[GRASS-SVN] r55185 - grass/branches/releasebranch_6_4/gui/wxpython
svn_grass at osgeo.org
Sun Feb 24 08:24:55 PST 2013
Author: annakrat
Date: 2013-02-24 08:24:55 -0800 (Sun, 24 Feb 2013)
New Revision: 55185
grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
wxGUI start screen: go back after creating new location
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2013-02-23 17:57:09 UTC (rev 55184)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2013-02-24 16:24:55 UTC (rev 55185)
@@ -26,6 +26,7 @@
import copy
import platform
import codecs
+import getpass
### i18N
import gettext
@@ -419,7 +420,13 @@
else:
self.SetDefaultRegion(location = gWizard.location)
- self.ExitSuccessfully()
+ dlg = wx.TextEntryDialog(parent=self,
+ message=_("Do you want to create new mapset?"),
+ caption=_("Create new mapset"),
+ defaultValue=self._getDefaultMapsetName())
+ if dlg.ShowModal() == wx.ID_OK:
+ mapsetName = dlg.GetValue()
+ self.CreateNewMapset(mapsetName)
def SetDefaultRegion(self, location):
"""!Asks to set default region."""
@@ -771,39 +778,43 @@
dlg.Destroy()
- def OnCreateMapset(self,event):
+ def OnCreateMapset(self, event):
"""!Create new mapset"""
- self.gisdbase = self.tgisdbase.GetValue()
- location = self.listOfLocations[self.lblocations.GetSelection()]
dlg = wx.TextEntryDialog(parent = self,
message = _('Enter name for new mapset:'),
- caption = _('Create new mapset'))
+ caption = _('Create new mapset'),
+ defaultValue = self._getDefaultMapsetName())
- if dlg.ShowModal() == wx.ID_OK:
mapset = dlg.GetValue()
- if mapset in self.listOfMapsets:
- GMessage(parent = self,
- message = _("Mapset <%s> already exists.") % mapset)
- return
- try:
- os.mkdir(os.path.join(self.gisdbase, location, mapset))
- # copy WIND file and its permissions from PERMANENT and set permissions to u+rw,go+r
- shutil.copy(os.path.join(self.gisdbase, location, 'PERMANENT', 'WIND'),
- os.path.join(self.gisdbase, location, mapset))
- # os.chmod(os.path.join(database,location,mapset,'WIND'), 0644)
- self.OnSelectLocation(None)
- self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
- except StandardError, e:
- GError(parent = self,
- message = _("Unable to create new mapset: %s") % e,
- showTraceback = False)
- return False
+ return self.CreateNewMapset(mapset = mapset)
+ else:
+ return False
+ def CreateNewMapset(self, mapset):
+ if mapset in self.listOfMapsets:
+ GMessage(parent = self,
+ message = _("Mapset <%s> already exists.") % mapset)
+ return False
- self.bstart.SetFocus()
- return True
+ try:
+ self.gisdbase = self.tgisdbase.GetValue()
+ location = self.listOfLocations[self.lblocations.GetSelection()]
+ os.mkdir(os.path.join(self.gisdbase, location, mapset))
+ # copy WIND file and its permissions from PERMANENT and set permissions to u+rw,go+r
+ shutil.copy(os.path.join(self.gisdbase, location, 'PERMANENT', 'WIND'),
+ os.path.join(self.gisdbase, location, mapset))
+ # os.chmod(os.path.join(database,location,mapset,'WIND'), 0644)
+ self.OnSelectLocation(None)
+ self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
+ self.bstart.SetFocus()
+ return True
+ except StandardError, e:
+ GError(parent = self,
+ message = _("Unable to create new mapset: %s") % e,
+ showTraceback = False)
+ return False
def OnStart(self, event):
"""'Start GRASS' button clicked"""
@@ -859,8 +870,18 @@
set = "LOCATION_NAME=%s" % location)
RunCommand("g.gisenv",
set = "MAPSET=%s" % mapset)
+ def _getDefaultMapsetName(self):
+ """!Returns default name for mapset."""
+ try:
+ defaultName = getpass.getuser()
+ defaultName.encode('ascii') # raise error if not ascii (not valid mapset name)
+ except: # whatever might go wrong
+ defaultName = 'user'
+ return defaultName
def ExitSuccessfully(self):
self.Destroy()
sys.exit(0)
