[GRASS-SVN] r55244 - grass/trunk/locale/po
svn_grass at osgeo.org
Wed Feb 27 11:12:34 PST 2013
Author: neteler
Date: 2013-02-27 11:12:34 -0800 (Wed, 27 Feb 2013)
New Revision: 55244
grass/trunk/locale/po/grasslibs_ar.po
grass/trunk/locale/po/grasslibs_cs.po
grass/trunk/locale/po/grasslibs_de.po
grass/trunk/locale/po/grasslibs_el.po
grass/trunk/locale/po/grasslibs_es.po
grass/trunk/locale/po/grasslibs_fr.po
grass/trunk/locale/po/grasslibs_it.po
grass/trunk/locale/po/grasslibs_ja.po
grass/trunk/locale/po/grasslibs_ko.po
grass/trunk/locale/po/grasslibs_lv.po
grass/trunk/locale/po/grasslibs_ml.po
grass/trunk/locale/po/grasslibs_pl.po
grass/trunk/locale/po/grasslibs_pt.po
grass/trunk/locale/po/grasslibs_pt_br.po
grass/trunk/locale/po/grasslibs_ru.po
grass/trunk/locale/po/grasslibs_sl.po
grass/trunk/locale/po/grasslibs_th.po
grass/trunk/locale/po/grasslibs_tr.po
grass/trunk/locale/po/grasslibs_vi.po
grass/trunk/locale/po/grasslibs_zh.po
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
grass/trunk/locale/po/grasswxpy_cs.po
grass/trunk/locale/po/grasswxpy_de.po
grass/trunk/locale/po/grasswxpy_el.po
grass/trunk/locale/po/grasswxpy_es.po
grass/trunk/locale/po/grasswxpy_fr.po
grass/trunk/locale/po/grasswxpy_id.po
grass/trunk/locale/po/grasswxpy_it.po
grass/trunk/locale/po/grasswxpy_ja.po
grass/trunk/locale/po/grasswxpy_lv.po
grass/trunk/locale/po/grasswxpy_ml.po
grass/trunk/locale/po/grasswxpy_pl.po
grass/trunk/locale/po/grasswxpy_pt.po
grass/trunk/locale/po/grasswxpy_pt_br.po
grass/trunk/locale/po/grasswxpy_ru.po
grass/trunk/locale/po/grasswxpy_th.po
grass/trunk/locale/po/grasswxpy_tr.po
grass/trunk/locale/po/grasswxpy_vi.po
grass/trunk/locale/po/grasswxpy_zh.po
msg update from templates
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_ar.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ar\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-02-18 14:05+0100\n"
+"POT-Creation-Date: 2013-02-26 14:45+0100\n"
"PO-Revision-Date: 2005-03-09 12:50+0100\n"
"Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
"Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -994,7 +994,7 @@
msgid "WARNING"
msgstr "ØªØØ°Ùر:"
-#: ../lib/init/grass.py:183
+#: ../lib/init/grass.py:186
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1002,7 +1002,7 @@
"Ø§ÙØ¥Ø³ØªØ®Ø¯Ø§Ù
:\n"
-#: ../lib/init/grass.py:184 ../lib/gis/parser_html.c:140
+#: ../lib/init/grass.py:187 ../lib/gis/parser_html.c:140
#: ../lib/gis/parser_rest.c:146
#, fuzzy
msgid "Flags"
@@ -1010,40 +1010,40 @@
"\n"
"Ø¹ÙØ§Ù
ات:\n"
-#: ../lib/init/grass.py:185
+#: ../lib/init/grass.py:188
msgid "print this help message"
msgstr ""
-#: ../lib/init/grass.py:186
+#: ../lib/init/grass.py:189
msgid "show version information and exit"
msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:190
msgid "create given database, location or mapset if it doesn't exist"
msgstr ""
-#: ../lib/init/grass.py:188
+#: ../lib/init/grass.py:191
msgid "use text based interface"
msgstr ""
-#: ../lib/init/grass.py:189 ../lib/init/grass.py:191
+#: ../lib/init/grass.py:192 ../lib/init/grass.py:194
#, fuzzy
msgid "and set as default"
msgstr "ÙÙØ¨ÙÙ Ø§ÙØ£Ø³Ø§Ø³ اÙÙ
خزÙ"
-#: ../lib/init/grass.py:190
+#: ../lib/init/grass.py:193
msgid "use $DEFAULT_GUI graphical user interface"
msgstr ""
-#: ../lib/init/grass.py:192
+#: ../lib/init/grass.py:195
msgid "print GRASS configuration parameters"
msgstr ""
-#: ../lib/init/grass.py:193
+#: ../lib/init/grass.py:196
msgid "options: arch,build,compiler,path,revision"
msgstr ""
-#: ../lib/init/grass.py:194 ../lib/gis/parser_html.c:180
+#: ../lib/init/grass.py:197 ../lib/gis/parser_html.c:180
#: ../lib/gis/parser_rest.c:179
#, fuzzy
msgid "Parameters"
@@ -1051,74 +1051,74 @@
"\n"
"Ø¥ØØ¯Ø§Ø«Ùات:\n"
-#: ../lib/init/grass.py:195
+#: ../lib/init/grass.py:198
msgid "initial database (path to GIS data)"
msgstr ""
-#: ../lib/init/grass.py:196
+#: ../lib/init/grass.py:199
msgid "initial location"
msgstr ""
-#: ../lib/init/grass.py:197
+#: ../lib/init/grass.py:200
msgid "initial mapset"
msgstr ""
-#: ../lib/init/grass.py:198
+#: ../lib/init/grass.py:201
msgid "fully qualified initial mapset directory"
msgstr ""
-#: ../lib/init/grass.py:199
+#: ../lib/init/grass.py:202
msgid "Environment variables relevant for startup"
msgstr ""
-#: ../lib/init/grass.py:200
+#: ../lib/init/grass.py:203
msgid "select GUI (text, gui)"
msgstr ""
-#: ../lib/init/grass.py:201
+#: ../lib/init/grass.py:204
msgid "set wish shell name to override 'wish'"
msgstr ""
-#: ../lib/init/grass.py:202
+#: ../lib/init/grass.py:205
msgid "set html web browser for help pages"
msgstr ""
-#: ../lib/init/grass.py:203
+#: ../lib/init/grass.py:206
msgid "set additional path(s) to local GRASS modules or user scripts"
msgstr ""
-#: ../lib/init/grass.py:204
+#: ../lib/init/grass.py:207
msgid "set additional GISBASE for locally installed GRASS Addons"
msgstr ""
-#: ../lib/init/grass.py:205
+#: ../lib/init/grass.py:208
msgid "shell script to be processed as batch job"
msgstr ""
-#: ../lib/init/grass.py:206
+#: ../lib/init/grass.py:209
msgid "set python shell name to override 'python'"
msgstr ""
-#: ../lib/init/grass.py:228
+#: ../lib/init/grass.py:231
#, fuzzy, python-format
msgid "Unable to create temporary directory <%s>! Exiting."
msgstr "ÙÙ
ÙÙ
Ù٠تÙÙÙØ± Ø°Ø§ÙØ±Ø© ÙØ§ÙÙØ©\n"
-#: ../lib/init/grass.py:306
+#: ../lib/init/grass.py:309
msgid "GUI <%s> not supported in this version"
msgstr "Ø§ÙØ´Ù٠اÙÙ
Ø·ÙÙØ¨ ØºÙØ± Ù
ØªØ§Ø ÙÙ ÙØ°Ø§ Ø§ÙØ£ØµØ¯Ø§Ø±"
-#: ../lib/init/grass.py:444
+#: ../lib/init/grass.py:447
msgid "Searched for a web browser, but none found"
msgstr ""
-#: ../lib/init/grass.py:468
+#: ../lib/init/grass.py:471
#, fuzzy
msgid "Hit RETURN to continue"
msgstr "RETURN أضغط ÙØ£Ùغاء Ø§ÙØ£Ù
ر\n"
-#: ../lib/init/grass.py:497
+#: ../lib/init/grass.py:500
msgid ""
"The python command does not work as expected!\n"
"Please check your GRASS_PYTHON environment variable.\n"
@@ -1128,7 +1128,7 @@
"Hit RETURN to continue.\n"
msgstr ""
-#: ../lib/init/grass.py:509
+#: ../lib/init/grass.py:512
msgid ""
"It appears that the X Windows system is not active.\n"
"A graphical based user interface is not supported.\n"
@@ -1137,34 +1137,34 @@
msgstr ""
-#: ../lib/init/grass.py:551 ../lib/init/grass.py:582
+#: ../lib/init/grass.py:554 ../lib/init/grass.py:585
msgid "<%s> is not a valid GRASS location"
msgstr "Ø£Ø³ÙØ§<%s> ÙÙØ³ Ø¥Ø®ØªÙØ§Ø± صØÙØ\n"
-#: ../lib/init/grass.py:563
+#: ../lib/init/grass.py:566
#, python-format
msgid "Failed to create new location. The location <%s> already exists."
msgstr ""
-#: ../lib/init/grass.py:580
+#: ../lib/init/grass.py:583
msgid "Missing WIND file fixed"
msgstr ""
-#: ../lib/init/grass.py:594
+#: ../lib/init/grass.py:597
msgid ""
"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
"Interactive startup needed."
msgstr ""
-#: ../lib/init/grass.py:608
+#: ../lib/init/grass.py:611
#, python-format
msgid ""
"Invalid user interface specified - <%s>.\n"
"Use the --help option to see valid interface names."
msgstr ""
-#: ../lib/init/grass.py:621
+#: ../lib/init/grass.py:624
msgid ""
"Error in GUI startup. If necessary, please report this error to the GRASS "
"developers.\n"
@@ -1173,19 +1173,19 @@
"Hit RETURN to continue..."
msgstr ""
-#: ../lib/init/grass.py:631
+#: ../lib/init/grass.py:634
msgid ""
"Received EXIT message from GUI.\n"
"GRASS is not started. Bye."
msgstr ""
-#: ../lib/init/grass.py:634
+#: ../lib/init/grass.py:637
msgid ""
"Invalid return code from GUI startup script.\n"
"Please advise GRASS developers of this error."
msgstr ""
-#: ../lib/init/grass.py:644
+#: ../lib/init/grass.py:647
msgid ""
"Error reading data path information from g.gisenv.\n"
"GISDBASE=%(gisbase)s\n"
@@ -1195,36 +1195,36 @@
"Check the <%s(file)> file."
msgstr ""
-#: ../lib/init/grass.py:727
+#: ../lib/init/grass.py:730
#, python-format
msgid "Path '%s' doesn't exist"
msgstr ""
-#: ../lib/init/grass.py:738
+#: ../lib/init/grass.py:741
#, python-format
msgid ""
"%(user)s is currently running GRASS in selected mapset (file %(file)s "
"found). Concurrent use not allowed."
msgstr ""
-#: ../lib/init/grass.py:742
+#: ../lib/init/grass.py:745
#, python-format
msgid ""
"Unable to properly access '%s'.\n"
"Please notify system personel."
msgstr ""
-#: ../lib/init/grass.py:756
+#: ../lib/init/grass.py:759
#, fuzzy
msgid "Building user fontcap..."
msgstr "ÙØªÙ
Ø§ÙØ§Ù Ø¨ÙØ§Ø¡ Ø§ÙØ·Ø¨ÙÙÙØ¬Ù ...\n"
-#: ../lib/init/grass.py:790
+#: ../lib/init/grass.py:793
#, fuzzy
msgid "The SHELL variable is not set"
msgstr "GISRC - اÙÙ
ØªØºÙØ± ÙÙ
ÙØØ¯Ø¯ بشÙ٠صØÙØ"
-#: ../lib/init/grass.py:800
+#: ../lib/init/grass.py:803
#, python-format
msgid ""
"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -1233,89 +1233,89 @@
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
-#: ../lib/init/grass.py:805
+#: ../lib/init/grass.py:808
#, python-format
msgid "Change file permission to 'executable' for '%s'"
msgstr ""
-#: ../lib/init/grass.py:807
+#: ../lib/init/grass.py:810
#, python-format
msgid "Executing '%s' ..."
msgstr ""
-#: ../lib/init/grass.py:812
+#: ../lib/init/grass.py:815
#, python-format
msgid "Execution of '%s' finished."
msgstr ""
-#: ../lib/init/grass.py:817
+#: ../lib/init/grass.py:820
#, python-format
msgid "GRASS GUI should be <%s>"
msgstr ""
-#: ../lib/init/grass.py:845
+#: ../lib/init/grass.py:848
#, python-format
msgid "Welcome to GRASS %s"
msgstr ""
-#: ../lib/init/grass.py:854
+#: ../lib/init/grass.py:857
msgid "GRASS homepage:"
msgstr ""
-#: ../lib/init/grass.py:855
+#: ../lib/init/grass.py:858
msgid "This version running through:"
msgstr ""
-#: ../lib/init/grass.py:857
+#: ../lib/init/grass.py:860
msgid "Help is available with the command:"
msgstr ""
-#: ../lib/init/grass.py:858
+#: ../lib/init/grass.py:861
msgid "See the licence terms with:"
msgstr ""
-#: ../lib/init/grass.py:861
+#: ../lib/init/grass.py:864
msgid "If required, restart the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:863
+#: ../lib/init/grass.py:866
msgid "Start the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:865
+#: ../lib/init/grass.py:868
msgid "When ready to quit enter:"
msgstr ""
-#: ../lib/init/grass.py:969
+#: ../lib/init/grass.py:972
msgid "Failed to start shell '%s'"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#: ../lib/init/grass.py:973
+#: ../lib/init/grass.py:976
#, python-format
msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
msgstr ""
-#: ../lib/init/grass.py:974 ../lib/init/grass.py:979
+#: ../lib/init/grass.py:977 ../lib/init/grass.py:982
msgid "Goodbye from GRASS GIS"
msgstr ""
-#: ../lib/init/grass.py:977
+#: ../lib/init/grass.py:980
#, fuzzy
msgid "Done."
msgstr "ÙØ§Ø´ÙØ¡"
-#: ../lib/init/grass.py:983
+#: ../lib/init/grass.py:986
#, fuzzy
msgid "Cleaning up temporary files..."
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ù
Ø¤ÙØª"
-#: ../lib/init/grass.py:1025
+#: ../lib/init/grass.py:1028
msgid "Parameter <%s> not supported"
msgstr "ØºÙØ± Ù
ÙØ¬Ùد'%s' اÙÙÙÙØªÙر"
-#: ../lib/init/grass.py:1166
+#: ../lib/init/grass.py:1169
#, python-format
msgid ""
"Unable to start GRASS. You can:\n"
@@ -1325,11 +1325,11 @@
"path/to/location/mapset`)"
msgstr ""
-#: ../lib/init/grass.py:1175
+#: ../lib/init/grass.py:1178
msgid "Starting GRASS GIS..."
msgstr ""
-#: ../lib/init/grass.py:1233
+#: ../lib/init/grass.py:1236
#, python-format
msgid "Launching <%s> GUI in the background, please wait..."
msgstr ""
@@ -3863,6 +3863,16 @@
msgid "Unable to list mapsets"
msgstr " %s ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#: ../lib/python/script/core.py:1410
+#, fuzzy, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr "ÙØ¬Ø¨ Ø£Ù ÙØ§ ÙØÙÙ ÙÙØ·Ø© Ø£Ù ÙÙÙ
Ø© Ù
عدÙÙ
Ø© <%s> اسÙ
Ù
ا٠ÙÙÙØªÙØ±Ù ØºÙØ± سÙÙÙ
\n"
+#: ../lib/python/script/core.py:1418
+msgid "Illegal filename <%s>. <%s> not allowed.\n"
+msgstr " ØºÙØ± Ù
سÙ
ÙØ Ø¨Ù ÙØ§ÙاسÙ
ØºÙØ± صØÙØ <%c> Ø§ÙØØ±Ù"
#: ../lib/python/script/raster3d.py:89
msgid "An error occurred while running r3.mapcalc"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_cs.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grasslibs_cs\n"
"PO-Revision-Date: 2010-03-07 15:47+0100\n"
"Last-Translator: \n"
"Language-Team: <cs at li.org>\n"
@@ -1047,7 +1047,7 @@
msgid "WARNING"
msgstr "UPOZORNÄNÃ: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1055,120 +1055,120 @@
"PoužitÃ:\n"
msgid "Flags"
msgstr "PÅepÃnaÄe"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "použÃt výchozÃ"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Parametry"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"neplatná mapová projekce\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nelze alokovat pamÄÅ¥"
msgstr "Požadovaný formát nenà zkompilován v této verzi"
msgstr ""
#, fuzzy
msgstr "stisknÄte RETURN pro pokraÄovánà -->"
msgid ""
@@ -1178,7 +1178,7 @@
msgstr ""
msgid ""
@@ -1187,34 +1187,34 @@
msgstr ""
msgstr "PromiÅte, ale <%s> nenà platná volba\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1223,20 +1223,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "ProsÃm, oznamte tuto chybu vývojáÅům GRASSu.\n"
msgid ""
@@ -1246,36 +1246,36 @@
msgstr ""
msgstr "%s:Plocha %d neexistuje"
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "VytváÅenà grafu ..."
#, fuzzy
msgstr "GISRC - promÄnná nenà nastavena"
#, python-format
msgid ""
@@ -1284,90 +1284,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "NápovÄda pro pÅÃkaz [%s] nenà dostupná\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nelze spustit ovladaÄ <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nic"
#, fuzzy
msgstr "Nelze otevÅÃt doÄasný soubor"
msgstr "Typ prvku OGR %d nenà podporován"
#, python-format
msgid ""
@@ -1377,11 +1377,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3995,6 +3995,16 @@
msgstr "Nelze zavÅÃt vstupnà mapu"
+msgstr "Nedovolený název souboru. Soubor se nemůže jmenovat '.' nebo 'NIC'\n"
+msgstr "Nedovolený název souboru. Znak <%c> nenà povolen.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_de.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grasslibs_de\n"
"PO-Revision-Date: 2012-11-09 17:21+0100\n"
"Last-Translator: Robert Nuske <robert.nuske nw-fva.de>\n"
"Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -81,10 +81,8 @@
#: ../lib/symbol/read.c:260
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
#: ../lib/symbol/read.c:284
#, c-format
@@ -131,12 +129,8 @@
msgstr "Ungültige Zeichenkette für Zeitstempel."
#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul "
-"sollte für die GRASS 6 Vector Library aktualisiert werden)."
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul sollte für die GRASS 6 Vector Library aktualisiert werden)."
#: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:342 ../lib/ogsf/Gp3.c:206
#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
@@ -167,8 +161,7 @@
msgstr "G_oldsite_new_struct: Ungültige # Dimensionen oder Felder"
#: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
msgstr ""
#: ../lib/ogsf/gsd_label.c:58
@@ -196,15 +189,13 @@
#: ../lib/ogsf/GS2.c:1655
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"Rasterkarte <%s> ist auÃerhalb der aktuellen Region. Laden fehlgeschlagen."
+msgstr "Rasterkarte <%s> ist auÃerhalb der aktuellen Region. Laden fehlgeschlagen."
#: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
#: ../lib/ogsf/GS2.c:1822
msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-"GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
+msgstr "GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
#: ../lib/ogsf/GS2.c:1850
msgid "Loading failed"
@@ -244,8 +235,7 @@
#: ../lib/ogsf/Gv3.c:261
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
#: ../lib/ogsf/Gv3.c:266
#, c-format
@@ -279,9 +269,7 @@
#: ../lib/ogsf/Gv3.c:406
#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+msgid "%d features without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/copy.c:142
@@ -293,8 +281,7 @@
#: ../lib/ogsf/Gp3.c:146
#, c-format
msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-"Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
#: ../lib/ogsf/Gp3.c:151
#, c-format
@@ -308,9 +295,7 @@
#: ../lib/ogsf/Gp3.c:286
#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
+msgid "%d points without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/gsd_prim.c:146
@@ -320,12 +305,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. "
-"Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
@@ -343,9 +324,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"Schnittflächenpunkte der Oberflächen passen nicht zusammen. Ãberprüfen Sie "
-"die Auflösung(en)."
+msgstr "Schnittflächenpunkte der Oberflächen passen nicht zusammen. Ãberprüfen Sie die Auflösung(en)."
#: ../lib/ogsf/gsdrape.c:207
msgid "Unable to process vector map - out of memory"
@@ -382,9 +361,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:319
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Kann nicht von der Dateiendung auf das Ausgabeformat schlieÃen: verwende "
-"MPEG."
+msgstr "Kann nicht von der Dateiendung auf das Ausgabeformat schlieÃen: verwende MPEG."
#: ../lib/ogsf/gsd_img_mpeg.c:323
msgid "Unable to find suitable output format"
@@ -528,8 +505,7 @@
#: ../lib/ogsf/Gs3.c:596
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
+msgstr "Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
#, c-format
@@ -538,9 +514,7 @@
#: ../lib/ogsf/Gs3.c:967
msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-"View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen "
-"auftreten."
+msgstr "View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen auftreten."
#: ../lib/ogsf/gsds.c:109
msgid "Maximum number of datasets exceeded"
@@ -576,17 +550,13 @@
#: ../lib/proj/convert.c:139
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR "
-"Fehler-Code %d)."
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR Fehler-Code %d)."
#: ../lib/proj/convert.c:146
#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
+msgstr "OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
#: ../lib/proj/convert.c:406
msgid "No projection name! Projection parameters likely to be meaningless."
@@ -599,21 +569,13 @@
#: ../lib/proj/convert.c:458
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. "
-"Sie sollten dies genauer untersuchen."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. Sie sollten dies genauer untersuchen."
#: ../lib/proj/convert.c:462
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. "
-"Datumstransformationsparameter bleiben unbestimmt."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. Datumstransformationsparameter bleiben unbestimmt."
#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
#, c-format
@@ -719,8 +681,7 @@
#: ../lib/raster3d/history.c:43
#, c-format
msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-"Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
+msgstr "Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
#: ../lib/raster3d/param.c:86
#, fuzzy
@@ -881,10 +842,7 @@
msgstr ""
#: ../lib/raster3d/test/test_main.c:78
-msgid ""
-"The tile size in kilo bytes to be used for the large file put/get value "
-"test. Set the tile size to 2048 and the number of row*cols*depths > 130000 "
-"to reproduce the tile rle error."
+msgid "The tile size in kilo bytes to be used for the large file put/get value test. Set the tile size to 2048 and the number of row*cols*depths > 130000 to reproduce the tile rle error."
msgstr ""
#: ../lib/raster3d/test/test_main.c:82 ../lib/gmath/test/test_main.c:79
@@ -907,9 +865,7 @@
msgstr ""
#: ../lib/raster3d/test/test_main.c:98
-msgid ""
-"Use run length encoding RLE to encode/decode single tiles. Attention RLE is "
-"buggy in case of large tiles or files."
+msgid "Use run length encoding RLE to encode/decode single tiles. Attention RLE is buggy in case of large tiles or files."
msgstr ""
#: ../lib/raster3d/test/test_main.c:118
@@ -1041,9 +997,7 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht "
-"möglich."
+msgstr "Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht möglich."
#: ../lib/init/lock.c:60
#, fuzzy, c-format
@@ -1055,7 +1009,7 @@
msgid "WARNING"
msgstr "WARNUNG: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1063,120 +1017,120 @@
"Benutzung:\n"
msgid "Flags"
msgstr "Flags"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Zum Akzeptieren der Standardeinstellung"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Parameter"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"Ungültige Projektion\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Kann keinen Speicher für temporäres Bild belegen."
msgstr "Das angeforderte Format ist in diese Version nicht einkompiliert."
msgstr ""
#, fuzzy
msgstr "RETURN zum Weitermachen drücken -->"
msgid ""
@@ -1186,7 +1140,7 @@
msgstr ""
msgid ""
@@ -1195,56 +1149,55 @@
msgstr ""
msgstr "Tut mir leid, <%s> ist keine gültige Option\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
"Switching to text mode now.\n"
"\n"
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "Bitte unterrichten Sie die GRASS-Entwickler über diesen Fehler.\n"
msgid ""
@@ -1254,142 +1207,138 @@
msgstr ""
msgstr "%s: Fläche %d existiert nicht."
#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Erzeuge Graphen..."
#, fuzzy
msgstr "GISRC - Variable nicht gesetzt."
#, python-format
msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
"\n"
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Leider keine Hilfe für den Befehl [%s] verfügbar.\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Kann den Treiber <%s> nicht starten."
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nichts"
#, fuzzy
msgstr "Kann temporäre Datei nicht öffnen."
msgstr "OGR Objekttyp %d wird nicht unterstützt."
#, python-format
msgid ""
" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -1461,9 +1410,7 @@
#: ../lib/raster/init.c:61
#, fuzzy
msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-"Fehler. System ist nicht initialisiert. Der Programmierer hat vergessen, "
-"G_gisinit() aufzurufen.\n"
+msgstr "Fehler. System ist nicht initialisiert. Der Programmierer hat vergessen, G_gisinit() aufzurufen.\n"
#: ../lib/raster/color_read.c:103
#, fuzzy
@@ -1536,9 +1483,7 @@
#: ../lib/raster/gdal.c:496
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../lib/raster/gdal.c:502
@@ -1582,21 +1527,15 @@
msgstr "Kann Datei %s in %s nicht öffnen"
#: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window.Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
#: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window.Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
#: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window.Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
#: ../lib/raster/color_rules.c:125
@@ -1639,12 +1578,8 @@
#: ../lib/raster/set_window.c:131
#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten "
-"Rasterdateien."
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten Rasterdateien."
#: ../lib/raster/set_window.c:158
#, c-format
@@ -1674,9 +1609,7 @@
#: ../lib/raster/reclass.c:171
#, fuzzy, c-format
msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-"Ungültiges Reklassifizierungs-Format in der Header-Datei für Karte [%s in "
-"%s]."
+msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei für Karte [%s in %s]."
#: ../lib/raster/reclass.c:273
msgid "Illegal reclass request"
@@ -1699,9 +1632,7 @@
#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist auÃerhalb der "
-"Region."
+msgstr "Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist auÃerhalb der Region."
#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
@@ -1722,12 +1653,8 @@
#: ../lib/raster/open.c:190
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung "
-"der Rasterkarte <%s@%s> ist, welche nicht existiert."
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung der Rasterkarte <%s@%s> ist, welche nicht existiert."
#: ../lib/raster/open.c:195
#, fuzzy, c-format
@@ -1746,9 +1673,7 @@
#: ../lib/raster/open.c:219
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
msgstr "Raster Karte Raster Karte."
#: ../lib/raster/open.c:226
@@ -1763,8 +1688,7 @@
#: ../lib/raster/open.c:256
#, fuzzy, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr "Karte"
#: ../lib/raster/open.c:264
@@ -1833,8 +1757,7 @@
#: ../lib/raster/open.c:929
#, fuzzy
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr "Raster"
#: ../lib/raster/null_val.c:64
@@ -1899,8 +1822,7 @@
#: ../lib/raster/put_row.c:682
#, fuzzy, c-format
msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr ""
-"%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
#: ../lib/raster/put_row.c:689
#, fuzzy
@@ -2025,9 +1947,7 @@
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
+msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
msgstr "Raster Karte Raster Karte"
#: ../lib/raster/get_cellhd.c:70
@@ -2138,19 +2058,13 @@
#: ../lib/imagery/sigsetfile.c:41
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> - <%s> "
-"nicht erstellen, da es nicht im aktuellen Mapset ist."
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> - <%s> nicht erstellen, da es nicht im aktuellen Mapset ist."
#: ../lib/imagery/sigsetfile.c:57
#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> nicht "
-"erstellen."
+msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> nicht erstellen."
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -2170,23 +2084,17 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht "
-"erstellen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht erstellen."
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"öffnen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht öffnen."
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"finden."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht finden."
#: ../lib/imagery/iclass.c:83
#, fuzzy, c-format
@@ -2211,8 +2119,7 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
+msgstr "Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
#: ../lib/imagery/target.c:38
#, c-format
@@ -2775,8 +2682,7 @@
#: ../lib/temporal/t.connect/main.c:38
#, fuzzy
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
msgstr "Die Datenbankverbindung für den Layer <%d> nicht definiert."
#: ../lib/temporal/t.connect/main.c:42
@@ -2991,8 +2897,7 @@
#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
#: ../lib/cairodriver/Draw_bitmap.c:47
@@ -3002,9 +2907,7 @@
#: ../lib/driver/parse_ftcap.c:84
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die "
-"Standardeinstellung."
+msgstr "%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die Standardeinstellung."
#: ../lib/driver/parse_ftcap.c:90
#, c-format
@@ -3129,9 +3032,7 @@
#: ../lib/python/temporal/mapcalc.py:139 ../lib/python/temporal/extract.py:89
-msgid ""
-"Space time %s dataset <%s> is already in database, use overwrite flag to "
-"overwrite"
+msgid "Space time %s dataset <%s> is already in database, use overwrite flag to overwrite"
msgstr "Vektorkarte <%s> existiert bereits und wird überschrieben."
#: ../lib/python/temporal/mapcalc.py:144
@@ -3147,10 +3048,7 @@
msgstr ""
#: ../lib/python/temporal/mapcalc.py:190
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
msgstr ""
#: ../lib/python/temporal/mapcalc.py:208
@@ -3163,8 +3061,7 @@
#: ../lib/python/temporal/mapcalc.py:273 ../lib/python/temporal/extract.py:137
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/mapcalc.py:293
@@ -3333,9 +3230,7 @@
#: ../lib/python/temporal/stds_import.py:345
#: ../lib/python/temporal/space_time_datasets_tools.py:882
-msgid ""
-"Space time %s dataset <%s> is already in the database. Use the overwrite "
-"flag."
+msgid "Space time %s dataset <%s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/stds_import.py:365
@@ -3351,15 +3246,11 @@
msgstr "Rasterkarte <%s> nicht im Mapset <%s> gefunden."
#: ../lib/python/temporal/core.py:82 ../lib/python/temporal/core.py:90
-msgid ""
-"Unable to initialize the temporal GIS DBMI interface. Use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:161
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:201
@@ -3406,9 +3297,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:114
#, python-format
-msgid ""
-"Space time %s dataset <%s> with relative time found, but no relative unit "
-"set for %s maps"
+msgid "Space time %s dataset <%s> with relative time found, but no relative unit set for %s maps"
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:182
@@ -3417,36 +3306,27 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:205
#, python-format
-msgid ""
-"Unable to register %s map <%s> with layer %s. The map has no valid time and "
-"the start time is not set."
+msgid "Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set."
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:209
#, python-format
-msgid ""
-"Unable to register %s map <%s>. The map has no valid time and the start time "
-"is not set."
+msgid "Unable to register %s map <%s>. The map has no valid time and the start time is not set."
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:224
-msgid ""
-"Map is already registered in temporal database. Unable to update %s map <%s> "
-"with layer %s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %s map <%s> with layer %s. Overwrite flag is not set."
#: ../lib/python/temporal/space_time_datasets_tools.py:229
-msgid ""
-"Map is already registered in temporal database. Unable to update %s map <"
-"%s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %s map <%s>. Overwrite flag is not set."
#: ../lib/python/temporal/space_time_datasets_tools.py:252
-msgid ""
-"Unable to update %s map <%s> with layer. The temporal types are different."
+msgid "Unable to update %s map <%s> with layer. The temporal types are different."
msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
#: ../lib/python/temporal/space_time_datasets_tools.py:256
@@ -3487,9 +3367,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:383
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
msgstr "Kann die Vektorkarte <%s> nicht nach <%s> kopieren."
#: ../lib/python/temporal/space_time_datasets_tools.py:388
@@ -3499,8 +3377,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:405
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
#: ../lib/python/temporal/space_time_datasets_tools.py:410
@@ -3541,9 +3418,7 @@
#: ../lib/python/temporal/aggregation.py:131
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
+msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/aggregation.py:134
@@ -3603,15 +3478,12 @@
#: ../lib/python/temporal/abstract_map_dataset.py:813
#, python-format
-msgid ""
-"Map <%s> with layer %s has incorrect time interval, start time is greater "
-"than end time"
+msgid "Map <%s> with layer %s has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:818
#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:823
@@ -3626,9 +3498,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:906
-msgid ""
-"Unregister %(type)s map <%(map)s> with layer %(layer)s from space time "
-"datasets"
+msgid "Unregister %(type)s map <%(map)s> with layer %(layer)s from space time datasets"
#: ../lib/python/temporal/abstract_map_dataset.py:911
@@ -3658,25 +3528,19 @@
msgstr "Rasterkarte <%s> wurde nicht gefunden."
#: ../lib/python/temporal/spatial_extent.py:123
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:360
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:500
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:607
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:678
@@ -3752,17 +3616,11 @@
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:679
-msgid ""
-"More than one map found in a granule. Temporal granularity seems to be "
-"invalid or the chosen granularity is not a greatest common divider of all "
-"intervals and gaps in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:711
-msgid ""
-"time instances in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all time instances in the dataset."
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:910
@@ -3806,9 +3664,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1095
#, python-format
-msgid ""
-"Temporal type of space time dataset <%s> and map <%s> with layer %s are "
-"different"
+msgid "Temporal type of space time dataset <%s> and map <%s> with layer %s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1099
@@ -3823,15 +3679,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1121
#, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> with layer %s "
-"are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> with layer %s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1125
#, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1133
@@ -3889,8 +3742,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1386
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:208
@@ -3960,12 +3812,8 @@
#: ../lib/python/script/raster.py:47
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im "
-"Schreibmodus geöffnet."
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
#: ../lib/python/script/raster.py:105
msgid "An error occurred while running r.mapcalc"
@@ -4014,6 +3862,16 @@
msgstr "Kann die Eingabekarte nicht schlieÃen."
+msgstr "Ungültiger Dateiname. Er darf nicht '.' oder 'NULL' sein.\n"
+msgstr "Ungültiger Dateiname. Das Zeichen <%c> ist nicht erlaubt.\n"
msgstr ""
@@ -4059,8 +3917,7 @@
#: ../lib/python/script/db.py:142
#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
#: ../lib/python/script/db.py:154
@@ -4559,12 +4416,8 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Klassengrenzen auÃerhalb der min-max Spanne. Anzahl der Klassen auf %i "
-"reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Klassengrenzen auÃerhalb der min-max Spanne. Anzahl der Klassen auf %i reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
#: ../lib/vector/neta/utils.c:195
#, fuzzy, c-format
@@ -4605,24 +4458,17 @@
#: ../lib/vector/diglib/plus_node.c:214
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu "
-"lesen: Knoten %d, Linie %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu lesen: Knoten %d, Linie %d"
#: ../lib/vector/diglib/cindex_rw.c:156
#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr "Vektor."
#: ../lib/vector/diglib/file.c:159
msgid "Writing to file loaded to memory not supported"
-msgstr ""
-"Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
+msgstr "Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
#: ../lib/vector/diglib/file.c:197
msgid "Unable to load file to memory, file not open"
@@ -4639,23 +4485,17 @@
#: ../lib/vector/diglib/spindex_rw.c:302
#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr "Vektor."
#: ../lib/vector/diglib/spindex_rw.c:308
#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr "Vektor."
#: ../lib/vector/diglib/spindex_rw.c:317
#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:858
@@ -4792,8 +4632,7 @@
#: ../lib/vector/diglib/plus_area.c:412
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
+msgstr "Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
#: ../lib/vector/diglib/plus_area.c:437
#, c-format
@@ -4822,28 +4661,22 @@
#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:104
#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:134
@@ -4853,8 +4686,7 @@
#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/test.c:165
@@ -4864,23 +4696,17 @@
#: ../lib/vector/diglib/plus_struct.c:523
#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr "Vektor."
#: ../lib/vector/diglib/plus_struct.c:529
#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr "Vektor."
#: ../lib/vector/diglib/plus_struct.c:539
#, fuzzy, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
msgstr "Vektor."
#: ../lib/vector/Vlib/write_nat.c:49 ../lib/vector/Vlib/write_nat.c:85
@@ -4904,14 +4730,12 @@
#: ../lib/vector/Vlib/legal_vname.c:43
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
#: ../lib/vector/Vlib/legal_vname.c:50
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
#: ../lib/vector/Vlib/legal_vname.c:58
#, c-format
@@ -4920,11 +4744,8 @@
#: ../lib/vector/Vlib/legal_vname.c:65
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als "
-"Vektorkartenname benutzt werden."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als Vektorkartenname benutzt werden."
#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
#, c-format
@@ -5005,13 +4826,11 @@
#: ../lib/vector/Vlib/build.c:126
msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-"Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr "Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
#: ../lib/vector/Vlib/build.c:135
msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-"Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr "Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
#: ../lib/vector/Vlib/build.c:145
msgid "Area of size = 0.0 ignored"
@@ -5157,9 +4976,7 @@
#: ../lib/vector/Vlib/build.c:1188
#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
msgstr "Vektor Karte"
#: ../lib/vector/Vlib/build.c:1211
@@ -5594,12 +5411,8 @@
#: ../lib/vector/Vlib/geos.c:55
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
-"Vektorkarte <%s>: %d)."
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
#: ../lib/vector/Vlib/geos.c:60
msgid "only native format supported"
@@ -5617,8 +5430,7 @@
#: ../lib/vector/Vlib/geos.c:104
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
+msgstr "Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
#: ../lib/vector/Vlib/geos.c:203
#, c-format
@@ -5664,12 +5476,8 @@
#: ../lib/vector/Vlib/read.c:168
#, fuzzy, c-format
-msgid ""
-"Requested feature id %d is not reasonable(max features in vector map <%s>: "
-"%d)"
-msgstr ""
-"Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
+msgid "Requested feature id %d is not reasonable(max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
#: ../lib/vector/Vlib/build_ogr.c:69
msgid "Empty OGR layer, nothing to build"
@@ -5682,11 +5490,8 @@
#: ../lib/vector/Vlib/build_ogr.c:82
#, fuzzy
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
-msgstr ""
-"Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support "
-"nicht erzeugen."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
+msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:90
#, c-format
@@ -5724,8 +5529,7 @@
#: ../lib/vector/Vlib/net.c:368
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
+msgstr "Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
#: ../lib/vector/Vlib/net.c:221
msgid "Registering arcs..."
@@ -5733,21 +5537,13 @@
#: ../lib/vector/Vlib/net.c:250
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht "
-"gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
#: ../lib/vector/Vlib/net.c:269
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden "
-"(Richtung der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden (Richtung der Linie übersprungen)."
#: ../lib/vector/Vlib/net.c:318
msgid "Cannot add network arc"
@@ -5760,9 +5556,7 @@
#: ../lib/vector/Vlib/net.c:411
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 "
-"gesetzt)."
+msgstr "Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 gesetzt)."
#: ../lib/vector/Vlib/net.c:440
msgid "Flattening the graph..."
@@ -5922,22 +5716,13 @@
#: ../lib/vector/Vlib/open_ogr.c:389
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. "
-"Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
#: ../lib/vector/Vlib/open_ogr.c:394
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
-"Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d."
-"%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu "
-"aktualisieren."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d.%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
#: ../lib/vector/Vlib/open_ogr.c:500
#, fuzzy, c-format
@@ -5951,20 +5736,13 @@
#: ../lib/vector/Vlib/open_nat.c:148
#, fuzzy, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist gröÃer als sie sein sollte (%ld Byte "
-"Ãberschuss)."
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist gröÃer als sie sein sollte (%ld Byte Ãberschuss)."
#: ../lib/vector/Vlib/open_nat.c:152
#, fuzzy, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte "
-"Fehlend)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte Fehlend)."
#: ../lib/vector/Vlib/write_sfa.c:107
#, fuzzy
@@ -5998,11 +5776,8 @@
msgstr "BUG: Aktualisiere die Karte, welche nicht im aktuellen Mapset ist."
#: ../lib/vector/Vlib/open.c:239
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum "
-"Aktualisierung geöffnet werden."
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum Aktualisierung geöffnet werden."
#: ../lib/vector/Vlib/open.c:276
#, fuzzy, c-format
@@ -6026,12 +5801,8 @@
#: ../lib/vector/Vlib/open.c:379 ../lib/vector/Vlib/open.c:401
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die "
-"Topologie mit v.build neu anzulegen."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die Topologie mit v.build neu anzulegen."
#: ../lib/vector/Vlib/open.c:410
#, fuzzy, c-format
@@ -6070,9 +5841,7 @@
#: ../lib/vector/Vlib/open.c:971
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"GröÃe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei "
-"gespeicherten Wert."
+msgstr "GröÃe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei gespeicherten Wert."
#: ../lib/vector/Vlib/open.c:982 ../lib/vector/Vlib/open.c:1081
#, c-format
@@ -6094,9 +5863,7 @@
msgstr ""
#: ../lib/vector/Vlib/dgraph.c:431
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
msgstr ""
#: ../lib/vector/Vlib/area.c:47
@@ -6131,9 +5898,7 @@
#: ../lib/vector/Vlib/cats.c:423
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine "
-"Kategoriespanne konvertieren."
+msgstr "Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine Kategoriespanne konvertieren."
#: ../lib/vector/Vlib/cats.c:516 ../lib/vector/Vlib/cats.c:610
#, fuzzy
@@ -6184,17 +5949,14 @@
#: ../lib/vector/Vlib/intersect.c:448
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
+msgstr "Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
#: ../lib/vector/Vlib/intersect.c:1179 ../lib/vector/Vlib/intersect.c:1185
#: ../lib/vector/Vlib/intersect.c:1187 ../lib/vector/Vlib/intersect.c:1241
#: ../lib/vector/Vlib/intersect.c:1250 ../lib/vector/Vlib/intersect.c:1271
#: ../lib/vector/Vlib/intersect.c:1288
msgid "Error while adding point to array. Out of memory"
-msgstr ""
-"Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend "
-"Arbeitsspeicher."
+msgstr "Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend Arbeitsspeicher."
#: ../lib/vector/Vlib/constraint.c:150
msgid "Layer constraint ignored for non-native vector formats"
@@ -6267,17 +6029,13 @@
#: ../lib/vector/Vlib/buffer2.c:589
#, fuzzy
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
-msgstr ""
-"Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr "Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
#: ../lib/vector/Vlib/buffer2.c:600
#, fuzzy
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
-msgstr ""
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
#: ../lib/vector/Vlib/buffer2.c:648
msgid "side != 0 feature not implemented"
@@ -6312,8 +6070,7 @@
#: ../lib/vector/Vlib/array.c:292
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
+msgstr "Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
#: ../lib/vector/Vlib/write.c:186
msgid "Unable to write feature, vector map is not opened"
@@ -6325,35 +6082,23 @@
#: ../lib/vector/Vlib/write.c:270
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem "
-"Level geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
#: ../lib/vector/Vlib/write.c:276
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus "
-"geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
#: ../lib/vector/Vlib/write.c:315
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf "
-"topologischem Level geöffnet."
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
#: ../lib/vector/Vlib/write.c:321
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:542
#, c-format
@@ -6455,9 +6200,7 @@
msgstr "Die Datenbankverbindung für den Layer <%d> ist nicht definiert."
#: ../lib/vector/Vlib/field.c:183
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
msgstr ""
#: ../lib/vector/Vlib/field.c:259
@@ -6493,17 +6236,12 @@
msgstr "Kann den OGR DBMI-Treiber nicht öffnen."
#: ../lib/vector/Vlib/field.c:755
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' "
-"sind in der OGR DB Tabelle vorhanden."
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' sind in der OGR DB Tabelle vorhanden."
#: ../lib/vector/Vlib/field.c:822
#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
#: ../lib/vector/Vlib/field.c:842
@@ -6522,8 +6260,7 @@
#: ../lib/vector/Vlib/field.c:1006
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
+msgstr "Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
#: ../lib/vector/Vlib/remove_areas.c:89
msgid "Area is composed of dead boundary"
@@ -6667,8 +6404,7 @@
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1534
-msgid ""
-"Inconsistency in topology detected: unable to determine next left/right edge."
+msgid "Inconsistency in topology detected: unable to determine next left/right edge."
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1601
@@ -6707,9 +6443,7 @@
#: ../lib/vector/Vlib/build_pg.c:79
#, fuzzy
msgid "Random read is not supported for this layer. Unable to build topology."
-msgstr ""
-"nicht erzeugen."
#: ../lib/vector/Vlib/build_pg.c:94
#, fuzzy
@@ -6990,22 +6724,13 @@
msgstr ""
#: ../lib/rst/interp_float/segmen2d.c:118
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie "
-"die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der "
-"Berechnung fort..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der Berechnung fort..."
#: ../lib/rst/interp_float/interp2d.c:214
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-"
-"value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-value %f, zmin %f, zmax %f."
#: ../lib/rst/interp_float/input2d.c:48
#, c-format
@@ -7074,8 +6799,7 @@
#: ../lib/rst/interp_float/vinput2d.c:249
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Es gibt Punkte auÃerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
+msgstr "Es gibt Punkte auÃerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
#: ../lib/rst/interp_float/vinput2d.c:252
#, c-format
@@ -7084,12 +6808,8 @@
#: ../lib/rst/interp_float/vinput2d.c:256
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die "
-"angegebenen NPMIN=%d."
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die angegebenen NPMIN=%d."
#: ../lib/rst/interp_float/vinput2d.c:261
msgid "Zero points in the given region"
@@ -7097,22 +6817,13 @@
#: ../lib/rst/interp_float/vinput2d.c:266
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum "
-"glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
#: ../lib/rst/interp_float/vinput2d.c:272
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung "
-"notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = "
-"%d (siehe Handbuch)."
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = %d (siehe Handbuch)."
#: ../lib/rst/interp_float/vinput2d.c:276
#, c-format
@@ -7412,12 +7123,8 @@
msgstr "G_getenv(): Variable %s nicht gesetzt."
#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut "
-"bauen oder verschiedene Installationen entwirren."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut bauen oder verschiedene Installationen entwirren."
#: ../lib/gis/gisinit.c:61
#, c-format
@@ -7431,9 +7138,7 @@
#: ../lib/gis/gisinit.c:97
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() "
-"aufzurufen."
+msgstr "System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() aufzurufen."
#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
msgid "Unable to seek"
@@ -7563,15 +7268,11 @@
#: ../lib/gis/parser.c:491
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --"
-"verbose."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --verbose."
#: ../lib/gis/parser.c:505
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"quiet."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --quiet."
#: ../lib/gis/parser.c:536
#, c-format
@@ -8108,8 +7809,7 @@
msgstr "Datenbank"
#: ../lib/gis/parser_standard_options.c:178
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
msgstr ""
#: ../lib/gis/parser_standard_options.c:187
@@ -8208,9 +7908,7 @@
msgstr "Datentyp verwendet in Ausgabedatei"
#: ../lib/gis/parser_standard_options.c:365
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
msgstr ""
#: ../lib/gis/parser_standard_options.c:375
@@ -8220,9 +7918,7 @@
#: ../lib/gis/parser_standard_options.c:385
#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
msgstr "Dimension der Kacheln, die für die Ausgabe verwerndet werden soll."
#: ../lib/gis/parser_standard_options.c:395
@@ -8268,13 +7964,8 @@
#: ../lib/gis/parser_standard_options.c:459
#, fuzzy
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
-msgstr ""
-"Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden."
-"Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
+msgstr "Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden.Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
#: ../lib/gis/parser_standard_options.c:469
#, fuzzy
@@ -8283,13 +7974,8 @@
#: ../lib/gis/parser_standard_options.c:471
#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
#: ../lib/gis/parser_standard_options.c:480
msgid "Category value"
@@ -8462,9 +8148,7 @@
#: ../lib/gis/parser_standard_options.c:766
#, fuzzy
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
#: ../lib/gis/parser_standard_options.c:767
@@ -8507,17 +8191,12 @@
#: ../lib/gis/view.c:545
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" Das in \"%s\" abgespeicherte Fenster ist komplett auÃerhalb des derzeitigen "
-"GRASS Fensters."
+msgstr " Das in \"%s\" abgespeicherte Fenster ist komplett auÃerhalb des derzeitigen GRASS Fensters."
#: ../lib/gis/view.c:549
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
-"derzeitigen GRASS-Fenster."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem derzeitigen GRASS-Fenster."
#: ../lib/gis/parser_html.c:53 ../lib/gis/parser_rest.c:60
msgid "NAME"
@@ -8551,9 +8230,7 @@
#: ../lib/gis/distance.c:154
#, fuzzy, c-format
msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) "
-"S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#: ../lib/gis/debug.c:80
#, c-format
@@ -8760,8 +8437,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:38
#, fuzzy, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
+msgstr "Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:45
#, fuzzy, c-format
@@ -8771,8 +8447,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:54
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-"Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
#: ../lib/db/dbmi_base/default_name.c:136
msgid "Programmer error"
@@ -8782,238 +8457,223 @@
msgid "send data: invalid C-type"
msgstr ""
-#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
-#~ msgstr ""
-#~ "Kann \"lockfile\" %s nicht anlegen (Festplatte voll? Zugriffsrechte?)"
-#~ msgid ""
-#~ "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-#~ msgstr ""
-#~ "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s@%s> "
-#~ "nicht öffnen."
-#~ msgid "Unable to open topo file for write <%s>"
-#~ msgstr "Kann Topologie-Datei nicht zum Schreiben von <%s> öffnen."
#, fuzzy
-#~ msgid ""
-#~ "Unable to get number of records for:\n"
-#~ "%s"
-#~ msgstr "Kann Datei head nicht lesen"
+msgid ""
+"Unable to get number of records for:\n"
+"%s"
+msgstr "Kann Datei head nicht lesen"
#, fuzzy
-#~ msgid "Unable to read node %d"
-#~ msgstr "Kann Linie %d nicht lesen."
+msgid "Unable to read node %d"
+msgstr "Kann Linie %d nicht lesen."
#, fuzzy
-#~ msgid "Unable to read nodes"
+msgid "Unable to read nodes"
#, fuzzy
-#~ msgid "Unable to read lines"
+msgid "Unable to read lines"
#, fuzzy
-#~ msgid "Unable to attach centroids"
-#~ msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
+msgid "Unable to attach centroids"
+msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
#, fuzzy
-#~ msgid "Unexpected feature type (%s) - should be (%d)"
-#~ msgstr "Eigenschaften"
+msgid "Unexpected feature type (%s) - should be (%d)"
+msgstr "Eigenschaften"
#, fuzzy
-#~ msgid "Unable to read centroid %d: %s"
-#~ msgstr "Kann die Objekt-ID %d nicht lesen."
+msgid "Unable to read centroid %d: %s"
+msgstr "Kann die Objekt-ID %d nicht lesen."
#, fuzzy
-#~ msgid "Unable to export node %d. Exiting."
-#~ msgstr "Kann keinen Speicher für temporäres Bild belegen."
+msgid "Unable to export node %d. Exiting."
+msgstr "Kann keinen Speicher für temporäres Bild belegen."
#, fuzzy
-#~ msgid "Unable to look up account id"
-#~ msgstr "Kann Codec nicht öffnen."
+msgid "Unable to look up account id"
+msgstr "Kann Codec nicht öffnen."
#, fuzzy
-#~ msgid "Unable to allocate memory for account name"
-#~ msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
+msgid "Unable to allocate memory for account name"
+msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
#, fuzzy
-#~ msgid "Unable to allocate memory for domain name"
+msgid "Unable to allocate memory for domain name"
#, fuzzy
-#~ msgid "Unable to remove space time dataset register table <%s>"
-#~ msgstr "Kann keine Daten aus der Tabelle <%s> beziehen."
+msgid "Unable to remove space time dataset register table <%s>"
+msgstr "Kann keine Daten aus der Tabelle <%s> beziehen."
#, fuzzy
-#~ msgid "Unable to drop table <%s>"
-#~ msgstr "Kann die Tabelle <%s> nicht kopieren."
+msgid "Unable to drop table <%s>"
+msgstr "Kann die Tabelle <%s> nicht kopieren."
#, fuzzy
-#~ msgid ""
-#~ "Unable to create the space time %s dataset register table for map <%s> "
-#~ "with layer %s"
-#~ msgstr "Kann Header-Datei für [%s] nicht erstellen."
+msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
+msgstr "Kann Header-Datei für [%s] nicht erstellen."
#, fuzzy
-#~ msgid "Unable to find map <%s> with layer %s in temporal database"
-#~ msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
+msgid "Unable to find map <%s> with layer %s in temporal database"
+msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
#, fuzzy
-#~ msgid ""
-#~ "Spatial index format version %d.%d is not supported by this release. Try "
-#~ "to rebuild topology or upgrade GRASS."
-#~ msgstr "Vektor."
+msgid "Spatial index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Vektor."
#, fuzzy
-#~ msgid "Unable to read read line %d"
-#~ msgstr "Kann Linie %d nicht lesen"
+msgid "Unable to read read line %d"
+msgstr "Kann Linie %d nicht lesen"
#, fuzzy
-#~ msgid "Unable to delete feature id %d from vector map <%s>"
-#~ msgstr "Vektor Karte"
+msgid "Unable to delete feature id %d from vector map <%s>"
+msgstr "Vektor Karte"
#, fuzzy
-#~ msgid "Unable to open null device"
-#~ msgstr "Kann %s nicht öffnen."
+msgid "Unable to open null device"
+msgstr "Kann %s nicht öffnen."
#, fuzzy
-#~ msgid "The support for OGR vector maps wasn't compiled in"
-#~ msgstr "Kategorie Unterstützung für die Vektordatei [%s] in Mapset [%s] %s"
+msgid "The support for OGR vector maps wasn't compiled in"
+msgstr "Kategorie Unterstützung für die Vektordatei [%s] in Mapset [%s] %s"
#, fuzzy
-#~ msgid "End time must be later than start time"
-#~ msgstr "Ostwert muss gröÃer als der Westwert sein."
+msgid "End time must be later than start time"
+msgstr "Ostwert muss gröÃer als der Westwert sein."
#, fuzzy
-#~ msgid "None"
-#~ msgstr "nichts"
+msgid "None"
+msgstr "nichts"
#, fuzzy
-#~ msgid "Unknown"
-#~ msgstr "nicht bekannt"
+msgid "Unknown"
+msgstr "nicht bekannt"
#, fuzzy
-#~ msgid "Uknown column <%s>"
-#~ msgstr "Unbekannter Spaltentyp (Spalte <%s>)"
+msgid "Uknown column <%s>"
+msgstr "Unbekannter Spaltentyp (Spalte <%s>)"
#, fuzzy
-#~ msgid "test, gmath"
-#~ msgstr "test, gpde"
+msgid "test, gmath"
+msgstr "test, gpde"
#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#~ msgstr "Kann Datei '%s' nicht löschen."
+msgid "Unable to delete file '%s'. Reason: %s"
+msgstr "Kann Datei '%s' nicht löschen."
#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#~ msgstr "Kann das Verzeichnis '%s' nicht in '%s' umbenennen."
+msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
+msgstr "Kann das Verzeichnis '%s' nicht in '%s' umbenennen."
#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
+msgid "Unable to delete prior null-cells file"
#, fuzzy
-#~ msgid "Unable to close the null-cells file"
-#~ msgstr "Kann head nicht in die plus-Datei schreiben."
+msgid "Unable to close the null-cells file"
+msgstr "Kann head nicht in die plus-Datei schreiben."
#, fuzzy
-#~ msgid "closecell: can't move [%s] to null-cells file [%s]"
-#~ msgstr ""
-#~ "closecell: Kann %s\n"
-#~ "nicht in die NULL-Datei %s verschieben."
+msgid "closecell: can't move [%s] to null-cells file [%s]"
+msgstr ""
+"closecell: Kann %s\n"
+"nicht in die NULL-Datei %s verschieben."
#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#~ msgstr "Kann keine temporäre NULL-Datei %s finden."
+msgid "Unable to delete the temporary null-cells file"
+msgstr "Kann keine temporäre NULL-Datei %s finden."
#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
+msgid "Unable to delete the empty temporary null-cells file"
#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
+msgid "Unable to delete the prior null-cells file"
#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
-#~ msgstr "Kann Header-Datei nicht lesen."
+msgid "Unable to close the 'cell' file"
+msgstr "Kann Header-Datei nicht lesen."
#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
+msgid "Unable to delete prior 'fcell' file"
#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
-#~ msgstr "Kann Tabelle <%s> nicht löschen."
+msgid "Unable to delete the prior %s file"
+msgstr "Kann Tabelle <%s> nicht löschen."
#, fuzzy
-#~ msgid "Unable to close file"
-#~ msgstr "Kann Datei %s nicht öffnen."
+msgid "Unable to close file"
+msgstr "Kann Datei %s nicht öffnen."
#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
+msgid "Unable to delete the prior 'cell' file"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to cell file [%s]"
-#~ msgstr ""
-#~ "nicht in die cell-Datei %s verschieben."
+msgid "closecell: can't move [%s] to cell file [%s]"
+msgstr ""
+"nicht in die cell-Datei %s verschieben."
#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
-#~ msgstr "Kann temporäre Datei nicht öffnen."
+msgid "Unable to delete the temporary 'cell' file"
+msgstr "Kann temporäre Datei nicht öffnen."
#, fuzzy
-#~ msgid "Unable to write quant file!"
-#~ msgstr "Kann quant-Datei nicht schreiben!"
+msgid "Unable to write quant file!"
+msgstr "Kann quant-Datei nicht schreiben!"
#, fuzzy
-#~ msgid "Unable to delete the %s file"
+msgid "Unable to delete the %s file"
#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#~ msgstr "Kann f_format Datei für cell-Karten nicht schreiben."
+msgid "Unable to write f_format file for CELL maps"
+msgstr "Kann f_format Datei für cell-Karten nicht schreiben."
-#~ msgid ""
-#~ "taking too long to find points for interpolation--please change the "
-#~ "region to area where your points are. Continuing calculations..."
-#~ msgstr ""
-#~ "Es dauert zu lange, um Punkte für die Interpolation zu finden -- bitte "
-#~ "ändern Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit "
-#~ "der Berechnung fort..."
+msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
+msgstr "Es dauert zu lange, um Punkte für die Interpolation zu finden -- bitte ändern Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit der Berechnung fort..."
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "Lese Linien der Vektorkarte ... "
+msgid "Reading lines from vector map ... "
+msgstr "Lese Linien der Vektorkarte ... "
-#~ msgid "Reading nodes from vector map ... "
-#~ msgstr "Lese Knoten der Vektorkarte ... "
+msgid "Reading nodes from vector map ... "
+msgstr "Lese Knoten der Vektorkarte ... "
-#~ msgid "strip exists with insufficient data"
-#~ msgstr "Es gibt einen Streifen mit unzureichend Daten."
+msgid "strip exists with insufficient data"
+msgstr "Es gibt einen Streifen mit unzureichend Daten."
-#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
-#~ msgstr ""
-#~ "Es sind Punkte auÃerhalb der angegebenen 2D/3D-Region gefunden worden - "
-#~ "ignoriere %d Punkte."
+msgid "there are points outside specified 2D/3D region--ignored %d points"
+msgstr "Es sind Punkte auÃerhalb der angegebenen 2D/3D-Region gefunden worden - ignoriere %d Punkte."
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "Ignoriere %d Punkte -- sie liegen zu dicht beieinander."
+msgid "ignoring %d points -- too dense"
+msgstr "Ignoriere %d Punkte -- sie liegen zu dicht beieinander."
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "einige Punkte sind auÃerhalb der Region -- ignoriere dies..."
+msgid "some points outside of region -- will ignore..."
+msgstr "einige Punkte sind auÃerhalb der Region -- ignoriere dies..."
-#~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d reservieren."
+msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d reservieren."
-#~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-#~ msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d reservieren."
+msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d reservieren."
-#~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d reservieren."
+msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d reservieren."
+#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
+#~ msgstr "Kann \"lockfile\" %s nicht anlegen (Festplatte voll? Zugriffsrechte?)"
+#~ msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+#~ msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s@%s> nicht öffnen."
+#~ msgid "Unable to open topo file for write <%s>"
+#~ msgstr "Kann Topologie-Datei nicht zum Schreiben von <%s> öffnen."
#~ msgid "cell_values_float: xdr_float failed for index %d"
#~ msgstr "cell_values_double: xdr_float ist fehlgeschlagen für Index %d."
@@ -9153,8 +8813,7 @@
#~ msgstr "Verwenden Sie d.mon, um ein Grafikfenster zu selektieren."
#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
+#~ msgstr "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
#~ msgid "Probably program error."
#~ msgstr "Wahrscheinlich ein Programmfehler."
@@ -9226,12 +8885,8 @@
#~ msgid "Cannot write quant rules: map %s is integer"
#~ msgstr "Kann quant-Regeln nicht schreiben: Karte %s ist eine Integerkarte."
-#~ msgid ""
-#~ "G_set_window(): projection/zone differs from that of currently open "
-#~ "raster maps"
-#~ msgstr ""
-#~ "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten "
-#~ "Rasterkarten."
+#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+#~ msgstr "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten Rasterkarten."
#~ msgid "The floating data range for %s@%s is empty"
#~ msgstr "Der FlieÃkomma-Wertebereich von %s@%s ist leer."
@@ -9243,23 +8898,16 @@
#~ msgstr "Quantisierungsdatei [%s] in Mapset [%s] %s."
#~ msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-#~ msgstr ""
-#~ "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]"
-#~ "_raster_row()!"
+#~ msgstr "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]_raster_row()!"
#~ msgid "%s: map [%s] not open for write - request ignored"
-#~ msgstr ""
-#~ "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+#~ msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
#~ msgid "%s: map [%s] not open for random write - request ignored"
-#~ msgstr ""
-#~ "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird "
-#~ "ignoriert."
+#~ msgstr "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird ignoriert."
#~ msgid "%s: map [%s] not open for sequential write - request ignored"
-#~ msgstr ""
-#~ "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage "
-#~ "wird ignoriert."
+#~ msgstr "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird ignoriert."
#~ msgid "%s: unopened file descriptor - request ignored"
#~ msgstr "%s: Ungeöffneter Dateideskriptor - Anfrage ignoriert."
@@ -9331,12 +8979,8 @@
#~ msgid "Layer number"
#~ msgstr "Layer-Nummer"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
-#~ msgstr ""
-#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#~ msgid "Sorry <%s> is not a valid option\n"
#~ msgstr "Tut mir leid, <%s> ist keine gültige Option\n"
@@ -9500,8 +9144,7 @@
#~ msgstr "Ungültiger Zeitstempel für %s Karte %s in Mapset %s angegeben."
#~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Kann die Zeitstempel-Datei für %s Karte %s in Mapset %s nicht öffnen."
+#~ msgstr "Kann die Zeitstempel-Datei für %s Karte %s in Mapset %s nicht öffnen."
#~ msgid "Can not create a new process!"
#~ msgstr "Kann keinen neuen Prozess erzeugen!"
@@ -9576,9 +9219,7 @@
#~ msgstr "Geben Sie %s Dateinamen ein."
#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr ""
-#~ "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien "
-#~ "ein.\n"
+#~ msgstr "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
#~ msgid "Enter 'list -f' for "
#~ msgstr "Geben Sie 'list -f' für "
@@ -9640,8 +9281,7 @@
#~ msgstr "Zu viele reklassifizierte Kategorien für [%s in %s]."
#~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr ""
-#~ "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
+#~ msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
#~ msgid "Unable to create header file for [%s in %s]"
#~ msgstr "Kann Header-Datei für [%s in %s] nicht anlegen."
@@ -9672,12 +9312,8 @@
#~ msgid "Unable to get GIS_LOCK environment variable value"
#~ msgstr "Kann den Inhalt der Umgebungsvariable GIS_LOCK nicht lesen."
-#~ msgid ""
-#~ "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S="
-#~ "(%f,%f)(%f,%f)"
-#~ msgstr ""
-#~ "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,"
-#~ "%f) S=(%f,%f)(%f,%f)"
+#~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#~ msgid "Unable to open raster map <%s@%s>"
#~ msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen."
@@ -9685,27 +9321,17 @@
#~ msgid "Unable to find <%s@%s>"
#~ msgstr "Kann <%s@%s> nicht finden."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different projection than current region. Found "
-#~ "raster map <%s@%s>, should be <%s>."
-#~ msgstr ""
-#~ "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle "
-#~ "Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
+#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+#~ msgstr "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-#~ msgstr ""
-#~ "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle "
-#~ "Region (%d)."
+#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region (%d)."
#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
#~ msgstr "Rasterkarte <%s@%s>: Bytes pro Zelle (%d) zu groÃ."
-#~ msgid ""
-#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-#~ msgstr ""
-#~ "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-"
-#~ "Unterstützung kompiliert."
+#~ msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-Unterstützung kompiliert."
#~ msgid "<%s>: bad mapset"
#~ msgstr "<%s>: schlechtes Mapset"
@@ -9713,16 +9339,11 @@
#~ msgid "G__open_raster_new(): no temp files available"
#~ msgstr "G__open_raster_new(): keine temp-Datei vorhanden."
-#~ msgid ""
-#~ "Unable to write embedded null values for raster map open for random access"
-#~ msgstr ""
-#~ "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet "
-#~ "für den direkten Zugriff."
+#~ msgid "Unable to write embedded null values for raster map open for random access"
+#~ msgstr "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für den direkten Zugriff."
#~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-#~ msgstr ""
-#~ "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen "
-#~ "werden."
+#~ msgstr "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
#~ msgid "Unable to find '%s' in '%s'"
#~ msgstr "Kann '%s' in '%s' nicht finden."
@@ -9730,11 +9351,8 @@
#~ msgid "Unable to open '%s'"
#~ msgstr "Kann '%s' nicht öffnen."
-#~ msgid ""
-#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
-#~ msgstr ""
-#~ "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten "
-#~ "aufgerufen werden."
+#~ msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen werden."
#~ msgid "Enter 'list' for the list of available datums\n"
#~ msgstr "Geben Sie 'list' für eine Liste der verfügbaren Datums ein\n"
@@ -9780,9 +9398,7 @@
#~ msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s> "
#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr ""
-#~ " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei "
-#~ "ungültig ist."
+#~ msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei ungültig ist."
#~ msgid " Invalid format."
#~ msgstr " Ungültiges Format."
@@ -9791,13 +9407,10 @@
#~ msgstr "Kann die History-Informationen der Karte [%s] nicht schreiben."
#~ msgid "Not enough room in history file to record command line."
-#~ msgstr ""
-#~ "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu "
-#~ "speichern."
+#~ msgstr "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu speichern."
#~ msgid "Not enough room in history file for command line (truncated)."
-#~ msgstr ""
-#~ "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
+#~ msgstr "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
#~ msgid "Graphics driver [%s] started"
#~ msgstr "Grafiktreiber [%s] gestartet."
@@ -9811,17 +9424,11 @@
#~ msgid "not implemented"
#~ msgstr "nicht implementiert"
-#~ msgid ""
-#~ "Unable to build spatial index from topology, vector map is not opened at "
-#~ "topo level 2"
-#~ msgstr ""
-#~ "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist "
-#~ "nicht auf dem topo level 2 geöffnet."
+#~ msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+#~ msgstr "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist nicht auf dem topo level 2 geöffnet."
#~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr ""
-#~ "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im "
-#~ "Schreibmodus geöffnet."
+#~ msgstr "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im Schreibmodus geöffnet."
#~ msgid "Error in rule on row %d in %s"
#~ msgstr "Fehler in der Regel in Zeile %d in %s."
@@ -9830,22 +9437,13 @@
#~ msgstr "Unbekanntes Schlüsselwort %s in Vektor Header."
#~ msgid "Next edge was visited but it is not the first one !!! breaking loop"
-#~ msgstr ""
-#~ "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
+#~ msgstr "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
-#~ msgid ""
-#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-#~ "excess)"
-#~ msgstr ""
-#~ "Coor-Datei der Vektorkarte <%s@%s> ist gröÃer als sie sein sollte (%ld "
-#~ "Byte zuviel)."
+#~ msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+#~ msgstr "Coor-Datei der Vektorkarte <%s@%s> ist gröÃer als sie sein sollte (%ld Byte zuviel)."
-#~ msgid ""
-#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-#~ "missing)."
-#~ msgstr ""
-#~ "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld "
-#~ "Byte fehlen)."
+#~ msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#~ msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte fehlen)."
#~ msgid "Intersections: %5d"
#~ msgstr "Ãberschneidungen: %5d"
@@ -9875,9 +9473,7 @@
#~ msgstr "Kann die Rasterzeile %i nicht schreiben."
#~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr ""
-#~ "Der GauÃsche Eliminierungslöser kann keine dünnbesetzten Matrizen "
-#~ "verarbeiten."
+#~ msgstr "Der GauÃsche Eliminierungslöser kann keine dünnbesetzten Matrizen verarbeiten."
#~ msgid "The linear equation system is not quadratic"
#~ msgstr "Das lineare Gleichungssystem ist nicht quadratisch."
@@ -9891,45 +9487,32 @@
#~ msgid "Matrix is not symmetric!"
#~ msgstr "Matrix ist nicht symmetrisch!"
-#~ msgid ""
-#~ "The type of solver which should solve the symmetric linear equation system"
-#~ msgstr ""
-#~ "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
+#~ msgid "The type of solver which should solve the symmetric linear equation system"
+#~ msgstr "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
#~ msgid "The type of solver which should solve the linear equation system"
#~ msgstr "Der Solver, der das lineare Gleichungssysteme lösen soll"
-#~ msgid ""
-#~ "Maximum number of iteration used to solver the linear equation system"
-#~ msgstr ""
-#~ "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
+#~ msgid "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
-#~ msgid ""
-#~ "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-#~ msgstr ""
-#~ "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
+#~ msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+#~ msgstr "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
-#~ msgid ""
-#~ "The relaxation parameter used by the jacobi and sor solver for speedup or "
-#~ "stabilizing"
-#~ msgstr ""
-#~ "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder "
-#~ "Stabilisierung der Jacobi und SOR Löser"
+#~ msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+#~ msgstr "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder Stabilisierung der Jacobi und SOR Löser"
#~ msgid "test, gpde"
#~ msgstr "Test, gpde"
#~ msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-#~ msgstr ""
-#~ "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
+#~ msgstr "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
#~ msgid "Illegal table map name <%s>. Must start with a letter.\n"
-#~ msgstr ""
-#~ "Ungültiger Tabellenname <%s>. Er muss mit einem Buchstaben beginnen.\n"
+#~ msgstr "Ungültiger Tabellenname <%s>. Er muss mit einem Buchstaben beginnen.\n"
#~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-#~ msgstr ""
-#~ "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+#~ msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
#~ msgid "Unable to feature %d from vector map <%s>"
#~ msgstr "Unable to feature %d from vector map <%s>"
@@ -9941,14 +9524,10 @@
#~ msgstr "Vektor ist nicht 3D."
#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. "
-#~ "mit v.info)."
+#~ msgstr "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. mit v.info)."
#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double sein)."
#~ msgid "Cannot read column type of smooth column"
#~ msgstr "Kann den Spaltentyp der Smooth-Spalte nicht lesen."
@@ -9957,9 +9536,7 @@
#~ msgstr "Spaltentyp der Smooth-Spalte (datetime) wird nicht unterstützt."
#~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double sein)."
#~ msgid "Unknown Location"
#~ msgstr "Unbekannte Location"
@@ -10088,8 +9665,7 @@
#~ msgstr "G3d_openCellOld: Fehler in G3d_readHeader"
#~ msgid "G3d_openCellOld: projection does not match window projection"
-#~ msgstr ""
-#~ "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
+#~ msgstr "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
#~ msgid "G3d_openCellOld: zone does not match window zone"
#~ msgstr "G3d_openCellOld: Zone passt nicht zu der Zone des Fensters"
@@ -10177,18 +9753,11 @@
#~ msgid "'%s' must be > 0 for '%s'"
#~ msgstr "'%s' muss > 0 für '%s' sein"
-#~ msgid ""
-#~ "Vect_read_line(): feature id %d is not reasonable (max features in vector "
-#~ "map <%s>: %d)"
-#~ msgstr ""
-#~ "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
-#~ "Vektorkarte <%s>: %d)."
+#~ msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+#~ msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
-#~ msgid ""
-#~ "Random read is not supported by OGR for this layer, cannot build support"
-#~ msgstr ""
-#~ "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann "
-#~ "Support nicht erzeugen."
+#~ msgid "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
#~ msgid "Feature %d without geometry ignored"
#~ msgstr "Objekt %d ohne Geometrie ignoriert."
@@ -10223,3 +9792,12 @@
#~ msgid "unable to write quant file!"
+#~ msgid "%d errors in category string."
+#~ msgstr "%d Fehler in Kategorie-Zeichenkette."
+#~ msgid "MAPSET %s not found"
+#~ msgstr "MAPSET %s nicht gefunden."
+#~ msgid "LOCATION << %s >> not available"
+#~ msgstr "LOCATION << %s >> ist nicht vorhanden."
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_el.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_el\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-02-18 14:05+0100\n"
+"POT-Creation-Date: 2013-02-26 14:45+0100\n"
"PO-Revision-Date: 2008-10-16 11:25+0300\n"
"Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -1056,7 +1056,7 @@
msgid "WARNING"
msgstr "ÐÑÏÓÏ×Ç:"
-#: ../lib/init/grass.py:183
+#: ../lib/init/grass.py:186
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1064,120 +1064,120 @@
"×ñÞóç:\n"
-#: ../lib/init/grass.py:184 ../lib/gis/parser_html.c:140
+#: ../lib/init/grass.py:187 ../lib/gis/parser_html.c:140
#: ../lib/gis/parser_rest.c:146
msgid "Flags"
msgstr ""
-#: ../lib/init/grass.py:185
+#: ../lib/init/grass.py:188
msgid "print this help message"
msgstr ""
-#: ../lib/init/grass.py:186
+#: ../lib/init/grass.py:189
msgid "show version information and exit"
msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:190
msgid "create given database, location or mapset if it doesn't exist"
msgstr ""
-#: ../lib/init/grass.py:188
+#: ../lib/init/grass.py:191
msgid "use text based interface"
msgstr ""
-#: ../lib/init/grass.py:189 ../lib/init/grass.py:191
+#: ../lib/init/grass.py:192 ../lib/init/grass.py:194
#, fuzzy
msgid "and set as default"
msgstr "ãéá íá áðïäåêôåßôå ôï ðñïêáèïñéóìÝíï"
-#: ../lib/init/grass.py:190
+#: ../lib/init/grass.py:193
msgid "use $DEFAULT_GUI graphical user interface"
msgstr ""
-#: ../lib/init/grass.py:192
+#: ../lib/init/grass.py:195
msgid "print GRASS configuration parameters"
msgstr ""
-#: ../lib/init/grass.py:193
+#: ../lib/init/grass.py:196
msgid "options: arch,build,compiler,path,revision"
msgstr ""
-#: ../lib/init/grass.py:194 ../lib/gis/parser_html.c:180
+#: ../lib/init/grass.py:197 ../lib/gis/parser_html.c:180
#: ../lib/gis/parser_rest.c:179
msgid "Parameters"
msgstr "ÐáñÜìåôñïé"
-#: ../lib/init/grass.py:195
+#: ../lib/init/grass.py:198
msgid "initial database (path to GIS data)"
msgstr ""
-#: ../lib/init/grass.py:196
+#: ../lib/init/grass.py:199
#, fuzzy
msgid "initial location"
msgstr ""
"\n"
"ËáíèáóìÝíç ðñïâïëÞ\n"
-#: ../lib/init/grass.py:197
+#: ../lib/init/grass.py:200
msgid "initial mapset"
msgstr ""
-#: ../lib/init/grass.py:198
+#: ../lib/init/grass.py:201
msgid "fully qualified initial mapset directory"
msgstr ""
-#: ../lib/init/grass.py:199
+#: ../lib/init/grass.py:202
msgid "Environment variables relevant for startup"
msgstr ""
-#: ../lib/init/grass.py:200
+#: ../lib/init/grass.py:203
msgid "select GUI (text, gui)"
msgstr ""
-#: ../lib/init/grass.py:201
+#: ../lib/init/grass.py:204
msgid "set wish shell name to override 'wish'"
msgstr ""
-#: ../lib/init/grass.py:202
+#: ../lib/init/grass.py:205
msgid "set html web browser for help pages"
msgstr ""
-#: ../lib/init/grass.py:203
+#: ../lib/init/grass.py:206
msgid "set additional path(s) to local GRASS modules or user scripts"
msgstr ""
-#: ../lib/init/grass.py:204
+#: ../lib/init/grass.py:207
msgid "set additional GISBASE for locally installed GRASS Addons"
msgstr ""
-#: ../lib/init/grass.py:205
+#: ../lib/init/grass.py:208
msgid "shell script to be processed as batch job"
msgstr ""
-#: ../lib/init/grass.py:206
+#: ../lib/init/grass.py:209
msgid "set python shell name to override 'python'"
msgstr ""
-#: ../lib/init/grass.py:228
+#: ../lib/init/grass.py:231
#, fuzzy, python-format
msgid "Unable to create temporary directory <%s>! Exiting."
msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ðñïóùñéíÞ åéêüíá"
-#: ../lib/init/grass.py:306
+#: ../lib/init/grass.py:309
msgid "GUI <%s> not supported in this version"
msgstr "Ôï óõãêåêñéìÝíï format äåí ãßíåé compiled ãéá ôçí Ýêäïóç áõôÞ"
-#: ../lib/init/grass.py:444
+#: ../lib/init/grass.py:447
msgid "Searched for a web browser, but none found"
msgstr ""
-#: ../lib/init/grass.py:468
+#: ../lib/init/grass.py:471
#, fuzzy
msgid "Hit RETURN to continue"
msgstr "ÐáôÞóôå RETURN ãéá óõíÝ÷åéá -->"
-#: ../lib/init/grass.py:497
+#: ../lib/init/grass.py:500
msgid ""
"The python command does not work as expected!\n"
"Please check your GRASS_PYTHON environment variable.\n"
@@ -1187,7 +1187,7 @@
"Hit RETURN to continue.\n"
msgstr ""
-#: ../lib/init/grass.py:509
+#: ../lib/init/grass.py:512
msgid ""
"It appears that the X Windows system is not active.\n"
"A graphical based user interface is not supported.\n"
@@ -1196,34 +1196,34 @@
msgstr ""
-#: ../lib/init/grass.py:551 ../lib/init/grass.py:582
+#: ../lib/init/grass.py:554 ../lib/init/grass.py:585
msgid "<%s> is not a valid GRASS location"
msgstr "Óõãíþìç <%s> äåí åßíáé áðïäåêôÞ åðéëïãÞ\n"
-#: ../lib/init/grass.py:563
+#: ../lib/init/grass.py:566
#, python-format
msgid "Failed to create new location. The location <%s> already exists."
msgstr ""
-#: ../lib/init/grass.py:580
+#: ../lib/init/grass.py:583
msgid "Missing WIND file fixed"
msgstr ""
-#: ../lib/init/grass.py:594
+#: ../lib/init/grass.py:597
msgid ""
"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
"Interactive startup needed."
msgstr ""
-#: ../lib/init/grass.py:608
+#: ../lib/init/grass.py:611
#, python-format
msgid ""
"Invalid user interface specified - <%s>.\n"
"Use the --help option to see valid interface names."
msgstr ""
-#: ../lib/init/grass.py:621
+#: ../lib/init/grass.py:624
msgid ""
"Error in GUI startup. If necessary, please report this error to the GRASS "
"developers.\n"
@@ -1232,13 +1232,13 @@
"Hit RETURN to continue..."
msgstr ""
-#: ../lib/init/grass.py:631
+#: ../lib/init/grass.py:634
msgid ""
"Received EXIT message from GUI.\n"
"GRASS is not started. Bye."
msgstr ""
-#: ../lib/init/grass.py:634
+#: ../lib/init/grass.py:637
#, fuzzy
msgid ""
"Invalid return code from GUI startup script.\n"
@@ -1247,7 +1247,7 @@
"Ðáñáêáëþ åíçìåñþóôå ôïõò ðñïãñáììáôéóôÝò ôïõ GRASS ãéá áõôü ôï ìÞíõìá "
"ëÜèïõò.\n"
-#: ../lib/init/grass.py:644
+#: ../lib/init/grass.py:647
msgid ""
"Error reading data path information from g.gisenv.\n"
"GISDBASE=%(gisbase)s\n"
@@ -1257,36 +1257,36 @@
"Check the <%s(file)> file."
msgstr ""
-#: ../lib/init/grass.py:727
+#: ../lib/init/grass.py:730
msgid "Path '%s' doesn't exist"
msgstr "%s: ÅðéäÜíåéá %d äåí õðÜñ÷åé"
-#: ../lib/init/grass.py:738
+#: ../lib/init/grass.py:741
#, python-format
msgid ""
"%(user)s is currently running GRASS in selected mapset (file %(file)s "
"found). Concurrent use not allowed."
msgstr ""
-#: ../lib/init/grass.py:742
+#: ../lib/init/grass.py:745
#, python-format
msgid ""
"Unable to properly access '%s'.\n"
"Please notify system personel."
msgstr ""
-#: ../lib/init/grass.py:756
+#: ../lib/init/grass.py:759
#, fuzzy
msgid "Building user fontcap..."
msgstr "Äçìéïõñãßá åðéöáíåéþí"
-#: ../lib/init/grass.py:790
+#: ../lib/init/grass.py:793
#, fuzzy
msgid "The SHELL variable is not set"
msgstr "GISRC - ç ðáñÜìåôñïò äåí Ý÷åé êáèïñéóôåß"
-#: ../lib/init/grass.py:800
+#: ../lib/init/grass.py:803
#, python-format
msgid ""
"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -1295,89 +1295,89 @@
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
-#: ../lib/init/grass.py:805
+#: ../lib/init/grass.py:808
#, python-format
msgid "Change file permission to 'executable' for '%s'"
msgstr ""
-#: ../lib/init/grass.py:807
+#: ../lib/init/grass.py:810
#, python-format
msgid "Executing '%s' ..."
msgstr ""
-#: ../lib/init/grass.py:812
+#: ../lib/init/grass.py:815
#, python-format
msgid "Execution of '%s' finished."
msgstr ""
-#: ../lib/init/grass.py:817
+#: ../lib/init/grass.py:820
#, python-format
msgid "GRASS GUI should be <%s>"
msgstr ""
-#: ../lib/init/grass.py:845
+#: ../lib/init/grass.py:848
#, python-format
msgid "Welcome to GRASS %s"
msgstr ""
-#: ../lib/init/grass.py:854
+#: ../lib/init/grass.py:857
msgid "GRASS homepage:"
msgstr ""
-#: ../lib/init/grass.py:855
+#: ../lib/init/grass.py:858
msgid "This version running through:"
msgstr ""
-#: ../lib/init/grass.py:857
+#: ../lib/init/grass.py:860
#, fuzzy
msgid "Help is available with the command:"
msgstr "Äåí õðÜñ÷åé êåßìåíï âïÞèåéáò ãéá ôçí åíôïëÞ [%s]\n"
-#: ../lib/init/grass.py:858
+#: ../lib/init/grass.py:861
msgid "See the licence terms with:"
msgstr ""
-#: ../lib/init/grass.py:861
+#: ../lib/init/grass.py:864
msgid "If required, restart the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:863
+#: ../lib/init/grass.py:866
msgid "Start the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:865
+#: ../lib/init/grass.py:868
msgid "When ready to quit enter:"
msgstr ""
-#: ../lib/init/grass.py:969
+#: ../lib/init/grass.py:972
msgid "Failed to start shell '%s'"
msgstr "Áäõíáìßá åêêßíçóçò ôïõ ïäçãïý <%s>"
-#: ../lib/init/grass.py:973
+#: ../lib/init/grass.py:976
#, python-format
msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
msgstr ""
-#: ../lib/init/grass.py:974 ../lib/init/grass.py:979
+#: ../lib/init/grass.py:977 ../lib/init/grass.py:982
msgid "Goodbye from GRASS GIS"
msgstr ""
-#: ../lib/init/grass.py:977
+#: ../lib/init/grass.py:980
#, fuzzy
msgid "Done."
msgstr "êáíÝíá"
-#: ../lib/init/grass.py:983
+#: ../lib/init/grass.py:986
msgid "Cleaning up temporary files..."
msgstr ""
-#: ../lib/init/grass.py:1025
+#: ../lib/init/grass.py:1028
msgid "Parameter <%s> not supported"
msgstr "Ï 3Ä ÷Üñôçò raster <%s> äåí âñÝèçêå"
-#: ../lib/init/grass.py:1166
+#: ../lib/init/grass.py:1169
#, python-format
msgid ""
"Unable to start GRASS. You can:\n"
@@ -1387,11 +1387,11 @@
"path/to/location/mapset`)"
msgstr ""
-#: ../lib/init/grass.py:1175
+#: ../lib/init/grass.py:1178
msgid "Starting GRASS GIS..."
msgstr ""
-#: ../lib/init/grass.py:1233
+#: ../lib/init/grass.py:1236
#, python-format
msgid "Launching <%s> GUI in the background, please wait..."
msgstr ""
@@ -4042,6 +4042,16 @@
msgid "Unable to list mapsets"
msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
+#: ../lib/python/script/core.py:1410
+#, fuzzy, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr "Ìç åðéôñåðôü üíïìá. äåí ìðïñåß íá åßíáé '.' Þ 'NULL'\n"
+#: ../lib/python/script/core.py:1418
+msgid "Illegal filename <%s>. <%s> not allowed.\n"
+msgstr "Ìç åðéôñåðôü üíïìá áñ÷åßïõ. Ï ÷áñáêôÞñáò <%c> äåí åðéôñÝðåôáé.\n"
#: ../lib/python/script/raster3d.py:89
msgid "An error occurred while running r3.mapcalc"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_es.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grasslibs_es\n"
"PO-Revision-Date: 2011-04-15 14:03+0100\n"
"Last-Translator: Joana Palahí <joana at sigte.udg.edu>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -1088,7 +1088,7 @@
msgid "WARNING"
msgstr "ADVERTENCIA: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1096,120 +1096,120 @@
"Uso:\n"
msgid "Flags"
msgstr "Opciones"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Aceptar el valor predeterminado."
