[GRASS-SVN] r55183 - grass/branches/releasebranch_6_4/lib/gis
svn_grass at osgeo.org
Sat Feb 23 03:01:54 PST 2013
Author: mmetz
Date: 2013-02-23 03:01:54 -0800 (Sat, 23 Feb 2013)
New Revision: 55183
grass/branches/releasebranch_6_4/lib/gis/color_write.c
libgis: revert r55122
Modified: grass/branches/releasebranch_6_4/lib/gis/color_write.c
--- grass/branches/releasebranch_6_4/lib/gis/color_write.c 2013-02-23 08:53:38 UTC (rev 55182)
+++ grass/branches/releasebranch_6_4/lib/gis/color_write.c 2013-02-23 11:01:54 UTC (rev 55183)
@@ -121,7 +121,7 @@
fprintf(fd, "%% %s %s\n", str1, str2);
if (colors->shift) {
- sprintf(str2, "%.15g", (double)colors->shift);
+ sprintf(str2, "%.17g", (double)colors->shift);
G_trim_decimal(str2);
fprintf(fd, "shift:%s\n", str2);
@@ -169,7 +169,7 @@
if (rule->low.value == dmin)
format_min(str, (double)rule->low.value);
else {
- sprintf(str, "%.15g", (double)rule->low.value);
+ sprintf(str, "%.17g", (double)rule->low.value);
G_trim_decimal(str);
fprintf(fd, "%s:%d", str, (int)rule->low.red);
@@ -180,7 +180,7 @@
if (rule->high.value == dmax)
format_max(str, (double)rule->high.value);
else {
- sprintf(str, "%.15g", (double)rule->high.value);
+ sprintf(str, "%.17g", (double)rule->high.value);
fprintf(fd, " %s:%d", str, (int)rule->high.red);
@@ -246,16 +246,16 @@
double dtmp;
- sprintf(str, "%.15g", dval);
+ sprintf(str, "%.17g", dval);
/* Note that G_trim_decimal() does not trim e.g. 1.0000000e-20 */
sscanf(str, "%lf", &dtmp);
if (dtmp != dval) { /* if no zeros after decimal point were trimmed */
/* lower dval by GRASS_EPSILON fraction */
if (dval > 0)
- sprintf(str, "%.15g", dval * (1 - GRASS_EPSILON));
+ sprintf(str, "%.17g", dval * (1 - GRASS_EPSILON));
else
- sprintf(str, "%.15g", dval * (1 + GRASS_EPSILON));
+ sprintf(str, "%.17g", dval * (1 + GRASS_EPSILON));
return 0;
@@ -265,16 +265,16 @@
double dtmp;
/* increase dval by by GRASS_EPSILON fraction */
if (dval > 0)
else
return 0;
