[GRASS-SVN] r55161 - grass/branches/releasebranch_6_4/scripts/r.pack
svn_grass at osgeo.org
Fri Feb 22 00:57:37 PST 2013
Author: hamish
Date: 2013-02-22 00:57:37 -0800 (Fri, 22 Feb 2013)
New Revision: 55161
grass/branches/releasebranch_6_4/scripts/r.pack/description.html
grass/branches/releasebranch_6_4/scripts/r.pack/r.pack
strip off mapset to remove fully qualified input (#1637, thanks MarkusN); for user reference, stash a copy of the PROJ_EPSG file, if it exists
Modified: grass/branches/releasebranch_6_4/scripts/r.pack/description.html
--- grass/branches/releasebranch_6_4/scripts/r.pack/description.html 2013-02-22 08:49:12 UTC (rev 55160)
+++ grass/branches/releasebranch_6_4/scripts/r.pack/description.html 2013-02-22 08:57:37 UTC (rev 55161)
@@ -4,6 +4,7 @@
(color table etc) for copying to another computer as a single compressed
file (gzip compression).
<h2>EXAMPLE</h2>
This command saves the raster map "elevation.dem" into the export
@@ -13,12 +14,15 @@
r.pack elevation.dem
</pre></div>
<h2>SEE ALSO</h2>
<em><a href="r.unpack.html">r.unpack</a></em>
<h2>AUTHOR</h2>
Hamish Bowman, Otago University, New Zealand
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/scripts/r.pack/r.pack
--- grass/branches/releasebranch_6_4/scripts/r.pack/r.pack 2013-02-22 08:49:12 UTC (rev 55160)
+++ grass/branches/releasebranch_6_4/scripts/r.pack/r.pack 2013-02-22 08:57:37 UTC (rev 55161)
@@ -2,7 +2,7 @@
# r.pack -- pack up a raster map:
# collect raster map elements => gzip
-# (c) 2004-2008, 2012 GRASS Development Team
+# (c) 2004-2013 GRASS Development Team
# AUTHOR: Hamish Bowman, Otago University, New Zealand
# This program is free software under the GNU General Public License
@@ -54,7 +54,7 @@
if [ -n "$GIS_OPT_OUTPUT" ] ; then
outfile="$GIS_OPT_OUTPUT"
else
- outfile="$GIS_OPT_INPUT.pack"
+ outfile="`echo $GIS_OPT_INPUT | cut -d'@' -f1`.pack"
fi
#be overly helpful
@@ -65,6 +65,9 @@
if [ -z "$name" ] ; then
g.message -e "Map not found"
exit 1
+else
+ # strip off mapset to remove fully qualified input
+ name=`echo "$name" | cut -d'@' -f1`
fi
@@ -87,14 +90,13 @@
BASEDIR=`echo "$file" | sed -e 's+/cell/.*$++'`
OLDDIR=`pwd`
for ELEMENT in cats cell cellhd colr fcell grid3 hist ; do
- if [ -e "$BASEDIR/$ELEMENT/$GIS_OPT_INPUT" ] ; then
+ if [ -e "$BASEDIR/$ELEMENT/$name" ] ; then
cp "$BASEDIR/$ELEMENT/$name" "$TMP_DIR/$ELEMENT"
fi
done
-if [ -d "$BASEDIR/cell_misc/$GIS_OPT_INPUT/" ] ; then
+if [ -d "$BASEDIR/cell_misc/$name/" ] ; then
mkdir "$TMP_DIR/cell_misc/"
cp "$BASEDIR/cell_misc/$name/"* "$TMP_DIR/cell_misc/"
fi
@@ -109,7 +111,7 @@
# (would prefer to use g.proj*, but this way is 5.3 and 5.7 compat)
eval `g.gisenv`
-for SUPPORT in INFO UNITS ; do
+for SUPPORT in INFO UNITS EPSG ; do
if [ -e "$GISDBASE/$LOCATION_NAME/PERMANENT/PROJ_$SUPPORT" ] ; then
cp "$GISDBASE/$LOCATION_NAME/PERMANENT/PROJ_$SUPPORT" "$TMP_DIR"
fi
