[GRASS-SVN] r55151 - grass/trunk/scripts/r.in.wms
svn_grass at osgeo.org
Thu Feb 21 12:20:37 PST 2013
Author: turek
Date: 2013-02-21 12:20:37 -0800 (Thu, 21 Feb 2013)
New Revision: 55151
grass/trunk/scripts/r.in.wms/wms_base.py
r.in.wms: avoid droping of +nadgrids parameter in gdalwarp
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py 2013-02-21 18:11:05 UTC (rev 55150)
+++ grass/trunk/scripts/r.in.wms/wms_base.py 2013-02-21 20:20:37 UTC (rev 55151)
@@ -101,16 +101,19 @@
# read projection info
self.proj_location = grass.read_command('g.proj',
flags ='jf').rstrip('\n')
+ self.proj_location = self._modifyProj(self.proj_location)
if self.params['srs'] in [3857, 900913]:
# HACK: epsg 3857 def: http://spatialreference.org/ref/sr-org/7483/
# g.proj can return: ...+a=6378137 +rf=298.257223563... (WGS84 elipsoid def instead of sphere), it can make 20km shift in Y, when raster is transformed
# needed to be tested on more servers
- self.proj_srs = '+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +no_defs +a=6378137 +b=6378137 +nadgrids=@null +to_meter=1 +wktext'
+ self.proj_srs = '+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +no_defs +a=6378137 +b=6378137 +nadgrids=@null +to_meter=1'
else:
self.proj_srs = grass.read_command('g.proj',
flags = 'jf',
epsg = str(self.params['srs']) ).rstrip('\n')
+ self.proj_srs = self._modifyProj(self.proj_srs)
if not self.proj_srs or not self.proj_location:
grass.fatal(_("Unable to get projection info"))
@@ -135,6 +138,15 @@
self._debug("_initialize_parameters", "finished")
+ def _modifyProj(self, proj):
+ """!Modify proj.4 string for usage in this module"""
+ # add +wktext parameter to avoid droping of +nadgrids parameter (if presented) in gdalwarp
+ if '+nadgrids=' in proj and ' +wktext' not in proj:
+ proj += ' +wktext'
+ return proj
def _checkIgnoeredParams(self, options, flags, driver_props):
"""!Write warnings for set parameters and flags, which chosen driver does not use."""