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Parámetros"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"Proyección no válida.\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "No se puede asignar una imagen temporal."
msgstr "El formato solicitado no ha sido compilado en esta versión."
msgstr ""
#, fuzzy
msgstr "Presione ENTER para continuar. -->"
msgid ""
@@ -1219,7 +1219,7 @@
msgstr ""
msgid ""
@@ -1228,34 +1228,34 @@
msgstr ""
msgstr "Disculpe pero <%s> no es una opción válida.\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1264,13 +1264,13 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
@@ -1278,7 +1278,7 @@
msgstr ""
"Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
msgid ""
@@ -1288,36 +1288,36 @@
msgstr ""
msgstr "%s: el área %d no existe."
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Construyendo grafica..."
#, fuzzy
msgstr "GISRC - variable no establecida."
#, python-format
msgid ""
@@ -1326,90 +1326,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "No hay ayuda disponible para el comando [%s].\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "No ha sido posible iniciar el controlador <%s>."
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "Ninguno."
#, fuzzy
msgstr "No se puede abrir el archivo temporal."
msgstr "No se soportan objetos espaciales del tipo %d OGR"
#, python-format
msgid ""
@@ -1419,11 +1419,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -4152,6 +4152,17 @@
msgstr "No es posible cerrar el mapa de entrada."
+msgstr "El nombre del archivo no está permitido. No puede ser '.' o 'NULL'\n"
+msgstr ""
+"El nombre del archivo no es admitido. El carácter <%c> no está permitido.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_fr.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasslibs_fr\n"
"PO-Revision-Date: 2013-01-26 13:45+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: French <grass-translations at lists.osgeo.org>\n"
@@ -80,11 +80,8 @@
#: ../lib/symbol/read.c:260
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nom du symbole incorrect : '%s' (devrait être group/nom ou groupe/"
-"nom at jeudedonnées)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nom du symbole incorrect : '%s' (devrait être group/nom ou groupe/nom at jeudedonnées)"
#: ../lib/symbol/read.c:284
#, c-format
@@ -131,9 +128,7 @@
msgstr "Chaîne d'horodatage illégale"
#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
msgstr ""
#: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:342 ../lib/ogsf/Gp3.c:206
@@ -165,8 +160,7 @@
msgstr ""
#: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
msgstr ""
#: ../lib/ogsf/gsd_label.c:58
@@ -194,8 +188,7 @@
#: ../lib/ogsf/GS2.c:1655
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"La carte raster <%s> est en dehors de la région courante. Chargement échoué."
+msgstr "La carte raster <%s> est en dehors de la région courante. Chargement échoué."
#: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
@@ -275,9 +268,7 @@
#: ../lib/ogsf/Gv3.c:406
#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+msgid "%d features without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/copy.c:142
@@ -303,9 +294,7 @@
#: ../lib/ogsf/Gp3.c:286
#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
+msgid "%d points without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/gsd_prim.c:146
@@ -315,12 +304,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot() : %c est une spécification d'axe non valide. Rotation ignorée. "
-"Merci d'avertir les développeurs GRASS de cette erreur"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot() : %c est une spécification d'axe non valide. Rotation ignorée. Merci d'avertir les développeurs GRASS de cette erreur"
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
@@ -378,9 +363,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:319
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Impossible de déduire le format de sortie de l'extension du fichier : "
-"utilisation de MPEG"
+msgstr "Impossible de déduire le format de sortie de l'extension du fichier : utilisation de MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:323
msgid "Unable to find suitable output format"
@@ -524,9 +507,7 @@
#: ../lib/ogsf/Gs3.c:596
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, "
-"maxcol=%d"
+msgstr "L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, maxcol=%d"
#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
#, c-format
@@ -571,11 +552,8 @@
#: ../lib/proj/convert.c:139
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR ne peut pas analyser la chaîne de paramètre PROJ.4 : %s (Le code erreur "
-"OGR était %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR ne peut pas analyser la chaîne de paramètre PROJ.4 : %s (Le code erreur OGR était %d)"
#: ../lib/proj/convert.c:146
#, c-format
@@ -584,9 +562,7 @@
#: ../lib/proj/convert.c:406
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Aucun nom de projection ! Projection de paramètres susceptibles d'être vide "
-"de sens."
+msgstr "Aucun nom de projection ! Projection de paramètres susceptibles d'être vide de sens."
#: ../lib/proj/convert.c:442
#, c-format
@@ -595,21 +571,13 @@
#: ../lib/proj/convert.c:458
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"La date <% s> est apparemment reconnue par GRASS mais aucun paramètre "
-"trouvé. Vous devez examiner."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "La date <% s> est apparemment reconnue par GRASS mais aucun paramètre trouvé. Vous devez examiner."
#: ../lib/proj/convert.c:462
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Numéro de transformation %d invalide ; la plage valide est de 1 à %d. "
-"Paramètres datum de la transformation laissés non spécifiés."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Numéro de transformation %d invalide ; la plage valide est de 1 à %d. Paramètres datum de la transformation laissés non spécifiés."
#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
#, c-format
@@ -672,13 +640,11 @@
#: ../lib/proj/ellipse.c:103
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-"Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
+msgstr "Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
#: ../lib/proj/ellipse.c:107
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
-"Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
+msgstr "Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
#: ../lib/proj/ellipse.c:120
msgid "No ellipsoid info given in file"
@@ -697,8 +663,7 @@
#: ../lib/proj/ellipse.c:274 ../lib/gis/get_ellipse.c:321
#, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-"Les lignes%s du fichier <%s> de la table de l'ellipsoïde sont invalides"
+msgstr "Les lignes%s du fichier <%s> de la table de l'ellipsoïde sont invalides"
#: ../lib/raster3d/range.c:73
#, fuzzy, c-format
@@ -879,10 +844,7 @@
msgstr ""
#: ../lib/raster3d/test/test_main.c:78
-msgid ""
-"The tile size in kilo bytes to be used for the large file put/get value "
-"test. Set the tile size to 2048 and the number of row*cols*depths > 130000 "
-"to reproduce the tile rle error."
+msgid "The tile size in kilo bytes to be used for the large file put/get value test. Set the tile size to 2048 and the number of row*cols*depths > 130000 to reproduce the tile rle error."
msgstr ""
#: ../lib/raster3d/test/test_main.c:82 ../lib/gmath/test/test_main.c:79
@@ -905,9 +867,7 @@
msgstr ""
#: ../lib/raster3d/test/test_main.c:98
-msgid ""
-"Use run length encoding RLE to encode/decode single tiles. Attention RLE is "
-"buggy in case of large tiles or files."
+msgid "Use run length encoding RLE to encode/decode single tiles. Attention RLE is buggy in case of large tiles or files."
msgstr ""
#: ../lib/raster3d/test/test_main.c:118
@@ -948,9 +908,7 @@
#: ../lib/raster3d/open.c:117
#, fuzzy
msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-"Rast3d_openCellOld : la projection ne correspond pas à la projection de la "
-"fenêtre"
+msgstr "Rast3d_openCellOld : la projection ne correspond pas à la projection de la fenêtre"
#: ../lib/raster3d/open.c:121
#, fuzzy
@@ -1020,9 +978,7 @@
#: ../lib/raster3d/color.c:331
#, fuzzy, c-format
msgid "mapset <%s> is not the current mapset"
-msgstr ""
-"Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de "
-"données (mapset) courant."
+msgstr "Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de données (mapset) courant."
#: ../lib/init/prompt.py:20
msgid "[Raster and Volume MASKs present]"
@@ -1043,9 +999,7 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans "
-"Windows"
+msgstr "Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans Windows"
#: ../lib/init/lock.c:60
#, fuzzy, c-format
@@ -1057,7 +1011,7 @@
msgid "WARNING"
msgstr "ATTENTION : "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1065,120 +1019,120 @@
"Utilisation :\n"
msgid "Flags"
msgstr "Drapeaux"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "pour accepter le choix par défaut"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Paramètres"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"projection invalide\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Allocation mémoire impossible\n"
msgstr "Le format demandé n'est pas compatible avec cette version"
msgstr ""
#, fuzzy
msgstr "pressez RETOUR pour continuer -->"
msgid ""
@@ -1188,7 +1142,7 @@
msgstr ""
msgid ""
@@ -1197,56 +1151,55 @@
msgstr ""
msgstr "Désolé, <%s> n'est pas une option valide\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
"Switching to text mode now.\n"
"\n"
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
"Please advise GRASS developers of this error."
msgstr "Veuillez avertir les développeurs GRASS de cette erreur.\n"
msgid ""
@@ -1256,142 +1209,138 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Construction du graphique ..."
#, fuzzy
msgstr "GISRC - variable sans valeur"
#, python-format
msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
"\n"
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Aucune aide disponible pour la commande [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Impossible d'ouvrir le fichier statistique <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "Aucun"
#, fuzzy
msgstr "Impossible d'ouvrir le fichier temporaire"
msgstr "Le type d'objet OGR %d n'est pas géré"
#, python-format
msgid ""
" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -1453,8 +1402,7 @@
#: ../lib/raster/put_title.c:67
#, c-format
msgid "can't write category information for [%s] in [%s]"
-msgstr ""
-"impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
+msgstr "impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
#: ../lib/raster/color_rand.c:33
#, c-format
@@ -1464,9 +1412,7 @@
#: ../lib/raster/init.c:61
#, fuzzy
msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-"\aERREUR : Le système n'est pas initialisé. Le développeur a oublié "
-"d'appeler G_gisinit()\n"
+msgstr "\aERREUR : Le système n'est pas initialisé. Le développeur a oublié d'appeler G_gisinit()\n"
#: ../lib/raster/color_read.c:103
#, fuzzy
@@ -1483,8 +1429,7 @@
#: ../lib/raster/color_read.c:112
#, fuzzy, c-format
msgid "Color support for <%s@%s> %s"
-msgstr ""
-"support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
+msgstr "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
#, fuzzy, c-format
@@ -1503,8 +1448,7 @@
#: ../lib/raster/close.c:474
msgid "unable to write f_format file for CELL maps"
-msgstr ""
-"pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+msgstr "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
#: ../lib/raster/auto_mask.c:69
msgid "Unable to open automatic MASK file"
@@ -1541,9 +1485,7 @@
#: ../lib/raster/gdal.c:496
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../lib/raster/gdal.c:502
@@ -1587,21 +1529,15 @@
msgstr "Impossible d'ouvrir la base de données <%s> avec le driver <%s>"
#: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window.Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
#: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window.Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
#: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window.Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
#: ../lib/raster/color_rules.c:125
@@ -1644,12 +1580,8 @@
#: ../lib/raster/set_window.c:131
#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window() : projection/zone diffèrent de ceux présents dans le fichier "
-"matriciel actuellement ouvert"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window() : projection/zone diffèrent de ceux présents dans le fichier matriciel actuellement ouvert"
#: ../lib/raster/set_window.c:158
#, c-format
@@ -1679,9 +1611,7 @@
#: ../lib/raster/reclass.c:171
#, fuzzy, c-format
msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-"Format de reclassification illégal dans l'en-tête de fichier pour [%s dans "
-"%s]"
+msgstr "Format de reclassification illégal dans l'en-tête de fichier pour [%s dans %s]"
#: ../lib/raster/reclass.c:273
msgid "Illegal reclass request"
@@ -1704,9 +1634,7 @@
#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"La lecture de la carte raster <%s@%s> demande la ligne %d en dehors de la "
-"région"
+msgstr "La lecture de la carte raster <%s@%s> demande la ligne %d en dehors de la région"
#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
@@ -1727,12 +1655,8 @@
#: ../lib/raster/open.c:190
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une "
-"reclassification de la carte raster <%s@%s> qui n'existe pas"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une reclassification de la carte raster <%s@%s> qui n'existe pas"
#: ../lib/raster/open.c:195
#, fuzzy, c-format
@@ -1747,25 +1671,19 @@
#: ../lib/raster/open.c:214
#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-"Carte raster <%s@%s> : format de champ invalide dans le fichier d'en-tête"
+msgstr "Carte raster <%s@%s> : format de champ invalide dans le fichier d'en-tête"
#: ../lib/raster/open.c:219
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
msgstr ""
-"[%s] dans le jeu de données (mapset) [%s] - est dans une projection "
-"différente par rapport à la région courante :\n"
+"[%s] dans le jeu de données (mapset) [%s] - est dans une projection différente par rapport à la région courante :\n"
" la couche [%s] dans: <%s>, devrait être <%s> "
#: ../lib/raster/open.c:226
#, fuzzy, c-format
msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente "
-"[%d] de celle de la région courante [%d]"
+msgstr "[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente [%d] de celle de la région courante [%d]"
#: ../lib/raster/open.c:231
#, fuzzy, c-format
@@ -1774,16 +1692,13 @@
#: ../lib/raster/open.c:256
#, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
#: ../lib/raster/open.c:264
#, fuzzy, c-format
msgid "Unable to open %s file for raster map <%s@%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'index de catégorie pour la couche "
-"vectorielle <%s@%s>"
+msgstr "Impossible d'ouvrir le fichier d'index de catégorie pour la couche vectorielle <%s@%s>"
#: ../lib/raster/open.c:301
#, fuzzy, c-format
@@ -1845,8 +1760,7 @@
msgstr "La carte raster <%s> n'est pas xdr : byte_order : %s"
#: ../lib/raster/open.c:929
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
#: ../lib/raster/null_val.c:64
@@ -1862,30 +1776,22 @@
#: ../lib/raster/put_row.c:120
#, fuzzy, c-format
msgid "Error writing uncompressed FP data for row %d of <%s>"
-msgstr ""
-"erreur en lisant la couche compressée [%s] dans le jeu de données [%s], "
-"ligne %d"
+msgstr "erreur en lisant la couche compressée [%s] dans le jeu de données [%s], ligne %d"
#: ../lib/raster/put_row.c:130
#, fuzzy, c-format
msgid "Error writing compressed FP data for row %d of <%s>"
-msgstr ""
-"ligne %d"
#: ../lib/raster/put_row.c:389 ../lib/raster/put_row.c:395
#, fuzzy, c-format
msgid "Error writing compressed data for row %d of <%s>"
-msgstr ""
-"ligne %d"
#: ../lib/raster/put_row.c:405
#, fuzzy, c-format
msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr ""
-"ligne %d"
#: ../lib/raster/put_row.c:464
#, fuzzy, c-format
@@ -1939,8 +1845,7 @@
#: ../lib/raster/quant_rw.c:157
#, fuzzy, c-format
msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr ""
-"Impossible d'écrire les règles de quantité : la couche %s est un entier"
+msgstr "Impossible d'écrire les règles de quantité : la couche %s est un entier"
#: ../lib/raster/quant_rw.c:166
#, fuzzy, c-format
@@ -1960,16 +1865,12 @@
#: ../lib/raster/cats.c:145
#, fuzzy, c-format
msgid "Category support for vector map <%s@%s> missing"
-msgstr ""
-"support de la catégorie pour le fichier vecteur [%s] dans le jeu de données "
-"(mapset) [%s] %s"
+msgstr "support de la catégorie pour le fichier vecteur [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/raster/cats.c:149
#, fuzzy, c-format
msgid "Category support for vector map <%s@%s> invalid"
-msgstr ""
-"(mapset) [%s] %s"
#: ../lib/raster/cats.c:968
#, fuzzy, c-format
@@ -2040,25 +1941,17 @@
#: ../lib/raster/quant_io.c:135
#, fuzzy, c-format
msgid "Quantization file for raster map <%s> is missing"
-msgstr ""
#: ../lib/raster/quant_io.c:145
#, fuzzy, c-format
msgid "Quantization file for raster map <%s> is empty"
-msgstr ""
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
-msgstr ""
-"impossible d'ouvrir [%s] dans [%s] puisqu'il s'agit d'une reclassification "
-"de [%s] dans [%s] qui n'existe pas"
+msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
+msgstr "impossible d'ouvrir [%s] dans [%s] puisqu'il s'agit d'une reclassification de [%s] dans [%s] qui n'existe pas"
#: ../lib/raster/get_cellhd.c:70
msgid "which is missing."
@@ -2168,19 +2061,13 @@
#: ../lib/imagery/sigsetfile.c:41
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> "
-"du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
#: ../lib/imagery/sigsetfile.c:57
#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"du groupe <%s>"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s>"
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -2200,21 +2087,17 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s "
-"de %s]"
+msgstr "Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/iclass.c:83
#, fuzzy, c-format
@@ -2239,8 +2122,7 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
+msgstr "Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
#: ../lib/imagery/target.c:38
#, c-format
@@ -2250,23 +2132,17 @@
#: ../lib/imagery/points.c:124
#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-"Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:132
#, c-format
msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-"Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:159
#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-"Impossible de créer le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Impossible de créer le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
msgid "Matrix dimensions out of range"
@@ -2358,8 +2234,7 @@
#: ../lib/gmath/la.c:746
msgid "Specified matrix column index is outside range"
-msgstr ""
-"L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
+msgstr "L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
#: ../lib/gmath/la.c:751 ../lib/gmath/la.c:792 ../lib/gmath/la.c:1105
#: ../lib/gmath/la.c:1157 ../lib/gmath/la.c:1232
@@ -2811,8 +2686,7 @@
#: ../lib/temporal/t.connect/main.c:38
#, fuzzy
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
msgstr "Connexion à la base de données indéfinie pour la couche %d"
#: ../lib/temporal/t.connect/main.c:42
@@ -3027,8 +2901,7 @@
#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
#: ../lib/cairodriver/Draw_bitmap.c:47
@@ -3038,9 +2911,7 @@
#: ../lib/driver/parse_ftcap.c:84
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s : Impossible de lire le fichier de définition de police, utilisation de "
-"celle par défaut"
+msgstr "%s : Impossible de lire le fichier de définition de police, utilisation de celle par défaut"
#: ../lib/driver/parse_ftcap.c:90
#, c-format
@@ -3165,9 +3036,7 @@
#: ../lib/python/temporal/mapcalc.py:139 ../lib/python/temporal/extract.py:89
-msgid ""
-"Space time %s dataset <%s> is already in database, use overwrite flag to "
-"overwrite"
+msgid "Space time %s dataset <%s> is already in database, use overwrite flag to overwrite"
msgstr "La couche vectorielle <%s> existe déjà et va être écrasé"
#: ../lib/python/temporal/mapcalc.py:144
@@ -3183,10 +3052,7 @@
msgstr ""
#: ../lib/python/temporal/mapcalc.py:190
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
msgstr ""
#: ../lib/python/temporal/mapcalc.py:208
@@ -3199,8 +3065,7 @@
#: ../lib/python/temporal/mapcalc.py:273 ../lib/python/temporal/extract.py:137
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/mapcalc.py:293
@@ -3268,8 +3133,7 @@
#: ../lib/python/temporal/stds_import.py:87
msgid "Unable to set the color rules for raster map <%s>."
-msgstr ""
-"Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
#: ../lib/python/temporal/stds_import.py:106
@@ -3370,9 +3234,7 @@
#: ../lib/python/temporal/stds_import.py:345
#: ../lib/python/temporal/space_time_datasets_tools.py:882
-msgid ""
-"Space time %s dataset <%s> is already in the database. Use the overwrite "
-"flag."
+msgid "Space time %s dataset <%s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/stds_import.py:365
@@ -3388,15 +3250,11 @@
msgstr "la couche matricielle demandée <%s> n'a pas été trouvée"
#: ../lib/python/temporal/core.py:82 ../lib/python/temporal/core.py:90
-msgid ""
-"Unable to initialize the temporal GIS DBMI interface. Use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:161
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:201
@@ -3443,9 +3301,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:114
#, python-format
-msgid ""
-"Space time %s dataset <%s> with relative time found, but no relative unit "
-"set for %s maps"
+msgid "Space time %s dataset <%s> with relative time found, but no relative unit set for %s maps"
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:182
@@ -3454,36 +3310,27 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:205
#, python-format
-msgid ""
-"Unable to register %s map <%s> with layer %s. The map has no valid time and "
-"the start time is not set."
+msgid "Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set."
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:209
#, python-format
-msgid ""
-"Unable to register %s map <%s>. The map has no valid time and the start time "
-"is not set."
+msgid "Unable to register %s map <%s>. The map has no valid time and the start time is not set."
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:224
-msgid ""
-"Map is already registered in temporal database. Unable to update %s map <%s> "
-"with layer %s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %s map <%s> with layer %s. Overwrite flag is not set."
#: ../lib/python/temporal/space_time_datasets_tools.py:229
-msgid ""
-"Map is already registered in temporal database. Unable to update %s map <"
-"%s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %s map <%s>. Overwrite flag is not set."
#: ../lib/python/temporal/space_time_datasets_tools.py:252
-msgid ""
-"Unable to update %s map <%s> with layer. The temporal types are different."
+msgid "Unable to update %s map <%s> with layer. The temporal types are different."
msgstr "Impossible de copier la couche vectorielle <%s> vers <%s>"
#: ../lib/python/temporal/space_time_datasets_tools.py:256
@@ -3524,9 +3371,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:383
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
#: ../lib/python/temporal/space_time_datasets_tools.py:388
@@ -3536,8 +3381,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:405
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
#: ../lib/python/temporal/space_time_datasets_tools.py:410
@@ -3578,9 +3422,7 @@
#: ../lib/python/temporal/aggregation.py:131
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
+msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/aggregation.py:134
@@ -3595,30 +3437,22 @@
#: ../lib/python/temporal/abstract_map_dataset.py:652
msgid "Start time must be of type datetime for %s map <%s> with layer: %s"
-msgstr ""
-"Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la "
-"couche %s %s dans le jeu de données (mapset) %s"
+msgstr "Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/python/temporal/abstract_map_dataset.py:657
msgid "Start time must be of type datetime for %s map <%s>"
-msgstr ""
-"Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s "
-"dans le jeu de données (mapset) %s"
+msgstr "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/python/temporal/abstract_map_dataset.py:663
msgid "End time must be of type datetime for %s map <%s> with layer: %s"
-msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:668
msgid "End time must be of type datetime for %s map <%s>"
-msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:675
@@ -3634,9 +3468,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:729
msgid "Unsupported relative time unit type for %s map <%s> with layer %s: %s"
-msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:735
@@ -3650,15 +3482,12 @@
#: ../lib/python/temporal/abstract_map_dataset.py:813
#, python-format
-msgid ""
-"Map <%s> with layer %s has incorrect time interval, start time is greater "
-"than end time"
+msgid "Map <%s> with layer %s has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:818
#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:823
@@ -3673,9 +3502,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:906
-msgid ""
-"Unregister %(type)s map <%(map)s> with layer %(layer)s from space time "
-"datasets"
+msgid "Unregister %(type)s map <%(map)s> with layer %(layer)s from space time datasets"
#: ../lib/python/temporal/abstract_map_dataset.py:911
@@ -3696,9 +3523,7 @@
#: ../lib/python/temporal/base.py:598
#, fuzzy
msgid "Wrong identifier, the mapset is missing"
-msgstr ""
#: ../lib/python/temporal/univar_statistics.py:67
#: ../lib/python/temporal/univar_statistics.py:158
@@ -3707,25 +3532,19 @@
msgstr "La carte vecteur <%s> n'a pas été trouvée"
#: ../lib/python/temporal/spatial_extent.py:123
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:360
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:500
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:607
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:678
@@ -3748,8 +3567,7 @@
#: ../lib/python/temporal/stds_export.py:96
msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-msgstr ""
#: ../lib/python/temporal/stds_export.py:119
@@ -3802,17 +3620,11 @@
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:679
-msgid ""
-"More than one map found in a granule. Temporal granularity seems to be "
-"invalid or the chosen granularity is not a greatest common divider of all "
-"intervals and gaps in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:711
-msgid ""
-"time instances in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all time instances in the dataset."
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:910
@@ -3856,9 +3668,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1095
#, python-format
-msgid ""
-"Temporal type of space time dataset <%s> and map <%s> with layer %s are "
-"different"
+msgid "Temporal type of space time dataset <%s> and map <%s> with layer %s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1099
@@ -3873,15 +3683,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1121
#, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> with layer %s "
-"are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> with layer %s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1125
#, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1133
@@ -3939,8 +3746,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1386
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:208
@@ -3951,9 +3757,7 @@
#: ../lib/python/temporal/space_time_datasets.py:212
msgid "Invalid datetime in timestamp for raster map <%s>"
-msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:224
@@ -3974,9 +3778,7 @@
#: ../lib/python/temporal/space_time_datasets.py:433
msgid "Invalid datetime in timestamp for raster3d map <%s>"
-msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:444
@@ -4001,9 +3803,7 @@
#: ../lib/python/temporal/space_time_datasets.py:658
msgid "Invalid datetime in timestamp for vector map <%s>"
-msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:671
@@ -4016,12 +3816,8 @@
#: ../lib/python/script/raster.py:47
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-"Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en mode "
-"'écriture'"
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
+msgstr "Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en mode 'écriture'"
#: ../lib/python/script/raster.py:105
msgid "An error occurred while running r.mapcalc"
@@ -4070,6 +3866,16 @@
msgstr "Impossible de fermer la carte en entrée"
+msgstr "Nom de fichier illégal. Ne peut pas être '.' ou 'NULL'\n"
+msgstr "Nom de fichier illégal. Caractère <%c> interdit.\n"
msgstr ""
@@ -4115,8 +3921,7 @@
#: ../lib/python/script/db.py:142
#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
#: ../lib/python/script/db.py:154
@@ -4615,9 +4420,7 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
msgstr ""
#: ../lib/vector/neta/utils.c:195
@@ -4659,18 +4462,12 @@
#: ../lib/vector/diglib/plus_node.c:214
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud : "
-"noeud %d, ligne %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud : noeud %d, ligne %d"
#: ../lib/vector/diglib/cindex_rw.c:156
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/file.c:159
@@ -4692,23 +4489,17 @@
#: ../lib/vector/diglib/spindex_rw.c:302
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:308
#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:317
#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:858
@@ -4845,20 +4636,17 @@
#: ../lib/vector/diglib/plus_area.c:412
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
+msgstr "Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
#: ../lib/vector/diglib/plus_area.c:437
#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
-"Tentative de suppression des information de la surface %d de l'île morte %d"
+msgstr "Tentative de suppression des information de la surface %d de l'île morte %d"
#: ../lib/vector/diglib/plus_area.c:787
#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
-"Tentative de suppression des informations de l'île % de la surface morte %d"
+msgstr "Tentative de suppression des informations de l'île % de la surface morte %d"
#: ../lib/vector/diglib/struct_alloc.c:491
#, fuzzy
@@ -4877,28 +4665,22 @@
#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:104
#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:134
@@ -4908,8 +4690,7 @@
#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/test.c:165
@@ -4919,23 +4700,17 @@
#: ../lib/vector/diglib/plus_struct.c:523
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/plus_struct.c:529
#, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/plus_struct.c:539
#, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
msgstr ""
#: ../lib/vector/Vlib/write_nat.c:49 ../lib/vector/Vlib/write_nat.c:85
@@ -4959,36 +4734,27 @@
#: ../lib/vector/Vlib/legal_vname.c:43
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
+msgstr "Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:50
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
+msgstr "Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
#: ../lib/vector/Vlib/legal_vname.c:58
#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas "
-"autorisé."
+msgstr "Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas autorisé."
#: ../lib/vector/Vlib/legal_vname.c:65
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être "
-"utilisés comme nom de carte vectorielle."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être utilisés comme nom de carte vectorielle."
#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"Le nom de sortie de la couche vectorielle <%s> n'est pas un nom de couche "
-"vectorielle valide"
+msgstr "Le nom de sortie de la couche vectorielle <%s> n'est pas un nom de couche vectorielle valide"
#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/legal_vname.c:148
#, c-format
@@ -5041,14 +4807,14 @@
msgstr ""
#: ../lib/vector/Vlib/snap.c:518
-#, fuzzy, c-format
+#, c-format
msgid "Snapped vertices: %d"
-msgstr "Sommets cassés"
+msgstr ""
#: ../lib/vector/Vlib/snap.c:519
#, fuzzy, c-format
msgid "New vertices: %d"
-msgstr "Nouveaux sommets"
+msgstr "Nombre de primitives : %d"
#: ../lib/vector/Vlib/snap.c:546
#, fuzzy
@@ -5214,11 +4980,8 @@
#: ../lib/vector/Vlib/build.c:1188
#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
-msgstr ""
-"Impossible d'ouvrir la couche vectorielle <%s> au niveau topologique %d"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgstr "Impossible d'ouvrir la couche vectorielle <%s> au niveau topologique %d"
#: ../lib/vector/Vlib/build.c:1211
#, c-format
@@ -5273,9 +5036,7 @@
#: ../lib/vector/Vlib/open_pg.c:192 ../lib/vector/Vlib/open_ogr.c:147
#, fuzzy, c-format
msgid "Unable to open feature index file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier des catégories d'index pour la couche "
-"vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier des catégories d'index pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open_pg.c:278
#, fuzzy, c-format
@@ -5654,12 +5415,8 @@
#: ../lib/vector/Vlib/geos.c:55
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): l'id d'objet %d n'est pas raisonnable (nombre maxi "
-"d'objets dans la carte vecteur <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): l'id d'objet %d n'est pas raisonnable (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:60
msgid "only native format supported"
@@ -5677,9 +5434,7 @@
#: ../lib/vector/Vlib/geos.c:104
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos() : impossible de lire l'île d'id %d de la surface d'id "
-"%d"
+msgstr "Vect_read_area_geos() : impossible de lire l'île d'id %d de la surface d'id %d"
#: ../lib/vector/Vlib/geos.c:203
#, c-format
@@ -5704,9 +5459,7 @@
#: ../lib/vector/Vlib/box.c:273
#, fuzzy, c-format
msgid "Unable to get bounding box for area %d"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/box.c:307
#, fuzzy
@@ -5727,12 +5480,8 @@
#: ../lib/vector/Vlib/read.c:168
#, fuzzy, c-format
-msgid ""
-"Requested feature id %d is not reasonable(max features in vector map <%s>: "
-"%d)"
-msgstr ""
-"Vect_read_line(): l'id d'objet %d n'est pas raisonnable (nombre maxi "
+msgid "Requested feature id %d is not reasonable(max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): l'id d'objet %d n'est pas raisonnable (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/build_ogr.c:69
msgid "Empty OGR layer, nothing to build"
@@ -5744,8 +5493,7 @@
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:82
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:90
@@ -5784,8 +5532,7 @@
#: ../lib/vector/Vlib/net.c:368
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Type de données de la colonne <%s> non pris en charge (doit être numeric)"
+msgstr "Type de données de la colonne <%s> non pris en charge (doit être numeric)"
#: ../lib/vector/Vlib/net.c:221
msgid "Registering arcs..."
@@ -5793,21 +5540,13 @@
#: ../lib/vector/Vlib/net.c:250
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, avant/"
-"toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, avant/toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:269
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, direction "
-"arrière) introuvable (direction de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, direction arrière) introuvable (direction de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:318
msgid "Cannot add network arc"
@@ -5820,9 +5559,7 @@
#: ../lib/vector/Vlib/net.c:411
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas "
-"été trouvé (coût fixé à 0)"
+msgstr "L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas été trouvé (coût fixé à 0)"
#: ../lib/vector/Vlib/net.c:440
#, fuzzy
@@ -5983,22 +5720,13 @@
#: ../lib/vector/Vlib/open_ogr.c:389
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"Le format d'index %d.%d n'est pas supporté par cette version. Essayez de "
-"reconstruire la topologie ou de mettre à jour GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Le format d'index %d.%d n'est pas supporté par cette version. Essayez de reconstruire la topologie ou de mettre à jour GRASS."
#: ../lib/vector/Vlib/open_ogr.c:394
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
-"Votre version de GRASS ne supporte pas complétement le format d'index %d.%d "
-"pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de "
-"GRASS."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Votre version de GRASS ne supporte pas complétement le format d'index %d.%d pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de GRASS."
#: ../lib/vector/Vlib/open_ogr.c:500
#, fuzzy, c-format
@@ -6008,20 +5736,16 @@
#: ../lib/vector/Vlib/open_nat.c:55
#, fuzzy, c-format
msgid "Unable to open coor file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open_nat.c:148
#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
msgstr ""
#: ../lib/vector/Vlib/open_nat.c:152
#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
msgstr ""
#: ../lib/vector/Vlib/write_sfa.c:107
@@ -6056,46 +5780,33 @@
msgstr "pas de fichier %s disponible dans le jeu de données actuel\n"
#: ../lib/vector/Vlib/open.c:239
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut "
-"pas être ouverte pour une mise à jour"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut pas être ouverte pour une mise à jour"
#: ../lib/vector/Vlib/open.c:276
#, fuzzy, c-format
msgid "Unable to read header file of vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/open.c:316
#, c-format
msgid "Unable to open topology file for vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/open.c:330
#, fuzzy, c-format
msgid "Unable to open spatial index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/cindex.c:510
#, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:379 ../lib/vector/Vlib/open.c:401
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Impossible d'ouvrir la carte vectorielle <%s> au niveau %d. Essayez de "
-"reconstruire la topologie avec v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Impossible d'ouvrir la carte vectorielle <%s> au niveau %d. Essayez de reconstruire la topologie avec v.build."
#: ../lib/vector/Vlib/open.c:410
#, fuzzy, c-format
@@ -6110,8 +5821,7 @@
#: ../lib/vector/Vlib/open.c:474
#, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/open.c:715
#, fuzzy, c-format
@@ -6121,8 +5831,7 @@
#: ../lib/vector/Vlib/open.c:770
#, fuzzy, c-format
msgid "Unable to open history file of vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/open.c:830
#, c-format
@@ -6136,9 +5845,7 @@
#: ../lib/vector/Vlib/open.c:971
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"La taille du fichier 'coord' est différente de la valeur sauvegardée dans le "
-"fichier de topologie"
+msgstr "La taille du fichier 'coord' est différente de la valeur sauvegardée dans le fichier de topologie"
#: ../lib/vector/Vlib/open.c:982 ../lib/vector/Vlib/open.c:1081
#, c-format
@@ -6148,9 +5855,7 @@
#: ../lib/vector/Vlib/open.c:1070
#, fuzzy
msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
#: ../lib/vector/Vlib/open.c:1134
#, fuzzy
@@ -6162,9 +5867,7 @@
msgstr ""
#: ../lib/vector/Vlib/dgraph.c:431
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
msgstr ""
#: ../lib/vector/Vlib/area.c:47
@@ -6194,15 +5897,12 @@
#: ../lib/vector/Vlib/cats.c:127
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-"Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
+msgstr "Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
#: ../lib/vector/Vlib/cats.c:423
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Impossible de convertir les catégories de caractères '%s' (de '%s') en "
-"intervalle de catégorie"
+msgstr "Impossible de convertir les catégories de caractères '%s' (de '%s') en intervalle de catégorie"
#: ../lib/vector/Vlib/cats.c:516 ../lib/vector/Vlib/cats.c:610
#, fuzzy
@@ -6253,8 +5953,7 @@
#: ../lib/vector/Vlib/intersect.c:448
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
+msgstr "Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
#: ../lib/vector/Vlib/intersect.c:1179 ../lib/vector/Vlib/intersect.c:1185
#: ../lib/vector/Vlib/intersect.c:1187 ../lib/vector/Vlib/intersect.c:1241
@@ -6333,13 +6032,11 @@
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:648
@@ -6375,9 +6072,7 @@
#: ../lib/vector/Vlib/array.c:292
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, "
-"où %s)"
+msgstr "Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, où %s)"
#: ../lib/vector/Vlib/write.c:186
msgid "Unable to write feature, vector map is not opened"
@@ -6389,35 +6084,23 @@
#: ../lib/vector/Vlib/write.c:270
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossible de supprimer la ligne %d, la carte vectorielle <%s> n'est pas "
-"ouverte au niveau topologique"
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossible de supprimer la ligne %d, la carte vectorielle <%s> n'est pas ouverte au niveau topologique"
#: ../lib/vector/Vlib/write.c:276
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossible de supprimer la ligne %d, la carte vecotirelle <%s> n'est pas "
-"ouverte en mode « écriture »"
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossible de supprimer la ligne %d, la carte vecotirelle <%s> n'est pas ouverte en mode « écriture »"
#: ../lib/vector/Vlib/write.c:315
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossible de restaurer la ligne %d, la carte vectorielle <%s> n'est pas "
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossible de restaurer la ligne %d, la carte vectorielle <%s> n'est pas ouverte au niveau topologique"
#: ../lib/vector/Vlib/write.c:321
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossible de restaurer la ligne %d, la carte vectorielle <%s> n'est pas ouverte en mode « écriture »"
#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:542
#, c-format
@@ -6457,9 +6140,7 @@
#: ../lib/vector/Vlib/close_pg.c:137 ../lib/vector/Vlib/close_ogr.c:109
#, fuzzy, c-format
msgid "Unable to save feature index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/cindex.c:29
msgid "Category index is not up to date"
@@ -6499,9 +6180,7 @@
#: ../lib/vector/Vlib/field.c:94
#, fuzzy
msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
-"Impossible d'ajouter un lien base de données, la couche n'est pas ouverte en "
-"ECRITURE."
+msgstr "Impossible d'ajouter un lien base de données, la couche n'est pas ouverte en ECRITURE."
#: ../lib/vector/Vlib/field.c:101
#, fuzzy
@@ -6523,9 +6202,7 @@
#: ../lib/vector/Vlib/field.c:183
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
msgstr ""
#: ../lib/vector/Vlib/field.c:259
@@ -6561,17 +6238,12 @@
msgstr "Impossible d'ouvrir le pilote OGR DBMI"
#: ../lib/vector/Vlib/field.c:755
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' "
-"ne sont disponibles dans la table OGR DB"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' ne sont disponibles dans la table OGR DB"
#: ../lib/vector/Vlib/field.c:822
#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
#: ../lib/vector/Vlib/field.c:842
@@ -6586,15 +6258,11 @@
#: ../lib/vector/Vlib/field.c:911
#, fuzzy, c-format
msgid "Unable to open vector database definition file '%s'"
-msgstr ""
-"impossible d'ouvrir le fichier '%s', définition de la base de données du "
-"vecteur "
+msgstr "impossible d'ouvrir le fichier '%s', définition de la base de données du vecteur "
#: ../lib/vector/Vlib/field.c:1006
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug : tentative de mise à jour d'une couche qui n'est pas dans le jeu de "
-"cartes courant"
+msgstr "Bug : tentative de mise à jour d'une couche qui n'est pas dans le jeu de cartes courant"
#: ../lib/vector/Vlib/remove_areas.c:89
msgid "Area is composed of dead boundary"
@@ -6739,8 +6407,7 @@
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1534
-msgid ""
-"Inconsistency in topology detected: unable to determine next left/right edge."
+msgid "Inconsistency in topology detected: unable to determine next left/right edge."
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1601
@@ -6816,14 +6483,12 @@
#: ../lib/vector/Vlib/header.c:87
#, fuzzy, c-format
msgid "Unable to create header file for vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/header.c:138
#, fuzzy, c-format
msgid "Unable to open header file of vector <%s>"
-msgstr ""
#: ../lib/vector/Vlib/header.c:146
#, c-format
@@ -6994,16 +6659,12 @@
#: ../lib/vector/Vlib/ascii.c:802
#, fuzzy, c-format
msgid "Unable to get boundary of area id %d"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/ascii.c:814
#, fuzzy, c-format
msgid "Unable to get boundary of isle id %d (area id %d)"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/select.c:116
#, c-format
@@ -7033,9 +6694,7 @@
#: ../lib/vector/vedit/cats.c:63
#, fuzzy, c-format
msgid "Unable to set category %d for (feature id %d)"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/vedit/select.c:231
msgid "Unknown query tool"
@@ -7067,18 +6726,12 @@
msgstr ""
#: ../lib/rst/interp_float/segmen2d.c:118
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Recherche de points pour l'interpolation trop longue -- merci de changer la "
-"région pour la zone où se trouvent vos points. Poursuite des calculs ..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Recherche de points pour l'interpolation trop longue -- merci de changer la région pour la zone où se trouvent vos points. Poursuite des calculs ..."
#: ../lib/rst/interp_float/interp2d.c:214
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
msgstr ""
#: ../lib/rst/interp_float/input2d.c:48
@@ -7151,8 +6804,7 @@
#: ../lib/rst/interp_float/vinput2d.c:249
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"il y a des points en-dehors de la région 2D/3D spécifiée - %d points ignorés"
+msgstr "il y a des points en-dehors de la région 2D/3D spécifiée - %d points ignorés"
#: ../lib/rst/interp_float/vinput2d.c:252
#, c-format
@@ -7161,12 +6813,8 @@
#: ../lib/rst/interp_float/vinput2d.c:256
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d points donnés pour l'interpolation (après squelettisation) est moins que "
-"le NPMIN=% donnéd"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d points donnés pour l'interpolation (après squelettisation) est moins que le NPMIN=% donnéd"
#: ../lib/rst/interp_float/vinput2d.c:261
msgid "Zero points in the given region"
@@ -7174,22 +6822,13 @@
#: ../lib/rst/interp_float/vinput2d.c:266
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Paramètres de segmentation invalides : npmin= %d, segmax= %d pour une bonne "
-"connexion des segments, npmin > segmax (voir le manuel)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Paramètres de segmentation invalides : npmin= %d, segmax= %d pour une bonne connexion des segments, npmin > segmax (voir le manuel)"
#: ../lib/rst/interp_float/vinput2d.c:272
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est "
-"nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d "
-"(voir manuel)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d (voir manuel)"
#: ../lib/rst/interp_float/vinput2d.c:276
#, c-format
@@ -7467,8 +7106,7 @@
#: ../lib/gis/legal_name.c:74 ../lib/gis/legal_name.c:78
#, c-format
msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
-"Le nom <%s> de la carte raster en sortie n'est pas un nom de carte valide"
+msgstr "Le nom <%s> de la carte raster en sortie n'est pas un nom de carte valide"
#: ../lib/gis/legal_name.c:115 ../lib/gis/legal_name.c:119
#, c-format
@@ -7491,12 +7129,8 @@
#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
#, fuzzy
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Version de librairie incompatible pour le module. Vous devez reconstruire "
-"GRASS ou gérer les versions multiples."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Version de librairie incompatible pour le module. Vous devez reconstruire GRASS ou gérer les versions multiples."
#: ../lib/gis/gisinit.c:61
#, c-format
@@ -7541,9 +7175,7 @@
#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>"
-"%g)"
+msgstr "Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>%g)"
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
msgid "Illegal latitude for North"
@@ -7552,9 +7184,7 @@
#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>"
-"%g)"
+msgstr "justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>%g)"
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
msgid "Illegal latitude for South"
@@ -7563,16 +7193,12 @@
#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière "
-"Ouest (%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Ouest (%g>%g)"
#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière Est "
-"(%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Est (%g>%g)"
#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
msgid "North must be north of South"
@@ -7650,15 +7276,11 @@
#: ../lib/gis/parser.c:491
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose supposé."
#: ../lib/gis/parser.c:505
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet supposé."
#: ../lib/gis/parser.c:536
#, fuzzy, c-format
@@ -7794,37 +7416,27 @@
#: ../lib/gis/timestamp.c:301
#, fuzzy, c-format
msgid "Invalid timestamp specified for %s map <%s@%s>"
-msgstr ""
-"L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est "
-"invalide dans le jeu de données (mapset) %s"
+msgstr "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est invalide dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:331
#, fuzzy, c-format
msgid "Unable to open timestamp file for %s map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:340
#, fuzzy, c-format
msgid "Invalid timestamp file for %s map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:479
#, fuzzy, c-format
msgid "Unable to open timestamp file for vector map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:488
#, fuzzy, c-format
msgid "Invalid timestamp file for vector map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:524
#, fuzzy, c-format
@@ -7834,9 +7446,7 @@
#: ../lib/gis/timestamp.c:533
#, fuzzy, c-format
msgid "Invalid timestamp specified for vector map <%s@%s>"
-msgstr ""
#: ../lib/gis/datum.c:160
#, c-format
@@ -8209,8 +7819,7 @@
msgstr "Nom de la base de données"
#: ../lib/gis/parser_standard_options.c:178
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
msgstr ""
#: ../lib/gis/parser_standard_options.c:187
@@ -8309,9 +7918,7 @@
msgstr "Type de données utilisées dans le fichier de sortie"
#: ../lib/gis/parser_standard_options.c:365
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
msgstr ""
#: ../lib/gis/parser_standard_options.c:375
@@ -8321,9 +7928,7 @@
#: ../lib/gis/parser_standard_options.c:385
#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
msgstr "Les dimensions des dalles utilisées dans le fichier de sortie"
#: ../lib/gis/parser_standard_options.c:395
@@ -8370,13 +7975,8 @@
#: ../lib/gis/parser_standard_options.c:459
#, fuzzy
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
-msgstr ""
-"Une seule carte vectorielle peut être connectée à plusieurs tables de base "
-"de données. Ce nombre détermine la table à utiliser."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
+msgstr "Une seule carte vectorielle peut être connectée à plusieurs tables de base de données. Ce nombre détermine la table à utiliser."
#: ../lib/gis/parser_standard_options.c:469
#, fuzzy
@@ -8385,13 +7985,8 @@
#: ../lib/gis/parser_standard_options.c:471
#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
#: ../lib/gis/parser_standard_options.c:480
msgid "Category value"
@@ -8566,9 +8161,7 @@
#: ../lib/gis/parser_standard_options.c:766
#, fuzzy
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
msgstr "WHERE conditions d'une clause SQL sans le mot-clef 'where'"
#: ../lib/gis/parser_standard_options.c:767
@@ -8612,17 +8205,12 @@
#: ../lib/gis/view.c:545
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-"La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre "
-"GRASS courante."
+msgstr "La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre GRASS courante."
#: ../lib/gis/view.c:549
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la "
-"fenêtre GRASS courante."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la fenêtre GRASS courante."
#: ../lib/gis/parser_html.c:53 ../lib/gis/parser_rest.c:60
msgid "NAME"
@@ -8666,8 +8254,7 @@
#: ../lib/gis/find_file.c:79
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-"'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
+msgstr "'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
#: ../lib/gis/find_file.c:87
#, c-format
@@ -8873,8 +8460,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:54
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-"Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
+msgstr "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
#: ../lib/db/dbmi_base/default_name.c:136
msgid "Programmer error"
@@ -8884,729 +8470,679 @@
msgid "send data: invalid C-type"
msgstr ""
-#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
-#~ msgstr ""
-#~ "Impossible d'écrire le fichier de verrouillage %s (disque plein ? "
-#~ "permissions ?)"
-#~ msgid ""
-#~ "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier de signatures <%s> pour le sous-groupe <"
-#~ "%s>du groupe <%s@%s>"
-#~ msgid "Unable to open topo file for write <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier topo en écriture <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Unable to get number of records for:\n"
-#~ "%s"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier des catégories d'index pour la couche "
-#~ "vectorielle <%s>"
+msgid ""
+"Unable to get number of records for:\n"
+"%s"
#, fuzzy
-#~ msgid "Unable to read node %d"
-#~ msgstr "Impossible de lire le fichier d'en-tête"
+msgid "Unable to read node %d"
+msgstr "Impossible de lire le fichier d'en-tête"
#, fuzzy
-#~ msgid "Unable to read nodes"
+msgid "Unable to read nodes"
#, fuzzy
-#~ msgid "Unable to read lines"
+msgid "Unable to read lines"
#, fuzzy
-#~ msgid "Unable to attach centroids"
-#~ msgstr "Impossible de calculer le centroïde de l'entité surfacique %d"
+msgid "Unable to attach centroids"
+msgstr "Impossible de calculer le centroïde de l'entité surfacique %d"
#, fuzzy
-#~ msgid "Unexpected feature type (%s) - should be (%d)"
-#~ msgstr "Type(s) d'entité(s)"
+msgid "Unexpected feature type (%s) - should be (%d)"
+msgstr "Type(s) d'entité(s)"
#, fuzzy
-#~ msgid "Unable to read centroid %d: %s"
-#~ msgstr "Impossible d'écrire la ligne matricielle %i"
+msgid "Unable to read centroid %d: %s"
+msgstr "Impossible d'écrire la ligne matricielle %i"
#, fuzzy
-#~ msgid "Unable to export node %d. Exiting."
-#~ msgstr "Allocation mémoire impossible\n"
+msgid "Unable to export node %d. Exiting."
+msgstr "Allocation mémoire impossible\n"
#, fuzzy
-#~ msgid "Unable to look up account id"
-#~ msgstr "Impossible d'ouvrir le codec"
+msgid "Unable to look up account id"
+msgstr "Impossible d'ouvrir le codec"
#, fuzzy
-#~ msgid "Unable to allocate memory for account name"
+msgid "Unable to allocate memory for account name"
#, fuzzy
-#~ msgid "Unable to allocate memory for domain name"
+msgid "Unable to allocate memory for domain name"
#, fuzzy
-#~ msgid "Unable to remove space time dataset register table <%s>"
-#~ msgstr "Impossible de copier la table <%s>"
+msgid "Unable to remove space time dataset register table <%s>"
+msgstr "Impossible de copier la table <%s>"
#, fuzzy
-#~ msgid "Unable to drop table <%s>"
+msgid "Unable to drop table <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Unable to create the space time %s dataset register table for map <%s> "
-#~ "with layer %s"
-#~ msgstr "Impossible de créer le fichier d'en-tête pour [%s]"
+msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
+msgstr "Impossible de créer le fichier d'en-tête pour [%s]"
#, fuzzy
-#~ msgid "Unable to find map <%s> with layer %s in temporal database"
-#~ msgstr "Impossible de copier la couche vectorielle <%s> vers <%s>"
+msgid "Unable to find map <%s> with layer %s in temporal database"
+msgstr "Impossible de copier la couche vectorielle <%s> vers <%s>"
#, fuzzy
-#~ msgid "Could not find area box"
-#~ msgstr "Impossible d'obtenir la ligne matricielle"
+msgid "Could not find area box"
+msgstr "Impossible d'obtenir la ligne matricielle"
#, fuzzy
-#~ msgid "Unable to read read line %d"
+msgid "Unable to read read line %d"
#, fuzzy
-#~ msgid "Unable to delete feature id %d from vector map <%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <"
-#~ "%s>"
+msgid "Unable to delete feature id %d from vector map <%s>"
#, fuzzy
-#~ msgid "Unable to open null device"
-#~ msgstr "Impossible d'ouvrir %s"
+msgid "Unable to open null device"
+msgstr "Impossible d'ouvrir %s"
#, fuzzy
-#~ msgid "The support for OGR vector maps wasn't compiled in"
-#~ msgstr ""
-#~ "support de la catégorie pour le fichier vecteur [%s] dans le jeu de "
-#~ "données (mapset) [%s] %s"
+msgid "The support for OGR vector maps wasn't compiled in"
+msgstr "support de la catégorie pour le fichier vecteur [%s] dans le jeu de données (mapset) [%s] %s"
#, fuzzy
-#~ msgid "End time must be later than start time"
-#~ msgstr "L'Est doit être plus grand que l'Ouest"
+msgid "End time must be later than start time"
+msgstr "L'Est doit être plus grand que l'Ouest"
#, fuzzy
-#~ msgid "None"
-#~ msgstr "Aucun"
+msgid "None"
+msgstr "Aucun"
#, fuzzy
-#~ msgid "Unknown"
-#~ msgstr "inconnu"
+msgid "Unknown"
+msgstr "inconnu"
#, fuzzy
-#~ msgid "Uknown column <%s>"
-#~ msgstr "Impossible de lire le type de colonne de la colonne de lissage"
+msgid "Uknown column <%s>"
+msgstr "Impossible de lire le type de colonne de la colonne de lissage"
#, fuzzy
-#~ msgid " valid options: %s\n"
-#~ msgstr " options : %s\n"
+msgid " valid options: %s\n"
+msgstr " options : %s\n"
#, fuzzy
-#~ msgid "Not enough room in history file to record command line"
-#~ msgstr ""
-#~ "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la "
-#~ "ligne de commande"
+msgid "Not enough room in history file to record command line"
+msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande"
#, fuzzy
-#~ msgid "Not enough room in history file for command line (truncated)"
-#~ msgstr ""
-#~ "ligne de commande (tronquée)"
+msgid "Not enough room in history file for command line (truncated)"
+msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande (tronquée)"
#, fuzzy
-#~ msgid "Raster map <%s> - unable to write row %d"
-#~ msgstr "couche [%s] - impossible d'écrire la ligne %d"
+msgid "Raster map <%s> - unable to write row %d"
+msgstr "couche [%s] - impossible d'écrire la ligne %d"
#, fuzzy
-#~ msgid "Error writing floating point format file for map <%s>"
-#~ msgstr ""
-#~ "Erreur lors de l'écriture en virgule flottante dans le fichier au format "
-#~ "de la couche %s"
+msgid "Error writing floating point format file for map <%s>"
+msgstr "Erreur lors de l'écriture en virgule flottante dans le fichier au format de la couche %s"
#, fuzzy
-#~ msgid "Unable to write feature, OGR layer not defined"
-#~ msgstr "Impossible d'écrire la ligne, la couche n'est pas ouverte"
+msgid "Unable to write feature, OGR layer not defined"
+msgstr "Impossible d'écrire la ligne, la couche n'est pas ouverte"
#, fuzzy
-#~ msgid "Unable to create a new process!"
-#~ msgstr "Impossible de créer un nouveau processus"
+msgid "Unable to create a new process!"
+msgstr "Impossible de créer un nouveau processus"
#, fuzzy
-#~ msgid ""
-#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
-#~ msgstr ""
-#~ "région pour le jeu de données (mapset) courant %s\n"
-#~ "lancer \"g.region\""
+msgid "Region for current mapset %s. Run \"g.region\" to fix the current region."
+msgstr ""
+"région pour le jeu de données (mapset) courant %s\n"
+"lancer \"g.region\""
#, fuzzy
-#~ msgid "Default region %s"
-#~ msgstr "région par défaut %s"
+msgid "Default region %s"
+msgstr "région par défaut %s"
#, fuzzy
-#~ msgid "Unable to set region"
+msgid "Unable to set region"
#, fuzzy
-#~ msgid "Failed writing raster map"
-#~ msgstr "Problème de lecture du fichier de cellules raster"
+msgid "Failed writing raster map"
+msgstr "Problème de lecture du fichier de cellules raster"
#, fuzzy
-#~ msgid "Unable to query drawable"
+msgid "Unable to query drawable"
#, fuzzy
-#~ msgid "Failed to initialize Xlib surface"
-#~ msgstr "Impossible d'initialiser pj cause : %s"
+msgid "Failed to initialize Xlib surface"
+msgstr "Impossible d'initialiser pj cause : %s"
#, fuzzy
-#~ msgid "test, gmath"
-#~ msgstr "test, gpde"
+msgid "test, gmath"
+msgstr "test, gpde"
-#~ msgid ""
-#~ "taking too long to find points for interpolation--please change the "
-#~ "region to area where your points are. Continuing calculations..."
-#~ msgstr ""
-#~ "la recherche de points pour l'interpolation prend trop de temps -- "
-#~ "veuillez changer la régionpour la zone où se trouvent vos points. Les "
-#~ "calculs se poursuivent..."
+msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
+msgstr "la recherche de points pour l'interpolation prend trop de temps -- veuillez changer la régionpour la zone où se trouvent vos points. Les calculs se poursuivent..."
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "Lignes de lecture de la carte vectorielle..."
+msgid "Reading lines from vector map ... "
+msgstr "Lignes de lecture de la carte vectorielle..."
#, fuzzy
-#~ msgid "Reading nodes from vector map ... "
+msgid "Reading nodes from vector map ... "
-#~ msgid "strip exists with insufficient data"
-#~ msgstr "la bande existe avec des données insuffisantes"
+msgid "strip exists with insufficient data"
+msgstr "la bande existe avec des données insuffisantes"
-#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
-#~ msgstr ""
-#~ "il y a des points en-dehors de la région 2D/3D spécifiée -- %d points "
-#~ "ignorés"
+msgid "there are points outside specified 2D/3D region--ignored %d points"
+msgstr "il y a des points en-dehors de la région 2D/3D spécifiée -- %d points ignorés"
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "%d points ignorés -- trop dense"
+msgid "ignoring %d points -- too dense"
+msgstr "%d points ignorés -- trop dense"
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "certains points sont en dehors de la région -- ignorés..."
+msgid "some points outside of region -- will ignore..."
+msgstr "certains points sont en dehors de la région -- ignorés..."
#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#~ msgstr "Impossible de supprimer le fichier <%s>"
+msgid "Unable to delete file '%s'. Reason: %s"
+msgstr "Impossible de supprimer le fichier <%s>"
#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#~ msgstr "Impossible de renommer le répertoire '%s' en '%s'"
+msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
+msgstr "Impossible de renommer le répertoire '%s' en '%s'"
#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
+msgid "Unable to delete prior null-cells file"
#, fuzzy
-#~ msgid "Unable to close the null-cells file"
+msgid "Unable to close the null-cells file"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to null-cells file [%s]"
-#~ msgstr ""
-#~ "closecell : impossible de se déplacer %s\n"
-#~ "jusqu'au fichier nul %s"
+msgid "closecell: can't move [%s] to null-cells file [%s]"
+msgstr ""
+"closecell : impossible de se déplacer %s\n"
+"jusqu'au fichier nul %s"
#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#~ msgstr "impossible de trouver un fichier temporaire null %s"
+msgid "Unable to delete the temporary null-cells file"
+msgstr "impossible de trouver un fichier temporaire null %s"
#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
+msgid "Unable to delete the empty temporary null-cells file"
#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
+msgid "Unable to delete the prior null-cells file"
#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
+msgid "Unable to close the 'cell' file"
#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
+msgid "Unable to delete prior 'fcell' file"
#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
-#~ msgstr "Impossible de supprimer la table <%s>"
+msgid "Unable to delete the prior %s file"
+msgstr "Impossible de supprimer la table <%s>"
#, fuzzy
-#~ msgid "Unable to close file"
-#~ msgstr "Impossible d'ouvrir le fichier %s"
+msgid "Unable to close file"
+msgstr "Impossible d'ouvrir le fichier %s"
#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
+msgid "Unable to delete the prior 'cell' file"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to cell file [%s]"
-#~ msgstr ""
-#~ "Ã la cellule du fichier %s"
+msgid "closecell: can't move [%s] to cell file [%s]"
+msgstr ""
+"Ã la cellule du fichier %s"
#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
+msgid "Unable to delete the temporary 'cell' file"
#, fuzzy
-#~ msgid "Unable to write quant file!"
-#~ msgstr "pas en mesure d'écrire le fichier!"
+msgid "Unable to write quant file!"
+msgstr "pas en mesure d'écrire le fichier!"
#, fuzzy
-#~ msgid "Unable to delete the %s file"
+msgid "Unable to delete the %s file"
#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#~ msgstr ""
-#~ "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+msgid "Unable to write f_format file for CELL maps"
+msgstr "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "La couche g3d demandée <%s> n'a pas été trouvée"
+msgid "Requested g3d map <%s> not found"
+msgstr "La couche g3d demandée <%s> n'a pas été trouvée"
-#~ msgid "Unknown Location"
-#~ msgstr "Secteur (Location) inconnu"
+msgid "Unknown Location"
+msgstr "Secteur (Location) inconnu"
#, fuzzy
-#~ msgid "Unable to feature %d from vector map <%s>"
-#~ msgstr "Impossible de créer la couche vectorielle <%s>"
+msgid "Unable to feature %d from vector map <%s>"
+msgstr "Impossible de créer la couche vectorielle <%s>"
-#~ msgid "Too many arguments"
-#~ msgstr "Trop d'arguments"
+msgid "Too many arguments"
+msgstr "Trop d'arguments"
-#~ msgid "Vector is not 3D"
-#~ msgstr "Le vecteur n'est pas 3D"
+msgid "Vector is not 3D"
+msgstr "Le vecteur n'est pas 3D"
-#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "Impossible de trouver la colonne z <%s> (veuillez vérifier le nom, par "
-#~ "exemple avec v.info)"
+msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
+msgstr "Impossible de trouver la colonne z <%s> (veuillez vérifier le nom, par exemple avec v.info)"
-#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Le type de colonne de la colonne z n'est pas supporté (doit être un "
-#~ "entier ou un double)"
+msgid "Column type of z column is not supported (must be integer or double)"
+msgstr "Le type de colonne de la colonne z n'est pas supporté (doit être un entier ou un double)"
-#~ msgid "Cannot read column type of smooth column"
+msgid "Cannot read column type of smooth column"
-#~ msgid "Column type of smooth column (datetime) is not supported"
-#~ msgstr ""
-#~ "Le type de colonne de la colonne de lissage (date temps) n'est pas géré"
+msgid "Column type of smooth column (datetime) is not supported"
+msgstr "Le type de colonne de la colonne de lissage (date temps) n'est pas géré"
-#~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Le type de la colonne s n'est pas supporté (doit être entier ou double)"
+msgid "Column type of s column is not supported (must be integer or double)"
+msgstr "Le type de la colonne s n'est pas supporté (doit être entier ou double)"
-#~ msgid "Registering points"
-#~ msgstr "Enregistrement des points"
+msgid "Registering points"
+msgstr "Enregistrement des points"
-#~ msgid "Registered points"
-#~ msgstr "Points enregistrés"
+msgid "Registered points"
+msgstr "Points enregistrés"
#, fuzzy
-#~ msgid "Registered points (unique coordinates)"
+msgid "Registered points (unique coordinates)"
#, fuzzy
-#~ msgid "Duplicates"
-#~ msgstr "multiples occurrences du champ Est"
+msgid "Duplicates"
+msgstr "multiples occurrences du champ Est"
-#~ msgid "Type"
-#~ msgstr "Type"
+msgid "Type"
+msgstr "Type"
-#~ msgid "G_malloc: out of memory"
-#~ msgstr "G_malloc : dépassement de mémoire"
+msgid "G_malloc: out of memory"
+msgstr "G_malloc : dépassement de mémoire"
-#~ msgid "G_calloc: out of memory"
-#~ msgstr "G_calloc : allocation mémoire impossible"
+msgid "G_calloc: out of memory"
+msgstr "G_calloc : allocation mémoire impossible"
-#~ msgid "G_realloc: out of memory"
-#~ msgstr "G_realloc : dépassement de mémoire"
+msgid "G_realloc: out of memory"
+msgstr "G_realloc : dépassement de mémoire"
-#~ msgid "Cannot get layer info"
-#~ msgstr "Impossible de récupérer les infos de la couche"
+msgid "Cannot get layer info"
+msgstr "Impossible de récupérer les infos de la couche"
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Impossible de décrire la table <%s>"
+msgid "Cannot describe table <%s>"
+msgstr "Impossible de décrire la table <%s>"
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "Impossible de lire la topologie pour la ligne [%d]"
+msgid "Cannot read topo for line [%d]"
+msgstr "Impossible de lire la topologie pour la ligne [%d]"
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr ""
-#~ "Le nom de sortie '%s' n'est pas un nom de couche matricielle valide."
+msgid "Output name '%s' is not valid rast name."
+msgstr "Le nom de sortie '%s' n'est pas un nom de couche matricielle valide."
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "La couche de sortie '%s' est utilisée en entrée"
+msgid "Output map '%s' is used as input"
+msgstr "La couche de sortie '%s' est utilisée en entrée"
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
+msgid "unable to open raster map [%s in %s]"
+msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Impossible de lire l'en-tête de fichier pour [%s dans %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "Impossible de lire l'en-tête de fichier pour [%s dans %s]\n"
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Impossible d'ouvrir le fichier d'en-tête pour [%s dans %s]"
+msgid "Can't open header file for [%s in %s]"
+msgstr "Impossible d'ouvrir le fichier d'en-tête pour [%s dans %s]"
-#~ msgid "Cannot get field info"
-#~ msgstr "Impossible d'obtenir les informations du champ"
+msgid "Cannot get field info"
+msgstr "Impossible d'obtenir les informations du champ"
#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
+msgid "Cannot open database"
+msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgid ""
-#~ "\r%d areas built \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d surfaces construites \n"
-#~ "%d îles construites\n"
+msgid ""
+"\r%d areas built \n"
+"%d isles built\n"
+msgstr ""
+"\r%d surfaces construites \n"
+"%d îles construites\n"
-#~ msgid "Cannot get column info"
-#~ msgstr "Impossible d'obtenir les informations de la colonne"
+msgid "Cannot get column info"
+msgstr "Impossible d'obtenir les informations de la colonne"
-#~ msgid "OGR feature type [%d] not supported"
-#~ msgstr "Le type d'objet OGR [%d] n'est pas supporté"
+msgid "OGR feature type [%d] not supported"
+msgstr "Le type d'objet OGR [%d] n'est pas supporté"
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_rewrite_line() n'est pas supportée pour ce format/niveau"
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "Vect_rewrite_line() n'est pas supportée pour ce format/niveau"
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#~ msgstr "Vect_delete_line() n'est pas supportée pour ce format/niveau"
+msgid "Vect_delete_line() for this format/level not supported"
+msgstr "Vect_delete_line() n'est pas supportée pour ce format/niveau"
-#~ msgid "Cannot delete line"
-#~ msgstr "Impossible de supprimer la ligne"
+msgid "Cannot delete line"
+msgstr "Impossible de supprimer la ligne"
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
+msgid "Output name '%s' is not valid vector name."
+msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Impossible de copier le vecteur '%s' vers '%s'"
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "Impossible de copier le vecteur '%s' vers '%s'"
#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "Impossible de supprimer le vecteur %s"
+msgid "Cannot open existing vector map <%s>"
+msgstr "Impossible de supprimer le vecteur %s"
#, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Impossible d'ouvrir le nouveau vecteur %s"
+msgid "Cannot open new vector %s"
+msgstr "Impossible d'ouvrir le nouveau vecteur %s"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
+msgid "Cannot open history file for vector '%s'"
+msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
#, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "Impossible d'ouvrir l'ancien vecteur %s"
+msgid "Can't open directory %s"
+msgstr "Impossible d'ouvrir l'ancien vecteur %s"
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "Aucun moniteur graphique correspondant à <%s>.\n"
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "Aucun moniteur graphique correspondant à <%s>.\n"
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr ""
-#~ "Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique "
-#~ "valide.\n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr "Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique valide.\n"
-#~ msgid "Can't stat %s\n"
-#~ msgstr "Impossible d'obtenir des informations sur %s\n"
+msgid "Can't stat %s\n"
+msgstr "Impossible d'obtenir des informations sur %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Erreur - Le moniteur <%s> est en cours d'utilisation.\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Erreur - Le moniteur <%s> est en cours d'utilisation.\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Erreur - Le moniteur <%s> est utilisé par %s.\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "Erreur - Le moniteur <%s> est utilisé par %s.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Erreur - Impossible de bloquer le moniteur <%s>.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "Erreur - Impossible de bloquer le moniteur <%s>.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Erreur - Impossible de créer un tube vers la sortie graphique.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Erreur - Impossible de créer un tube vers la sortie graphique.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Erreur - Le moniteur graphique <%s> n'est pas lancé!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Erreur - Le moniteur graphique <%s> n'est pas lancé!\n"
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Veuillez démarrer le moniteur graphique <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
+msgstr "Veuillez démarrer le moniteur graphique <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Aucune connexion...\n"
+msgid "Not connected...\n"
+msgstr "Aucune connexion...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr ""
-#~ "Impossible de se connecter au moniteur. Nous allons essayer encore une "
-#~ "fois.\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "Impossible de se connecter au moniteur. Nous allons essayer encore une fois.\n"
-#~ msgid "G_dump: memory allocated to G__"
-#~ msgstr "G_dump: mémoire allouée à G__"
+msgid "G_dump: memory allocated to G__"
+msgstr "G_dump: mémoire allouée à G__"
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr ""
-#~ "Taille de cellule dans les couches en nombres en virgule flottante = %d"
+msgid "Size of cell in fp maps = %d"
+msgstr "Taille de cellule dans les couches en nombres en virgule flottante = %d"
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr ""
-#~ "type d'écriture pour les couches en nombres en virgule flottante = %d"
+msgid "type for writing floating maps = %d"
+msgstr "type d'écriture pour les couches en nombres en virgule flottante = %d"
-#~ msgid "current window = %p"
-#~ msgstr "fenêtre courante = %p"
+msgid "current window = %p"
+msgstr "fenêtre courante = %p"
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Drapeau: fenêtre définie? %d"
+msgid "Flag: window set? %d"
+msgstr "Drapeau: fenêtre définie? %d"
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Descripteur de fichier pour le masque automatique %d"
+msgid "File descriptor for automatic mask %d"
+msgstr "Descripteur de fichier pour le masque automatique %d"
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "Drapeau signifiant un masquage automatique %d"
+msgid "Flag denoting automatic masking %d"
+msgstr "Drapeau signifiant un masquage automatique %d"
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "Tampon du masque de CELLULE %p"
+msgid "CELL mask buffer %p"
+msgstr "Tampon du masque de CELLULE %p"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "tampon pour lire les lignes nulles %p"
+msgid "buffer for reading null rows %p"
+msgstr "tampon pour lire les lignes nulles %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Tampon pour les données compressées pre/post %p"
+msgid "Pre/post compressed data buffer %p"
+msgstr "Tampon pour les données compressées pre/post %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "sizeof compressed_buf %d"
+msgid "sizeof compressed_buf %d"
+msgstr "sizeof compressed_buf %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "tampon des données de travail %p"
+msgid "work data buffer %p"
+msgstr "tampon des données de travail %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "sizeof work_buf %d"
+msgid "sizeof work_buf %d"
+msgstr "sizeof work_buf %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "sizeof null_buf %d"
+msgid "sizeof null_buf %d"
+msgstr "sizeof null_buf %d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "sizeof mask_buf %d"
+msgid "sizeof mask_buf %d"
+msgstr "sizeof mask_buf %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "Demande de construction d'un histogramme %d"
+msgid "Histogram request %d"
+msgstr "Demande de construction d'un histogramme %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: fichier #%d"
+msgid "G_dump: file #%d"
+msgstr "G_dump: fichier #%d"
-#~ msgid "open mode = %d"
-#~ msgstr "mode d'ouverture = %d"
+msgid "open mode = %d"
+msgstr "mode d'ouverture = %d"
-#~ msgid "Cell header %p"
-#~ msgstr "En-tête de cellule %p"
+msgid "Cell header %p"
+msgstr "En-tête de cellule %p"
-#~ msgid "Table reclass %p"
-#~ msgstr "Tableau de reclassification %p"
+msgid "Table reclass %p"
+msgstr "Tableau de reclassification %p"
-#~ msgid "Cell stats %p"
-#~ msgstr "Statistiques de cellule %p"
+msgid "Cell stats %p"
+msgstr "Statistiques de cellule %p"
-#~ msgid "Range structure %p"
-#~ msgstr "Structure de l'intervalle %p"
+msgid "Range structure %p"
+msgstr "Structure de l'intervalle %p"
-#~ msgid "float Range structure %p"
-#~ msgstr "structure de l'intervalle en nombres en virgule flottante %p"
+msgid "float Range structure %p"
+msgstr "structure de l'intervalle en nombres en virgule flottante %p"
-#~ msgid "want histogram? %d"
-#~ msgstr "un histogramme?..%d"
+msgid "want histogram? %d"
+msgstr "un histogramme?..%d"
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "Drapeau de reclassification automatique %d"
+msgid "Automatic reclass flag %d"
+msgstr "Drapeau de reclassification automatique %d"
-#~ msgid "File row addresses %p"
-#~ msgstr "Adresses de la ligne du fichier %p"
+msgid "File row addresses %p"
+msgstr "Adresses de la ligne du fichier %p"
-#~ msgid "Data to window col mapping %p"
-#~ msgstr "Donnée du tracé de la colonne dans la fenêtre %p"
+msgid "Data to window col mapping %p"
+msgstr "Donnée du tracé de la colonne dans la fenêtre %p"
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "Données des constantes de lignes dans la fenêtre %f,%f"
+msgid "Data to window row constants %f,%f"
+msgstr "Données des constantes de lignes dans la fenêtre %f,%f"
-#~ msgid "Current data row in memory %d"
-#~ msgstr "Lignes de données actuellement en mémoire %d"
+msgid "Current data row in memory %d"
+msgstr "Lignes de données actuellement en mémoire %d"
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "Nombre d'octets par cellule pour la ligne courante %d"
+msgid "nbytes per cell for current row %d"
+msgstr "Nombre d'octets par cellule pour la ligne courante %d"
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Tampon de données décompressées %s"
+msgid "Decompressed data buffer %s"
+msgstr "Tampon de données décompressées %s"
-#~ msgid "bytes per cell %d"
-#~ msgstr "octets par cellule %d"
+msgid "bytes per cell %d"
+msgstr "octets par cellule %d"
-#~ msgid "type: int, float or double map %d"
-#~ msgstr ""
-#~ "type: entier(int), nombre en virgule flottante (float) ou double couche %d"
+msgid "type: int, float or double map %d"
+msgstr "type: entier(int), nombre en virgule flottante (float) ou double couche %d"
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Nom temporaire pour les NOUVEAUX fichiers %s"
+msgid "Temporary name for NEW files %s"
+msgstr "Nom temporaire pour les NOUVEAUX fichiers %s"
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Nom temporaire pour les NOUVEAUX fichier %s NULS"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "Nom temporaire pour les NOUVEAUX fichier %s NULS"
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Mapset du fichier ouvert %s"
+msgid "Mapset of open file %s"
+msgstr "Mapset du fichier ouvert %s"
-#~ msgid "io error warning given %d"
-#~ msgstr "erreur d'entrée/sortie renvoyée %d"
+msgid "io error warning given %d"
+msgstr "erreur d'entrée/sortie renvoyée %d"
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "flux xdr pour lire fp %p"
+msgid "xdr stream for reading fp %p"
+msgstr "flux xdr pour lire fp %p"
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS array[%d] = %p"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "NULL_ROWS array[%d] = %p"
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "tampon de données pour lire les lignes nulles %p"
+msgid "data buffer for reading null rows %p"
+msgstr "tampon de données pour lire les lignes nulles %p"
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "Nombre minimum d'une ligne d'une ligne nulle en mémoire %d"
+msgid "Minimum row null row number in memory %d"
+msgstr "Nombre minimum d'une ligne d'une ligne nulle en mémoire %d"
-#~ msgid "Quant ptr = %p"
-#~ msgstr "Quant ptr = %p"
+msgid "Quant ptr = %p"
+msgstr "Quant ptr = %p"
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump: fin"
+msgid "G_dump: end"
+msgstr "G_dump: fin"
#, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
#, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier %s dans %s"
+msgid "Not able to open cellfile for [%s]"
+msgstr "Impossible d'ouvrir le fichier %s dans %s"
-#~ msgid "Too many open raster maps"
-#~ msgstr "Trop de fichiers raster ouverts"
+msgid "Too many open raster maps"
+msgstr "Trop de fichiers raster ouverts"
-#~ msgid "Too many open files"
-#~ msgstr "Trop de fichiers ouverts"
+msgid "Too many open files"
+msgstr "Trop de fichiers ouverts"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ERREUR: Géodatabase (GISBASE) sans valeur\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "ERREUR: Géodatabase (GISBASE) sans valeur\n"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr ""
-#~ "Erreur en lisant le paramètre de décalage du datum dans la table pour %s"
+msgid "Error reading datum shift parameters for %s from table"
+msgstr "Erreur en lisant le paramètre de décalage du datum dans la table pour %s"
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr ""
-#~ "Erreur en lisant les paramètres de l'ellipsoïde depuis la table pour %s"
+msgid "Error reading ellipsoid parameters for %s from table"
+msgstr "Erreur en lisant les paramètres de l'ellipsoïde depuis la table pour %s"
-#~ msgid "No ellipsoid field %s in file %s in %s"
-#~ msgstr "Pas de champ ellipsoïde %s dans le fichier %s de %s"
+msgid "No ellipsoid field %s in file %s in %s"
+msgstr "Pas de champ ellipsoïde %s dans le fichier %s de %s"
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "valeur invalide: champ %s dans le fichier %s de %s"
+msgid "invalid value: field %s in file %s in %s"
+msgstr "valeur invalide: champ %s dans le fichier %s de %s"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "Pas de n-dims dans site_list"
+msgid "No n-dims in site_list"
+msgstr "Pas de n-dims dans site_list"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "Aucun attribut double dans site_list"
+msgid "No double attributes in site_list"
+msgstr "Aucun attribut double dans site_list"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "Pas d'attribut chaîne de caractère dans site_list"
+msgid "No string attributes in site_list"
+msgstr "Pas d'attribut chaîne de caractère dans site_list"
-#~ msgid "String attribute index out of range"
-#~ msgstr "Index de l'attribut chaîne en dehors des limites"
+msgid "String attribute index out of range"
+msgstr "Index de l'attribut chaîne en dehors des limites"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "Attribut inconnu dans l'appel a G_readsites_xyz()!\n"
+msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+msgstr "Attribut inconnu dans l'appel a G_readsites_xyz()!\n"
-#~ msgid "Reading sites list ... "
-#~ msgstr "Lecture de la liste des sites... "
+msgid "Reading sites list ... "
+msgstr "Lecture de la liste des sites... "
-#~ msgid "failed to guess format"
-#~ msgstr "impossible de deviner le format"
+msgid "failed to guess format"
+msgstr "impossible de deviner le format"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "le champ décimal %i n'est pas présent dans le fichier de sites"
+msgid "decimal field %i not present in sites file"
+msgstr "le champ décimal %i n'est pas présent dans le fichier de sites"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr ""
-#~ "J'ai trouvé des enregistrements sans attribut en virgule flottante "
-#~ "(champs préfixés par '%')"
+msgid "I'm finding records that do not have a floating point attributes (fields prefixed with '%')."
+msgstr "J'ai trouvé des enregistrements sans attribut en virgule flottante (champs préfixés par '%')"
-#~ msgid "WARNING: can not create a new process\n"
-#~ msgstr "ATTENTION: impossible de créer un nouveau processus\n"
+msgid "WARNING: can not create a new process\n"
+msgstr "ATTENTION: impossible de créer un nouveau processus\n"
-#~ msgid "Select type: point, line, boundary, centroid or area"
-#~ msgstr "Sélectionnez un type: point, ligne, intervalle, centroïde ou zone"
+msgid "Select type: point, line, boundary, centroid or area"
+msgstr "Sélectionnez un type: point, ligne, intervalle, centroïde ou zone"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Le vecteur '%s' existe déjà ."
+msgid "The vector '%s' already exists."
+msgstr "Le vecteur '%s' existe déjà ."
-#~ msgid "unable to find [%s] in [%s]"
-#~ msgstr "impossible de trouver [%s] dans [%s]"
+msgid "unable to find [%s] in [%s]"
+msgstr "impossible de trouver [%s] dans [%s]"
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "Mémoire insuffisante pour l'attribution gaussienne"
+msgid "Insufficent memory for allocation of gaussian"
+msgstr "Mémoire insuffisante pour l'attribution gaussienne"
-#~ msgid "Registering lines: "
-#~ msgstr "Enregistrement des lignes : "
+msgid "Registering lines: "
+msgstr "Enregistrement des lignes : "
-#~ msgid "All vertices"
-#~ msgstr "Tous les sommets"
+msgid "All vertices"
+msgstr "Tous les sommets"
-#~ msgid "Snaps"
-#~ msgstr "Cassés"
+msgid "Snaps"
+msgstr "Cassés"
-#~ msgid "Cannot delete the line, map '%s' is not opened on level 2"
-#~ msgstr ""
-#~ "Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en "
-#~ "niveau 2"
+msgid "Cannot delete the line, map '%s' is not opened on level 2"
+msgstr "Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en niveau 2"
#, fuzzy
-#~ msgid "Unable to delete layer/category %d/%d line %d"
-#~ msgstr "Impossible de supprimer la couche vectorielle <%s>"
+msgid "Unable to delete layer/category %d/%d line %d"
+msgstr "Impossible de supprimer la couche vectorielle <%s>"
-#~ msgid "Cannot find input map '%s'"
-#~ msgstr "Impossible de trouver la couche d'entrée '%s'"
+msgid "Cannot find input map '%s'"
+msgstr "Impossible de trouver la couche d'entrée '%s'"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "Impossible de réécrire la ligne"
+msgid "Cannot rewrite line"
+msgstr "Impossible de réécrire la ligne"
#, fuzzy
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "aucun fichier %s disponible\n"
+msgid "Color file for [%s] not available"
+msgstr "aucun fichier %s disponible\n"
-#~ msgid "Snapped vertices"
-#~ msgstr "Sommets cassés"
+msgid "Snapped vertices"
+msgstr "Sommets cassés"
-#~ msgid "New vertices"
-#~ msgstr "Nouveaux sommets"
+msgid "New vertices"
+msgstr "Nouveaux sommets"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** nom illégal **"
+msgid "%s - ** illegal name **"
+msgstr "%s - ** nom illégal **"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "Echec lors de la conversion de l'attribut."
+msgid "Failed to convert string attribute."
+msgstr "Echec lors de la conversion de l'attribut."
+#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
+#~ msgstr "Impossible d'écrire le fichier de verrouillage %s (disque plein ? permissions ?)"
+#~ msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+#~ msgstr "Impossible d'ouvrir le fichier de signatures <%s> pour le sous-groupe <%s>du groupe <%s@%s>"
+#~ msgid "Unable to open topo file for write <%s>"
+#~ msgstr "Impossible d'ouvrir le fichier topo en écriture <%s>"
#~ msgid "cell_values_float: xdr_float failed for index %d"
#~ msgstr "cell_values_float : xdr_float échec de l'indice %d"
@@ -9623,8 +9159,7 @@
#~ msgstr "Calcul des plus courts chemins pour toutes les paires..."
#~ msgid "Unable to open fidx file for vector map <%s@%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier fidx pour la couche vectorielle <%s@%s>"
+#~ msgstr "Impossible d'ouvrir le fichier fidx pour la couche vectorielle <%s@%s>"
#~ msgid "Unable to write feature (negative offset)"
#~ msgstr "Impossible d'écrire la ligne (décalage négatif)"
@@ -9693,8 +9228,7 @@
#~ msgstr "Lecture des noeuds depuis la carte vectorielle ..."
#~ msgid "Precision used in the output file (default, max, or 0 to 52)"
-#~ msgstr ""
-#~ "Précision utilisée dans le fichier de sortie (par défaut, max, ou 0 à 52)"
+#~ msgstr "Précision utilisée dans le fichier de sortie (par défaut, max, ou 0 à 52)"
#~ msgid " Presented as: %s\n"
#~ msgstr " Présenté comme : %s\n"
@@ -9706,8 +9240,7 @@
#~ msgstr " Vous avez fourni %d éléments :\n"
#~ msgid "quantization file [%s] in mapset [%s] %s"
-#~ msgstr ""
-#~ "fichier de quantification [%s] dans le jeu de données (mapset) [%s] %s"
+#~ msgstr "fichier de quantification [%s] dans le jeu de données (mapset) [%s] %s"
#~ msgid ""
#~ "\n"
@@ -9736,9 +9269,7 @@
#~ msgstr "Impossible d'ouvrir '%s'"
#~ msgid "Error writing floating point format file for map %s"
-#~ msgstr ""
+#~ msgstr "Erreur lors de l'écriture en virgule flottante dans le fichier au format de la couche %s"
#~ msgid "Unable to read header file for raster map <%s@%s>."
#~ msgstr "Impossible de lire le fichier d'en-tête de la carte raster <%s@%s>."
