[GRASS-SVN] r55165 - grass-addons/grass7/vector/v.concave.hull
svn_grass at osgeo.org
Fri Feb 22 02:15:14 PST 2013
Author: mmetz
Date: 2013-02-22 02:15:13 -0800 (Fri, 22 Feb 2013)
New Revision: 55165
Added:
grass-addons/grass7/vector/v.concave.hull/Makefile
grass-addons/grass7/vector/v.concave.hull/concave.png
grass-addons/grass7/vector/v.concave.hull/convex.png
grass-addons/grass7/vector/v.concave.hull/v.concave.hull.html
grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py
add v.concave.hull
Added: grass-addons/grass7/vector/v.concave.hull/Makefile
--- grass-addons/grass7/vector/v.concave.hull/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.concave.hull/Makefile 2013-02-22 10:15:13 UTC (rev 55165)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=v.concave.hull
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.concave.hull/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.concave.hull/concave.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.concave.hull/concave.png
+ image/png
Added: grass-addons/grass7/vector/v.concave.hull/convex.png
Property changes on: grass-addons/grass7/vector/v.concave.hull/convex.png
+ image/png
Added: grass-addons/grass7/vector/v.concave.hull/v.concave.hull.html
--- grass-addons/grass7/vector/v.concave.hull/v.concave.hull.html (rev 0)
+++ grass-addons/grass7/vector/v.concave.hull/v.concave.hull.html 2013-02-22 10:15:13 UTC (rev 55165)
@@ -0,0 +1,34 @@
+<h2>DESCRIPTION</h2>
+<em>v.concave.hull</em> creates a concave hull around points. Contrary
+to a convex hull, a concave hull can describe the shape of a point cloud.
+<h2>EXAMPLE</h2>
+Creating a convex and a concave hull around schools_wake in the
+North Carolina sample dataset:
+<div class="code"><pre>
+v.hull in=schools_wake out=schools_wake_convex
+v.concave.hull in=schools_wake out=schools_wake_concave
+</pre></div>
+<p>Convex hull around schools:
+<p><img src="convex.png" alt="convex hull" border="1">
+<p>Concave hull around schools:
+<p><img src="concave.png" alt="concave hull" border="1">
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.hull.html">v.hull</a>,
+<a href="v.buffer.html">v.buffer,</a>,
+<a href="v.kernel.html">v.kernel</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.concave.hull/v.concave.hull.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py
--- grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py (rev 0)
+++ grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py 2013-02-22 10:15:13 UTC (rev 55165)
@@ -0,0 +1,179 @@
+#!/usr/bin/env python
+# MODULE: v.concave.hull
+# AUTHOR(S): Markus Metz
+# PURPOSE: Creates a concave hull around points
+# COPYRIGHT: (C) 2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Creates a concave hull around points.
+#% keywords: vector
+#% keywords: geometry
+#%end
+#%option G_OPT_V_INPUT
+#% label: Input points
+#%end
+#%option G_OPT_V_OUTPUT
+#%end
+#%option
+#% key: threshold
+#% type: double
+#% description: Lower values make the hull more concave
+#% required : no
+#% answer: 7
+#% options: 0-10
+#%end
+import sys
+import os
+import atexit
+import math
+import grass.script as grass
+def cleanup():
+ for ext in ['', '.sort']:
+ grass.try_remove(tmp + ext)
+ grass.run_command('g.mremove', flags = 'f', vect = prefix + '_*', quiet = True)
+def sortfile(infile, outfile):
+ inf = file(infile, 'r')
+ outf = file(outfile, 'w')
+ if grass.find_program('sort', ['-n']):
+ grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
+ else:
+ # FIXME: we need a large-file sorting function
+ grass.warning(_("'sort' not found: sorting in memory"))
+ lines = inf.readlines()
+ for i in range(len(lines)):
+ lines[i] = float(lines[i].rstrip('\r\n'))
+ lines.sort()
+ for line in lines:
+ outf.write(str(line) + '\n')
+ inf.close()
+ outf.close()
+def main():
+ global tmp, prefix
+ tmp = grass.tempfile()
+ prefix = 'concave_hull_tmp_%d' % os.getpid()
+ input = options['input']
+ output = options['output']
+ perc = options['threshold']
+ perc = float(perc) + 90
+ delaunay=prefix + '_delaunay'
+ grass.message(_("Delaunay triangulation..."))
