[GRASS-SVN] r55142 - grass/branches/releasebranch_6_4/vector/v.category
svn_grass at osgeo.org
Thu Feb 21 05:18:29 PST 2013
Author: mmetz
Date: 2013-02-21 05:18:29 -0800 (Thu, 21 Feb 2013)
New Revision: 55142
grass/branches/releasebranch_6_4/vector/v.category/main.c
v.category: add option=layers
Modified: grass/branches/releasebranch_6_4/vector/v.category/main.c
--- grass/branches/releasebranch_6_4/vector/v.category/main.c 2013-02-21 10:48:05 UTC (rev 55141)
+++ grass/branches/releasebranch_6_4/vector/v.category/main.c 2013-02-21 13:18:29 UTC (rev 55142)
@@ -26,6 +26,7 @@
#define O_SUM 5
#define O_CHFIELD 6
#define O_TYPE_REP 7 /* report number of features for each type */
+#define O_LYR 9
#define FRTYPES 7 /* number of field report types */
@@ -78,7 +79,7 @@
option_opt->type = TYPE_STRING;
option_opt->required = NO;
option_opt->multiple = NO;
- option_opt->options = "add,del,chlayer,sum,report,print";
+ option_opt->options = "add,del,chlayer,sum,report,print,layers";
option_opt->answer = "add";
option_opt->description = _("Action to be done");
option_opt->descriptions = _("add;add a new category;"
@@ -86,7 +87,8 @@
"chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);"
"sum;add the value specified by cat option to the current category value;"
"report;print report (statistics), in shell style: layer type count min max;"
- "print;print category values, more cats in the same layer are separated by '/'");
+ "print;print category values, more cats in the same layer are separated by '/';"
+ "layers;print only layer numbers");
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->guisection = _("Selection");
@@ -143,8 +145,35 @@
case ('p'):
option = O_PRN;
break;
+ case ('l'):
+ option = O_LYR;
+ break;
+ if (option == O_LYR) {
+ /* print vector layer numbers */
+ /* open vector on level 2 head only, this is why this option
+ * is processed here, all other options need (?) to fully open
+ * the input vector */
+ Vect_set_open_level(2);
+ if (Vect_open_old_head(&In, in_opt->answer, "") < 2) {
+ G_fatal_error(_("Can not open vector <%s> on level %d"),
+ Vect_get_full_name(&In), 2);
+ if (In.format == GV_FORMAT_NATIVE) {
+ nfields = Vect_cidx_get_num_fields(&In);
+ for (i = 0; i < nfields; i++) {
+ if ((field = Vect_cidx_get_field_number(&In, i)) > 0)
+ fprintf(stdout, "%d\n", field);
+ else
+ fprintf(stdout, "%s\n", field_opt->answer);
+ Vect_close(&In);
+ exit(EXIT_SUCCESS);
cat = atoi(cat_opt->answer);
step = atoi(step_opt->answer);
otype = Vect_option_to_types(type_opt);