@@ -9775,17 +9306,13 @@
#~ "%s"
#~ msgid "Unable to open category index file for vector map <%s@%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier d'index de catégorie pour la couche "
-#~ "vectorielle <%s@%s>"
+#~ msgstr "Impossible d'ouvrir le fichier d'index de catégorie pour la couche vectorielle <%s@%s>"
#~ msgid "Unable to create header file for [%s in %s]"
#~ msgstr "Impossible de créer l'en-tête de fichier pour [%s dans %s]"
#~ msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-#~ msgstr ""
-#~ "G_put_map_row : %s n'est pas un entier! Utiliser G_put_[f/d]_raster_row"
+#~ msgstr "G_put_map_row : %s n'est pas un entier! Utiliser G_put_[f/d]_raster_row() !"
#~ msgid "can't read f_range file for [%s in %s]"
#~ msgstr "impossible de lire le fichier f_range pour [%s dans %s]"
@@ -9814,9 +9341,7 @@
#~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier d'étiquettes date&heure (timestamp) pour "
-#~ "la couche %s %s dans le jeu de données (mapset) %s"
+#~ msgstr "Impossible d'ouvrir le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#~ msgid "Can't read %s for [%s in %s]"
#~ msgstr "Impossible de lire %s pour [%s dans %s]"
@@ -9831,9 +9356,7 @@
#~ msgstr "La matrice n'est pas symétrique!"
#~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr ""
-#~ "La résolution par la méthode de Gauss ne fonctionne pas avec les matrices "
-#~ "creuses"
+#~ msgstr "La résolution par la méthode de Gauss ne fonctionne pas avec les matrices creuses"
#~ msgid "The lu solver does not work with sparse matrices"
#~ msgstr "Le solveur LU ne fonctionne pas avec les matrices creuses"
@@ -9841,46 +9364,26 @@
#~ msgid "The cholesky solver does not work with sparse matrices"
#~ msgstr "Le solveur de Cholesky ne fonctionne pas avec les matrices creuses"
-#~ msgid ""
-#~ "The type of solver which should solve the symmetric linear equation system"
-#~ msgstr ""
-#~ "Le type de solveur qui devrait résoudre le système d'équations linéaires "
-#~ "symétrique"
+#~ msgid "The type of solver which should solve the symmetric linear equation system"
+#~ msgstr "Le type de solveur qui devrait résoudre le système d'équations linéaires symétrique"
#~ msgid "The type of solver which should solve the linear equation system"
-#~ msgstr ""
-#~ "Le type de solveur qui devrait permettre de résoudre le système "
-#~ "d'équations linéaires"
+#~ msgstr "Le type de solveur qui devrait permettre de résoudre le système d'équations linéaires"
-#~ msgid ""
-#~ "Maximum number of iteration used to solver the linear equation system"
-#~ msgstr ""
-#~ "Nombre maximum d'itérations utilisées pour le solutionneur du système "
+#~ msgid "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr "Nombre maximum d'itérations utilisées pour le solutionneur du système d'équations linéaires"
-#~ msgid ""
-#~ "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-#~ msgstr ""
-#~ "Erreur de critères pour le solveur par itération (Jacobi, sor, cg ou "
-#~ "bicgstab)"
+#~ msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+#~ msgstr "Erreur de critères pour le solveur par itération (Jacobi, sor, cg ou bicgstab)"
-#~ msgid ""
-#~ "The relaxation parameter used by the jacobi and sor solver for speedup or "
-#~ "stabilizing"
-#~ msgstr ""
-#~ "Les paramètres utilisés par le solveur pour les méthodes jacobi et sor "
-#~ "pour accélérer ou stabiliser"
+#~ msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+#~ msgstr "Les paramètres utilisés par le solveur pour les méthodes jacobi et sor pour accélérer ou stabiliser"
-#~ msgid ""
-#~ "Unable to write embedded null values for raster map open for random access"
-#~ msgstr ""
-#~ "Impossible d'écrire les valeurs nulles intégrées pour une carte raster "
-#~ "ouverte en accès aléatoire"
+#~ msgid "Unable to write embedded null values for raster map open for random access"
+#~ msgstr "Impossible d'écrire les valeurs nulles intégrées pour une carte raster ouverte en accès aléatoire"
#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr ""
-#~ " C'est une reclassification de la carte raster <%s@%s> dont l'en-tête est "
-#~ "invalide."
+#~ msgstr " C'est une reclassification de la carte raster <%s@%s> dont l'en-tête est invalide."
#~ msgid " Invalid format."
#~ msgstr "Format invalide."
@@ -9963,8 +9466,7 @@
#~ msgstr ""
#~ "\n"
#~ "\n"
-#~ "La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de "
-#~ "données (mapset) [%s].\n"
+#~ "La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de données (mapset) [%s].\n"
#~ msgid ""
#~ "\n"
@@ -10143,8 +9645,7 @@
#~ msgstr "Pilote graphique [%s] commencé"
#~ msgid "or 'custom' if you wish to enter custom parameters\n"
-#~ msgstr ""
-#~ "ou 'personnalisé' si vous souhaitez entrer des paramètres personnalisés\n"
+#~ msgstr "ou 'personnalisé' si vous souhaitez entrer des paramètres personnalisés\n"
#~ msgid "Allow overwrite"
#~ msgstr "Autoriser d'écraser"
@@ -10156,12 +9657,10 @@
#~ msgstr "Exécuter en silence"
#~ msgid "%s: map [%s] not open for random write - request ignored"
-#~ msgstr ""
-#~ "%s : couche [%s] non ouverte en écriture aléatoire - demande ignorée"
+#~ msgstr "%s : couche [%s] non ouverte en écriture aléatoire - demande ignorée"
#~ msgid "%s: map [%s] not open for sequential write - request ignored"
-#~ msgstr ""
-#~ "%s : couche [%s] non ouverte en écriture séquentielle - demande ignorée"
+#~ msgstr "%s : couche [%s] non ouverte en écriture séquentielle - demande ignorée"
#~ msgid "Connect attempt timed out."
#~ msgstr "Le temps d'attente de connexion a expiré."
@@ -10182,15 +9681,10 @@
#~ msgstr "La couche raster %s@%s est vide"
#~ msgid "Cannot write quant rules: map %s is integer"
-#~ msgstr ""
-#~ "Impossible d'écrire les règles de quantité : la couche %s est un entier"
+#~ msgstr "Impossible d'écrire les règles de quantité : la couche %s est un entier"
-#~ msgid ""
-#~ "G_set_window(): projection/zone differs from that of currently open "
-#~ "raster maps"
-#~ msgstr ""
-#~ "G_set_window() : projection/zone diffèrent de ceux présents dans le "
-#~ "fichier matriciel actuellement ouvert"
+#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+#~ msgstr "G_set_window() : projection/zone diffèrent de ceux présents dans le fichier matriciel actuellement ouvert"
#~ msgid "The floating data range for %s@%s is empty"
#~ msgstr "L'intervalle de nombre en virgule flottante pour %s@%s est vide"
@@ -10214,13 +9708,10 @@
#~ msgstr "erreur lors de l'écriture d'une ligne nulle %d"
#~ msgid "category support for [%s] in mapset [%s] %s"
-#~ msgstr ""
-#~ "support de la catégorie [%s] dans le jeu de données (mapset) [%s] %s"
+#~ msgstr "support de la catégorie [%s] dans le jeu de données (mapset) [%s] %s"
#~ msgid "category support for vector map [%s] in mapset [%s] %s"
-#~ msgstr ""
+#~ msgstr "support de la catégorie pour le fichier vecteur [%s] dans le jeu de données (mapset) [%s] %s"
#~ msgid "Cannot open temp file"
#~ msgstr "Impossible d'ouvrir le fichier temporaire"
@@ -10250,12 +9741,8 @@
#~ msgid "Layer number"
#~ msgstr "Numéro de la couche"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
-#~ msgstr ""
-#~ "Une seule carte vectorielle peut être connectée à plusieurs tables de "
-#~ "base de données. Ce nombre détermine la table à utiliser."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Une seule carte vectorielle peut être connectée à plusieurs tables de base de données. Ce nombre détermine la table à utiliser."
#~ msgid ""
#~ "\n"
@@ -10287,13 +9774,10 @@
#~ msgstr "pour accepter le choix par défaut"
#~ msgid "color support for [%s] in mapset [%s] %s"
-#~ msgstr ""
-#~ "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
+#~ msgstr "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
#~ msgid "Invalid timestamp specified for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est "
-#~ "invalide dans le jeu de données (mapset) %s"
+#~ msgstr "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est invalide dans le jeu de données (mapset) %s"
#~ msgid "Error reading compressed map <%s@%s>, row %d"
#~ msgstr "Erreur de lecture de la carte compressée <%s@%s>, ligne %d"
@@ -10330,25 +9814,16 @@
#~ msgstr "Trop de catégories de reclassification pour [%s dans %s]"
#~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr ""
-#~ "Format de reclassification illégal dans l'en-tête de fichier pour [%s "
-#~ "dans %s]"
+#~ msgstr "Format de reclassification illégal dans l'en-tête de fichier pour [%s dans %s]"
#~ msgid "Unable to create dependency file in [%s in %s]"
#~ msgstr "Impossible de créer le fichier de dépendances dans [%s dans %s]"
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different projection than current region. Found "
-#~ "raster map <%s@%s>, should be <%s>."
-#~ msgstr ""
-#~ "Carte raster <%s@%s> dans une projection différente de la région "
-#~ "courante. La carte raster <%s@%s>, devrait être <%s>."
+#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+#~ msgstr "Carte raster <%s@%s> dans une projection différente de la région courante. La carte raster <%s@%s>, devrait être <%s>."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-#~ msgstr ""
-#~ "Carte raster <%s@%s> est dans une zone différentes (%d) de la région "
-#~ "courante (%d)"
+#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr "Carte raster <%s@%s> est dans une zone différentes (%d) de la région courante (%d)"
#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
#~ msgstr "Carte raster <%s@%s> : octets par cellule (%d) trop grands"
@@ -10360,19 +9835,13 @@
#~ msgstr "impossible d'écrire l'historique pour [%s]"
#~ msgid "Not enough room in history file to record command line."
-#~ msgstr ""
+#~ msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande"
#~ msgid "Not enough room in history file for command line (truncated)."
-#~ msgstr ""
+#~ msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande (tronquée)"
#~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr ""
-#~ "Impossible d'ajouter un lien base de données, la carte n'est pas ouverte "
-#~ "en mode ÃCRITURE"
+#~ msgstr "Impossible d'ajouter un lien base de données, la carte n'est pas ouverte en mode ÃCRITURE"
#~ msgid "Error in rule on row %d in %s"
#~ msgstr "Erreur dans la règle à la ligne %d dans %s"
@@ -10452,8 +9921,7 @@
#~ msgstr "Nom de table illégal <%s>. Doit commencer par une lettre.\n"
#~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-#~ msgstr ""
-#~ "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
+#~ msgstr "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
#~ msgid "Data type used in the output file"
#~ msgstr "Type de données utilisées dans le fichier de sortie"
@@ -10489,9 +9957,7 @@
#~ msgstr "G3d_openCellOld : erreur dans G3d_readHeader"
#~ msgid "G3d_openCellOld: projection does not match window projection"
-#~ msgstr ""
-#~ "G3d_openCellOld : la projection ne correspond pas à la projection de la "
-#~ "fenêtre"
+#~ msgstr "G3d_openCellOld : la projection ne correspond pas à la projection de la fenêtre"
#~ msgid "G3d_openCellOld: zone does not match window zone"
#~ msgstr "G3d_openCellOld : la zone ne correspond pas à la zone de la fenêtre"
@@ -10630,14 +10096,10 @@
#~ "Veuillez spécifier un nom d'ellipsoïde\n"
#~ msgid "Can't create timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour "
+#~ msgstr "Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s "
-#~ "dans le jeu de données (mapset) %s"
+#~ msgstr "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s dans le jeu de données (mapset) %s"
#~ msgid ""
#~ "\n"
@@ -10646,12 +10108,8 @@
#~ "\n"
#~ "Veuillez spécifier un nom de datum\n"
-#~ msgid ""
-#~ "Unable to build spatial index from topology, vector map is not opened at "
-#~ "topo level 2"
-#~ msgstr ""
-#~ "Impossible de construire l'index spatial à partir de la topologie, la "
-#~ "carte vecteur n'est pas ouverte au niveau topo 2"
+#~ msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+#~ msgstr "Impossible de construire l'index spatial à partir de la topologie, la carte vecteur n'est pas ouverte au niveau topo 2"
#~ msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
#~ msgstr "BUG (Vect_build_sidx_from_topo) : le nÅud n'existe pas"
@@ -10671,19 +10129,11 @@
#~ msgid "OGR format cannot be updated"
#~ msgstr "Le format OGR ne peut pas être mis à jour"
-#~ msgid ""
-#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-#~ "excess)"
-#~ msgstr ""
-#~ "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus long qu'il "
-#~ "ne devrait être (excès de %ld bytes)"
+#~ msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+#~ msgstr "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus long qu'il ne devrait être (excès de %ld bytes)"
-#~ msgid ""
-#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-#~ "missing)."
-#~ msgstr ""
-#~ "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus court "
-#~ "qu'il ne devrait être (excès de %ld bytes)"
+#~ msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#~ msgstr "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus court qu'il ne devrait être (excès de %ld bytes)"
#~ msgid "Option <%s> does not accept multiple answers\n"
#~ msgstr "L'option <%s> n'accepte pas de réponses multiples\n"
@@ -10706,21 +10156,14 @@
#~ msgid "'%s' must be > 0 for '%s'"
#~ msgstr "'%s' doit être > 0 pour '%s'"
-#~ msgid ""
-#~ "Vect_read_line(): feature id %d is not reasonable (max features in vector "
-#~ "map <%s>: %d)"
-#~ msgstr ""
-#~ "Vect_read_line(): l'id d'objet %d n'est pas raisonnable (nombre maxi "
-#~ "d'objets dans la carte vecteur <%s>: %d)"
+#~ msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+#~ msgstr "Vect_read_line(): l'id d'objet %d n'est pas raisonnable (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#~ msgid "not implemented"
#~ msgstr "non implémenté"
-#~ msgid ""
-#~ "Random read is not supported by OGR for this layer, cannot build support"
-#~ msgstr ""
-#~ "Lecture aléatoire non supportée par OGR pour cette couche, impossible de "
-#~ "construire les fichiers support"
+#~ msgid "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr "Lecture aléatoire non supportée par OGR pour cette couche, impossible de construire les fichiers support"
#~ msgid "Feature %d without geometry ignored"
#~ msgstr "L'objet %d sans géométrie a été ignoré"
@@ -10749,25 +10192,17 @@
#~ msgid "Unable to get GIS_LOCK environment variable value"
#~ msgstr "Impossible d'obtenir la variable d'environnement GIS_LOCK"
-#~ msgid ""
-#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-#~ msgstr ""
-#~ "la carte <%s@%s> est un lien GDAL mais GRASS est compilé sans le support "
-#~ "GDAL"
+#~ msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr "la carte <%s@%s> est un lien GDAL mais GRASS est compilé sans le support GDAL"
#~ msgid "G__open_raster_new(): no temp files available"
#~ msgstr "G__open_raster_new() : pas de fichiers temporaires disponibles"
#~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-#~ msgstr ""
-#~ "G_set_fp_type() : ne peut être appellé que pour des FCELL_TYPE ou des "
-#~ "DCELL_TYPE"
+#~ msgstr "G_set_fp_type() : ne peut être appellé que pour des FCELL_TYPE ou des DCELL_TYPE"
-#~ msgid ""
-#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
-#~ msgstr ""
-#~ "G_set_quant_rules() ne peut être appellé que pour des cartes raster "
-#~ "ouvertes en lecture"
+#~ msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr "G_set_quant_rules() ne peut être appellé que pour des cartes raster ouvertes en lecture"
#~ msgid ""
#~ "\n"
@@ -10779,9 +10214,14 @@
#~ msgid "unable to write quant file!"
-#~ msgid ""
-#~ "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S="
-#~ "(%f,%f)(%f,%f)"
-#~ msgstr ""
-#~ "G_distance_point_to_line_segment : ne devrait pas arriver : code=%d P=(%f,"
-#~ "%f) S=(%f,%f)(%f,%f)"
+#~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgstr "G_distance_point_to_line_segment : ne devrait pas arriver : code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgid "%d errors in category string."
+#~ msgstr "%d erreurs dans la chaîne des catégories"
+#~ msgid "MAPSET %s not found"
+#~ msgstr "Jeu de données (MAPSET) %s n'a pas été trouvé"
+#~ msgid "LOCATION << %s >> not available"
+#~ msgstr "Secteur (LOCATION) << %s >> indisponible"
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_it.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -13,7 +13,7 @@
msgstr ""
"Project-Id-Version: grasslibs_it\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-02-18 14:05+0100\n"
+"POT-Creation-Date: 2013-02-26 14:45+0100\n"
"PO-Revision-Date: 2013-02-03 12:21+0100\n"
"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -82,11 +82,8 @@
#: ../lib/symbol/read.c:260
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nome del simbolo errato: '%s' (dovrebbe essere: gruppo/nome o gruppo/"
-"nome at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nome del simbolo errato: '%s' (dovrebbe essere: gruppo/nome o gruppo/nome at mapset)"
#: ../lib/symbol/read.c:284
#, c-format
@@ -133,13 +130,8 @@
msgstr "Stringa del timestamp non valida"
#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Nota per sviluppatori: Per i vettoriali a punti viene usata una sites "
-"library modificata. (il modulo va aggiornato alla libreria vettoriale di "
-"GRASS6)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Nota per sviluppatori: Per i vettoriali a punti viene usata una sites library modificata. (il modulo va aggiornato alla libreria vettoriale di GRASS6)"
#: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:342 ../lib/ogsf/Gp3.c:206
#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
@@ -170,8 +162,7 @@
msgstr "G_oldsite_new_struct: numero di dimensioni o campi non valido"
#: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
msgstr ""
#: ../lib/ogsf/gsd_label.c:58
@@ -279,9 +270,7 @@
#: ../lib/ogsf/Gv3.c:406
#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+msgid "%d features without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/copy.c:142
@@ -307,9 +296,7 @@
#: ../lib/ogsf/Gp3.c:286
#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
+msgid "%d points without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/gsd_prim.c:146
@@ -319,12 +306,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c è una specifica dell'asse non valida. Rotazione ignorata. Si "
-"notifichino gli sviluppatori GRASS"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c è una specifica dell'asse non valida. Rotazione ignorata. Si notifichino gli sviluppatori GRASS"
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
@@ -379,9 +362,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:319
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Impossibile ricavare il formato di output dall'estensione del file: si userà "
-"MPEG"
+msgstr "Impossibile ricavare il formato di output dall'estensione del file: si userà MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:323
msgid "Unable to find suitable output format"
@@ -525,9 +506,7 @@
#: ../lib/ogsf/Gs3.c:596
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Il range della tabella di colori non corrisponde ai dati (mincol=%d, maxcol="
-"%d"
+msgstr "Il range della tabella di colori non corrisponde ai dati (mincol=%d, maxcol=%d"
#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
#, c-format
@@ -572,24 +551,17 @@
#: ../lib/proj/convert.c:139
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR non sa parsare la stringa di parametri in stile PROJ.4: %s (il codice di "
-"errore OGR era %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR non sa parsare la stringa di parametri in stile PROJ.4: %s (il codice di errore OGR era %d)"
#: ../lib/proj/convert.c:146
#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR non sa ottenere la stringa di parametri in stile WKT (il codice di "
+msgstr "OGR non sa ottenere la stringa di parametri in stile WKT (il codice di errore OGR era %d)"
#: ../lib/proj/convert.c:406
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Nome della proiezione mancante! Probabilmente i parametri di proiezione sono "
-"errati."
+msgstr "Nome della proiezione mancante! Probabilmente i parametri di proiezione sono errati."
#: ../lib/proj/convert.c:442
#, c-format
@@ -598,21 +570,13 @@
#: ../lib/proj/convert.c:458
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro "
-"è stato trovato. Dovresto controllare all'interno di questo."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro è stato trovato. Dovresto controllare all'interno di questo."
#: ../lib/proj/convert.c:462
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Numero di trasformazione %d non valido; il range valido è da 1 a %d. I "
-"parametri di trasformazione del datum non vengono specificati."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Numero di trasformazione %d non valido; il range valido è da 1 a %d. I parametri di trasformazione del datum non vengono specificati."
#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
#, c-format
@@ -698,8 +662,7 @@
#: ../lib/proj/ellipse.c:274 ../lib/gis/get_ellipse.c:321
#, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-"Le linee %s della tabella degli ellissoidi nel file <%s> non sono valide"
+msgstr "Le linee %s della tabella degli ellissoidi nel file <%s> non sono valide"
#: ../lib/raster3d/range.c:73
#, fuzzy, c-format
@@ -868,10 +831,7 @@
msgstr ""
#: ../lib/raster3d/test/test_main.c:78
-msgid ""
-"The tile size in kilo bytes to be used for the large file put/get value "
-"test. Set the tile size to 2048 and the number of row*cols*depths > 130000 "
-"to reproduce the tile rle error."
+msgid "The tile size in kilo bytes to be used for the large file put/get value test. Set the tile size to 2048 and the number of row*cols*depths > 130000 to reproduce the tile rle error."
msgstr ""
#: ../lib/raster3d/test/test_main.c:82 ../lib/gmath/test/test_main.c:79
@@ -894,9 +854,7 @@
msgstr ""
#: ../lib/raster3d/test/test_main.c:98
-msgid ""
-"Use run length encoding RLE to encode/decode single tiles. Attention RLE is "
-"buggy in case of large tiles or files."
+msgid "Use run length encoding RLE to encode/decode single tiles. Attention RLE is buggy in case of large tiles or files."
msgstr ""
#: ../lib/raster3d/test/test_main.c:118
@@ -937,8 +895,7 @@
#: ../lib/raster3d/open.c:117
#, fuzzy
msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-"Rast3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
+msgstr "Rast3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
#: ../lib/raster3d/open.c:121
#, fuzzy
@@ -978,8 +935,7 @@
#: ../lib/raster3d/open.c:230
#, fuzzy, c-format
msgid "map <%s> is not in the current mapset"
-msgstr ""
-"Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
+msgstr "Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
#: ../lib/raster3d/open.c:240
#, fuzzy
@@ -1009,8 +965,7 @@
#: ../lib/raster3d/color.c:331
#, fuzzy, c-format
msgid "mapset <%s> is not the current mapset"
-msgstr ""
#: ../lib/init/prompt.py:20
msgid "[Raster and Volume MASKs present]"
@@ -1043,7 +998,7 @@
msgid "WARNING"
msgstr "ATTENZIONE: "
-#: ../lib/init/grass.py:183
+#: ../lib/init/grass.py:186
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1051,120 +1006,120 @@
"Uso:\n"
-#: ../lib/init/grass.py:184 ../lib/gis/parser_html.c:140
+#: ../lib/init/grass.py:187 ../lib/gis/parser_html.c:140
#: ../lib/gis/parser_rest.c:146
msgid "Flags"
msgstr "Flag"
-#: ../lib/init/grass.py:185
+#: ../lib/init/grass.py:188
msgid "print this help message"
msgstr ""
-#: ../lib/init/grass.py:186
+#: ../lib/init/grass.py:189
msgid "show version information and exit"
msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:190
msgid "create given database, location or mapset if it doesn't exist"
msgstr ""
-#: ../lib/init/grass.py:188
+#: ../lib/init/grass.py:191
msgid "use text based interface"
msgstr ""
-#: ../lib/init/grass.py:189 ../lib/init/grass.py:191
+#: ../lib/init/grass.py:192 ../lib/init/grass.py:194
#, fuzzy
msgid "and set as default"
msgstr "per accettare i valori predefiniti"
-#: ../lib/init/grass.py:190
+#: ../lib/init/grass.py:193
msgid "use $DEFAULT_GUI graphical user interface"
msgstr ""
-#: ../lib/init/grass.py:192
+#: ../lib/init/grass.py:195
msgid "print GRASS configuration parameters"
msgstr ""
-#: ../lib/init/grass.py:193
+#: ../lib/init/grass.py:196
msgid "options: arch,build,compiler,path,revision"
msgstr ""
-#: ../lib/init/grass.py:194 ../lib/gis/parser_html.c:180
+#: ../lib/init/grass.py:197 ../lib/gis/parser_html.c:180
#: ../lib/gis/parser_rest.c:179
msgid "Parameters"
msgstr "Parametri"
-#: ../lib/init/grass.py:195
+#: ../lib/init/grass.py:198
msgid "initial database (path to GIS data)"
msgstr ""
-#: ../lib/init/grass.py:196
+#: ../lib/init/grass.py:199
#, fuzzy
msgid "initial location"
msgstr ""
"\n"
"proiezione non valida\n"
-#: ../lib/init/grass.py:197
+#: ../lib/init/grass.py:200
msgid "initial mapset"
msgstr ""
-#: ../lib/init/grass.py:198
+#: ../lib/init/grass.py:201
msgid "fully qualified initial mapset directory"
msgstr ""
-#: ../lib/init/grass.py:199
+#: ../lib/init/grass.py:202
msgid "Environment variables relevant for startup"
msgstr ""
-#: ../lib/init/grass.py:200
+#: ../lib/init/grass.py:203
msgid "select GUI (text, gui)"
msgstr ""
-#: ../lib/init/grass.py:201
+#: ../lib/init/grass.py:204
msgid "set wish shell name to override 'wish'"
msgstr ""
-#: ../lib/init/grass.py:202
+#: ../lib/init/grass.py:205
msgid "set html web browser for help pages"
msgstr ""
-#: ../lib/init/grass.py:203
+#: ../lib/init/grass.py:206
msgid "set additional path(s) to local GRASS modules or user scripts"
msgstr ""
-#: ../lib/init/grass.py:204
+#: ../lib/init/grass.py:207
msgid "set additional GISBASE for locally installed GRASS Addons"
msgstr ""
-#: ../lib/init/grass.py:205
+#: ../lib/init/grass.py:208
msgid "shell script to be processed as batch job"
msgstr ""
-#: ../lib/init/grass.py:206
+#: ../lib/init/grass.py:209
msgid "set python shell name to override 'python'"
msgstr ""
-#: ../lib/init/grass.py:228
+#: ../lib/init/grass.py:231
#, fuzzy, python-format
msgid "Unable to create temporary directory <%s>! Exiting."
msgstr "Impossibile allocare memoria\n"
-#: ../lib/init/grass.py:306
+#: ../lib/init/grass.py:309
msgid "GUI <%s> not supported in this version"
msgstr "Il formato richiesto non è stato compilato per questa versione"
-#: ../lib/init/grass.py:444
+#: ../lib/init/grass.py:447
msgid "Searched for a web browser, but none found"
msgstr ""
-#: ../lib/init/grass.py:468
+#: ../lib/init/grass.py:471
#, fuzzy
msgid "Hit RETURN to continue"
msgstr "premi INVIO per continuare -->"
-#: ../lib/init/grass.py:497
+#: ../lib/init/grass.py:500
msgid ""
"The python command does not work as expected!\n"
"Please check your GRASS_PYTHON environment variable.\n"
@@ -1174,7 +1129,7 @@
"Hit RETURN to continue.\n"
msgstr ""
-#: ../lib/init/grass.py:509
+#: ../lib/init/grass.py:512
msgid ""
"It appears that the X Windows system is not active.\n"
"A graphical based user interface is not supported.\n"
@@ -1183,56 +1138,55 @@
msgstr ""
-#: ../lib/init/grass.py:551 ../lib/init/grass.py:582
+#: ../lib/init/grass.py:554 ../lib/init/grass.py:585
msgid "<%s> is not a valid GRASS location"
msgstr "Mi spiace <%s> non è una opzione valida\n"
-#: ../lib/init/grass.py:563
+#: ../lib/init/grass.py:566
#, python-format
msgid "Failed to create new location. The location <%s> already exists."
msgstr ""
-#: ../lib/init/grass.py:580
+#: ../lib/init/grass.py:583
msgid "Missing WIND file fixed"
msgstr ""
-#: ../lib/init/grass.py:594
+#: ../lib/init/grass.py:597
msgid ""
"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
"Interactive startup needed."
msgstr ""
-#: ../lib/init/grass.py:608
+#: ../lib/init/grass.py:611
#, python-format
msgid ""
"Invalid user interface specified - <%s>.\n"
"Use the --help option to see valid interface names."
msgstr ""
-#: ../lib/init/grass.py:621
+#: ../lib/init/grass.py:624
msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
"Switching to text mode now.\n"
"\n"
"Hit RETURN to continue..."
msgstr ""
-#: ../lib/init/grass.py:631
+#: ../lib/init/grass.py:634
msgid ""
"Received EXIT message from GUI.\n"
"GRASS is not started. Bye."
msgstr ""
-#: ../lib/init/grass.py:634
+#: ../lib/init/grass.py:637
#, fuzzy
msgid ""
"Invalid return code from GUI startup script.\n"
"Please advise GRASS developers of this error."
msgstr "Per piacere avvisa gli sviluppatori GRASS per questo errore\n"
-#: ../lib/init/grass.py:644
+#: ../lib/init/grass.py:647
msgid ""
"Error reading data path information from g.gisenv.\n"
"GISDBASE=%(gisbase)s\n"
@@ -1242,142 +1196,138 @@
"Check the <%s(file)> file."
msgstr ""
-#: ../lib/init/grass.py:727
+#: ../lib/init/grass.py:730
msgid "Path '%s' doesn't exist"
msgstr "%s: Area %d non esiste"
-#: ../lib/init/grass.py:738
+#: ../lib/init/grass.py:741
#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
msgstr ""
-#: ../lib/init/grass.py:742
+#: ../lib/init/grass.py:745
#, python-format
msgid ""
"Unable to properly access '%s'.\n"
"Please notify system personel."
msgstr ""
-#: ../lib/init/grass.py:756
+#: ../lib/init/grass.py:759
#, fuzzy
msgid "Building user fontcap..."
msgstr "Creazione topologia...\n"
-#: ../lib/init/grass.py:790
+#: ../lib/init/grass.py:793
#, fuzzy
msgid "The SHELL variable is not set"
msgstr "GISRC - variabile non impostata"
-#: ../lib/init/grass.py:800
+#: ../lib/init/grass.py:803
#, python-format
msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
"\n"
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
-#: ../lib/init/grass.py:805
+#: ../lib/init/grass.py:808
#, python-format
msgid "Change file permission to 'executable' for '%s'"
msgstr ""
-#: ../lib/init/grass.py:807
+#: ../lib/init/grass.py:810
#, python-format
msgid "Executing '%s' ..."
msgstr ""
-#: ../lib/init/grass.py:812
+#: ../lib/init/grass.py:815
#, python-format
msgid "Execution of '%s' finished."
msgstr ""
-#: ../lib/init/grass.py:817
+#: ../lib/init/grass.py:820
#, python-format
msgid "GRASS GUI should be <%s>"
msgstr ""
-#: ../lib/init/grass.py:845
+#: ../lib/init/grass.py:848
#, python-format
msgid "Welcome to GRASS %s"
msgstr ""
-#: ../lib/init/grass.py:854
+#: ../lib/init/grass.py:857
msgid "GRASS homepage:"
msgstr ""
-#: ../lib/init/grass.py:855
+#: ../lib/init/grass.py:858
msgid "This version running through:"
msgstr ""
-#: ../lib/init/grass.py:857
+#: ../lib/init/grass.py:860
#, fuzzy
msgid "Help is available with the command:"
msgstr "Nessun aiuto disponibile per il comando [%s]\n"
-#: ../lib/init/grass.py:858
+#: ../lib/init/grass.py:861
msgid "See the licence terms with:"
msgstr ""
-#: ../lib/init/grass.py:861
+#: ../lib/init/grass.py:864
msgid "If required, restart the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:863
+#: ../lib/init/grass.py:866
msgid "Start the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:865
+#: ../lib/init/grass.py:868
msgid "When ready to quit enter:"
msgstr ""
-#: ../lib/init/grass.py:969
+#: ../lib/init/grass.py:972
msgid "Failed to start shell '%s'"
msgstr "Impossibile aprire il file %s in %s"
-#: ../lib/init/grass.py:973
+#: ../lib/init/grass.py:976
#, python-format
msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
msgstr ""
-#: ../lib/init/grass.py:974 ../lib/init/grass.py:979
+#: ../lib/init/grass.py:977 ../lib/init/grass.py:982
msgid "Goodbye from GRASS GIS"
msgstr ""
-#: ../lib/init/grass.py:977
+#: ../lib/init/grass.py:980
#, fuzzy
msgid "Done."
msgstr "nessuno"
-#: ../lib/init/grass.py:983
+#: ../lib/init/grass.py:986
#, fuzzy
msgid "Cleaning up temporary files..."
-#: ../lib/init/grass.py:1025
+#: ../lib/init/grass.py:1028
msgid "Parameter <%s> not supported"
msgstr "Tipo %d di feature OGR non supportato"
-#: ../lib/init/grass.py:1166
+#: ../lib/init/grass.py:1169
#, python-format
msgid ""
"Unable to start GRASS. You can:\n"
" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
msgstr ""
-#: ../lib/init/grass.py:1175
+#: ../lib/init/grass.py:1178
msgid "Starting GRASS GIS..."
msgstr ""
-#: ../lib/init/grass.py:1233
+#: ../lib/init/grass.py:1236
#, python-format
msgid "Launching <%s> GUI in the background, please wait..."
msgstr ""
@@ -1449,9 +1399,7 @@
#: ../lib/raster/init.c:61
#, fuzzy
msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-"ERRORE: Sistema non inizializzato. Il programmatore si è scordato di usare "
-"la funzione G_gisinit()\n"
+msgstr "ERRORE: Sistema non inizializzato. Il programmatore si è scordato di usare la funzione G_gisinit()\n"
#: ../lib/raster/color_read.c:103
#, fuzzy
@@ -1524,9 +1472,7 @@
#: ../lib/raster/gdal.c:496
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../lib/raster/gdal.c:502
@@ -1570,21 +1516,15 @@
#: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window.Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
#: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window.Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
#: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window.Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
#: ../lib/raster/color_rules.c:125
@@ -1627,12 +1567,8 @@
#: ../lib/raster/set_window.c:131
#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window(): la proiezione/zona differisce da quella del raster "
-"attualmente aperto"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): la proiezione/zona differisce da quella del raster attualmente aperto"
#: ../lib/raster/set_window.c:158
#, c-format
@@ -1662,8 +1598,7 @@
#: ../lib/raster/reclass.c:171
#, fuzzy, c-format
msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-"Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
+msgstr "Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
#: ../lib/raster/reclass.c:273
msgid "Illegal reclass request"
@@ -1686,8 +1621,7 @@
#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-" Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
+msgstr " Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
@@ -1708,12 +1642,8 @@
#: ../lib/raster/open.c:190
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@"
-"%s> che non esiste"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@%s> che non esiste"
#: ../lib/raster/open.c:195
#, fuzzy, c-format
@@ -1732,12 +1662,9 @@
#: ../lib/raster/open.c:219
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
msgstr ""
-"[%s] nel mapset [%s] - proiezione differenza rispetto alla regione "
-"attualmente in uso:\n"
+"[%s] nel mapset [%s] - proiezione differenza rispetto alla regione attualmente in uso:\n"
" la mappa trovata [%s] in: <%s>, deve essere <%s> "
#: ../lib/raster/open.c:226
@@ -1752,8 +1679,7 @@
#: ../lib/raster/open.c:256
#, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
#: ../lib/raster/open.c:264
@@ -1821,8 +1747,7 @@
msgstr "Raster <%s> non è xdr: byte_order: %s"
#: ../lib/raster/open.c:929
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
#: ../lib/raster/null_val.c:64
@@ -1838,26 +1763,22 @@
#: ../lib/raster/put_row.c:120
#, fuzzy, c-format
msgid "Error writing uncompressed FP data for row %d of <%s>"
-msgstr ""
-"errore nella lettura della mappa compressa [%s] nel mapset [%s], riga %d"
+msgstr "errore nella lettura della mappa compressa [%s] nel mapset [%s], riga %d"
#: ../lib/raster/put_row.c:130
#, fuzzy, c-format
msgid "Error writing compressed FP data for row %d of <%s>"
-msgstr ""
#: ../lib/raster/put_row.c:389 ../lib/raster/put_row.c:395
#, fuzzy, c-format
msgid "Error writing compressed data for row %d of <%s>"
-msgstr ""
#: ../lib/raster/put_row.c:405
#, fuzzy, c-format
msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr ""
#: ../lib/raster/put_row.c:464
#, fuzzy, c-format
@@ -2016,12 +1937,8 @@
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
-msgstr ""
-"impossibile aprire [%s] in [%s] poiché è una riclassificazione di [%s] in "
-"[%s] che non esiste"
+msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
+msgstr "impossibile aprire [%s] in [%s] poiché è una riclassificazione di [%s] in [%s] che non esiste"
#: ../lib/raster/get_cellhd.c:70
msgid "which is missing."
@@ -2131,18 +2048,13 @@
#: ../lib/imagery/sigsetfile.c:41
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Impossibile creare il file <%s> per il sottogruppo <%s> del gruppo <%s> - <"
-"%s> non è nel mapset attuale"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Impossibile creare il file <%s> per il sottogruppo <%s> del gruppo <%s> - <%s> non è nel mapset attuale"
#: ../lib/imagery/sigsetfile.c:57
#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"Impossibile creare il file <%s> per il sottogruppo <%s> del gruppo <%s>"
+msgstr "Impossibile creare il file <%s> per il sottogruppo <%s> del gruppo <%s>"
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -2162,20 +2074,17 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossibile creare il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
+msgstr "Impossibile creare il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossibile aprire il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
+msgstr "Impossibile aprire il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
+msgstr "Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
#: ../lib/imagery/iclass.c:83
#, fuzzy, c-format
@@ -2210,21 +2119,17 @@
#: ../lib/imagery/points.c:124
#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-"Impossibile aprire il file dei punti di controllo per il gruppo [%s in %s]"
+msgstr "Impossibile aprire il file dei punti di controllo per il gruppo [%s in %s]"
#: ../lib/imagery/points.c:132
#, c-format
msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-"Formato non supportato nel file dei punti di controllo per il gruppo [%s in "
-"%s]"
+msgstr "Formato non supportato nel file dei punti di controllo per il gruppo [%s in %s]"
#: ../lib/imagery/points.c:159
#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-"Impossibile creare il file dei punti di controllo per il gruppo [%s in %s]"
+msgstr "Impossibile creare il file dei punti di controllo per il gruppo [%s in %s]"
#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
msgid "Matrix dimensions out of range"
@@ -2280,9 +2185,7 @@
#: ../lib/gmath/la.c:527
msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-"La matrice (o sottomatrice) presenta singolarità . La soluzione è "
-"indeterminata."
+msgstr "La matrice (o sottomatrice) presenta singolarità . La soluzione è indeterminata."
#: ../lib/gmath/la.c:531
msgid "Problem in LA routine."
@@ -2290,8 +2193,7 @@
#: ../lib/gmath/la.c:538
msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-"Procedura non ancora disponibile per la tipologia della matrice selezionata"
+msgstr "Procedura non ancora disponibile per la tipologia della matrice selezionata"
#: ../lib/gmath/la.c:572
msgid "Matrix is not square. Cannot determine inverse"
@@ -2724,8 +2626,7 @@
#: ../lib/temporal/t.connect/main.c:38
#, fuzzy
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
msgstr "La connessione del database non è definita per il layer %d"
#: ../lib/temporal/t.connect/main.c:42
@@ -2940,8 +2841,7 @@
#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
#: ../lib/cairodriver/Draw_bitmap.c:47
@@ -2951,8 +2851,7 @@
#: ../lib/driver/parse_ftcap.c:84
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Impossibile leggere file definizione di scrittura; usa il predefinito"
+msgstr "%s: Impossibile leggere file definizione di scrittura; usa il predefinito"
#: ../lib/driver/parse_ftcap.c:90
#, c-format
@@ -3077,9 +2976,7 @@
#: ../lib/python/temporal/mapcalc.py:139 ../lib/python/temporal/extract.py:89
-msgid ""
-"Space time %s dataset <%s> is already in database, use overwrite flag to "
-"overwrite"
+msgid "Space time %s dataset <%s> is already in database, use overwrite flag to overwrite"
msgstr "Il vettoriale '%s' è già presente e sarà sovrascritto"
#: ../lib/python/temporal/mapcalc.py:144
@@ -3095,10 +2992,7 @@
msgstr ""
#: ../lib/python/temporal/mapcalc.py:190
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
msgstr ""
#: ../lib/python/temporal/mapcalc.py:208
@@ -3111,8 +3005,7 @@
#: ../lib/python/temporal/mapcalc.py:273 ../lib/python/temporal/extract.py:137
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/mapcalc.py:293
@@ -3243,8 +3136,7 @@
#: ../lib/python/temporal/stds_import.py:247
msgid "Unable to create default temporal database in new location %s"
-msgstr ""
-"Impossibile aprire il file %s delle definizioni del database vettoriale"
+msgstr "Impossibile aprire il file %s delle definizioni del database vettoriale"
#: ../lib/python/temporal/stds_import.py:299
#, python-format
@@ -3282,9 +3174,7 @@
#: ../lib/python/temporal/stds_import.py:345
#: ../lib/python/temporal/space_time_datasets_tools.py:882
-msgid ""
-"Space time %s dataset <%s> is already in the database. Use the overwrite "
-"flag."
+msgid "Space time %s dataset <%s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/stds_import.py:365
@@ -3300,15 +3190,11 @@
msgstr "Raster <%s> non trovato nel mapset <%s>"
#: ../lib/python/temporal/core.py:82 ../lib/python/temporal/core.py:90
-msgid ""
-"Unable to initialize the temporal GIS DBMI interface. Use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:161
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:201
@@ -3355,9 +3241,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:114
#, python-format
-msgid ""
-"Space time %s dataset <%s> with relative time found, but no relative unit "
-"set for %s maps"
+msgid "Space time %s dataset <%s> with relative time found, but no relative unit set for %s maps"
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:182
@@ -3366,36 +3250,27 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:205
#, python-format
-msgid ""
-"Unable to register %s map <%s> with layer %s. The map has no valid time and "
-"the start time is not set."
+msgid "Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set."
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:209
#, python-format
-msgid ""
-"Unable to register %s map <%s>. The map has no valid time and the start time "
-"is not set."
+msgid "Unable to register %s map <%s>. The map has no valid time and the start time is not set."
msgstr ""
#: ../lib/python/temporal/space_time_datasets_tools.py:224
-msgid ""
-"Map is already registered in temporal database. Unable to update %s map <%s> "
-"with layer %s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %s map <%s> with layer %s. Overwrite flag is not set."
#: ../lib/python/temporal/space_time_datasets_tools.py:229
-msgid ""
-"Map is already registered in temporal database. Unable to update %s map <"
-"%s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %s map <%s>. Overwrite flag is not set."
#: ../lib/python/temporal/space_time_datasets_tools.py:252
-msgid ""
-"Unable to update %s map <%s> with layer. The temporal types are different."
+msgid "Unable to update %s map <%s> with layer. The temporal types are different."
msgstr "Impossibile trovare il vettoriale <%s> in <%s>"
#: ../lib/python/temporal/space_time_datasets_tools.py:256
@@ -3435,9 +3310,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:383
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
msgstr "Impossibile copiare il vettoriale <%s> in <%s>"
#: ../lib/python/temporal/space_time_datasets_tools.py:388
@@ -3447,8 +3320,7 @@
#: ../lib/python/temporal/space_time_datasets_tools.py:405
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
#: ../lib/python/temporal/space_time_datasets_tools.py:410
@@ -3489,9 +3361,7 @@
#: ../lib/python/temporal/aggregation.py:131
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
+msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/aggregation.py:134
@@ -3506,8 +3376,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:652
msgid "Start time must be of type datetime for %s map <%s> with layer: %s"
-msgstr ""
-"Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
+msgstr "Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
#: ../lib/python/temporal/abstract_map_dataset.py:657
@@ -3538,8 +3407,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:729
msgid "Unsupported relative time unit type for %s map <%s> with layer %s: %s"
-msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:735
@@ -3553,15 +3421,12 @@
#: ../lib/python/temporal/abstract_map_dataset.py:813
#, python-format
-msgid ""
-"Map <%s> with layer %s has incorrect time interval, start time is greater "
-"than end time"
+msgid "Map <%s> with layer %s has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:818
#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:823
@@ -3576,9 +3441,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:906
-msgid ""
-"Unregister %(type)s map <%(map)s> with layer %(layer)s from space time "
-"datasets"
+msgid "Unregister %(type)s map <%(map)s> with layer %(layer)s from space time datasets"
#: ../lib/python/temporal/abstract_map_dataset.py:911
@@ -3608,25 +3471,19 @@
msgstr "Raster <%s> non trovato"
#: ../lib/python/temporal/spatial_extent.py:123
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:360
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:500
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:607
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:678
@@ -3702,17 +3559,11 @@
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:679
-msgid ""
-"More than one map found in a granule. Temporal granularity seems to be "
-"invalid or the chosen granularity is not a greatest common divider of all "
-"intervals and gaps in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:711
-msgid ""
-"time instances in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all time instances in the dataset."
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:910
@@ -3756,9 +3607,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1095
#, python-format
-msgid ""
-"Temporal type of space time dataset <%s> and map <%s> with layer %s are "
-"different"
+msgid "Temporal type of space time dataset <%s> and map <%s> with layer %s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1099
@@ -3773,15 +3622,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1121
#, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> with layer %s "
-"are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> with layer %s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1125
#, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1133
@@ -3830,19 +3676,16 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1324
msgid "Map <%s> with layer %s is not registered in space time dataset <%s>"
-msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1329
msgid "Map <%s> is not registered in space time dataset <%s>"
-msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1386
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:208
@@ -3912,12 +3755,8 @@
#: ../lib/python/script/raster.py:47
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-"Non posso cancellare la linea, la mappa '%s' non è aperta in modalità di "
-"scrittura ('write')"
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
+msgstr "Non posso cancellare la linea, la mappa '%s' non è aperta in modalità di scrittura ('write')"
#: ../lib/python/script/raster.py:105
msgid "An error occurred while running r.mapcalc"
@@ -3966,6 +3805,16 @@
msgid "Unable to list mapsets"
msgstr "Impossibile aprire %s"
+#: ../lib/python/script/core.py:1410
+#, fuzzy, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr "Nome file non valido. Non può essere '.' oppure 'NULL'\n"
+#: ../lib/python/script/core.py:1418
+msgid "Illegal filename <%s>. <%s> not allowed.\n"
+msgstr "Nome del file non valido. Il carattere <%c> non è permesso.\n"
#: ../lib/python/script/raster3d.py:89
msgid "An error occurred while running r3.mapcalc"
msgstr ""
@@ -4010,8 +3859,7 @@
#: ../lib/python/script/db.py:142
#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
#: ../lib/python/script/db.py:154
@@ -4498,12 +4346,8 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Ci sono interruzioni di classe fuori dal range min-max. Numero di classi "
-"ridotto a %i, ma saranno usate probabiltà per %i classi."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Ci sono interruzioni di classe fuori dal range min-max. Numero di classi ridotto a %i, ma saranno usate probabiltà per %i classi."
#: ../lib/vector/neta/utils.c:195
#, fuzzy, c-format
@@ -4544,21 +4388,13 @@
#: ../lib/vector/diglib/plus_node.c:214
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Tentativo di leggere l'angolo della linea che non è connesso al nodo: nodo "
-"%d, linea %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Tentativo di leggere l'angolo della linea che non è connesso al nodo: nodo %d, linea %d"
#: ../lib/vector/diglib/cindex_rw.c:156
#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
-"Versione %d.%d del formato dell'indice delle features non è supportata da "
-"questa release. Ricostruire la topologia o aggiornare GRASS."
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr "Versione %d.%d del formato dell'indice delle features non è supportata da questa release. Ricostruire la topologia o aggiornare GRASS."
#: ../lib/vector/diglib/file.c:159
msgid "Writing to file loaded to memory not supported"
@@ -4579,25 +4415,17 @@
#: ../lib/vector/diglib/spindex_rw.c:302
#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-msgstr ""
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
#: ../lib/vector/diglib/spindex_rw.c:308
#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:317
#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:858
@@ -4734,23 +4562,17 @@
#: ../lib/vector/diglib/plus_area.c:412
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Centroide inesistente %d registrato per l'area (baco nella libreria "
-"vettoriale)"
+msgstr "Centroide inesistente %d registrato per l'area (baco nella libreria vettoriale)"
#: ../lib/vector/diglib/plus_area.c:437
#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
-"Tentativo di cancellare le informazioni dell'area %d dall'isola inesistente "
-"%d"
+msgstr "Tentativo di cancellare le informazioni dell'area %d dall'isola inesistente %d"
#: ../lib/vector/diglib/plus_area.c:787
#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
-"Tentativo di cancellare le informazioni dell'isola %d dall'area inesistente "
-"%d"
+msgstr "Tentativo di cancellare le informazioni dell'isola %d dall'area inesistente %d"
#: ../lib/vector/diglib/struct_alloc.c:491
#, fuzzy
@@ -4769,28 +4591,22 @@
#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:104
#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:134
@@ -4800,8 +4616,7 @@
#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/test.c:165
@@ -4811,31 +4626,18 @@
#: ../lib/vector/diglib/plus_struct.c:523
#, fuzzy, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
#: ../lib/vector/diglib/plus_struct.c:529
#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-msgstr ""
-"Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice "
-"delle features del vettore. Si consiglia di ricostruire la topologia o "
-"aggiornare GRASS."
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice delle features del vettore. Si consiglia di ricostruire la topologia o aggiornare GRASS."
#: ../lib/vector/diglib/plus_struct.c:539
#, fuzzy, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-msgstr ""
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
#: ../lib/vector/Vlib/write_nat.c:49 ../lib/vector/Vlib/write_nat.c:85
#, c-format
@@ -4858,14 +4660,12 @@
#: ../lib/vector/Vlib/legal_vname.c:43
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
+msgstr "Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:50
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
+msgstr "Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
#: ../lib/vector/Vlib/legal_vname.c:58
#, c-format
@@ -4874,11 +4674,8 @@
#: ../lib/vector/Vlib/legal_vname.c:65
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono "
-"essere usate come nome della mappa."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono essere usate come nome della mappa."
#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
#, c-format
@@ -5109,11 +4906,8 @@
#: ../lib/vector/Vlib/build.c:1188
#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
-msgstr ""
-"Non riesco a cancellare la linea, la mappa '%s' non è aperta a livello 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgstr "Non riesco a cancellare la linea, la mappa '%s' non è aperta a livello 2"
#: ../lib/vector/Vlib/build.c:1211
#, fuzzy, c-format
@@ -5333,8 +5127,7 @@
#: ../lib/vector/Vlib/overlay.c:127
msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-"Intersezione: tipologie area per area non supportate dall'operatore AND"
+msgstr "Intersezione: tipologie area per area non supportate dall'operatore AND"
#: ../lib/vector/Vlib/level.c:34
msgid "Map structure was never initialized"
@@ -5547,12 +5340,8 @@
#: ../lib/vector/Vlib/geos.c:55
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo "
-"di features nel vettoriale <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:60
msgid "only native format supported"
@@ -5571,9 +5360,7 @@
#: ../lib/vector/Vlib/geos.c:104
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): impossibile leggere l'isola con id %d nell' area con "
-"id %d"
+msgstr "Vect_read_area_geos(): impossibile leggere l'isola con id %d nell' area con id %d"
#: ../lib/vector/Vlib/geos.c:203
#, c-format
@@ -5619,12 +5406,8 @@
#: ../lib/vector/Vlib/read.c:168
#, fuzzy, c-format
-msgid ""
-"Requested feature id %d is not reasonable(max features in vector map <%s>: "
-"%d)"
-msgstr ""
-"Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di "
-"features nel vettoriale <%s>: %d)"
+msgid "Requested feature id %d is not reasonable(max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
#: ../lib/vector/Vlib/build_ogr.c:69
msgid "Empty OGR layer, nothing to build"
@@ -5637,11 +5420,8 @@
#: ../lib/vector/Vlib/build_ogr.c:82
#, fuzzy
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
-msgstr ""
-"Lettura random non è supportata da OGR per questo layer, non è possibile "
-"costruire supporto"
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
+msgstr "Lettura random non è supportata da OGR per questo layer, non è possibile costruire supporto"
#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:90
#, c-format
@@ -5687,16 +5467,12 @@
#: ../lib/vector/Vlib/net.c:250
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
msgstr ""
#: ../lib/vector/Vlib/net.c:269
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
msgstr ""
#: ../lib/vector/Vlib/net.c:318
@@ -5710,9 +5486,7 @@
#: ../lib/vector/Vlib/net.c:411
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Record del database non trovato per il nodo %d (cat = %d) (costo impostato a "
-"0)"
+msgstr "Record del database non trovato per il nodo %d (cat = %d) (costo impostato a 0)"
#: ../lib/vector/Vlib/net.c:440
msgid "Flattening the graph..."
@@ -5871,22 +5645,13 @@
#: ../lib/vector/Vlib/open_ogr.c:389
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
#: ../lib/vector/Vlib/open_ogr.c:394
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
#: ../lib/vector/Vlib/open_ogr.c:500
#, fuzzy, c-format
@@ -5900,15 +5665,12 @@
#: ../lib/vector/Vlib/open_nat.c:148
#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
msgstr ""
#: ../lib/vector/Vlib/open_nat.c:152
#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
msgstr ""
#: ../lib/vector/Vlib/write_sfa.c:107
@@ -5940,15 +5702,11 @@
#: ../lib/vector/Vlib/open.c:225
#, fuzzy, c-format
msgid "Vector map <%s> not found in current mapset"
-msgstr ""
#: ../lib/vector/Vlib/open.c:239
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Il vettoriale che non presente nel mapset in uso non può essere aperta per "
-"gli aggiornamenti"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Il vettoriale che non presente nel mapset in uso non può essere aperta per gli aggiornamenti"
#: ../lib/vector/Vlib/open.c:276
#, fuzzy, c-format
@@ -5972,12 +5730,8 @@
#: ../lib/vector/Vlib/open.c:379 ../lib/vector/Vlib/open.c:401
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Impossibile aprire il vettoriale <%s> sul livello %d. Provare a ricostruire "
-"la topologia con v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Impossibile aprire il vettoriale <%s> sul livello %d. Provare a ricostruire la topologia con v.build."
#: ../lib/vector/Vlib/open.c:410
#, fuzzy, c-format
@@ -6016,9 +5770,7 @@
#: ../lib/vector/Vlib/open.c:971
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"La dimensione del file 'coor' differisce dal valore salvato nel file di "
-"topologia"
+msgstr "La dimensione del file 'coor' differisce dal valore salvato nel file di topologia"
#: ../lib/vector/Vlib/open.c:982 ../lib/vector/Vlib/open.c:1081
#, c-format
@@ -6028,9 +5780,7 @@
#: ../lib/vector/Vlib/open.c:1070
#, fuzzy
msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
-"La dimensione del file 'coor' è diverso dal valore salvato nel file di "
-"topologia"
+msgstr "La dimensione del file 'coor' è diverso dal valore salvato nel file di topologia"
#: ../lib/vector/Vlib/open.c:1134
#, fuzzy
@@ -6042,9 +5792,7 @@
msgstr ""
#: ../lib/vector/Vlib/dgraph.c:431
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
msgstr ""
#: ../lib/vector/Vlib/area.c:47
@@ -6079,9 +5827,7 @@
#: ../lib/vector/Vlib/cats.c:423
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Impossibile convertire la stringa '%s' della categoria (da '%s') al range "
-"della categoria"
+msgstr "Impossibile convertire la stringa '%s' della categoria (da '%s') al range della categoria"
#: ../lib/vector/Vlib/cats.c:516 ../lib/vector/Vlib/cats.c:610
#, fuzzy
@@ -6211,13 +5957,11 @@
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:648
@@ -6265,35 +6009,23 @@
#: ../lib/vector/Vlib/write.c:270
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperto sul "
-"livello topologico"
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperto sul livello topologico"
#: ../lib/vector/Vlib/write.c:276
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperta in "
-"modalità di scrittura"
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperta in modalità di scrittura"
#: ../lib/vector/Vlib/write.c:315
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperto sul "
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperto sul livello topologico"
#: ../lib/vector/Vlib/write.c:321
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperta in "
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperta in modalità di scrittura"
#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:542
#, c-format
@@ -6373,9 +6105,7 @@
#: ../lib/vector/Vlib/field.c:94
#, fuzzy
msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
-"Non riesco ad aprire un collegamento database, la mappa non è stata aperta "
-"in modalità di SCRITTURA."
+msgstr "Non riesco ad aprire un collegamento database, la mappa non è stata aperta in modalità di SCRITTURA."
#: ../lib/vector/Vlib/field.c:101
#, fuzzy
@@ -6397,9 +6127,7 @@
#: ../lib/vector/Vlib/field.c:183
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
msgstr ""
#: ../lib/vector/Vlib/field.c:259
@@ -6435,17 +6163,12 @@
msgstr "Impossibile aprire il driver OGR DBMI"
#: ../lib/vector/Vlib/field.c:755
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Fallimento di tutti i test FID. Nella tabella DB OGR non è presente nessuno "
-"di: 'FID', 'ogc_fid', 'ogr_fid', 'gid'"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Fallimento di tutti i test FID. Nella tabella DB OGR non è presente nessuno di: 'FID', 'ogc_fid', 'ogr_fid', 'gid'"
#: ../lib/vector/Vlib/field.c:822
#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
#: ../lib/vector/Vlib/field.c:842
@@ -6460,13 +6183,11 @@
#: ../lib/vector/Vlib/field.c:911
#, c-format
msgid "Unable to open vector database definition file '%s'"
-msgstr ""
#: ../lib/vector/Vlib/field.c:1006
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
#: ../lib/vector/Vlib/remove_areas.c:89
msgid "Area is composed of dead boundary"
@@ -6609,8 +6330,7 @@
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1534
-msgid ""
-"Inconsistency in topology detected: unable to determine next left/right edge."
+msgid "Inconsistency in topology detected: unable to determine next left/right edge."
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1601
@@ -6649,9 +6369,7 @@
#: ../lib/vector/Vlib/build_pg.c:79
#, fuzzy
msgid "Random read is not supported for this layer. Unable to build topology."
-msgstr ""
#: ../lib/vector/Vlib/build_pg.c:94
#, fuzzy
@@ -6932,22 +6650,13 @@
msgstr ""
#: ../lib/rst/interp_float/segmen2d.c:118
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"La ricerca dei punti per l'interpolazione sta durando troppo - si modifichi "
-"la regione per includere l'area dove si trovano i punti. Continuando i "
-"calcoli..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "La ricerca dei punti per l'interpolazione sta durando troppo - si modifichi la regione per includere l'area dove si trovano i punti. Continuando i calcoli..."
#: ../lib/rst/interp_float/interp2d.c:214
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene "
-"alla cella (%d,%d). Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene alla cella (%d,%d). Z-value %f, zmin %f, zmax %f."
#: ../lib/rst/interp_float/input2d.c:48
#, c-format
@@ -7016,8 +6725,7 @@
#: ../lib/rst/interp_float/vinput2d.c:249
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Ci sono punti fuori dalla regione 2D/3D specificata - %d punti ignorati"
+msgstr "Ci sono punti fuori dalla regione 2D/3D specificata - %d punti ignorati"
#: ../lib/rst/interp_float/vinput2d.c:252
#, c-format
@@ -7026,9 +6734,7 @@
#: ../lib/rst/interp_float/vinput2d.c:256
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
msgstr ""
#: ../lib/rst/interp_float/vinput2d.c:261
@@ -7037,22 +6743,13 @@
#: ../lib/rst/interp_float/vinput2d.c:266
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Parametri di segmentazione impostati a valori non validi: npmin= %d, segmax= "
-"%d per connessione continua dei segmenti, npmin > segmax (consultare il "
-"manuale)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Parametri di segmentazione impostati a valori non validi: npmin= %d, segmax= %d per connessione continua dei segmenti, npmin > segmax (consultare il manuale)"
#: ../lib/rst/interp_float/vinput2d.c:272
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Ci sono meno di %d punti per l'interpolazione. Non è richiesta "
-"segmentazione, per accelerare il programma impostare segmax=%d (cfr. manuale)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Ci sono meno di %d punti per l'interpolazione. Non è richiesta segmentazione, per accelerare il programma impostare segmax=%d (cfr. manuale)"
#: ../lib/rst/interp_float/vinput2d.c:276
#, c-format
@@ -7353,12 +7050,8 @@
msgstr "G_getenv(): variabile %s non impostata"
#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Versione incompatibile della libreria per il modulo. Ã necessario "
-"ricompilare GRASS o eliminare i conflitti tra installazioni multiple."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Versione incompatibile della libreria per il modulo. Ã necessario ricompilare GRASS o eliminare i conflitti tra installazioni multiple."
#: ../lib/gis/gisinit.c:61
#, c-format
@@ -7372,9 +7065,7 @@
#: ../lib/gis/gisinit.c:97
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"Sistema non inizializzato. Il programmatore si è scordato di usare la "
-"funzione G_gisinit()."
+msgstr "Sistema non inizializzato. Il programmatore si è scordato di usare la funzione G_gisinit()."
#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
msgid "Unable to seek"
@@ -7403,9 +7094,7 @@
#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine nord "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine nord (%g>%g)"
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
msgid "Illegal latitude for North"
@@ -7414,9 +7103,7 @@
#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine sud "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine sud (%g>%g)"
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
msgid "Illegal latitude for South"
@@ -7425,16 +7112,12 @@
#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine ovest "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine ovest (%g>%g)"
#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine est "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine est (%g>%g)"
#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
msgid "North must be north of South"
@@ -7512,15 +7195,11 @@
#: ../lib/gis/parser.c:491
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta "
-"automatica: --verbose."
+msgstr "Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta automatica: --verbose."
#: ../lib/gis/parser.c:505
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"automatica: --quiet."
+msgstr "Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta automatica: --quiet."
#: ../lib/gis/parser.c:536
#, fuzzy, c-format
@@ -8058,8 +7737,7 @@
msgstr "Nome database"
#: ../lib/gis/parser_standard_options.c:178
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
msgstr ""
#: ../lib/gis/parser_standard_options.c:187
@@ -8158,9 +7836,7 @@
msgstr "Tipo dati usato nel file di output"
#: ../lib/gis/parser_standard_options.c:365
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
msgstr ""
#: ../lib/gis/parser_standard_options.c:375
@@ -8170,9 +7846,7 @@
#: ../lib/gis/parser_standard_options.c:385
#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
msgstr "I dimensioni dei tile usati nel file di output"
#: ../lib/gis/parser_standard_options.c:395
@@ -8218,13 +7892,8 @@
#: ../lib/gis/parser_standard_options.c:459
#, fuzzy
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
-msgstr ""
-"Una singola mappa vettoriale può essere connessa a database multiple. Questo "
-"numero determina quale tabella viene usata."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
+msgstr "Una singola mappa vettoriale può essere connessa a database multiple. Questo numero determina quale tabella viene usata."
#: ../lib/gis/parser_standard_options.c:469
#, fuzzy
@@ -8233,13 +7902,8 @@
#: ../lib/gis/parser_standard_options.c:471
#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
#: ../lib/gis/parser_standard_options.c:480
msgid "Category value"
@@ -8333,8 +7997,7 @@
#: ../lib/gis/parser_standard_options.c:632
#, fuzzy
msgid "Name of the input space time datasets"
-msgstr ""
-"Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
+msgstr "Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
#: ../lib/gis/parser_standard_options.c:640
#, fuzzy
@@ -8389,8 +8052,7 @@
#: ../lib/gis/parser_standard_options.c:724
#, fuzzy
msgid "Type of the input space time dataset"
-msgstr ""
#: ../lib/gis/parser_standard_options.c:732
#, fuzzy
@@ -8414,9 +8076,7 @@
#: ../lib/gis/parser_standard_options.c:766
#, fuzzy
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
msgstr "La clausola WHERE del comando SQL manca della parola chiave 'where'"
#: ../lib/gis/parser_standard_options.c:767
@@ -8459,17 +8119,12 @@
#: ../lib/gis/view.c:545
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" La finestra salvata in \"%s\" è completamente al di fuori della finestra "
-"GRASS attualmente in uso."
+msgstr " La finestra salvata in \"%s\" è completamente al di fuori della finestra GRASS attualmente in uso."
#: ../lib/gis/view.c:549
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Solo %d%% della finestra salvata in \"%s\" si sovrappone con la finestra "
-"GRASS in uso"
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Solo %d%% della finestra salvata in \"%s\" si sovrappone con la finestra GRASS in uso"
#: ../lib/gis/parser_html.c:53 ../lib/gis/parser_rest.c:60
msgid "NAME"
@@ -8697,23 +8352,17 @@
#: ../lib/db/dbmi_base/legal_dbname.c:38
#, fuzzy, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o "
-"'NULL'.\n"
+msgstr "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o 'NULL'.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:45
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr ""
-"Nome della tabella della mappa <%s> non valido. Deve iniziare con una "
-"lettera.\n"
+msgstr "Nome della tabella della mappa <%s> non valido. Deve iniziare con una lettera.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:54
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-"Il nome <%s> non è valido per una mappa vettoriale. Il carattere <%c> non è "
-"permesso.\n"
+msgstr "Il nome <%s> non è valido per una mappa vettoriale. Il carattere <%c> non è permesso.\n"
#: ../lib/db/dbmi_base/default_name.c:136
msgid "Programmer error"
@@ -8723,202 +8372,196 @@
msgid "send data: invalid C-type"
msgstr ""
-#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
-#~ msgstr ""
-#~ "Impossibile scriver il lockfile %s (Fine dello spazio su disco? Permessi?)"
-#~ msgid ""
-#~ "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-#~ msgstr ""
-#~ "Impossibile aprire il file <%s> per il sottogruppo <%s> del gruppo <%s@%s>"
-#~ msgid "Unable to open topo file for write <%s>"
-#~ msgstr "Impossibile aprire il file di topologia in scrittura <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Unable to get number of records for:\n"
-#~ "%s"
-#~ msgstr "Non riesco ad aprire il file temp"
+msgid ""
+"Unable to get number of records for:\n"
+"%s"
+msgstr "Non riesco ad aprire il file temp"
#, fuzzy
-#~ msgid "Unable to read node %d"
-#~ msgstr "Impossibile leggere la linea %d"
+msgid "Unable to read node %d"
+msgstr "Impossibile leggere la linea %d"
#, fuzzy
-#~ msgid "Unable to read nodes"
+msgid "Unable to read nodes"
#, fuzzy
-#~ msgid "Unable to read lines"
+msgid "Unable to read lines"
#, fuzzy
-#~ msgid "Unable to attach centroids"
-#~ msgstr "Impossibile calcolare il centroide per l'area %d"
+msgid "Unable to attach centroids"
+msgstr "Impossibile calcolare il centroide per l'area %d"
#, fuzzy
-#~ msgid "Unexpected feature type (%s) - should be (%d)"
-#~ msgstr "Tipo di "
+msgid "Unexpected feature type (%s) - should be (%d)"
+msgstr "Tipo di "
#, fuzzy
-#~ msgid "Unable to read centroid %d: %s"
-#~ msgstr "Impossibile leggere la feature con id %d"
+msgid "Unable to read centroid %d: %s"
+msgstr "Impossibile leggere la feature con id %d"
#, fuzzy
-#~ msgid "Unable to export node %d. Exiting."
-#~ msgstr "Impossibile allocare memoria\n"
+msgid "Unable to export node %d. Exiting."
+msgstr "Impossibile allocare memoria\n"
#, fuzzy
-#~ msgid "Unable to look up account id"
-#~ msgstr "Impossibile aprire il codec"
+msgid "Unable to look up account id"
+msgstr "Impossibile aprire il codec"
#, fuzzy
-#~ msgid "Unable to allocate memory for account name"
-#~ msgstr "Impossibile allocare memoria per buffer nulla"
+msgid "Unable to allocate memory for account name"
+msgstr "Impossibile allocare memoria per buffer nulla"
#, fuzzy
-#~ msgid "Unable to allocate memory for domain name"
+msgid "Unable to allocate memory for domain name"
#, fuzzy
-#~ msgid "Unable to remove space time dataset register table <%s>"
-#~ msgstr "Impossibile ottenere i dati dalla tabella <%s>"
+msgid "Unable to remove space time dataset register table <%s>"
+msgstr "Impossibile ottenere i dati dalla tabella <%s>"
#, fuzzy
-#~ msgid "Unable to drop table <%s>"
-#~ msgstr "Impossibile copiare la tabella <%s>"
+msgid "Unable to drop table <%s>"
+msgstr "Impossibile copiare la tabella <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Unable to create the space time %s dataset register table for map <%s> "
-#~ "with layer %s"
-#~ msgstr "Impossibile creare il file di intestazione per [%s]"
+msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
+msgstr "Impossibile creare il file di intestazione per [%s]"
#, fuzzy
-#~ msgid "Unable to find map <%s> with layer %s in temporal database"
-#~ msgstr "Impossibile trovare il vettoriale <%s> in <%s>"
+msgid "Unable to find map <%s> with layer %s in temporal database"
+msgstr "Impossibile trovare il vettoriale <%s> in <%s>"
#, fuzzy
-#~ msgid "Unable to read read line %d"
+msgid "Unable to read read line %d"
#, fuzzy
-#~ msgid "Unable to delete feature id %d from vector map <%s>"
-#~ msgstr "impossibile cambiare la directory %s"
+msgid "Unable to delete feature id %d from vector map <%s>"
+msgstr "impossibile cambiare la directory %s"
#, fuzzy
-#~ msgid "Unable to open null device"
-#~ msgstr "Impossibile aprire %s"
+msgid "Unable to open null device"
+msgstr "Impossibile aprire %s"
#, fuzzy
-#~ msgid "The support for OGR vector maps wasn't compiled in"
-#~ msgstr ""
-#~ "categoria di supporto per il file vettoriale [%s] nel mapset [%s] %s"
+msgid "The support for OGR vector maps wasn't compiled in"
+msgstr "categoria di supporto per il file vettoriale [%s] nel mapset [%s] %s"
#, fuzzy
-#~ msgid "End time must be later than start time"
-#~ msgstr "L'Est deve essere più grande dell'Ovest"
+msgid "End time must be later than start time"
+msgstr "L'Est deve essere più grande dell'Ovest"
#, fuzzy
-#~ msgid "None"
-#~ msgstr "nessuno"
+msgid "None"
+msgstr "nessuno"
#, fuzzy
-#~ msgid "Unknown"
-#~ msgstr "sconosciuto"
+msgid "Unknown"
+msgstr "sconosciuto"
#, fuzzy
-#~ msgid "Uknown column <%s>"
-#~ msgstr ""
-#~ "\n"
-#~ "Comando sconosciuto: %d ultimo: %d\n"
+msgid "Uknown column <%s>"
+msgstr ""
+"\n"
+"Comando sconosciuto: %d ultimo: %d\n"
-#~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_malloc: impossibile allocare %lu bytes a %s:%d"
+msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+msgstr "G_malloc: impossibile allocare %lu bytes a %s:%d"
-#~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-#~ msgstr "G_calloc: impossibile allocare %lu * %lu bytes a %s:%d"
+msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+msgstr "G_calloc: impossibile allocare %lu * %lu bytes a %s:%d"
-#~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_realloc: impossibile allocare %lu bytes a %s:%d"
+msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+msgstr "G_realloc: impossibile allocare %lu bytes a %s:%d"
#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#~ msgstr "Impossibile eliminare il file '%s'"
+msgid "Unable to delete file '%s'. Reason: %s"
+msgstr "Impossibile eliminare il file '%s'"
#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#~ msgstr "Impossibile rinominare la directory '%s' a '%s'"
+msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
+msgstr "Impossibile rinominare la directory '%s' a '%s'"
#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
+msgid "Unable to delete prior null-cells file"
#, fuzzy
-#~ msgid "Unable to close the null-cells file"
-#~ msgstr "Impossibile scrivere head nel file plus"
+msgid "Unable to close the null-cells file"
+msgstr "Impossibile scrivere head nel file plus"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to null-cells file [%s]"
-#~ msgstr ""
-#~ "closecell: impossibile spostare %s\n"
-#~ "a file senza valore %s"
+msgid "closecell: can't move [%s] to null-cells file [%s]"
+msgstr ""
+"closecell: impossibile spostare %s\n"
+"a file senza valore %s"
#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#~ msgstr "impossibile trovare un file %s temporaneo nullo"
+msgid "Unable to delete the temporary null-cells file"
+msgstr "impossibile trovare un file %s temporaneo nullo"
#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
+msgid "Unable to delete the empty temporary null-cells file"
#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
+msgid "Unable to delete the prior null-cells file"
#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
-#~ msgstr "Impossibile leggere il file dell'intestazione"
+msgid "Unable to close the 'cell' file"
+msgstr "Impossibile leggere il file dell'intestazione"
#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
+msgid "Unable to delete prior 'fcell' file"
#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
-#~ msgstr "Impossibile eliminare la tabella <%s>"
+msgid "Unable to delete the prior %s file"
+msgstr "Impossibile eliminare la tabella <%s>"
#, fuzzy
-#~ msgid "Unable to close file"
-#~ msgstr "Impossibile aprire il file %s"
+msgid "Unable to close file"
+msgstr "Impossibile aprire il file %s"
#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
+msgid "Unable to delete the prior 'cell' file"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to cell file [%s]"
-#~ msgstr ""
-#~ "closecell: impossilbile spostare %s\n"
-#~ " a file di cellula %s"
+msgid "closecell: can't move [%s] to cell file [%s]"
+msgstr ""
+"closecell: impossilbile spostare %s\n"
+" a file di cellula %s"
#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
-#~ msgstr "Impossibile aprire il file temporaneo"
+msgid "Unable to delete the temporary 'cell' file"
+msgstr "Impossibile aprire il file temporaneo"
#, fuzzy
-#~ msgid "Unable to write quant file!"
-#~ msgstr "Impossibile scrivere il quant file!"
+msgid "Unable to write quant file!"
+msgstr "Impossibile scrivere il quant file!"
#, fuzzy
-#~ msgid "Unable to delete the %s file"
+msgid "Unable to delete the %s file"
#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#~ msgstr "Impossibile scrivere file f_format per mappe CELL"
+msgid "Unable to write f_format file for CELL maps"
+msgstr "Impossibile scrivere file f_format per mappe CELL"
+#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
+#~ msgstr "Impossibile scriver il lockfile %s (Fine dello spazio su disco? Permessi?)"
+#~ msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+#~ msgstr "Impossibile aprire il file <%s> per il sottogruppo <%s> del gruppo <%s@%s>"
+#~ msgid "Unable to open topo file for write <%s>"
+#~ msgstr "Impossibile aprire il file di topologia in scrittura <%s>"
#~ msgid "cell_values_float: xdr_float failed for index %d"
#~ msgstr "cell_values_float: xdr_float lettura non riuscita per l'indice %d"
@@ -9136,12 +8779,8 @@
#~ msgid "Cannot write quant rules for map %s"
#~ msgstr "Non riesco a scrivere le regole quant per la mappa %s"
-#~ msgid ""
-#~ "G_set_window(): projection/zone differs from that of currently open "
-#~ "raster maps"
-#~ msgstr ""
-#~ "G_set_window(): la proiezione/zona differisce da quella del raster "
-#~ "attualmente aperto"
+#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+#~ msgstr "G_set_window(): la proiezione/zona differisce da quella del raster attualmente aperto"
#~ msgid "The floating data range for %s@%s is empty"
#~ msgstr "Il valore floating per l'intervallo %s@%s è vuoto"
@@ -9180,8 +8819,7 @@
#~ msgstr "categoria di supporto per [%s] nel mapset [%s] %s"
#~ msgid "category support for vector map [%s] in mapset [%s] %s"
-#~ msgstr ""
+#~ msgstr "categoria di supporto per il file vettoriale [%s] nel mapset [%s] %s"
#~ msgid "%s not found"
#~ msgstr "%s non trovato"
@@ -9238,12 +8876,8 @@
#~ msgid "Layer number"
#~ msgstr "Numero layer"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
-#~ msgstr ""
-#~ "Un singolo vettoriale può essere connessa a database multiple. Questo "
-#~ "numero determina quale tabella viene usata."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Un singolo vettoriale può essere connessa a database multiple. Questo numero determina quale tabella viene usata."
#~ msgid "Sorry <%s> is not a valid option\n"
#~ msgstr "Mi spiace <%s> non è una opzione valida\n"
@@ -9416,8 +9050,7 @@
#~ msgstr "timestamp specificato non valido per %s mappa %s nel mapset %s"
#~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
+#~ msgstr "Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
#~ msgid "Can not create a new process!"
#~ msgstr "impossibile creare un nuovo processo!"
@@ -9554,9 +9187,7 @@
#~ msgstr "Troppe categorie di riclassificazione per [%s in %s]"
#~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr ""
-#~ "Formato illegale di riclassificazione nel file di intestazione per [%s in "
-#~ "%s]"
+#~ msgstr "Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
#~ msgid "Unable to create header file for [%s in %s]"
#~ msgstr "Impossibile creare il file di intestazione per [%s in %s]"
@@ -9590,12 +9221,8 @@
#~ msgid "Unable to get GIS_LOCK environment variable value"
#~ msgstr "Impossibile ottenere il valore della variabile d'ambiente GIS_LOCK"
-#~ msgid ""
-#~ "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S="
-#~ "(%f,%f)(%f,%f)"
-#~ msgstr ""
-#~ "G_distance_point_to_line_segment: non dovrebbe accadere: code=%d P=(%f,"
-#~ "%f) S=(%f,%f)(%f,%f)"
+#~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgstr "G_distance_point_to_line_segment: non dovrebbe accadere: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#~ msgid "Unable to open raster map <%s@%s>"
#~ msgstr "Impossibile aprire il raster <%s@%s>"
@@ -9603,25 +9230,17 @@
#~ msgid "Unable to find <%s@%s>"
#~ msgstr "Impossibile trovare <%s@%s>"
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different projection than current region. Found "
-#~ "raster map <%s@%s>, should be <%s>."
-#~ msgstr ""
-#~ "Raster <%s@%s> ha una proiezione differente rispetto alla regione "
-#~ "attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
+#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+#~ msgstr "Raster <%s@%s> ha una proiezione differente rispetto alla regione attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
#~ msgstr "Il raster <%s@%s> è in zona (%d) diversa dalla regione in uso (%d)"
#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
#~ msgstr "Il raster <%s@%s>: byte per cella (%d) troppo grande"
-#~ msgid ""
-#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-#~ msgstr ""
-#~ "la mappa <%s@%s> è un link a GDAL, ma GRASS è stato compilato senza il "
-#~ "supporto a GDAL"
+#~ msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr "la mappa <%s@%s> è un link a GDAL, ma GRASS è stato compilato senza il supporto a GDAL"
#~ msgid "<%s>: bad mapset"
#~ msgstr "<%s>: mapset non valido"
@@ -9629,14 +9248,11 @@
#~ msgid "G__open_raster_new(): no temp files available"
#~ msgstr "G__open_raster_new(): non sono disponibili file temporanei"
-#~ msgid ""
-#~ "Unable to write embedded null values for raster map open for random access"
-#~ msgstr ""
-#~ "Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
+#~ msgid "Unable to write embedded null values for raster map open for random access"
+#~ msgstr "Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
#~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-#~ msgstr ""
-#~ "G_set_fp_type(): può essere chiamato solo con FCELL_TYPE o DCELL_TYPE"
+#~ msgstr "G_set_fp_type(): può essere chiamato solo con FCELL_TYPE o DCELL_TYPE"
#~ msgid "Unable to find '%s' in '%s'"
#~ msgstr "Impossibile trovare '%s' in '%s'"
@@ -9644,11 +9260,8 @@
#~ msgid "Unable to open '%s'"
#~ msgstr "Impossibile aprire '%s'"
-#~ msgid ""
-#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
-#~ msgstr ""
-#~ "G_set_quant_rules() può essere chiamato solo per le mappe raster aperte "
-#~ "in lettura"
+#~ msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr "G_set_quant_rules() può essere chiamato solo per le mappe raster aperte in lettura"
#~ msgid "Enter 'list' for the list of available datums\n"
#~ msgstr "Digita 'list' per la lista dei datum disponibili\n"
@@ -9760,9 +9373,7 @@
#~ msgstr "Ã una riclassificazione del raster <%s@%s>"
#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr ""
-#~ "à una riclassificazione del raster <%s@%s> il cui file header non è "
-#~ "valido."
+#~ msgstr "à una riclassificazione del raster <%s@%s> il cui file header non è valido."
#~ msgid " Invalid format."
#~ msgstr "Formato non valido."
@@ -9771,14 +9382,10 @@
#~ msgstr "non riesco a scrivere le informazioni dello storico per [%s]"
#~ msgid "Not enough room in history file to record command line."
-#~ msgstr ""
-#~ "Insufficiente spazio nel file della history per salvare la riga di "
-#~ "comando."
+#~ msgstr "Insufficiente spazio nel file della history per salvare la riga di comando."
#~ msgid "Not enough room in history file for command line (truncated)."
-#~ msgstr ""
-#~ "comando (troncato)."
+#~ msgstr "Insufficiente spazio nel file della history per salvare la riga di comando (troncato)."
#~ msgid "Graphics driver [%s] started"
#~ msgstr "Driver grafico [%s] avviato"
@@ -9792,20 +9399,14 @@
#~ msgid "not implemented"
#~ msgstr "non implementato"
-#~ msgid ""
-#~ "Unable to build spatial index from topology, vector map is not opened at "
-#~ "topo level 2"
-#~ msgstr ""
-#~ "Impossibile costruire l'indice spaziale dalla topologia, il vettoriale "
-#~ "non è aperto al livello 2 della topologia"
+#~ msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+#~ msgstr "Impossibile costruire l'indice spaziale dalla topologia, il vettoriale non è aperto al livello 2 della topologia"
#~ msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
#~ msgstr "BUG (Vect_build_sidx_from_topo): nodo inesistente"
#~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr ""
-#~ "Impossibile aprire il collegamento al database, la mappa non è stata "
-#~ "aperta in modalità di SCRITTURA"
+#~ msgstr "Impossibile aprire il collegamento al database, la mappa non è stata aperta in modalità di SCRITTURA"
#~ msgid "Error in rule on row %d in %s"
#~ msgstr "Errore nella regola alla riga %d in %s"
@@ -9813,19 +9414,11 @@
#~ msgid "Unknown keyword %s in vector head"
#~ msgstr "Parola chiave %s sconosciuta nell'header del vettoriale"
-#~ msgid ""
-#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-#~ "excess)"
-#~ msgstr ""
-#~ "Il file coor del vettoriale <%s@%s> è più grande dell'atteso (%ld bytes "
-#~ "in eccesso)"
+#~ msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+#~ msgstr "Il file coor del vettoriale <%s@%s> è più grande dell'atteso (%ld bytes in eccesso)"
-#~ msgid ""
-#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-#~ "missing)."
-#~ msgstr ""
-#~ "Il file coor del vettoriale <%s@%s> è più piccolo dell'atteso (%ld bytes "
-#~ "mancanti)"
+#~ msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#~ msgstr "Il file coor del vettoriale <%s@%s> è più piccolo dell'atteso (%ld bytes mancanti)"
#~ msgid "Intersections: %5d"
#~ msgstr "Intersezione: %5d"
@@ -9840,9 +9433,7 @@
#~ msgstr "Impossibile aprire il layer <%s>"
#~ msgid "Unable to open category index file for vector map <%s@%s>"
-#~ msgstr ""
-#~ "Impossibile aprire il file di indici di categoria per il vettoriale <%s@"
-#~ "%s>"
+#~ msgstr "Impossibile aprire il file di indici di categoria per il vettoriale <%s@%s>"
#~ msgid "Feature: "
#~ msgstr "Elemento: "
@@ -9856,11 +9447,8 @@
#~ msgid "Matrix is not symmetric!"
#~ msgstr "La matrice non è simmetrica!"
