[GRASS-SVN] r55169 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Fri Feb 22 03:06:52 PST 2013
Author: hamish
Date: 2013-02-22 03:06:52 -0800 (Fri, 22 Feb 2013)
New Revision: 55169
grass/trunk/ps/ps.map/main.c
stray whitespace
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2013-02-22 11:05:46 UTC (rev 55168)
+++ grass/trunk/ps/ps.map/main.c 2013-02-22 11:06:52 UTC (rev 55169)
@@ -118,14 +118,14 @@
_("Describe map-box's position on the page and exit (inches from top-left of paper)");
bflag->suppress_required = YES;
bflag->guisection = _("Utility");
input_file = G_define_standard_option(G_OPT_F_INPUT);
input_file->label = _("File containing mapping instructions");
input_file->description = _("Use '-' to enter instructions from keyboard)");
output_file = G_define_standard_option(G_OPT_F_OUTPUT);
output_file->description = _("Name for PostScript output file");
copies = G_define_option();
copies->key = "copies";
copies->type = TYPE_INTEGER;
@@ -133,16 +133,17 @@
copies->description = _("Number of copies to print");
copies->required = NO;
copies->guisection = _("Output settings");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* PS.map_* variables are set to 0 (not defined) and then may be
* reset by 'maploc'. When script is read, main() should call
* reset_map_location() to reset map size to fit to paper */
G_zero(&PS, sizeof(struct PS_data));
/* Print paper sizes to stdout */
if (pflag->answer) {
print_papers();
@@ -201,7 +202,7 @@
if (strcmp(input_file->answer, "-")) {
inputfd = fopen(input_file->answer, "r");
if (!inputfd)
- G_fatal_error(_("Unable to open file '%s': %s"),
+ G_fatal_error(_("Unable to open file '%s': %s"),
input_file->answer, strerror(errno));
else {
@@ -212,7 +213,7 @@
G_fatal_error(_("Required parameter <%s> not set:\n\t(%s)"),
input_file->key, input_file->label);
if (copies->answer) {
if (sscanf(copies->answer, "%d", &ps_copies) != 1) {
ps_copies = 1;
@@ -224,7 +225,7 @@
if (!bflag->answer) {
if (output_file->answer) {
if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
- G_fatal_error("Unable to create file '%s': %s",
+ G_fatal_error("Unable to create file '%s': %s",
output_file->answer, strerror(errno));
else {
@@ -242,10 +243,10 @@
Rast_get_window(&PS.w);
read_instructions(copies_set, can_reset_scale);
/* reset map location base on 'paper' on 'location' */
reset_map_location();
if (bflag->answer) {
map_setup();
fprintf(stdout, "bbox=%.3f,%.3f,%.3f,%.3f\n", PS.map_left / 72.0,
