[GRASS-SVN] r55222 - grass/branches/develbranch_6/scripts/v.db.reconnect.all
svn_grass at osgeo.org
Mon Feb 25 15:28:21 PST 2013
Author: hamish
Date: 2013-02-25 15:28:21 -0800 (Mon, 25 Feb 2013)
New Revision: 55222
grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all
better handle spaces in GISDBASE (#1683)
Modified: grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all
--- grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all 2013-02-25 23:19:59 UTC (rev 55221)
+++ grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all 2013-02-25 23:28:21 UTC (rev 55222)
@@ -47,14 +47,11 @@
exit 1
fi
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
OLD_DATABASE="$GIS_OPT_OLD_DATABASE"
NEW_DATABASE="$GIS_OPT_NEW_DATABASE"
OLD_SCHEMA="$GIS_OPT_OLD_SCHEMA"
@@ -70,10 +67,13 @@
exit 1
fi
+MAPSET=`g.gisenv get=MAPSET`
for VECT in `g.list type=vect mapset="$MAPSET" | sed 1,2d | grep -v '^-*$'`
do
- g.message message="Reconnecting vector '${VECT}@${MAPSET}'"
- for LINK in `v.db.connect -g fs="|" map=${VECT}@${MAPSET}` ; do
+ g.message message="Reconnecting vector <$VECT> in mapset <$MAPSET>"
+ for LINK in `v.db.connect -g fs="|" map="$VECT@$MAPSET"` ; do
eval `echo "$LINK" | sed 's$\([^\|]*\)|\([^\|]*\)|\([^\|]*\)|\([^\|]*\)|\([^\|]*\)$LAYER=\1 SCHEMA_TABLE=\2 KEY=\3 DATABASE=\4 DRIVER=\5$'`
SCHEMA=`echo "$SCHEMA_TABLE" | grep '\.' | sed 's/\([^.]*\)\..*/\1/'`