-#~ msgid ""
-#~ "Maximum number of iteration used to solver the linear equation system"
-#~ msgstr ""
-#~ "Numero massimo di iterazioni utilizzato per risolvere il sistema di "
-#~ "equazioni lineari"
+#~ msgid "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr "Numero massimo di iterazioni utilizzato per risolvere il sistema di equazioni lineari"
#~ msgid "test, gpde"
#~ msgstr "test, gpde"
@@ -9899,8 +9487,7 @@
#~ msgstr "G3d_openCellOld: errore in G3d_readHeader"
#~ msgid "G3d_openCellOld: projection does not match window projection"
-#~ msgstr ""
-#~ "G3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
+#~ msgstr "G3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
#~ msgid "G3d_openCellOld: zone does not match window zone"
#~ msgstr "G3d_openCellOld: zona non corrisponde alla zona della finestra"
@@ -9933,19 +9520,13 @@
#~ msgstr "G3d_openCellNew: errore in G3d_fillHeader"
#~ msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-#~ msgstr ""
-#~ "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o "
-#~ "'NULL'.\n"
+#~ msgstr "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o 'NULL'.\n"
#~ msgid "Illegal table map name <%s>. Must start with a letter.\n"
-#~ msgstr ""
-#~ "Nome della tabella della mappa <%s> non valido. Deve iniziare con una "
-#~ "lettera.\n"
+#~ msgstr "Nome della tabella della mappa <%s> non valido. Deve iniziare con una lettera.\n"
#~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-#~ msgstr ""
-#~ "Il nome <%s> non è valido per un vettoriale. Il carattere <%c> non è "
-#~ "permesso.\n"
+#~ msgstr "Il nome <%s> non è valido per un vettoriale. Il carattere <%c> non è permesso.\n"
#~ msgid "Unable to allocate memory for a null buffer"
@@ -9964,8 +9545,7 @@
#~ "Per piacere specifica il nome dell'ellissoide\n"
#~ msgid "Can't create timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
+#~ msgstr "Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
#~ msgstr "timestamp non valido nel file per %s mappa %s nel mapset %s"
@@ -9998,18 +9578,11 @@
#~ msgid "'%s' must be > 0 for '%s'"
#~ msgstr "'%s' deve essere > 0 per '%s'"
-#~ msgid ""
-#~ "Vect_read_line(): feature id %d is not reasonable (max features in vector "
-#~ "map <%s>: %d)"
-#~ msgstr ""
-#~ "Vect_read_line(): l'id %d della feature è irragionevole (numero massimo "
-#~ "di features nel vettoriale <%s>: %d)"
+#~ msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+#~ msgstr "Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
-#~ msgid ""
-#~ "Random read is not supported by OGR for this layer, cannot build support"
-#~ msgstr ""
-#~ "Lettura random non è supportata da OGR per questo layer, non è possibile "
-#~ "costruire supporto"
+#~ msgid "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr "Lettura random non è supportata da OGR per questo layer, non è possibile costruire supporto"
#~ msgid "Feature %d without geometry ignored"
#~ msgstr "La feature %d priva di geometria viene ignorata"
@@ -10047,3 +9620,12 @@
#~ msgid "unable to write quant file!"
+#~ msgid "%d errors in category string."
+#~ msgstr "%d errori nella stringa della categoria"
+#~ msgid "MAPSET %s not found"
+#~ msgstr "MAPSET %s non trovato"
+#~ msgid "LOCATION << %s >> not available"
+#~ msgstr "LOCATION << %s >> non disponibile"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_ja.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ja\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-02-18 14:05+0100\n"
+"POT-Creation-Date: 2013-02-26 14:45+0100\n"
"PO-Revision-Date: 2012-03-05 12:14+0900\n"
"Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -1043,7 +1043,7 @@
msgid "WARNING"
msgstr "è¦å: "
-#: ../lib/init/grass.py:183
+#: ../lib/init/grass.py:186
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1051,120 +1051,120 @@
"ç¨ä¾:\n"
-#: ../lib/init/grass.py:184 ../lib/gis/parser_html.c:140
+#: ../lib/init/grass.py:187 ../lib/gis/parser_html.c:140
#: ../lib/gis/parser_rest.c:146
msgid "Flags"
msgstr "ãã©ãã°"
-#: ../lib/init/grass.py:185
+#: ../lib/init/grass.py:188
msgid "print this help message"
msgstr ""
-#: ../lib/init/grass.py:186
+#: ../lib/init/grass.py:189
msgid "show version information and exit"
msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:190
msgid "create given database, location or mapset if it doesn't exist"
msgstr ""
-#: ../lib/init/grass.py:188
+#: ../lib/init/grass.py:191
msgid "use text based interface"
msgstr ""
-#: ../lib/init/grass.py:189 ../lib/init/grass.py:191
+#: ../lib/init/grass.py:192 ../lib/init/grass.py:194
#, fuzzy
msgid "and set as default"
msgstr "ããã©ã«ãã®è¨±å¯"
-#: ../lib/init/grass.py:190
+#: ../lib/init/grass.py:193
msgid "use $DEFAULT_GUI graphical user interface"
msgstr ""
-#: ../lib/init/grass.py:192
+#: ../lib/init/grass.py:195
msgid "print GRASS configuration parameters"
msgstr ""
-#: ../lib/init/grass.py:193
+#: ../lib/init/grass.py:196
msgid "options: arch,build,compiler,path,revision"
msgstr ""
-#: ../lib/init/grass.py:194 ../lib/gis/parser_html.c:180
+#: ../lib/init/grass.py:197 ../lib/gis/parser_html.c:180
#: ../lib/gis/parser_rest.c:179
msgid "Parameters"
msgstr "ãã©ã¡ã¼ã¿"
-#: ../lib/init/grass.py:195
+#: ../lib/init/grass.py:198
msgid "initial database (path to GIS data)"
msgstr ""
-#: ../lib/init/grass.py:196
+#: ../lib/init/grass.py:199
#, fuzzy
msgid "initial location"
msgstr ""
"\n"
"ç¡å¹ãªæå½±æ³\n"
-#: ../lib/init/grass.py:197
+#: ../lib/init/grass.py:200
msgid "initial mapset"
msgstr ""
-#: ../lib/init/grass.py:198
+#: ../lib/init/grass.py:201
msgid "fully qualified initial mapset directory"
msgstr ""
-#: ../lib/init/grass.py:199
+#: ../lib/init/grass.py:202
msgid "Environment variables relevant for startup"
msgstr ""
-#: ../lib/init/grass.py:200
+#: ../lib/init/grass.py:203
msgid "select GUI (text, gui)"
msgstr ""
-#: ../lib/init/grass.py:201
+#: ../lib/init/grass.py:204
msgid "set wish shell name to override 'wish'"
msgstr ""
-#: ../lib/init/grass.py:202
+#: ../lib/init/grass.py:205
msgid "set html web browser for help pages"
msgstr ""
-#: ../lib/init/grass.py:203
+#: ../lib/init/grass.py:206
msgid "set additional path(s) to local GRASS modules or user scripts"
msgstr ""
-#: ../lib/init/grass.py:204
+#: ../lib/init/grass.py:207
msgid "set additional GISBASE for locally installed GRASS Addons"
msgstr ""
-#: ../lib/init/grass.py:205
+#: ../lib/init/grass.py:208
msgid "shell script to be processed as batch job"
msgstr ""
-#: ../lib/init/grass.py:206
+#: ../lib/init/grass.py:209
msgid "set python shell name to override 'python'"
msgstr ""
-#: ../lib/init/grass.py:228
+#: ../lib/init/grass.py:231
msgid "Unable to create temporary directory <%s>! Exiting."
msgstr "ä»®ã®ç»åãå²ãå½ã¦ããã¾ãã"
-#: ../lib/init/grass.py:306
+#: ../lib/init/grass.py:309
msgid "GUI <%s> not supported in this version"
msgstr "è¦æ±ããããã©ã¼ãããã¯ãã®ãã¼ã¸ã§ã³ã§ã¯ã³ã³ãã¤ã«ããã¾ãã"
-#: ../lib/init/grass.py:444
+#: ../lib/init/grass.py:447
msgid "Searched for a web browser, but none found"
msgstr ""
-#: ../lib/init/grass.py:468
+#: ../lib/init/grass.py:471
#, fuzzy
msgid "Hit RETURN to continue"
msgstr "ç¶è¡ã®ããã«ãªã¿ã¼ã³ãæ¼ã -->"
-#: ../lib/init/grass.py:497
+#: ../lib/init/grass.py:500
msgid ""
"The python command does not work as expected!\n"
"Please check your GRASS_PYTHON environment variable.\n"
@@ -1174,7 +1174,7 @@
"Hit RETURN to continue.\n"
msgstr ""
-#: ../lib/init/grass.py:509
+#: ../lib/init/grass.py:512
msgid ""
"It appears that the X Windows system is not active.\n"
"A graphical based user interface is not supported.\n"
@@ -1183,34 +1183,34 @@
msgstr ""
-#: ../lib/init/grass.py:551 ../lib/init/grass.py:582
+#: ../lib/init/grass.py:554 ../lib/init/grass.py:585
#, fuzzy, python-format
msgid "<%s> is not a valid GRASS location"
msgstr "<%s> ãªãã·ã§ã³ã¯ç¡å¹ã§ã\n"
-#: ../lib/init/grass.py:563
+#: ../lib/init/grass.py:566
#, python-format
msgid "Failed to create new location. The location <%s> already exists."
msgstr ""
-#: ../lib/init/grass.py:580
+#: ../lib/init/grass.py:583
msgid "Missing WIND file fixed"
msgstr ""
-#: ../lib/init/grass.py:594
+#: ../lib/init/grass.py:597
msgid ""
"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
"Interactive startup needed."
msgstr ""
-#: ../lib/init/grass.py:608
+#: ../lib/init/grass.py:611
#, python-format
msgid ""
"Invalid user interface specified - <%s>.\n"
"Use the --help option to see valid interface names."
msgstr ""
-#: ../lib/init/grass.py:621
+#: ../lib/init/grass.py:624
msgid ""
"Error in GUI startup. If necessary, please report this error to the GRASS "
"developers.\n"
@@ -1219,20 +1219,20 @@
"Hit RETURN to continue..."
msgstr ""
-#: ../lib/init/grass.py:631
+#: ../lib/init/grass.py:634
msgid ""
"Received EXIT message from GUI.\n"
"GRASS is not started. Bye."
msgstr ""
-#: ../lib/init/grass.py:634
+#: ../lib/init/grass.py:637
#, fuzzy
msgid ""
"Invalid return code from GUI startup script.\n"
"Please advise GRASS developers of this error."
msgstr "ãã®ã¨ã©ã¼ãGRASSéçºè
ã«å ±åãã¦ãã ãã.\n"
-#: ../lib/init/grass.py:644
+#: ../lib/init/grass.py:647
msgid ""
"Error reading data path information from g.gisenv.\n"
"GISDBASE=%(gisbase)s\n"
@@ -1242,36 +1242,36 @@
"Check the <%s(file)> file."
msgstr ""
-#: ../lib/init/grass.py:727
+#: ../lib/init/grass.py:730
msgid "Path '%s' doesn't exist"
msgstr "%s: ã¨ãªã¢ %d ã¯åå¨ãã¾ãã"
-#: ../lib/init/grass.py:738
+#: ../lib/init/grass.py:741
#, python-format
msgid ""
"%(user)s is currently running GRASS in selected mapset (file %(file)s "
"found). Concurrent use not allowed."
msgstr ""
-#: ../lib/init/grass.py:742
+#: ../lib/init/grass.py:745
#, python-format
msgid ""
"Unable to properly access '%s'.\n"
"Please notify system personel."
msgstr ""
-#: ../lib/init/grass.py:756
+#: ../lib/init/grass.py:759
#, fuzzy
msgid "Building user fontcap..."
msgstr "ã°ã©ãã使ãã¦ãã¾ã..."
-#: ../lib/init/grass.py:790
+#: ../lib/init/grass.py:793
#, fuzzy
msgid "The SHELL variable is not set"
msgstr "GISRC - 夿°ãè¨å®ããã¦ãã¾ãã"
-#: ../lib/init/grass.py:800
+#: ../lib/init/grass.py:803
#, python-format
msgid ""
"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -1280,90 +1280,90 @@
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
-#: ../lib/init/grass.py:805
+#: ../lib/init/grass.py:808
#, python-format
msgid "Change file permission to 'executable' for '%s'"
msgstr ""
-#: ../lib/init/grass.py:807
+#: ../lib/init/grass.py:810
#, python-format
msgid "Executing '%s' ..."
msgstr ""
-#: ../lib/init/grass.py:812
+#: ../lib/init/grass.py:815
#, python-format
msgid "Execution of '%s' finished."
msgstr ""
-#: ../lib/init/grass.py:817
+#: ../lib/init/grass.py:820
#, python-format
msgid "GRASS GUI should be <%s>"
msgstr ""
-#: ../lib/init/grass.py:845
+#: ../lib/init/grass.py:848
#, python-format
msgid "Welcome to GRASS %s"
msgstr ""
-#: ../lib/init/grass.py:854
+#: ../lib/init/grass.py:857
msgid "GRASS homepage:"
msgstr ""
-#: ../lib/init/grass.py:855
+#: ../lib/init/grass.py:858
msgid "This version running through:"
msgstr ""
-#: ../lib/init/grass.py:857
+#: ../lib/init/grass.py:860
#, fuzzy
msgid "Help is available with the command:"
msgstr "ã³ãã³ãã®ãã«ããå©ç¨ã§ãã¾ãã [%s]\n"
-#: ../lib/init/grass.py:858
+#: ../lib/init/grass.py:861
msgid "See the licence terms with:"
msgstr ""
-#: ../lib/init/grass.py:861
+#: ../lib/init/grass.py:864
msgid "If required, restart the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:863
+#: ../lib/init/grass.py:866
msgid "Start the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:865
+#: ../lib/init/grass.py:868
msgid "When ready to quit enter:"
msgstr ""
-#: ../lib/init/grass.py:969
+#: ../lib/init/grass.py:972
msgid "Failed to start shell '%s'"
msgstr "ãã©ã¤ãã¼ <%s> ãã¹ã¿ã¼ãã§ãã¾ãã"
-#: ../lib/init/grass.py:973
+#: ../lib/init/grass.py:976
#, python-format
msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
msgstr ""
-#: ../lib/init/grass.py:974 ../lib/init/grass.py:979
+#: ../lib/init/grass.py:977 ../lib/init/grass.py:982
msgid "Goodbye from GRASS GIS"
msgstr ""
-#: ../lib/init/grass.py:977
+#: ../lib/init/grass.py:980
#, fuzzy
msgid "Done."
msgstr "ç¡ã"
-#: ../lib/init/grass.py:983
+#: ../lib/init/grass.py:986
#, fuzzy
msgid "Cleaning up temporary files..."
msgstr "䏿ãã¡ã¤ã«ãéãã¾ãã"
-#: ../lib/init/grass.py:1025
+#: ../lib/init/grass.py:1028
msgid "Parameter <%s> not supported"
msgstr "OGRãã£ã¼ãã£ã¿ã¤ã %d ã¯ãµãã¼ãããã¾ãã"
-#: ../lib/init/grass.py:1166
+#: ../lib/init/grass.py:1169
#, python-format
msgid ""
"Unable to start GRASS. You can:\n"
@@ -1373,11 +1373,11 @@
"path/to/location/mapset`)"
msgstr ""
-#: ../lib/init/grass.py:1175
+#: ../lib/init/grass.py:1178
msgid "Starting GRASS GIS..."
msgstr ""
-#: ../lib/init/grass.py:1233
+#: ../lib/init/grass.py:1236
#, python-format
msgid "Launching <%s> GUI in the background, please wait..."
msgstr ""
@@ -3925,6 +3925,16 @@
msgid "Unable to list mapsets"
msgstr "å
¥åããããéããã¾ãã"
+#: ../lib/python/script/core.py:1410
+#, fuzzy, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr "���"
+#: ../lib/python/script/core.py:1418
+msgid "Illegal filename <%s>. <%s> not allowed.\n"
+msgstr "���"
#: ../lib/python/script/raster3d.py:89
msgid "An error occurred while running r3.mapcalc"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_ko.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ko\n"
"PO-Revision-Date: 2005-12-22 14:49+0100\n"
"Last-Translator: Huidae Cho\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -986,120 +986,120 @@
msgid "WARNING"
msgstr ""
msgid "Usage"
msgstr ""
msgid "Flags"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Datum %s í
ì´ë¸íì¼ì ì´ ì ììµëë¤"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgstr "ì·¨ì를 ìíìë©´ RETURNì ë르ì¸ì\n"
msgid ""
@@ -1109,7 +1109,7 @@
msgstr ""
msgid ""
@@ -1118,34 +1118,34 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1154,19 +1154,19 @@
msgstr ""
msgid ""
msgstr ""
msgid ""
msgstr ""
msgid ""
@@ -1176,34 +1176,34 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgid ""
@@ -1212,87 +1212,87 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Datum %s í
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
@@ -1302,11 +1302,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3808,6 +3808,16 @@
msgstr "Datum %s í
+#, python-format
+msgstr ""
+#, python-format
+msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_lv.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_lv\n"
"PO-Revision-Date: 2012-08-01 14:37+0300\n"
"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
"Language-Team: Latvian\n"
@@ -1010,7 +1010,7 @@
msgid "WARNING"
msgstr "BRĪDINÄJUMS:"
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1018,7 +1018,7 @@
"Pieleitojums:\n"
#, fuzzy
msgid "Flags"
@@ -1026,40 +1026,40 @@
"\n"
"Karogi:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "lai apstiprinÄtu noklusÄto"
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgid "Parameters"
@@ -1067,77 +1067,77 @@
"\n"
"Parametri:\n"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"nederīga projekcija\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "NeiespÄjami piešķirt atmiÅu\n"
msgstr "PieprasÄ«tais formÄts nav pieejams/iekļauts Å¡ijÄ versijÄ"
msgstr ""
#, fuzzy
msgstr "spied ENTER lai turpinÄtu -->"
msgid ""
@@ -1147,7 +1147,7 @@
msgstr ""
msgid ""
@@ -1156,34 +1156,34 @@
msgstr ""
msgstr "Atvainojiet, <%s> ir nedrīgs parametrs\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1192,20 +1192,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "LÅ«dzu dod ziÅu GRASS izstrÄdÄtÄjiem par Å¡o kļūdu.\n"
msgid ""
@@ -1215,36 +1215,36 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Veidojam topoloģiju... \n"
#, fuzzy
msgstr "GISRC - mainÄ«gais nav norÄdÄ«ts"
#, python-format
msgid ""
@@ -1253,88 +1253,88 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr "GRASS mÄjas lapa:"
msgstr ""
#, fuzzy
msgstr "Nav pieejama palīdzība komandai [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr "Pabeigts."
msgstr "Satīra pagaidu failus..."
msgstr "Ieejas vektors '%s' nav atrasts"
#, python-format
msgid ""
@@ -1344,11 +1344,11 @@
msgstr ""
msgstr "StartÄ GRASS GIS..."
#, python-format
msgstr ""
@@ -3934,6 +3934,16 @@
msgstr "NeisespÄjami atvÄrt %s"
+msgstr "Neatļauts faila nosaukums. Nevar būt '.' vai 'NULL'\n"
+msgstr "Neatļauts faila nosaukums. zīme <%c> nav atļauta.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_ml.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ml\n"
"PO-Revision-Date: 2010-08-24 11:31+0530\n"
"Last-Translator: Mohammed Rashad <rashadkm at gmail.com>\n"
"Language-Team: GRASS Malayalam Translation Team <rashadkm at gmail.com>\n"
@@ -976,119 +976,119 @@
msgid "WARNING"
msgstr ""
msgid "Usage"
msgstr ""
msgid "Flags"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "à´àµà´¬à´¿àµ¾ à´à´£àµà´à´¾à´àµà´à´¾àµ» പറàµà´±àµà´¨àµà´¨à´¿à´²àµà´² <%s>"
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgid ""
@@ -1098,7 +1098,7 @@
msgstr ""
msgid ""
@@ -1107,34 +1107,34 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1143,19 +1143,19 @@
msgstr ""
msgid ""
msgstr ""
msgid ""
msgstr ""
msgid ""
@@ -1165,35 +1165,35 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "à´à´¤àµà´°à´¯à´³à´µàµ പണിയàµà´¨àµà´¨àµ..."
msgstr ""
#, python-format
msgid ""
@@ -1202,87 +1202,87 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "à´¡àµà´°à´¯àµà´µàµà´µàµ¼ à´¤àµà´à´àµà´à´¾àµ» സാധിà´àµà´àµà´¨àµà´¨à´¿à´²àµà´² <%s>"
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr ""
msgstr ""
msgstr "റാസàµà´±àµà´±àµàµ¼ മാപàµà´ªàµ <%s> à´à´£àµà´®à´¾à´¨à´¿à´²àµà´²"
#, python-format
msgid ""
@@ -1292,11 +1292,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3789,6 +3789,16 @@
msgstr "à´µàµà´àµà´±àµà´±àµ¼ à´
à´à´¯àµà´àµà´à´¾àµ» പറàµà´±àµà´¨àµà´¨à´¿à´²àµà´² <%s>"
+msgstr "à´
സാധàµà´µà´¾à´¯ à´àµà´¬à´¿àµ¾ മാപàµà´ªà´¿à´¨àµà´±àµ à´ªàµàµ¼ <%s> '.' à´à´£àµà´à´¾à´à´¾àµ» പാà´à´¿à´²àµà´² \n"
+msgstr "à´
സാധàµà´µà´¾à´¯ à´àµà´¬à´¿àµ¾ മാപàµà´ªà´¿à´¨àµà´±àµ à´ªàµàµ¼ <%s> à´ à´
à´àµà´·à´°à´ à´
à´¨àµà´µà´¦à´¿à´àµà´àµà´¨àµà´¨à´¤à´²àµà´² <%c> \n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_pl.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pl\n"
"PO-Revision-Date: 2012-09-17 22:46+0100\n"
"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: GRASS Translation Team\n"
@@ -1046,119 +1046,119 @@
msgid "WARNING"
msgstr "UWAGA:"
msgid "Usage"
msgstr ""
msgid "Flags"
msgstr "Flagi"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Parametry"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nie można usunÄ
Ä katalogu '%s'"
msgstr "Å»Ä
dany format nie jest skompilowany w tej wersji"
msgstr ""
msgstr ""
msgid ""
@@ -1168,7 +1168,7 @@
msgstr ""
msgid ""
@@ -1177,34 +1177,34 @@
msgstr ""
msgstr "<%s> nie jest poprawnÄ
opcjÄ
\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1213,19 +1213,19 @@
msgstr ""
msgid ""
msgstr ""
msgid ""
msgstr ""
msgid ""
@@ -1235,36 +1235,36 @@
msgstr ""
msgstr "%s: Obszar %d nie istnieje"
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Tworzenie obszarów..."
#, fuzzy
msgstr "GISRC - brak ustawieÅ zmiennych"
#, python-format
msgid ""
@@ -1273,88 +1273,88 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nie można uruchomiÄ sterownika <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "brak"
msgstr ""
msgstr "Obiekty OGR typu %d nie sÄ
obsÅugiwane"
#, python-format
msgid ""
@@ -1364,11 +1364,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3952,6 +3952,16 @@
msgstr "Nie można zamknÄ
Ä mapy wejÅciowej "
+msgstr "Niedozwolona nazwa pliku. Nazwa nie może zawieraÄ '.' lub 'NULL'\n"
+msgstr "Niedozwolona nazwa pliku. Znak <%c> jest niedopuszczalny.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_pt.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pt\n"
"PO-Revision-Date: 2007-06-18 22:26-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
"Language-Team: Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -1047,7 +1047,7 @@
msgid "WARNING"
msgstr "ATENÇÃO: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1055,120 +1055,120 @@
"Uso:\n"
msgid "Flags"
msgstr "Opções"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "para aceitar os valores padrão"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Parâmetros"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"projeção inválida\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "não consegui alocar memória\n"
msgstr "O formato requisitado não foi compilado nesta versão"
msgstr ""
#, fuzzy
msgstr "Pressione ENTER para continuar -->"
msgid ""
@@ -1178,7 +1178,7 @@
msgstr ""
msgid ""
@@ -1187,34 +1187,34 @@
msgstr ""
msgstr "Desculpe <%s> não é uma opção válida\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1223,20 +1223,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "Por favor avise aos desenvolvedores do GRASS sobre este erro.\n"
msgid ""
@@ -1246,36 +1246,36 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Construindo grafo ..."
#, fuzzy
msgstr "GISRC - variável não incializada"
#, python-format
msgid ""
@@ -1284,90 +1284,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "No há ajuda disponível para o comando [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Impossível abrir arquivo %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nenhum"
#, fuzzy
msgstr "não consegui abrir arquivo temporário"
msgstr "Feição OGR tipo %d não suportada)"
#, python-format
msgid ""
@@ -1377,11 +1377,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3986,6 +3986,16 @@
msgstr "Impossível fechar mapa de entrada"
+msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
+msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_pt_br.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pt_br\n"
"PO-Revision-Date: 2007-05-20 10:44-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
"Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -1028,7 +1028,7 @@
msgid "WARNING"
msgstr "ATENÇÃO: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1036,7 +1036,7 @@
"Uso:\n"
#, fuzzy
msgid "Flags"
@@ -1044,40 +1044,40 @@
"\n"
"Flags:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgid "Parameters"
@@ -1085,77 +1085,77 @@
"\n"
"Parâmetros:\n"
msgstr ""
#, fuzzy
msgstr ""
"\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgid ""
@@ -1165,7 +1165,7 @@
msgstr ""
msgid ""
@@ -1174,34 +1174,34 @@
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1210,20 +1210,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgid ""
@@ -1233,36 +1233,36 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Criando topologia ...\n"
#, fuzzy
#, python-format
msgid ""
@@ -1271,90 +1271,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "não foi possível abrir o arquivo %s em %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nenhum"
#, fuzzy
#, python-format
msgid ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3927,6 +3927,16 @@
msgstr "não consegui abrir [%s]"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_ru.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ru\n"
"PO-Revision-Date: 2009-01-27 22:58-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -1039,7 +1039,7 @@
msgid "WARNING"
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1047,120 +1047,120 @@
"ÐÑполÑзование:\n"
msgid "Flags"
msgstr "Флаги"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "ÑÑÐ¾Ð±Ñ ÑÑÑановиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "ÐаÑамеÑÑÑ"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"невеÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Ðевозможно ÑазмеÑÑиÑÑ Ð²Ñеменное изобÑажение"
msgstr "ÐапÑаÑиваемÑй ÑоÑÐ¼Ð°Ñ Ð´Ð»Ñ ÑÑой веÑÑии не ÑкомпилиÑован."
msgstr ""
#, fuzzy
msgstr "нажмиÑе RETURN Ð´Ð»Ñ Ð¿ÑÐ¾Ð´Ð¾Ð»Ð¶ÐµÐ½Ð¸Ñ -->"
msgid ""
@@ -1170,7 +1170,7 @@
msgstr ""
msgid ""
@@ -1179,34 +1179,34 @@
msgstr ""
msgstr "ÐзвиниÑе, опÑÐ¸Ñ <%s> невеÑна\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1215,20 +1215,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "СообÑиÑе ÑазÑабоÑÑикам GRASS об ÑÑой оÑибке.\n"
msgid ""
@@ -1238,36 +1238,36 @@
msgstr ""
msgstr "%s: Ðолигон %d не ÑÑÑеÑÑвÑеÑ"
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "ÐоÑÑÑоение гÑаÑа..."
#, fuzzy
msgstr "GISRC - пеÑÐµÐ¼ÐµÐ½Ð½Ð°Ñ Ð½Ðµ ÑÑÑановлена"
#, python-format
msgid ""
@@ -1276,90 +1276,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "ÐÐµÑ ÑпÑавки Ð´Ð»Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Ðевозможен запÑÑк дÑайвеÑа <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "неÑ"
#, fuzzy
msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÑеменнÑй Ñайл"
msgstr "Ñип даннÑÑ
OGR %d не поддеÑживаеÑÑÑ"
#, python-format
msgid ""
@@ -1369,11 +1369,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3988,6 +3988,16 @@
msgstr "Ðевозможно закÑÑÑÑ Ð¸ÑÑ
однÑй Ñлой"
+msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ Ñайла. Ðе должно бÑÑÑ '.' или 'NULL'\n"
+msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ Ñайла. Ðнак <%c> недопÑÑÑим.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_sl.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_sl\n"
"PO-Revision-Date: 2005-04-26 09:38+0200\n"
"Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
"Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
@@ -1006,7 +1006,7 @@
msgid "WARNING"
msgstr "OPOZORILO: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1014,7 +1014,7 @@
"Uporaba:\n"
#, fuzzy
msgid "Flags"
@@ -1022,40 +1022,40 @@
"\n"
"Izbire:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "za izbrati privzeto"
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgid "Parameters"
@@ -1063,77 +1063,77 @@
"\n"
"Parametri:\n"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"neveljavna projekcija\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nezmo¾en dodeliti spomin\n"
msgstr "Zahtevani format ni bil preveden v tej verziji"
msgstr ""
#, fuzzy
msgstr "pritisnite RETURN za nadaljevanje -->"
msgid ""
@@ -1143,7 +1143,7 @@
msgstr ""
msgid ""
@@ -1152,34 +1152,34 @@
msgstr ""
msgstr "Oprostite <%s> ni veljavna mo¾nost\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1188,20 +1188,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "Prosim sporoèite razvijalcem GRASS-a o tej napaki.\n"
msgid ""
@@ -1211,36 +1211,36 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Gradim topologijo ...\n"
#, fuzzy
msgstr "GISRC - spremenljivka ni nastavljena"
#, python-format
msgid ""
@@ -1249,90 +1249,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nezmo¾en odpreti datoteko %s v %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "ga ni"
#, fuzzy
msgstr "Ne morem odpreti temp datoteke"
msgstr "Vneseni vektor '%s' ni bil najden"
#, python-format
msgid ""
@@ -1342,11 +1342,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3916,6 +3916,16 @@
msgstr "Ne morem odpreti %s"
+msgstr "Neveljavno ime datoteke. Ne more biti '.' ali 'NULL'\n"
+msgstr "Neveljavno ime. Znak <%c> je prepovedan."
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_th.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_th\n"
"PO-Revision-Date: 2008-01-05 15:19+0700\n"
"Last-Translator: man <mansv68 at yahoo.co.th>\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -1049,7 +1049,7 @@
msgid "WARNING"
msgstr "à¸à¸³à¹à¸à¸·à¸à¸: "
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1057,120 +1057,120 @@
"วิà¸à¸µà¹à¸à¹:\n"
msgid "Flags"
msgstr "à¸à¸"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "à¹à¸à¹à¸à¹à¸²à¸à¸±à¹à¸à¸à¹à¸"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "à¸à¸±à¸§à¹à¸à¸£"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"à¸à¸²à¸£à¸à¸²à¸¢à¸ าà¸à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸à¸à¸«à¸à¹à¸§à¸¢à¸à¸§à¸²à¸¡à¸à¸³à¹à¸à¹\n"
msgstr "รูà¸à¹à¸à¸à¸à¸µà¹à¸à¹à¸à¸à¸à¸²à¸£à¸¢à¸±à¸à¹à¸à¹à¹à¸¡à¹à¹à¸à¹à¹à¸ รุà¹à¸à¸à¸µà¹"
msgstr ""
#, fuzzy
msgstr "à¸à¸ RETURN à¹à¸à¸·à¹à¸à¸à¸³à¹à¸à¸´à¸à¸à¸²à¸£à¸à¹à¸ -->"
msgid ""
@@ -1180,7 +1180,7 @@
msgstr ""
msgid ""
@@ -1189,34 +1189,34 @@
msgstr ""
msgstr "à¹à¸ªà¸µà¸¢à¹à¸ <%s> à¹à¸¡à¹à¸¡à¸µà¸à¸¢à¸¹à¹à¹à¸à¹à¸à¸·à¹à¸à¸à¹à¸\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1225,20 +1225,20 @@
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "à¹à¸à¸£à¸à¹à¸à¹à¸à¸à¸à¹à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸«à¹à¸à¸±à¸ à¸à¸µà¸à¸±à¸à¸à¸² GRASS\n"
msgid ""
@@ -1248,36 +1248,36 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "สรà¹à¸²à¸ graph ..."
#, fuzzy
msgstr "GISRC - à¹à¸¡à¹à¹à¸à¹à¸à¸³à¸«à¸à¸à¸à¹à¸²à¸à¸±à¸§à¹à¸à¸¥"
#, python-format
msgid ""
@@ -1286,90 +1286,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸§à¸²à¸¡à¸à¹à¸§à¸¢à¹à¸«à¸¥à¸·à¸à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¸µà¹ [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸£à¸°à¸à¸¸à¸ªà¸ าà¸à¹à¸à¸¥à¹ <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "none"
#, fuzzy
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ temp à¹à¸à¸¥à¹"
msgstr "à¸à¸à¸´à¸à¸à¹à¸à¸¡à¸¹à¸¥ OGR %d à¹à¸¡à¹à¸£à¸à¸à¸£à¸±à¸)"
#, python-format
msgid ""
@@ -1379,11 +1379,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3987,6 +3987,16 @@
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸´à¸à¸à¸²à¸£à¸à¸³à¹à¸à¹à¸²à¹à¸à¸à¸à¸µà¹"
+msgstr "à¸à¸·à¸à¹à¸à¸¥à¹à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸ à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¹ '.' หรืภ'NULL'\n"
+msgstr "à¸à¸·à¸à¹à¸à¸¥à¹à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸ à¸à¸±à¸§à¸à¸±à¸à¸©à¸£ <%c> à¹à¸à¹à¹à¸¡à¹à¹à¸à¹\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_tr.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasslibs_tr\n"
"PO-Revision-Date: 2010-11-08 15:14+0200\n"
"Last-Translator: Saban Safak <ssafak at cvm.com.tr>\n"
"Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -989,7 +989,7 @@
msgid "WARNING"
msgstr "UYARI:"
#, fuzzy
msgid "Usage"
msgstr ""
@@ -997,120 +997,120 @@
"Kullanım:\n"
msgid "Flags"
msgstr "Flamalar"
msgstr "yardım mesajını yazdır"
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "varsayılanı kabul et"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Parametreler"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"geçersiz projeksiyon\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "'%s' dizini kaldırılamıyor "
msgstr "İstenen format bu sürümde derlenmedi."
msgstr ""
#, fuzzy
msgstr "Devam etmek için ENTER'a basın -->"
msgid ""
@@ -1120,7 +1120,7 @@
msgstr ""
msgid ""
@@ -1129,34 +1129,34 @@
msgstr ""
msgstr "Ãzgünüm <%s> geçerli bir seçenek deÄil\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1165,19 +1165,19 @@
msgstr ""
msgid ""
msgstr ""
msgid ""
msgstr ""
msgid ""
@@ -1187,36 +1187,36 @@
msgstr ""
msgstr "%s: Alan %d mevcut deÄil"
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Grafik oluÅturuluyor..."
#, fuzzy
msgstr "GISRC - deÄiÅken ayarlanmadı"
#, python-format
msgid ""
@@ -1225,90 +1225,90 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "[%s] komutu için yardım yoktur\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "<%s> Sürücüsü baÅlatılamıyor"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "hiçbiri"
#, fuzzy
msgstr "Geçici dosya açılamıyor"
msgstr "%d OGR obje tipi desteklenmiyor"
#, python-format
msgid ""
@@ -1318,11 +1318,11 @@
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3870,6 +3870,16 @@
msgstr "Girdi haritası kapatılamıyor"
+msgstr "Uygun olmayan dosya adı. '.' veya 'NULL' olmamalı\n"
+msgstr "Uygun olmayan dosya adı. <%c> karakteri kullanılamaz.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_vi.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_vi\n"
"PO-Revision-Date: 2010-08-27 11:18+0700\n"
"Last-Translator: \n"
"Language-Team: American English <kde-i18n-doc at kde.org>\n"
msgid "WARNING"
msgstr "CẢNH BÃO: "
#, fuzzy
msgid "Usage"
msgstr ""
"Cách dùng:\n"
"â© "
msgid "Flags"
msgstr "Các cá»"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Äá» chấp nháºn mặc Äá»nh"
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "Các tham sá»"
msgstr ""
#, fuzzy
msgstr ""
"\n"
"phép chiếu không hợp lá»\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Không thỠcấp phát hình ảnh tạm"
msgstr "Äá»nh dạng ÄÆ°á»£c yêu cầu không ÄÆ°á»£c biên dá»ch trong phiên bản nà y"
msgstr ""
#, fuzzy
msgstr "bấm RETURN Äá» tiếp tục -->"
msgid ""
msgstr ""
msgid ""
msgstr ""
msgstr "Xin lá»i <%s> không phải là tùy chá»n hợp lá»\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgid ""
msgstr "Vui lòng báo cho các nhà phát triá»n GRASS vá» lá»i nà y.\n"
msgid ""
msgstr ""
msgstr "%s: Vùng %d không tá»n tại"
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "Äang xây dá»±ng biá»u Äá»..."
#, fuzzy
msgstr "GISRC - biến không ÄÆ°á»£c thiết láºp"
#, python-format
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Không có trợ giúp cho lá»nh [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Không thá» khá»i Äá»ng trình Äiá»u khiá»n <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "không có"
#, fuzzy
msgstr "Không thá» má» táºp tin tạm"
msgstr "Kiá»u Äá»i tượng OGR %d không ÄÆ°á»£c há» trợ"
#, python-format
msgid ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3998,6 +3998,16 @@
msgstr "Không thá» Äóng bản Äá» Äầu và o"
+msgstr "Tên táºp tin không hợp lá». Không thá» là '.' hay 'NULL'\n"
+msgstr "Tên táºp tin không hợp lá». Ký tá»± <%c> không ÄÆ°á»£c phép.\n"
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grasslibs_zh.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_zh\n"
"PO-Revision-Date: 2007-12-13 16:42+0100\n"
"Last-Translator: Su Yongheng <night2008 at gmail.com>\n"
"Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
@@ -1051,7 +1051,7 @@
msgid "WARNING"
msgstr "è¦åï¼"
#, fuzzy
msgid "Usage"
msgstr ""
@@ -1059,115 +1059,115 @@
"ç¨æ³ï¼\n"
msgid "Flags"
msgstr "æ è®°ï¼"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Parameters"
msgstr "åæ°ï¼"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "æ æ³åé
å
å\n"
msgstr "å¨è¿ä¸çæ¬ä¸æ²¡æç¼è¯è¯·æ±çæ ¼å¼"
msgstr ""
msgstr ""
msgid ""
@@ -1177,7 +1177,7 @@
msgstr ""
msgid ""
@@ -1186,34 +1186,34 @@
msgstr ""
msgstr "对ä¸èµ·ï¼<%s>䏿¯ææçé项\n"
#, python-format
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
msgid ""
"developers.\n"
@@ -1222,19 +1222,19 @@
msgstr ""
msgid ""
msgstr ""
msgid ""
msgstr ""
msgid ""
@@ -1244,36 +1244,36 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
#, fuzzy
msgstr "å»ºç«ææ...\n"
#, fuzzy
msgstr "GISRC - åéæªè®¾ç½®"
#, python-format
msgid ""
@@ -1282,88 +1282,88 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "æ æ³æå¼æä»¶ %s å¨ %s ä¸"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "æ "
msgstr ""
msgstr "䏿¯æç OGR è¦ç´ ç±»å %d"
#, python-format
msgid ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -3992,6 +3992,16 @@
msgstr "æ æ³æå¼%s"
+msgstr "éæ³çæä»¶åãä¸è½æ¯'.'æ'NULL'\n"
+msgstr "éæ³çæä»¶åãä¸å
许å
å«å符<%c>ã\n"
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grassmods_ar.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ar\n"
"PO-Revision-Date: 2005-03-09 12:50+0100\n"
"Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
"Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -232,7 +232,7 @@
#: ../vector/v.distance/main.c:87 ../vector/v.to.db/main.c:36
#: ../vector/v.mkgrid/main.c:70 ../vector/v.net.bridge/main.c:47
#: ../vector/v.build.polylines/main.c:112 ../vector/v.delaunay/main.c:85
-#: ../vector/v.qcount/main.c:60 ../vector/v.category/main.c:74
+#: ../vector/v.qcount/main.c:60 ../vector/v.category/main.c:75
#: ../vector/v.net.flow/main.c:58 ../vector/v.in.region/main.c:38
#: ../vector/v.buffer/main.c:223 ../vector/v.surf.rst/main.c:142
#: ../vector/v.transform/main.c:70 ../vector/v.reclass/main.c:67
@@ -481,7 +481,7 @@
msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ¥ØªØµØ§Ù Ø¨ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª\n"
#: ../doc/vector/v.example/main.c:126 ../display/d.vect/opt.c:147
-#: ../display/d.thematic.area/main.c:205 ../vector/v.edit/select.c:506
+#: ../display/d.thematic.area/main.c:204 ../vector/v.edit/select.c:506
#: ../vector/v.db.connect/main.c:215 ../vector/v.db.connect/main.c:281
#: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
#: ../vector/v.drape/main.c:250 ../vector/v.out.vtk/writeVTK.c:644
@@ -3565,7 +3565,7 @@
msgid "One coordinate pair per line, please"
msgstr "Ø§ØØ¯Ø§Ø«Ù Ø§ÙØ´Ø±Ù, Ø§ÙØ£Ø³Ø§Ø³ ÙÙ Ù
Ø±ÙØ² Ø§ÙØ®Ø±Ùطة"
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:75
+#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
#, fuzzy
msgid "category"
msgstr "عدد ÙÙØ§Ø· Ø§ÙØ¥Ø³ØªÙÙØ§Ø¡"
@@ -5576,7 +5576,7 @@
#: ../raster/r.spread/main.c:153 ../raster/r.spread/main.c:161
#: ../raster/r.spread/main.c:169
#, fuzzy
-msgid "Input_maps"
+msgid "Input maps"
msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
#: ../raster/r.spread/main.c:120
@@ -5635,7 +5635,7 @@
#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
#: ../raster/r.spread/main.c:230
#, fuzzy
-msgid "Output_maps"
+msgid "Output maps"
msgstr "Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
#: ../raster/r.spread/main.c:216
@@ -8801,8 +8801,9 @@
#: ../raster/r.horizon/main.c:255 ../raster/r.horizon/main.c:263
#: ../raster/simwe/r.sim.sediment/main.c:175
#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Input_options"
-msgstr ""
+#, fuzzy
+msgid "Input options"
+msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ "
#: ../raster/r.sun/main.c:257
msgid ""
@@ -8890,8 +8891,9 @@
#: ../raster/r.horizon/main.c:272 ../raster/r.horizon/main.c:282
#: ../raster/r.horizon/main.c:290 ../raster/simwe/r.sim.sediment/main.c:168
#: ../raster/simwe/r.sim.water/main.c:216
-msgid "Output_options"
-msgstr ""
+#, fuzzy
+msgid "Output options"
+msgstr "Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
#: ../raster/r.sun/main.c:393
msgid ""
@@ -8956,114 +8958,115 @@
msgstr ""
#: ../raster/r.sun/main.c:504
-msgid "Incorporate the shadowing effect of terrain"
+#, fuzzy
+msgid "Do not incorporate the shadowing effect of terrain"
msgstr "Ù
Ø´Ø§Ø±ÙØ© عاÙ
Ù Ø§ÙØ¸Ù ÙÙØªØ¶Ø§Ø±Ùس"
#: ../raster/r.sun/main.c:509
msgid "Use the low-memory version of the program"
msgstr ""
-#: ../raster/r.sun/main.c:556
+#: ../raster/r.sun/main.c:550
msgid "You must give the longitude raster if you use civil time"
msgstr ""
-#: ../raster/r.sun/main.c:559
+#: ../raster/r.sun/main.c:553
#, fuzzy
msgid "Error reading civil time zone value"
msgstr "خطا ÙÙ Ù
ØØ§ÙÙØ© ÙØ±Ø§Ø¡Ø© Ù
ÙÙ ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª dbmscap\n"
-#: ../raster/r.sun/main.c:562
+#: ../raster/r.sun/main.c:556
#, fuzzy
msgid "Invalid civil time zone value"
msgstr "ØªÙØ±Ùر Ø§ÙØ¥ØØµØ§Ø¦Ùات ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
-#: ../raster/r.sun/main.c:587
+#: ../raster/r.sun/main.c:581
msgid "insol_time and incidout are incompatible options"
msgstr ""
-#: ../raster/r.sun/main.c:592
+#: ../raster/r.sun/main.c:586
#, fuzzy
msgid "Error reading time step size"
msgstr "خطا ÙÙ Ù
ØØ§ÙÙØ© ÙØ±Ø§Ø¡Ø© Ù
-#: ../raster/r.sun/main.c:594
+#: ../raster/r.sun/main.c:588
#, fuzzy
msgid "Invalid time step size"
msgstr "Ù
Ø³Ø§ØØ©: %d عدد Ø§ÙØ¬Ø²Ø±: %d\n"
-#: ../raster/r.sun/main.c:598
+#: ../raster/r.sun/main.c:592
#, fuzzy
msgid "Error reading horizon step size"
msgstr "%s ÙÙ
ÙØªÙ
Ø§ÙØ¹Ø«Ùر عÙÙ Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
-#: ../raster/r.sun/main.c:602
+#: ../raster/r.sun/main.c:596
msgid "The horizon step size must be greater than 0."
msgstr ""
-#: ../raster/r.sun/main.c:605
+#: ../raster/r.sun/main.c:599
msgid ""
"If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr ""
-#: ../raster/r.sun/main.c:611
+#: ../raster/r.sun/main.c:605
msgid "Time and insol_time are incompatible options"
msgstr ""
-#: ../raster/r.sun/main.c:613
+#: ../raster/r.sun/main.c:607
msgid ""
"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
"time"
msgstr ""
-#: ../raster/r.sun/main.c:618
+#: ../raster/r.sun/main.c:612
msgid "incidout requires time parameter to be set"
msgstr ""
-#: ../raster/r.sun/main.c:620
+#: ../raster/r.sun/main.c:614
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr ""
-#: ../raster/r.sun/main.c:666
+#: ../raster/r.sun/main.c:660
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
-#: ../raster/r.sun/main.c:679
+#: ../raster/r.sun/main.c:673
msgid ""
"If you want to save memory and to use shadows, you must use pre-calculated "
"horizons."
msgstr ""
-#: ../raster/r.sun/main.c:724 ../display/d.where/main.c:107
+#: ../raster/r.sun/main.c:718 ../display/d.where/main.c:107
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
msgstr ""
-#: ../raster/r.sun/main.c:728 ../raster/r.horizon/main.c:476
+#: ../raster/r.sun/main.c:722 ../raster/r.horizon/main.c:476
#: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:250
#: ../general/g.region/printwindow.c:506 ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
msgstr ""
-#: ../raster/r.sun/main.c:732 ../raster/r.horizon/main.c:480
+#: ../raster/r.sun/main.c:726 ../raster/r.horizon/main.c:480
#: ../ps/ps.map/do_geogrid.c:272 ../display/d.where/main.c:113
#: ../display/d.grid/plot.c:335 ../general/g.region/printwindow.c:253
#: ../general/g.region/printwindow.c:509 ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
msgstr ""
-#: ../raster/r.sun/main.c:742 ../raster/r.horizon/main.c:490
+#: ../raster/r.sun/main.c:736 ../raster/r.horizon/main.c:490
#: ../imagery/i.latlong/main.c:114 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
#: ../display/d.grid/plot.c:342 ../display/d.grid/plot.c:369
msgid "Unable to set up lat/long projection parameters"
msgstr ""
-#: ../raster/r.sun/main.c:746
+#: ../raster/r.sun/main.c:740
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
msgstr ""
-#: ../raster/r.sun/main.c:751
+#: ../raster/r.sun/main.c:745
msgid "Both latin and longin raster maps must be given, or neither"
msgstr ""
@@ -19508,7 +19511,7 @@
msgid "illegal maploc request"
msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
-#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:219
+#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
msgid "illegal copies request"
msgstr ""
@@ -19869,12 +19872,12 @@
msgid "Number of copies to print"
-#: ../ps/ps.map/main.c:204
+#: ../ps/ps.map/main.c:205
#, fuzzy, c-format
msgid "Unable to open file '%s': %s"
msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
-#: ../ps/ps.map/main.c:212 ../ps/ps.map/main.c:231
+#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
#: ../vector/v.univar/main.c:139 ../vector/v.to.db/parse.c:141
#: ../vector/v.to.db/parse.c:144
#, fuzzy, c-format
@@ -19883,7 +19886,7 @@
"\t(%s)"
msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© "
-#: ../ps/ps.map/main.c:272
+#: ../ps/ps.map/main.c:273
#, c-format
msgid "PostScript file '%s' successfully written."
msgstr ""
@@ -20003,7 +20006,7 @@
#: ../display/d.grid/main.c:233 ../display/d.his/main.c:118
#: ../display/d.geodesic/main.c:96 ../display/d.labels/main.c:117
#: ../display/d.colortable/main.c:141 ../display/d.rast/main.c:97
-#: ../display/d.thematic.area/main.c:371 ../display/d.fontlist/main.c:54
+#: ../display/d.thematic.area/main.c:370 ../display/d.fontlist/main.c:54
#: ../display/d.graph/main.c:98 ../display/d.rgb/main.c:82
#: ../display/d.path/main.c:154 ../display/d.rast.arrow/main.c:224
#: ../display/d.legend/main.c:294 ../display/d.font/main.c:86
@@ -20016,12 +20019,12 @@
msgstr "%s - ÙÙÙ ØºÙØ± Ù
عرÙÙ\n"
#: ../display/d.vect/opt.c:143 ../display/d.what.vect/what.c:413
-#: ../display/d.thematic.area/main.c:201 ../vector/v.db.connect/main.c:175
+#: ../display/d.thematic.area/main.c:200 ../vector/v.db.connect/main.c:175
#, fuzzy, c-format
msgid "Database connection not defined"
msgstr "ÙÙ
ÙØªÙ
-#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:210
+#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:209
#: ../vector/v.convert/att.c:74 ../db/db.select/main.c:73
#: ../db/db.execute/main.c:76 ../db/db.tables/main.c:47
#: ../db/db.describe/main.c:56
@@ -20095,8 +20098,8 @@
#: ../display/d.vect/main.c:80 ../display/d.vect/main.c:105
#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
#: ../display/d.vect/main.c:314 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:135
-#: ../display/d.thematic.area/main.c:138 ../vector/v.net.centrality/main.c:121
+#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:137 ../vector/v.net.centrality/main.c:121
#: ../vector/v.net.centrality/main.c:123 ../vector/v.in.ogr/main.c:146
#: ../vector/v.in.ogr/main.c:159 ../vector/v.in.ogr/main.c:164
#: ../vector/v.in.ogr/main.c:173 ../vector/v.in.ogr/main.c:189
@@ -20111,8 +20114,8 @@
#: ../vector/v.extract/main.c:100 ../vector/v.extract/main.c:106
#: ../vector/v.extract/main.c:109 ../vector/v.extract/main.c:112
#: ../vector/v.extract/main.c:122 ../vector/v.extract/main.c:132
-#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:83
-#: ../vector/v.category/main.c:86 ../vector/v.category/main.c:90
+#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:84
+#: ../vector/v.category/main.c:87 ../vector/v.category/main.c:91
#: ../vector/v.buffer/main.c:232 ../vector/v.buffer/main.c:235
#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:243
#: ../vector/v.surf.rst/main.c:173 ../vector/v.surf.rst/main.c:185
@@ -21089,7 +21092,7 @@
msgid "Maximum value used for bar plot reference"
msgstr ""
-#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:164
+#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:163
msgid "Create legend information and send to stdout"
msgstr ""
@@ -21835,126 +21838,126 @@
msgid "Colors (one per class)."
msgstr ""
-#: ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:133
msgid "Layer number. If -1, all layers are displayed."
msgstr ""
-#: ../display/d.thematic.area/main.c:144 ../display/d.thematic.area/main.c:152
+#: ../display/d.thematic.area/main.c:143 ../display/d.thematic.area/main.c:151
#, fuzzy
msgid "Boundaries"
msgstr "ÙÙ
ÙØªÙ
ØªØØ¯ÙØ« Ø§ÙØØ¯ÙØ¯"
-#: ../display/d.thematic.area/main.c:145
+#: ../display/d.thematic.area/main.c:144
msgid "Boundary width"
msgstr ""
-#: ../display/d.thematic.area/main.c:151
+#: ../display/d.thematic.area/main.c:150
msgid "Boundary color"
msgstr ""
-#: ../display/d.thematic.area/main.c:158
+#: ../display/d.thematic.area/main.c:157
msgid "File in which to save d.graph instructions for legend display"
msgstr ""
-#: ../display/d.thematic.area/main.c:169
+#: ../display/d.thematic.area/main.c:168
msgid ""
"When printing legend info , include extended statistical info from "
"classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:173
+#: ../display/d.thematic.area/main.c:172
#, fuzzy
msgid "Do not draw map, only output the legend"
msgstr "عدÙ
ضبط اÙÙ
خرج باÙÙ
دخÙ"
-#: ../display/d.thematic.area/main.c:192
+#: ../display/d.thematic.area/main.c:191
#, fuzzy, c-format
msgid "%s: You must build topology on vector map. Run v.build."
msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
-#: ../display/d.thematic.area/main.c:199
+#: ../display/d.thematic.area/main.c:198
#, fuzzy
msgid "'layer' must be > 0"
msgstr "Ø·Ø¨ÙØªÙÙ ÙØ¬Ø¨ ØªØØ¯ÙدÙÙ
-#: ../display/d.thematic.area/main.c:225
+#: ../display/d.thematic.area/main.c:224
#, fuzzy, c-format
msgid "Data (%s) not numeric. Column must be numeric."
msgstr "ÙÙ
ØªÙØ¬Ø¯<%s>Ø§ÙØ®Ø±Ùطة اÙÙÙÙØªÙØ±ÙØ©"
-#: ../display/d.thematic.area/main.c:229
+#: ../display/d.thematic.area/main.c:228
#: ../display/d.thematic.area/plot1.c:134
#: ../display/d.thematic.area/plot1.c:162
#, fuzzy, c-format
msgid "Cannot select data (%s) from table"
msgstr "ÙÙ
ÙÙ
ÙÙ Ø§Ø®ØªÙØ§Ø± Ø§ÙØ¨ÙØ§ÙØ§Øª Ù
Ù Ø§ÙØ¬Ø¯ÙÙ"
-#: ../display/d.thematic.area/main.c:292
+#: ../display/d.thematic.area/main.c:291
#, fuzzy, c-format
msgid "Unknown color: [%s]"
عرÙÙ\n"
-#: ../display/d.thematic.area/main.c:303
+#: ../display/d.thematic.area/main.c:302
msgid ""
"You gave both manual breaks and a classification algorithm or a number of "
"classes. The manual breaks have precedence and will thus be used."
msgstr ""
-#: ../display/d.thematic.area/main.c:340
+#: ../display/d.thematic.area/main.c:339
msgid "You must either give classbreaks or a classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:353
+#: ../display/d.thematic.area/main.c:352
#, c-format
msgid ""
"Not enough colors or error in color specifications.\n"
"Need %i colors."
msgstr ""
-#: ../display/d.thematic.area/main.c:358
+#: ../display/d.thematic.area/main.c:357
#, fuzzy, c-format
msgid "Error interpreting color %s"
msgstr "%s ÙÙ
ÙØªÙ
-#: ../display/d.thematic.area/main.c:377
+#: ../display/d.thematic.area/main.c:376
#, fuzzy
msgid "Plotting ..."
msgstr "Ø§ÙØªÙÙÙØ¹ ..."
-#: ../display/d.thematic.area/main.c:384
+#: ../display/d.thematic.area/main.c:383
#, fuzzy
msgid ""
"The bounding box of the map is outside the current region, nothing drawn."
msgstr " Ø§ÙØµÙدÙ٠اÙÙ
ØÙØ· ÙÙØ®Ø±Ùطة خارج اÙÙ
ÙØ·ÙØ© Ø§ÙØØ§ÙÙØ© ÙÙ ÙØªÙ
عرض Ø´ÙØ¦\n"
-#: ../display/d.thematic.area/main.c:434
+#: ../display/d.thematic.area/main.c:433
#, fuzzy, c-format
msgid ""
"\n"
"Total number of records: %.0f\n"
msgstr "Ù
-#: ../display/d.thematic.area/main.c:436
+#: ../display/d.thematic.area/main.c:435
#, c-format
msgid "Classification of %s into %i classes\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:438 ../vector/v.class/main.c:202
+#: ../display/d.thematic.area/main.c:437 ../vector/v.class/main.c:202
#, c-format
msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:440 ../vector/v.class/main.c:203
+#: ../display/d.thematic.area/main.c:439 ../vector/v.class/main.c:203
#, fuzzy, c-format
msgid "Mean: %f\tStandard deviation = %f\n"
msgstr "Ø§ÙØ¥ÙØØ±Ø§Ù اÙÙ
Ø¹ÙØ§Ø±Ù"
-#: ../display/d.thematic.area/main.c:444
+#: ../display/d.thematic.area/main.c:443
#, c-format
msgid "Last chi2 = %f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:447 ../vector/v.class/main.c:210
+#: ../display/d.thematic.area/main.c:446 ../vector/v.class/main.c:210
#, c-format
msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
@@ -22397,12 +22400,12 @@
msgid "Input map contains no data"
Ø¯Ø®ÙØ© ØØ§ÙÙØ© Ø§ÙØ®Ø·ÙØ·"
-#: ../display/d.legend/main.c:381 ../display/d.legend/main.c:541
-msgid "Color range exceeds lower limit of actual data"
+#: ../display/d.legend/main.c:381
+msgid "Requested range exceeds lower limit of actual data"
msgstr ""
-#: ../display/d.legend/main.c:387 ../display/d.legend/main.c:545
-msgid "Color range exceeds upper limit of actual data"
+#: ../display/d.legend/main.c:387
+msgid "Requested range exceeds upper limit of actual data"
msgstr ""
#: ../display/d.legend/main.c:446
@@ -22418,6 +22421,14 @@
msgid "Forcing a smooth legend: too many categories for current window height"
msgstr ""
+#: ../display/d.legend/main.c:541
+msgid "Color range exceeds lower limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:545
+msgid "Color range exceeds upper limit of actual data"
+msgstr ""
#: ../display/d.legend/main.c:552
#, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
@@ -24729,7 +24740,7 @@
#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:152
#: ../vector/v.proj/main.c:411 ../vector/v.kcv/main.c:142
-#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:719
+#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:750
#: ../vector/v.transform/main.c:286 ../vector/v.rectify/main.c:285
#, fuzzy
msgid "Failed to copy attribute table to output map"
@@ -25649,7 +25660,7 @@
msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
#: ../vector/v.in.ogr/main.c:1208 ../vector/v.delaunay/main.c:171
-#: ../vector/v.category/main.c:326
+#: ../vector/v.category/main.c:357
#, fuzzy
msgid "Unable to calculate area centroid"
msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
@@ -26221,6 +26232,7 @@
#: ../vector/v.net.distance/main.c:98 ../vector/v.net.distance/main.c:103
#: ../vector/v.net.distance/main.c:109 ../vector/v.distance/main.c:97
#: ../vector/v.distance/main.c:102 ../vector/v.distance/main.c:109
+#: ../vector/v.distance/main.c:188
#, fuzzy
msgid "From"
msgstr "ÙÙØ¹ اÙÙ
Ø¸ÙØ±"
@@ -27815,7 +27827,8 @@
msgid "Use drand48() (ignored)"
msgstr ""
-#: ../vector/v.kcv/main.c:119
+#: ../vector/v.kcv/main.c:119 ../vector/v.category/main.c:181
+#: ../vector/v.category/main.c:243 ../vector/v.category/main.c:251
#, fuzzy, c-format
msgid "Unable to open vector map <%s> at topological level %d"
msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
@@ -28902,10 +28915,6 @@
"Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
-#: ../vector/v.distance/main.c:188
-msgid "From_map"
-msgstr ""
#: ../vector/v.distance/main.c:193
msgid "Column name of nearest feature (used with upload=to_attr)"
msgstr ""
@@ -29571,178 +29580,178 @@
msgid "Counting points quadrats..."
msgstr "dig ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
-#: ../vector/v.category/main.c:77
+#: ../vector/v.category/main.c:78
msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:90
msgid "Feature ids (by default all features are processed)"
msgstr ""
-#: ../vector/v.category/main.c:101
+#: ../vector/v.category/main.c:102
#, fuzzy
msgid "Action to be done"
msgstr "اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ø§ÙØ·ÙÙØ¨ Ø¥Ø¯Ø®Ø§ÙØ©"
-#: ../vector/v.category/main.c:111
+#: ../vector/v.category/main.c:113
#, fuzzy
msgid "add a new category"
-#: ../vector/v.category/main.c:112
+#: ../vector/v.category/main.c:114
msgid "delete category (-1 to delete all categories of given layer)"
msgstr ""
-#: ../vector/v.category/main.c:113
+#: ../vector/v.category/main.c:115
msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
msgstr ""
-#: ../vector/v.category/main.c:114
+#: ../vector/v.category/main.c:116
msgid "add the value specified by cat option to the current category value"
msgstr ""
-#: ../vector/v.category/main.c:115
+#: ../vector/v.category/main.c:117
msgid ""
"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
"layer 1 to layer 2 and 3)"
msgstr ""
-#: ../vector/v.category/main.c:116
+#: ../vector/v.category/main.c:118
msgid "print report (statistics), in shell style: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:117
+#: ../vector/v.category/main.c:119
msgid "print category values, more cats in the same layer are separated by '/'"
msgstr ""
-#: ../vector/v.category/main.c:129
+#: ../vector/v.category/main.c:120
+#, fuzzy
+msgid "print only layer numbers"
+msgstr "طباعة Ø¹ÙØ§ÙÙ٠اÙÙØ¦Ø©"
+#: ../vector/v.category/main.c:132
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
msgid "Category increment"
msgstr ""
-#: ../vector/v.category/main.c:133
+#: ../vector/v.category/main.c:136
msgid "Shell script style, currently only for report"
msgstr ""
-#: ../vector/v.category/main.c:134
+#: ../vector/v.category/main.c:137
msgid "Format: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:152
+#: ../vector/v.category/main.c:155
msgid ""
"Database connection and attribute tables for concerned layers are not changed"
msgstr ""
-#: ../vector/v.category/main.c:173
+#: ../vector/v.category/main.c:203
msgid ""
"Invalid category number (must be equal to or greater than 0). Normally "
"category number starts at 1."
msgstr ""
-#: ../vector/v.category/main.c:182
+#: ../vector/v.category/main.c:212
#, c-format
msgid "%d errors in id option"
msgstr ""
-#: ../vector/v.category/main.c:191
+#: ../vector/v.category/main.c:221
#, fuzzy
msgid "Output vector wasn't entered"
msgstr "اÙÙÙÙØªÙر اÙÙ
خرج ÙÙ
ÙØªÙ
إدخاÙÙ"
-#: ../vector/v.category/main.c:212 ../vector/v.category/main.c:220
-#, fuzzy, c-format
-msgid "Can not open vector <%s> on level %d"
-msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
-#: ../vector/v.category/main.c:237
+#: ../vector/v.category/main.c:268
msgid "Too many layers for this operation"
msgstr "Ø·Ø¨ÙØ§Øª ÙØ«Ùرة ÙÙØ°Ù Ø§ÙØ¹Ù
ÙÙØ©"
-#: ../vector/v.category/main.c:240 ../vector/v.category/main.c:243
+#: ../vector/v.category/main.c:271 ../vector/v.category/main.c:274
msgid "2 layers must be specified"
-#: ../vector/v.category/main.c:251
+#: ../vector/v.category/main.c:282
#, fuzzy, c-format
msgid "Categories already exist in layer %d"
msgstr "%d ÙØ¦Ø§Øª Ù
ØÙ
ÙØ© Ù
Ù Ø§ÙØ¬Ø¯ÙÙ\n"
-#: ../vector/v.category/main.c:294 ../vector/v.select/select.c:40
+#: ../vector/v.category/main.c:325 ../vector/v.select/select.c:40
#, fuzzy
msgid "Processing features..."
-#: ../vector/v.category/main.c:340
+#: ../vector/v.category/main.c:371
#, fuzzy, c-format
msgid "%d new centroids placed in output map"
msgstr "%-5d أشبا٠اÙÙ
Ø±Ø§ÙØ² ÙØªØ¨Øª ÙÙ Ù
Ù٠اÙÙ
خرج\n"
-#: ../vector/v.category/main.c:629
+#: ../vector/v.category/main.c:660
#, fuzzy
msgid "Layer/table"
msgstr " nv ÙÙÙ\n"
-#: ../vector/v.category/main.c:633
+#: ../vector/v.category/main.c:664
#, fuzzy
msgid "Layer"
msgstr " nv ÙÙÙ\n"
-#: ../vector/v.category/main.c:635
+#: ../vector/v.category/main.c:666
#, fuzzy, c-format
msgid "type count min max\n"
msgstr " إختبر Ù
تبÙÙÙÙÙÙÙÙÙÙÙÙÙÙÙÙÙØ§Øª Ø§ÙØ®ÙÙÙÙÙÙÙÙÙØ±Ùطة\n"
-#: ../vector/v.category/main.c:636
+#: ../vector/v.category/main.c:667
#, fuzzy
msgid "point"
msgstr "اسÙ
Ø§ÙØ¬Ø¯ÙÙ"
-#: ../vector/v.category/main.c:640
+#: ../vector/v.category/main.c:671
msgid "line"
msgstr ""
-#: ../vector/v.category/main.c:644
+#: ../vector/v.category/main.c:675
#, fuzzy
msgid "boundary"
msgstr "ÙÙ
ÙØªÙ
ØªØØ¯ÙØ« Ø§ÙØØ¯ÙØ¯"
-#: ../vector/v.category/main.c:648
+#: ../vector/v.category/main.c:679
#: ../locale/scriptstrings/v.centroids_to_translate.c:3
#, fuzzy
msgid "centroid"
Ø±Ø§ÙØ² ÙØ±Ø§Øª\n"
-#: ../vector/v.category/main.c:652
+#: ../vector/v.category/main.c:683
#: ../locale/scriptstrings/v.centroids_to_translate.c:4
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
#, fuzzy
msgid "area"
msgstr "اÙÙ
Ø³Ø§ØØ©\n"
-#: ../vector/v.category/main.c:656
+#: ../vector/v.category/main.c:687
#, fuzzy
msgid "face"
msgstr "تباÙ٠اÙÙ
جÙ
ÙØ¹"
-#: ../vector/v.category/main.c:660
+#: ../vector/v.category/main.c:691
msgid "kernel"
msgstr ""
-#: ../vector/v.category/main.c:664
+#: ../vector/v.category/main.c:695
msgid "all"
msgstr ""
-#: ../vector/v.category/main.c:717 ../vector/v.rectify/main.c:283
+#: ../vector/v.category/main.c:748 ../vector/v.rectify/main.c:283
#, fuzzy
msgid "Copying attribute table(s)..."
msgstr "عدÙ
Ø§ÙØ´Ø§Ø¡ جدÙÙ Ø§ÙØ®Ùاص"
-#: ../vector/v.category/main.c:725
+#: ../vector/v.category/main.c:756
#, fuzzy, c-format
msgid "Categories copied from layer %d to layer %d"
ØÙ
ÙØ© Ù
Ù Ø§ÙØ¬Ø¯ÙÙ\n"
-#: ../vector/v.category/main.c:727
+#: ../vector/v.category/main.c:758
#, fuzzy, c-format
msgid "%d features modified."
msgstr "%d ÙÙØ·Ø© ÙØªØ¨Øª ÙÙÙ
خرج\n"
@@ -38956,6 +38965,14 @@
msgstr "Ù
ÙÙÙØ¨ ÙØ±Ù Ø§ÙØ¹Ø²Ù
#, fuzzy
+#~ msgid "Output_maps"
+#~ msgstr "Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "Can not open vector <%s> on level %d"
+#~ msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
+#, fuzzy
#~ msgid "Name of raster map(s) for Elevation"
#~ msgstr "اسÙ
اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙ
ÙØ¬Ùد"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grassmods_cs.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -13,7 +13,7 @@
msgstr ""
"Project-Id-Version: grassmods_cs\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-02-18 14:05+0100\n"
+"POT-Creation-Date: 2013-02-26 14:45+0100\n"
"PO-Revision-Date: 2010-03-07 15:38+0100\n"
"Language-Team: <cs at li.org>\n"
@@ -232,7 +232,7 @@
@@ -478,7 +478,7 @@
msgstr "Spojenàs databázà nebylo definováno pro vrstvu %d "
@@ -3627,7 +3627,7 @@
msgstr "Jeden pár souÅadnic na Åádek, prosÃm."
#, fuzzy
msgid "category"
msgstr "vektorová mapa, kategorie"
@@ -5737,7 +5737,8 @@
#: ../raster/r.spread/main.c:136 ../raster/r.spread/main.c:145
-msgid "Input_maps"
+#, fuzzy
+msgid "Input maps"
msgstr "Vstupnà mapy"
@@ -5802,8 +5803,9 @@
-msgstr "Výstupnà mapy"
+#, fuzzy
+msgstr "Výstupnà mapa"
msgid "Name of raster map to contain OUTPUT spread time (min)"
@@ -8999,7 +9001,8 @@
+#, fuzzy
msgstr "VstupnÃ_volby"
@@ -9085,7 +9088,8 @@
+#, fuzzy
msgstr "VýstupnÃ_volby"
@@ -9153,79 +9157,80 @@
msgstr "Äasové pásmo, pokud nezadáno, bude použit lokálnà sluneÄnà Äas"
+#, fuzzy
msgstr "Zahrnout vliv zastÃnÄnà okolnÃm reliéfem"
msgstr "Použij ménÄ hardwarovÄ nároÄnou verzi programu"
msgstr "Je tÅba zadat rastr se zemÄpisnou délkou pokud použÃváte bÄžný Äas"
#, fuzzy
msgstr "Chyba pÅi Ätenà velikosti Äasového kroku"
#, fuzzy
msgstr "Neplatná hodnota pro scalex"
msgstr "insol_time a incidout jsou nesluÄitelné volby"
#, fuzzy
msgstr "Chybný Äasový otisk"
msgstr "Chyba pÅi Ätenà velikosti horizontálnÃho kroku"
msgstr "velikost horizontálnÃho kroku musà být vÄtšà než nula"
msgid ""
msgstr ""
"POkud zadáte volbu obzor, musÃte také nastavit parametr 'krok horizontu'"
msgstr "time a insol_time jsou nesluÄitelné volby"
msgid ""
"time"
msgstr "Mode 1: okamžitý solárnà ůhel dopadu & ozáÅenost daná lokálnÃm Äasem"
msgstr "incidout požaduje nastavený parametr Äasu"
msgstr "Mode 2: dennà ozáÅenost pro zadaný den roku."
msgstr ""
"POkud použijete volbu -s a žádnou rastrovou mapu s horizontem, numpartitions "
"musà být =1"
msgid ""
"horizons."
@@ -9233,38 +9238,38 @@
"Pokud chcete uÅ¡etÅit zabránà množstvà pamÄti a zároveÅ použÃt stÃny, je "
"tÅeba použÃt pÅed-vypoÄÃtané horizonty."
#, fuzzy
msgstr "Nelze zÃskat jednotky mapové projekce aktuálnà location"
msgstr "Nelze zÃskat klÃÄové hodnoty mapové projekce aktuálnà location"
msgstr "Nelze nastavit parametry mapové projekce lat/long"
msgstr ""
msgstr ""
@@ -19749,7 +19754,7 @@
msgstr "Neplatná žádost delete"
#, fuzzy
@@ -20096,12 +20101,12 @@
msgstr "PoÄet kopià pro tisk"
#, fuzzy, c-format
msgstr "Nelze otevÅÃt soubor <%s>"
#, fuzzy, c-format
@@ -20110,7 +20115,7 @@
"\t(%s)"
msgstr "Požadovaný parametr <%s> nebyl zadán"
#, fuzzy, c-format
msgstr "Soubor Postscriptu [%s] byl úspÄÅ¡nÄ zapsán."
@@ -20236,7 +20241,7 @@
@@ -20249,12 +20254,12 @@
msgstr "Neznámý barevný požadavek '%s'"
#, c-format
msgstr "Spojenàs databázà nebylo definováno"
@@ -20327,8 +20332,8 @@
@@ -20343,8 +20348,8 @@
@@ -21351,7 +21356,7 @@
msgstr ""
#, fuzzy
msgstr "Vytiskne transfoemaÄnà matici na standartnà výstup"
@@ -22101,132 +22106,132 @@
msgstr ""
#, fuzzy
msgstr ""
"Jméno OGR vrstvy, pokud nenà zadán, jsou pouze vytiÅ¡tÄny pÅÃtomné vrstvy"
#, fuzzy
msgid "Boundaries"
msgstr "Hranice"
#, fuzzy
msgstr "Å ÃÅka hranice"
#, fuzzy
msgstr "Barva rámeÄku"
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgstr "Nezarovnávej výstup se vstupem"
#, fuzzy, c-format
msgstr "Pro vektorový soubor <%s> musÃte vybudovat topologii"
#, fuzzy
msgstr "'layer' musà být . 0 pro 'where'"
#, fuzzy, c-format
msgstr "|Sloupec musà být ÄÃselnéh typu"
#, fuzzy, c-format
msgstr "Nelze vybrat data z tabulky"
#, fuzzy, c-format
msgstr "Neznámá metrika: [%s]."
msgid ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"Need %i colors."
msgstr ""
#, fuzzy, c-format
msgstr "Chyba pÅi Ätenà souboru color pro <%s>"
#, fuzzy
msgstr "PÅevádÃm..."
#, fuzzy
msgid ""
msgstr "PoÄáteÄnà bod %d je mimo souÄasný region"
#, fuzzy, c-format
msgid ""
"\n"
msgstr "Neplatné ÄÃslo Åádku <%s>"
#, fuzzy, c-format
msgstr ""
"\n"
"Clasifikace %s do %i tÅÃd\n"
#, c-format
msgstr "Použitý algoritmus: *** %s ***\n"
#, c-format
msgstr "PrůmÄr: %f\tSmÄrodatná odchylka =%f\n"
#, fuzzy, c-format
msgstr "Nejmenšà chi2 = %f\n"
#, c-format
msgstr "StÅednà odchylka vynásobena %.4f pro urÄenà kroku\n"
@@ -22679,12 +22684,12 @@
msgstr "Oblast neobsahuje žádná data"
msgstr ""
msgstr ""
@@ -22700,6 +22705,14 @@
msgstr ""
+msgstr ""
+msgstr ""
#, c-format
@@ -25050,7 +25063,7 @@
msgstr "Nelze kopÃrovat atributovou tabulku do výstupnà mapy"
@@ -25976,7 +25989,7 @@
msgstr "Mazánà mostů"
msgstr "Nelze vypoÄÃtat centroid plochy"
@@ -26548,6 +26561,7 @@
msgid "From"
msgstr "From (z_mapy)"
@@ -28122,7 +28136,8 @@
msgstr "POužÃt drand48()"
#, c-format
msgstr "Vektorová mapa <%s> nemohla být otevÅena na úrovnà topologie %d"
@@ -29234,10 +29249,6 @@
msgstr ""
"Jméno(a) sloupců, kde hodnoty specifikované volbou 'upload' budou uloženy"
-msgid "From_map"
-msgstr "z_mapy"
msgstr "Jméno sloupce nejbližšÃho prvku (k použità spolu s upload=to_attr)"
@@ -29890,72 +29901,77 @@
msgstr "PoÄÃtám plochy ve zkusných plochách ..."
#, fuzzy
msgstr "PÅilož, smaž nebo vypiÅ¡ vektorové kategorie dp mapové geometrie."
msgstr "Id prvků (ve výchozÃm nastavenà bude id pÅidÄleno vÅ¡em prvkům)"
msgstr "Akce, majÃcà být vykonána"
#, fuzzy
msgstr "Linie %d nemá žádnou kategorii"
#, fuzzy
msgstr ""
"Vypsat min imálnà rozmÄry regionu vybraného vektorového prvku mÃsto atributů"
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgstr "Formát: vrstva typ poÄet min max"
msgstr ""
+#, fuzzy
+msgstr "pracuji na souboru <%s> pro ÄÃsla kategoriÃ"
msgstr "ZvÄtÅ¡enà hodnoty kategorià o"
msgstr "Styl shelového skriptu, pouze pro výpis"
msgid ""
msgstr "Databázové spojenà a tabulka atributů pro danou vrstvu se nezmÄnnily"
msgid ""
@@ -29963,102 +29979,97 @@
"Å patné ÄÃslo kategorie (musà být vÄtšà nebo rovno 0) bÄžnÄ ÄÃsla kategorie "
"zaÄÃnajà od 1."
#, c-format
msgstr "%d chyb ve volbÄ id"
msgstr "Výstupnà vektorová mapa nebyla zadána."
-#, fuzzy, c-format
-msgstr "Nelze otevÅÃt vektorový soubor <%s> v úrovni topologie %d"
msgstr "PÅÃliÅ¡ mnoho vrstev pro tuto operaci"
msgstr "Musà být zadány 2 vrstvy"
#, fuzzy, c-format
msgstr "NaÄteno %d kategorià z vektorové mapy (vrstva %d)"
msgstr "Zpracovávám prvky..."
#, c-format
msgstr "%d nové centroidy byly zapsány do výstupnÃho souboru"
msgid "Layer/table"
msgstr "Vrstva / tabulka"
msgid "Layer"
msgstr "Vrstva"
#, c-format
msgstr "typ souÄet min max\n"
msgid "point"
msgstr "Bod"
msgid "line"
msgstr "Linie"
msgid "boundary"
msgstr "Hranice"
msgid "centroid"
msgstr "centroid"
msgid "area"
msgstr "Plocha"
#, fuzzy
msgid "face"
msgstr "Povrch"
#, fuzzy
msgid "kernel"
msgstr "obecné"
msgid "all"
msgstr "vše"
msgstr "KopÃruji atributovou tabulku...."
#, fuzzy, c-format
#, c-format
msgstr "%d prvků zmÄnÄno."
@@ -39342,7 +39353,17 @@
msgid "Percent to brighten"
msgstr "Procentuálnà konvergence"
+#~ msgstr "Výstupnà mapy"
+#~ msgid "From_map"
+#~ msgstr "z_mapy"
#, fuzzy
+#~ msgstr "Nelze otevÅÃt vektorový soubor <%s> v úrovni topologie %d"
+#, fuzzy
#~ msgstr "Název rastrové mapy pro vloženà do skupiny"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grassmods_de.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grassmods_de\n"
"PO-Revision-Date: 2012-11-26 16:00+0100\n"
"Last-Translator: Robert Nuske <robert.nuske nw-fva.de>\n"
"Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -229,7 +229,7 @@
@@ -475,7 +475,7 @@
msgstr "Die Datenbankverbindung für den Layer<%d> ist nicht definiert."
@@ -908,8 +908,7 @@
msgid "Cannot create mask file: RASTER3D_MASK already exists"
msgstr ""
"Kann keine Maskendatei erzeugen: RASTER3D_MASK existiert bereits.\n"
-"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu "
-"löschen."
+"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu löschen."
#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:462
@@ -1054,8 +1053,7 @@
msgstr "Raster, Kachelung"
#: ../raster3d/r3.retile/main.c:104
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
msgstr ""
#: ../raster3d/r3.retile/main.c:118 ../misc/m.nviz.image/volume.c:42
@@ -1134,8 +1132,7 @@
#: ../raster3d/r3.in.v5d/main.c:195
#, fuzzy
msgid "Import 3-dimensional Vis5D files."
-msgstr ""
-"Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
+msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
#: ../raster3d/r3.info/r3.info.main.c:76 ../raster3d/r3.support/main.c:50
#: ../raster/r.support/main.c:56 ../raster/r.region/main.c:52
@@ -1240,11 +1237,8 @@
#: ../raster3d/r3.support/main.c:51
#, fuzzy
-msgid ""
-"Allows creation and/or modification of raster3d map layer support files."
-msgstr ""
-"Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-"
-"Dateien."
+msgid "Allows creation and/or modification of raster3d map layer support files."
+msgstr "Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-Dateien."
#: ../raster3d/r3.support/main.c:61 ../raster/r.support/main.c:67
msgid "Text to use for map title"
@@ -1337,30 +1331,22 @@
#: ../raster3d/r3.gwflow/main.c:60
#, fuzzy
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
#: ../raster3d/r3.gwflow/main.c:65
#, fuzzy
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster3d/r3.gwflow/main.c:70
#, fuzzy
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster3d/r3.gwflow/main.c:75
#, fuzzy
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der Z-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster3d/r3.gwflow/main.c:80
@@ -1380,44 +1366,33 @@
#: ../raster3d/r3.gwflow/main.c:93
#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
-msgstr ""
-"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
-"diese Karte geschrieben."
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
+msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
#: ../raster3d/r3.gwflow/main.c:99
#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
msgstr ""
"Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
"und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
#: ../raster3d/r3.gwflow/main.c:105
#, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:111
#, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:117
#, fuzzy
-msgid ""
-"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
+msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
msgstr ""
@@ -1427,9 +1402,7 @@
msgstr "Benutzte RASTER3D Maske (falls existent)."
#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
msgstr ""
#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:206
@@ -1451,20 +1424,15 @@
#: ../raster3d/r3.gwflow/main.c:163
#, fuzzy
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
-msgstr ""
-"Programm zur Berechnung des transienten, beschränkten Grundwasserflusses in "
-"drei Dimensionen."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
+msgstr "Programm zur Berechnung des transienten, beschränkten Grundwasserflusses in drei Dimensionen."
#: ../raster3d/r3.gwflow/main.c:180
#, fuzzy
msgid ""
"The cholesky solver does not work with sparse matrices.\n"
"Consider to choose a full filled quadratic matrix with flag -f "
-msgstr ""
-"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
#: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:541
msgid "Unable to create and solve the linear equation system"
@@ -1480,12 +1448,8 @@
msgstr "Fehler beim SchlieÃen der G3D-Datei."
#: ../raster3d/r3.mkdspf/main.c:82
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem "
-"gegebenen Threshold."
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem gegebenen Threshold."
#: ../raster3d/r3.mkdspf/main.c:90
msgid "Name of an existing 3d raster map"
@@ -1653,8 +1617,7 @@
#: ../raster3d/r3.out.v5d/main.c:287
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
-"Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei"
+msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei"
#: ../raster3d/r3.out.v5d/main.c:294
msgid "Use map coordinates instead of xyz coordinates"
@@ -1670,12 +1633,8 @@
#: ../raster3d/r3.to.rast/main.c:96
#, fuzzy
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
-msgstr ""
-"Verwende dieselbe Auflösung wie die RASTER3D-Eingabekarte für die 2D-"
-"Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
+msgstr "Verwende dieselbe Auflösung wie die RASTER3D-Eingabekarte für die 2D-Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
#: ../raster3d/r3.to.rast/main.c:207 ../raster/r.to.rast3/main.c:198
#: ../raster/r.to.vect/main.c:71 ../raster/r.in.ascii/main.c:71
@@ -1702,12 +1661,8 @@
msgstr "Fehler beim Ãffnen der 3D-Rasterkarte <%s>."
#: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:450
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Die 2D und 3D Regionsparameter sind unterschiedlich. Verwende die 2D-"
-"Fenstereinstellungen, um den 2D-Teil der 3D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Die 2D und 3D Regionsparameter sind unterschiedlich. Verwende die 2D-Fenstereinstellungen, um den 2D-Teil der 3D-Region anzupassen."
#: ../raster3d/r3.to.rast/main.c:295 ../raster/r.to.rast3/main.c:244
#: ../raster/r.li/r.li.daemon/list.c:49 ../imagery/i.smap/multialloc.c:115
@@ -1754,10 +1709,8 @@
#: ../raster3d/r3.to.rast/main.c:308
#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr ""
-"Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
#: ../raster3d/r3.cross.rast/main.c:90
msgid "Input 3D raster map for cross section."
@@ -1779,20 +1732,12 @@
#: ../raster3d/r3.cross.rast/main.c:233
#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
-msgstr ""
-"Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
-"Rasterkarte basierend auf 2D-Höhenkarte."
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
#: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"Die 2D- und 3D-Regionsparameter sind unterschiedlich. Verwende die 3D-"
-"Rasterkarteneinstellungen, um die 2D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Die 2D- und 3D-Regionsparameter sind unterschiedlich. Verwende die 3D-Rasterkarteneinstellungen, um die 2D-Region anzupassen."
#: ../raster3d/r3.cross.rast/main.c:302
msgid "Output map already exists. Will be overwritten!"
@@ -1817,18 +1762,12 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:335
#, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer "
-"Tiefe von %i in eine VTK-ASCII-Datei."
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer Tiefe von %i in eine VTK-ASCII-Datei."
#: ../raster3d/r3.out.vtk/writeVTKData.c:441
msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Falsche Werte in der 3D-Rasterkarte! Werte sollten zwischen 0 und 255 "
-"liegen!\n"
+msgstr "Falsche Werte in der 3D-Rasterkarte! Werte sollten zwischen 0 und 255 liegen!\n"
#: ../raster3d/r3.out.vtk/parameters.c:30
msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
@@ -1844,8 +1783,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standard ist Zelldaten)."
+msgstr "Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standard ist Zelldaten)."
#: ../raster3d/r3.out.vtk/parameters.c:56
msgid "top surface 2D raster map"
@@ -1856,24 +1794,16 @@
msgstr "2D Rasterkarte für den Boden."
#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide "
-"Rasterkarten werden benötigt."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide Rasterkarten werden benötigt."
