[GRASS-SVN] r55225 - grass/branches/develbranch_6/scripts/v.in.geonames
svn_grass at osgeo.org
Mon Feb 25 15:44:29 PST 2013
Author: hamish
Date: 2013-02-25 15:44:29 -0800 (Mon, 25 Feb 2013)
New Revision: 55225
grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames
better handle spaces in GISDBASE (#1683), remove unused variables
Modified: grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames
--- grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames 2013-02-25 23:40:16 UTC (rev 55224)
+++ grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames 2013-02-25 23:44:29 UTC (rev 55225)
@@ -57,8 +57,6 @@
exec g.parser "$0" "$@"
fi
-PROG=`basename "$0"`
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
g.message -e "awk required, please install awk/gawk first"
@@ -70,11 +68,7 @@
LC_NUMERIC=C
export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
if [ -n "$GIS_OPT_INPUT" ] ; then
FILEORIG="$GIS_OPT_INPUT"
if [ -n "$GIS_OPT_VECT" ] ; then
@@ -97,8 +91,8 @@
#are we in LatLong location?
g.proj -p | grep -i name | grep -i Lon > /dev/null
if [ $? -eq 1 ] ; then
- g.message -e "This module only operates in LatLong/WGS84 locations"
- exit 1
+ g.message -e "This module only operates in LatLong/WGS84 locations"
+ exit 1
fi
# input test
@@ -110,7 +104,7 @@
# DBF doesn't support lengthy text fields
driver=`db.connect -p | grep -i driver | cut -d':' -f2`
if [ "$driver" = "dbf" ] ; then
- g.message -w "Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"
+ g.message -w "Since the DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"
fi