+ grass.run_command('v.delaunay', input = input, output = delaunay, quiet = True)
+ out_points = prefix + '_delaunay_pnts'
+ out_lines_nocat = prefix + '_delaunay_lines_nocat'
+ out_lines = prefix + '_delaunay_lines'
+ out_lines_tmp = prefix + '_delaunay_lines_tmp'
+ grass.message(_("Geometry conversion..."))
+ grass.run_command('v.extract', input = delaunay, output = out_lines_tmp,
+ type = 'boundary', layer = '-1', quiet = True)
+ grass.run_command('v.type', input = out_lines_tmp, output = out_lines_nocat,
+ from_type = 'boundary', to_type = 'line', quiet = True)
+ grass.run_command('v.type', input = delaunay, output = out_points,
+ from_type = 'centroid', to_type = 'point', quiet = True)
+ grass.run_command('v.category', input = out_lines_nocat, output = out_lines,
+ op = 'add', type = 'line', quiet = True)
+ grass.run_command('v.db.addtable', map = out_lines,
+ col = 'cat integer,length double', quiet = True)
+ grass.message(_("Evaluating threshold..."))
+ grass.run_command('v.to.db', map = out_lines, type = 'line', op = 'length',
+ col = 'length', quiet = True)
+ db_info = grass.vector_db(map = out_lines, layer = '1')[1]
+ table = db_info['table']
+ database = db_info['database']
+ driver = db_info['driver']
+ sql = "SELECT length FROM %s" % (table)
+ tmpf = file(tmp, 'w')
+ grass.run_command('db.select', flags = 'c', table = table,
+ database = database, driver = driver, sql = sql,
+ stdout = tmpf)
+ tmpf.close()
+ # check if result is empty
+ tmpf = file(tmp)
+ if tmpf.read(1) == '':
+ grass.fatal(_("Table <%s> contains no data.") % table)
+ tmpf.close()
+ N = 0
+ tmpf = file(tmp)
+ for line in tmpf:
+ N += 1
+ tmpf.close()
+ max_length = 0.0
+ sortfile(tmp, tmp + ".sort")
+ ppos = round(N * perc / 100)
+ inf = file(tmp + ".sort")
+ l = 0
+ for line in inf:
+ if l == ppos:
+ max_length = float(line.rstrip('\r\n'))
+ break
+ l += 1
+ inf.close()
+ grass.message(_("Feature selection..."))
+ lines_concave = prefix + '_delaunay_lines_select'
+ lines_concave_nocat = prefix + '_delaunay_lines_select_nocat'
+ grass.run_command('v.extract', input = out_lines, output = lines_concave,
+ type = 'line', where = 'length < %f' % max_length, quiet = True)
+ grass.run_command('v.category', input = lines_concave,
+ output = lines_concave_nocat, type = 'line',
+ op = 'del', cat = '-1', quiet = True)
+ borders_concave = prefix + '_delaunay_borders_select'
+ grass.run_command('v.type', input = lines_concave_nocat,
+ output = borders_concave, from_type = 'line',
+ to_type = 'boundary', quiet = True)
+ areas_concave = prefix + '_delaunay_areas_select'
+ grass.run_command('v.centroids', input = borders_concave,
+ output = areas_concave, quiet = True)
+ grass.run_command('v.db.droptable', map = areas_concave, flags = 'f', quiet = True)
+ grass.run_command('v.db.addtable', map = areas_concave,
+ col = 'cat integer,count integer', quiet = True)
+ grass.run_command('v.vect.stats', points = out_points, areas = areas_concave,
+ ccolumn = 'count', quiet = True)
+ areas_concave_extr = prefix + '_delaunay_areas_extract'
+ grass.run_command('v.extract', input = areas_concave,
+ output = areas_concave_extr, type = 'area',
+ where='count = 1', quiet = True)
+ grass.message(_("The following warnings can be ignored"), flag = 'i')
+ grass.run_command('v.dissolve', input = areas_concave_extr,
+ output = output, col = 'count', layer = '1', quiet = True)
+ grass.message(_("Concave hull successfully created"))
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/vector/v.concave.hull/v.concave.hull.py
Added: svn:executable
+ text/x-python
+ native
