[GRASS-SVN] r55128 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Wed Feb 20 02:04:06 PST 2013
Author: hamish
Date: 2013-02-20 02:04:05 -0800 (Wed, 20 Feb 2013)
New Revision: 55128
grass/trunk/raster/r.in.lidar/r.in.lidar.html
preserve tense (merge from r.in.xyz)
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2013-02-20 10:01:24 UTC (rev 55127)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2013-02-20 10:04:05 UTC (rev 55128)
@@ -3,17 +3,20 @@
The <em>r.in.lidar</em> module will load and bin LAS LiDAR point clouds
into a new raster map. The user may choose from a variety of statistical
methods in creating the new raster.
<p>
-Please note that the current region extents and resolution are used for
-the import. It is therefore recommended to first use the <em>-s</em>
-flag to get the extents of the LiDAR point cloud to be imported, then
-adjust the current region accordingly and only now proceed with the
+Please note that the current region extents and resolution are used for
+the import. It is therefore recommended to first use the <em>-s</em>
+flag to get the extents of the LiDAR point cloud to be imported, then
+adjust the current region accordinglyi, and only then proceed with the
actual import.
<p>
<em>r.in.lidar</em> is designed for processing massive point cloud datasets,
-for example raw LIDAR or sidescan sonar swath data. It has been tested with
+for example raw LiDAR or sidescan sonar swath data. It has been tested with
datasets as large as tens of billion of points (705GB in a single file).
<!-- Doug Newcomb, US Fish & Wildlife Service -->
<p>
Available statistics for populating the raster are:<br>
<ul>