#: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [redmap,greenmap,"
-"bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [redmap,greenmap,bluemap]"
#: ../raster3d/r3.out.vtk/parameters.c:92
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [xmap,ymap,zmap]"
+msgstr "Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [xmap,ymap,zmap]"
#: ../raster3d/r3.out.vtk/parameters.c:98 ../raster/r.out.vtk/parameters.c:88
#: ../vector/v.out.vtk/main.c:73
@@ -1902,9 +1832,7 @@
msgstr "Korrigiere die Koordinaten, um sie der VTK-OpenGL anzupassen."
#: ../raster3d/r3.out.vtk/parameters.c:133
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
msgstr ""
#: ../raster3d/r3.out.vtk/main.c:117
@@ -1937,17 +1865,12 @@
#: ../raster3d/r3.out.vtk/main.c:168
msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr ""
-"Bitte geben Sie drei 3D-Rasterkarten für die xyz-Vektorkarten an [x,y,z]."
+msgstr "Bitte geben Sie drei 3D-Rasterkarten für die xyz-Vektorkarten an [x,y,z]."
#: ../raster3d/r3.out.vtk/main.c:175
#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
-msgstr ""
-"Keine RASTER3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur "
-"die Geometrien schreiben."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
+msgstr "Keine RASTER3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
#: ../raster3d/r3.out.vtk/main.c:209
msgid "No RGB Data will be created."
@@ -1971,9 +1894,7 @@
#: ../raster3d/r3.out.vtk/main.c:541
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Kann die 3D-Rasterkarte nicht schlieÃen. Die VTK-Datei könnte unvollständig "
-"sein."
+msgstr "Kann die 3D-Rasterkarte nicht schlieÃen. Die VTK-Datei könnte unvollständig sein."
#: ../raster3d/r3.out.vtk/main.c:556
msgid "Unable to close VTK-ASCII file"
@@ -1989,8 +1910,7 @@
#: ../raster3d/r3.out.vtk/writeVTKHead.c:118
msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr ""
-"write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
+msgstr "write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
#: ../raster3d/r3.in.ascii/main.c:83 ../raster/r.in.ascii/main.c:78
#: ../vector/v.in.ascii/main.c:56
@@ -2000,9 +1920,7 @@
#: ../raster3d/r3.in.ascii/main.c:94
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner "
-"existiert)"
+msgstr "Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner existiert)"
#: ../raster3d/r3.in.ascii/main.c:184
#, fuzzy, c-format
@@ -2025,17 +1943,13 @@
#: ../raster3d/r3.in.ascii/main.c:289
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"Nach vollständigem Import der erwarteten Daten befinden sie sich in der "
-"Input-Datei. [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Nach vollständigem Import der erwarteten Daten befinden sie sich in der Input-Datei. [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:325
#, fuzzy
msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr ""
-"Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
+msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
#: ../raster3d/r3.in.ascii/main.c:368
msgid "Unable to close ASCII file"
@@ -2146,8 +2060,7 @@
#: ../misc/m.nviz.script/main.c:148
msgid "Either -i flag and/or route parameter must be used"
-msgstr ""
-"Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
+msgstr "Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
#: ../misc/m.nviz.script/main.c:172
msgid "Off-screen only available with full render mode"
@@ -2176,13 +2089,8 @@
msgstr "Habe NVIZ-Skript <%s> erzeugt."
#: ../misc/m.nviz.script/main.c:440
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Lasse diesen Punkt aus, der selektierte Punkt liegt auÃerhalb der Region. "
-"Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante "
-"gerutscht ist?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Lasse diesen Punkt aus, der selektierte Punkt liegt auÃerhalb der Region. Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante gerutscht ist?"
#: ../misc/m.nviz.image/args.c:51
msgid "Use draw mode for all loaded surfaces"
@@ -2414,8 +2322,7 @@
#: ../misc/m.nviz.image/args.c:561
msgid "Focus to point on surface (from SW corner in map units)"
-msgstr ""
-"Fokussiere auf Punkt auf der Oberfläche (von SW Ecke in Karteneinheiten)"
+msgstr "Fokussiere auf Punkt auf der Oberfläche (von SW Ecke in Karteneinheiten)"
#: ../misc/m.nviz.image/args.c:571 ../misc/m.nviz.image/args.c:606
#: ../misc/m.nviz.image/args.c:618 ../misc/m.nviz.image/args.c:628
@@ -2566,12 +2473,8 @@
msgstr "Höhe der Randzone"
#: ../misc/m.nviz.image/args.c:860
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
-msgstr ""
-"Platziere den Nordpfeil an der angegeben Position \t(in "
-"Bildschirmkoordinaten von der unteren linken Ecke)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
+msgstr "Platziere den Nordpfeil an der angegeben Position \t(in Bildschirmkoordinaten von der unteren linken Ecke)"
#: ../misc/m.nviz.image/args.c:862 ../misc/m.nviz.image/args.c:871
#: ../misc/m.nviz.image/args.c:878
@@ -2685,25 +2588,18 @@
msgstr "Erzeugt eine 3D Darstellung aus GIS Daten."
#: ../misc/m.nviz.image/main.c:56
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D "
-"Rasterdaten) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D Rasterdaten) in 3D."
#: ../misc/m.nviz.image/main.c:139
#, c-format
msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-"Vertikale Ãberhöhung wurde nicht spezifiziert, verwende den berechneten Wert "
-"%.0f."
+msgstr "Vertikale Ãberhöhung wurde nicht spezifiziert, verwende den berechneten Wert %.0f."
#: ../misc/m.nviz.image/main.c:151
#, c-format
msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
+msgstr "Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
#: ../misc/m.nviz.image/main.c:233
msgid "Unsupported output format"
@@ -2774,12 +2670,8 @@
msgstr "Distanz"
#: ../misc/m.cogo/main.c:227
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten "
-"umrechnet und umgekehrt."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten umrechnet und umgekehrt."
#: ../misc/m.cogo/main.c:229
msgid "It assumes a cartesian coordinate system"
@@ -2894,8 +2786,7 @@
#: ../misc/m.transform/main.c:320
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
+msgstr "Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
#: ../misc/m.transform/main.c:329
msgid "Rectification polynomial order"
@@ -2967,9 +2858,7 @@
#: ../misc/m.transform/main.c:361
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu "
-"lesen)."
+msgstr "Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu lesen)."
#: ../misc/m.transform/main.c:362
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
@@ -3030,12 +2919,8 @@
msgstr "Fläche:\n"
#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:362
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format "
-"konvertieren, zwecks Ãberprüfung."
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format konvertieren, zwecks Ãberprüfung."
#: ../raster/r.external/proj.c:34 ../raster/r.in.lidar/main.c:296
#: ../raster/r.in.gdal/main.c:378 ../vector/v.in.ogr/main.c:650
@@ -3050,8 +2935,7 @@
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location "
-"übereinzustimmen.\n"
+"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location übereinzustimmen.\n"
"\n"
#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:393
@@ -3072,38 +2956,24 @@
#: ../raster/r.external/proj.c:107
msgid ""
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern "
-"und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
#: ../raster/r.external/proj.c:110 ../raster/r.in.gdal/main.c:456
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten "
-"des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu "
-"erzeugen.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu erzeugen.\n"
#: ../raster/r.external/proj.c:115 ../raster/r.in.lidar/main.c:379
#: ../raster/r.in.gdal/main.c:461 ../vector/v.in.ogr/main.c:733
#: ../vector/v.in.lidar/main.c:461
msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-"Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
-"Location scheinen übereinzustimmen."
+msgstr "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen Location scheinen übereinzustimmen."
#: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie "
-"können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden "
-"nach oben zeigt."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden nach oben zeigt."
#: ../raster/r.external/window.c:26
msgid "Applying horizontal flip"
@@ -3428,12 +3298,8 @@
msgstr "Raster, Kartenalgebra"
#: ../raster/r.mode/main.c:58
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen "
-"mit gleichen Werten in einer benutzerdefinierten Basiskarte."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
#: ../raster/r.mode/main.c:64
msgid "Base map to be reclassified"
@@ -3458,9 +3324,7 @@
#: ../raster/r.profile/main.c:53
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) "
-"benutzerdefinierter Linien liegt."
+msgstr "Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) benutzerdefinierter Linien liegt."
#: ../raster/r.profile/main.c:61
msgid "Name of file for output (use output=- for stdout)"
@@ -3503,8 +3367,7 @@
#: ../raster/r.profile/main.c:153
#, c-format
msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr ""
-"[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
+msgstr "[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
#: ../raster/r.profile/main.c:155
#, c-format
@@ -3534,15 +3397,13 @@
msgstr "Bitte nur ein Koordinatenpaar pro Zeile."
#, fuzzy
msgid "category"
msgstr "Kein Punkte mit Kategorie [%d]."
#: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
msgstr "Verwaltet die Kategoriewerte und Label von Rasterkarten."
#: ../raster/r.category/main.c:68
@@ -3555,13 +3416,11 @@
#: ../raster/r.category/main.c:84
msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
#: ../raster/r.category/main.c:91
msgid "Default label or format string for dynamic labeling"
-msgstr ""
-"Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
+msgstr "Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
#: ../raster/r.category/main.c:93
msgid "Used when no explicit label exists for the category"
@@ -3599,9 +3458,7 @@
#: ../raster/r.category/main.c:253
msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"Die Karte ist eine FlieÃkommazahl-Karte. Ignoriere Kategorieliste, nehme "
-"stattdessen Vals-Liste."
+msgstr "Die Karte ist eine FlieÃkommazahl-Karte. Ignoriere Kategorieliste, nehme stattdessen Vals-Liste."
#: ../raster/r.category/main.c:270
msgid "vals argument is required for floating point map!"
@@ -3656,9 +3513,7 @@
#: ../raster/r.watershed/ram/do_cum.c:474
#, c-format
msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr ""
-"MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d "
-"Zellen"
+msgstr "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
#: ../raster/r.watershed/ram/do_cum.c:478
#: ../raster/r.watershed/seg/do_cum.c:528
@@ -3685,42 +3540,21 @@
#, fuzzy, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
"\n"
msgstr ""
"VERWENDUNG für Einzugsgebietskartierung:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
"\n"
"VERWENDUNG für ARMSED-Datei Erzeugung:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
"\n"
"VERWENDUNG für Hanglängenberechnung:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
#: ../raster/r.watershed/ram/do_flatarea.c:56
msgid "Beautify flat areas: priority queue error"
@@ -3790,9 +3624,7 @@
#: ../raster/r.watershed/seg/init_vars.c:166
#, fuzzy
msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
-msgstr ""
-"Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
-"Standardwert 300 MB."
+msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
#: ../raster/r.watershed/seg/init_vars.c:243
#, c-format
@@ -3825,9 +3657,7 @@
#: ../raster/r.watershed/seg/do_cum.c:524
#, fuzzy
msgid "MFD: A * path already processed when distributing flow: %d of %"
-msgstr ""
-"Zellen"
#: ../raster/r.watershed/seg/close_maps2.c:86
#, fuzzy
@@ -3890,36 +3720,27 @@
#: ../raster/r.watershed/shed/com_line.c:28
#, c-format
msgid "in its fast mode or its slow mode. If you run %s"
-msgstr ""
-"im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
+msgstr "im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
#: ../raster/r.watershed/shed/com_line.c:30
msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-"im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig "
-"sein "
+msgstr "im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig sein "
#: ../raster/r.watershed/shed/com_line.c:31
msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-"als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
+msgstr "als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
#: ../raster/r.watershed/shed/com_line.c:32
msgid "at the same time. The fast mode also places all of the data into"
-msgstr ""
-"zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausÃerdem alle "
-"Daten"
+msgstr "zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausÃerdem alle Daten"
#: ../raster/r.watershed/shed/com_line.c:33
msgid "RAM, which limits the size of window that can be run. The slow"
-msgstr ""
-"in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
+msgstr "in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
#: ../raster/r.watershed/shed/com_line.c:34
msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS "
-"befindet. "
+msgstr "Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS befindet. "
#: ../raster/r.watershed/shed/com_line.c:35
msgid "stored. Thus, if the program does not work in the slow mode, you will"
@@ -3927,14 +3748,12 @@
#: ../raster/r.watershed/shed/com_line.c:36
msgid "need to remove unnecessary files from that partition. The slow mode"
-msgstr ""
-"das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
+msgstr "das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
#: ../raster/r.watershed/shed/com_line.c:37
#, c-format
msgid "will allow other processes to run concurrently with %s.\n"
-msgstr ""
-"gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
+msgstr "gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
#: ../raster/r.watershed/shed/com_line.c:69
#: ../raster/r.watershed/shed/com_line.c:182
@@ -3960,38 +3779,28 @@
"Eine der Optionen für %s ist eine `Senkungskarte'. Eine "
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
msgstr "Senkungskarte zeigt alle Orte im aktuellen Fenster an wo "
#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
msgstr "sich Wasser sammelt und nicht am Kartenrand austritt. Seen ohne "
#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
-msgstr ""
-"Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie "
-"eine "
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgstr "Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie eine "
#: ../raster/r.watershed/shed/com_line.c:86
msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-"Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der "
-"die Nicht-Null Zellen "
+msgstr "Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der die Nicht-Null Zellen "
#: ../raster/r.watershed/shed/com_line.c:87
msgid "locations where depressions occur.\n"
msgstr "Orte anzeigen an denen Senken vorkommen.\n"
#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-"Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken "
-"gibt."
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr "Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken gibt."
#: ../raster/r.watershed/shed/com_line.c:99
#, c-format
@@ -4003,79 +3812,50 @@
"Das %s Programm wird die Höhenkarte in ein Anzahl von "
#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
-msgstr ""
-"Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
+msgid "watershed basins. The number of watershed basins is indirectly determined"
+msgstr "Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
-msgstr ""
-"vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die "
-"notwendige Fläche für "
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
+msgstr "vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die notwendige Fläche für "
#: ../raster/r.watershed/shed/com_line.c:103
#, c-format
msgid "%s to define a unique watershed basin. This area only applies to"
-msgstr ""
-"%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
+msgstr "%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
-msgstr ""
-"auÃenliegende Einzugsgebiete. Ein auÃenliegendes Einzugsgebiet hat keine "
-"anderen "
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
+msgstr "auÃenliegende Einzugsgebiete. Ein auÃenliegendes Einzugsgebiet hat keine anderen "
#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
-msgstr ""
-"Einzugsgebiete die mit einflieÃen. Die GröÃe von Binneneinzugsgebieten ist "
-"festgelegt "
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
+msgstr "Einzugsgebiete die mit einflieÃen. Die GröÃe von Binneneinzugsgebieten ist festgelegt "
#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-"durch den Oberflächenabfluss, der in Flussabschnitten zwischen "
-"Stromunterbrechungen flieÃt. "
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr "durch den Oberflächenabfluss, der in Flussabschnitten zwischen Stromunterbrechungen flieÃt. "
#: ../raster/r.watershed/shed/com_line.c:108
#, c-format
msgid "Thus interior drainage basins can be of any size. The %s program"
-msgstr ""
-"Daher können Binneneinzugsgebiete eine beliebige GröÃe haben. Das Programm "
-"%s "
+msgstr "Daher können Binneneinzugsgebiete eine beliebige GröÃe haben. Das Programm %s "
#: ../raster/r.watershed/shed/com_line.c:110
msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-"ermöglicht es dem Benutzer sogar die BehältergröÃe in Beziehung zum "
-"Oberflächenabfluss zu setzen "
+msgstr "ermöglicht es dem Benutzer sogar die BehältergröÃe in Beziehung zum Oberflächenabfluss zu setzen "
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-"(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen "
-"um "
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr "(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen um "
#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-"Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen "
-"Infiltrationsraten). "
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr "Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen Infiltrationsraten). "
#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten "
-"generieren, und "
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten generieren, und "
#: ../raster/r.watershed/shed/com_line.c:114
#, c-format
@@ -4105,8 +3885,7 @@
"How large an area (or how many overland flow units) must a drainage basin"
msgstr ""
"\n"
-"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein "
-"Einzugsgebiet "
+"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein Einzugsgebiet "
#: ../raster/r.watershed/shed/com_line.c:132
#, c-format
@@ -4196,9 +3975,7 @@
#: ../raster/r.watershed/shed/com_line.c:292
#, c-format
msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr ""
-"%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-"
-"Aspekt und "
+msgstr "%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-Aspekt und "
#: ../raster/r.watershed/shed/com_line.c:294
#, c-format
@@ -4206,11 +3983,8 @@
msgstr "Bildschirmversion der Akkumulationskarte). %s hat auch die "
#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
-msgstr ""
-"Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised "
-"Universal Soil Loss Equation; Rusle) "
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
+msgstr "Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised Universal Soil Loss Equation; Rusle) "
#: ../raster/r.watershed/shed/com_line.c:297
msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
@@ -4227,17 +4001,11 @@
#: ../raster/r.watershed/shed/com_line.c:349
#, c-format
msgid "disturbed land. %s reflects this with an optional map layer or value"
-msgstr ""
-"gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem "
-"Wert "
+msgstr "gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem Wert "
#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-"wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der "
-"Zelle angibt. "
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr "wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der Zelle angibt. "
#: ../raster/r.watershed/shed/com_line.c:352
msgid "Type <return> if you do not have a disturbed land map layer."
@@ -4249,8 +4017,7 @@
"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
"\n"
-"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. "
-"Dieser Wert "
+"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. Dieser Wert "
#: ../raster/r.watershed/shed/com_line.c:365
msgid "be used for every cell in the current region."
@@ -4271,8 +4038,7 @@
"Overland surface flow only occurs for a set distance before swales form."
msgstr ""
"\n"
-"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke "
-"entsteht. "
+"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke entsteht. "
#: ../raster/r.watershed/shed/com_line.c:380
#, c-format
@@ -4282,12 +4048,10 @@
#: ../raster/r.watershed/shed/com_line.c:382
#, c-format
msgid "these swales. %s allows for an input (warning: kludge factor)"
-msgstr ""
-"Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
+msgstr "Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr "das verhindert dass die Distanz des Oberflächenabfluss zu lang wird. "
#: ../raster/r.watershed/shed/com_line.c:385
@@ -4303,8 +4067,7 @@
"StraÃen, Gräben, Ãnderung in der Oberflächenabdeckung und andere Faktoren "
#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
+msgid "slope length. You may input a raster map indicating the locations of these"
msgstr "begrenzen die Hanglänge. Eine Rasterkarte mit den Standorten dieser "
#: ../raster/r.watershed/shed/com_line.c:402
@@ -4312,11 +4075,8 @@
msgstr "blockierenden Faktoren sollte angegeben werden.\n"
#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-"Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen "
-"gibt. "
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr "Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen gibt. "
#: ../raster/r.watershed/shed/basin_maps.c:12
msgid ""
@@ -4326,8 +4086,7 @@
msgstr ""
"\n"
"\n"
-"Bitte geben Sie an welche Karten verwendet werden sollen in dem "
-"konzentrierten "
+"Bitte geben Sie an welche Karten verwendet werden sollen in dem konzentrierten "
#: ../raster/r.watershed/shed/basin_maps.c:13
msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
@@ -4366,15 +4125,11 @@
#: ../raster/r.watershed/shed/basin_maps.c:39
msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-"1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, "
-"oder 2) "
+msgstr "1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, oder 2) "
#: ../raster/r.watershed/shed/basin_maps.c:40
msgid "data from the basin, and all basins upstream of it."
-msgstr ""
-"es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen "
-"verwendet. "
+msgstr "es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen verwendet. "
#: ../raster/r.watershed/shed/basin_maps.c:43
msgid ""
@@ -4424,8 +4179,7 @@
#: ../raster/r.watershed/shed/intro.c:8
#, c-format
msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-"%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
+msgstr "%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
@@ -4450,9 +4204,7 @@
#: ../raster/r.watershed/shed/intro.c:18
#, c-format
msgid "divided by basin. %s will then run %s and create the report."
-msgstr ""
-"von Behältern getrennt werden. %s wird dann %s starten und einen Bericht "
-"erstellen. "
+msgstr "von Behältern getrennt werden. %s wird dann %s starten und einen Bericht erstellen. "
#: ../raster/r.watershed/shed/valid.c:24
msgid "accum file missing in valid_basins()"
@@ -4495,9 +4247,7 @@
#: ../raster/r.watershed/front/main.c:82
msgid "All non-NULL and non-zero cells are considered as real depressions"
-msgstr ""
-"Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte "
-"Bodensenke aufgefasst."
+msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Bodensenke aufgefasst."
#: ../raster/r.watershed/front/main.c:88
#, fuzzy
@@ -4517,16 +4267,12 @@
#: ../raster/r.watershed/front/main.c:102
#, fuzzy
msgid "IName of input raster map blocking overland surface flow"
-msgstr ""
-"Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
#: ../raster/r.watershed/front/main.c:104
#, fuzzy
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
-msgstr ""
-"Hindernis aufgefasst."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
#: ../raster/r.watershed/front/main.c:111
#, fuzzy
@@ -4536,9 +4282,7 @@
#: ../raster/r.watershed/front/main.c:119
#, fuzzy
msgid "Maximum length of surface flow in map units"
-msgstr ""
-"Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für "
-"USLE."
+msgstr "Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für USLE."
#: ../raster/r.watershed/front/main.c:128
#, fuzzy
@@ -4637,14 +4381,11 @@
#: ../raster/r.watershed/front/main.c:191
msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
-"1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende "
-"Fluss. Empfohlen: 5."
+msgstr "1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende Fluss. Empfohlen: 5."
#: ../raster/r.watershed/front/main.c:198
msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
-"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
#: ../raster/r.watershed/front/main.c:202
msgid "SFD (D8) flow (default is MFD)"
@@ -4663,25 +4404,16 @@
msgstr "Schalte Auslagerung auf Festplatte an: Operation ist langsam."
#: ../raster/r.watershed/front/main.c:216
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher "
-"überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen "
-"berechnet werden."
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen berechnet werden."
#: ../raster/r.watershed/front/main.c:221
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-"Verwende positive Flussakkumulation, auch für vorraussichtliche "
-"Unterschätzungen."
+msgstr "Verwende positive Flussakkumulation, auch für vorraussichtliche Unterschätzungen."
#: ../raster/r.watershed/front/main.c:223
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-"Siehe Handbuch für detaillierte Beschreibung der Ausgabe der "
-"Flussakkumulation."
+msgstr "Siehe Handbuch für detaillierte Beschreibung der Ausgabe der Flussakkumulation."
#: ../raster/r.watershed/front/main.c:228
msgid "Beautify flat areas"
@@ -4772,8 +4504,7 @@
#: ../raster/r.drain/main.c:111
#, fuzzy
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
msgstr "Verfolgt einen Fluss durch ein Höhenmodell auf einer Rasterkarte."
#: ../raster/r.drain/main.c:114
@@ -4799,9 +4530,7 @@
#: ../raster/r.drain/main.c:130
#, fuzzy
msgid "Recommended for cost surface made using knight's move"
-msgstr ""
-"Ausgabe AbfluÃvektorkarte (empfohlen für Kostenkarten erstellt mittels "
-"Rösselsprung)."
+msgstr "Ausgabe AbfluÃvektorkarte (empfohlen für Kostenkarten erstellt mittels Rösselsprung)."
#: ../raster/r.drain/main.c:134 ../raster/r.cost/main.c:188
#: ../raster/r.walk/main.c:230
@@ -4841,12 +4570,8 @@
#: ../raster/r.drain/main.c:161
#, fuzzy
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
-msgstr ""
-"Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muà auch eine "
-"Richtungskarte angegeben werden)."
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
+msgstr "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muà auch eine Richtungskarte angegeben werden)."
#: ../raster/r.drain/main.c:173
#, fuzzy
@@ -4859,21 +4584,13 @@
#: ../raster/r.drain/main.c:181
#, fuzzy, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
-msgstr ""
-"Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, "
-"muà eine Richtungskarte angegeben werden."
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
+msgstr "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, muà eine Richtungskarte angegeben werden."
#: ../raster/r.drain/main.c:188
#, fuzzy, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
-msgstr ""
-"Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluà nicht "
-"angegeben werden."
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
+msgstr "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluà nicht angegeben werden."
#: ../raster/r.drain/main.c:207
msgid "Specify just one of the -c, -a and -n flags"
@@ -4942,9 +4659,7 @@
#: ../raster/r.param.scale/process.c:74
msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-"ZellengröÃe in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende "
-"den Mittelwert."
+msgstr "ZellengröÃe in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende den Mittelwert."
#: ../raster/r.param.scale/main.c:42
msgid "Lat/Long locations are not supported by this module"
@@ -4960,12 +4675,8 @@
msgstr "Extrahiert Terrainparameter aus einem DGM."
#: ../raster/r.param.scale/interface.c:57
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf "
-"jede FenstergröÃe angepasst werden (über die Methode der kleinsten Quadrate)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf jede FenstergröÃe angepasst werden (über die Methode der kleinsten Quadrate)."
#: ../raster/r.param.scale/interface.c:75
msgid "Output raster layer containing morphometric parameter"
@@ -4973,8 +4684,7 @@
#: ../raster/r.param.scale/interface.c:79
msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr ""
-"Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
+msgstr "Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
#: ../raster/r.param.scale/interface.c:86
msgid "Curvature tolerance that defines 'planar' surface"
@@ -4987,9 +4697,7 @@
#: ../raster/r.param.scale/interface.c:101
msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
-"Morphometrische Parameter, die innerhalb der FenstergröÃe berechnet werden "
-"sollen."
+msgstr "Morphometrische Parameter, die innerhalb der FenstergröÃe berechnet werden sollen."
#: ../raster/r.param.scale/interface.c:109
msgid "Exponent for distance weighting (0.0-4.0)"
@@ -5044,9 +4752,7 @@
#: ../raster/r.support/main.c:57
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Dateien."
#: ../raster/r.support/main.c:81
msgid "Text to use for map data units"
@@ -5059,8 +4765,7 @@
#: ../raster/r.support/main.c:130
#, fuzzy
msgid "Update statistics (histogram, range)"
-msgstr ""
-"Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
#: ../raster/r.support/main.c:134
#, fuzzy
@@ -5093,8 +4798,7 @@
#: ../raster/r.topmodel/main.c:65
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr ""
-"Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
+msgstr "Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
#: ../raster/r.topmodel/main.c:75
#, fuzzy
@@ -5134,8 +4838,7 @@
#: ../raster/r.topmodel/main.c:89 ../raster/r.fill.dir/main.c:100
#, fuzzy
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
msgstr "(o) Richtungskarte für abflusslose Höhenkarte."
#: ../raster/r.topmodel/main.c:95
@@ -5300,11 +5003,8 @@
msgstr "%s: SCHRITT 1 ... "
#: ../raster/r.cross/main.c:76
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
#: ../raster/r.cross/main.c:85
#, c-format
@@ -5510,13 +5210,8 @@
msgstr "Vektor, Geometrie"
#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder "
-"mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte "
-"gefüllt werden."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte gefüllt werden."
#: ../raster/r.patch/main.c:62
msgid "Name of raster maps to be patched together"
@@ -5692,83 +5387,56 @@
msgstr "Linie"
#: ../raster/r.spread/main.c:105
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und "
-"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
-"Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung "
-"und der Ursprung."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
#: ../raster/r.spread/main.c:110
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
-msgstr ""
-"Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um "
-"Ausbreitungspfade nachzuzeichnen."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
+msgstr "Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um Ausbreitungspfade nachzuzeichnen."
#: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
#: ../raster/r.spread/main.c:136 ../raster/r.spread/main.c:145
#: ../raster/r.spread/main.c:153 ../raster/r.spread/main.c:161
#: ../raster/r.spread/main.c:169
-msgid "Input_maps"
-msgstr "Eingabekarten"
+#, fuzzy
+msgid "Input maps"
+msgstr "Eingabekarte"
#: ../raster/r.spread/main.c:120
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-"Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/"
-"min]."
+msgstr "Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/min]."
#: ../raster/r.spread/main.c:129
msgid "Name of raster map containing DIRections of max ROS (degree)"
-msgstr ""
-"Name der Rasterkarte mit den Richtungen der Maximalen "
-"Ausbreitungsgeschwindigkeit [Grad]."
+msgstr "Name der Rasterkarte mit den Richtungen der Maximalen Ausbreitungsgeschwindigkeit [Grad]."
#: ../raster/r.spread/main.c:138
msgid "Name of raster map containing BASE ROS (cm/min)"
-msgstr ""
-"Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
+msgstr "Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
#: ../raster/r.spread/main.c:147
msgid "Name of raster map containing STARTing sources"
msgstr "Name der Rasterkarte mit Startpunkten."
#: ../raster/r.spread/main.c:155
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] "
-"(gefordert von dem Schalter -s)."
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] (gefordert von dem Schalter -s)."
#: ../raster/r.spread/main.c:163
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/"
-"min] (gefordert von dem Schalter -s)."
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min] (gefordert von dem Schalter -s)."
#: ../raster/r.spread/main.c:171
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer "
-"Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
#: ../raster/r.spread/main.c:179
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-"StichprobenrahmengröÃe, die für eine bestimmte Genauigkeit benötigt wird (3)."
+msgstr "StichprobenrahmengröÃe, die für eine bestimmte Genauigkeit benötigt wird (3)."
#: ../raster/r.spread/main.c:186
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
+msgstr "Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
#: ../raster/r.spread/main.c:193
msgid "INITial TIME for current simulation (0) (min)"
@@ -5780,14 +5448,13 @@
#: ../raster/r.spread/main.c:207
msgid "Name of raster map as a display backdrop"
-msgstr ""
-"Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt "
-"werden soll."
+msgstr "Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt werden soll."
#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
#: ../raster/r.spread/main.c:230
-msgid "Output_maps"
-msgstr "Ausgabekarten"
+#, fuzzy
+msgid "Output maps"
+msgstr "Ausgabekarte"
#: ../raster/r.spread/main.c:216
msgid "Name of raster map to contain OUTPUT spread time (min)"
@@ -5811,9 +5478,7 @@
#: ../raster/r.spread/main.c:244
msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-"Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der "
-"Entdeckung (Spotting-Effect)."
+msgstr "Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der Entdeckung (Spotting-Effect)."
#: ../raster/r.spread/main.c:256
#, fuzzy
@@ -5836,20 +5501,13 @@
msgstr "Optionales kumulatives Kostenmaximum."
#: ../raster/r.cost/main.c:141
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen "
-"zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
-"Kategoriewerte der Eingabekarte repräsentieren die Kosten."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die Kategoriewerte der Eingabekarte repräsentieren die Kosten."
#: ../raster/r.cost/main.c:148
#, fuzzy
msgid "Name of input raster map containing grid cell cost information"
-msgstr ""
-"Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
+msgstr "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
#: ../raster/r.cost/main.c:156
#, fuzzy
@@ -5897,9 +5555,7 @@
#: ../raster/r.cost/main.c:214 ../raster/r.walk/main.c:254
msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Kosten werden NULL-Zellen zugewiesen. StandardmäÃig werden NULL-Zellen "
-"ignoriert."
+msgstr "Kosten werden NULL-Zellen zugewiesen. StandardmäÃig werden NULL-Zellen ignoriert."
#: ../raster/r.cost/main.c:215 ../raster/r.cost/main.c:235
#: ../raster/r.walk/main.c:255 ../raster/r.walk/main.c:305
@@ -5915,9 +5571,7 @@
#: ../raster/r.cost/main.c:230 ../raster/r.walk/main.c:300
msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-"Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber "
-"genauer."
+msgstr "Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber genauer."
#: ../raster/r.cost/main.c:234
msgid "Keep null values in output raster map"
@@ -5934,9 +5588,7 @@
#: ../raster/r.cost/main.c:294 ../raster/r.walk/main.c:363
msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Es muss exakt entweder start_points, start_rast oder coordinate angegeben "
-"werden."
+msgstr "Es muss exakt entweder start_points, start_rast oder coordinate angegeben werden."
#: ../raster/r.cost/main.c:299 ../raster/r.cost/main.c:705
#: ../raster/r.walk/main.c:368
@@ -5955,8 +5607,7 @@
#: ../raster/r.cost/main.c:328
msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
+msgstr "Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
#: ../raster/r.cost/main.c:406 ../raster/r.cost/main.c:415
#: ../raster/r.walk/main.c:557 ../raster/r.walk/main.c:567
@@ -5989,12 +5640,8 @@
#: ../raster/r.cost/main.c:479
#, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
-msgstr ""
-"Negative Werte in Zeile %d, Spalte %d gefunden. Setze die negativen Werte "
-"auf den null_cost-Wert."
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
+msgstr "Negative Werte in Zeile %d, Spalte %d gefunden. Setze die negativen Werte auf den null_cost-Wert."
#: ../raster/r.cost/main.c:496
#, fuzzy
@@ -6139,23 +5786,16 @@
#: ../raster/r.out.vtk/parameters.c:61
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte "
-"angegeben wurde)."
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte angegeben wurde)."
#: ../raster/r.out.vtk/parameters.c:71
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,"
-"blaue Karte]."
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,blaue Karte]."
#: ../raster/r.out.vtk/parameters.c:81
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
+msgstr "Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
#: ../raster/r.out.vtk/parameters.c:106
msgid "Use structured grid for elevation (not recommended)"
@@ -6166,17 +5806,12 @@
msgstr "Benutze Polydata-Dreiecksstreifen für die Erzeugung des Höhengitters."
#: ../raster/r.out.vtk/parameters.c:118
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-"Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für "
-"vtkDelauny2D)."
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr "Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für vtkDelauny2D)."
#: ../raster/r.out.vtk/parameters.c:124
msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-"Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben "
-"wurde)."
+msgstr "Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben wurde)."
#: ../raster/r.out.vtk/main.c:61
#, fuzzy
@@ -6184,9 +5819,7 @@
msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
#: ../raster/r.out.vtk/main.c:72
-msgid ""
-"No input maps specified. You need to specify at least one input map or three "
-"vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
msgstr ""
#: ../raster/r.out.vtk/main.c:130 ../raster/r.out.vtk/main.c:190
@@ -6201,20 +5834,15 @@
#: ../raster/r.out.vtk/main.c:231
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde "
-"nicht hinzugefügt!"
+msgstr "Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde nicht hinzugefügt!"
#: ../raster/r.out.vtk/main.c:260
msgid "Writing VTK Vector Data\n"
msgstr "Schreibe VTK Vektordaten.\n"
#: ../raster/r.out.vtk/main.c:270
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe "
-"wurde nicht hinzugefügt!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr "FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe wurde nicht hinzugefügt!"
#: ../raster/r.out.vtk/main.c:282
msgid "Error closing VTK-ASCII file"
@@ -6270,8 +5898,7 @@
#: ../raster/r.recode/read_rules.c:30
#, fuzzy, c-format
msgid "Data range of %s is %s to %s (entire map)"
-msgstr ""
-"Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
+msgstr "Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:332
#, c-format
@@ -6371,11 +5998,8 @@
msgstr "Neuskalieren"
#: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
#: ../raster/r.rescale.eq/main.c:65 ../raster/r.rescale/main.c:60
msgid "The name of the raster map to be rescaled"
@@ -6383,9 +6007,7 @@
#: ../raster/r.rescale.eq/main.c:73 ../raster/r.rescale/main.c:68
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Wertebereich der Eingangsdaten, der reskaliert werden soll (Standard: "
-"gesamter Wertebereich der Eingabekarte)"
+msgstr "Wertebereich der Eingangsdaten, der reskaliert werden soll (Standard: gesamter Wertebereich der Eingabekarte)"
#: ../raster/r.rescale.eq/main.c:80 ../raster/r.rescale/main.c:75
msgid "The resulting raster map name"
@@ -6495,8 +6117,7 @@
#: ../raster/r.los/main.c:162
msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
-"Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
+msgstr "Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
#: ../raster/r.los/main.c:167
msgid "Specified observer coordinate is outside current region bounds."
@@ -6507,11 +6128,8 @@
msgstr "Musterkarte sollte eine binäre 0/1 Rasterkarte sein."
#: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, "
-"verwende Kugel (6370997.0)."
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, verwende Kugel (6370997.0)."
#: ../raster/r.los/main.c:250
#, c-format
@@ -6536,12 +6154,8 @@
msgstr ""
#: ../raster/r.his/main.c:67
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der "
-"Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
#: ../raster/r.his/main.c:76 ../display/d.his/main.c:77
msgid "Name of layer to be used for HUE"
@@ -6549,13 +6163,11 @@
#: ../raster/r.his/main.c:83 ../display/d.his/main.c:84
msgid "Name of layer to be used for INTENSITY"
-msgstr ""
-"Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
+msgstr "Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
#: ../raster/r.his/main.c:90 ../display/d.his/main.c:91
msgid "Name of layer to be used for SATURATION"
-msgstr ""
-"Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
+msgstr "Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
#: ../raster/r.his/main.c:97
msgid "Name of output layer to be used for RED"
@@ -6599,12 +6211,8 @@
#: ../raster/r.buffer/main.c:69
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
-"haben."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
#: ../raster/r.buffer/main.c:81
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
@@ -6682,9 +6290,7 @@
#: ../raster/r.circle/main.c:54
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
-"Punkt ziehen."
+msgstr "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen Punkt ziehen."
#: ../raster/r.circle/main.c:64
msgid "The coordinate of the center (east,north)"
@@ -6712,9 +6318,7 @@
#: ../raster/r.circle/main.c:117
msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-"Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären "
-"Schalter verwenden."
+msgstr "Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären Schalter verwenden."
#: ../raster/r.circle/main.c:154 ../raster/r.composite/main.c:261
#: ../raster/r.in.gdal/main.c:1136 ../raster/r.surf.fractal/main.c:85
@@ -6729,16 +6333,8 @@
#: ../raster/r.walk/main.c:185
#, fuzzy
-msgid ""
-"Computes anisotropic cumulative cost of moving between different geographic "
-"locations on an input elevation raster map whose cell category values "
-"represent elevation combined with an input raster map layer whose cell "
-"values represent friction cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die "
-"beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. "
-"Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
-"mit Reibungs-Kosten kombiniert."
+msgid "Computes anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
#: ../raster/r.walk/main.c:196
msgid "Name of input raster map containing friction costs"
@@ -6751,18 +6347,15 @@
#: ../raster/r.walk/main.c:274
msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-"Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
+msgstr "Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
#: ../raster/r.walk/main.c:284
msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
+msgstr "Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
#: ../raster/r.walk/main.c:294
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
+msgstr "Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
#: ../raster/r.walk/main.c:304
msgid "Keep null values in output map"
@@ -6799,9 +6392,7 @@
#: ../raster/r.walk/main.c:422
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden "
-"ausgeschlossen."
+msgstr "Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
#: ../raster/r.walk/main.c:607
#, fuzzy, c-format
@@ -6958,8 +6549,7 @@
#: ../raster/r.contour/main.c:90
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
+msgstr "Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
#: ../raster/r.contour/main.c:101
msgid "List of contour levels"
@@ -7090,17 +6680,11 @@
msgstr "Sites"
#: ../raster/r.series/main.c:137
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
-"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
#: ../raster/r.series/main.c:146
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
msgstr ""
#: ../raster/r.series/main.c:157
@@ -7108,8 +6692,7 @@
msgstr "Aggregationsverfahren"
#: ../raster/r.series/main.c:172
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
msgstr ""
#: ../raster/r.series/main.c:179
@@ -7240,8 +6823,7 @@
#: ../raster/r.random.surface/main.c:102
#, fuzzy
msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
-msgstr ""
-"Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
+msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
#: ../raster/r.random.surface/main.c:108
msgid "Maximum cell value of distribution"
@@ -7343,9 +6925,7 @@
#: ../raster/r.statistics3/main.c:469
#, fuzzy, c-format
msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
-"Spalten (%d) in der Eingabe überein."
+msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
#: ../raster/r.statistics3/main.c:478 ../raster/r.statistics2/main.c:180
#, fuzzy
@@ -7399,9 +6979,7 @@
#: ../raster/r.shaded.relief2/main.c:147
#, fuzzy
msgid "Scale factor for converting meters to elevation units"
-msgstr ""
-"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
-"Höheneinheiten"
+msgstr "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu Höheneinheiten"
#: ../raster/r.shaded.relief2/main.c:154
#, fuzzy
@@ -7446,12 +7024,8 @@
msgstr ""
#: ../raster/r.in.xyz/main.c:164
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
-"univariater Statistik."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
#: ../raster/r.in.xyz/main.c:168
msgid "ASCII file containing input data (or \"-\" to read from stdin)"
@@ -7480,8 +7054,7 @@
#: ../raster/r.in.xyz/main.c:199
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
+msgstr "Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
#: ../raster/r.in.xyz/main.c:207
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
@@ -7494,9 +7067,7 @@
msgstr "Spaltenummer der Daten in der Eingabedatei."
#: ../raster/r.in.xyz/main.c:217
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
msgstr ""
#: ../raster/r.in.xyz/main.c:226 ../raster/r.in.lidar/main.c:195
@@ -7541,18 +7112,13 @@
#: ../raster/r.in.xyz/main.c:286 ../raster/r.in.lidar/main.c:228
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der gröÃsten "
-"Beobachtungen."
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+msgstr "Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der gröÃsten Beobachtungen."
#: ../raster/r.in.xyz/main.c:291 ../raster/r.in.lidar/main.c:238
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
msgid "Scan data file for extent then exit"
-msgstr ""
-"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
+msgstr "Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
#: ../raster/r.in.xyz/main.c:296 ../raster/r.in.lidar/main.c:244
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
@@ -7587,17 +7153,12 @@
#: ../raster/r.in.xyz/main.c:485 ../raster/r.in.lidar/main.c:528
#, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
-"value lower than 100."
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
msgstr ""
#: ../raster/r.in.xyz/main.c:537
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang "
-"ausgeführt werden."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang ausgeführt werden."
#: ../raster/r.in.xyz/main.c:543
#, fuzzy
@@ -7618,12 +7179,10 @@
#: ../raster/r.in.xyz/main.c:1172 ../raster/r.in.xyz/main.c:1180
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe "
-"die folgenden Zeichen in Zeile %lu gefunden:\n"
+"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe die folgenden Zeichen in Zeile %lu gefunden:\n"
"[%s]"
#: ../raster/r.in.xyz/main.c:661 ../raster/r.in.xyz/main.c:1176
@@ -7675,11 +7234,8 @@
msgstr "vollständig"
#: ../raster/r.composite/main.c:75
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten "
-"Rasterkarte."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten Rasterkarte."
#: ../raster/r.composite/main.c:89 ../raster/r.out.ppm3/main.c:63
#, c-format
@@ -7736,9 +7292,7 @@
#: ../raster/r.solute.transport/main.c:79
#, fuzzy
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
#: ../raster/r.solute.transport/main.c:85
@@ -7765,14 +7319,11 @@
msgstr "Wasserquellen und -senken [m^3/s]."
#: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
msgstr ""
#: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
msgstr ""
#: ../raster/r.solute.transport/main.c:117
@@ -7793,27 +7344,19 @@
#: ../raster/r.solute.transport/main.c:132
#, fuzzy
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
-msgstr ""
-"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
-"diese Karte geschrieben."
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
+msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
#: ../raster/r.solute.transport/main.c:140
#, fuzzy
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
msgstr ""
"Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
"und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
#: ../raster/r.solute.transport/main.c:147
#, fuzzy
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
msgstr ""
@@ -7827,9 +7370,7 @@
msgstr ""
#: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
msgstr ""
#: ../raster/r.solute.transport/main.c:187
@@ -7847,20 +7388,14 @@
#: ../raster/r.solute.transport/main.c:233
#, fuzzy
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
-"Programm zur numerischen Berechnung von transienten, beschränkten und "
-"unbeschränkten Grundwasserfluss in zwei Dimensionen."
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
+msgstr "Programm zur numerischen Berechnung von transienten, beschränkten und unbeschränkten Grundwasserfluss in zwei Dimensionen."
#: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:219
#: ../raster/r.topidx/main.c:53
#, c-format
msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-"Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die "
-"Karte zuerst."
+msgstr "Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die Karte zuerst."
#: ../raster/r.solute.transport/main.c:258
msgid "The direct LU solver do not work with sparse matrices"
@@ -7868,8 +7403,7 @@
#: ../raster/r.solute.transport/main.c:260
msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr ""
-"Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
#: ../raster/r.solute.transport/main.c:370
#, c-format
@@ -7893,8 +7427,7 @@
#: ../raster/r.solute.transport/main.c:385
#, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
msgstr ""
#: ../raster/r.solute.transport/main.c:397
@@ -7913,18 +7446,12 @@
msgstr "Volumen"
#: ../raster/r.volume/main.c:61
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
-"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
#: ../raster/r.volume/main.c:67
msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-"Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen "
-"aufsummiert werden."
+msgstr "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen aufsummiert werden."
#: ../raster/r.volume/main.c:73
msgid "Existing raster map, preferably the output of r.clump"
@@ -7953,23 +7480,17 @@
#: ../raster/r.gwflow/main.c:62
#, fuzzy
-msgid ""
-"Name of input raster map providing Boundary condition status: 0-inactive, 1-"
-"active, 2-dirichlet"
+msgid "Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
msgstr "Status der Randbedingungen, 0-inaktive, 1-aktive, 2-dirichlet."
#: ../raster/r.gwflow/main.c:67
#, fuzzy
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster/r.gwflow/main.c:72
#, fuzzy
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster/r.gwflow/main.c:77
@@ -7978,9 +7499,7 @@
#: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity "
-"for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
msgstr ""
#: ../raster/r.gwflow/main.c:86
@@ -7994,14 +7513,12 @@
#: ../raster/r.gwflow/main.c:92
#, fuzzy
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
msgstr "Untere Oberfläche wasserführende Schicht [m]."
#: ../raster/r.gwflow/main.c:96
#, fuzzy
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
#: ../raster/r.gwflow/main.c:100
@@ -8011,18 +7528,14 @@
#: ../raster/r.gwflow/main.c:106
#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
msgstr ""
#: ../raster/r.gwflow/main.c:112
#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
msgstr ""
@@ -8045,44 +7558,31 @@
#: ../raster/r.gwflow/main.c:140
#, fuzzy
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
msgstr "Wasserstand des Flusses (head) mit Sicker-Verbindung [m]."
#: ../raster/r.gwflow/main.c:147
#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
msgstr "Sicker-Koeffizient des Flussbettes [1/s]."
#: ../raster/r.gwflow/main.c:155
#, fuzzy
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
msgstr "Höhe der Drainage [m]."
#: ../raster/r.gwflow/main.c:162
#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
msgstr "Sicker-Koeffizient der Drainage [1/s]."
#: ../raster/r.gwflow/main.c:173
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear "
-"equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
msgstr ""
#: ../raster/r.gwflow/main.c:209
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
#: ../raster/r.gwflow/main.c:234
msgid "Please provide river_head, river_leak and river_bed maps"
@@ -8094,11 +7594,8 @@
#: ../raster/r.gwflow/main.c:258
#, fuzzy
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full "
-"filled quadratic matrix, flag -f."
-msgstr ""
-"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
+msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
#: ../raster/r.gwflow/main.c:288
#, fuzzy, c-format
@@ -8127,20 +7624,12 @@
#: ../raster/r.topidx/main.c:42
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines "
-"digitalen Höhenmodells."
+msgstr "Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines digitalen Höhenmodells."
#: ../raster/r.topidx/file_io.c:35
#, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
-msgstr ""
-"Die Auflösung der aktuellen Region [%s x %s] ist feiner als die Auflösung "
-"der Eingabekarte [%s x %s]. Die Auflösungen der aktuellen Region muss "
-"identisch oder gröber sein als die der Eingabekarte."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
+msgstr "Die Auflösung der aktuellen Region [%s x %s] ist feiner als die Auflösung der Eingabekarte [%s x %s]. Die Auflösungen der aktuellen Region muss identisch oder gröber sein als die der Eingabekarte."
#: ../raster/r.topidx/file_io.c:42
msgid "Reading elevation map..."
@@ -8156,16 +7645,8 @@
msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
#: ../raster/r.ros/main.c:215
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der "
-"(rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) "
-"Geschwindigkeit, 3) die Richtung der gröÃten Ausbreitungsgeschwindigkeit und "
-"optional 4) die maximale Entdeckungsentfernung."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der (rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) Geschwindigkeit, 3) die Richtung der gröÃten Ausbreitungsgeschwindigkeit und optional 4) die maximale Entdeckungsentfernung."
#: ../raster/r.ros/main.c:222
msgid "Name of raster map containing fuel MODELs"
@@ -8173,29 +7654,23 @@
#: ../raster/r.ros/main.c:228
msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:234
msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:240
msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:245
msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:251
msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
-msgstr ""
-"min]."
+msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min]."
#: ../raster/r.ros/main.c:257
msgid "Name of raster map containing wind DIRECTIONs (degree)"
@@ -8207,15 +7682,11 @@
#: ../raster/r.ros/main.c:269
msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-"Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom "
-"Osten]."
+msgstr "Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom Osten]."
#: ../raster/r.ros/main.c:274
msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem "
-"Schalter -s)."
+msgstr "Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem Schalter -s)."
#: ../raster/r.ros/main.c:277
#, fuzzy
@@ -8227,23 +7698,17 @@
msgstr "Auch die maximale Entdeckungsentfernung berechnen."
#: ../raster/r.ros/main.c:296
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
msgstr ""
#: ../raster/r.ros/main.c:320
#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
msgstr ""
#: ../raster/r.ros/main.c:325
#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
msgstr ""
#: ../raster/r.ros/main.c:339
@@ -8273,11 +7738,8 @@
#: ../raster/r.in.arc/main.c:63
#, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr ""
-"Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
-"GRASS Rasterkarte."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
#: ../raster/r.in.arc/main.c:67
#, fuzzy
@@ -8348,12 +7810,8 @@
msgstr "Einzugsgebiet Durchgang %d"
#: ../raster/r.fill.dir/main.c:89
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtert und generiert ein depressionsloses Höhenmodell und eine "
-"FlieÃrichtungskarte auf Basis eines gegebenen Höhenmodells."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtert und generiert ein depressionsloses Höhenmodell und eine FlieÃrichtungskarte auf Basis eines gegebenen Höhenmodells."
#: ../raster/r.fill.dir/main.c:105
#, fuzzy
@@ -8509,9 +7967,7 @@
#: ../raster/r.statistics2/main.c:104
#, fuzzy
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
msgstr "Berechnet kategorie- oder objektorientierte Statistik."
#: ../raster/r.statistics2/main.c:177
@@ -8556,8 +8012,7 @@
#: ../raster/r.out.arc/main.c:93
msgid "Use cell center reference in header instead of cell corner"
-msgstr ""
-"Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
+msgstr "Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
#: ../raster/r.rescale/main.c:51
msgid "Rescales the range of category values in a raster map layer."
@@ -8579,12 +8034,8 @@
msgstr "1 Klasse gefunden."
#: ../raster/r.clump/main.c:50
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch "
-"diskreter Areale zu eindeutigen Kategorie gruppiert werden."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch diskreter Areale zu eindeutigen Kategorie gruppiert werden."
#: ../raster/r.clump/main.c:96
#, c-format
@@ -8612,9 +8063,7 @@
msgstr "Eingabe-Vektorkarte mit Linien."
#: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
msgstr ""
#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
@@ -8709,16 +8158,12 @@
#: ../raster/r.colors/edit_colors.c:168
#, fuzzy, c-format
msgid "Options <%s> or <%s> must be specified"
-msgstr ""
-"Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder "
-"\"rules\" muss angegeben werden!"
+msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
#: ../raster/r.colors/edit_colors.c:181
#, fuzzy, c-format
msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
#: ../raster/r.colors/edit_colors.c:186
#, fuzzy, c-format
@@ -8798,8 +8243,7 @@
#: ../raster/r.colors/rules.c:40
#, c-format
msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
+msgstr "Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
#: ../raster/r.colors/rules.c:49
#, c-format
@@ -8817,8 +8261,7 @@
"Your color rules do not cover the whole range of data!\n"
" (rules %f to %f but data %f to %f)"
msgstr ""
-"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten "
-"Wertebereich!\n"
+"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten Wertebereich!\n"
"(Regelsatz: %f - %f aber Daten: %f - %f)"
#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
@@ -8873,9 +8316,7 @@
#: ../raster/r.colors/stats.c:73
msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-"Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null "
-"enthält."
+msgstr "Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null enthält."
#: ../raster/r.colors/stats.c:118
msgid "Error opening 3d raster map"
@@ -8904,20 +8345,15 @@
#: ../raster/r.to.rast3/main.c:201
msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
+msgstr "Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
#: ../raster/r.to.rast3/main.c:213
msgid "No output map"
msgstr "Keine Ausgabekarte angegeben."
#: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-"Die 2D- und 3D-Regionsparameter sind unterschiedlich. Werde die Parameter "
-"der 3D-Region verwenden, um die 2D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr "Die 2D- und 3D-Regionsparameter sind unterschiedlich. Werde die Parameter der 3D-Region verwenden, um die 2D-Region anzupassen."
#: ../raster/r.to.rast3/main.c:262
#, c-format
@@ -8926,8 +8362,7 @@
#: ../raster/r.to.rast3/main.c:275
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
+msgstr "Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
msgid "Creating 3D raster map"
@@ -8952,23 +8387,8 @@
msgstr "Modell der Sonnen-Strahlungsdichte und -Strahlungssumme."
#: ../raster/r.sun/main.c:234
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für "
-"einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische "
-"Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, "
-"extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der "
-"Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, "
-"daraus wird der Einfallswinkel der Strahlung und/oder die "
-"Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann "
-"eingebunden werden."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, daraus wird der Einfallswinkel der Strahlung und/oder die Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann eingebunden werden."
#: ../raster/r.sun/main.c:248 ../raster/r.horizon/main.c:197
msgid "Name of the input elevation raster map [meters]"
@@ -8988,38 +8408,29 @@
#: ../raster/r.horizon/main.c:255 ../raster/r.horizon/main.c:263
#: ../raster/simwe/r.sim.sediment/main.c:175
#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Input_options"
+#, fuzzy
+msgid "Input options"
msgstr "Eingabe Optionen"
#: ../raster/r.sun/main.c:257
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des "
-"Sonnenstandes) [in Dezimalgrad]."
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des Sonnenstandes) [in Dezimalgrad]."
#: ../raster/r.sun/main.c:266
msgid "A single value of the orientation (aspect), 270 is south"
msgstr "Ein einzelner Wert für die Orientierung (aspect), 270 ist Süden."
#: ../raster/r.sun/main.c:275
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder "
-"Sonnenstandsinklination) [in Grad]."
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder Sonnenstandsinklination) [in Grad]."
#: ../raster/r.sun/main.c:283
msgid "A single value of inclination (slope)"
msgstr "Ein einzelner Wert für die Inklination (slope)."
#: ../raster/r.sun/main.c:292
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
#: ../raster/r.sun/main.c:302
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -9043,20 +8454,13 @@
#: ../raster/r.sun/main.c:350
#, fuzzy
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
-msgstr ""
-"Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' "
-"Sonneneinstrahlung [-]."
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
+msgstr "Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' Sonneneinstrahlung [-]."
#: ../raster/r.sun/main.c:359
#, fuzzy
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr ""
-"Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' "
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgstr "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' Sonneneinstrahlung [-]."
#: ../raster/r.sun/main.c:367
msgid "The horizon information input map prefix"
@@ -9076,44 +8480,29 @@
#: ../raster/r.horizon/main.c:272 ../raster/r.horizon/main.c:282
#: ../raster/r.horizon/main.c:290 ../raster/simwe/r.sim.sediment/main.c:168
#: ../raster/simwe/r.sim.water/main.c:216
-msgid "Output_options"
+#, fuzzy
+msgid "Output options"
msgstr "Ausgabe Optionen"
#: ../raster/r.sun/main.c:393
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh."
-"m-2.day-1] (Modus 2)."
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
#: ../raster/r.sun/main.c:402
msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr "Ausgabe-Rasterkarte der Sonneneinstrahlungszeit [in h] (nur Modus 2)."
#: ../raster/r.sun/main.c:411
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder "
-"der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
#: ../raster/r.sun/main.c:420
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh."
-"m-2.day1] (Modus 2)."
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh.m-2.day1] (Modus 2)."
#: ../raster/r.sun/main.c:429
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) "
-"oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
#: ../raster/r.sun/main.c:436
msgid "No. of day of the year (1-365)"
@@ -9121,20 +8510,15 @@
#: ../raster/r.sun/main.c:445
msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-"
-"Stunden]."
+msgstr "Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-Stunden]."
#: ../raster/r.sun/main.c:452
msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Deklinationswert (überschreibt den intern berechneten Wert) [BogenmaÃ]."
+msgstr "Deklinationswert (überschreibt den intern berechneten Wert) [BogenmaÃ]."
#: ../raster/r.sun/main.c:460
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-"
-"Stunden]"
+msgstr "Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-Stunden]"
#: ../raster/r.sun/main.c:483 ../raster/r.horizon/main.c:289
msgid "Sampling distance step coefficient (0.5-1.5)"
@@ -9146,149 +8530,118 @@
#: ../raster/r.sun/main.c:498
msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
-"Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit "
-"verwendet."
+msgstr "Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit verwendet."
#: ../raster/r.sun/main.c:504
-msgid "Incorporate the shadowing effect of terrain"
+#, fuzzy
+msgid "Do not incorporate the shadowing effect of terrain"
msgstr "Berücksichtige den Schatteneffekt der Oberfläche."
#: ../raster/r.sun/main.c:509
msgid "Use the low-memory version of the program"
msgstr "Verwende die Version des Programms mit geringem Speicherverbrauch. "
-#: ../raster/r.sun/main.c:556
+#: ../raster/r.sun/main.c:550
msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-"Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit "
-"verwenden."
+msgstr "Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit verwenden."
-#: ../raster/r.sun/main.c:559
+#: ../raster/r.sun/main.c:553
msgid "Error reading civil time zone value"
msgstr "Fehler beim Lesen der Zeitzone."
-#: ../raster/r.sun/main.c:562
+#: ../raster/r.sun/main.c:556
msgid "Invalid civil time zone value"
msgstr "Ungültiger Wert der Zeitzone."
-#: ../raster/r.sun/main.c:587
+#: ../raster/r.sun/main.c:581
msgid "insol_time and incidout are incompatible options"
msgstr "insol_time und indcidout sind nicht kompatible Optionen."
-#: ../raster/r.sun/main.c:592
+#: ../raster/r.sun/main.c:586
msgid "Error reading time step size"
msgstr "Fehler beim Lesen der ZeitschrittgröÃe."
-#: ../raster/r.sun/main.c:594
+#: ../raster/r.sun/main.c:588
msgid "Invalid time step size"
msgstr "Ungültige ZeitschrittgröÃe."
-#: ../raster/r.sun/main.c:598
+#: ../raster/r.sun/main.c:592
msgid "Error reading horizon step size"
msgstr "Fehler beim Lesen der Horizont-SchrittgröÃe."
-#: ../raster/r.sun/main.c:602
+#: ../raster/r.sun/main.c:596
msgid "The horizon step size must be greater than 0."
msgstr "Die Horizont-SchrittgröÃe muss gröÃer sein als 0."
-#: ../raster/r.sun/main.c:605
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-"
-"Parameter angeben."
+#: ../raster/r.sun/main.c:599
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-Parameter angeben."
-#: ../raster/r.sun/main.c:611
+#: ../raster/r.sun/main.c:605
msgid "Time and insol_time are incompatible options"
msgstr "Time und insol_time sind nicht kompatible Optionen."
-#: ../raster/r.sun/main.c:613
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
-"bekannter lokaler Zeit"
+#: ../raster/r.sun/main.c:607
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
-#: ../raster/r.sun/main.c:618
+#: ../raster/r.sun/main.c:612
msgid "incidout requires time parameter to be set"
msgstr "incidout benötigt den Zeit-Parameter."
-#: ../raster/r.sun/main.c:620
+#: ../raster/r.sun/main.c:614
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr "Modus 2: integrierte tägliche Strahlung für einen Tag des Jahres"
-#: ../raster/r.sun/main.c:666
+#: ../raster/r.sun/main.c:660
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-"Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 "
-"sein."
+msgstr "Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 sein."
-#: ../raster/r.sun/main.c:679
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen "
-"vorher berechneten Horizont verwenden."
+#: ../raster/r.sun/main.c:673
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen vorher berechneten Horizont verwenden."
-#: ../raster/r.sun/main.c:724 ../display/d.where/main.c:107
+#: ../raster/r.sun/main.c:718 ../display/d.where/main.c:107
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
-msgstr ""
-"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
-#: ../raster/r.sun/main.c:728 ../raster/r.horizon/main.c:476
+#: ../raster/r.sun/main.c:722 ../raster/r.horizon/main.c:476
#: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:250
#: ../general/g.region/printwindow.c:506 ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
msgstr "Kann die Projektionseinheit der aktuellen Location nicht ermitteln."
-#: ../raster/r.sun/main.c:732 ../raster/r.horizon/main.c:480
+#: ../raster/r.sun/main.c:726 ../raster/r.horizon/main.c:480
#: ../ps/ps.map/do_geogrid.c:272 ../display/d.where/main.c:113
#: ../display/d.grid/plot.c:335 ../general/g.region/printwindow.c:253
#: ../general/g.region/printwindow.c:509 ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
msgstr "Kann die Projektionsinformationen der aktuellen Location nicht holen."
-#: ../raster/r.sun/main.c:742 ../raster/r.horizon/main.c:490
+#: ../raster/r.sun/main.c:736 ../raster/r.horizon/main.c:490
#: ../imagery/i.latlong/main.c:114 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
#: ../display/d.grid/plot.c:342 ../display/d.grid/plot.c:369
msgid "Unable to set up lat/long projection parameters"
msgstr "Kann LL-Projektionsparameter nicht einrichten."
-#: ../raster/r.sun/main.c:746
+#: ../raster/r.sun/main.c:740
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-"Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon "
-"Location."
+msgstr "Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon Location."
-#: ../raster/r.sun/main.c:751
+#: ../raster/r.sun/main.c:745
msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-"Entweder müssen die beiden Rasterkarten latin und longin oder keine von "
-"beiden angegeben werden."
+msgstr "Entweder müssen die beiden Rasterkarten latin und longin oder keine von beiden angegeben werden."
#: ../raster/r.le/r.le.patch/main.c:50
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Berechnet Attribute, Patch-GröÃe, Kerngebiets-GröÃe, Form, Fraktale "
-"Dimension und Umfang für ein Satz von Patches in einer Landschaft."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Berechnet Attribute, Patch-GröÃe, Kerngebiets-GröÃe, Form, Fraktale Dimension und Umfang für ein Satz von Patches in einer Landschaft."
#: ../raster/r.le/r.le.trace/main.c:57
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt "
-"auÃerdem die Attribute, GröÃe, Umfang und Form Indices jedes Patches und "
-"speichert die Daten in eine Ausgabedatei."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt auÃerdem die Attribute, GröÃe, Umfang und Form Indices jedes Patches und speichert die Daten in eine Ausgabedatei."
#: ../raster/r.le/r.le.trace/main.c:551 ../raster/r.random/random.c:43
#: ../raster/r.random/random.c:47 ../raster/r.mapcalc/map3.c:515
@@ -9319,12 +8672,8 @@
msgstr "Name der Ausgabedatei zum Speichern des Reports."
#: ../raster/r.le/r.le.setup/main.c:59
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, "
-"der von den anderen r.le-Progammen verwendet wird. "
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, der von den anderen r.le-Progammen verwendet wird. "
#: ../raster/r.le/r.le.setup/main.c:63
msgid "Raster map to use to setup sampling"
@@ -9339,12 +8688,8 @@
msgstr "Kann Vektor nicht lesen."
#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Beinhaltet ein Satz von MaÃen für Attribute, Diversität, Textur, "
-"Nebeneinanderstellung und Kanten"
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Beinhaltet ein Satz von MaÃen für Attribute, Diversität, Textur, Nebeneinanderstellung und Kanten"
#: ../raster/r.digit/get_label.c:31
#, c-format
@@ -9361,18 +8706,12 @@
msgstr "Sieht gut so aus?"
#: ../raster/r.digit/main.c:46
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der "
-"Maus zeichnet und als Rasterkarte speichert."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der Maus zeichnet und als Rasterkarte speichert."
#: ../raster/r.digit/main.c:55
msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-"Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt "
-"durch ';')."
+msgstr "Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt durch ';')."
#: ../raster/r.digit/main.c:78
msgid "No graphics device selected!"
@@ -9430,9 +8769,7 @@
#: ../raster/r.surf.contour/main.c:64
#, fuzzy
msgid "Generates surface raster map from rasterized contours."
-msgstr ""
-"Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
-"Höheninformationen."
+msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
#: ../raster/r.surf.contour/main.c:67
#, fuzzy
@@ -9500,18 +8837,12 @@
#: ../raster/r.in.bin/main.c:426
msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr ""
-"Entweder alle oder keine Angabe von north=, south=, east= and west= müssen "
-"angegeben werden"
+msgstr "Entweder alle oder keine Angabe von north=, south=, east= and west= müssen angegeben werden"
#: ../raster/r.in.bin/main.c:464
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
-msgstr ""
-"Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich "
-"wesentlich. Haben Sie east= and west= korrekt gesetzt?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgstr "Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich wesentlich. Haben Sie east= and west= korrekt gesetzt?"
#: ../raster/r.in.bin/main.c:487
msgid "File Size %"
@@ -9537,12 +8868,8 @@
#: ../raster/r.kappa/main.c:72
#, fuzzy
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
-"(accuracy assessment) der Klassifikationsergebnisse."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
#: ../raster/r.kappa/main.c:78
msgid "Name of raster map containing classification result"
@@ -9571,7 +8898,7 @@
#: ../locale/scriptstrings/r.unpack_to_translate.c:9
#, fuzzy
msgid "Output settings"
-msgstr "Ausgabe Optionen"
+msgstr "Wolkeneinstellungen"
#: ../raster/r.kappa/main.c:96
msgid "Title for error matrix and kappa"
@@ -9608,16 +8935,12 @@
#: ../raster/r.kappa/calc_kappa.c:32
#, c-format
msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
-"Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter "
-"zu schreiben."
+msgstr "Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter zu schreiben."
#: ../raster/r.kappa/prt_mat.c:39
#, c-format
msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
-"Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) "
-"zu schreiben."
+msgstr "Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) zu schreiben."
#: ../raster/r.out.png/main.c:116
#, fuzzy
@@ -9634,8 +8957,7 @@
#: ../raster/r.out.png/main.c:131
msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
-"(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
+msgstr "(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
#: ../raster/r.out.png/main.c:138
msgid "Make NULL cells transparent"
@@ -9680,14 +9002,8 @@
msgstr "Kann Worldfile nicht zum Schreiben öffnen."
#: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Reinterpoliert und berechnet ggf. topographische Analysen basierend auf "
-"einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von "
-"regularized splines with tension and smoothing (RST)."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Reinterpoliert und berechnet ggf. topographische Analysen basierend auf einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von regularized splines with tension and smoothing (RST)."
#: ../raster/r.resamp.rst/main.c:162
msgid "Desired east-west resolution"
@@ -9759,8 +9075,7 @@
#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:166
msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-"Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
+msgstr "Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
#: ../raster/r.resamp.rst/main.c:313
#, fuzzy
@@ -9807,9 +9122,7 @@
#: ../raster/r.resamp.rst/main.c:389
msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-"Auflösung der Eingabekarte unterscheidet sich von der aktuellen "
-"Regionsauflösung!"
+msgstr "Auflösung der Eingabekarte unterscheidet sich von der aktuellen Regionsauflösung!"
#: ../raster/r.resamp.rst/main.c:407
msgid "Processing all selected output files will require"
@@ -9868,8 +9181,7 @@
#: ../raster/r.resamp.rst/main.c:526
#, fuzzy
msgid "Unable to write raster maps -- try increasing cell size"
-msgstr ""
-"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
#: ../raster/r.resamp.rst/main.c:558 ../vector/v.surf.rst/main.c:826
#, fuzzy, c-format
@@ -9886,8 +9198,7 @@
#: ../raster/r.quantile/main.c:285
msgid "Generate recode rules based on quantile-defined intervals."
-msgstr ""
-"Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
+msgstr "Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
#: ../raster/r.quantile/main.c:313
#, fuzzy
@@ -9933,22 +9244,17 @@
#: ../raster/r.compress/main.c:110
#, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
-"[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
-"dekomprimieren."
+msgstr "[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht dekomprimieren."
#: ../raster/r.compress/main.c:112
#, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
-"<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
-"komprimieren."
+msgstr "<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht komprimieren."
#: ../raster/r.compress/main.c:117
#, c-format
msgid "[%s] is a GDAL-linked map - can't (un)compress"
-msgstr ""
-"[%s] ist eine per GDAL verknüpfte Karte - kann nicht (de)komprimieren."
+msgstr "[%s] ist eine per GDAL verknüpfte Karte - kann nicht (de)komprimieren."
#: ../raster/r.compress/main.c:159
#, c-format
@@ -10013,22 +9319,16 @@
msgstr "Die Statistiken für <%s> wurde aktualisiert."
#: ../raster/r.spreadpath/main.c:93
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
-"denen der kumulative Weg bestimmt wurde."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von denen der kumulative Weg bestimmt wurde."
#: ../raster/r.spreadpath/main.c:102
msgid "Name of raster map containing back-path easting information"
-msgstr ""
-"Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
+msgstr "Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
#: ../raster/r.spreadpath/main.c:110
msgid "Name of raster map containing back-path northing information"
-msgstr ""
-"Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
+msgstr "Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
#: ../raster/r.spreadpath/main.c:118
msgid "The map E and N grid coordinates of starting points"
@@ -10096,12 +9396,8 @@
msgstr "Abtast-Methode (sampling)."
#: ../raster/r.random/main.c:56
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
-"Punkte enthalten."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete Punkte enthalten."
#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
#: ../imagery/i.zc/main.c:65
@@ -10178,8 +9474,7 @@
#: ../raster/r.grow.distance/main.c:152
#, fuzzy
msgid "Generates a raster map of distance to features in input raster map."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
#: ../raster/r.grow.distance/main.c:159
#, fuzzy
@@ -10286,8 +9581,7 @@
#: ../raster/r.report/parse.c:104 ../raster/r.stats/main.c:134
msgid "Number of fp subranges to collect stats from"
-msgstr ""
-"Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
+msgstr "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
#: ../raster/r.report/parse.c:105 ../raster/r.report/parse.c:133
#: ../raster/r.report/parse.c:139
@@ -10320,9 +9614,7 @@
#: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:198
msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Lese FlieÃkommakarte als Integerkarte (benutze Quantisierungsregeln der "
-"Karte)."
+msgstr "Lese FlieÃkommakarte als Integerkarte (benutze Quantisierungsregeln der Karte)."
#: ../raster/r.report/parse.c:181
msgid "nsteps has to be > 0; using nsteps=255"
@@ -10380,8 +9672,7 @@
#: ../raster/r.out.pov/main.c:180
#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-"Die Rasterkarte ist zu groÃ! Sie hat mehr als %d Spalten oder %d Zeilen."
+msgstr "Die Rasterkarte ist zu groÃ! Sie hat mehr als %d Spalten oder %d Zeilen."
#: ../raster/r.out.pov/main.c:201
msgid "Negative elevation values in input"
@@ -10438,28 +9729,20 @@
msgstr "Verarbeite Zeilen... "
#: ../raster/r.carve/enforce_ds.c:174
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist "
-"leider noch nicht implementiert!"
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist leider noch nicht implementiert!"
#: ../raster/r.carve/lobf.c:74
msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"Versuche durch 0 zu teilen... Keine eindeutige Lösung...Ãbergehe das..."
+msgstr "Versuche durch 0 zu teilen... Keine eindeutige Lösung...Ãbergehe das..."
#: ../raster/r.carve/main.c:76
msgid "Generates stream channels."
msgstr ""
#: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat "
-"und subtrahiert die Tiefe vom Ausgabe-DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat und subtrahiert die Tiefe vom Ausgabe-DEM."
#: ../raster/r.carve/main.c:82
msgid "Name of input raster elevation map"
@@ -10534,19 +9817,12 @@
#: ../raster/r.out.tiff/main.c:174
#, fuzzy, c-format
-msgid ""
-"Raster map <%s>> is a floating point map. Fractional values will be rounded "
-"to integer"
-msgstr ""
-"Die Rasterkarte <%s> im Mapset <%s> ist eine FlieÃkommakarte. "
-"Nachkommastellen werden auf ganze Zahlen gerundet!"
+msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
+msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine FlieÃkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
#: ../raster/r.out.tiff/main.c:180
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
#: ../raster/r.out.tiff/main.c:194
#, c-format
@@ -10595,15 +9871,11 @@
#: ../raster/r.null/main.c:96
msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-"Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei "
-"existiert."
+msgstr "Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei existiert."
#: ../raster/r.null/main.c:102
msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-"Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
-"erklärt."
+msgstr "Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig erklärt."
#: ../raster/r.null/main.c:106
msgid "Remove NULL-value bitmap file"
@@ -10611,13 +9883,8 @@
#: ../raster/r.null/main.c:125
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
-msgstr ""
-"Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. "
-"Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu "
-"erzeugen. Beende mich."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgstr "Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu erzeugen. Beende mich."
#: ../raster/r.null/main.c:131
#, c-format
@@ -10723,11 +9990,8 @@
msgstr "Anzahl der Interpolationspunkte."
#: ../raster/r.surf.idw2/main.c:84
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie "
-"stattdessen r.surf.idw."
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie stattdessen r.surf.idw."
#: ../raster/r.surf.idw2/main.c:88
#, c-format
@@ -10753,9 +10017,7 @@
#: ../db/db.select/main.c:236
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
-"Name der Ausgabekarte (wenn keiner oder \"-\" angegeben wurdeerfolgt die "
-"Ausgabe nach stdout)."
+msgstr "Name der Ausgabekarte (wenn keiner oder \"-\" angegeben wurdeerfolgt die Ausgabe nach stdout)."
#: ../raster/r.stats/main.c:125 ../raster/r.describe/main.c:68
msgid "String representing no data cell value"
@@ -10779,8 +10041,7 @@
#: ../raster/r.stats/main.c:160
msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
+msgstr "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
#: ../raster/r.stats/main.c:165
msgid "Print category labels"
@@ -10821,30 +10082,18 @@
#: ../raster/r.stats/main.c:277
#, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die "
-"Option '%s' werden ignoriert."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die Option '%s' werden ignoriert."
#: ../raster/r.stats/main.c:293
#, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten "
-"Beschriftungen. Verwende %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten Beschriftungen. Verwende %s=%d."
#: ../raster/r.stats/main.c:299
#, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der "
-"Rasterkarte <%s> und ignoriere die Option '%s'."
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der Rasterkarte <%s> und ignoriere die Option '%s'."
#: ../raster/r.region/main.c:54
msgid "Sets the boundary definitions for a raster map."
@@ -10922,8 +10171,7 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-"zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
+msgstr "zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
msgid "Extended"
@@ -10950,22 +10198,16 @@
msgstr "Tabellenausgabeformat anstatt Standardausgabeformat"
#: ../raster/r.univar/r.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
#: ../raster/r.univar/r3.univar_main.c:37
msgid "3D Raster map used for zoning, must be of type CELL"
msgstr "3D-Rasterkarte für Zonenbildung, muss vom Typ CELL sein."
#: ../raster/r.univar/r3.univar_main.c:101
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-"
-"Rasterkarte."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-Rasterkarte."
#: ../raster/r.describe/main.c:57
msgid "Prints terse list of category values found in a raster map layer."
@@ -11077,9 +10319,7 @@
#: ../raster/r.in.lidar/main.c:164
#, fuzzy
msgid "Create a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
-"univariater Statistik."
+msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
#: ../raster/r.in.lidar/main.c:168
#, fuzzy
@@ -11089,9 +10329,7 @@
#: ../raster/r.in.lidar/main.c:234 ../vector/v.in.ogr/main.c:256
#: ../vector/v.in.lidar/main.c:202
msgid "Override dataset projection (use location's projection)"
-msgstr ""
-"Ãbersteuere die Projektion des Datensatzes (verwende Projektion der "
-"Location)."
+msgstr "Ãbersteuere die Projektion des Datensatzes (verwende Projektion der Location)."
#: ../raster/r.in.lidar/main.c:263 ../vector/v.in.lidar/main.c:236
#, c-format
@@ -11100,12 +10338,8 @@
#: ../raster/r.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:635
#: ../vector/v.in.lidar/main.c:363
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
-"konvertieren, zwecks Ãberprüfung."
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format konvertieren, zwecks Ãberprüfung."
#: ../raster/r.in.lidar/main.c:311 ../vector/v.in.ogr/main.c:665
#: ../vector/v.in.lidar/main.c:393
@@ -11120,17 +10354,12 @@
"You can use the -o flag to %s to override this projection check.\n"
msgstr ""
"\n"
-"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
-"übersteuern.\n"
+"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu übersteuern.\n"
#: ../raster/r.in.lidar/main.c:374 ../vector/v.in.ogr/main.c:728
#: ../vector/v.in.lidar/main.c:456
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
-"Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
#: ../raster/r.in.lidar/main.c:567
msgid "zrange will not be taken into account during scan"
@@ -11142,36 +10371,25 @@
msgstr "Konnte die Ausgabedate <%s> nicht öffnen."
#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. "
-"Sonnenposition muss direkt eingegeben werden."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. Sonnenposition muss direkt eingegeben werden."
#: ../raster/r.sunmask/g_solposition.c:88
#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-"Angegebener Punkt %f, %f ist auÃerhalb der aktuellen Gebietsausdehnung, ist "
-"dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "Angegebener Punkt %f, %f ist auÃerhalb der aktuellen Gebietsausdehnung, ist dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
#: ../raster/r.sunmask/g_solposition.c:98 ../imagery/i.latlong/main.c:101
msgid "Unable to get projection info of current location"
-msgstr ""
#: ../raster/r.sunmask/g_solposition.c:101 ../imagery/i.latlong/main.c:103
msgid "Unable to get projection units of current location"
-msgstr ""
-"Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
+msgstr "Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
#: ../raster/r.sunmask/g_solposition.c:104 ../imagery/i.latlong/main.c:105
msgid "Unable to get projection key values of current location"
-msgstr ""
-"Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
+msgstr "Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
#: ../raster/r.sunmask/g_solposition.c:127
#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
@@ -11189,18 +10407,12 @@
msgstr "Volumen Position"
#: ../raster/r.sunmask/main.c:119
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
-"Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr "Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
#: ../raster/r.sunmask/main.c:120
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur "
-"Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
#: ../raster/r.sunmask/main.c:134
msgid "Altitude of the sun above horizon, degrees (A)"
@@ -11252,9 +10464,7 @@
#: ../raster/r.sunmask/main.c:200
msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr ""
-"Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit "
-"genutzt"
+msgstr "Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit genutzt"
#: ../raster/r.sunmask/main.c:209
msgid "Easting coordinate (point of interest)"
@@ -11298,12 +10508,8 @@
msgstr "Definiere Sie entweder die Sonnenposition oder Ort/Datum/Zeit."
#: ../raster/r.sunmask/main.c:280
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind "
-"vollständig angegeben."
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind vollständig angegeben."
#: ../raster/r.sunmask/main.c:284
#, c-format
@@ -11311,12 +10517,8 @@
msgstr "Berechne Sonnenposition... (verwende solpos (V. %s) vom NREL)"
#: ../raster/r.sunmask/main.c:289
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-"Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell "
-"anderen Werte)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr "Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell anderen Werte)"
#: ../raster/r.sunmask/main.c:397
msgid "Please correct settings"
@@ -11358,8 +10560,7 @@
#: ../raster/r.sunmask/main.c:454
#, c-format
msgid "Unable to open range file for raster map <%s>"
-msgstr ""
-"Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
+msgstr "Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
#: ../raster/r.sunmask/main.c:470
msgid "Calculating shadows from DEM..."
@@ -11453,8 +10654,7 @@
#: ../raster/r.sunmask/solpos00.c:993
#, c-format
msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr ""
-"S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
+msgstr "S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
#: ../raster/r.regression.line/main.c:49
msgid "Calculates linear regression from two raster maps: y = a + b*x."
@@ -11469,12 +10669,8 @@
msgstr "Karte mit Werten für Y-Koeffizienten."
#: ../raster/r.regression.line/main.c:64
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen "
-"(wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen (wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
#: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:141
#: ../locale/scriptstrings/i.oif_to_translate.c:11
@@ -11564,12 +10760,8 @@
msgstr "c=%d"
#: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren "
-"Spanne vom Benutzer angegeben werden kann."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren Spanne vom Benutzer angegeben werden kann."
#: ../raster/r.surf.random/main.c:47
msgid "Minimum random value"
@@ -11773,11 +10965,8 @@
msgstr ""
#: ../raster/r.li/r.li.patchnum/main.c:35
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
-"Nachbarn-Algorithmus."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.simpson/simpson.c:38
msgid "Calculates Simpson's diversity index on a raster map"
@@ -11802,12 +10991,8 @@
msgstr "Berechnet Pielou-Diversitäts-Index einer Rasterkarte."
#: ../raster/r.li/r.li.mps/mps.c:39
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Berechnet mittleren Patch-GröÃen-Index einer Rasterkarte, unter Verwendung "
-"eines 4-Nachbarn-Algorithmus."
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet mittleren Patch-GröÃen-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.shannon/shannon.c:37
msgid "Calculates Shannon's diversity index on a raster map"
@@ -11826,11 +11011,8 @@
msgstr "Der alpha-Wert ist die GröÃenordnung der generalisierten Entropie"
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.padrange/padrange.c:38
msgid "Calculates range of patch area size on a raster map"
@@ -11880,8 +11062,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:365
#, c-format
msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-"Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
+msgstr "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
#: ../raster/r.li/r.li.daemon/daemon.c:372
msgid "Illegal configuration file (sample area)"
@@ -11911,20 +11092,15 @@
#: ../raster/r.li/r.li.mpa/mpa.c:38
msgid "Calculates mean pixel attribute index on a raster map"
-msgstr ""
-"Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer "
-"Rasterkarte."
+msgstr "Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer Rasterkarte."
#: ../raster/r.li/r.li.padcv/padcv.c:38
msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr "Berechnet Variationskoeffizient der Patch-GröÃen einer Rasterkarte."
#: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.out.ppm/main.c:55
#, fuzzy
@@ -11982,8 +11158,7 @@
#: ../raster/r.random.cells/main.c:66
msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr ""
-"Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
+msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
#: ../raster/r.timestamp/main.c:37 ../vector/v.timestamp/main.c:37
#, fuzzy
@@ -11996,8 +11171,7 @@
#: ../raster/r.timestamp/main.c:39
msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-"Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
+msgstr "Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
#: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:49
msgid "Datetime, datetime1/datetime2, or 'none' to remove"
@@ -12026,17 +11200,12 @@
msgstr "Name der Ausgabe ASCII-Grid Datei (verwende out=- für stdout)."
#: ../raster/r.out.ascii/main.c:90
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-"Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur "
-"beim SURFER oder MODFLOW-Format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr "Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur beim SURFER oder MODFLOW-Format)"
#: ../raster/r.out.ascii/main.c:98
msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
-"Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
+msgstr "Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
#: ../raster/r.out.ascii/main.c:106
msgid "Write SURFER (Golden Software) ASCII grid"
@@ -12077,12 +11246,8 @@
msgstr "Lesen in Zeile %d fehlgeschlagen."
#: ../raster/r.slope.aspect/main.c:153
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-"Ableitungen aus einer Rasterkarte mit Höheninformationen."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen."
#: ../raster/r.slope.aspect/main.c:155
msgid "Aspect is calculated counterclockwise from east."
@@ -12113,18 +11278,12 @@
msgstr "Name der Ausgabe-Rasterkarte mit horizontaler Wölbung."
#: ../raster/r.slope.aspect/main.c:207
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West "
-"Hangneigung)."
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
#: ../raster/r.slope.aspect/main.c:214
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd "
-"Hangneigung)."
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
#: ../raster/r.slope.aspect/main.c:221
msgid "Name for output second order partial derivative dxx raster map"
@@ -12144,24 +11303,16 @@
#: ../raster/r.slope.aspect/main.c:250
msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-"Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet "
-"werden soll."
+msgstr "Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet werden soll."
#: ../raster/r.slope.aspect/main.c:259
msgid "Do not align the current region to the elevation layer"
-msgstr ""
-"Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen "
-"anpassen."
+msgstr "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen anpassen."
#: ../raster/r.slope.aspect/main.c:334
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> oder <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> oder <%s>"
#: ../raster/r.slope.aspect/main.c:356
#, c-format
@@ -12192,8 +11343,7 @@
#: ../raster/r.slope.aspect/main.c:1105
#, c-format
msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr ""
-"minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
+msgstr "minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
#: ../raster/r.slope.aspect/main.c:1158
#, c-format
@@ -12328,9 +11478,7 @@
#: ../raster/r.to.vect/main.c:98
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen "
-"Sequenzen (nur bei CELL-Karten)."
