[GRASS-SVN] r55172 - grass/trunk/raster/r.horizon
svn_grass at osgeo.org
Fri Feb 22 03:28:26 PST 2013
Author: hamish
Date: 2013-02-22 03:28:25 -0800 (Fri, 22 Feb 2013)
New Revision: 55172
grass/trunk/raster/r.horizon/main.c
gui section can handle spaces
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2013-02-22 11:27:33 UTC (rev 55171)
+++ grass/trunk/raster/r.horizon/main.c 2013-02-22 11:28:25 UTC (rev 55172)
@@ -195,7 +195,7 @@
parm.elevin->gisprompt = "old,cell,raster";
parm.elevin->description =
_("Name of the input elevation raster map [meters]");
- parm.elevin->guisection = _("Input_options");
+ parm.elevin->guisection = _("Input options");
parm.direction = G_define_option();
@@ -204,7 +204,7 @@
parm.direction->required = NO;
parm.direction->description =
_("Direction in which you want to know the horizon height");
- parm.direction->guisection = _("Input_options");
+ parm.direction->guisection = _("Input options");
parm.step = G_define_option();
parm.step->key = "horizonstep";
@@ -212,7 +212,7 @@
parm.step->required = NO;
parm.step->description =
_("Angle step size for multidirectional horizon [degrees]");
- parm.step->guisection = _("Input_options");
+ parm.step->guisection = _("Input options");
parm.bufferzone = G_define_option();
parm.bufferzone->key = "bufferzone";
@@ -220,7 +220,7 @@
parm.bufferzone->required = NO;
parm.bufferzone->description =
_("For horizon rasters, read from the DEM an extra buffer around the present region");
- parm.bufferzone->guisection = _("Input_options");
+ parm.bufferzone->guisection = _("Input options");
parm.e_buff = G_define_option();
parm.e_buff->key = "e_buff";
@@ -228,7 +228,7 @@
parm.e_buff->required = NO;
parm.e_buff->description =
_("For horizon rasters, read from the DEM an extra buffer eastward the present region");
- parm.e_buff->guisection = _("Input_options");
+ parm.e_buff->guisection = _("Input options");
parm.w_buff = G_define_option();
parm.w_buff->key = "w_buff";
@@ -236,7 +236,7 @@
parm.w_buff->required = NO;
parm.w_buff->description =
_("For horizon rasters, read from the DEM an extra buffer westward the present region");
- parm.w_buff->guisection = _("Input_options");
+ parm.w_buff->guisection = _("Input options");
parm.n_buff = G_define_option();
parm.n_buff->key = "n_buff";
@@ -244,7 +244,7 @@
parm.n_buff->required = NO;
parm.n_buff->description =
_("For horizon rasters, read from the DEM an extra buffer northward the present region");
- parm.n_buff->guisection = _("Input_options");
+ parm.n_buff->guisection = _("Input options");
parm.s_buff = G_define_option();
parm.s_buff->key = "s_buff";
@@ -252,7 +252,7 @@
parm.s_buff->required = NO;
parm.s_buff->description =
_("For horizon rasters, read from the DEM an extra buffer southward the present region");
- parm.s_buff->guisection = _("Input_options");
+ parm.s_buff->guisection = _("Input options");
parm.maxdistance = G_define_option();
parm.maxdistance->key = "maxdistance";
@@ -260,7 +260,7 @@
parm.maxdistance->required = NO;
parm.maxdistance->description =
_("The maximum distance to consider when finding the horizon height");
- parm.maxdistance->guisection = _("Input_options");
+ parm.maxdistance->guisection = _("Input options");
parm.horizon = G_define_option();
@@ -269,7 +269,7 @@
parm.horizon->required = NO;
parm.horizon->gisprompt = "old,cell,raster";
parm.horizon->description = _("Prefix of the horizon raster output maps");
- parm.horizon->guisection = _("Output_options");
+ parm.horizon->guisection = _("Output options");
parm.coord = G_define_option();
@@ -279,7 +279,7 @@
parm.coord->required = NO;
parm.coord->description =
_("Coordinate for which you want to calculate the horizon");
- parm.coord->guisection = _("Output_options");
+ parm.coord->guisection = _("Output options");
parm.dist = G_define_option();
parm.dist->key = "dist";
@@ -287,7 +287,7 @@
parm.dist->answer = DIST;
parm.dist->required = NO;
parm.dist->description = _("Sampling distance step coefficient (0.5-1.5)");
- parm.dist->guisection = _("Output_options");
+ parm.dist->guisection = _("Output options");
flag.degreeOutput = G_define_flag();
