk/man/build_html.py
--- grass/trunk/man/build_html.py 2013-02-20 09:49:53 UTC (rev 55125)
+++ grass/trunk/man/build_html.py 2013-02-20 09:52:07 UTC (rev 55126)
@@ -238,7 +238,7 @@
message_tmpl = string.Template(\
r"""Generated HTML docs in ${html_dir}/index.html
-Following modules are missing the 'description.html' file in src code:
+Following modules are missing the 'modulename.html' file in src code:
Modified: grass/trunk/man/build_rest.py
--- grass/trunk/man/build_rest.py 2013-02-20 09:49:53 UTC (rev 55125)
+++ grass/trunk/man/build_rest.py 2013-02-20 09:52:07 UTC (rev 55126)
@@ -261,7 +261,7 @@
r"""Generated HTML docs in ${rest_dir}/index.txt
-Following modules are missing the 'description.txt' file in src code:
+Following modules are missing the 'modulename.txt' file in src code:
def check_for_desc_override(basename):