+msgstr "Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen Sequenzen (nur bei CELL-Karten)."
#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
#: ../vector/v.overlay/main.c:128 ../vector/v.overlay/main.c:138
@@ -12351,9 +11499,7 @@
#: ../raster/r.to.vect/main.c:104
#, fuzzy
msgid "Table is not created. Currently supported only for points."
-msgstr ""
-"Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. "
-"Derzeit werden nur Punkte unterstützt."
+msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
#: ../raster/r.to.vect/main.c:110
#, fuzzy
@@ -12363,21 +11509,15 @@
#: ../raster/r.to.vect/main.c:111
#, fuzzy
msgid "Recommended for massive point conversion"
-msgstr ""
-"Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
-"extrem groÃen Punktmengen)."
+msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem groÃen Punktmengen)."
#: ../raster/r.to.vect/main.c:121
msgid "z flag is supported only for points"
msgstr "Der Schalter '-z' wird nur für Punkte unterstützt."
#: ../raster/r.to.vect/main.c:131
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
-msgstr ""
-"Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-"
-"v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+msgstr "Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
#: ../raster/r.to.vect/main.c:209 ../vector/v.random/main.c:195
#: ../vector/v.lrs/v.lrs.create/main.c:327 ../vector/v.in.ascii/main.c:395
@@ -12425,9 +11565,7 @@
msgstr "Extrahiere Punkte ... "
#: ../raster/r.series.interp/main.c:68
-msgid ""
-"Interpolate raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolate raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
msgstr ""
#: ../raster/r.series.interp/main.c:78
@@ -12436,9 +11574,7 @@
msgstr "Kann die Projektionsinformation der Eingabekarte nicht ermitteln."
#: ../raster/r.series.interp/main.c:83
-msgid ""
-"Input file with an input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with an input raster map name and data point position per line, field separator between name and sample point is |"
msgstr ""
#: ../raster/r.series.interp/main.c:95
@@ -12447,9 +11583,7 @@
msgstr "Selektiere Feature..."
#: ../raster/r.series.interp/main.c:99
-msgid ""
-"Input infile with an output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input infile with an output raster map name and sample point position per line, field separator between name and sample point is |"
msgstr ""
#: ../raster/r.series.interp/main.c:109
@@ -12519,8 +11653,7 @@
#: ../raster/r.series.interp/main.c:240
#, fuzzy, c-format
msgid "The number of %s maps and %s point positions must be equal"
-msgstr ""
-"Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
+msgstr "Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
#: ../raster/r.series.interp/main.c:269
#, c-format
@@ -12529,9 +11662,7 @@
#: ../raster/r.series.interp/main.c:289
#, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
msgstr ""
#: ../raster/r.series.interp/main.c:309
@@ -12547,9 +11678,7 @@
#: ../raster/r.out.ppm3/main.c:58
#, fuzzy
msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung "
-"der DERZEITIG EINGESTELLTEN REGION."
+msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
#: ../raster/r.out.ppm3/main.c:83
msgid "Name for new PPM file. (use out=- for stdout)"
@@ -12565,11 +11694,8 @@
#: ../raster/r.resamp.bspline/main.c:85 ../vector/v.surf.bspline/main.c:95
#, fuzzy
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-"Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
#: ../raster/r.resamp.bspline/main.c:93
#, fuzzy
@@ -12587,15 +11713,12 @@
#: ../raster/r.resamp.bspline/main.c:107
#, fuzzy
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
msgstr "Spline-Interpolations-Schrittweite in Ost-West-Richtung."
#: ../raster/r.resamp.bspline/main.c:115
#, fuzzy
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
msgstr "Spline-Interpolations-Schrittweite in Nord-Süd-Richtung"
#: ../raster/r.resamp.bspline/main.c:122 ../vector/v.surf.bspline/main.c:159
@@ -12612,18 +11735,13 @@
msgstr "Behalte NULL-Werte in Ausgabekarte."
#: ../raster/r.resamp.bspline/main.c:143 ../vector/v.surf.bspline/main.c:100
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
-msgstr ""
-"Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" "
-"Kreuzvalidierung."
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgstr "Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" Kreuzvalidierung."
#: ../raster/r.resamp.bspline/main.c:150
#, fuzzy
msgid "Maximum memory to be used (in MB)"
-msgstr ""
-"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
#: ../raster/r.resamp.bspline/main.c:185
#, fuzzy
@@ -12713,9 +11831,7 @@
#: ../raster/r.resamp.bspline/main.c:718
#, fuzzy
msgid "No data within this subregion. Consider increasing the spline step."
-msgstr ""
-"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
-"ändern."
+msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
#: ../raster/r.resamp.bspline/main.c:734 ../vector/v.surf.bspline/main.c:877
msgid "Writing output..."
@@ -12723,9 +11839,7 @@
#: ../raster/r.resamp.bspline/crosscorr.c:160
#, fuzzy, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
msgstr "%d sind zu viele Punkte. Die Kreuzvalidierung würde zu lange dauern."
#: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -12741,11 +11855,8 @@
#: ../raster/r.resamp.bspline/crosscorr.c:193
#: ../vector/v.surf.bspline/crosscorr.c:151
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr ""
-"Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" "
-"\"sin=\") zu ändern."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgstr "Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" \"sin=\") zu ändern."
#: ../raster/r.resamp.bspline/crosscorr.c:211
#, fuzzy, c-format
@@ -12765,20 +11876,14 @@
#: ../raster/r.resamp.bspline/crosscorr.c:313
#: ../vector/v.surf.bspline/crosscorr.c:313
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
-msgstr ""
-"Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die "
-"Kreuzvalidierung angegeben."
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgstr "Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die Kreuzvalidierung angegeben."
#: ../raster/r.resamp.bspline/crosscorr.c:315
#: ../vector/v.surf.bspline/crosscorr.c:315
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-"Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr "Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
#: ../raster/r.resamp.bspline/crosscorr.c:323
msgid "Results into a table:"
@@ -12809,11 +11914,8 @@
msgstr "Vektor, extrahieren"
#: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den "
-"Benutzer festgelegten Linie(n) liegen."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den Benutzer festgelegten Linie(n) liegen."
#: ../raster/r.transect/main.c:110
msgid "Raster map to be queried"
@@ -12900,9 +12002,7 @@
#: ../raster/r.grow/main.c:125 ../locale/scriptstrings/r.grow_to_translate.c:1
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen "
-"Flächen."
+msgstr "Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen Flächen."
#: ../raster/r.grow/main.c:136 ../locale/scriptstrings/r.grow_to_translate.c:4
msgid "Radius of buffer in raster cells"
@@ -12910,9 +12010,7 @@
#: ../raster/r.grow/main.c:152 ../locale/scriptstrings/r.grow_to_translate.c:6
msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr ""
-"Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben "
-"werden."
+msgstr "Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben werden."
#: ../raster/r.grow/main.c:158 ../locale/scriptstrings/r.grow_to_translate.c:7
msgid "Value to write for \"grown\" cells"
@@ -12934,19 +12032,12 @@
msgstr "Fehler beim Lesen der Farb-Datei für <%s>."
#: ../raster/r.neighbors/main.c:145
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
-"Kategoriewerte basierend auf einer FenstergröÃe zu und erstellt neue "
-"Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer FenstergröÃe zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
#: ../raster/r.neighbors/main.c:155
#, fuzzy
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
#: ../raster/r.neighbors/main.c:174 ../vector/v.neighbors/main.c:71
@@ -13001,15 +12092,12 @@
#: ../raster/r.neighbors/main.c:296
#, fuzzy, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+msgid "Method %s not compatible with weighing window, using weight mask instead"
msgstr "Methode %s ist nicht kompatibel mit GauÃ'schem Filter."
#: ../raster/r.neighbors/main.c:304
#, fuzzy, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
#: ../raster/r.neighbors/main.c:353
@@ -13029,8 +12117,7 @@
#: ../raster/r.resamp.interp/main.c:79
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
+msgstr "Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
#: ../raster/r.resamp.interp/main.c:88 ../vector/v.sample/main.c:102
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
@@ -13078,8 +12165,7 @@
#: ../raster/r.proj/main.c:148
#, fuzzy
msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-"Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
#: ../raster/r.proj/main.c:151
msgid "Name of input raster map to re-project"
@@ -13145,16 +12231,11 @@
#: ../raster/r.proj/main.c:218
msgid "Print input map's bounds in the current projection and exit"
-msgstr ""
-"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und "
-"beendet sich."
+msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und beendet sich."
#: ../raster/r.proj/main.c:224
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-"
-"Format aus und beendet sich."
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-Format aus und beendet sich."
#: ../raster/r.proj/main.c:250 ../vector/v.proj/main.c:143
#: ../vector/v.external/main.c:140
@@ -13172,8 +12253,7 @@
#: ../raster/r.proj/main.c:268
msgid "Unable to get projection info of output raster map"
-msgstr ""
-"Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr "Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
#: ../raster/r.proj/main.c:271
msgid "Unable to get projection units of output raster map"
@@ -13181,8 +12261,7 @@
#: ../raster/r.proj/main.c:274
msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr "Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
#: ../raster/r.proj/main.c:283
#, c-format
@@ -13358,12 +12437,8 @@
#: ../raster/r.reclass/main.c:54
#, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
-"Kategorien einer existierenden Rasterkarte basieren."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
#: ../raster/r.reclass/main.c:59
#, fuzzy
@@ -13390,8 +12465,7 @@
#: ../raster/r.reclass/main.c:103
#, c-format
msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
+msgstr "Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
#: ../raster/r.reclass/main.c:105
#, fuzzy, c-format
@@ -13449,12 +12523,8 @@
msgstr "%f gerundet auf %d\n"
#: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
-"Rasterkarten."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei Rasterkarten."
#: ../raster/r.coin/main.c:77
msgid "Name of first raster map"
@@ -13469,13 +12539,8 @@
msgstr "MaÃeinheit"
#: ../raster/r.coin/main.c:92
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der "
-"Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-"
-"Meilen)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-Meilen)"
#: ../raster/r.coin/main.c:99
msgid "Wide report, 132 columns (default: 80)"
@@ -13509,12 +12574,8 @@
#: ../raster/r.texture/h_measure.c:123
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu "
-"reklassifizieren oder zu reskalieren."
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu reklassifizieren oder zu reskalieren."
#: ../raster/r.texture/main.c:67
#, fuzzy, c-format
@@ -13601,14 +12662,10 @@
#: ../raster/r.in.gdal/main.c:111
msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Name der Location, von der Projektionsinformationen für eine GCP-"
-"Transformation gelesen werden soll."
+msgstr "Name der Location, von der Projektionsinformationen für eine GCP-Transformation gelesen werden soll."
#: ../raster/r.in.gdal/main.c:127
-msgid ""
-"The offset will be added to the band number while output raster map name "
-"creation"
+msgid "The offset will be added to the band number while output raster map name creation"
msgstr ""
#: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:203
@@ -13625,16 +12682,12 @@
msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
#: ../raster/r.in.gdal/main.c:167
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
msgstr ""
#: ../raster/r.in.gdal/main.c:192
msgid "You have to specify a target location different from output location"
-msgstr ""
-"Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-"
-"Location."
+msgstr "Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-Location."
#: ../raster/r.in.gdal/main.c:196
#, fuzzy
@@ -13661,42 +12714,21 @@
msgstr "Die Rasterkarte <%s> existiert bereits."
#: ../raster/r.in.gdal/main.c:261
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
-msgstr ""
-"Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert "
-"nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der "
-"'thin plate spline rectification' (-tps)."
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgstr "Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der 'thin plate spline rectification' (-tps)."
#: ../raster/r.in.gdal/main.c:282
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
-msgstr ""
-"Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen "
-"werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so "
-"dass Norden oben ist."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so dass Norden oben ist."
#: ../raster/r.in.gdal/main.c:323
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
-msgstr ""
-"Die Begrenzung ist an geographische Koordinaten gebunden. Eine Ãberprüfung "
-"der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region "
-"dieser Parameter ist für die weitere Berechnung empfehlenswert."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+msgstr "Die Begrenzung ist an geographische Koordinaten gebunden. Eine Ãberprüfung der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region dieser Parameter ist für die weitere Berechnung empfehlenswert."
#: ../raster/r.in.gdal/main.c:343 ../vector/v.in.ogr/main.c:613
#: ../vector/v.in.lidar/main.c:338
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
-"erstelle daher keine neue Location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; erstelle daher keine neue Location."
#: ../raster/r.in.gdal/main.c:349 ../general/g.proj/create.c:15
#: ../vector/v.in.ogr/main.c:619 ../vector/v.in.lidar/main.c:344
@@ -13707,13 +12739,10 @@
#: ../raster/r.in.gdal/main.c:453
msgid ""
"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der "
-"Projektion zu übersteuern und die Projektionsinformation der Location für "
-"diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der Projektion zu übersteuern und die Projektionsinformation der Location für diesen Datensatz zu verwenden.\n"
#: ../raster/r.in.gdal/main.c:518
#, fuzzy, c-format
@@ -13783,76 +12812,39 @@
#: ../raster/r.horizon/main.c:181
msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
-"Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
+msgstr "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
#: ../raster/r.horizon/main.c:183
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-"Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. "
-"Dies Modul hat zwei verschiedende Betriebsarten: 1. Berechnet den gesamten "
-"Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben "
-"wurden. Die Horizonthöhe wird im Bogenmaà ausgegeben. 2. Berechnet eine "
-"oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist "
-"der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 "
-"etc. Die Ausgabe ist die Horizonthöhe im BogenmaÃ. "
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr "Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. Dies Modul hat zwei verschiedende Betriebsarten: 1. Berechnet den gesamten Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben wurden. Die Horizonthöhe wird im Bogenmaà ausgegeben. 2. Berechnet eine oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 etc. Die Ausgabe ist die Horizonthöhe im BogenmaÃ. "
#: ../raster/r.horizon/main.c:206
msgid "Direction in which you want to know the horizon height"
msgstr "Richtung in der die Horizonthöhe berechnet werden soll."
#: ../raster/r.horizon/main.c:222
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die "
-"aktuelle Region herum ein."
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die aktuelle Region herum ein."
#: ../raster/r.horizon/main.c:230
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich "
-"der aktuellen Region ein."
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:238
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich "
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:246
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich "
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:254
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der "
-"aktuellen Region ein."
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:262
msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
-"Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende "
-"Distanz."
+msgstr "Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende Distanz."
#: ../raster/r.horizon/main.c:271
msgid "Prefix of the horizon raster output maps"
@@ -13872,8 +12864,7 @@
#: ../raster/r.horizon/main.c:362
msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
-"Sie haben keine Wert für die Richtung oder SchrittgröÃe angegeben. Breche ab."
+msgstr "Sie haben keine Wert für die Richtung oder SchrittgröÃe angegeben. Breche ab."
#: ../raster/r.horizon/main.c:367
msgid "You didn't specify a horizon raster name. Aborting."
@@ -13918,12 +12909,8 @@
msgstr "Konnte die maximale Distanz nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:472
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte "
-"setzen Sie geog. Länge via 'lat' oder 'latin'!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte setzen Sie geog. Länge via 'lat' oder 'latin'!"
#: ../raster/r.horizon/main.c:787 ../raster/r.horizon/main.c:805
#: ../imagery/i.latlong/main.c:133 ../ps/ps.map/do_geogrid.c:86
@@ -13956,12 +12943,8 @@
msgstr "Position"
#: ../raster/simwe/r.sim.sediment/main.c:117
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der "
-"\"path sampling\" Methode (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der \"path sampling\" Methode (SIMWE)."
#: ../raster/simwe/r.sim.sediment/main.c:124
#, fuzzy
@@ -14019,9 +13002,7 @@
msgstr "Name der Eingabe-Vektorkarte mit Startpunkten."
#: ../raster/simwe/r.sim.sediment/main.c:181
-msgid ""
-"Name of the sampling points output text file. For each observation vector "
-"point the time series of sediment transport is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
msgstr ""
#: ../raster/simwe/r.sim.sediment/main.c:187
@@ -14032,8 +13013,7 @@
#: ../raster/simwe/r.sim.sediment/main.c:194
#, fuzzy
msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
-msgstr ""
-"Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
#: ../raster/simwe/r.sim.sediment/main.c:201
#, fuzzy
@@ -14103,15 +13083,12 @@
#: ../raster/simwe/r.sim.water/main.c:113
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Hydrologische Simulation des Oberflächenabfluà mittels der \"path sampling\" "
-"Methode (SIMWE)."
+msgstr "Hydrologische Simulation des Oberflächenabfluà mittels der \"path sampling\" Methode (SIMWE)."
#: ../raster/simwe/r.sim.water/main.c:130
#, fuzzy
msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr ""
-"Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
+msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
#: ../raster/simwe/r.sim.water/main.c:139
msgid "Rainfall excess rate unique value [mm/hr]"
@@ -14136,9 +13113,7 @@
msgstr "Name Rasterkarte, die den Fluà kontrolliert (Permeabilität: 0-1)."
#: ../raster/simwe/r.sim.water/main.c:190
-msgid ""
-"point the time series of water depth is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
msgstr ""
#: ../raster/simwe/r.sim.water/main.c:196
@@ -14167,9 +13142,7 @@
#: ../raster/simwe/r.sim.water/main.c:268
#, fuzzy
msgid "Diffusion increases after this water depth is reached"
-msgstr ""
-"Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe "
-"erreicht wurde)."
+msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
#: ../raster/simwe/r.sim.water/main.c:276
msgid "Diffusion increase constant"
@@ -14208,12 +13181,8 @@
#: ../raster/simwe/simlib/input.c:58
#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
-msgstr ""
-"Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, "
-"welche prozessiert werden dürfen."
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgstr "Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, welche prozessiert werden dürfen."
#: ../raster/simwe/simlib/input.c:171
msgid "Zero value in Mannings n"
@@ -14221,8 +13190,7 @@
#: ../raster/simwe/simlib/input.c:222
msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-"Die Infiltration übersteigt den Niederschlag überall! Kein OberflächenabfluÃ."
+msgstr "Die Infiltration übersteigt den Niederschlag überall! Kein OberflächenabfluÃ."
#: ../raster/simwe/simlib/input.c:246
#, c-format
@@ -14236,9 +13204,7 @@
#: ../raster/simwe/simlib/input.c:248
#, c-format
msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
-"Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or "
-"kg/m2s \n"
+msgstr "Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or kg/m2s \n"
#: ../raster/simwe/simlib/input.c:250
#, c-format
@@ -14285,9 +13251,7 @@
#: ../raster/r.thin/main.c:59
msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr ""
-"Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer "
-"Rasterkarte abbilden."
+msgstr "Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
#: ../raster/r.thin/main.c:71
msgid "Maximal number of iterations"
@@ -14349,17 +13313,11 @@
#: ../raster/r.thin/thin_lines.c:175
msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-"Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter "
-"'iterations' zu erhöhen."
+msgstr "Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter 'iterations' zu erhöhen."
#: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert "
-"Rasterkarte(n) aus."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert Rasterkarte(n) aus."
#: ../raster/r.covar/main.c:61
msgid "Print correlation matrix"
@@ -14381,45 +13339,23 @@
#: ../raster/r.out.gdal/export_band.c:160
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
-msgstr ""
-"Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
-"%d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie "
-"können NoData-Wert mit dem Parameter %s bestimmen."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:165
#, fuzzy, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
-msgstr ""
-"Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
-"%d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
-"können Nodata-Wert mit dem Parameter %s bestimmen."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:175
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-"Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
-"Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem "
-"Parameter %s an."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgstr "Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem Parameter %s an."
#: ../raster/r.out.gdal/export_band.c:182
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-"Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu "
-"Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
-"Parameter %s an."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgstr "Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem Parameter %s an."
#: ../raster/r.out.gdal/export_band.c:224
msgid "Unable to get raster band"
@@ -14526,9 +13462,7 @@
#: ../raster/r.out.gdal/main.c:159
#, fuzzy
msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr ""
-"GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
-"beachten, siehe auch den Schalter -l)."
+msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
#: ../raster/r.out.gdal/main.c:180
#, fuzzy
@@ -14548,12 +13482,8 @@
msgstr "Metadaten Schlüsselwort(e) und Wert(e), die eingefügt werden sollen."
#: ../raster/r.out.gdal/main.c:202
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
-msgstr ""
-"Im Format \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. "
-"Wird nicht von allen Treibern unterstützt."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgstr "Im Format \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. Wird nicht von allen Treibern unterstützt."
#: ../raster/r.out.gdal/main.c:212
msgid "Assign a specified nodata value to output bands"
@@ -14576,12 +13506,8 @@
#: ../raster/r.out.gdal/main.c:266
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-"Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-"
-"Treiber für einen Zwischendatensatz."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr "Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-Treiber für einen Zwischendatensatz."
#: ../raster/r.out.gdal/main.c:271
msgid "Unable to get in-memory raster driver"
@@ -14604,36 +13530,22 @@
#: ../raster/r.out.gdal/main.c:422
msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-"Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
+msgstr "Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
#: ../raster/r.out.gdal/main.c:433
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
-msgstr ""
-"Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert "
-"werden. Dies kann verhindert werden mit %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgstr "Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert werden. Dies kann verhindert werden mit %s."
#: ../raster/r.out.gdal/main.c:444
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-"Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten "
-"werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch "
-"Export nach Int32 oder Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr "Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch Export nach Int32 oder Float64."
#: ../raster/r.out.gdal/main.c:452
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
-msgstr ""
-"Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> "
-"nicht erhalten. Dies kann verhindert werden mit Float64."
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgstr "Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> nicht erhalten. Dies kann verhindert werden mit Float64."
#: ../raster/r.out.gdal/main.c:461 ../raster/r.out.gdal/main.c:504
msgid "Forcing raster export."
@@ -14702,10 +13614,7 @@
#: ../raster/r.out.gdal/main.c:742 ../raster/r.out.gdal/main.c:755
#: ../raster/r.out.gdal/main.c:770
#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:718 ../raster/r.out.gdal/main.c:745
@@ -14721,14 +13630,8 @@
#: ../raster/r.out.gdal/main.c:784
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
-msgstr ""
-"NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
-"Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von "
-"dem gewählten GDAL-Datentyp nach %g konvertiert."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von dem gewählten GDAL-Datentyp nach %g konvertiert."
#: ../raster/r.out.gdal/main.c:787
#, c-format
@@ -14748,8 +13651,7 @@
msgstr "Koordinaten der Startpunkte"
#: ../raster/r.lake/main.c:177
-msgid ""
-"Name of input raster map with given starting point(s) (at least 1 cell > 0)"
+msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
#: ../raster/r.lake/main.c:183
@@ -14758,20 +13660,15 @@
#: ../raster/r.lake/main.c:188
msgid "Overwrite seed map with result (lake) map"
-msgstr ""
-"Ãberschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
+msgstr "Ãberschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
#: ../raster/r.lake/main.c:194
msgid "Both seed map and coordinates cannot be specified"
-msgstr ""
-"Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig "
-"verwendet werden."
+msgstr "Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig verwendet werden."
#: ../raster/r.lake/main.c:197
msgid "Seed map or seed coordinates must be set!"
-msgstr ""
-"Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben "
-"werden."
+msgstr "Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben werden."
# Einige Daten können u.U. verloren sein.er/r.lake/main.c:212
#: ../raster/r.lake/main.c:200
@@ -14780,15 +13677,11 @@
#: ../raster/r.lake/main.c:203
msgid "Both lake and overwrite cannot be specified"
-msgstr ""
-"Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet "
-"werden."
+msgstr "Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet werden."
#: ../raster/r.lake/main.c:206
msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-"Entweder eine Ausgabe-Seekarte oder das Ãberschreiben-'flag' muss angegeben "
-"werden."
+msgstr "Entweder eine Ausgabe-Seekarte oder das Ãberschreiben-'flag' muss angegeben werden."
#: ../raster/r.lake/main.c:233
msgid "Seed point outside the current region"
@@ -14799,13 +13692,8 @@
msgstr "G_malloc: Kein Speicher mehr da."
#: ../raster/r.lake/main.c:269
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
-msgstr ""
-"Der angegebene Wasserstand am Startpunkt befindet sich unter der "
-"Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den "
-"Startpunkt."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+msgstr "Der angegebene Wasserstand am Startpunkt befindet sich unter der Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den Startpunkt."
#: ../raster/r.lake/main.c:348
#, c-format
@@ -14824,24 +13712,17 @@
#: ../raster/r.lake/main.c:351
msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-"Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in "
-"Metern angegeben wurde."
+msgstr "Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in Metern angegeben wurde."
#: ../raster/r.surf.gauss/main.c:42
#, fuzzy
msgid "Generates a raster map using gaussian random number generator."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
#: ../raster/r.surf.gauss/main.c:44
#, fuzzy
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
-msgstr ""
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
#: ../raster/r.surf.gauss/main.c:51
msgid "Distribution mean"
@@ -14962,9 +13843,7 @@
#: ../raster/r.in.ascii/gethead.c:169
msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-"Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt "
-"wurde."
+msgstr "Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:176
msgid "illegal multiplier field: using 1.0"
@@ -14972,15 +13851,11 @@
#: ../raster/r.in.ascii/gethead.c:181
msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-"Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der "
-"Kommandozeile gesetzt wurde."
+msgstr "Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der Kommandozeile gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:189
msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-"Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile "
-"gesetzt wurde."
+msgstr "Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:218
msgid "error in ascii data format"
@@ -15022,8 +13897,7 @@
#: ../raster/r.out.vrml/main.c:51
#, fuzzy
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-"Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
+msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
#: ../raster/r.out.vrml/main.c:58
msgid "Name of elevation map"
@@ -15041,16 +13915,12 @@
#: ../raster/r.out.vrml/main.c:95
#, fuzzy, c-format
msgid "Range info for [%s] not available (run r.support)"
-msgstr ""
-"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
-"aus)."
+msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
#: ../raster/r.out.vrml/main.c:104
#, fuzzy, c-format
msgid "Range info for <%s> not available (run r.support)"
-msgstr ""
-"aus)."
#: ../raster/r.out.vrml/main.c:136
#, c-format
@@ -15067,9 +13937,7 @@
#: ../raster/r.surf.fractal/process.c:54
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"Kann keinen Speicher für Datenbuffer reservieren. Ãberprüfen Sie die "
-"aktuelle Region mit g.region."
+msgstr "Kann keinen Speicher für Datenbuffer reservieren. Ãberprüfen Sie die aktuelle Region mit g.region."
#: ../raster/r.surf.fractal/main.c:40
#, fuzzy
@@ -15078,8 +13946,7 @@
#: ../raster/r.surf.fractal/main.c:42
msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-"Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
+msgstr "Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
#: ../raster/r.surf.fractal/main.c:48
msgid "Fractal dimension of surface (2 < D < 3)"
@@ -15164,8 +14031,7 @@
#: ../raster/r.to.rast3elev/main.c:99
msgid "The number of input and elevation maps is not equal"
-msgstr ""
#: ../raster/r.to.rast3elev/main.c:165
msgid "The value to fill the upper cells, default is null"
@@ -15173,8 +14039,7 @@
#: ../raster/r.to.rast3elev/main.c:172
msgid "The value to fill the lower cells, default is null"
-msgstr ""
-"Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
+msgstr "Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
#: ../raster/r.to.rast3elev/main.c:185
msgid "Use the input map values to fill the upper cells"
@@ -15190,9 +14055,7 @@
#: ../raster/r.to.rast3elev/main.c:366
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren "
-"Rasterkarten."
+msgstr "Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren Rasterkarten."
#: ../raster/r.to.rast3elev/main.c:400
msgid "The upper value is not valid"
@@ -15420,9 +14283,7 @@
#: ../raster/r.flow/precomp.c:116
#, c-format
msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-"Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die "
-"Eingabekarte."
+msgstr "Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die Eingabekarte."
#: ../raster/r.flow/main.c:424
#, fuzzy
@@ -15431,12 +14292,8 @@
#: ../raster/r.flow/main.c:426
#, fuzzy
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
-msgstr ""
-"Erzeugt Hangkurven (flowlines), FlieÃlängen und Flussdichte (upslope areas) "
-"aus einem angegebenen digitalen Höhenmodell (DEM)."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+msgstr "Erzeugt Hangkurven (flowlines), FlieÃlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
#: ../raster/r.flow/main.c:435
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
@@ -15487,30 +14344,20 @@
#: ../raster/r.flow/main.c:535
msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, "
-"dsout)."
+msgstr "Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, dsout)."
#: ../raster/r.flow/main.c:551
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-"Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie "
-"'r.watershed' für die Berechnung der Fussakkumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgstr "Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie 'r.watershed' für die Berechnung der Fussakkumulation."
#: ../raster/r.flow/io.c:87
#, fuzzy
msgid "Elevation raster map resolution differs from current region resolution"
-msgstr ""
-"Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen "
-"Region."
+msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
#: ../raster/r.flow/io.c:104
msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der "
-"aktuellen Region"
+msgstr "Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der aktuellen Region"
#: ../raster/r.flow/io.c:121
msgid "Reading input files: barrier"
@@ -15579,9 +14426,7 @@
msgstr "Vektor, Transformation"
#: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Prestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
msgstr ""
#: ../imagery/i.evapo.pt/main.c:75
@@ -15783,12 +14628,8 @@
msgstr ""
#: ../imagery/i.smap/main.c:43
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
-"'sequential maximum a posteriori (SMAP)' Ansatzes durch."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des 'sequential maximum a posteriori (SMAP)' Ansatzes durch."
#: ../imagery/i.smap/write_img.c:15
#, fuzzy
@@ -15812,9 +14653,7 @@
#: ../imagery/i.smap/parse.c:33
#, fuzzy
msgid "Name for output raster map holding goodness of fit (lower is better)"
-msgstr ""
-"Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten "
-"geschrieben werden"
+msgstr "Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten geschrieben werden"
#: ../imagery/i.smap/parse.c:37
msgid "Size of submatrix to process at one time"
@@ -15902,8 +14741,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
msgstr ""
#: ../imagery/i.vi/main.c:101
@@ -15955,8 +14793,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:120
-msgid ""
-"Infrared Percentage Vegetation IndexInfrared Percentage Vegetation Index"
+msgid "Infrared Percentage Vegetation IndexInfrared Percentage Vegetation Index"
msgstr ""
#: ../imagery/i.vi/main.c:121
@@ -16058,9 +14895,7 @@
msgstr "Maximaler Radius der Ring/Kreis-Karte (in Metern)."
#: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
-"for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
msgstr ""
#: ../imagery/i.vi/main.c:227
@@ -16096,8 +14931,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:253
-msgid ""
-"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi2 index requires red and nir maps, and 3 parameters related to soil line"
msgstr ""
#: ../imagery/i.vi/main.c:256
@@ -16130,18 +14964,12 @@
#: ../imagery/i.landsat.acca/main.c:70
#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
-msgstr ""
-"Eingabe Rasterkarte <%s> enthält keine FlieÃkomma-Werte (verarbeiten Sie "
-"zunächst die DN mittels i.landsat.toar zu Strahlungswerten)."
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
+msgstr "Eingabe Rasterkarte <%s> enthält keine FlieÃkomma-Werte (verarbeiten Sie zunächst die DN mittels i.landsat.toar zu Strahlungswerten)."
#: ../imagery/i.landsat.acca/main.c:104
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-"Führt automatische Landsat TM/ETM+ Einschätzung der Wolkenbedeckung (ACCA) "
-"durch."
+msgstr "Führt automatische Landsat TM/ETM+ Einschätzung der Wolkenbedeckung (ACCA) durch."
#: ../imagery/i.landsat.acca/main.c:106 ../imagery/i.landsat.toar/main.c:70
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
@@ -16195,11 +15023,8 @@
msgstr "Verwende immer die Wolkensignatur (Schritt 14)"
#: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
-msgstr ""
-"Ãberspringe den zweiten Durchgang und fasse warme (nicht mehrdeutig) und "
-"kalte Wolken zusammen."
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgstr "Ãberspringe den zweiten Durchgang und fasse warme (nicht mehrdeutig) und kalte Wolken zusammen."
#: ../imagery/i.landsat.acca/main.c:164
msgid "Include a category for cloud shadows"
@@ -16326,16 +15151,11 @@
#: ../imagery/i.maxlik/main.c:65
msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-"Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
+msgstr "Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
#: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Die Klassifikation basiert auf der Information der spektralen Signatur "
-"erzeugt von .cluster, i.class, oder i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "Die Klassifikation basiert auf der Information der spektralen Signatur erzeugt von .cluster, i.class, oder i.gensig."
#: ../imagery/i.maxlik/main.c:81
#, fuzzy
@@ -16345,8 +15165,7 @@
#: ../imagery/i.maxlik/main.c:91
#, fuzzy
msgid "Name for output raster map holding reject threshold results"
-msgstr ""
-"Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
+msgstr "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
#: ../imagery/i.maxlik/open.c:20 ../imagery/i.cluster/open_files.c:22
#, c-format
@@ -16355,21 +15174,13 @@
#: ../imagery/i.maxlik/open.c:27
#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die "
-"Untergruppe muss mindestens 2 Rasterkarten haben."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
+msgstr "Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die Untergruppe muss mindestens 2 Rasterkarten haben."
#: ../imagery/i.maxlik/open.c:30
#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe "
-"muss mindestens 2 Rasterkarten haben."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
+msgstr "Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe muss mindestens 2 Rasterkarten haben."
#: ../imagery/i.maxlik/open.c:47
#, c-format
@@ -16397,12 +15208,8 @@
msgstr "Metadaten-Datei <%s> nicht gefunden"
#: ../imagery/i.landsat.toar/main.c:67
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
-msgstr ""
-"Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für "
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
+msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+."
#: ../imagery/i.landsat.toar/main.c:69 ../imagery/i.aster.toar/main.c:98
#, fuzzy
@@ -16503,8 +15310,7 @@
#: ../imagery/i.landsat.toar/main.c:174
msgid "Minimum pixels to consider digital number as dark object"
-msgstr ""
-"Minimum Pixel um die \"digital number\" als dunkles Objekt zu betrachten"
+msgstr "Minimum Pixel um die \"digital number\" als dunkles Objekt zu betrachten"
#: ../imagery/i.landsat.toar/main.c:182
msgid "Rayleigh atmosphere (diffuse sky irradiance)"
@@ -16643,8 +15449,7 @@
#: ../imagery/i.class/add_point.c:22
#, c-format
msgid "Can't mark another point. Only %d points allowed. Sorry."
-msgstr ""
-"Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
+msgstr "Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
#: ../imagery/i.class/draw_reg.c:89
#, c-format
@@ -16687,20 +15492,12 @@
msgstr "Fehler beim Entfernen der alten Maske (MASK)."
#: ../imagery/i.class/main.c:94
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
-msgstr ""
-"Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
-"Trainingsgebiete zu markieren."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
#: ../imagery/i.class/main.c:97
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als "
-"Start-Signatur für i.cluster verwendet werden."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als Start-Signatur für i.cluster verwendet werden."
#: ../imagery/i.class/main.c:101 ../display/d.rast/main.c:61
msgid "Name of raster map to be displayed"
@@ -16720,9 +15517,7 @@
#: ../imagery/i.class/main.c:133
msgid "You have a mask set. Unset mask and run again"
-msgstr ""
-"Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es "
-"erneut"
+msgstr "Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es erneut"
#: ../imagery/i.class/main.c:142 ../imagery/i.group/main.c:113
#: ../imagery/i.target/main.c:80
@@ -16732,8 +15527,7 @@
#: ../imagery/i.class/main.c:251
#, c-format
msgid "** The following raster maps in subgroup [%s] do not exist:"
-msgstr ""
-"** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
+msgstr "** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
#: ../imagery/i.class/main.c:260
#, c-format
@@ -16935,9 +15729,7 @@
msgstr ""
#: ../imagery/i.aster.toar/main.c:104
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN.\n"
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
msgstr ""
#: ../imagery/i.aster.toar/main.c:108
@@ -17064,12 +15856,8 @@
msgstr "Untergruppe <%s> in Gruppe <%s> enthält keine Rasterkarten."
#: ../imagery/i.his.rgb/main.c:51
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum "
-"in den RGB (Rot-Grün-Blau) Farbraum."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum in den RGB (Rot-Grün-Blau) Farbraum."
#: ../imagery/i.his.rgb/main.c:57
msgid "Name of input raster map (hue)"
@@ -17096,9 +15884,7 @@
msgstr "Name der Ausgabe-Rasterkarte (blau)."
#: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
msgstr ""
#: ../imagery/i.evapo.mh/main.c:78
@@ -17159,8 +15945,7 @@
#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
#, c-format
msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr ""
-"Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
+msgstr "Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
#: ../imagery/i.rectify/rectify.c:111
#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
@@ -17174,12 +15959,8 @@
msgstr "Bildverarbeitung, Rektifikation"
#: ../imagery/i.rectify/main.c:97
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel "
-"des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
#: ../imagery/i.rectify/main.c:111
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
@@ -17202,11 +15983,8 @@
#: ../imagery/i.rectify/main.c:148
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-"Verwende die Einstellungen der aktuelle Region für die Ziellocation "
-"(Standard: Berechne den kleinsten Bereich)."
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr "Verwende die Einstellungen der aktuelle Region für die Ziellocation (Standard: Berechne den kleinsten Bereich)."
#: ../imagery/i.rectify/main.c:152
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
@@ -17345,9 +16123,7 @@
#: ../imagery/i.rectify/cp.c:21 ../vector/v.rectify/cp.c:359
#, c-format
msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-"Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden "
-"benötigt."
+msgstr "Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden benötigt."
#: ../imagery/i.rectify/cp.c:25 ../vector/v.rectify/cp.c:363
msgid "Poorly placed control points."
@@ -17426,12 +16202,8 @@
msgstr "Kann Symbol nicht lesen; stelle daher die Punkte nicht dar."
#: ../imagery/i.vpoints/main.c:97
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
-msgstr ""
-"Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder "
-"durch Koordinateneingaben über die Tastatur."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
+msgstr "Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder durch Koordinateneingaben über die Tastatur."
#: ../imagery/i.eb.h_sebal01/main.c:85 ../imagery/i.eb.evapfr/main.c:49
msgid "soil moisture"
@@ -17587,13 +16359,11 @@
#: ../imagery/i.topo.corr/main.c:100
msgid "Solar azimuth is necessary to calculate illumination terrain model"
-msgstr ""
-"Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
+msgstr "Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
#: ../imagery/i.topo.corr/main.c:104
msgid "Reflectance maps are necessary to make topographic correction"
-msgstr ""
-"Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
+msgstr "Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
#: ../imagery/i.topo.corr/main.c:164
msgid "Illumination model is of CELL type"
@@ -17646,9 +16416,7 @@
msgstr ""
#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
msgstr ""
#: ../imagery/i.albedo/main.c:127
@@ -17712,9 +16480,7 @@
#: ../imagery/i.fft/main.c:106
msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN "
-"Seiten). Fahre trotzdem fort..."
+msgstr "Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN Seiten). Fahre trotzdem fort..."
#: ../imagery/i.fft/main.c:129
#, c-format
@@ -17915,8 +16681,7 @@
msgstr ""
#: ../imagery/i.modis.qc/main.c:256
-msgid ""
-"Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
msgstr ""
#: ../imagery/i.modis.qc/main.c:260
@@ -18062,16 +16827,12 @@
#: ../imagery/i.gensigset/subcluster.c:552
msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-"Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl "
-"von Anfangsclustern."
+msgstr "Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl von Anfangsclustern."
#: ../imagery/i.gensigset/subcluster.c:561
#, c-format
msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
-"Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d "
-"verbleiben)."
+msgstr "Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d verbleiben)."
#: ../imagery/i.emissivity/main.c:45 ../imagery/i.eb.netrad/main.c:93
#: ../imagery/i.eb.netrad/main.c:95
@@ -18102,8 +16863,7 @@
#: ../imagery/i.cca/main.c:88
msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
#: ../imagery/i.cca/main.c:102
msgid "File containing spectral signatures"
@@ -18280,20 +17040,12 @@
msgstr "Sites"
#: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-"Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels "
-"eines Clusteralgorithmus."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
#: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um "
-"eine unüberwachte Bildklassifikation zu erzeugen."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um eine unüberwachte Bildklassifikation zu erzeugen."
#: ../imagery/i.cluster/main.c:101
msgid "Initial number of classes"
@@ -18478,9 +17230,7 @@
#: ../imagery/i.cluster/main.c:286
msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-"Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren "
-"StichprobengröÃe."
+msgstr "Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren StichprobengröÃe."
#: ../imagery/i.cluster/main.c:292
#, c-format
@@ -18488,18 +17238,12 @@
msgstr "StichprobengröÃe: %d Punkte\n"
#: ../imagery/i.cluster/main.c:295
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer "
-"gröÃeren Stichprobe."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer gröÃeren Stichprobe."
#: ../imagery/i.cluster/main.c:299
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle "
-"Region (und Maske)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle Region (und Maske)."
#: ../imagery/i.cluster/main.c:312
#, c-format
@@ -18518,9 +17262,7 @@
#: ../imagery/i.cluster/main.c:324
#, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht "
-"erzeugen."
+msgstr "Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht erzeugen."
#: ../imagery/i.cluster/main.c:329
#, c-format
@@ -18665,9 +17407,7 @@
msgstr "Features"
#: ../imagery/i.eb.netrad/main.c:89
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
msgstr ""
#: ../imagery/i.eb.netrad/main.c:90
@@ -18730,9 +17470,7 @@
msgstr "Ãffnen der temporären Datei nicht möglich."
#: ../imagery/i.eb.evapfr/main.c:53
-msgid ""
-"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
-"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
msgstr ""
#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
@@ -18765,9 +17503,7 @@
msgstr ""
#: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
msgstr ""
#: ../imagery/i.evapo.time/main.c:86
@@ -18878,8 +17614,7 @@
msgstr "Name der Eingabe-Rasterkarte."
#: ../imagery/i.segment/parse_args.c:117
-msgid ""
-"Must be integer values, each area will be segmented independent of the others"
+msgid "Must be integer values, each area will be segmented independent of the others"
msgstr ""
#: ../imagery/i.segment/parse_args.c:123
@@ -18888,9 +17623,7 @@
msgstr "Name der Ausgabe-Rasterkarte mit vertikaler Wölbung."
#: ../imagery/i.segment/parse_args.c:128
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
msgstr ""
#: ../imagery/i.segment/parse_args.c:134
@@ -18967,9 +17700,7 @@
#: ../imagery/i.segment/create_isegs.c:493
#, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
msgstr ""
#: ../imagery/i.segment/create_isegs.c:495
@@ -19013,8 +17744,7 @@
#: ../imagery/i.segment/create_isegs.c:1479
#, fuzzy, c-format
msgid "Region size is larger than 2: %d"
-msgstr ""
-"Region-GröÃe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
+msgstr "Region-GröÃe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
#: ../imagery/i.segment/create_isegs.c:1564
#, c-format
@@ -19203,9 +17933,7 @@
#: ../imagery/i.pca/main.c:272
msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-"Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: "
-"0,255. "
+msgstr "Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: 0,255. "
#: ../imagery/i.pca/main.c:318
msgid "Computing covariance matrix..."
@@ -19221,12 +17949,8 @@
msgstr "Berechne Hauptkomponenten..."
#: ../imagery/i.rgb.his/main.c:51
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS "
-"(Hue-Intensity-Saturation) Farbraum."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS (Hue-Intensity-Saturation) Farbraum."
#: ../imagery/i.rgb.his/main.c:57
msgid "Name of input raster map (red)"
@@ -19253,9 +17977,7 @@
msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
#: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
msgstr ""
#: ../imagery/i.evapo.pm/main.c:65
@@ -19373,8 +18095,7 @@
#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
#, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
msgstr ""
#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -19406,9 +18127,7 @@
#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:216
#, fuzzy, c-format
msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
-msgstr ""
-"Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei "
-"[%s]."
+msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
#, fuzzy
@@ -19498,12 +18217,8 @@
msgstr "Keine Höhe in Zeile %d, Spalte %d vorhanden."
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
-msgstr ""
-"Orthorektifiziert ein Bild mittels der Foto zu Koordinaten "
-"Transformationsmatrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
+msgstr "Orthorektifiziert ein Bild mittels der Foto zu Koordinaten Transformationsmatrix."
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
msgid "Raster map with camera angle relative to ground surface"
@@ -19596,12 +18311,8 @@
msgstr "Führe OPTION 5 von i.ortho.photo aus!\n"
#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
-msgstr ""
-"Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition "
-"der Kamera für die Bildgruppe referenziert durch Unterblöcke."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
+msgstr "Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition der Kamera für die Bildgruppe referenziert durch Unterblöcke."
#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
#, fuzzy
@@ -19802,10 +18513,10 @@
msgid "illegal maploc request"
msgstr "Ungültige Löschanfrage."
-#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:219
+#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
#, fuzzy
msgid "illegal copies request"
-msgstr "Ungültige Löschanfrage."
+msgstr "Ungültige Spalten-Anfrage."
#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
#, fuzzy
@@ -19860,7 +18571,7 @@
#: ../ps/ps.map/r_instructions.c:309
#, fuzzy
msgid "illegal scale request"
+msgstr "Ungültige Wertebereichs-Anfrage."
#: ../ps/ps.map/r_instructions.c:369
#, fuzzy
@@ -19940,7 +18651,7 @@
#: ../ps/ps.map/ps_outline.c:107
#, fuzzy
msgid "illegal outline sub-request"
+msgstr "Ungültige colortabe sub-request"
#: ../ps/ps.map/r_group.c:29
msgid "Can't get group information"
@@ -20011,36 +18722,32 @@
#: ../ps/ps.map/ps_fclrtbl.c:93 ../ps/ps.map/ps_fclrtbl.c:98
#: ../ps/ps.map/ps_clrtbl.c:69
msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Die Y-Position der Farbtabelle liegt auÃerhalb der Seitenränder. Korrigiere "
-"dies."
+msgstr "Die Y-Position der Farbtabelle liegt auÃerhalb der Seitenränder. Korrigiere dies."
#: ../ps/ps.map/ps_fclrtbl.c:104 ../ps/ps.map/ps_fclrtbl.c:109
#: ../ps/ps.map/ps_clrtbl.c:75
msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Die X-Position der Farbtabelle liegt auÃerhalb der Seitenränder. Korrigiere "
-"dies."
+msgstr "Die X-Position der Farbtabelle liegt auÃerhalb der Seitenränder. Korrigiere dies."
#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
#, fuzzy
msgid "illegal numbers request"
#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
#, fuzzy
msgid "illegal grid width request"
+msgstr "Ungültige Weiten-Anfrage."
#: ../ps/ps.map/getgrid.c:132
#, fuzzy
msgid "illegal request (grid)"
#: ../ps/ps.map/getgrid.c:240
#, fuzzy
msgid "illegal request (geogrid)"
+msgstr "Ungültige Farb-Anfrage (Farbtabelle)."
#: ../ps/ps.map/r_plt.c:173
msgid "Can't open eps file"
@@ -20064,7 +18771,7 @@
#: ../ps/ps.map/r_header.c:77
#, fuzzy
msgid "illegal header sub-request"
+msgstr "Ungültiges vlegend sub-request"
#: ../ps/ps.map/do_labels.c:44
#, c-format
@@ -20110,9 +18817,7 @@
#: ../ps/ps.map/main.c:105
#, fuzzy
msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten"
-"(Rand) )."
+msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
msgid "Utility"
@@ -20123,12 +18828,8 @@
msgstr "Erzeugt EPS (Encapsulated PostScript) anstatt PostScript-Dateien."
#: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
-msgstr ""
-"Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich "
-"(Inch von der linken-oberen Ecke). "
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgstr "Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich (Inch von der linken-oberen Ecke). "
#: ../ps/ps.map/main.c:123
#, fuzzy
@@ -20148,12 +18849,12 @@
msgid "Number of copies to print"
msgstr "Anzahl der Kopien."
-#: ../ps/ps.map/main.c:204
+#: ../ps/ps.map/main.c:205
#, fuzzy, c-format
msgid "Unable to open file '%s': %s"
msgstr "Kann die Datei <%s> nicht öffnen."
-#: ../ps/ps.map/main.c:212 ../ps/ps.map/main.c:231
+#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
#: ../vector/v.univar/main.c:139 ../vector/v.to.db/parse.c:141
#: ../vector/v.to.db/parse.c:144
#, c-format
@@ -20164,7 +18865,7 @@
"Benötigter Parameter <%s> wurde nicht angegeben:\n"
"\t(%s)"
-#: ../ps/ps.map/main.c:272
+#: ../ps/ps.map/main.c:273
#, fuzzy, c-format
msgid "PostScript file '%s' successfully written."
msgstr "Die PostScript Datei [%s] wurde erfolgreich geschrieben."
@@ -20204,15 +18905,8 @@
msgstr "Kategorie-Dateien für <%s> nicht vorhanden. "
#: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln "
-"ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie "
-"einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile "
-"wurde nicht ausgeführt."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile wurde nicht ausgeführt."
#: ../ps/ps.map/do_plt.c:38
msgid "Reading point/line file ..."
@@ -20224,12 +18918,8 @@
msgstr "Berechne Histogramm"
#: ../display/d.histogram/main.c:88
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene "
-"Rasterkarte dar."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene Rasterkarte dar."
#: ../display/d.histogram/main.c:92
msgid "Raster map for which histogram will be displayed"
@@ -20245,14 +18935,11 @@
#: ../display/d.histogram/main.c:113
msgid "Indicate if cell counts or map areas should be displayed"
-msgstr ""
-"Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
+msgstr "Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
#: ../display/d.histogram/main.c:123
msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-"Anzahl der Klassen, in die der Wertebereich geteilt werden soll (nur "
-"FlieÃkommakarten)"
+msgstr "Anzahl der Klassen, in die der Wertebereich geteilt werden soll (nur FlieÃkommakarten)"
#: ../display/d.histogram/main.c:130
msgid "Display information for null cells"
@@ -20289,7 +18976,7 @@
#: ../display/d.grid/main.c:233 ../display/d.his/main.c:118
#: ../display/d.geodesic/main.c:96 ../display/d.labels/main.c:117
#: ../display/d.colortable/main.c:141 ../display/d.rast/main.c:97
-#: ../display/d.thematic.area/main.c:371 ../display/d.fontlist/main.c:54
+#: ../display/d.thematic.area/main.c:370 ../display/d.fontlist/main.c:54
#: ../display/d.graph/main.c:98 ../display/d.rgb/main.c:82
#: ../display/d.path/main.c:154 ../display/d.rast.arrow/main.c:224
#: ../display/d.legend/main.c:294 ../display/d.font/main.c:86
@@ -20302,12 +18989,12 @@
msgstr "Unbekannte Farbe: '%s'."
#: ../display/d.vect/opt.c:143 ../display/d.what.vect/what.c:413
-#: ../display/d.thematic.area/main.c:201 ../vector/v.db.connect/main.c:175
+#: ../display/d.thematic.area/main.c:200 ../vector/v.db.connect/main.c:175
#, c-format
msgid "Database connection not defined"
msgstr "Datenbankverbindung nicht definiert."
-#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:210
+#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:209
#: ../vector/v.convert/att.c:74 ../db/db.select/main.c:73
#: ../db/db.execute/main.c:76 ../db/db.tables/main.c:47
#: ../db/db.describe/main.c:56
@@ -20322,12 +19009,8 @@
#: ../display/d.vect/lines.c:121
#, fuzzy
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
-msgstr ""
-"Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
-"vorhanden ist."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
#: ../display/d.vect/lines.c:169
#, fuzzy, c-format
@@ -20370,9 +19053,7 @@
msgstr "Kein Attribut für cat %d: %s gefunden."
#: ../display/d.vect/topo.c:17
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
msgstr ""
#: ../display/d.vect/main.c:74
@@ -20382,8 +19063,8 @@
#: ../display/d.vect/main.c:80 ../display/d.vect/main.c:105
#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
#: ../display/d.vect/main.c:314 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:135
-#: ../display/d.thematic.area/main.c:138 ../vector/v.net.centrality/main.c:121
+#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:137 ../vector/v.net.centrality/main.c:121
#: ../vector/v.net.centrality/main.c:123 ../vector/v.in.ogr/main.c:146
#: ../vector/v.in.ogr/main.c:159 ../vector/v.in.ogr/main.c:164
#: ../vector/v.in.ogr/main.c:173 ../vector/v.in.ogr/main.c:189
@@ -20398,8 +19079,8 @@
#: ../vector/v.extract/main.c:100 ../vector/v.extract/main.c:106
#: ../vector/v.extract/main.c:109 ../vector/v.extract/main.c:112
#: ../vector/v.extract/main.c:122 ../vector/v.extract/main.c:132
-#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:83
-#: ../vector/v.category/main.c:86 ../vector/v.category/main.c:90
+#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:84
+#: ../vector/v.category/main.c:87 ../vector/v.category/main.c:91
#: ../vector/v.buffer/main.c:232 ../vector/v.buffer/main.c:235
#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:243
#: ../vector/v.surf.rst/main.c:173 ../vector/v.surf.rst/main.c:185
@@ -20455,9 +19136,7 @@
#: ../display/d.vect/main.c:98
#, fuzzy
msgid "Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
-"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
-"sollen."
+msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
#: ../display/d.vect/main.c:119
msgid "Feature color"
@@ -20517,8 +19196,7 @@
#: ../display/d.vect/main.c:159
#, fuzzy
msgid "These values will be scaled by width_scale"
-msgstr ""
-"Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
#: ../display/d.vect/main.c:166
#, fuzzy
@@ -20541,9 +19219,7 @@
#: ../display/d.vect/main.c:187
msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-"Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column "
-"verwendet wird."
+msgstr "Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column verwendet wird."
#: ../display/d.vect/main.c:193
msgid "Name of numeric column containing symbol size"
@@ -20567,9 +19243,7 @@
#: ../display/d.vect/main.c:209
msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
-"Layernummer für die Beschriftungen (Standard: die bereits gegebene "
-"Layernummer)."
+msgstr "Layernummer für die Beschriftungen (Standard: die bereits gegebene Layernummer)."
#: ../display/d.vect/main.c:215
msgid "Name of column to be displayed"
@@ -20614,18 +19288,12 @@
msgstr "Vertikale Labelausrichtung"
#: ../display/d.vect/main.c:286
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-"Minimale GröÃe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
-"der Karte."
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr "Minimale GröÃe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
#: ../display/d.vect/main.c:294
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-"Maximale GröÃe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
-"der Karte."
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr "Maximale GröÃe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
#: ../display/d.vect/main.c:302
#, fuzzy
@@ -20633,12 +19301,8 @@
msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
#: ../display/d.vect/main.c:308
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern "
-"(oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern (oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
#: ../display/d.vect/main.c:315
msgid "Use values from 'cats' option as feature id"
@@ -20653,30 +19317,22 @@
msgstr ""
#: ../display/d.vect/main.c:326
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
msgstr ""
#: ../display/d.vect/main.c:346
#, fuzzy
msgid "Region size is lower than minreg, nothing displayed"
-msgstr ""
#: ../display/d.vect/main.c:354
#, fuzzy
msgid "Region size is greater than maxreg, nothing displayed"
-msgstr ""
-"Region-GröÃe ist gröÃer als die Maximal-Region; es wird nichts angezeigt."
+msgstr "Region-GröÃe ist gröÃer als die Maximal-Region; es wird nichts angezeigt."
#: ../display/d.vect/main.c:368
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
-msgstr ""
-"Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der "
-"Schalter '-c' wird ignoriert!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
+msgstr "Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der Schalter '-c' wird ignoriert!"
#: ../display/d.vect/main.c:390 ../display/d.vect/main.c:396
#, fuzzy, c-format
@@ -20695,11 +19351,8 @@
#: ../display/d.vect/main.c:424
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
-msgstr ""
-"Die BoundingBox der Karte liegt auÃerhalb der derzeitigen Region, es wird "
-"nichts gezeichnet."
+msgid "The bounding box of the map is outside the current region, nothing drawn"
+msgstr "Die BoundingBox der Karte liegt auÃerhalb der derzeitigen Region, es wird nichts gezeichnet."
#: ../display/d.vect/main.c:487
#, fuzzy
@@ -20708,9 +19361,7 @@
#: ../display/d.vect/area.c:37
#, fuzzy
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
#: ../display/d.vect/area.c:137
@@ -20734,15 +19385,8 @@
#: ../display/d.vect/shape.c:68
#, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
-msgstr ""
-"Farbdefinitionsspalte ('%s') ist keine Zeichenkette. Die Spalte muss die "
-"Form 'RRR:GGG:BBB' haben. Die RGB-Werte müssen zwischen 0 und 255 liegen. "
-"Sie können das Modul '%s' verwenden um Farbregeln zu definieren. Kann die "
-"Feature nicht einfärben."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+msgstr "Farbdefinitionsspalte ('%s') ist keine Zeichenkette. Die Spalte muss die Form 'RRR:GGG:BBB' haben. Die RGB-Werte müssen zwischen 0 und 255 liegen. Sie können das Modul '%s' verwenden um Farbregeln zu definieren. Kann die Feature nicht einfärben."
#: ../display/d.vect/shape.c:75 ../display/d.vect/shape.c:98
#: ../display/d.vect/shape.c:129 ../display/d.vect/shape.c:160
@@ -20781,8 +19425,7 @@
msgstr "Spalte für die Symbolrotation (%s) is nicht numerisch."
#: ../display/d.vect/shape.c:183
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
msgstr ""
#: ../display/d.vect/shape.c:254 ../display/d.vect/shape.c:259
@@ -20835,12 +19478,8 @@
#: ../display/d.where/main.c:48
#, fuzzy
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
-msgstr ""
-"Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-"
-"Fenster."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
+msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
#: ../display/d.where/main.c:58
#, fuzzy
@@ -20850,8 +19489,7 @@
#: ../display/d.where/main.c:63
#, fuzzy
msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr ""
-"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
#: ../display/d.where/main.c:67
msgid "Output lat/long in decimal degree"
@@ -20862,13 +19500,8 @@
msgstr "Ausgabe auf den aktuellen Ellipsoid referenziert."
#: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten "
-"Datumstransformationsparametern der aktuellen Location (sofern vorhanden) "
-"aus."
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten Datumstransformationsparametern der aktuellen Location (sofern vorhanden) aus."
#: ../display/d.where/main.c:83
msgid "Output frame coordinates of current display monitor (percentage)"
@@ -20880,17 +19513,13 @@
#: ../display/d.where/main.c:94
msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr ""
-"Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
+msgstr "Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
#: ../display/d.where/main.c:136
msgid ""
"WGS84 output not possible as this location does not contain\n"
"datum transformation parameters. Try running g.setproj."
-msgstr ""
-"Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-"
-"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu "
-"benutzen."
+msgstr "Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
#: ../display/d.where/where.c:29
#, fuzzy, c-format
@@ -21033,12 +19662,8 @@
msgstr "Warnung: Vektorkarte '%s' wurde nicht gefunden.\n"
#: ../display/d.what.vect/main.c:61
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
-"aktuellen Region."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der aktuellen Region."
#: ../display/d.what.vect/main.c:68 ../display/d.what.rast/main.c:80
msgid "Identify just one location"
@@ -21085,9 +19710,7 @@
msgstr "Darstellung, Kartographie"
#: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
msgstr "Zeichnet Text im aktiven Graphik-Fenster mit der aktuellen Schrift."
#: ../display/d.text/main.c:148
@@ -21104,21 +19727,15 @@
#: ../display/d.text/main.c:173
msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B "
-"Tripel."
+msgstr "Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
#: ../display/d.text/main.c:182
msgid "The screen line number on which text will begin to be drawn"
msgstr "Die Zeile des Grafikfensters, in der der Text beginnt."
#: ../display/d.text/main.c:190
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in "
-"Prozent, [0,0] ist die untere linke Ecke)."
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in Prozent, [0,0] ist die untere linke Ecke)."
#: ../display/d.text/main.c:198
msgid "Text alignment"
@@ -21184,8 +19801,7 @@
"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
msgstr ""
"\n"
-"Bitte geben Sie Anweisungen ein. Um dies zu beenden geben Sie in der "
-"letzten Zeile EOF (Strg-d) ein.\n"
+"Bitte geben Sie Anweisungen ein. Um dies zu beenden geben Sie in der letzten Zeile EOF (Strg-d) ein.\n"
#: ../display/d.text/main.c:566
#, c-format
@@ -21193,11 +19809,8 @@
msgstr "[%s]: Diese Farbe gibt es nicht, verwende '%s'."
#: ../display/d.linegraph/main.c:122
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
-"Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+msgstr "Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
#: ../display/d.linegraph/main.c:126
msgid "Name of data file for X axis of graph"
@@ -21292,13 +19905,8 @@
msgstr "Sie klicken auÃerhalb der Karte."
#: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an "
-"einem angeklickten Punkt in der aktuellen Region abzufragen."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an einem angeklickten Punkt in der aktuellen Region abzufragen."
#: ../display/d.what.rast/main.c:75
msgid "Field separator (terse mode only)"
@@ -21306,9 +19914,7 @@
#: ../display/d.what.rast/main.c:89
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-"Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der "
-"Region aus."
+msgstr "Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der Region aus."
#: ../display/d.info/main.c:33 ../display/d.erase/main.c:31
#: ../display/d.mon/main.c:39
@@ -21344,8 +19950,7 @@
#: ../display/d.info/main.c:59
msgid "Display geographic coordinates and resolution of entire screen"
-msgstr ""
-"Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
+msgstr "Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
#: ../display/d.info/main.c:66
#, fuzzy
@@ -21353,8 +19958,7 @@
msgstr "Keine Karte angegeben."
#: ../display/d.vect.chart/main.c:66
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
msgstr "Stellt Diagramme von Vektordaten im aktiven Grafikfenster dar."
#: ../display/d.vect.chart/main.c:83
@@ -21378,9 +19982,7 @@
#: ../display/d.vect.chart/main.c:105
msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-"GröÃe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für "
-"Balkendiagrramm)."
+msgstr "GröÃe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für Balkendiagrramm)."
#: ../display/d.vect.chart/main.c:112
msgid "Scale for size (to get size in pixels)"
@@ -21402,7 +20004,7 @@
msgid "Maximum value used for bar plot reference"
msgstr "Maximaler Wert wird für die Referenz des Balkenplots verwendet."
-#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:164
+#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:163
msgid "Create legend information and send to stdout"
msgstr "Erzeuge Legendeninformation und gebe sie auf stdout aus."
@@ -21432,12 +20034,8 @@
#: ../display/d.barscale/main.c:92
#, fuzzy
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is lower-left of "
-"frame)"
-msgstr ""
-"Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist "
-"oben links)."
+msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
+msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
#: ../display/d.barscale/main.c:100
#, fuzzy
@@ -21460,12 +20058,8 @@
#: ../display/d.erase/main.c:34
#, fuzzy
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
-msgstr ""
-"Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten "
-"Farbe."
+msgid "Erases the contents of the active graphics display frame with user defined color."
+msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
#: ../display/d.erase/main.c:40
msgid "Remove all frames and erase the screen"
@@ -21476,12 +20070,8 @@
msgstr ""
#: ../display/d.zoom/main.c:64
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der "
-"Maus zu ändern."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der Maus zu ändern."
#: ../display/d.zoom/main.c:76 ../display/d.legend/main.c:92
msgid "Name of raster map"
@@ -21570,9 +20160,7 @@
#: ../display/d.zoom/zoom.c:41
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue "
-"Region einzustellen.\n"
+msgstr "Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue Region einzustellen.\n"
#: ../display/d.zoom/pan.c:17
#, c-format
@@ -21591,12 +20179,8 @@
#: ../display/d.rast.num/main.c:79
#, fuzzy
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
-msgstr ""
-"Ãberlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-"
-"Fenster."
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
+msgstr "Ãberlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-Fenster."
#: ../display/d.rast.num/main.c:87
msgid "Color for drawing grid, or \"none\""
@@ -21619,18 +20203,14 @@
#, c-format
msgid ""
"Current region size: %d rows X %d cols\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
msgstr ""
"Aktuelle Region: %d rows X %d cols\n"
-"Ihre aktuelle Fenstereinstellung könnte zu groà sein. Die im Grafikfenster "
-"dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu "
-"können."
+"Ihre aktuelle Fenstereinstellung könnte zu groà sein. Die im Grafikfenster dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu können."
#: ../display/d.rast.num/main.c:182
msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
-msgstr ""
-"Abbruch (Region gröÃer als 200 Zeilen x 200 Spalten sind nicht erlaubt)"
+msgstr "Abbruch (Region gröÃer als 200 Zeilen x 200 Spalten sind nicht erlaubt)"
#: ../display/d.grid/plot.c:356
msgid ""
@@ -21638,8 +20218,7 @@
msgstr ""
"Ausgabe in WGS84 ist unmöglich, da diese Location keine Datums-\n"
-"benutzen."
+"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
#: ../display/d.grid/plot.c:528
msgid "Error in pj_do_proj1"
@@ -21662,9 +20241,7 @@
msgstr "Fehler in pj_do_proj6"
#: ../display/d.grid/main.c:53
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
msgstr "Ãberlagert ein benutzerdefiniertes Gitter im aktiven Grafikfenster."
#: ../display/d.grid/main.c:61
@@ -21674,12 +20251,8 @@
#: ../display/d.grid/main.c:62
#, fuzzy
-msgid ""
-"0 for north-south resolution of the current region. In map units or DDD:MM:"
-"SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-"In Karteneinheiten oder im DDD:MM:SS Format. Beispiel: \"1000\" oder "
-"\"0:10\""
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgstr "In Karteneinheiten oder im DDD:MM:SS Format. Beispiel: \"1000\" oder \"0:10\""
#: ../display/d.grid/main.c:70
msgid "Lines of the grid pass through this coordinate"
@@ -21797,25 +20370,16 @@
msgstr "Einstellungen"
#: ../display/d.his/main.c:68
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- "
-"und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
#: ../display/d.his/main.c:96
msgid "Percent to brighten intensity channel"
msgstr "Prozent, die der Intensitätskanal aufgehellt wird."
#: ../display/d.geodesic/main.c:46
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
-msgstr ""
-"Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei "
-"geographischen Punkten auf dem GroÃkreis, in einem longitude/latitude "
-"Datensatz dar"
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+msgstr "Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei geographischen Punkten auf dem GroÃkreis, in einem longitude/latitude Datensatz dar"
#: ../display/d.geodesic/main.c:69
msgid "Text color or \"none\""
@@ -21833,9 +20397,7 @@
msgstr "Vektor, Zeichen Label"
#: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
msgstr "Zeigt Text-Label (mit v.label erstellt) im aktiven Grafikfenster."
#: ../display/d.labels/main.c:52
@@ -21861,13 +20423,11 @@
#: ../display/d.labels/main.c:97
msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
#: ../display/d.labels/main.c:105
msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
#, c-format
@@ -22062,14 +20622,12 @@
#: ../display/d.colortable/main.c:114
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:128
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:139
@@ -22115,9 +20673,7 @@
msgstr "%s: ungültiger Wert."
#: ../display/d.thematic.area/main.c:80
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
msgstr "Stellt eine thematische Vektorkarte im aktiven Grafikfenster dar."
#: ../display/d.thematic.area/main.c:90
@@ -22159,84 +20715,69 @@
msgid "Colors (one per class)."
msgstr "Farben (eine pro Klasse)."
-#: ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:133
msgid "Layer number. If -1, all layers are displayed."
msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer dargestellt."
-#: ../display/d.thematic.area/main.c:144 ../display/d.thematic.area/main.c:152
+#: ../display/d.thematic.area/main.c:143 ../display/d.thematic.area/main.c:151
msgid "Boundaries"
msgstr "Grenzen"
-#: ../display/d.thematic.area/main.c:145
+#: ../display/d.thematic.area/main.c:144
msgid "Boundary width"
msgstr "Breite der Grenze"
-#: ../display/d.thematic.area/main.c:151
+#: ../display/d.thematic.area/main.c:150
msgid "Boundary color"
msgstr "Farbe der Grenze"
-#: ../display/d.thematic.area/main.c:158
+#: ../display/d.thematic.area/main.c:157
msgid "File in which to save d.graph instructions for legend display"
-msgstr ""
-"Datei in der die d.grap-Anweisungen für die Darstellung der Legende "
-"gespeichert werden."
+msgstr "Datei in der die d.grap-Anweisungen für die Darstellung der Legende gespeichert werden."
-#: ../display/d.thematic.area/main.c:169
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
-msgstr ""
-"Beim ausgeben der Legenden-Info auch die erweiterte Statistik des "
-"Klassifikationsalgorithmus ausgeben."
+#: ../display/d.thematic.area/main.c:168
+msgid "When printing legend info , include extended statistical info from classification algorithm"
+msgstr "Beim ausgeben der Legenden-Info auch die erweiterte Statistik des Klassifikationsalgorithmus ausgeben."
-#: ../display/d.thematic.area/main.c:173
+#: ../display/d.thematic.area/main.c:172
msgid "Do not draw map, only output the legend"
msgstr "Zeichne nicht die Karte, gebe nur die Legende aus."
-#: ../display/d.thematic.area/main.c:192
+#: ../display/d.thematic.area/main.c:191
#, c-format
msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-"%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v."
-"build aus."
+msgstr "%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v.build aus."
-#: ../display/d.thematic.area/main.c:199
+#: ../display/d.thematic.area/main.c:198
msgid "'layer' must be > 0"
msgstr "'layer' muss > 0 sein."
-#: ../display/d.thematic.area/main.c:225
+#: ../display/d.thematic.area/main.c:224
#, c-format
msgid "Data (%s) not numeric. Column must be numeric."
msgstr "Daten (%s) nicht numerisch. Spalte muss numerisch sein."
-#: ../display/d.thematic.area/main.c:229
+#: ../display/d.thematic.area/main.c:228
#: ../display/d.thematic.area/plot1.c:134
#: ../display/d.thematic.area/plot1.c:162
#, c-format
msgid "Cannot select data (%s) from table"
msgstr "Kann die Daten (%s) nicht aus der Tabelle selektieren."
-#: ../display/d.thematic.area/main.c:292
+#: ../display/d.thematic.area/main.c:291
#, c-format
msgid "Unknown color: [%s]"
msgstr "Unbekannte Farbe: [%s]."
-#: ../display/d.thematic.area/main.c:303
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-"Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/"
-"Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und "
-"werden daher verwendet."
+#: ../display/d.thematic.area/main.c:302
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+msgstr "Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und werden daher verwendet."
-#: ../display/d.thematic.area/main.c:340
+#: ../display/d.thematic.area/main.c:339
msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
-"Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus "
-"angeben."
+msgstr "Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus angeben."
-#: ../display/d.thematic.area/main.c:353
+#: ../display/d.thematic.area/main.c:352
#, c-format
msgid ""
"Not enough colors or error in color specifications.\n"
@@ -22245,23 +20786,20 @@
"Nicht genügend Farben oder ein Fehler in der Farbspezifikation.\n"
"Brauche %i Farben."
-#: ../display/d.thematic.area/main.c:358
+#: ../display/d.thematic.area/main.c:357
#, c-format
msgid "Error interpreting color %s"
msgstr "Fehler beim Interpretieren der Farbe %s."
-#: ../display/d.thematic.area/main.c:377
+#: ../display/d.thematic.area/main.c:376
msgid "Plotting ..."
msgstr "Zeichne..."
-#: ../display/d.thematic.area/main.c:384
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
+#: ../display/d.thematic.area/main.c:383
+msgid "The bounding box of the map is outside the current region, nothing drawn."
-#: ../display/d.thematic.area/main.c:434
+#: ../display/d.thematic.area/main.c:433
#, c-format
msgid ""
"\n"
@@ -22270,40 +20808,35 @@
"\n"
"Gesamtzahl der Datensätze: %.0f\n"
-#: ../display/d.thematic.area/main.c:436
+#: ../display/d.thematic.area/main.c:435
#, c-format
msgid "Classification of %s into %i classes\n"
msgstr "Klassifikation von %s in %i Klassen\n"
-#: ../display/d.thematic.area/main.c:438 ../vector/v.class/main.c:202
+#: ../display/d.thematic.area/main.c:437 ../vector/v.class/main.c:202
#, c-format
msgid "Using algorithm: *** %s ***\n"
msgstr "Verwende den Algorithmus: *** %s ***\n"
-#: ../display/d.thematic.area/main.c:440 ../vector/v.class/main.c:203
+#: ../display/d.thematic.area/main.c:439 ../vector/v.class/main.c:203
#, c-format
msgid "Mean: %f\tStandard deviation = %f\n"
msgstr "Mittelwert: %f\tStandardabweichung = %f\n"
-#: ../display/d.thematic.area/main.c:444
+#: ../display/d.thematic.area/main.c:443
#, c-format
msgid "Last chi2 = %f\n"
msgstr "Letztes chi^2 = %f\n"
-#: ../display/d.thematic.area/main.c:447 ../vector/v.class/main.c:210
+#: ../display/d.thematic.area/main.c:446 ../vector/v.class/main.c:210
#, c-format
msgid "Stdev multiplied by %.4f to define step\n"
msgstr "Standardabweichung multipliziert mit %.4f definiert die Schrittweite\n"
#: ../display/d.thematic.area/plot1.c:129
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
-"Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die "
-"folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 "
-"liegen."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+msgstr "Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 liegen."
#: ../display/d.thematic.area/plot1.c:147
msgid "Line width column not specified."
@@ -22325,12 +20858,8 @@
#: ../display/d.thematic.area/plot1.c:278
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-"Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: "
-"Farbwert [%s]."
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: Farbwert [%s]."
#: ../display/d.thematic.area/plot1.c:285
#, c-format
@@ -22339,11 +20868,8 @@
#: ../display/d.thematic.area/plot1.c:353
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-"Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: "
-"Linienbreite [%d]."
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr "Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: Linienbreite [%d]."
#: ../display/d.fontlist/main.c:40
#, fuzzy
@@ -22376,24 +20902,16 @@
msgstr "Probleme beim Parsen des Befehls [%s]."
#: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-"Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr "Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
#: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird "
-"von der Standardeingabe gelesen."
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird von der Standardeingabe gelesen."
#: ../display/d.graph/main.c:73
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-"
-"Tripel."
+msgstr "Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-Tripel."
#: ../display/d.graph/main.c:80
msgid "Coordinates are given in map units"
@@ -22405,12 +20923,8 @@
msgstr "Grafik-Datei <%s> nicht gefunden."
#: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
-"Stellt drei Rasterkarten als rot, grün und blau Ãberlagerung im aktuellen "
-"Kartenfenster dar."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
+msgstr "Stellt drei Rasterkarten als rot, grün und blau Ãberlagerung im aktuellen Kartenfenster dar."
#: ../display/d.rgb/main.c:69
#, c-format
@@ -22549,12 +21063,8 @@
"\n"
#: ../display/d.rast.arrow/main.c:99
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf "
-"einer Rasterkarte mit Expositionsdaten."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf einer Rasterkarte mit Expositionsdaten."
#: ../display/d.rast.arrow/main.c:103
msgid "Name of raster aspect map to be displayed"
@@ -22603,8 +21113,7 @@
#: ../display/d.rast.arrow/main.c:214
msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr ""
-"Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
+msgstr "Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
#: ../display/d.rast.arrow/main.c:219
msgid "Scale option requires magnitude_map"
@@ -22624,14 +21133,11 @@
#: ../display/d.extract/extract.c:45
msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-"- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung "
-"entfernt werden soll."
+msgstr "- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung entfernt werden soll."
#: ../display/d.extract/extract.c:46
msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-" - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
+msgstr " - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
#: ../display/d.extract/extract.c:48
msgid "L: add M: remove R: quit and save\n"
@@ -22639,9 +21145,7 @@
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-"Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine "
-"neue Karte."
+msgstr "Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine neue Karte."
#: ../display/d.extract/main.c:117
msgid "Copying tables..."
@@ -22649,14 +21153,10 @@
#: ../display/d.extract/main.c:125
msgid "Cannot get db link info -> cannot copy table."
-msgstr ""
-"Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle "
-"nicht kopieren."
+msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle nicht kopieren."
#: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
msgstr "Zeichnet eine Legende für eine Rasterkarte im aktiven Grafikfenster."
#: ../display/d.legend/main.c:96 ../display/d.legend/main.c:158
@@ -22685,10 +21185,8 @@
#: ../display/d.legend/main.c:131
#, fuzzy
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr ""
-"Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
#: ../display/d.legend/main.c:140
msgid "List of discrete category numbers/values for legend"
@@ -22702,8 +21200,7 @@
#: ../display/d.legend/main.c:150
msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-"Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
+msgstr "Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
#: ../display/d.legend/main.c:167
#, fuzzy
@@ -22734,32 +21231,29 @@
#: ../display/d.legend/main.c:348
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"Legende liegt auÃerhalb des Rahmens. Text könnte nicht richtig dargestellt "
-"werden."
+msgstr "Legende liegt auÃerhalb des Rahmens. Text könnte nicht richtig dargestellt werden."
#: ../display/d.legend/main.c:352
msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
+msgstr "Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
#: ../display/d.legend/main.c:363
#, c-format
msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
-"aus)."
+msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
#: ../display/d.legend/main.c:368
msgid "Input map contains no data"
msgstr "Eingabekarte enthält keine Daten."
-#: ../display/d.legend/main.c:381 ../display/d.legend/main.c:541
-msgid "Color range exceeds lower limit of actual data"
+#: ../display/d.legend/main.c:381
+#, fuzzy
+msgid "Requested range exceeds lower limit of actual data"
msgstr "Farbspanne überschreitet untere Grenze des aktuellen Datensatzes."
-#: ../display/d.legend/main.c:387 ../display/d.legend/main.c:545
-msgid "Color range exceeds upper limit of actual data"
+#: ../display/d.legend/main.c:387
+#, fuzzy
+msgid "Requested range exceeds upper limit of actual data"
msgstr "Farbspanne überschreitet obere Grenze des aktuellen Datensatzes."
#: ../display/d.legend/main.c:446
@@ -22769,15 +21263,20 @@
#: ../display/d.legend/main.c:487
msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-"Nichts zu zeichnen! (Keine Kategorien mit Labeln? AuÃerhalb der Spanne?"
+msgstr "Nichts zu zeichnen! (Keine Kategorien mit Labeln? AuÃerhalb der Spanne?"
#: ../display/d.legend/main.c:497
msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des "
-"aktuellen Fensters."
+msgstr "Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des aktuellen Fensters."
+#: ../display/d.legend/main.c:541
+msgid "Color range exceeds lower limit of actual data"
+msgstr "Farbspanne überschreitet untere Grenze des aktuellen Datensatzes."
+#: ../display/d.legend/main.c:545
+msgid "Color range exceeds upper limit of actual data"
+msgstr "Farbspanne überschreitet obere Grenze des aktuellen Datensatzes."
#: ../display/d.legend/main.c:552
#, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
@@ -22788,12 +21287,8 @@
msgstr "Nichts zu zeichnen! Evtl. keine Kategorien mit Labeln?"
#: ../display/d.measure/main.c:49
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
-msgstr ""
-"Misst die Länge und Fläche von Features, gezeichnet vom Benutzer, im aktiven "
-"Grafikfenster."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
+msgstr "Misst die Länge und Fläche von Features, gezeichnet vom Benutzer, im aktiven Grafikfenster."
#: ../display/d.measure/main.c:55
msgid "Line color 1"
@@ -22816,11 +21311,8 @@
msgstr "Ausgabe auch in Kilometer."
#: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr ""
-"Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die "
-"Darstellung mit d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr "Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die Darstellung mit d.text."
#: ../display/d.title/main.c:63
msgid "Sets the text color"
@@ -22851,12 +21343,8 @@
#: ../display/d.font/main.c:49
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt "
-"wird."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt wird."
#: ../display/d.font/main.c:57
msgid "Choose new current font"
@@ -22886,11 +21374,8 @@
#: ../display/d.font/main.c:127
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-"Der Name des Fonts <%s> ist nicht gültig. Ãberprüfe Sie den Namen oder "
-"überlegen Sie 'g.mkfontcap' auszuführen."
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr "Der Name des Fonts <%s> ist nicht gültig. Ãberprüfe Sie den Namen oder überlegen Sie 'g.mkfontcap' auszuführen."
#: ../general/g.filename/main.c:41
msgid "Prints GRASS data base file names."
@@ -22954,9 +21439,7 @@
#: ../general/g.gui/main.c:70
msgid "Do not launch GUI after updating the default GUI setting"
-msgstr ""
-"Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen "
-"geändert haben."
+msgstr "Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen geändert haben."
#: ../general/g.gui/main.c:98
#, c-format
@@ -22996,14 +21479,11 @@
#: ../general/g.access/main.c:64
msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-"Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht "
-"unterstützt."
+msgstr "Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht unterstützt."
#: ../general/g.access/main.c:72
msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-"Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
+msgstr "Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
#: ../general/g.access/main.c:76
msgid "Unable to determine mapset permissions"
@@ -23108,12 +21588,8 @@
#: ../general/g.findfile/main.c:97
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
-msgstr ""
-"Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der "
-"Parameter Mapset <%s> stimmt damit nicht überein."
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgstr "Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der Parameter Mapset <%s> stimmt damit nicht überein."
#: ../general/g.proj/datumtrans.c:47
#, c-format
@@ -23155,22 +21631,12 @@
#: ../general/g.proj/create.c:36
#, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Sie müssen das PERMANENT-Mapset selektieren, bevor Sie die Projektion der "
-"aktuelle Location aktualisieren (aktuelles Mapset: <%s>)."
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Sie müssen das PERMANENT-Mapset selektieren, bevor Sie die Projektion der aktuelle Location aktualisieren (aktuelles Mapset: <%s>)."
#: ../general/g.proj/create.c:62
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
-msgstr ""
-"Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie "
-"aber mehrere Mapsets haben, sollten Sie `g.region -d` in jedem ausführen, "
-"um die Einstellungen von der Standardregion zu übernehmen."
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
+msgstr "Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben, sollten Sie `g.region -d` in jedem ausführen, um die Einstellungen von der Standardregion zu übernehmen."
#: ../general/g.proj/create.c:66
msgid "Projection information updated"
@@ -23182,12 +21648,8 @@
msgstr "Location: %s\n"
#: ../general/g.proj/main.c:68
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
-msgstr ""
-"Ausgabe und Manipulation von GRASS Projektionsinformationsdateien (in "
-"verschieden Koordinatensystembeschreibungen)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
+msgstr "Ausgabe und Manipulation von GRASS Projektionsinformationsdateien (in verschieden Koordinatensystembeschreibungen)."
#: ../general/g.proj/main.c:71
msgid "Can also be used to create new GRASS locations."
@@ -23207,16 +21669,14 @@
#: ../general/g.proj/main.c:93
msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Ãberprüfe Datum-Informationen und gebe die Transformationsparameter aus."
+msgstr "Ãberprüfe Datum-Informationen und gebe die Transformationsparameter aus."
#: ../general/g.proj/main.c:99
msgid "Print projection information in PROJ.4 format"
msgstr "Gebe die Projektionsinformationen im PROJ.4-Format aus."
#: ../general/g.proj/main.c:105
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr "Ausgabe ohne Zeilenumbrüche (nur bei WKT- und PROJ.4-Ausgaben)"
#: ../general/g.proj/main.c:115
@@ -23234,9 +21694,7 @@
#: ../general/g.proj/main.c:129
msgid "Name of georeferenced data file to read projection information from"
-msgstr ""
-"Name der Datei georeferenzierten Daten, von der Projektionsinformationen "
-"gelesen werden sollen"
+msgstr "Name der Datei georeferenzierten Daten, von der Projektionsinformationen gelesen werden sollen"
#: ../general/g.proj/main.c:138
msgid "Name of ASCII file containing a WKT projection description"
@@ -23267,9 +21725,7 @@
#: ../general/g.proj/main.c:170
msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
-msgstr ""
-"Akzeptiert Standard GRASS Datumcodes oder \"list\" zum Anzeigen der Liste "
-"und beenden"
+msgstr "Akzeptiert Standard GRASS Datumcodes oder \"list\" zum Anzeigen der Liste und beenden"
#: ../general/g.proj/main.c:180
msgid "Index number of datum transform parameters"
@@ -23277,17 +21733,11 @@
#: ../general/g.proj/main.c:181
msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-"\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu "
-"beenden"
+msgstr "\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu beenden"
#: ../general/g.proj/main.c:187
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
-msgstr ""
-"Erzwinge das Ãbersteuern der Datumtransformationsinformation des Eingabe "
-"Koordinatensystems."
+msgid "Force override of datum transformation information in input co-ordinate system"
+msgstr "Erzwinge das Ãbersteuern der Datumtransformationsinformation des Eingabe Koordinatensystems."
#: ../general/g.proj/main.c:193
msgid "Create new projection files (modifies current location)"
@@ -23305,8 +21755,7 @@
#: ../general/g.proj/main.c:218
#, c-format
msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-"Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
+msgstr "Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
#: ../general/g.proj/main.c:261
msgid "Projection files missing"
@@ -23315,21 +21764,17 @@
#: ../general/g.proj/main.c:281
#, c-format
msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-"Nur ein Schalter von -%c, -%c, -%c, -%c, -%c oder -%c kann angegeben werden"
+msgstr "Nur ein Schalter von -%c, -%c, -%c, -%c, -%c oder -%c kann angegeben werden"
#: ../general/g.proj/main.c:308
#, c-format
msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr ""
-"Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c, -%c oder "
-"-%c"
+msgstr "Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c, -%c oder -%c"
#: ../general/g.proj/main.c:312
#, c-format
msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr ""
-"Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c oder -%c"
+msgstr "Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c oder -%c"
#: ../general/g.proj/input.c:91
msgid "Error reading WKT projection description"
@@ -23367,13 +21812,8 @@
#: ../general/g.proj/input.c:259
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine "
-"Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird "
-"benutzt."
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird benutzt."
#: ../general/g.proj/output.c:181
#, c-format
@@ -23388,16 +21828,13 @@
#: ../general/g.mremove/check_reclass.c:22
#, fuzzy, c-format
msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
-msgstr ""
-"[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
+msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
#: ../general/g.mremove/check_reclass.c:45
#: ../general/g.mremove/check_reclass.c:59
#, c-format
msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr ""
-"Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist "
-"fehlgeschlagen."
+msgstr "Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist fehlgeschlagen."
#: ../general/g.mremove/main.c:63 ../general/g.remove/main.c:103
#: ../locale/scriptstrings/t.remove_to_translate.c:4
@@ -23412,9 +21849,7 @@
#: ../general/g.mremove/main.c:66
#, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using regular "
-"expressions."
+msgid "Removes data base element files from the user's current mapset using regular expressions."
msgstr "Löscht Karten aus dem aktuellen Mapset."
#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:102
@@ -23465,9 +21900,7 @@
#: ../general/g.mremove/main.c:153
#, fuzzy, c-format
msgid "You must use the force flag (-%c) to actually remove them. Exiting."
-msgstr ""
-"Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende "
-"mich."
+msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
#: ../general/g.mapset/main.c:51
#, fuzzy
@@ -23475,11 +21908,8 @@
msgstr "Ãndere aktuelles Mapset."
#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-"Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der "
-"Location auf."
+msgid "Optionally create new mapset or list available mapsets in given location."
+msgstr "Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der Location auf."
#: ../general/g.mapset/main.c:56
msgid "Name of mapset where to switch"
@@ -23496,9 +21926,7 @@
#: ../general/g.mapset/main.c:76
#, fuzzy
msgid "Full path to the directory where the new location is"
-msgstr ""
-"Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue "
-"L0cation befindet)."
+msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue L0cation befindet)."
#: ../general/g.mapset/main.c:81
msgid "Create mapset if it doesn't exist"
@@ -23527,8 +21955,7 @@
#: ../general/g.mapset/main.c:168
#, fuzzy, c-format
msgid "Mapset <%s> does not exist. Use -c flag to create it."
-msgstr ""
-"Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
+msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
#: ../general/g.mapset/main.c:178
msgid "Unable to read GIS_LOCK environment variable"
@@ -23542,9 +21969,7 @@
#: ../general/g.mapset/main.c:197
#, fuzzy, c-format
msgid "There appears to be an active GRASS session in selected mapset <%s>"
-msgstr ""
-"%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann "
-"nicht überprüft werden."
+msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
#: ../general/g.mapset/main.c:203
msgid "Cleaning up temporary files..."
@@ -23728,12 +22153,8 @@
msgstr ""
#: ../general/g.mlist/main.c:66
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten "
-"Datentyps und verwende optional ein Suchmuster."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps und verwende optional ein Suchmuster."
#: ../general/g.mlist/main.c:81
msgid "Map name search pattern (default: all)"
@@ -23992,9 +22413,7 @@
#: ../general/g.region/main.c:87
msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen "
-"Ellipsoid/Datum aus."
+msgstr "Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen Ellipsoid/Datum aus."
#: ../general/g.region/main.c:93
msgid "Print the current region extent"
@@ -24021,12 +22440,8 @@
msgstr "Gebe den Konvergenzwinkel aus (Grad CCW)."
#: ../general/g.region/main.c:124
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
-msgstr ""
-"Die Differenz zwischen dem Gitternord der Projektion und der wahren "
-"Nordrichtung gemessen im Zentrum der aktuellen Region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+msgstr "Die Differenz zwischen dem Gitternord der Projektion und der wahren Nordrichtung gemessen im Zentrum der aktuellen Region."
#: ../general/g.region/main.c:130
msgid "Print also 3D settings"
@@ -24037,12 +22452,8 @@
msgstr "Gebe die maximale Bounding-Box in Lat/Long Koordinaten in WGS84 aus."
#: ../general/g.region/main.c:147
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Passe Region an die Auflösung an (Standard = passe an die Grenzen an; "
-"funktioniert nur für 2D-Auflösung)."
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Passe Region an die Auflösung an (Standard = passe an die Grenzen an; funktioniert nur für 2D-Auflösung)."
#: ../general/g.region/main.c:153
msgid "Do not update the current region"
@@ -24066,9 +22477,7 @@
#: ../general/g.region/main.c:180
#, fuzzy
msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
-msgstr ""
-"Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-"
-"Werte)."
+msgstr "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-Werte)."
#: ../general/g.region/main.c:188
#, fuzzy
@@ -24124,9 +22533,7 @@
#: ../general/g.region/main.c:328
msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-"Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser "
-"Rasterkarte stösst."
+msgstr "Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser Rasterkarte stösst."
#: ../general/g.region/main.c:339
msgid "Adjust region cells to cleanly align with this raster map"
@@ -24134,9 +22541,7 @@
#: ../general/g.region/main.c:350
msgid "Save current region settings in named region file"
-msgstr ""
-"Speichere die Einstellungen der aktuellen Region in eine benannte Regions-"
-"Datei."
+msgstr "Speichere die Einstellungen der aktuellen Region in eine benannte Regions-Datei."
#: ../general/g.region/main.c:409
#, c-format
@@ -24184,9 +22589,7 @@
#: ../general/g.region/main.c:820
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht "
-"<PERMANENT>."
+msgstr "Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht <PERMANENT>."
#: ../general/g.region/main.c:837
#, c-format
@@ -24200,24 +22603,15 @@
#: ../general/g.region/printwindow.c:410
msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr ""
-"Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
+msgstr "Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
#: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
-msgstr ""
-"Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon "
-"ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgstr "Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"WGS84 Ausgabe nicht möglich, da diese Location keine "
-"Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "WGS84 Ausgabe nicht möglich, da diese Location keine Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
#: ../general/g.region/printwindow.c:783
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -24225,14 +22619,10 @@
#: ../general/g.list/main.c:48
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-"Datentyps."
+msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps."
#: ../general/g.mkfontcap/main.c:72
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+msgid "Generates the font configuration file by scanning various directories for fonts."
msgstr ""
#: ../general/g.mkfontcap/main.c:78
@@ -24240,8 +22630,7 @@
msgstr ""
#: ../general/g.mkfontcap/main.c:83
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
msgstr ""
#: ../general/g.mkfontcap/main.c:90
@@ -24249,21 +22638,16 @@
msgstr ""
#: ../general/g.mkfontcap/main.c:92
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
msgstr ""
#: ../general/g.mkfontcap/main.c:109
#, fuzzy, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
msgstr "Die Datei '%s' existiert bereits und wird überschrieben."
#: ../general/g.mkfontcap/main.c:121
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
msgstr ""
#: ../general/g.mkfontcap/main.c:148
@@ -24287,8 +22671,7 @@
#: ../general/g.setproj/main.c:88
msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
-"Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
+msgstr "Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
#: ../general/g.setproj/main.c:101
msgid "PERMANENT: permission denied"
@@ -24393,14 +22776,8 @@
msgstr "Die Information zu der UTM Zone wurde nicht aktualisiert."
#: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
-msgstr ""
-"Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der "
-"Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch "
-"umprojezieren oder die Header existierender Karten ändern."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgstr "Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch umprojezieren oder die Header existierender Karten ändern."
#: ../general/g.setproj/main.c:461
msgid "Would you still like to change the UTM zone?"
@@ -24456,8 +22833,7 @@
#: ../general/g.setproj/get_stp.c:43
msgid "This should not happen see your system admin"
-msgstr ""
-"Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
+msgstr "Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
#: ../general/g.setproj/get_stp.c:99
msgid "Unable to open FIPS code file"
@@ -24487,15 +22863,12 @@
#: ../general/g.remove/main.c:41
#, fuzzy, c-format
msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr ""
#: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
#, fuzzy, c-format
msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr ""
-"fehlgeschlagen."
#: ../general/g.remove/main.c:105
msgid "Removes data base element files from the user's current mapset."
@@ -24576,15 +22949,12 @@
msgstr "PostScript"
#: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr "Gibt eine Nachricht, Warnung oder fatalen Fehler im GRASS-Stil aus."
#: ../general/g.message/main.c:39
msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-"Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den "
-"Benutzer auszugeben."
+msgstr "Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den Benutzer auszugeben."
#: ../general/g.message/main.c:44
msgid "Print message as warning"
@@ -24667,18 +23037,13 @@
msgstr "Ãndere den aktuellen Mapset-Suchpfad aus."
#: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen "
-"Mapsets in der aktuellen Location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr "Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen Mapsets in der aktuellen Location."
#: ../general/g.mapsets/main.c:75
#, fuzzy
msgid "Name(s) of existing mapset(s) to add/remove or set"
-msgstr ""
-"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
#: ../general/g.mapsets/main.c:76 ../general/g.mapsets/main.c:85
msgid "Search path"
@@ -24781,9 +23146,7 @@
#: ../general/g.copy/main.c:45
#, fuzzy
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
#: ../general/g.copy/main.c:52
@@ -24830,9 +23193,7 @@
msgstr "Maximale z-Höhe (benötigt den Schalter '-z' oder Spaltenname)."
#: ../vector/v.random/main.c:122
-msgid ""
-"The seed to initialize the random generator. If not set the process id is "
-"used."
+msgid "The seed to initialize the random generator. If not set the process id is used."
msgstr ""
#: ../vector/v.random/main.c:125
@@ -24868,12 +23229,8 @@
msgstr "Tabelle sollte nur zwei Spalten haben."
#: ../vector/v.random/main.c:236
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
-msgstr ""
-"Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt "
-"nur die Spaltentypen INTEGER und DOUBLE PRECISION."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgstr "Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt nur die Spaltentypen INTEGER und DOUBLE PRECISION."
#: ../vector/v.random/main.c:272
msgid "Generating points..."
@@ -24889,14 +23246,8 @@
msgstr "Linie"
#: ../vector/v.net.iso/main.c:76
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
-msgstr ""
-"Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). "
-"Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
-"Knotens gehen in die Berechnung ein."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
+msgstr "Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knotens gehen in die Berechnung ein."
#: ../vector/v.net.iso/main.c:100 ../vector/v.net.centrality/main.c:129
#: ../vector/v.net.distance/main.c:138 ../vector/v.net.alloc/main.c:93
@@ -24926,12 +23277,8 @@
msgstr "Spalte mit Kosten für Knoten (Zahl)."
#: ../vector/v.net.iso/main.c:114
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
-msgstr ""
-"Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. "
-"Layer für diese Kategorien wird mit der Option nlayer angegeben. "
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
+msgstr "Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. Layer für diese Kategorien wird mit der Option nlayer angegeben. "
#: ../vector/v.net.iso/main.c:123
msgid "Costs for isolines"
@@ -24954,8 +23301,7 @@
#: ../vector/v.net.iso/main.c:172
msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-"Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
+msgstr "Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
#: ../vector/v.net.iso/main.c:198 ../vector/v.net.steiner/main.c:441
#: ../vector/v.net.alloc/main.c:163 ../vector/v.net.salesman/main.c:236
@@ -24974,8 +23320,7 @@
#: ../vector/v.net.iso/main.c:227
msgid "Not enough centres for selected nlayer. Nothing will be allocated."
-msgstr ""
-"Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
+msgstr "Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
#: ../vector/v.net.iso/main.c:247
#, c-format
@@ -24985,8 +23330,7 @@
#: ../vector/v.net.iso/main.c:508 ../vector/v.net.alloc/main.c:343
#: ../vector/v.net.alloc/main.c:354
msgid "Cannot get line segment, segment out of line"
-msgstr ""
-"Kann das Liniensegment nicht bekommen, Segment ist auÃerhalb der Linie."
+msgstr "Kann das Liniensegment nicht bekommen, Segment ist auÃerhalb der Linie."
#: ../vector/v.net.centrality/main.c:98
#, fuzzy
@@ -24994,12 +23338,8 @@
msgstr "Berechne ZentralitätsmaÃe..."
#: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor "
-"centrality Werte im Netzwerk."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor centrality Werte im Netzwerk."
#: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
@@ -25053,8 +23393,7 @@
#: ../vector/v.net.centrality/main.c:175
msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr ""
-"Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
+msgstr "Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
#: ../vector/v.net.centrality/main.c:183
msgid "Cummulative error tolerance for eigenvector centrality"
@@ -25115,7 +23454,7 @@
#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:152
#: ../vector/v.proj/main.c:411 ../vector/v.kcv/main.c:142
-#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:719
+#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:750
#: ../vector/v.transform/main.c:286 ../vector/v.rectify/main.c:285
msgid "Failed to copy attribute table to output map"
msgstr "Kopieren der Attributtabelle in die Ausgabekarte fehlgeschlagen."
@@ -25194,12 +23533,8 @@
#: ../vector/v.voronoi/main.c:123
#, fuzzy
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
-msgstr ""
-"Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder "
-"Zentroiden."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
#: ../vector/v.voronoi/main.c:127 ../vector/v.sample/main.c:82
#: ../vector/v.surf.bspline/main.c:114
@@ -25261,13 +23596,8 @@
msgstr "Erzeuge 'Steiner Tree' für das Netzwerk und die gegebenen Stationen"
#: ../vector/v.net.steiner/main.c:351
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
-msgstr ""
-"Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem "
-"Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis "
-"suboptimal sein."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
+msgstr "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis suboptimal sein."
#: ../vector/v.net.steiner/main.c:371
msgid "Node layer (used for terminals)"
@@ -25279,8 +23609,7 @@
#: ../vector/v.net.steiner/main.c:383
msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
-"Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegeben)"
+msgstr "Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegeben)"
#: ../vector/v.net.steiner/main.c:391
msgid "Number of steiner points (-1 for all possible)"
@@ -25297,17 +23626,12 @@
#: ../vector/v.net.steiner/main.c:513
#, c-format
msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-"Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden "
-"werden"
+msgstr "Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden werden"
#: ../vector/v.net.steiner/main.c:529
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-"[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-"
-"Punktkandidaten entfernt"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr "[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-Punktkandidaten entfernt"
#: ../vector/v.net.steiner/main.c:534
#, c-format
@@ -25322,9 +23646,7 @@
#: ../vector/v.net.steiner/main.c:561
#, c-format
msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-"Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten "
-"= %f)."
+msgstr "Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten = %f)."
#: ../vector/v.net.steiner/main.c:573
msgid "No Steiner point found -> leaving cycle"
@@ -25419,19 +23741,11 @@
#: ../vector/v.overlay/main.c:100
msgid "Operator defines features written to output vector map"
-msgstr ""
-"Operator bestimmt, welche Feature in die Ausgabe-Vektorkarte geschrieben "
-"werden."
+msgstr "Operator bestimmt, welche Feature in die Ausgabe-Vektorkarte geschrieben werden."
#: ../vector/v.overlay/main.c:103
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"Ein Feature wird in die Ausgabekarte geschrieben, wenn das Ergebnis der "
-"Operation 'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als "
-"wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgstr "Ein Feature wird in die Ausgabekarte geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
#: ../vector/v.overlay/main.c:110
msgid "also known as 'intersection' in GIS"
@@ -25446,9 +23760,7 @@
msgstr ""
#: ../vector/v.overlay/main.c:113
-msgid ""
-"features from either ainput or binput but not those from ainput overlayed by "
-"binput (only for atype=area)"
+msgid "features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
msgstr ""
#: ../vector/v.overlay/main.c:124
@@ -25539,13 +23851,8 @@
#: ../vector/v.kernel/main.c:112
#, fuzzy
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
-msgstr ""
-"Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines "
-"gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem "
-"Vektornetzwerk erstellt werden."
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+msgstr "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem Vektornetzwerk erstellt werden."
#: ../vector/v.kernel/main.c:116
#, fuzzy
@@ -25602,9 +23909,7 @@
#: ../vector/v.kernel/main.c:180
#, fuzzy
msgid "No method applied at nodes with more than 2 arcs"
-msgstr ""
-"nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;"
-"Equal split (Okabe 2009) angewendet bei Knoten;"
+msgstr "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;Equal split (Okabe 2009) angewendet bei Knoten;"
#: ../vector/v.kernel/main.c:181
msgid "Equal split (Okabe 2009) applied at nodes"
@@ -25615,34 +23920,21 @@
msgstr "Kernel Funktion"
#: ../vector/v.kernel/main.c:197
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu "
-"berechnen (experimentell)."
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu berechnen (experimentell)."
#: ../vector/v.kernel/main.c:202
msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte "
-"wird geschrieben)."
+msgstr "Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte wird geschrieben)."
#: ../vector/v.kernel/main.c:207
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-"Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte "
-"multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte "
-"ergibt 1.0 * mult."
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgstr "Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte ergibt 1.0 * mult."
#: ../vector/v.kernel/main.c:213
#, fuzzy
msgid "In network mode, multiply the result by number of input points"
-msgstr ""
-"Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-"
-"Punkte."
+msgstr "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-Punkte."
#: ../vector/v.kernel/main.c:223 ../vector/v.in.lidar/main.c:472
#, c-format
@@ -25664,20 +23956,12 @@
msgstr "Unbekannte Kernelfunktion"
#: ../vector/v.kernel/main.c:276
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
-msgstr ""
-"Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode "
-"'none' und die Kernelfunktion 'gaussian' unterstützt."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode 'none' und die Kernelfunktion 'gaussian' unterstützt."
#: ../vector/v.kernel/main.c:280
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
-msgstr ""
-"Optimale Berechnung der Standardabweichung wird nur durch die Kernel-"
-"Funktion 'gaussian' unterstützt."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Kernel-Funktion 'gaussian' unterstützt."
#: ../vector/v.kernel/main.c:297
#, fuzzy, c-format
@@ -25696,12 +23980,8 @@
#: ../vector/v.kernel/main.c:358
#, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der "
-"Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
#: ../vector/v.kernel/main.c:365
#, c-format
@@ -25720,12 +24000,8 @@
#: ../vector/v.kernel/main.c:383
#, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), "
-"daher kann kein optimaler Wert berechnet werden."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), daher kann kein optimaler Wert berechnet werden."
#: ../vector/v.kernel/main.c:394
#, c-format
@@ -25779,9 +24055,7 @@
#: ../vector/v.in.ogr/main.c:142
msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer "
-"importiert."
+msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer importiert."
#: ../vector/v.in.ogr/main.c:144
msgid ""
@@ -25807,8 +24081,7 @@
#: ../vector/v.in.ogr/main.c:174
msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Kleinere Flächen und Inseln werden ignoriert. Sollte gröÃer sein als snap^2."
+msgstr "Kleinere Flächen und Inseln werden ignoriert. Sollte gröÃer sein als snap^2."
#: ../vector/v.in.ogr/main.c:180
msgid "Optionally change default input type"
@@ -25839,12 +24112,8 @@
msgstr "'-1' für kein snapping"
#: ../vector/v.in.ogr/main.c:212
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der "
-"Erste entspricht der Kategoriespalte."
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der Erste entspricht der Kategoriespalte."
#: ../vector/v.in.ogr/main.c:221
#, fuzzy
@@ -25887,9 +24156,7 @@
msgstr "Ãndere Spaltenname zu Kleinbuchstaben"
#: ../vector/v.in.ogr/main.c:279
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
msgstr ""
#: ../vector/v.in.ogr/main.c:298
@@ -25928,9 +24195,7 @@
#: ../vector/v.in.ogr/main.c:486 ../vector/v.in.lidar/main.c:281
msgid "Select either the current region flag or the spatial option, not both"
-msgstr ""
-"Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option "
-"'spatial' aber nicht beide."
+msgstr "Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option 'spatial' aber nicht beide."
#: ../vector/v.in.ogr/main.c:488
msgid "The region flag is applied only to the first OGR layer"
@@ -25949,8 +24214,7 @@
msgstr "4 Werte sind für den Parameter 'spatial' nötig."
#: ../vector/v.in.ogr/main.c:553
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
msgstr ""
#: ../vector/v.in.ogr/main.c:587
@@ -25980,25 +24244,17 @@
#: ../vector/v.in.ogr/main.c:908
#, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas "
-"abgeschnitten worden sein). "
+msgstr "Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
#: ../vector/v.in.ogr/main.c:931
#, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR "
-"bestimmt). Einige Texte können abgeschnitten worden sein!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR bestimmt). Einige Texte können abgeschnitten worden sein!"
#: ../vector/v.in.ogr/main.c:943
#, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-"Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas "
+msgstr "Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
#: ../vector/v.in.ogr/main.c:947
#, c-format
@@ -26064,7 +24320,7 @@
msgstr "Entferne Brücken"
#: ../vector/v.in.ogr/main.c:1208 ../vector/v.delaunay/main.c:171
-#: ../vector/v.category/main.c:326
+#: ../vector/v.category/main.c:357
msgid "Unable to calculate area centroid"
msgstr "Kann den Zentroid der Fläche nicht berechnen."
@@ -26075,15 +24331,8 @@
#: ../vector/v.in.ogr/main.c:1291
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem "
-"Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in "
-"der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
-"als Kategoriewert im Layer %d abgelegt."
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist als Kategoriewert im Layer %d abgelegt."
#: ../vector/v.in.ogr/main.c:1301
#, c-format
@@ -26127,12 +24376,8 @@
#: ../vector/v.in.ogr/main.c:1376
#, fuzzy
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
-msgstr ""
-"Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur "
-"2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
+msgstr "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
#: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
#, fuzzy
@@ -26180,9 +24425,7 @@
#: ../vector/v.net/args.c:15
#, fuzzy
msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr ""
-"Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des "
-"gegebenen Schwellenwertes."
+msgstr "Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des gegebenen Schwellenwertes."
#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:56
msgid "Arcs"
@@ -26213,8 +24456,7 @@
msgstr ""
#: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
+msgid "connect still unconnected points to vector network by inserting new line(s)"
msgstr ""
#: ../vector/v.net/args.c:44
@@ -26222,21 +24464,16 @@
msgstr ""
#: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
+msgid "print to standard output {line_category start_point_category end_point_category}"
msgstr ""
#: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
+msgid "print to standard output {point_category line_category[,line_category...]}"
msgstr ""
#: ../vector/v.net/args.c:72
msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
#: ../vector/v.net/args.c:76
#, fuzzy
@@ -26262,9 +24499,7 @@
msgstr "Vektorkarte mit den Stopp-Punkten"
#: ../vector/v.net/args.c:91
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
msgstr ""
#: ../vector/v.net/args.c:113
@@ -26347,8 +24582,7 @@
#: ../vector/v.proj/main.c:69
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
#: ../vector/v.proj/main.c:75
#, fuzzy
@@ -26387,9 +24621,7 @@
#: ../vector/v.proj/main.c:115
msgid "Assume z co-ordinate is ellipsoidal height and transform if possible"
-msgstr ""
-"Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und "
-"transformiere, wenn möglich."
+msgstr "Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und transformiere, wenn möglich."
#: ../vector/v.proj/main.c:121
msgid "Latlon output only, default is -180,180"
@@ -26503,8 +24735,7 @@
#: ../vector/v.label/main.c:137
msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
+msgstr "Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
#: ../vector/v.label/main.c:144
msgid "Label size (in points)"
@@ -26529,16 +24760,11 @@
#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe "
-"ausgewählt wurde)."
+msgstr "Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe ausgewählt wurde)."
#: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"GröÃen- und Abstandsoptionen differieren signifikant, was zu einer komischen "
-"Ausgabe führen kann."
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "GröÃen- und Abstandsoptionen differieren signifikant, was zu einer komischen Ausgabe führen kann."
#: ../vector/v.label/main.c:259
msgid "Too many parameters for <reference>"
@@ -26565,33 +24791,24 @@
#: ../vector/v.univar/main.c:95
#, fuzzy
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
-msgstr ""
-"Berechnet univariate Statistiken für die Attribute. Die Varianz und "
-"Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+msgid "Variance and standard deviation is calculated only for points if specified."
+msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
#: ../vector/v.univar/main.c:130
msgid "Calculate geometry distances instead of table data."
msgstr "Berechne Geometriedistanzen an Stelle der Tabellenwerte."
#: ../vector/v.univar/main.c:161
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Feature, das "
-"Minimum, das Maximum und die Spanne berechnet werden."
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Feature, das Minimum, das Maximum und die Spanne berechnet werden."
#: ../vector/v.univar/main.c:166
msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
+msgstr "Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
#: ../vector/v.univar/main.c:191
msgid "'layer' must be > 0 for 'where'."
-msgstr ""
-"Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
+msgstr "Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
#: ../vector/v.univar/main.c:206
#, c-format
@@ -26621,22 +24838,13 @@
msgstr ""
#: ../vector/v.net.distance/main.c:67
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das "
-"Netzwerk."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das Netzwerk."
#: ../vector/v.net.distance/main.c:70
#, fuzzy
-msgid ""
-"Finds the shortest paths from a point 'from' to every feature 'to' and "
-"various information about this relation are uploaded to the attribute table."
-msgstr ""
-"Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und "
-"zahlreiche Informationen über diese Beziehung wird in der Attributtabelle "
-"abgespeichert"
+msgid "Finds the shortest paths from a point 'from' to every feature 'to' and various information about this relation are uploaded to the attribute table."
+msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
#: ../vector/v.net.distance/main.c:97
msgid "From layer number or name"
@@ -26645,6 +24853,7 @@
#: ../vector/v.net.distance/main.c:98 ../vector/v.net.distance/main.c:103
#: ../vector/v.net.distance/main.c:109 ../vector/v.distance/main.c:97
#: ../vector/v.distance/main.c:102 ../vector/v.distance/main.c:109
+#: ../vector/v.distance/main.c:188
msgid "From"
msgstr "From"
@@ -26654,8 +24863,7 @@
#: ../vector/v.net.distance/main.c:108
msgid "From WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.distance/main.c:113
msgid "To layer number or name"
@@ -26678,8 +24886,7 @@
#: ../vector/v.net.distance/main.c:131
msgid "To WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.distance/main.c:218
#, c-format
@@ -26718,12 +24925,8 @@
msgstr "Vektor, Netzwerk"
#: ../vector/v.lrs/v.lrs.segment/main.c:74
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des "
-"Linearenreferenzsystems und Positionen von stdin oder einer Datei."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
#: ../vector/v.lrs/v.lrs.segment/main.c:78
#: ../vector/v.lrs/v.lrs.where/main.c:66
@@ -26765,9 +24968,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:113
msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
-"Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von "
-"stdin gelesen."
+msgstr "Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von stdin gelesen."
#: ../vector/v.lrs/v.lrs.segment/main.c:152
#: ../vector/v.lrs/v.lrs.where/main.c:145
@@ -26804,8 +25005,7 @@
"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
"%s"
msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] "
-"(Linienlänge = %f)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] (Linienlänge = %f)\n"
"%s"
#: ../vector/v.lrs/v.lrs.segment/main.c:249
@@ -26832,8 +25032,7 @@
"Requested offset for the 1. point not found, using nearest found:\n"
" %s"
msgstr ""
-"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den "
-"Nächsten:\n"
+"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den Nächsten:\n"
" %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:269
@@ -26851,8 +25050,7 @@
"Requested offset for the 2. point not found, using nearest found:\n"
" %s"
msgstr ""
-"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den "
-"Nächsten:\n"
+"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den Nächsten:\n"
" %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:278
@@ -26879,8 +25077,7 @@
"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
"%s"
msgstr ""
-"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie "
-"= %f)\n"
+"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie = %f)\n"
"%s"
#: ../vector/v.lrs/v.lrs.segment/main.c:332 ../vector/v.segment/main.c:217
@@ -26910,12 +25107,8 @@
msgstr "[%d] Linien in die Ausgabekarte geschrieben (%d verloren)."
#: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte "
-"einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
#: ../vector/v.lrs/v.lrs.where/main.c:70
msgid "Input vector map containing points"
@@ -26957,8 +25150,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:133
msgid "Output vector map where oriented lines are written"
-msgstr ""
-"Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
+msgstr "Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
#: ../vector/v.lrs/v.lrs.create/main.c:138
msgid "Output vector map of errors"
@@ -26978,28 +25170,19 @@
#: ../vector/v.lrs/v.lrs.create/main.c:173
msgid "Column containing milepost position for the beginning of next segment"
-msgstr ""
-"Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes "
-"kennzeichnen."
+msgstr "Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
-msgstr ""
-"Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes "
-"zu kennzeichnen."
+msgid "Column containing offset from milepost for the beginning of next segment"
+msgstr "Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes zu kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:191
msgid "Column containing milepost position for the end of previous segment"
-msgstr ""
-"Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes "
-"kennzeichnen."
+msgstr "Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:200
msgid "Column containing offset from milepost for the end of previous segment"
-msgstr ""
-"Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes "
-"zu kennzeichnen."
+msgstr "Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes zu kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:223
msgid "Name of table where the reference system will be written"
@@ -27058,8 +25241,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:479
#, c-format
msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-"Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
+msgstr "Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
#: ../vector/v.lrs/v.lrs.create/main.c:501
#, c-format
@@ -27093,21 +25275,17 @@
#: ../vector/v.lrs/v.lrs.create/main.c:750
#, c-format
msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr ""
-"Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
+msgstr "Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
#: ../vector/v.lrs/v.lrs.create/main.c:764
#, c-format
msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-"Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die "
-"Linie."
+msgstr "Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die Linie."
#: ../vector/v.lrs/v.lrs.create/main.c:769
#, c-format
msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr ""
-"Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
+msgstr "Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
#: ../vector/v.lrs/v.lrs.create/main.c:773
#, c-format
@@ -27130,8 +25308,7 @@
#: ../vector/v.lrs/v.lrs.label/main.c:105
#, fuzzy
msgid "Creates stationing from input lines, and linear reference system."
-msgstr ""
-"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
+msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
#: ../vector/v.lrs/v.lrs.label/main.c:113
msgid "Output vector map where stationing will be written"
@@ -27191,9 +25368,7 @@
#: ../vector/v.out.ascii/args.c:30
#, fuzzy
msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
-"Schalter '-o' angegeben ist."
+msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
#: ../vector/v.out.ascii/args.c:32
#, fuzzy
@@ -27202,8 +25377,7 @@
#: ../vector/v.out.ascii/args.c:36
msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr ""
-"Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
+msgstr "Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
#: ../vector/v.out.ascii/args.c:37
msgid "\"*\" for all columns"
@@ -27237,9 +25411,7 @@
#: ../vector/v.out.ascii/args.c:88
msgid "Only export points falling within current 3D region (points mode)"
-msgstr ""
-"Exportiere nur Punkte, die sich in der aktuellen 3D-Region befinden (Punkt-"
-"Modus)."
+msgstr "Exportiere nur Punkte, die sich in der aktuellen 3D-Region befinden (Punkt-Modus)."
#: ../vector/v.out.ascii/args.c:103 ../vector/v.out.vtk/main.c:155
msgid "Failed to interpret 'dp' parameter as an integer"
@@ -27252,8 +25424,7 @@
#: ../vector/v.out.ascii/main.c:51
#, fuzzy
msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr ""
-"Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
#: ../vector/v.out.ascii/main.c:58
#, fuzzy
@@ -27270,12 +25441,8 @@
#: ../vector/v.out.ascii/main.c:78
#, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
-msgstr ""
-"Kann die Vektorkarte <%s> topologisch nicht öffnen. Flächen werden nicht "
-"verarbeitet."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
+msgstr "Kann die Vektorkarte <%s> topologisch nicht öffnen. Flächen werden nicht verarbeitet."
#: ../vector/v.out.ascii/main.c:105
#, fuzzy, c-format
@@ -27363,8 +25530,7 @@
#: ../vector/v.support/main.c:61
msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
-msgstr ""
-"Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
+msgstr "Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
#: ../vector/v.support/main.c:68
msgid "Person who created vector map"
@@ -27395,11 +25561,8 @@
msgstr "Text, der an den Kommentar Metadatendatei der Karte angehängt wird"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-"Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird "
-"(verwendet für Vektor-Skripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
+msgstr "Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird (verwendet für Vektor-Skripts)"
#: ../vector/v.support/main.c:122
msgid "Replace comment instead of appending it"
@@ -27421,12 +25584,8 @@
#: ../vector/v.outlier/main.c:76 ../vector/v.lidar.edgedetection/main.c:82
#: ../vector/v.lidar.correction/main.c:77 ../vector/v.surf.bspline/main.c:106
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
-msgstr ""
-"Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der "
-"aktuellen Region und beende mich."
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgstr "Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der aktuellen Region und beende mich."
#: ../vector/v.outlier/main.c:88
msgid "Name of output outlier vector map"
@@ -27473,9 +25632,7 @@
#: ../vector/v.surf.bspline/main.c:400 ../vector/v.lidar.growing/main.c:163
#, c-format
msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect "
-"benutzen"
+msgstr "Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect benutzen"
#: ../vector/v.outlier/main.c:170 ../vector/v.lidar.edgedetection/main.c:192
#: ../vector/v.lidar.edgedetection/main.c:204
@@ -27517,9 +25674,7 @@
#: ../vector/v.outlier/main.c:419 ../vector/v.lidar.edgedetection/main.c:456
#: ../vector/v.lidar.correction/main.c:425
msgid "No data within this subregion. Consider changing the spline step."
-msgstr ""
-"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
-"ändern."
+msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
#: ../vector/v.outlier/main.c:429 ../vector/v.lidar.edgedetection/main.c:466
#: ../vector/v.lidar.correction/main.c:436
@@ -27571,11 +25726,8 @@
#: ../vector/v.build/main.c:49
#, fuzzy
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
-msgstr ""
-"Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden "
-"sollen."
+msgid "Name for output vector map where erroneous vector features are written to"
+msgstr "Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden sollen."
#: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
#: ../db/db.execute/main.c:161
@@ -27586,9 +25738,7 @@
#: ../vector/v.build/main.c:61
#, fuzzy
msgid "Build topology or dump topology or indeces to standard output"
-msgstr ""
-"Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach "
-"stdout."
+msgstr "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach stdout."
#: ../vector/v.build/main.c:65
#, fuzzy
@@ -27624,9 +25774,7 @@
#: ../vector/v.build/main.c:106
#, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
msgstr ""
#: ../vector/v.build/main.c:111
@@ -27693,9 +25841,7 @@
#: ../vector/v.edit/args.c:68
#, fuzzy
msgid "Set new categories to selected vector features for defined layer"
-msgstr ""
-"Gebe anstelle der Attribute die minimale Ausdehnung der Region der "
-"selektierten Vektorfeatures aus."
+msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorfeatures aus."
#: ../vector/v.edit/args.c:70
msgid "Delete categories from selected vector features for defined layer"
@@ -27745,8 +25891,7 @@
#: ../vector/v.edit/args.c:99
#, fuzzy
msgid "Difference in x,y,z direction for moving feature or vertex"
-msgstr ""
-"Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
+msgstr "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
#: ../vector/v.edit/args.c:106
msgid "Threshold distance (coords,snap,query)"
@@ -27754,8 +25899,7 @@
#: ../vector/v.edit/args.c:108
msgid "'-1' for threshold based on the current resolution settings"
-msgstr ""
-"'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
+msgstr "'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
#: ../vector/v.edit/args.c:124
msgid "List of point coordinates"
@@ -27775,9 +25919,7 @@
#: ../vector/v.edit/args.c:154
msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr ""
-"Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte "
-"für 'Längere'."
+msgstr "Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte für 'Längere'."
#: ../vector/v.edit/args.c:160
#, fuzzy
@@ -27793,12 +25935,8 @@
msgstr "Name der Hintergrund-Vektorkarte(n)."
#: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
-msgstr ""
-"Snap hinzugefügte oder veränderte Features innerhalb des angegebenen "
-"Schwellwertes auf das nächste existierende Feature."
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgstr "Snap hinzugefügte oder veränderte Features innerhalb des angegebenen Schwellwertes auf das nächste existierende Feature."
#: ../vector/v.edit/args.c:182
msgid "Not apply snapping"
@@ -27827,8 +25965,7 @@
#: ../vector/v.edit/args.c:204
msgid "Close added boundaries (using threshold distance)"
-msgstr ""
-"SchlieÃe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
+msgstr "SchlieÃe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
#: ../vector/v.edit/args.c:208
msgid "Do not expect header of input data"
@@ -27871,12 +26008,8 @@
msgstr "Einstellungen"
#: ../vector/v.edit/main.c:58
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ãndern "
-"ausgewählter Vektor Feature."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ãndern ausgewählter Vektor Feature."
#: ../vector/v.edit/main.c:67
#, c-format
@@ -27890,21 +26023,13 @@
#: ../vector/v.edit/main.c:137
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' "
-"benötigt aber den topologischen Modus."
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
+msgstr "Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' benötigt aber den topologischen Modus."
#: ../vector/v.edit/main.c:157
#, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
-msgstr ""
-"Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu "
-"editierende Karte ausgewählte wurde."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr "Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu editierende Karte ausgewählte wurde."
#: ../vector/v.edit/main.c:168
#, c-format
@@ -27925,13 +26050,8 @@
#: ../vector/v.edit/main.c:231
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
-msgstr ""
-"Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-"
-"Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe "
-"von %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgstr "Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe von %s."
#: ../vector/v.edit/main.c:271
#, c-format
@@ -27997,12 +26117,8 @@
#: ../vector/v.edit/main.c:358
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
-msgstr ""
-"Mehrere Hintergrundkarten wurden angegeben. Selektierte Feature werden nur "
-"von der Vektorkarte <%s> kopiert."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgstr "Mehrere Hintergrundkarten wurden angegeben. Selektierte Feature werden nur von der Vektorkarte <%s> kopiert."
#: ../vector/v.edit/main.c:368
#, c-format
@@ -28075,8 +26191,7 @@
#: ../vector/v.in.dwg/main.c:102
msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-"Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
+msgstr "Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:145
msgid "Create 3D vector map"
@@ -28197,21 +26312,13 @@
#: ../vector/v.net.alloc/main.c:66
#, fuzzy
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
-msgstr ""
-"Knoten gehen im die Berechnung mit ein."
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
#: ../vector/v.net.alloc/main.c:111
#, fuzzy
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
-"wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegebn."
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegebn."
#: ../vector/v.net.alloc/main.c:189
#, fuzzy, c-format
@@ -28221,8 +26328,7 @@
#: ../vector/v.net.alloc/main.c:192
#, fuzzy
msgid "Not enough centers for selected nlayer. Nothing will be allocated."
-msgstr ""
#: ../vector/v.net.alloc/main.c:203
#, fuzzy
@@ -28256,7 +26362,8 @@
msgid "Use drand48() (ignored)"
msgstr "Verwende drand48()"
-#: ../vector/v.kcv/main.c:119
+#: ../vector/v.kcv/main.c:119 ../vector/v.category/main.c:181
+#: ../vector/v.category/main.c:243 ../vector/v.category/main.c:251
#, c-format
msgid "Unable to open vector map <%s> at topological level %d"
msgstr "Kann Vektorkarte <%s> auf der topologischen Ebene %d nicht öffnen"
@@ -28293,9 +26400,7 @@
#: ../vector/v.extract/extract.c:225
#, fuzzy
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
msgstr "Finde Zentroide der Layer: %s"
#: ../vector/v.extract/copy_tab.c:86
@@ -28324,12 +26429,8 @@
#: ../vector/v.extract/main.c:80
#, fuzzy
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
-msgstr ""
-"Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
-"neue Karte nur mit den selektierten Objekten."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
#: ../vector/v.extract/main.c:85
msgid "Dissolve common boundaries (default is no)"
@@ -28338,8 +26439,7 @@
#: ../vector/v.extract/main.c:89
#, fuzzy
msgid "Do not copy attributes (see also 'new' parameter)"
-msgstr ""
-"Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
#: ../vector/v.extract/main.c:105
msgid "Types to be extracted"
@@ -28347,9 +26447,7 @@
#: ../vector/v.extract/main.c:120
msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr ""
-"Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert "
-"werden sollen."
+msgstr "Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert werden sollen."
#: ../vector/v.extract/main.c:121
msgid "If '-' given reads from standard input"
@@ -28357,14 +26455,11 @@
#: ../vector/v.extract/main.c:129
msgid "Number of random categories matching vector objects to extract"
-msgstr ""
-"Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert "
-"werden."
+msgstr "Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert werden."
#: ../vector/v.extract/main.c:131
msgid "Number must be smaller than unique cat count in layer"
-msgstr ""
-"Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
+msgstr "Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
#: ../vector/v.extract/main.c:139
msgid "Desired new category value (enter -1 to keep original categories)"
@@ -28377,12 +26472,8 @@
#: ../vector/v.extract/main.c:158
#, fuzzy, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
-"one of them."
-msgstr ""
-"Die Optionen list, file, where und random schlieÃen sich gegenseitig aus. "
-"Bitte geben Sie nur eine von diesen an."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
+msgstr "Die Optionen list, file, where und random schlieÃen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
#: ../vector/v.extract/main.c:203
#, c-format
@@ -28420,12 +26511,8 @@
msgstr "%d Kategorien aus der Tabelle geladen."
#: ../vector/v.extract/main.c:279
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
-msgstr ""
-"Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um "
-"dieser Karte Kategorien zuzuordnen."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgstr "Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um dieser Karte Kategorien zuzuordnen."
#: ../vector/v.extract/main.c:286
msgid "Please specify random number larger than 0"
@@ -28433,26 +26520,16 @@
#: ../vector/v.extract/main.c:290
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
-msgstr ""
-"Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der "
-"Feature. Es gibt nur %d Feature des Typs: %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgstr "Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der Feature. Es gibt nur %d Feature des Typs: %s"
#: ../vector/v.extract/main.c:313
#, fuzzy, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count "
-"%d"
-msgstr ""
-"Die Zahl der zufälligen Kategorien ist gröÃer oder gleich der Zahl der "
-"eindeutigen \"%s\" Feature Kategorien %d."
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
+msgstr "Die Zahl der zufälligen Kategorien ist gröÃer oder gleich der Zahl der eindeutigen \"%s\" Feature Kategorien %d."
#: ../vector/v.extract/main.c:318
-msgid ""
-"There are more categories than random number generator can reach. Report "
-"this as a GRASS bug."
+msgid "There are more categories than random number generator can reach. Report this as a GRASS bug."
msgstr ""
#: ../vector/v.extract/main.c:349
@@ -28480,21 +26557,15 @@
#: ../vector/v.out.postgis/options.c:30
#, fuzzy
msgid "If not specified, input name is used"
-msgstr ""
-"Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
+msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
#: ../vector/v.out.postgis/options.c:37
#, fuzzy
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
-msgstr ""
-"Erzeugt eine neue Vektorkarte als einen ausschlieÃlich lesbaren Link zu "
-"einem OGR-Layer."
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
+msgstr "Erzeugt eine neue Vektorkarte als einen ausschlieÃlich lesbaren Link zu einem OGR-Layer."
#: ../vector/v.out.postgis/options.c:39
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
msgstr ""
#: ../vector/v.out.postgis/options.c:45
@@ -28576,16 +26647,12 @@
#: ../vector/v.out.postgis/table.c:50
#, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
msgstr ""
#: ../vector/v.out.postgis/table.c:57
#, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
msgstr ""
#: ../vector/v.db.connect/main.c:52 ../vector/v.distance/main.c:90
@@ -28650,15 +26717,12 @@
#: ../vector/v.db.connect/main.c:55
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
-"Attributtabelle."
+msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer Attributtabelle."
#: ../vector/v.db.connect/main.c:77
#, fuzzy
msgid "Format: layer number[/layer name]"
-msgstr ""
-"Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
+msgstr "Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
#: ../vector/v.db.connect/main.c:81
msgid "Field separator for shell script style output"
@@ -28671,19 +26735,15 @@
#: ../vector/v.db.connect/main.c:91
#, fuzzy
msgid "Print all map connection parameters in shell script style and exit"
-msgstr ""
-"Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
#: ../vector/v.db.connect/main.c:93
msgid "Format: layer[/layer name] table key database driver"
-msgstr ""
#: ../vector/v.db.connect/main.c:99
msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und "
-"beendet sich. "
+msgstr "Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und beendet sich. "
#: ../vector/v.db.connect/main.c:106
msgid "Overwrite connection parameter for certain layer"
@@ -28713,26 +26773,18 @@
#: ../vector/v.db.connect/main.c:195
#, fuzzy, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-"Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der "
-"Schlüsselspalte <%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr "Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der Schlüsselspalte <%s>\n"
#: ../vector/v.db.connect/main.c:201
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
#: ../vector/v.db.connect/main.c:264
#, c-format
msgid "Use -o to overwrite existing link for layer <%d>"
-msgstr ""
-"Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu "
-"überschreiben."
+msgstr "Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu überschreiben."
#: ../vector/v.db.connect/main.c:272 ../vector/v.db.connect/main.c:312
#, c-format
@@ -28751,12 +26803,8 @@
#: ../vector/v.db.connect/main.c:300 ../vector/v.db.connect/main.c:318
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS "
-"Modulen gelöscht und überschrieben werden."
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS Modulen gelöscht und überschrieben werden."
#: ../vector/v.db.connect/main.c:339
#, c-format
@@ -28768,18 +26816,13 @@
msgstr "Select-Privilegien wurden für die Tabelle gewährt."
#: ../vector/v.db.connect/main.c:349
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter "
-"angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
#: ../vector/v.in.ascii/main.c:52
#, fuzzy
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-"Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
+msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
#: ../vector/v.in.ascii/main.c:70
msgid "simple x,y[,z] list"
@@ -28800,21 +26843,15 @@
#: ../vector/v.in.ascii/main.c:87
msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden "
-"soll (Punktmodus)."
+msgstr "Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden soll (Punktmodus)."
#: ../vector/v.in.ascii/main.c:96
msgid "Column definition in SQL style (points mode)"
msgstr "Spaltendefinition im SQL-Stil (Punkt-Modus)."
#: ../vector/v.in.ascii/main.c:97
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
-msgstr ""
-"Zum Beispiel: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgstr "Zum Beispiel: 'x double precision, y double precision, cat int, name varchar(10)'"
#: ../vector/v.in.ascii/main.c:109 ../vector/v.in.ascii/main.c:119
msgid "First column is 1"
@@ -28830,26 +26867,19 @@
#: ../vector/v.in.ascii/main.c:129
msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-"Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
+msgstr "Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
#: ../vector/v.in.ascii/main.c:139
msgid "Number of column used as category (points mode)"
msgstr "Nummer der Spalte, die als Kategorie genutzt wird (Punkt-Modus)."
#: ../vector/v.in.ascii/main.c:141
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie "
-"zugeweisen und in die neue Spalte 'cat' geschrieben."
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie zugeweisen und in die neue Spalte 'cat' geschrieben."
#: ../vector/v.in.ascii/main.c:150
msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr ""
-"Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird "
-"eingelesen."
+msgstr "Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird eingelesen."
#: ../vector/v.in.ascii/main.c:155
msgid "Don't expect a header when reading in standard format"
@@ -28861,14 +26891,11 @@
#: ../vector/v.in.ascii/main.c:170
msgid "Only import points falling within current region (points mode)"
-msgstr ""
-"Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
+msgstr "Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
#: ../vector/v.in.ascii/main.c:184
msgid "Please specify reasonable number of lines to skip"
-msgstr ""
-"Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden "
-"sollen."
+msgstr "Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden sollen."
#: ../vector/v.in.ascii/main.c:187
msgid "Please specify z column"
@@ -28924,15 +26951,13 @@
"(falsches Trennzeichen?)"
#: ../vector/v.in.ascii/main.c:280
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"Z-Spaltennummer > letzte Spaltennummer\n"
#: ../vector/v.in.ascii/main.c:285
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
msgstr "cat-Spaltennummer > letzte Spaltennummer (falsches Trennzeichen?)"
#: ../vector/v.in.ascii/main.c:291
@@ -28957,66 +26982,51 @@
#: ../vector/v.in.ascii/main.c:426
#, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
-"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
-"Spalten (%d) in der Eingabe überein."
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
#: ../vector/v.in.ascii/main.c:454
#, c-format
msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
+msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
#: ../vector/v.in.ascii/main.c:459
#, c-format
msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
+msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
#: ../vector/v.in.ascii/main.c:467
#, c-format
msgid "Column number %d <%s> defined as integer has double values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
+msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
#: ../vector/v.in.ascii/main.c:472
#, c-format
msgid "Column number %d <%s> defined as string has double values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
+msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
#: ../vector/v.in.ascii/main.c:480
#, c-format
msgid "Column number %d <%s> defined as integer has string values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
+msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
#: ../vector/v.in.ascii/main.c:486
#, c-format
msgid "Column number %d <%s> defined as double has string values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
+msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
#: ../vector/v.in.ascii/main.c:492
#, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte "
-"(%d)."
+msgstr "Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte (%d)."
#: ../vector/v.in.ascii/main.c:532
msgid "Populating table..."
msgstr "Fülle Tabelle..."
#: ../vector/v.in.ascii/main.c:538
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
-msgstr ""
-"Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle "
-"Attribute akzeptiert."
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
+msgstr "Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle Attribute akzeptiert."
#: ../vector/v.in.ascii/points.c:83
msgid "Scanning input for column types..."
@@ -29170,9 +27180,7 @@
#: ../vector/v.colors/main.c:179
#, fuzzy, c-format
msgid "One of -%c, -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
-"Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder "
-"\"rules\" muss angegeben werden!"
+msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
#: ../vector/v.colors/main.c:193
#, fuzzy, c-format
@@ -29235,8 +27243,7 @@
#: ../vector/v.sample/main.c:89
#, fuzzy
msgid "Name of attribute column to use for comparison"
-msgstr ""
-"Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
#: ../vector/v.sample/main.c:92
#, fuzzy
@@ -29256,9 +27263,7 @@
#: ../vector/v.sample/main.c:114
#, fuzzy
msgid "Sampled values will be multiplied by this factor"
-msgstr ""
-"Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
-"diesem Faktor multipliziert."
+msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
#: ../vector/v.sample/main.c:140 ../vector/v.reclass/main.c:125
#: ../vector/v.surf.idw/read_sites.c:36
@@ -29269,8 +27274,7 @@
#: ../vector/v.sample/main.c:154
#, c-format
msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr ""
-"Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
+msgstr "Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
#: ../vector/v.sample/main.c:160 ../vector/v.normal/main.c:134
#: ../vector/v.surf.idw/read_sites.c:56
@@ -29289,12 +27293,8 @@
msgstr "Lese Eingaben..."
#: ../vector/v.distance/main.c:92
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
-"Vektorkarte 'from'. "
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der Vektorkarte 'from'. "
#: ../vector/v.distance/main.c:96
msgid "Name of existing vector map (from)"
@@ -29324,9 +27324,7 @@
#: ../vector/v.distance/main.c:131
msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-"Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen "
-"Elementen."
+msgstr "Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen Elementen."
#: ../vector/v.distance/main.c:139
msgid "Maximum distance or -1 for no limit"
@@ -29338,9 +27336,7 @@
#: ../vector/v.distance/main.c:155
msgid "Values describing the relation between two nearest features"
-msgstr ""
-"Werte, die die Verbindung zwischen zwei nächstgelegenen Featuren "
-"beschreiben. "
+msgstr "Werte, die die Verbindung zwischen zwei nächstgelegenen Featuren beschreiben. "
#: ../vector/v.distance/main.c:165
#, fuzzy
@@ -29363,14 +27359,11 @@
msgstr "Ost-Koordinate eines Punktes der Ebene."
#: ../vector/v.distance/main.c:169
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
msgstr ""
#: ../vector/v.distance/main.c:171
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
msgstr ""
#: ../vector/v.distance/main.c:174
@@ -29378,51 +27371,33 @@
msgstr ""
#: ../vector/v.distance/main.c:187
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr ""
-"Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte "
-"gespeichert werden."
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr "Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte gespeichert werden."
-#: ../vector/v.distance/main.c:188
-msgid "From_map"
-msgstr "From_map"
#: ../vector/v.distance/main.c:193
msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr ""
-"Spaltenname der nächstgelegenen Feature (verwendet mit upload=to_attr)."
+msgstr "Spaltenname der nächstgelegenen Feature (verwendet mit upload=to_attr)."
#: ../vector/v.distance/main.c:199
#, fuzzy
msgid "Name of table created when the 'distance to all' flag is used"
-msgstr ""
-"Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' "
-"gesetzt wurde."
+msgstr "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
#: ../vector/v.distance/main.c:204
msgid "Print output to stdout, don't update attribute table"
-msgstr ""
-"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
+msgstr "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
#: ../vector/v.distance/main.c:206
msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-"Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' "
-"benannt."
+msgstr "Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' benannt."
#: ../vector/v.distance/main.c:211
msgid "Calculate distances to all features within the threshold"
msgstr "Berechne Distanzen zu allen Features innerhalb des Schwellwertes."
#: ../vector/v.distance/main.c:213
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
-msgstr ""
-"Die Ausgabe wird nach stdout geschrieben und kann auch in eine neue Tabelle "
-"geschrieben werden, die von diesem Modul erzeugt wird. Es können mehrere "
-"'upload' Optionen verwendet werden."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
+msgstr "Die Ausgabe wird nach stdout geschrieben und kann auch in eine neue Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es können mehrere 'upload' Optionen verwendet werden."
#: ../vector/v.distance/main.c:268
msgid "to_column option missing"
@@ -29476,9 +27451,7 @@
#: ../vector/v.distance/main.c:1211
msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr ""
-"Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute "
-"geschrieben."
+msgstr "Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute geschrieben."
#: ../vector/v.distance/main.c:1229
msgid "Unable to open default database"
@@ -29522,8 +27495,7 @@
#: ../vector/v.distance/main.c:1582
#, c-format
msgid "%d categories read from the map exist in the table"
-msgstr ""
-"%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
+msgstr "%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
#: ../vector/v.distance/main.c:1585
#, c-format
@@ -29551,9 +27523,7 @@
#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
#, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db."
-"connect."
+msgstr "Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db.connect."
#: ../vector/v.to.db/query.c:93
msgid "Querying database... "
@@ -29561,19 +27531,13 @@
#: ../vector/v.to.db/query.c:108
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-"Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu "
-"viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten "
-"Werte für cat 0 sind nicht korrekt. "
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgstr "Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten Werte für cat 0 sind nicht korrekt. "
#: ../vector/v.to.db/query.c:145
#, c-format
msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr ""
-"Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
+msgstr "Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
#: ../vector/v.to.db/query.c:152
msgid "Unable to fetch record"
@@ -29615,8 +27579,7 @@
#: ../vector/v.to.db/parse.c:43
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
+msgstr "Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
#: ../vector/v.to.db/parse.c:54
msgid "Value to upload"
@@ -29672,15 +27635,11 @@
msgstr ""
#: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, 'qlayer' is "
-"used for area category"
+msgid "categories of areas on the left and right side of the boundary, 'qlayer' is used for area category"
msgstr ""
#: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'qlayer' option"
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'qlayer' option"
msgstr ""
#: ../vector/v.to.db/parse.c:88
@@ -29689,14 +27648,11 @@
msgstr "Ausgabekarte der Hangneigungsfaktoren (S) für USLE."
#: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
+msgid "line sinuousity, calculated as line length / distance between end points"
msgstr ""
#: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
msgstr ""
#: ../vector/v.to.db/parse.c:94
@@ -29733,8 +27689,7 @@
#: ../vector/v.to.db/parse.c:132
#, fuzzy
msgid "Print also totals for option length, area, or count"
-msgstr ""
-"Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
+msgstr "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
#: ../vector/v.to.db/parse.c:178
msgid "This option requires one column"
@@ -29782,16 +27737,12 @@
#: ../vector/v.to.db/report.c:201
#, c-format
msgid "%d categories read from vector map exist in selection from table"
-msgstr ""
-"%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der "
-"Tabelle."
+msgstr "%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der Tabelle."
#: ../vector/v.to.db/report.c:204
#, c-format
msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-"%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion "
-"der Tabelle."
+msgstr "%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion der Tabelle."
#: ../vector/v.to.db/report.c:206
#, c-format
@@ -29823,8 +27774,7 @@
#: ../vector/v.mkgrid/main.c:72
#, fuzzy
msgid "Creates a vector map of a user-defined grid."
-msgstr ""
-"Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
#: ../vector/v.mkgrid/main.c:79
#, fuzzy
@@ -29976,12 +27926,8 @@
msgstr "Lese Feature..."
#: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit "
-"Punkten oder Zentroiden."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
msgid "Use only points in current region"
@@ -29989,9 +27935,7 @@
#: ../vector/v.delaunay/main.c:103
msgid "Output triangulation as a graph (lines), not areas"
-msgstr ""
-"Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen "
-"aus."
+msgstr "Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen aus."
#: ../vector/v.delaunay/main.c:146
msgid "no points to triangulate"
@@ -30027,12 +27971,8 @@
#: ../vector/v.qcount/main.c:71
#, fuzzy
-msgid ""
-"Name for output quadrant centres map (number of points is written as "
-"category)"
-msgstr ""
-"Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
-"ausgegeben."
+msgid "Name for output quadrant centres map (number of points is written as category)"
+msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
#: ../vector/v.qcount/main.c:77
msgid "Number of quadrats"
@@ -30055,179 +27995,167 @@
msgid "Counting points quadrats..."
msgstr "Zähle Sites in den Quadraten..."
-#: ../vector/v.category/main.c:77
+#: ../vector/v.category/main.c:78
#, fuzzy
msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-"Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
-#: ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:90
msgid "Feature ids (by default all features are processed)"
msgstr "ID der Feature (standardmäÃig werden alle Feature bearbeitet)."
-#: ../vector/v.category/main.c:101
+#: ../vector/v.category/main.c:102
msgid "Action to be done"
msgstr "Aktion die ausgeführt werden soll."
-#: ../vector/v.category/main.c:111
+#: ../vector/v.category/main.c:113
#, fuzzy
msgid "add a new category"
msgstr "Linie %d hat keine Kategorie."
-#: ../vector/v.category/main.c:112
+#: ../vector/v.category/main.c:114
#, fuzzy
msgid "delete category (-1 to delete all categories of given layer)"
-msgstr ""
-#: ../vector/v.category/main.c:113
+#: ../vector/v.category/main.c:115
msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
msgstr ""
-#: ../vector/v.category/main.c:114
+#: ../vector/v.category/main.c:116
msgid "add the value specified by cat option to the current category value"
msgstr ""
-#: ../vector/v.category/main.c:115
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+#: ../vector/v.category/main.c:117
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
msgstr ""
-#: ../vector/v.category/main.c:116
+#: ../vector/v.category/main.c:118
#, fuzzy
msgid "print report (statistics), in shell style: layer type count min max"
msgstr "Format: Layer Typ Anzahl Min Max"
-#: ../vector/v.category/main.c:117
+#: ../vector/v.category/main.c:119
msgid "print category values, more cats in the same layer are separated by '/'"
msgstr ""
-#: ../vector/v.category/main.c:129
+#: ../vector/v.category/main.c:120
+#, fuzzy
+msgid "print only layer numbers"
+msgstr "Zeige keine Kategorienummern."
+#: ../vector/v.category/main.c:132
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
msgid "Category increment"
msgstr "Inkrement für die Kategorienummern"
-#: ../vector/v.category/main.c:133
+#: ../vector/v.category/main.c:136
msgid "Shell script style, currently only for report"
msgstr "Shell-Skript-Stil, zur Zeit nur für den Bericht."
-#: ../vector/v.category/main.c:134
+#: ../vector/v.category/main.c:137
msgid "Format: layer type count min max"
-#: ../vector/v.category/main.c:152
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
-msgstr ""
-"Die Datenbankverbindung und die Attributtabellen der betroffenen Layer "
-"werden nicht geändert."
+#: ../vector/v.category/main.c:155
+msgid "Database connection and attribute tables for concerned layers are not changed"
+msgstr "Die Datenbankverbindung und die Attributtabellen der betroffenen Layer werden nicht geändert."
-#: ../vector/v.category/main.c:173
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
-msgstr ""
-"Ungültige Kategorie (muss gröÃer oder gleich 0 sein). Normalerweise beginnen "
-"die Kategorien bei 1."
+#: ../vector/v.category/main.c:203
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgstr "Ungültige Kategorie (muss gröÃer oder gleich 0 sein). Normalerweise beginnen die Kategorien bei 1."
-#: ../vector/v.category/main.c:182
+#: ../vector/v.category/main.c:212
#, c-format
msgid "%d errors in id option"
msgstr "%d Fehler in id Option."
-#: ../vector/v.category/main.c:191
+#: ../vector/v.category/main.c:221
msgid "Output vector wasn't entered"
msgstr "Ausgabe-Vektorkarte wurde nicht eingegeben."
-#: ../vector/v.category/main.c:212 ../vector/v.category/main.c:220
-#, fuzzy, c-format
-msgid "Can not open vector <%s> on level %d"
-msgstr "Kann die Vektorkarte <%s> nicht öffnen."
-#: ../vector/v.category/main.c:237
+#: ../vector/v.category/main.c:268
msgid "Too many layers for this operation"
msgstr "Zu viele Layer für diese Operation."
-#: ../vector/v.category/main.c:240 ../vector/v.category/main.c:243
+#: ../vector/v.category/main.c:271 ../vector/v.category/main.c:274
msgid "2 layers must be specified"
msgstr "2 Layer müssen angegeben werden."
-#: ../vector/v.category/main.c:251
+#: ../vector/v.category/main.c:282
#, fuzzy, c-format
msgid "Categories already exist in layer %d"
msgstr "%d Kategorien gelesen von der Vektorkarte (Layer %d)."
-#: ../vector/v.category/main.c:294 ../vector/v.select/select.c:40
+#: ../vector/v.category/main.c:325 ../vector/v.select/select.c:40
msgid "Processing features..."
msgstr "Verarbeite Feature..."
-#: ../vector/v.category/main.c:340
+#: ../vector/v.category/main.c:371
#, c-format
msgid "%d new centroids placed in output map"
msgstr "[%d] neue Zentroide sind in die Ausgabekarte gesetzt worden."
-#: ../vector/v.category/main.c:629
+#: ../vector/v.category/main.c:660
msgid "Layer/table"
msgstr "Layer/Tabelle"
-#: ../vector/v.category/main.c:633
+#: ../vector/v.category/main.c:664
msgid "Layer"
msgstr "Layer"
-#: ../vector/v.category/main.c:635
+#: ../vector/v.category/main.c:666
#, c-format
msgid "type count min max\n"
msgstr "Typ Anzahl Min Max\n"
-#: ../vector/v.category/main.c:636
+#: ../vector/v.category/main.c:667
msgid "point"
msgstr "Punkt"
-#: ../vector/v.category/main.c:640
+#: ../vector/v.category/main.c:671
msgid "line"
msgstr "Linie"
-#: ../vector/v.category/main.c:644
+#: ../vector/v.category/main.c:675
msgid "boundary"
msgstr "Grenze"
-#: ../vector/v.category/main.c:648
+#: ../vector/v.category/main.c:679
#: ../locale/scriptstrings/v.centroids_to_translate.c:3
msgid "centroid"
msgstr "Zentroid"
-#: ../vector/v.category/main.c:652
+#: ../vector/v.category/main.c:683
#: ../locale/scriptstrings/v.centroids_to_translate.c:4
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
msgid "area"
msgstr "Fläche"
-#: ../vector/v.category/main.c:656
+#: ../vector/v.category/main.c:687
#, fuzzy
msgid "face"
msgstr "Oberfläche"
-#: ../vector/v.category/main.c:660
+#: ../vector/v.category/main.c:691
#, fuzzy
msgid "kernel"
msgstr "Allgemein"
-#: ../vector/v.category/main.c:664
+#: ../vector/v.category/main.c:695
msgid "all"
msgstr "Alle"
-#: ../vector/v.category/main.c:717 ../vector/v.rectify/main.c:283
+#: ../vector/v.category/main.c:748 ../vector/v.rectify/main.c:283
msgid "Copying attribute table(s)..."
msgstr "Kopiere Attributtabelle(n)..."
-#: ../vector/v.category/main.c:725
+#: ../vector/v.category/main.c:756
#, fuzzy, c-format
msgid "Categories copied from layer %d to layer %d"
-#: ../vector/v.category/main.c:727
+#: ../vector/v.category/main.c:758
#, c-format
msgid "%d features modified."
msgstr "%d Feature verändert."
@@ -30238,8 +28166,7 @@
#: ../vector/v.net.flow/main.c:62
msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-"Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
+msgstr "Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
#: ../vector/v.net.flow/main.c:84
msgid "Name for output vector map containing a minimum cut"
@@ -30251,8 +28178,7 @@
#: ../vector/v.net.flow/main.c:113
msgid "Source WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.flow/main.c:118
msgid "Sink category values"
@@ -30264,8 +28190,7 @@
#: ../vector/v.net.flow/main.c:124
msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.flow/main.c:198
#, c-format
@@ -30333,9 +28258,7 @@
#: ../vector/v.buffer/main.c:227
#, fuzzy
msgid "Creates a buffer around vector features of given type."
-msgstr ""
-"Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen "
-"Zentroide enthalten)."
+msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
#: ../vector/v.buffer/main.c:252
msgid "Buffer distance along major axis in map units"
@@ -30360,12 +28283,8 @@
msgstr "Skalierfaktor für die Werte der Attributspalte"
#: ../vector/v.buffer/main.c:291
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als "
-"Vielfaches des Buffers"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als Vielfaches des Buffers"
#: ../vector/v.buffer/main.c:296
msgid "Make outside corners straight"
@@ -30382,15 +28301,11 @@
#: ../vector/v.buffer/main.c:323
msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr ""
-"Wählen Sie entweder die Buffer distance/minordistance/angle oder eine "
-"Spalte, aber nicht beides"
+msgstr "Wählen Sie entweder die Buffer distance/minordistance/angle oder eine Spalte, aber nicht beides"
#: ../vector/v.buffer/main.c:338
#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
msgstr ""
#: ../vector/v.buffer/main.c:349
@@ -30427,17 +28342,11 @@
msgstr "Kann keine Daten der Tabelle <%s> selektieren"
#: ../vector/v.buffer/main.c:451
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
-msgstr ""
-"Keine Objekte zum Buffern vorhanden. Ãberprüfen Sie die Option type und die "
-"Objekte in der Eingabe-Vektorkarte."
+msgid "No features available for buffering. Check type option and features available in the input vector."
+msgstr "Keine Objekte zum Buffern vorhanden. Ãberprüfen Sie die Option type und die Objekte in der Eingabe-Vektorkarte."
#: ../vector/v.buffer/main.c:467
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
msgstr ""
#: ../vector/v.buffer/main.c:477
@@ -30507,20 +28416,11 @@
#: ../vector/v.surf.rst/main.c:146
#, fuzzy
msgid "Performs surface interpolation from vector points map by splines."
-msgstr ""
-"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
-"Squared Weighting."
+msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
#: ../vector/v.surf.rst/main.c:148
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Räumliche Approximation und topographische Analyse auf Basis gegebener "
-"Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
-"Splinefunktion mit Spannung. Das Ergebnis wird in eine FlieÃkomma-"
-"Rasterkarte geschrieben."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine FlieÃkomma-Rasterkarte geschrieben."
#: ../vector/v.surf.rst/main.c:155
msgid "Perform cross-validation procedure without raster approximation"
@@ -30533,14 +28433,10 @@
#: ../vector/v.surf.rst/main.c:179
#, fuzzy
msgid "Name of the attribute column with values to be used for approximation"
-msgstr ""
-"Name der Attributspalte mit Werten, die für die Approximation verwendet "
-"werden (wen der Layer >0)."
+msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
#: ../vector/v.surf.rst/main.c:180
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
msgstr ""
#: ../vector/v.surf.rst/main.c:190
@@ -30600,21 +28496,15 @@
#: ../vector/v.surf.rst/main.c:301 ../vector/v.vol.rst/main.c:339
msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-"Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
+msgstr "Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
#: ../vector/v.surf.rst/main.c:309
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen "
-"weiterer Punkte)."
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen weiterer Punkte)."
#: ../vector/v.surf.rst/main.c:318
msgid "Conversion factor for values used for approximation"
-msgstr ""
-"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
-"sollen."
+msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
#: ../vector/v.surf.rst/main.c:326
msgid "Anisotropy angle (in degrees counterclockwise from East)"
@@ -30628,30 +28518,19 @@
#: ../vector/v.surf.rst/main.c:417
msgid "You are not outputting any raster or vector maps"
-msgstr ""
-"Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
+msgstr "Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
#: ../vector/v.surf.rst/main.c:426
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) "
-"müssen angegeben werden."
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) müssen angegeben werden."
#: ../vector/v.surf.rst/main.c:429
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder "
-"der 'devi'-Datei berechnet werden."
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder der 'devi'-Datei berechnet werden."
#: ../vector/v.surf.rst/main.c:447
msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr ""
-"Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben "
-"werden."
+msgstr "Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben werden."
#: ../vector/v.surf.rst/main.c:455
msgid "Both smatt and smooth options specified - using constant"
@@ -30659,8 +28538,7 @@
#: ../vector/v.surf.rst/main.c:465
msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-"Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
+msgstr "Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
#: ../vector/v.surf.rst/main.c:483
msgid "Not enough memory for az"
@@ -30703,9 +28581,7 @@
msgstr "Kann tree-Information nicht erzeugen."
#: ../vector/v.surf.rst/main.c:542
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
msgstr ""
#: ../vector/v.surf.rst/main.c:544
@@ -30715,22 +28591,16 @@
#: ../vector/v.surf.rst/main.c:548
#, fuzzy
msgid "Input is 2D: using attribute values for approximation"
-msgstr ""
-"sollen."
#: ../vector/v.surf.rst/main.c:550
#, fuzzy
msgid "Input is 2D: using category values for approximation"
-msgstr ""
-"sollen."
#: ../vector/v.surf.rst/main.c:662
#, fuzzy, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for "
-"temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
msgstr ""
"Bearbeite alle ausgewählten Ausgabedateien.\n"
"Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
@@ -30747,16 +28617,11 @@
#: ../vector/v.surf.rst/main.c:706
#, fuzzy
msgid "Unable to write raster maps - try to increase resolution"
-msgstr ""
-"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
#: ../vector/v.transform/main.c:73
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Führt eine affine Transformation (schieben, skalieren und rotieren oder "
-"GPCs) von Vektorkarten durch."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
#: ../vector/v.transform/main.c:78
msgid "Shift all z values to bottom=0"
@@ -30822,9 +28687,7 @@
#: ../vector/v.transform/main.c:185
#, fuzzy, c-format
msgid "Columns require a valid layer. Please use '%s' parameter."
-msgstr ""
-"Der Name der Tabelle wurde nicht angegeben. Bitte verwenden Sie den "
-"Parameter '%s'."
+msgstr "Der Name der Tabelle wurde nicht angegeben. Bitte verwenden Sie den Parameter '%s'."
#: ../vector/v.transform/main.c:215
#, fuzzy, c-format
@@ -30870,13 +28733,8 @@
#: ../vector/v.transform/trans_digit.c:112
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
-msgstr ""
-"Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht "
-"selektieren. Verwende für die Kategorie %d den "
-"Standardtransformationsparameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgstr "Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht selektieren. Verwende für die Kategorie %d den Standardtransformationsparameter %.3f."
#: ../vector/v.transform/trans_digit.c:123
msgid "No category number defined. Using default transformation parameters."
@@ -30888,23 +28746,16 @@
msgstr "Attribute"
#: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Ãndert die Kategorien einer existierenden Vektorkarte entsprechend den "
-"Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Ãndert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
#: ../vector/v.reclass/main.c:88
msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-"Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
+msgstr "Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
#: ../vector/v.reclass/main.c:89
msgid "The source for the new key column must be type integer or string"
-msgstr ""
-"Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string "
-"sein."
+msgstr "Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string sein."
#: ../vector/v.reclass/main.c:94
msgid "Full path to the reclass rule file"
@@ -30995,14 +28846,8 @@
#: ../vector/v.neighbors/main.c:55
#, fuzzy
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
-msgstr ""
-"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
-"Kategoriewerte basierend auf einer FenstergröÃe zu und erstellt neue "
-"Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer FenstergröÃe zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
#: ../vector/v.neighbors/main.c:77
#, fuzzy
@@ -31234,32 +29079,20 @@
#: ../vector/v.external/list.c:291
#, fuzzy, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
-msgstr ""
-"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
-"kann daher keine neue Location erstellen."
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
+msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
#: ../vector/v.external/main.c:54
#, fuzzy
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
-msgstr ""
-"einem OGR-Layer."
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
#: ../vector/v.external/main.c:73 ../vector/v.external.out/link.c:46
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
msgstr ""
#: ../vector/v.external/main.c:78 ../vector/v.external.out/link.c:53
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
msgstr ""
#: ../vector/v.external/main.c:157
@@ -31460,9 +29293,7 @@
#: ../vector/v.lidar.edgedetection/main.c:259
#, c-format
msgid "It was impossible to create <%s> interpolation table in database."
-msgstr ""
-"Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu "
-"erstellen."
+msgstr "Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu erstellen."
#: ../vector/v.lidar.edgedetection/main.c:392
msgid "Allocating memory for bilinear interpolation"
@@ -31492,11 +29323,8 @@
#: ../vector/v.out.ogr/args.c:17
#, fuzzy
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
-msgstr ""
-"Die Die Kombination von Typen wird nicht von allen Formaten unterstützt."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
+msgstr "Die Die Kombination von Typen wird nicht von allen Formaten unterstützt."
#: ../vector/v.out.ogr/args.c:28
msgid "OGR output datasource name"
@@ -31504,13 +29332,11 @@
#: ../vector/v.out.ogr/args.c:30
msgid "For example: ESRI Shapefile: filename or directory for storage"
-msgstr ""
-"Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
+msgstr "Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
#: ../vector/v.out.ogr/args.c:37
msgid "OGR layer name. If not specified, input name is used."
-msgstr ""
#: ../vector/v.out.ogr/args.c:39
msgid "For example: ESRI Shapefile: shapefile name"
@@ -31523,8 +29349,7 @@
#: ../vector/v.out.ogr/args.c:58
msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
-"Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
+msgstr "Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
#: ../vector/v.out.ogr/args.c:68
msgid "OGR layer creation option (format specific, NAME=VALUE)"
@@ -31544,22 +29369,16 @@
#: ../vector/v.out.ogr/args.c:88
#, fuzzy
-msgid ""
-"Also export features without category (not labeled). Otherwise only features "
-"with category are exported."
-msgstr ""
-"Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden "
-"alle Objekte exportiert."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
+msgstr "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
#: ../vector/v.out.ogr/args.c:94
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
+msgstr "Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
#: ../vector/v.out.ogr/args.c:100
msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
-"Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
+msgstr "Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
#: ../vector/v.out.ogr/args.c:106
msgid "Export lines as polygons"
@@ -31567,12 +29386,8 @@
#: ../vector/v.out.ogr/args.c:112
#, fuzzy
-msgid ""
-"Create a new empty OGR layer in defined OGR datasource and exit. Nothing is "
-"read from input."
-msgstr ""
-"eingelesen."
+msgid "Create a new empty OGR layer in defined OGR datasource and exit. Nothing is read from input."
#: ../vector/v.out.ogr/create.c:20
#, fuzzy, c-format
@@ -31600,9 +29415,7 @@
#: ../vector/v.out.ogr/main.c:97 ../vector/v.external.out/link.c:26
#, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
-"\" given)"
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
msgstr ""
#: ../vector/v.out.ogr/main.c:162
@@ -31616,8 +29429,7 @@
#: ../vector/v.out.ogr/main.c:228
msgid "The combination of types is not supported by all formats."
-msgstr ""
#: ../vector/v.out.ogr/main.c:257
#, c-format
@@ -31625,135 +29437,83 @@
msgstr ""
#: ../vector/v.out.ogr/main.c:272
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
msgstr ""
#: ../vector/v.out.ogr/main.c:278
#, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
-"Ãberprüfen Sie bitte den 'type'-Parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:283
#, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:289
#, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:295
#, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:300
#, fuzzy, c-format
-msgid ""
-"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:304
#, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:309
#, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:315
#, fuzzy
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d Punkt(e) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No points found, but requested to be exported. Will skip this feature type."
+msgstr "%d Punkt(e) gefunden, die allerdings nicht exportiert werden sollen. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:324
#, fuzzy
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d Linie(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No lines found, but requested to be exported. Will skip this feature type."
+msgstr "%d Linie(n) gefunden, die allerdings nicht exportiert werden sollen. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:334
#, fuzzy
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"%d Grenzlinie(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
+msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht exportiert werden sollen. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:343
#, fuzzy
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No areas found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:353
#, fuzzy
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"%d Zentroid(e) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
+msgstr "%d Zentroid(e) gefunden, die allerdings nicht exportiert werden sollen. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:362
#, fuzzy
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No faces found, but requested to be exported. Will skip this feature type."
+msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Ãberprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:371
#, fuzzy
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:380
#, fuzzy
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:391
msgid "Nothing to export"
@@ -31766,9 +29526,7 @@
#: ../vector/v.out.ogr/main.c:415
#, c-format
-msgid ""
-"Append existing layer requires opening data source in update mode, forcing '-"
-"%c' flag"
+msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
msgstr ""
#: ../vector/v.out.ogr/main.c:433
@@ -31797,33 +29555,18 @@
#: ../vector/v.out.ogr/main.c:500
#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-"Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
-"Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) "
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
#: ../vector/v.out.ogr/main.c:512
#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
#: ../vector/v.out.ogr/main.c:519
#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)."
#: ../vector/v.out.ogr/main.c:536 ../db/drivers/ogr/execute.c:56
#, fuzzy, c-format
@@ -31836,9 +29579,7 @@
#: ../vector/v.out.ogr/main.c:550
msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"Keine Attributtabelle gefunden -> benutze nur Kategorienummern als "
-"Attributes."
+msgstr "Keine Attributtabelle gefunden -> benutze nur Kategorienummern als Attributes."
#: ../vector/v.out.ogr/main.c:554
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -31911,9 +29652,7 @@
#: ../vector/v.out.ogr/attrb.c:65
#, c-format
msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr ""
-"Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde "
-"deaktiviert."
+msgstr "Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde deaktiviert."
#: ../vector/v.patch/main.c:70
#, fuzzy
@@ -31921,19 +29660,12 @@
msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
#: ../vector/v.patch/main.c:81
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
-msgstr ""
-"Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten "
-"geschrieben werden"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgstr "Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten geschrieben werden"
#: ../vector/v.patch/main.c:85
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-"Hänge Dateien an eine existierende Datei an. Das Ãberschreiben von "
-"existierenden Dateien muss aktiviert sein"
+msgid "Append files to existing file (overwriting existing files must be activated)"
+msgstr "Hänge Dateien an eine existierende Datei an. Das Ãberschreiben von existierenden Dateien muss aktiviert sein"
#: ../vector/v.patch/main.c:90
msgid "Copy also attribute table"
@@ -31983,9 +29715,7 @@
#: ../vector/v.patch/main.c:326
#, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt "
-"sein"
+msgstr "Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt sein"
#: ../vector/v.patch/main.c:369
#, c-format
@@ -32058,9 +29788,7 @@
msgstr "Verschiebewert für Z-Koordinate."
#: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
msgstr ""
#: ../vector/v.out.pov/main.c:82
@@ -32098,14 +29826,8 @@
msgstr "Operator bestimmt das erforderte Verhältnis zwischen den Features"
#: ../vector/v.select/args.c:49
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"Ein Feature wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation "
-"'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als wahr "
-"aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgstr "Ein Feature wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als wahr aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
#: ../vector/v.select/args.c:57 ../vector/v.select/args.c:73
#, fuzzy
@@ -32145,9 +29867,7 @@
msgstr ""
#: ../vector/v.select/args.c:82
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
msgstr ""
#: ../vector/v.select/args.c:92
@@ -32169,11 +29889,8 @@
msgstr "Kann die Tabelle <%s> nicht kopieren."
#: ../vector/v.select/main.c:51
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Selektiert Feature der Vektorkarte (A) durch Feature von eine anderen "
-"Vektorkarte (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Selektiert Feature der Vektorkarte (A) durch Feature von eine anderen Vektorkarte (B)."
#: ../vector/v.select/main.c:93
msgid "Operator can only be 'overlap'"
@@ -32209,8 +29926,7 @@
#: ../vector/v.convert/att.c:37
msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
+msgstr "Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
#: ../vector/v.convert/att.c:42
msgid "Unable to open dig_cats file"
@@ -32240,9 +29956,7 @@
#: ../vector/v.convert/old2new.c:88
#, c-format
msgid "Failed to attach an attribute (category %d) to a line."
-msgstr ""
-"Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist "
-"fehlgeschlagen."
+msgstr "Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist fehlgeschlagen."
#: ../vector/v.convert/old2new.c:93
#, c-format
@@ -32280,13 +29994,8 @@
msgstr "Eingabedatei ist portabel."
#: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; "
-"dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere "
-"Informationen."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere Informationen."
#: ../vector/v.convert/read.c:185
#, c-format
@@ -32311,8 +30020,7 @@
#: ../vector/v.convert/read.c:192
#, c-format
msgid "[%d] area boundaries read and written to output"
-msgstr ""
-"[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
+msgstr "[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
#: ../vector/v.convert/read.c:193
#, c-format
@@ -32414,16 +30122,13 @@
#: ../vector/v.what.rast3/main.c:71
#, fuzzy
msgid "Uploads 3d raster values at positions of vector points to the table."
-msgstr ""
-"Ãbernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
-"Attributtabelle."
+msgstr "Ãbernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
#: ../vector/v.what.rast3/main.c:75 ../vector/v.what.rast/main.c:80
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
#, fuzzy
msgid "Name of vector points map for which to edit attributes"
-msgstr ""
-"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
#: ../vector/v.what.rast3/main.c:81
#, fuzzy
@@ -32522,15 +30227,11 @@
#: ../vector/v.in.sites/main.c:100
msgid "Floating point category values, using sequential integer for category"
-msgstr ""
-"FlieÃkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die "
-"Kategorien."
+msgstr "FlieÃkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
#: ../vector/v.in.sites/main.c:103
msgid "No category values, using sequential integer for category"
-msgstr ""
-"Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die "
-"Kategorien."
+msgstr "Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
#: ../vector/v.in.sites/main.c:185
msgid "Transferring sites to vector point map..."
@@ -32553,19 +30254,15 @@
#: ../vector/v.clean/prune.c:215
#, fuzzy, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
msgstr ""
"\n"
-"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z."
-"B. %.2f %%"
+"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
#: ../vector/v.clean/prune.c:219
#, c-format
msgid "%d boundaries not pruned because pruning would damage topology"
-msgstr ""
-"%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt "
-"hätte."
+msgstr "%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt hätte."
#: ../vector/v.clean/main.c:52
msgid "Toolset for cleaning topology of vector map."
@@ -32593,9 +30290,7 @@
msgstr ""
#: ../vector/v.clean/main.c:97
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
msgstr ""
#: ../vector/v.clean/main.c:99
@@ -32603,9 +30298,7 @@
msgstr ""
#: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
msgstr ""
#: ../vector/v.clean/main.c:102
@@ -32619,17 +30312,11 @@
msgstr "Entferne doppelte Zentroide"
#: ../vector/v.clean/main.c:104
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
msgstr ""
#: ../vector/v.clean/main.c:107
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachement of "
-"centroid), first and last segment of the boundary is never changed"
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed"
msgstr ""
#: ../vector/v.clean/main.c:111
@@ -32649,9 +30336,7 @@
#: ../vector/v.clean/main.c:121
#, fuzzy
msgid "Threshold in map units, one value for each tool"
-msgstr ""
-"Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: "
-"0.0[,0.0,...])."
+msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
#: ../vector/v.clean/main.c:122
msgid "Default: 0.0[,0.0,...])"
@@ -32905,14 +30590,8 @@
#: ../vector/v.perturb/main.c:88
#, fuzzy
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
-msgstr ""
-"Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
-"nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
-"zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
#: ../vector/v.perturb/main.c:98
msgid "Minimum deviation in map units"
@@ -32965,7 +30644,7 @@
#: ../vector/v.vect.stats/main.c:156
#, fuzzy
msgid "Layer number for area map"
-msgstr "Layer-Nummer (from)."
+msgstr "Layer-Nummer (Vektorkarte A)"
#: ../vector/v.vect.stats/main.c:172
#, fuzzy
@@ -32988,9 +30667,7 @@
msgstr "Spaltennamen oder Ausdruck"
#: ../vector/v.vect.stats/main.c:189
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:196
@@ -32999,30 +30676,23 @@
#: ../vector/v.vect.stats/main.c:198
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:205
#, fuzzy
msgid "Print output to stdout, do not update attribute table"
-msgstr ""
#: ../vector/v.vect.stats/main.c:206
#, fuzzy
msgid "First column is always area category"
-msgstr ""
-"benannt."
#: ../vector/v.vect.stats/main.c:260
#, c-format
msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht "
-"aktualisiert werden."
+msgstr "Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht aktualisiert werden."
#: ../vector/v.vect.stats/main.c:307 ../vector/v.vect.stats/main.c:383
#, fuzzy, c-format
@@ -33072,7 +30742,7 @@
#: ../vector/v.vect.stats/main.c:576
#, fuzzy, c-format
msgid "could not find area category %d"
-msgstr "Kein Punkte mit Kategorie [%d]."
+msgstr "Kein Eintrag für Kategorie [%d]."
#: ../vector/v.vect.stats/main.c:704
#, c-format
@@ -33097,14 +30767,8 @@
msgstr "Kann Daten der Tabelle nicht selektieren."
#: ../vector/v.class/main.c:171
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
-msgstr ""
-"Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen "
-"nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, "
-"die Anzahl der Klassen zu reduzieren."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgstr "Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, die Anzahl der Klassen zu reduzieren."
#: ../vector/v.class/main.c:200
#, c-format
@@ -33181,11 +30845,8 @@
#: ../vector/v.info/parse.c:30
#, fuzzy
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
-"Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+msgid "Print types/names of table columns for specified layer instead of info and exit"
+msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
#: ../vector/v.info/parse.c:35
#, fuzzy
@@ -33205,9 +30866,7 @@
#: ../vector/v.info/print.c:130
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-"
-"Datei."
+msgstr "Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-Datei."
#: ../vector/v.info/print.c:134
#, fuzzy, c-format
@@ -33447,17 +31106,12 @@
msgstr "Typ der Komponenten"
#: ../vector/v.lidar.correction/main.c:71
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
-msgstr ""
-"Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen "
-"um LIDAR zu filtern."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen um LIDAR zu filtern."
#: ../vector/v.lidar.correction/main.c:81
msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr ""
-"Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
+msgstr "Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
#: ../vector/v.lidar.correction/main.c:84
msgid "Output classified vector map name"
@@ -33524,9 +31178,7 @@
#: ../vector/v.to.3d/args.c:32
msgid "Can be used for reverse transformation, to store height of points"
-msgstr ""
-"Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der "
-"Punkte zu speichern. "
+msgstr "Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der Punkte zu speichern. "
#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
msgid "Height"
@@ -33618,11 +31270,8 @@
msgstr "NULL-Wert-Indikator"
#: ../vector/v.db.select/main.c:91
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
-msgstr ""
-"Gebe anstelle der Attribute die minimale Ausdehnung der Region der "
-"selektierten Vektorfeatures aus."
+msgid "Print minimal region extent of selected vector features instead of attributes"
+msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorfeatures aus."
#: ../vector/v.db.select/main.c:92
#, fuzzy
@@ -33639,12 +31288,8 @@
#: ../vector/v.db.select/main.c:137
#, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' "
-"benötigt aber den topologischen Modus."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr "Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' benötigt aber den topologischen Modus."
#: ../vector/v.db.select/main.c:171
msgid "Unable to open select cursor"
@@ -33703,8 +31348,7 @@
#: ../vector/v.in.dxf/main.c:91
#, fuzzy
msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr ""
-"Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
+msgstr "Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
#: ../vector/v.in.dxf/main.c:96
msgid "Import all objects into one layer"
@@ -33822,15 +31466,12 @@
#, fuzzy, c-format
msgid "Unable to make line segment: %f - %f (line length = %f)"
msgstr ""
-"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = "
-"%.15g)\n"
+"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = %.15g)\n"
"%s"
#: ../vector/v.what.rast/main.c:76
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Attributtabelle."
#: ../vector/v.what.rast/main.c:86
msgid "Name of existing raster map to be queried"
@@ -33842,9 +31483,7 @@
#: ../vector/v.what.rast/main.c:151
msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Rastertyp ist FlieÃkomma und der Spaltentyp ist Integer. Etwas "
-"Informationsgehalt der Daten geht verloren!!"
+msgstr "Rastertyp ist FlieÃkomma und der Spaltentyp ist Integer. Etwas Informationsgehalt der Daten geht verloren!!"
#: ../vector/v.net.salesman/main.c:128
msgid "salesman"
@@ -33852,17 +31491,11 @@
#: ../vector/v.net.salesman/main.c:130
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-"
-"Problem)."
+msgstr "Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-Problem)."
#: ../vector/v.net.salesman/main.c:132
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
-msgstr ""
-"Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt "
-"ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr "Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
#: ../vector/v.net.salesman/main.c:150
msgid "Node layer (used for cities)"
@@ -33876,15 +31509,11 @@
#: ../vector/v.net.salesman/main.c:169
#, fuzzy
msgid "Name for output file holding node sequence (\"-\" for stdout)"
-msgstr ""
-"Name der Ausgabekarte (wenn keiner oder \"-\" angegeben wurdeerfolgt die "
-"Ausgabe nach stdout)."
+msgstr "Name der Ausgabekarte (wenn keiner oder \"-\" angegeben wurdeerfolgt die Ausgabe nach stdout)."
#: ../vector/v.net.salesman/main.c:174
msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-"Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer "
-"bestimmt)."
+msgstr "Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer bestimmt)."
#: ../vector/v.net.salesman/main.c:248
#, c-format
@@ -33932,9 +31561,7 @@
#: ../vector/v.to.points/main.c:184
#, fuzzy
msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr ""
-"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
-"Layern."
+msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
#: ../vector/v.to.points/main.c:187
#, fuzzy
@@ -34056,8 +31683,7 @@
"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
"%s"
msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der "
-"Linie = %.15g)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der Linie = %.15g)\n"
"%s"
#: ../vector/v.segment/main.c:189
@@ -34070,8 +31696,7 @@
"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
"%s"
msgstr ""
-"%.15g)\n"
"%s"
#: ../vector/v.segment/main.c:224
@@ -34263,9 +31888,7 @@
#: ../vector/v.what/main.c:158
#, fuzzy, c-format
msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr ""
-"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
-"Spalten (%d) in der Eingabe überein."
+msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
#: ../vector/v.what/main.c:167
#, c-format
@@ -34408,20 +32031,15 @@
#: ../vector/v.generalize/main.c:156
msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr ""
-"Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
+msgstr "Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
#: ../vector/v.generalize/main.c:165
msgid "Slide of computed point toward the original point"
-msgstr ""
-"Verschieben von berechneten Punkten in Richtung seiner ursprünglichen "
-"Position."
+msgstr "Verschieben von berechneten Punkten in Richtung seiner ursprünglichen Position."
#: ../vector/v.generalize/main.c:174
msgid "Minimum angle between two consecutive segments in Hermite method"
-msgstr ""
-"Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-"
-"Methode."
+msgstr "Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-Methode."
#: ../vector/v.generalize/main.c:182
msgid "Degree threshold in network generalization"
@@ -34429,8 +32047,7 @@
#: ../vector/v.generalize/main.c:191
msgid "Closeness threshold in network generalization"
-msgstr ""
-"Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
+msgstr "Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
#: ../vector/v.generalize/main.c:199
msgid "Betweeness threshold in network generalization"
@@ -34486,17 +32103,13 @@
#: ../vector/v.generalize/main.c:526
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
-msgstr ""
-"%d Grenzen wurden nicht geändert, weil Ãnderungen die Topologie beschädigen "
-"würden."
+msgid "%d boundaries were not modified because modification would damage topology"
+msgstr "%d Grenzen wurden nicht geändert, weil Ãnderungen die Topologie beschädigen würden."
#: ../vector/v.generalize/main.c:529
#, c-format
msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr ""
-"%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
+msgstr "%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
#: ../vector/v.generalize/main.c:544
#, fuzzy, c-format
@@ -34516,12 +32129,8 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:244
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpoliert Punkte zu einer 3D Rasterkarte unter Verwendung des regularized "
-"spline with tension (RST) Algorithmus."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "Interpoliert Punkte zu einer 3D Rasterkarte unter Verwendung des regularized spline with tension (RST) Algorithmus."
#: ../vector/v.vol.rst/main.c:249
#, fuzzy
@@ -34643,9 +32252,7 @@
#: ../vector/v.vol.rst/main.c:747 ../vector/v.vol.rst/main.c:765
#, fuzzy
msgid "Not enough disk space - cannot write temp files"
-msgstr ""
-"Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
-"schreiben."
+msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
#: ../vector/v.vol.rst/main.c:646 ../vector/v.vol.rst/main.c:664
#: ../vector/v.vol.rst/main.c:682 ../vector/v.vol.rst/main.c:700
@@ -34670,21 +32277,16 @@
#: ../vector/v.vol.rst/user1.c:109
msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr ""
-"Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
+msgstr "Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
#: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
-msgstr ""
-"Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder "
-"double sein)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
+msgstr "Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder double sein)"
#: ../vector/v.to.rast3/main.c:51
#, fuzzy
msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-"Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
+msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
#: ../vector/v.to.rast3/main.c:62
#, fuzzy
@@ -34762,11 +32364,8 @@
msgstr "Rand-Breite (nur für die Ausgabe von ps.map)."
#: ../vector/v.in.db/main.c:58
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
-"Koordinaten beinhaltet."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die Koordinaten beinhaltet."
#: ../vector/v.in.db/main.c:62
msgid "Input table name"
@@ -34809,11 +32408,8 @@
#: ../vector/v.in.db/main.c:141
#, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-"Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert "
-"bereits."
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr "Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert bereits."
#: ../vector/v.in.db/main.c:191
msgid "Key column must be integer"
@@ -34833,12 +32429,8 @@
msgstr "%d Punkte in die Vektorkarte geschrieben."
#: ../vector/v.surf.idw/main.c:90
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
#: ../vector/v.surf.idw/main.c:99
#, fuzzy
@@ -34854,19 +32446,13 @@
msgstr "Indiziere die Punkte nicht mittels der Rasterzellen."
#: ../vector/v.surf.idw/main.c:116
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Langsamer, aber braucht weniger Speicher und integriert auch Punkte "
-"auÃerhalb der Region in die Interpolation."
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Langsamer, aber braucht weniger Speicher und integriert auch Punkte auÃerhalb der Region in die Interpolation."
#: ../vector/v.surf.idw/main.c:123 ../vector/v.surf.bspline/main.c:110
#, fuzzy
msgid "Use z coordinates for approximation (3D vector maps only)"
-msgstr ""
-"sollen."
#: ../vector/v.surf.idw/main.c:131
#, fuzzy
@@ -34909,9 +32495,7 @@
#: ../vector/v.hull/main.c:75
msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr ""
-"Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten "
-"besteht."
+msgstr "Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten besteht."
#: ../vector/v.hull/main.c:100
#, c-format
@@ -34970,9 +32554,7 @@
#: ../vector/v.drape/main.c:147
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
-"Höheninformationen."
+msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
#: ../vector/v.drape/main.c:158
msgid "Elevation raster map for height extraction"
@@ -35006,9 +32588,7 @@
#: ../vector/v.drape/main.c:191
msgid "Will set Z to this value, if value from raster map can not be read"
-msgstr ""
-"Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen "
-"werden kann."
+msgstr "Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen werden kann."
#: ../vector/v.drape/main.c:267
msgid "No features match Your query"
@@ -35016,17 +32596,12 @@
#: ../vector/v.drape/main.c:368 ../vector/v.drape/main.c:378
msgid "Due to error attribute data to new map are not transferred"
-msgstr ""
-"Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte "
-"übetragen."
+msgstr "Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte übetragen."
#: ../vector/v.drape/main.c:389
#, fuzzy
-msgid ""
-"No features drapped. Check your computational region and input vector map."
-msgstr ""
-"Keine Feature wurden drapiert. Ãberprüfen Sie die aktuelle Region und die "
-"Eingabe-Rasterkarte."
+msgid "No features drapped. Check your computational region and input vector map."
+msgstr "Keine Feature wurden drapiert. Ãberprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
#: ../vector/v.net.path/path.c:82
#, c-format
@@ -35041,9 +32616,7 @@
#: ../vector/v.net.path/path.c:209
#, c-format
msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der "
-"Kategorie [%d]."
+msgstr "Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der Kategorie [%d]."
#: ../vector/v.net.path/path.c:266
#, c-format
@@ -35063,50 +32636,32 @@
#: ../vector/v.net.path/path.c:335
#, c-format
msgid "%d destination(s) unreachable (including points out of threshold)"
-msgstr ""
-"%d Ziele sind unerreichbar (inklusive der Punkte auÃerhalb des "
-"Schwellwertes)."
+msgstr "%d Ziele sind unerreichbar (inklusive der Punkte auÃerhalb des Schwellwertes)."
#: ../vector/v.net.path/main.c:43
msgid "Finds shortest path on vector network."
msgstr "Findet den kürzesten Weg in einem Vektor-Netzwerk."
#: ../vector/v.net.path/main.c:66
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von "
-"stdin gelesen."
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von stdin gelesen."
#: ../vector/v.net.path/main.c:93
msgid "Maximum distance to the network"
msgstr "Maximale Distanz zum Netzwerk."
#: ../vector/v.net.path/main.c:94
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
-msgstr ""
-"Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/"
-"Endpunkt auÃerhalb des Schwellwertes sind, wird der kürzeste Weg nicht "
-"gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu "
-"beschleunigen, wählen Sie den Wert so gering wie möglich."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgstr "Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/Endpunkt auÃerhalb des Schwellwertes sind, wird der kürzeste Weg nicht gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu beschleunigen, wählen Sie den Wert so gering wie möglich."
#: ../vector/v.net.path/main.c:107
msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-"Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden "
-"Weg als eine Linie."
+msgstr "Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden Weg als eine Linie."
#: ../vector/v.rectify/main.c:73
#, fuzzy
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-"Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel "
-"des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgstr "Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
#: ../vector/v.rectify/main.c:88
#, fuzzy
@@ -35116,9 +32671,7 @@
#: ../vector/v.rectify/main.c:93
#, fuzzy
msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
-msgstr ""
#: ../vector/v.rectify/main.c:105
#, fuzzy
@@ -35190,8 +32743,7 @@
#: ../vector/v.timestamp/main.c:39
#, fuzzy
msgid "Print/add/remove a timestamp for a vector map."
-msgstr ""
-"Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
+msgstr "Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
#: ../vector/v.timestamp/main.c:65
#, fuzzy, c-format
@@ -35205,8 +32757,7 @@
#: ../vector/v.net.connectivity/main.c:57
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr "Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
#: ../vector/v.net.connectivity/main.c:97
msgid "Set1 category values"
@@ -35219,8 +32770,7 @@
#: ../vector/v.net.connectivity/main.c:103
msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.connectivity/main.c:108
msgid "Set2 category values"
@@ -35233,8 +32783,7 @@
#: ../vector/v.net.connectivity/main.c:114
msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.connectivity/main.c:148
#: ../vector/v.net.connectivity/main.c:155
@@ -35274,14 +32823,11 @@
#: ../vector/v.surf.bspline/main.c:192
#, fuzzy
msgid "Maximum memory to be used for raster output (in MB)"
-msgstr ""
-"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
#: ../vector/v.surf.bspline/main.c:204
msgid "Choose either vector or raster output, not both"
-msgstr ""
-"Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht "
-"beides."
+msgstr "Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht beides."
#: ../vector/v.surf.bspline/main.c:207
msgid "No raster or vector or cross-validation output"
@@ -35339,12 +32885,8 @@
#: ../vector/v.surf.bspline/main.c:324
#, fuzzy, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
-msgstr ""
-"Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
-"erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
+msgstr "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
#: ../vector/v.surf.bspline/main.c:347
#, c-format
@@ -35369,9 +32911,7 @@
#: ../vector/v.surf.bspline/main.c:407
#, c-format
msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr ""
-"Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu "
-"erstellen."
+msgstr "Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu erstellen."
#: ../vector/v.surf.bspline/main.c:475
#, fuzzy
@@ -35405,9 +32945,7 @@
#: ../vector/v.surf.bspline/main.c:871
msgid "No data within this subregion. Consider increasing spline step values."
-msgstr ""
-"Keine Daten in dieser Unterregion. Ãberlegen Sie die Splineschrittweite zu "
-"vergröÃern."
+msgstr "Keine Daten in dieser Unterregion. Ãberlegen Sie die Splineschrittweite zu vergröÃern."
#: ../vector/v.surf.bspline/main.c:924
#, fuzzy
@@ -35420,12 +32958,8 @@
msgstr "%d sind zu viele Punkte. Die Kreuzvalidierung würde zu lange dauern."
#: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
-msgstr ""
-"Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen "
-"zu verwenden."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
+msgstr "Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen zu verwenden."
#: ../vector/v.surf.bspline/crosscorr.c:119
#, c-format
@@ -35461,12 +32995,8 @@
msgstr "...beende nun das Modul..."
#: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens "
-"zu Ermittelung des Gebäude Inneren."
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens zu Ermittelung des Gebäude Inneren."
#: ../vector/v.lidar.growing/main.c:83
msgid "Input vector (v.lidar.edgedetection output"
@@ -35524,8 +33054,7 @@
#: ../vector/v.to.rast/support.c:176
#, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
+msgstr "Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
#: ../vector/v.to.rast/support.c:179
msgid "Color set to [200:200:200]"
@@ -35538,9 +33067,7 @@
#: ../vector/v.to.rast/support.c:273
msgid "Label column was not specified, no labels will be written"
-msgstr ""
-"Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine "
-"Beschriftungen ausgegeben."
+msgstr "Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine Beschriftungen ausgegeben."
#: ../vector/v.to.rast/support.c:352 ../vector/v.to.rast/support.c:497
#, c-format
@@ -35588,14 +33115,12 @@
#: ../vector/v.to.rast/vect2rast.c:162
#, c-format
msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr ""
-"Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
+msgstr "Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
#: ../vector/v.to.rast/vect2rast.c:174
#, c-format
msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr ""
-"Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
+msgstr "Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
#: ../vector/v.to.rast/vect2rast.c:199
msgid "Creating support files for raster map..."
@@ -35654,8 +33179,7 @@
#: ../vector/v.to.rast/main.c:86
msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
+msgstr "Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
#: ../vector/v.to.rast/main.c:92
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -35675,21 +33199,15 @@
#: ../vector/v.to.rast/main.c:132
msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes "
-"kombiniert werden."
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes kombiniert werden."
#: ../vector/v.to.rast/main.c:137
msgid "Column parameter cannot be combined with use of value option"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert "
-"werden."
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert werden."
#: ../vector/v.to.rast/main.c:142
msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten "
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten kombiniert werden."
#: ../vector/v.to.rast/main.c:148
#, c-format
@@ -35703,8 +33221,7 @@
#: ../vector/v.to.rast/do_lines.c:133
#, c-format
msgid "%d lines with varying height were not written to raster"
-msgstr ""
-"%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
+msgstr "%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
#, c-format
@@ -35725,17 +33242,12 @@
msgstr "Zentroid ohne Kategorie."
#: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-"Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-"
-"Typ ausgewählt."
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr "Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-Typ ausgewählt."
#: ../vector/v.out.vtk/writeVTK.c:632
msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-msgstr ""
-"Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Ãberspringe "
-"den Export."
+msgstr "Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Ãberspringe den Export."
#: ../vector/v.out.vtk/writeVTK.c:640
msgid "No attribute table found"
@@ -35771,8 +33283,7 @@
#: ../vector/v.out.vtk/main.c:91
msgid "Export numeric attribute table fields as VTK scalar variables"
-msgstr ""
-"Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
+msgstr "Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
#: ../vector/v.out.vtk/main.c:157
msgid "dp has to be from 0 to 8"
@@ -35784,9 +33295,7 @@
#: ../vector/v.out.vtk/main.c:185
#, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
msgstr ""
#: ../vector/v.net.visibility/main.c:48
@@ -35847,9 +33356,7 @@
msgstr "Gebe Rasterhistorie anstelle der Info aus."
#: ../vector/v.in.lidar/main.c:217
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
msgstr ""
#: ../vector/v.in.lidar/main.c:276
@@ -35965,12 +33472,8 @@
#: ../db/drivers/ogr/describe.c:192
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) "
-"abgespeichert. Einige Daten könnten verloren gehen."
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
#: ../db/drivers/ogr/select.c:50
#, fuzzy
@@ -36071,15 +33574,11 @@
#: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:59
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' "
-"verwenden."
+msgstr "'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
#: ../db/drivers/mysql/parse.c:76 ../db/drivers/postgres/parse.c:63
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db."
-"login' verwenden."
+msgstr "'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
#: ../db/drivers/mysql/parse.c:81
#, fuzzy
@@ -36133,12 +33632,8 @@
#: ../db/drivers/mysql/describe.c:127
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige "
-"Datensätze könnten beschädigt sein."
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
#: ../db/drivers/mysql/select.c:42
#, fuzzy
@@ -36264,30 +33759,18 @@
#: ../db/drivers/postgres/describe.c:130
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. "
-"Einige Datensätze könnten beschädigt sein."
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
#: ../db/drivers/postgres/describe.c:134
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. "
-"Einige Daten könnten verloren gehen."
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
#: ../db/drivers/postgres/describe.c:140
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 "
-"(falsch), 1 (wahr) abgespeichert."
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 (falsch), 1 (wahr) abgespeichert."
#: ../db/drivers/postgres/select.c:31
msgid "Unable set DATESTYLE"
@@ -36364,8 +33847,7 @@
msgstr "Kann den Zeitstempel nicht auslesen:"
#: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
msgstr ""
#: ../db/drivers/sqlite/fetch.c:223
@@ -36661,9 +34143,7 @@
#: ../db/db.select/main.c:264
#, fuzzy
msgid "Performs SQL query statement(s)."
-msgstr ""
-"Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) "
-"aus)."
+msgstr "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) aus)."
#: ../db/db.select/main.c:299
#, c-format
@@ -36678,9 +34158,7 @@
#: ../db/db.connect/main.c:48
#, fuzzy
msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
-"beendet sich."
+msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
#: ../db/db.connect/main.c:52
msgid "Print current connection parameters and exit"
@@ -36693,9 +34171,7 @@
#: ../db/db.connect/main.c:63
msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-"Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet "
-"sich."
+msgstr "Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet sich."
#: ../db/db.connect/main.c:68
#, fuzzy
@@ -36762,13 +34238,8 @@
msgstr "Kopiere eine Tabelle."
#: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die "
-"'select'-Option verwendet werden, aber nicht 'from_table' und 'select' "
-"können zur selben Zeit."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die 'select'-Option verwendet werden, aber nicht 'from_table' und 'select' können zur selben Zeit."
#: ../db/db.copy/main.c:46
msgid "Input driver name"
@@ -36780,8 +34251,7 @@
#: ../db/db.copy/main.c:59
msgid "Input table name (only, if 'select' is not used)"
-msgstr ""
-"Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
+msgstr "Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
#: ../db/db.copy/main.c:65
msgid "Output driver name"
@@ -36797,9 +34267,7 @@
#: ../db/db.copy/main.c:87
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht "
-"verwendet werden)."
+msgstr "Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht verwendet werden)."
#: ../db/db.copy/main.c:88
msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -36927,12 +34395,8 @@
msgstr "Erzeugt eine leere Datenbank."
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importiert LÃnderdateien vom US-NGA GEOnet Names Server (GNS) in eine "
-"Vektorpunktkarte."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importiert LÃnderdateien vom US-NGA GEOnet Names Server (GNS) in eine Vektorpunktkarte."
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -37007,9 +34471,7 @@
#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"Create a new location and import the data into it. Please do not run this "
-"module in parallel or interrupt it when a new location should be created."
+msgid "Create a new location and import the data into it. Please do not run this module in parallel or interrupt it when a new location should be created."
msgstr ""
#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
@@ -37023,9 +34485,7 @@
msgstr "VergröÃere die Location basierend auf dem neuen Datensatz."
#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
-msgid ""
-"import the space time raster datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
msgstr ""
#: ../locale/scriptstrings/g.manual_to_translate.c:1
@@ -37061,12 +34521,8 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygon "
-"map and uploads statistics to new attribute columns."
-msgstr ""
-"Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
-"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
+msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
msgid "Continue if upload column(s) already exist"
@@ -37164,8 +34620,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:1
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
+msgstr "Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
#: ../locale/scriptstrings/r.blend_to_translate.c:4
msgid "Name of first raster map for blending"
@@ -37178,8 +34633,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:6
#, fuzzy
msgid "Prefix for red, green and blue output raster maps containing"
-msgstr ""
-"Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
#: ../locale/scriptstrings/r.blend_to_translate.c:7
msgid "Percentage weight of first map for color blending"
@@ -37190,9 +34644,7 @@
msgstr ""
#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
msgstr ""
#: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -37231,9 +34683,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Name der Attribut-Spalte, die für die thematische Darstellung (muà umerisch "
-"sein)."
+msgstr "Name der Attribut-Spalte, die für die thematische Darstellung (muà umerisch sein)."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
msgid "Type of thematic display"
@@ -37270,15 +34720,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Kleinste SymbolgröÃe / Linienbreite für die gestufte Darstellung von Punkten/"
-"Linien."
+msgstr "Kleinste SymbolgröÃe / Linienbreite für die gestufte Darstellung von Punkten/Linien."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-"GröÃste SymbolgröÃe / Linienbreite für die gestufte Darstellung von Punkten/"
-"Linien."
+msgstr "GröÃste SymbolgröÃe / Linienbreite für die gestufte Darstellung von Punkten/Linien."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
msgid "Number of classes for interval theme (integer)"
@@ -37298,8 +34744,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
+msgstr "GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
msgid "Color for graduated lines or point/area outlines"
@@ -37307,8 +34752,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
msgid "Beginning color for custom color gradient"
@@ -37342,15 +34786,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Speichere die Befehle zur Erstellung der thematischen Karte in die group-"
-"Datei für den GIS-Manager."
+msgstr "Speichere die Befehle zur Erstellung der thematischen Karte in die group-Datei für den GIS-Manager."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im "
-"aktuellen Verzeichnis gespeichert."
+msgstr "Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im aktuellen Verzeichnis gespeichert."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
msgid "If not set, no psmap instruction files will be created)"
@@ -37358,9 +34798,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Name der group-Datei, in der die Befehle zur Erstellung der thematischen "
-"Karte gespeichert werden."
+msgstr "Name der group-Datei, in der die Befehle zur Erstellung der thematischen Karte gespeichert werden."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
msgid "Create graphic legend in x11 display monitor"
@@ -37376,9 +34814,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr ""
-"Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in "
-"Skripten)."
+msgstr "Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in Skripten)."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
msgid "Use math notation brackets in legend"
@@ -37399,9 +34835,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
-"Höheneinheiten"
+msgstr "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu Höheneinheiten"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
@@ -37410,18 +34844,13 @@
msgstr "Shading"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: "
-"scale=1)."
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr "Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: scale=1)."
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
#, fuzzy
msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-"Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
-"numerischen Spalte der Attributtabelle."
+msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
#, fuzzy
@@ -37443,9 +34872,7 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
msgstr "Liste die Vektorkarten der Eingabe-Location und beendet sich."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -37483,11 +34910,8 @@
msgstr "Datenbank-Schema"
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
-"Vektorkarte um."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten Vektorkarte um."
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
msgid "Old and new name of the column (old,new)"
@@ -37498,9 +34922,7 @@
msgstr ""
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
msgstr ""
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
@@ -37509,9 +34931,7 @@
msgstr "Name der Rasterkarte, die angezeigt werden soll."
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
-msgid ""
-"Name of the vector column to be created and to store sampled raster values, "
-"otherwise the space time raster name is used as column name"
+msgid "Name of the vector column to be created and to store sampled raster values, otherwise the space time raster name is used as column name"
msgstr ""
#: ../locale/scriptstrings/t.create_to_translate.c:1
@@ -37565,9 +34985,7 @@
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-"
-"Karte."
+msgstr "Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-Karte."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
#, fuzzy
@@ -37576,9 +34994,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen "
-"oder FlieÃrichtungen."
+msgstr "Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen oder FlieÃrichtungen."
#: ../locale/scriptstrings/d.polar_to_translate.c:3
#: ../locale/scriptstrings/d.correlate_to_translate.c:5
@@ -37592,9 +35008,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:5
msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-"Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von "
-"NULL)."
+msgstr "Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von NULL)."
#: ../locale/scriptstrings/d.polar_to_translate.c:6
#, fuzzy
@@ -37607,9 +35021,7 @@
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
#, fuzzy
-msgid ""
-"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
-"space time raster datasets."
+msgid "Perform spatio-temporal mapcalc expressions on temporal sampled maps of space time raster datasets."
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
@@ -37619,9 +35031,7 @@
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
#, fuzzy
-msgid ""
-"Base name of the new created raster maps. This name will be extended with a "
-"numerical prefix"
+msgid "Base name of the new created raster maps. This name will be extended with a numerical prefix"
msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
@@ -37667,16 +35077,12 @@
msgstr "Verwende die Version des Programms mit geringem Speicherverbrauch. "
#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
-msgid ""
-"The export format of a single raster map. Supported are GeoTIFF via r.out."
-"gdal and the GRASS package format of r.pack."
+msgid "The export format of a single raster map. Supported are GeoTIFF via r.out.gdal and the GRASS package format of r.pack."
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Ermöglicht es eine Tabelle an eine Attributtabelle einer Vektorkarte zu "
-"joinen."
+msgstr "Ermöglicht es eine Tabelle an eine Attributtabelle einer Vektorkarte zu joinen."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
msgid "Vector map to which to join other table"
@@ -37729,8 +35135,7 @@
#: ../locale/scriptstrings/r.mask_to_translate.c:6
#, fuzzy
msgid "Raster values to use for mask (format: 1 2 3 thru 7 *)"
-msgstr ""
-"Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
+msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
#: ../locale/scriptstrings/r.mask_to_translate.c:8
#, fuzzy
@@ -37769,11 +35174,8 @@
msgstr "Entferne existierende Maske (MASK). Ãbersteuert andere Optionen"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
msgid "Extended statistics (quartiles and 90th percentile)"
@@ -37786,16 +35188,12 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
#, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr ""
-"Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
msgstr "Erzeugt/verändert die Farbtabelle einer Rasterkarte."
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
@@ -37827,12 +35225,8 @@
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
#, fuzzy
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
-msgstr ""
-"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
-"univariater Statistik."
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
+msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
msgid "raster3d, import, voxel, LiDAR"
@@ -37896,12 +35290,8 @@
msgstr "Namen der Eingabedateien."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reklassifiziert eine Rasterkarte mit Flächen gröÃer oder kleiner als eine "
-"benutzerspezifizierte Fläche (in Hektar)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reklassifiziert eine Rasterkarte mit Flächen gröÃer oder kleiner als eine benutzerspezifizierte Fläche (in Hektar)."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
msgid "Lesser value option that sets the <= area size limit [hectares]"
@@ -37918,8 +35308,7 @@
msgstr "GröÃerer-Wert-Option bestimmt das >= Flächengrenze [Hektar]."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
msgstr "Löscht eine Spalte der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -37949,11 +35338,8 @@
msgstr "Name für automatisch erzeugte Schlüsselwert-Spalte."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
msgid "Layer number where to add column(s)"
@@ -37964,12 +35350,8 @@
msgstr "Name and Typ der neuen Spalten ('name type [,name type, ...]')"
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen "
-"VARCHAR(), INT, DOUBLE PRECISION und DATE."
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION und DATE."
#: ../locale/scriptstrings/v.pack_to_translate.c:1
#, fuzzy
@@ -38052,11 +35434,8 @@
msgstr ""
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe "
-"oder in Bilderen."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe oder in Bilderen."
#: ../locale/scriptstrings/i.spectral_to_translate.c:5
#, fuzzy
@@ -38084,17 +35463,12 @@
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
#, fuzzy
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
msgstr "."
#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
-"(inclination), Ausrichtung (azimuth) und einem Punkt."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
#: ../locale/scriptstrings/r.plane_to_translate.c:4
#, fuzzy
@@ -38141,8 +35515,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
+msgstr "Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
@@ -38165,9 +35538,7 @@
msgstr "Name der 3D Eingabe-Rasterkarte."
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
msgstr ""
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
@@ -38177,12 +35548,8 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-"Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative "
-"DGMs mit Hilfe von gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
#, fuzzy
@@ -38195,23 +35562,17 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
#, fuzzy
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
-msgstr ""
-"L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
-"einzelnen Kanal umrechnen."
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
#, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
#, fuzzy
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -38288,22 +35649,16 @@
msgstr "Name der Ausgabedatei."
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
#, fuzzy
-msgid ""
-"Temporally aggregates the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Temporally aggregates the maps of a space time raster dataset by a user defined granularity."
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
@@ -38351,11 +35706,8 @@
#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
#, fuzzy
@@ -38364,14 +35716,11 @@
#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
#, fuzzy
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output "
-"map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
msgstr "Konvertiert 3D-Rasterkarten in 2D-Rasterkarten."
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
+msgid "Allows to update a column in the attribute table connected to a vector map."
msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
@@ -38381,11 +35730,8 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
#, fuzzy
-msgid ""
-"Value to update the column with, can be (combination of) other column(s)"
-msgstr ""
-"Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
-"einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+msgid "Value to update the column with, can be (combination of) other column(s)"
+msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
#, fuzzy
@@ -38411,15 +35757,12 @@
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
#, fuzzy
-msgid ""
-"Replace gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replace gaps in a space time raster dataset with interpolated raster maps."
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
#, fuzzy
-msgid ""
-"Base name of the interpolated raster maps. This name will be extended with a "
-"numerical prefix"
+msgid "Base name of the interpolated raster maps. This name will be extended with a numerical prefix"
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
@@ -38428,21 +35771,16 @@
msgstr "Anzahl der Interpolationspunkte."
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
msgstr ""
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu "
-"Vektorkarten."
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu Vektorkarten."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Fülle Flächen ohne Daten in Rasterkarten mit Hilfe von Spline-Interpolation."
+msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe von Spline-Interpolation."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
msgid "Spline tension parameter"
@@ -38475,15 +35813,11 @@
msgstr "Raster"
#: ../locale/scriptstrings/t.register_to_translate.c:9
-msgid ""
-"Input file with map names, one per line. Additionally the start time and the "
-"end time can be specified per line"
+msgid "Input file with map names, one per line. Additionally the start time and the end time can be specified per line"
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid ""
-"Valid start date and time of the first map. Format absolute time: \"yyyy-mm-"
-"dd HH:MM:SS +HHMM\", relative time is of type integer)."
+msgid "Valid start date and time of the first map. Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:12
@@ -38496,9 +35830,7 @@
msgstr "Zeitschritt \t= %.2f s\n"
#: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid ""
-"Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:"
-"SS +HHMM\", relative time is of type integer)."
+msgid "Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -38506,10 +35838,7 @@
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative is integer: 5)"
+msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5)"
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:19
@@ -38518,8 +35847,7 @@
msgstr "Feld-Trennzeichen"
#: ../locale/scriptstrings/t.register_to_translate.c:21
-msgid ""
-"Create an interval (start and end time) in case an increment is provided"
+msgid "Create an interval (start and end time) in case an increment is provided"
msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
@@ -38535,12 +35863,8 @@
msgstr "Startwert der Kategorienummern.goriewerte."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden "
-"Vektorkarte."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden Vektorkarte."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
msgid "Name of new attribute table (default: vector map name)"
@@ -38566,12 +35890,8 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
#, fuzzy
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: \"label varchar(250), type integer\""
-msgstr ""
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: \"label varchar(250), type integer\""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
#, fuzzy
@@ -38597,8 +35917,7 @@
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities file"
+msgid "The given code must be supported by the server, consult the capabilities file"
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
@@ -38619,9 +35938,7 @@
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -38630,12 +35947,8 @@
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
#, fuzzy
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
-msgstr ""
-"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
-"panchromatischer Kanäle."
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
msgid "fusion"
@@ -38675,9 +35988,7 @@
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
#, fuzzy
msgid "Input raster map for high resolution panchromatic channel"
-msgstr ""
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
msgid "Serial processing rather than parallel processing"
@@ -38707,9 +36018,7 @@
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time raster3d datasets."
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
@@ -38718,9 +36027,7 @@
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
#, fuzzy
-msgid ""
-"Base name of the new created 3d raster maps. This name will be extended with "
-"a numerical prefix"
+msgid "Base name of the new created 3d raster maps. This name will be extended with a numerical prefix"
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
@@ -38769,29 +36076,22 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Teste den Datenbank-Treiber. Die Datenbank muà existieren und mittels db."
-"connect verbunden sein."
+msgstr "Teste den Datenbank-Treiber. Die Datenbank muà existieren und mittels db.connect verbunden sein."
#: ../locale/scriptstrings/db.test_to_translate.c:4
msgid "Test name"
msgstr "Testname"
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das "
-"aktuelle Format."
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das aktuelle Format."
#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:1
msgid "Rebuilds all locally installed GRASS Addons extensions."
msgstr ""
#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
msgstr ""
#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:4
@@ -38845,9 +36145,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:1
#, fuzzy
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
-"Frontend)."
+msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
#: ../locale/scriptstrings/m.proj_to_translate.c:4
#, fuzzy
@@ -38866,9 +36164,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:6
#, fuzzy
msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr ""
-"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
-"soll)."
+msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
#: ../locale/scriptstrings/m.proj_to_translate.c:8
#, fuzzy
@@ -38896,21 +36192,15 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:15
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-"
-"Projektion."
+msgstr "Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-Projektion."
#: ../locale/scriptstrings/m.proj_to_translate.c:17
msgid "Use current location as input and LL WGS84 as output projection"
msgstr "Verwende LL WGS84 als Eingabe-Projektion und Ausgabe-Projektion."
#: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen "
-"Dezimalstellen aus"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen Dezimalstellen aus"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
#, fuzzy
@@ -38924,8 +36214,7 @@
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
#: ../locale/scriptstrings/i.oif_to_translate.c:5
msgid "LANDSAT TM band 1."
@@ -38967,9 +36256,7 @@
msgstr "Name der Expositions-Rasterkarte."
#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-msgid ""
-"The export format of a single raster map. Supported are GML via v.out.ogr "
-"and the GRASS package format of v.pack."
+msgid "The export format of a single raster map. Supported are GML via v.out.ogr and the GRASS package format of v.pack."
msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
@@ -38978,8 +36265,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-"Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
+msgstr "Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
#, fuzzy
@@ -38997,18 +36283,13 @@
#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-msgid ""
-"import the space time vector datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
msgstr ""
#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster3d map of a space time raster3d dataset."
-msgstr ""
+msgid "Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset."
#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
@@ -39019,8 +36300,7 @@
#: ../locale/scriptstrings/t.list_to_translate.c:1
#, fuzzy
msgid "List space time datasets and maps registered in the temporal database."
-msgstr ""
-"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
#: ../locale/scriptstrings/t.list_to_translate.c:5
#, fuzzy
@@ -39029,8 +36309,7 @@
#: ../locale/scriptstrings/t.list_to_translate.c:8
#: ../locale/scriptstrings/t.list_to_translate.c:11
-msgid ""
-"Columns number_of_maps and granularity only available for space time datasets"
+msgid "Columns number_of_maps and granularity only available for space time datasets"
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:9
@@ -39065,9 +36344,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
#, fuzzy
msgid "Mosaics several images and extends colormap."
-msgstr ""
-"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
-"Karten."
+msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
msgid "mosaicking"
@@ -39075,11 +36352,8 @@
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
#, fuzzy
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr ""
-"Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das "
-"von GpsBabel unterstützt wird."
+msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
msgid "GPS"
@@ -39113,17 +36387,12 @@
#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
#, fuzzy
-msgid ""
-"Separator character between the output columns, default is tabular \"\t\""
+msgid "Separator character between the output columns, default is tabular \"\t\""
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region "
-"und -Projektion."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region und -Projektion."
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
msgid "Produces shell script output"
@@ -39134,11 +36403,8 @@
msgstr "Erzeugt ein Web Map Server Query-String."
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Name der Region die anstelle der aktuellen Region für die Ausdehnung "
-"(bounding box) und Auflösung verwendet werden soll."
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Name der Region die anstelle der aktuellen Region für die Ausdehnung (bounding box) und Auflösung verwendet werden soll."
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
msgid "Source projection"
@@ -39209,9 +36475,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben "
-"wird die aktuelle Region verwendet."
+msgstr "Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben wird die aktuelle Region verwendet."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
msgid "WMS standard"
@@ -39276,10 +36540,7 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
@@ -39293,8 +36554,7 @@
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
@@ -39348,15 +36608,11 @@
msgstr "Löscht eine Spalte aus einer Attributtabelle."
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:1
-msgid ""
-"Aggregated data of an existing space time raster dataset using the temporal "
-"topology of a second space time dataset."
+msgid "Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset."
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are "
-"used for aggregation computation"
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
@@ -39385,9 +36641,7 @@
#: ../locale/scriptstrings/t.sample_to_translate.c:1
#, fuzzy
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
#: ../locale/scriptstrings/t.sample_to_translate.c:4
@@ -39401,10 +36655,7 @@
msgstr "Name der neuen Datenbank."
#: ../locale/scriptstrings/t.sample_to_translate.c:8
-msgid ""
-"Separator character between the output columns, default is tabular \" | \". "
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "Separator character between the output columns, default is tabular \" | \". Do not use \",\" as this char is reserved to list several map ids in a sample granule"
msgstr ""
#: ../locale/scriptstrings/t.sample_to_translate.c:10
@@ -39414,40 +36665,26 @@
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
#, fuzzy
-msgid ""
-"Store raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
-msgstr ""
-"Ãbernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
-"Attributtabelle."
+msgid "Store raster map values at spatial and temporal positions of vector points as vector attributes."
+msgstr "Ãbernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
#, fuzzy
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:1
#, fuzzy
msgid "Maintains GRASS Addons extensions in local GRASS installation."
-msgstr ""
-"Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
+msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
-msgstr ""
-"Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN "
-"Repository' in der lokalen GRASS Installation oder Entfernt installierte "
-"Erweiterungen. "
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
+msgstr "Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN Repository' in der lokalen GRASS Installation oder Entfernt installierte Erweiterungen. "
#: ../locale/scriptstrings/g.extension_to_translate.c:6
msgid "Name of extension to install/remove"
@@ -39469,16 +36706,12 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:12
#, fuzzy
-msgid ""
-"List available extensions in the GRASS Addons SVN repository including "
-"module description"
+msgid "List available extensions in the GRASS Addons SVN repository including module description"
msgstr "Zeigt die vorhandenen Regelsätze und SchluÃ."
#: ../locale/scriptstrings/g.extension_to_translate.c:14
#, fuzzy
-msgid ""
-"List available extensions in the GRASS Addons SVN repository (shell script "
-"style)"
+msgid "List available extensions in the GRASS Addons SVN repository (shell script style)"
#: ../locale/scriptstrings/g.extension_to_translate.c:16
@@ -39488,8 +36721,7 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:18
msgid "Install system-wide (may need system administrator rights)"
-msgstr ""
-"Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
+msgstr "Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
#: ../locale/scriptstrings/g.extension_to_translate.c:19
#: ../locale/scriptstrings/g.extension_to_translate.c:21
@@ -39517,11 +36749,8 @@
#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr ""
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
#, fuzzy
@@ -39533,9 +36762,7 @@
msgstr ""
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
-msgid ""
-"The base name of the new created raster maps. This name will be extended "
-"with a numerical prefix"
+msgid "The base name of the new created raster maps. This name will be extended with a numerical prefix"
msgstr ""
#: ../locale/scriptstrings/v.unpack_to_translate.c:1
@@ -39569,24 +36796,16 @@
#: ../locale/scriptstrings/t.support_to_translate.c:9
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the grass spatial database. Check for removed maps and delete them from the "
-"temporal database and all effected space time datasets."
+msgid "Update the metadata information and spatial extent of registered maps from the grass spatial database. Check for removed maps and delete them from the temporal database and all effected space time datasets."
msgstr ""
#: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid ""
-"Update metadata information, temporal and spatial extent from registered maps"
+msgid "Update metadata information, temporal and spatial extent from registered maps"
msgstr ""
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
-"gleichem Attributwert auf."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder gleichem Attributwert auf."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
msgid "dissolve"
@@ -39600,24 +36819,17 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
#, fuzzy
msgid "Name of attribute column used to dissolve common boundaries"
-msgstr ""
-"Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden "
-"soll."
+msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"raster map of a space time raster dataset."
-msgstr ""
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
#, fuzzy
msgid "Drapes a color raster over a shaded relief map."
-msgstr ""
-"Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
-"Verwendung von d.his."
+msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
#, fuzzy
@@ -39633,9 +36845,414 @@
msgid "Percent to brighten"
msgstr "Prozentuale Aufhellung."
+#, fuzzy
+msgid "Can not open vector <%s> on level %d"
+msgstr "Kann die Vektorkarte <%s> nicht öffnen."
+msgid "Please provide three G3D vector maps [x,y,z]"
+msgstr "Bitte geben Sie drei G3D Vektorkarten an [x,y,z]."
+#, fuzzy
+msgid "output map with walking costs"
+msgstr "Ausgabekarte <%s> ignoriert."
+msgid "Starting points raster map"
+msgstr "Rasterkarte mit Startpunkten."
+#, fuzzy
+msgid "No %s map specified"
+msgstr "Keine Rasterkarte angegeben."
+msgid "Use RASTER3D mask (if exists) with output map"
+msgstr "Benutzt RASTER3D Maske (falls existent) für die Ausgabekarte."
+msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
+msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Ich werde die G3D Parameter verwenden, um die 2D Region anzupassen."
+msgid "Use RASTER3D mask (if exists) with input map"
+msgstr "Benutzt RASTER3D Maske (falls existent) mit der Eingabekarte"
+msgid "Error writing RASTER3D double data"
+msgstr "Fehler beim Schreiben der RASTER3D double-Daten."
+#, fuzzy
+msgid "Name of the input map"
+msgstr "Name der Eingabe-Rasterkarte."
+#, fuzzy
+msgid "viname"
+msgstr "Name"
+#, fuzzy
+msgid "Name of the chan7 channel surface reflectance map"
+msgstr "Name der Rasterkarte mit Mannings n."
+msgid "Illegal value of iterations (%s>)"
+msgstr "Unzulässige Wert für die Iterationen (%s>)."
+#, fuzzy
+msgid "version"
+msgstr "Position"
+#, fuzzy
+msgid "Name of mask files"
+msgstr "Namen der Maske-Dateien."
+#, fuzzy
+msgid "unable to open input file %s"
+msgstr "Kann die Eingabedatei <%s> nicht öffnen."
+#, fuzzy
+msgid "unable to allocate PNG structure"
+msgstr "Belegen von Speicherplatz für die Site-Struktur fehlgeschlagen."
+#, fuzzy
+msgid "unable to open output file %s"
+msgstr "Kann die Ausgabedatei nicht öffnen."
+#, fuzzy
+msgid "List available OGR layers including feature types in data source and exit"
+msgstr "Zeigt die vorhandenen Layer in der Datenquelle und beendet sich."
+#, fuzzy
+msgid "PostGIS output datasource name"
+msgstr "Name der OGR-Ausgabe Datenquelle. "
+#, fuzzy
+msgid "Name for output surface raster map (elevation)"
+msgstr "Ausgabekarte mit den Oberflächeninformationen (Höheninformationen)."
+#, fuzzy
+msgid "db_driver_list_databases() is not implemented"
+msgstr "Operation nicht implementiert."
+#, fuzzy
+msgid "Old database schema"
+msgstr "Datenbank-Schema"
+msgid "Create inverse mask from specified 'maskcats' list"
+msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste"
+#, fuzzy
+msgid "Name of point vector map containing sample data"
+msgstr "Namde der Eingabe-Vektorkarte mit Linien."
+#, fuzzy
+msgid "Name of attribute column with numerical value to be interpolated"
+msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
+#, fuzzy
+msgid "Range value"
+msgstr "Rasterwert"
+#, fuzzy
+msgid "Sill value"
+msgstr "Sortiere Nicht-NULL-Werte."
+#, fuzzy
+msgid "Table name to drop"
+msgstr "Tabelle die gelöscht werden soll."
+#, fuzzy
+msgid "Name of an existing space time or map dataset"
+msgstr "Name einer existierenden Rasterkarte."
+msgid "Open 3d raster map <%s>"
+msgstr "Ãffne RASTER3D Rasterkarte <%s>."
+#, fuzzy
+msgid "Print 3D raster tile number and size information only"
+msgstr "Gebe nur die Region der 3D-Rasterkarte aus."
+#, fuzzy
+msgid "groundwater"
+msgstr "Grenze"
+#, fuzzy
+msgid "numeric"
+msgstr "Metrisch"
+#, fuzzy
+msgid "Title"
+msgstr "Dateien"
+#, fuzzy
+msgid "Raster map to use for masking"
+msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
+#, fuzzy
+msgid "DN"
+msgstr "D"
+#, fuzzy
+msgid "QC"
+msgstr "C"
+#, fuzzy
+msgid "Surface Reflectance"
+msgstr "Isoflächen-Level"
+#, fuzzy
+msgid "Modis"
+msgstr "Verschiedenes"
+#, fuzzy
+msgid "Name of the Surface temperature map [degree Kelvin]"
+msgstr "Name der Ausgabe-Rasterkarte (grün)."
+#, fuzzy
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);arcs;new line is created from start point to end point;report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
+#, fuzzy
+msgid "Unable to build topology for <%s>"
+msgstr "Kann den Stoppvektor <%s> nicht finden."
+#, fuzzy
+msgid "add;add a new category;del;delete category (-1 to delete all categories of given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;transfer;copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3);report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
+msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ãndere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option 'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht (Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
+#, fuzzy
+msgid "Name of input OGR layer"
+msgstr "Name der Eingabekarte."
+#, fuzzy
+msgid "List available OGR layers including feature types in datatsource and exit"
+#, fuzzy
+msgid "Supported OGR formats for reading:"
+msgstr "Zeige unterstützte Formate an und SchluÃ."
+#, fuzzy
+msgid "Do not build topology for output vector"
+msgstr "Erzeugt keine Topologie für die Ausgabe Vektorkarte."
+#, fuzzy
+msgid "Supported Formats:"
+msgstr "Unterstützte Formate:\n"
+#, fuzzy
+msgid "Unable to open OGR file"
+msgstr "Kann kein Face erzeugen."
+#, fuzzy
+msgid "dsn: %s\n"
+msgstr "Maske: %s\n"
+#, fuzzy
+msgid "not set (default 'ogr')"
+msgstr "Zu selektierende Kanäle (Standard: alle)."
+#, fuzzy
+msgid "format: %s\n"
+msgstr "Format"
+#, fuzzy
+msgid "not set (default ESRI_Shapefile)"
+#, fuzzy
+msgid "<none>"
+msgstr "Fertig."
+#, fuzzy
+msgid "Unable to create OGR file"
+#, fuzzy
+msgid "Error writing OGR file"
+msgstr "Fehler beim Schreiben der PGM-Datei."
+msgid "Error trying to read dbmscap file\n"
+msgstr "Fehler beim Lesen der Datei dbmscap\n"
+#, fuzzy
+msgid "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
+msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht konvertiert."
+#, fuzzy
+msgid "Name of file with SQL select statement(s)"
+msgstr "Name der Datei, die SQL-Befehle enthält"
+#, fuzzy
+msgid ""
+"Unable to open file <%s> for reading.\n"
+"Details: %s"
+msgstr "Kann die Datei [%s] nicht zum Lesen öffnen."
+#, fuzzy
+msgid "'-' to read from standard input"
+msgstr "Wenn '-' angegeben wird von Standardeingabe gelesen."
+#, fuzzy
+msgid "dataset"
+msgstr "Datenbank, SQL"
+#, fuzzy
+msgid "spacetime"
+msgstr "Platzierung"
+#, fuzzy
+msgid "Name of a space time vector dataset"
+msgstr "Name der Expositions-Rasterkarte."
+#, fuzzy
+msgid "absolute"
+msgstr "south=%f"
+#, fuzzy
+msgid "Name(s) of existing raster, raster3d or vector map(s)"
+msgstr "Name existierender Rasterkarte(n)"
+#, fuzzy
+msgid "Input map type"
+msgstr "Eingabekarte"
+#, fuzzy
+msgid "Type of the space time dataset, default is space time raster dataset (strds)"
+msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
+#, fuzzy
+msgid "Unregister vector map(s) from a specific or from all space time vector dataset in which it is registered"
+msgstr "Liste die Vektorkarten der Eingabe-Location und beendet sich."
+#, fuzzy
+msgid "spacetime vector dataset"
+msgstr "Aktualisiere die Metadaten einer Vektorkarte"
+#, fuzzy
+msgid "Name(s) of existing vector map(s) to unregister"
+msgstr "Name einer existierenden Vektorkarte."
+#, fuzzy
+msgid "spacetime raster dataset"
+msgstr "Aktualisiere die Statistik der Rasterkarte."
+#, fuzzy
+msgid "Name of a space time raster dataset"
+#, fuzzy
+msgid "verride projection (use location's projection)"
+msgstr "Ãbersteuere die Projektion (verwende Projektion der Location)."
+#, fuzzy
+msgid "Name of the new space time dataset"
+msgstr "Name der neuen Datenbank."
+#, fuzzy
+msgid "Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets"
+#, fuzzy
+msgid "space time vector dataset"
+#, fuzzy
+msgid "space time raster dataset"
+#, fuzzy
+msgid "The space time raster dataset to use"
+#, fuzzy
+msgid "Name of an existing space time vector dataset"
+#, fuzzy
+msgid "Name(s) of existing vector map(s)"
+#, fuzzy
+msgid "The unit of the relative time"
+msgstr "Höhe des Flussbetts [m]."
+#, fuzzy
+msgid "spacetime raster3d dataset"
+#, fuzzy
+msgid "Name of an existing space time raster3d dataset"
+#, fuzzy
+msgid "Name(s) of existing raster3d map(s)"
+#, fuzzy
+msgid "edit"
+msgstr "Einstellungen"
+#, fuzzy
+msgid "Name(s) of existing raster map(s) to unregister"
+msgstr "Rasterkarte(n) zum abfragen."
+#, fuzzy
+msgid "Name of an existing space time raster dataset"
+#, fuzzy
+msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
+msgstr "Verzeichnis um heruntergeladene Daten zu speichern."
+#, fuzzy
+msgid "Name(s) of existing raster map(s)"
+#, fuzzy
+msgid "sample"
+msgstr "Raster, Resamplen"
+#, fuzzy
+msgid "Name of a space time dataset"
+#, fuzzy
+msgid "The method to be used for sampling"
+msgstr "Text für den Kartentitel."
+#, fuzzy
+msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2"
+msgstr "Name der Eingabe-Rasterkarte (NIR: tm4 | qbird_nir | spot2)."
+#, fuzzy
+msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3"
+msgstr "Name der Eingabe-Rasterkarte (MIR; tm5 | qbird_red | spot3)."
+#, fuzzy
+msgid "Name of a space time raster3d dataset"
+#, fuzzy
+msgid "Name of the output space time raster3d dataset"
+#, fuzzy
+msgid "Name of the space time dataset"
+msgid "PostScript file [%s] successfully written."
+msgstr "Die PostScript Datei [%s] wurde erfolgreich geschrieben."
+msgid "Unknown column type '%s' values lost"
+msgstr "Unbekannter Spalten-Typ '%s', Werte verloren"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
+#~ msgid "Input_maps"
+#~ msgstr "Eingabekarten"
+#~ msgid "Output_maps"
+#~ msgstr "Ausgabekarten"
+#~ msgid "From_map"
+#~ msgstr "From_map"
#~ msgid "nviz - Visualization and animation tool for GRASS data."
-#~ msgstr ""
-#~ "nviz - Visualisations- und Animations-Werkzeug für GRASS Datensätze."
+#~ msgstr "nviz - Visualisations- und Animations-Werkzeug für GRASS Datensätze."
#~ msgid "Name of raster map(s) for Elevation"
#~ msgstr "Name der Rasterkarte(n) mit Höheninformationen."
@@ -39656,9 +37273,7 @@
#~ msgstr "Schnellstart - Lade keine Daten."
#~ msgid "Exit after completing script launched from the command line"
-#~ msgstr ""
-#~ "Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig "
-#~ "ist"
+#~ msgstr "Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig ist"
#~ msgid "Start in Demo mode (skip the \"please wait\" message)"
#~ msgstr "Starte im Demo-Modus (überspringe die \"please wait\" Mitteilung)"
@@ -39673,9 +37288,7 @@
#~ msgstr "Lade gespeicherte Zustandsdatei."
#~ msgid "Number of elevation files does not match number of colors files"
-#~ msgstr ""
-#~ "Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der "
-#~ "Farbinformationen überein."
+#~ msgstr "Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der Farbinformationen überein."
#~ msgid "Loading data failed"
#~ msgstr "Laden der Daten fehlgeschlagen."
@@ -39683,9 +37296,6 @@
#~ msgid "Image file"
#~ msgstr "Bild-Datei"
-#~ msgid "Please provide three G3D vector maps [x,y,z]"
-#~ msgstr "Bitte geben Sie drei G3D Vektorkarten an [x,y,z]."
#~ msgid "ASCII raster map to be imported"
#~ msgstr "Zu importierende ASCII Raster-Datei"
@@ -39704,26 +37314,15 @@
#~ msgid "Elevation raster map"
#~ msgstr "Rasterkarte mit Höhenwerten"
-#~ msgid ""
-#~ "Creates a raster map layer showing buffer zones surrounding cells that "
-#~ "contain non-NULL category values."
-#~ msgstr ""
-#~ "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
-#~ "haben."
+#~ msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+#~ msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
#~ msgid "Name of elevation input raster map"
#~ msgstr "Eingabe-Rasterkarte mit Höheninformationen."
-#, fuzzy
-#~ msgid "output map with walking costs"
-#~ msgstr "Ausgabekarte <%s> ignoriert."
#~ msgid "Starting points vector map"
#~ msgstr "Vektorkarte mit Startpunkten"
-#~ msgid "Starting points raster map"
-#~ msgstr "Rasterkarte mit Startpunkten."
#~ msgid "The map E and N grid coordinates of a starting point (E,N)"
#~ msgstr "Die Startkoordinaten eines Punktes (Ost, Nord)"
@@ -39733,35 +37332,14 @@
#~ msgid "An optional maximum cumulative cost"
#~ msgstr "Ein optionales kumulatives Kostenmaximum."
-#, fuzzy
-#~ msgid "No %s map specified"
-#~ msgstr "Keine Rasterkarte angegeben."
-#~ msgid "Use RASTER3D mask (if exists) with output map"
-#~ msgstr "Benutzt RASTER3D Maske (falls existent) für die Ausgabekarte."
-#~ msgid ""
-#~ "The 2d and 3d region settings are different. I will use the g3d settings "
-#~ "to adjust the 2d region."
-#~ msgstr ""
-#~ "Die 2D und 3D Regions Parameter sind unterschiedlich. Ich werde die G3D "
-#~ "Parameter verwenden, um die 2D Region anzupassen."
#~ msgid "Name for new TIFF file"
#~ msgstr "Name für neue TIFF-Datei."
#~ msgid "Special characters: space, comma, tab"
#~ msgstr "Spezialzeichen: Leerzeichen, Komma, Tabulator"
-#~ msgid ""
-#~ "GRASS module to produce a raster map layer of gaussian deviates whose "
-#~ "mean and standard deviation can be expressed by the user. It uses a "
-#~ "gaussian random number generator."
-#~ msgstr ""
-#~ "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer GauÃ'schen "
-#~ "Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer "
-#~ "angegeben werden können. Ein GauÃ'scher Zufallszahlengenerator wird "
-#~ "verwendet."
+#~ msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+#~ msgstr "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer GauÃ'schen Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer angegeben werden können. Ein GauÃ'scher Zufallszahlengenerator wird verwendet."
#~ msgid "Name of the output random surface"
#~ msgstr "Name der Ausgabe-Rasterkarte mit zufälliger Oberfläche"
@@ -39769,12 +37347,6 @@
#~ msgid "Name for new VRML file"
#~ msgstr "Name der neuen VRML-Datei."
-#~ msgid "Use RASTER3D mask (if exists) with input map"
-#~ msgstr "Benutzt RASTER3D Maske (falls existent) mit der Eingabekarte"
-#~ msgid "Error writing RASTER3D double data"
-#~ msgstr "Fehler beim Schreiben der RASTER3D double-Daten."
#~ msgid "Calculating maps ..."
#~ msgstr "Berechne Karten..."
@@ -39790,21 +37362,6 @@
#~ msgid "Unable to find file %s"
#~ msgstr "Kann die Datei %s nicht finden."
-#, fuzzy
-#~ msgid "Name of the input map"
-#~ msgstr "Name der Eingabe-Rasterkarte."
-#, fuzzy
-#~ msgid "viname"
-#~ msgstr "Name"
-#, fuzzy
-#~ msgid "Name of the chan7 channel surface reflectance map"
-#~ msgstr "Name der Rasterkarte mit Mannings n."
-#~ msgid "Illegal value of iterations (%s>)"
-#~ msgstr "Unzulässige Wert für die Iterationen (%s>)."
#~ msgid "Sets the legend's text color"
#~ msgstr "Setzt die Texfarbe für die Legende."
@@ -39814,26 +37371,6 @@
#~ msgid "Name of output file"
#~ msgstr "Name der Ausgabedatei."
-#, fuzzy
-#~ msgid "version"
-#~ msgstr "Position"
-#, fuzzy
-#~ msgid "Name of mask files"
-#~ msgstr "Namen der Maske-Dateien."
-#, fuzzy
-#~ msgid "unable to open input file %s"
-#~ msgstr "Kann die Eingabedatei <%s> nicht öffnen."
-#, fuzzy
-#~ msgid "unable to allocate PNG structure"
-#~ msgstr "Belegen von Speicherplatz für die Site-Struktur fehlgeschlagen."
-#, fuzzy
-#~ msgid "unable to open output file %s"
-#~ msgstr "Kann die Ausgabedatei nicht öffnen."
#~ msgid "Name(s) of existing mapset(s)"
#~ msgstr "Name(n) existierender Rasterkarte(n)."
@@ -39858,11 +37395,6 @@
#~ msgid "Dimension > 2 supported only by gaussian function"
#~ msgstr "Dimension > 2 wird nur von der Gaussian-Funktion unterstützt."
-#, fuzzy
-#~ msgid ""
-#~ "List available OGR layers including feature types in data source and exit"
-#~ msgstr "Zeigt die vorhandenen Layer in der Datenquelle und beendet sich."
#~ msgid "Column name changed: '%s' -> '%s'"
#~ msgstr "Spaltenname wurde geändert: '%s' -> '%s'"
@@ -39872,20 +37404,12 @@
#~ msgid "Point not found: %.3lf %.3lf %.3lf line category: %d"
#~ msgstr "Punkt nicht gefunden: %.3lf %.3lf %.3lf Kategorie der Linie: %d"
-#, fuzzy
-#~ msgid "PostGIS output datasource name"
-#~ msgstr "Name der OGR-Ausgabe Datenquelle. "
#~ msgid "Database schema"
#~ msgstr "Datenbank-Schema"
#~ msgid "Finding nearest areas..."
#~ msgstr "Finde nächste Flächen..."
-#, fuzzy
-#~ msgid "Name for output surface raster map (elevation)"
-#~ msgstr "Ausgabekarte mit den Oberflächeninformationen (Höheninformationen)."
#~ msgid "'%s' must be > 0 for '%s'"
#~ msgstr "'%s' muss > 0 sein für '%s'"
@@ -39938,19 +37462,13 @@
#~ msgstr "Kann Tabelle %s nicht erzeugen"
#~ msgid "Use all vector points (do not limit to current region)"
-#~ msgstr ""
-#~ "Verwende alle Punkte (beschränkt sich nicht auf die aktuelle Region)."
+#~ msgstr "Verwende alle Punkte (beschränkt sich nicht auf die aktuelle Region)."
#~ msgid "Special characters: newline, space, comma, tab"
-#~ msgstr ""
-#~ "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder "
-#~ "Tabulator."
+#~ msgstr "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
-#~ msgid ""
-#~ "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-#~ msgstr ""
-#~ "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-"
-#~ "Regularisierung."
+#~ msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+#~ msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
#~ msgid "Unable to process areas from vector map <%s>"
#~ msgstr "Kann Flächen der Vektorkarte <%s> nicht verarbeiten."
@@ -39958,364 +37476,15 @@
#~ msgid "Path to resulting VTK file"
#~ msgstr "Pfad zur resultierenden VTK-Datei."
-#, fuzzy
-#~ msgid "db_driver_list_databases() is not implemented"
-#~ msgstr "Operation nicht implementiert."
#~ msgid "Location name"
#~ msgstr "Name der Location"
#~ msgid "Reconnects vectors to a new database."
#~ msgstr "Verbindet Vektor mit einer neuen Datenbank."
-#, fuzzy
-#~ msgid "Old database schema"
-#~ msgstr "Datenbank-Schema"
-#~ msgid "Create inverse mask from specified 'maskcats' list"
-#~ msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste"
-#, fuzzy
-#~ msgid "Name of point vector map containing sample data"
-#~ msgstr "Namde der Eingabe-Vektorkarte mit Linien."
-#, fuzzy
-#~ msgid "Name of attribute column with numerical value to be interpolated"
-#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
-#, fuzzy
-#~ msgid "Range value"
-#~ msgstr "Rasterwert"
-#, fuzzy
-#~ msgid "Sill value"
-#~ msgstr "Sortiere Nicht-NULL-Werte."
#~ msgid "Table name of SQL DB table"
#~ msgstr "Tabellenname der SQL DB Tabelle."
-#, fuzzy
-#~ msgid "Table name to drop"
-#~ msgstr "Tabelle die gelöscht werden soll."
-#, fuzzy
-#~ msgid "Name of an existing space time or map dataset"
-#~ msgstr "Name einer existierenden Rasterkarte."
-#~ msgid "Open 3d raster map <%s>"
-#~ msgstr "Ãffne RASTER3D Rasterkarte <%s>."
-#, fuzzy
-#~ msgid "Print 3D raster tile number and size information only"
-#~ msgstr "Gebe nur die Region der 3D-Rasterkarte aus."
-#, fuzzy
-#~ msgid "groundwater"
-#~ msgstr "Grenze"
-#, fuzzy
-#~ msgid "numeric"
-#~ msgstr "Metrisch"
-#, fuzzy
-#~ msgid "Title"
-#~ msgstr "Dateien"
-#, fuzzy
-#~ msgid "Raster map to use for masking"
-#~ msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
-#, fuzzy
-#~ msgid "DN"
-#~ msgstr "D"
-#, fuzzy
-#~ msgid "QC"
-#~ msgstr "C"
-#, fuzzy
-#~ msgid "Surface Reflectance"
-#~ msgstr "Isoflächen-Level"
-#, fuzzy
-#~ msgid "Modis"
-#~ msgstr "Verschiedenes"
-#, fuzzy
-#~ msgid "Name of the Surface temperature map [degree Kelvin]"
-#~ msgstr "Name der Ausgabe-Rasterkarte (grün)."
-#, fuzzy
-#~ msgid ""
-#~ "nodes;new point is placed on each node (line end) if doesn't exist;"
-#~ "connect;connect still unconnected points to vector network by inserting "
-#~ "new line(s);arcs;new line is created from start point to end point;report;"
-#~ "print to standard output {line_category start_point_category "
-#~ "end_point_category};nreport;print to standard output {point_category "
-#~ "line_category[,line_category...]}"
-#~ msgstr ""
-#~ "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, "
-#~ "wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des "
-#~ "Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe "
-#~ "{line_category start_point_category end_point_category} aus;nreport;Gebe "
-#~ "auf der Standardausgabe {point_category line_category [line_category...]}"
-#~ "aus"
-#, fuzzy
-#~ msgid "Unable to build topology for <%s>"
-#~ msgstr "Kann den Stoppvektor <%s> nicht finden."
-#, fuzzy
-#~ msgid ""
-#~ "add;add a new category;del;delete category (-1 to delete all categories "
-#~ "of given layer);chlayer;change layer number (e.g. layer=3,1 changes layer "
-#~ "3 to layer 1);sum;add the value specified by cat option to the current "
-#~ "category value;transfer;copy values from one layer to another (e.g. "
-#~ "layer=1,2,3 copies values from layer 1 to layer 2 and 3);report;print "
-#~ "report (statistics), in shell style: layer type count min max;print;print "
-#~ "category values, more cats in the same layer are separated by '/'"
-#~ msgstr ""
-#~ "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines "
-#~ "gegebenen Layers;chlayer;Ãndere die Layer-Nummer (z.B. layer=3,1 ändert "
-#~ "von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option "
-#~ "'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht "
-#~ "(Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe "
-#~ "Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
-#, fuzzy
-#~ msgid "Name of input OGR layer"
-#~ msgstr "Name der Eingabekarte."
-#, fuzzy
-#~ msgid ""
-#~ "List available OGR layers including feature types in datatsource and exit"
-#, fuzzy
-#~ msgid "Supported OGR formats for reading:"
-#~ msgstr "Zeige unterstützte Formate an und SchluÃ."
-#, fuzzy
-#~ msgid "Do not build topology for output vector"
-#~ msgstr "Erzeugt keine Topologie für die Ausgabe Vektorkarte."
-#, fuzzy
-#~ msgid "Supported Formats:"
-#~ msgstr "Unterstützte Formate:\n"
-#, fuzzy
-#~ msgid "Unable to open OGR file"
-#~ msgstr "Kann kein Face erzeugen."
-#, fuzzy
-#~ msgid "dsn: %s\n"
-#~ msgstr "Maske: %s\n"
-#, fuzzy
-#~ msgid "not set (default 'ogr')"
-#~ msgstr "Zu selektierende Kanäle (Standard: alle)."
-#, fuzzy
-#~ msgid "format: %s\n"
-#~ msgstr "Format"
-#, fuzzy
-#~ msgid "not set (default ESRI_Shapefile)"
-#, fuzzy
-#~ msgid "<none>"
-#~ msgstr "Fertig."
-#, fuzzy
-#~ msgid "Unable to create OGR file"
-#, fuzzy
-#~ msgid "Error writing OGR file"
-#~ msgstr "Fehler beim Schreiben der PGM-Datei."
-#~ msgid "Error trying to read dbmscap file\n"
-#~ msgstr "Fehler beim Lesen der Datei dbmscap\n"
-#, fuzzy
-#~ msgid ""
-#~ "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be "
-#~ "converted"
-#~ msgstr ""
-#~ "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht "
-#~ "konvertiert."
-#, fuzzy
-#~ msgid "Name of file with SQL select statement(s)"
-#~ msgstr "Name der Datei, die SQL-Befehle enthält"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open file <%s> for reading.\n"
-#~ "Details: %s"
-#~ msgstr "Kann die Datei [%s] nicht zum Lesen öffnen."
-#, fuzzy
-#~ msgid "'-' to read from standard input"
-#~ msgstr "Wenn '-' angegeben wird von Standardeingabe gelesen."
-#, fuzzy
-#~ msgid "dataset"
-#~ msgstr "Datenbank, SQL"
-#, fuzzy
-#~ msgid "spacetime"
-#~ msgstr "Platzierung"
-#, fuzzy
-#~ msgid "Name of a space time vector dataset"
-#~ msgstr "Name der Expositions-Rasterkarte."
-#, fuzzy
-#~ msgid "absolute"
-#~ msgstr "south=%f"
-#, fuzzy
-#~ msgid "Name(s) of existing raster, raster3d or vector map(s)"
-#~ msgstr "Name existierender Rasterkarte(n)"
-#, fuzzy
-#~ msgid "Input map type"
-#~ msgstr "Eingabekarte"
-#, fuzzy
-#~ msgid ""
-#~ "Type of the space time dataset, default is space time raster dataset "
-#~ "(strds)"
-#~ msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
-#, fuzzy
-#~ msgid ""
-#~ "Unregister vector map(s) from a specific or from all space time vector "
-#~ "dataset in which it is registered"
-#~ msgstr "Liste die Vektorkarten der Eingabe-Location und beendet sich."
-#, fuzzy
-#~ msgid "spacetime vector dataset"
-#~ msgstr "Aktualisiere die Metadaten einer Vektorkarte"
-#, fuzzy
-#~ msgid "Name(s) of existing vector map(s) to unregister"
-#~ msgstr "Name einer existierenden Vektorkarte."
-#, fuzzy
-#~ msgid "spacetime raster dataset"
-#~ msgstr "Aktualisiere die Statistik der Rasterkarte."
-#, fuzzy
-#~ msgid "Name of a space time raster dataset"
-#, fuzzy
-#~ msgid "verride projection (use location's projection)"
-#~ msgstr "Ãbersteuere die Projektion (verwende Projektion der Location)."
-#, fuzzy
-#~ msgid "Name of the new space time dataset"
-#~ msgstr "Name der neuen Datenbank."
-#, fuzzy
-#~ msgid ""
-#~ "Uploads raster map values at spatial and temporal positions of vector "
-#~ "points to the tables. The maps are registered in space time datasets"
-#~ msgstr ""
-#~ "Ãbernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
-#~ "Attributtabelle."
-#, fuzzy
-#~ msgid "space time vector dataset"
-#, fuzzy
-#~ msgid "space time raster dataset"
-#, fuzzy
-#~ msgid "The space time raster dataset to use"
-#, fuzzy
-#~ msgid "Name of an existing space time vector dataset"
-#, fuzzy
-#~ msgid "Name(s) of existing vector map(s)"
-#, fuzzy
-#~ msgid "The unit of the relative time"
-#~ msgstr "Höhe des Flussbetts [m]."
-#, fuzzy
-#~ msgid "spacetime raster3d dataset"
-#, fuzzy
-#~ msgid "Name of an existing space time raster3d dataset"
-#, fuzzy
-#~ msgid "Name(s) of existing raster3d map(s)"
-#, fuzzy
-#~ msgid "edit"
-#~ msgstr "Einstellungen"
-#, fuzzy
-#~ msgid "Name(s) of existing raster map(s) to unregister"
-#~ msgstr "Rasterkarte(n) zum abfragen."
-#, fuzzy
-#~ msgid "Name of an existing space time raster dataset"
-#, fuzzy
-#~ msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
-#~ msgstr "Verzeichnis um heruntergeladene Daten zu speichern."
-#, fuzzy
-#~ msgid "Name(s) of existing raster map(s)"
-#, fuzzy
-#~ msgid "sample"
-#~ msgstr "Raster, Resamplen"
-#, fuzzy
-#~ msgid "Name of a space time dataset"
-#, fuzzy
-#~ msgid "The method to be used for sampling"
-#~ msgstr "Text für den Kartentitel."
-#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2"
-#~ msgstr "Name der Eingabe-Rasterkarte (NIR: tm4 | qbird_nir | spot2)."
-#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3"
-#~ msgstr "Name der Eingabe-Rasterkarte (MIR; tm5 | qbird_red | spot3)."
-#, fuzzy
-#~ msgid "Name of a space time raster3d dataset"
-#, fuzzy
-#~ msgid "Name of the output space time raster3d dataset"
-#, fuzzy
-#~ msgid "Name of the space time dataset"
#~ msgid "Name of input 3D raster map"
#~ msgstr "Name der Eingabe-3D-Rasterkarte"
@@ -40331,18 +37500,11 @@
#~ msgid "Print 3D raster history instead of info"
#~ msgstr "Gebe 3D Rasterhistorie anstelle der Info aus."
-#~ msgid ""
-#~ "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr ""
-#~ "Gebe nur den Zeitstempel der 3D-Rasterkarte aus (Tag.Monat.Jahr Stunde:"
-#~ "Minute:Sekunde)"
+#~ msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
+#~ msgstr "Gebe nur den Zeitstempel der 3D-Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
-#~ msgid ""
-#~ "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East "
-#~ "edge"
-#~ msgstr ""
-#~ "nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;"
-#~ "Süd-Ost-Begrenzung"
+#~ msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+#~ msgstr "nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;Süd-Ost-Begrenzung"
#~ msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
#~ msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d."
@@ -40350,35 +37512,20 @@
#~ msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
#~ msgstr "Inkonsistente Attributanzahl (<%s> %d: <%s> %d."
-#~ msgid ""
-#~ "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-#~ "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-#~ "forward coordinates difference (destination);rxy;reverse coordinates "
-#~ "difference (source);fd;forward error (destination);rd;reverse error "
-#~ "(source)"
-#~ msgstr ""
-#~ "idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-"
-#~ "Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-"
-#~ "Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);"
-#~ "fd;Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
+#~ msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
+#~ msgstr "idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
#~ msgid "Require exact range"
#~ msgstr "Erfordert den exakten Wertebereich."
-#~ msgid ""
-#~ "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;"
-#~ "percent cover"
-#~ msgstr ""
-#~ "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
+#~ msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+#~ msgstr "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
#~ msgid "Lake depth from %f to %f"
#~ msgstr "Seetiefe von %f bis %f"
-#~ msgid ""
-#~ "ASCII raster file to be imported. If not given reads from standard input"
-#~ msgstr ""
-#~ "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird "
-#~ "von der Standardeingabe gelesen."
+#~ msgid "ASCII raster file to be imported. If not given reads from standard input"
+#~ msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird von der Standardeingabe gelesen."
#~ msgid "Integer values are imported"
#~ msgstr "Integer-Werte wurden importiert."
@@ -40392,12 +37539,8 @@
#~ msgid "Base name for output raster maps"
#~ msgstr "Basisname der Ausgabe-Rasterkarten."
-#~ msgid ""
-#~ "The mapping instruction <%s> will be renamed to <%s> in future versions "
-#~ "of GRASS. Please use <%s> instead."
-#~ msgstr ""
-#~ "Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen "
-#~ "Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
+#~ msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
+#~ msgstr "Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
#~ msgid "rows: %d"
#~ msgstr "Zeilen: %d"
@@ -40408,192 +37551,77 @@
#~ msgid "Aborting."
#~ msgstr "Breche ab."
-#~ msgid ""
-#~ "int;simple intervals;std;standard deviations;qua;quantiles;equ;"
-#~ "equiprobable (normal distribution);"
-#~ msgstr ""
-#~ "int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;"
-#~ "gleichwahrscheinlich(Normalverteilung);"
+#~ msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
+#~ msgstr "int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;gleichwahrscheinlich(Normalverteilung);"
#~ msgid "Unable to open vector map <%s@%s>"
#~ msgstr "Kann die Vektorkarte <%s@%s> nicht öffnen."
#~ msgid "Name(s) of existing mapset(s) to add to search path"
-#~ msgstr ""
-#~ "Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden "
-#~ "sollen."
+#~ msgstr "Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
-#~ msgid ""
-#~ "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-#~ "(only for atype=area);not;features from ainput not overlayed by features "
-#~ "from binput;xor;features from either ainput or binput but not those from "
-#~ "ainput overlayed by binput (only for atype=area)"
-#~ msgstr ""
-#~ "and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS "
-#~ "bekannt (nur für atype=area);not;Feature von ainput nicht überlagert von "
-#~ "Featuren von binput;xor;Feature von ainput oder binput, aber nicht solche "
-#~ "von ainput die von binput überlagert werden(nur für atype=area)"
+#~ msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+#~ msgstr "and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS bekannt (nur für atype=area);not;Feature von ainput nicht überlagert von Featuren von binput;xor;Feature von ainput oder binput, aber nicht solche von ainput die von binput überlagert werden(nur für atype=area)"
-#~ msgid ""
-#~ "point;import area centroids as points;line;import area boundaries as "
-#~ "lines;boundary;import lines as area boundaries;centroid;import points as "
-#~ "centroids"
-#~ msgstr ""
-#~ "point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;"
-#~ "boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als "
-#~ "Zentroide"
+#~ msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
+#~ msgstr "point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als Zentroide"
-#~ msgid ""
-#~ "left;Parallel line is on the left;right;Parallel line is on the right;"
-#~ "both;Parallel lines on both sides"
-#~ msgstr ""
-#~ "left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;"
-#~ "Parallele Linien auf beiden Seiten"
+#~ msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
+#~ msgstr "left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;Parallele Linien auf beiden Seiten"
-#~ msgid ""
-#~ "build;build topology;dump;write topology to stdout;sdump;write spatial "
-#~ "index to stdout;cdump;write category index to stdout"
-#~ msgstr ""
-#~ "build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;"
-#~ "Schreibe den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-"
-#~ "Index nach stdout"
+#~ msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
+#~ msgstr "build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;Schreibe den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-Index nach stdout"
-#~ msgid ""
-#~ "length;Select only lines or boundaries shorter/longer than threshold "
-#~ "distance;dangle;Select dangles shorter/longer than threshold distance"
-#~ msgstr ""
-#~ "length; Selektiere nur Linien oder Grenzen kürzer/länger als der "
-#~ "Schwellwert; dangle; Selektiere Ãberstände (dangles) kürzer/länger als "
-#~ "der Schwellwert"
+#~ msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
+#~ msgstr "length; Selektiere nur Linien oder Grenzen kürzer/länger als der Schwellwert; dangle; Selektiere Ãberstände (dangles) kürzer/länger als der Schwellwert"
-#~ msgid ""
-#~ "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also "
-#~ "to vertex"
-#~ msgstr ""
-#~ "no; Kein Snapping; node; Snap nur auf Nodes; vertex; Erlaube auch ein "
-#~ "Snap auf Vertices"
+#~ msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
+#~ msgstr "no; Kein Snapping; node; Snap nur auf Nodes; vertex; Erlaube auch ein Snap auf Vertices"
#~ msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
#~ msgstr "point;einfache x,y[,z] Liste;standard;GRASS Vektor-ASCII-Format"
-#~ msgid ""
-#~ "cat;category of the nearest feature;dist;minimum distance to nearest "
-#~ "feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y "
-#~ "coordinate of the nearest point on the 'to' feature;to_along;distance to "
-#~ "the nearest point on the 'to' feature along that linear feature;to_angle;"
-#~ "angle along the nearest linear feature in the 'to' map, measured CCW from "
-#~ "the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute "
-#~ "of nearest feature given by to_column option"
-#~ msgstr ""
-#~ "cat;Kategorie des nächsten Features;dist;Minimumdistanz zum nächsten "
-#~ "Feature;to_x;X Koordinate des nächsten Punkts des 'to'-Features;to_y;Y "
-#~ "Koordinate des nächsten Punktes des 'to'-Feature;to_along;Distanz zum "
-#~ "nächsten Punkt des 'to'-Features entlang des linearen Features;to_angle;"
-#~ "Winkel entlang des nächsten linearen Features der 'to'-Karte, gemessen "
-#~ "gegen den Uhrzeigersinn von der positiven X-Achse im Bogenmaà (zwischen -"
-#~ "Pi und Pi);to_attr;Attribut des nächsten Features gegeben durch die "
-#~ "Option to_column"
+#~ msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
+#~ msgstr "cat;Kategorie des nächsten Features;dist;Minimumdistanz zum nächsten Feature;to_x;X Koordinate des nächsten Punkts des 'to'-Features;to_y;Y Koordinate des nächsten Punktes des 'to'-Feature;to_along;Distanz zum nächsten Punkt des 'to'-Features entlang des linearen Features;to_angle;Winkel entlang des nächsten linearen Features der 'to'-Karte, gemessen gegen den Uhrzeigersinn von der positiven X-Achse im Bogenmaà (zwischen -Pi und Pi);to_attr;Attribut des nächsten Features gegeben durch die Option to_column"
#~ msgid "bridge;Finds bridges;articulation;Finds articulation points;"
#~ msgstr "bridge;Findet Brücken;articulation;Findet Artikulationspunkte;"
-#~ msgid ""
-#~ "no;Do not assign any category number to polyline;first;Assign category "
-#~ "number of first line to polyline;multi;Assign multiple category numbers "
-#~ "to polyline"
-#~ msgstr ""
-#~ "no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die "
-#~ "Kategorie der ersten Linie zu;multi;Weise der Polylinie mehrere "
-#~ "Kategorien zu"
+#~ msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
+#~ msgstr "no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die Kategorie der ersten Linie zu;multi;Weise der Polylinie mehrere Kategorien zu"
#~ msgid "Neither %s nor %s was given"
#~ msgstr "Weder %s noch %s wurde angegeben"
-#~ msgid ""
-#~ "The bufcol option may contain bugs during the cleaning step. If you "
-#~ "encounter problems, use the debug option or clean manually with v.clean "
-#~ "tool=break; v.category step=0; v.extract -d type=area"
-#~ msgstr ""
-#~ "Die Option 'bufcol' kann Fehler enthalten während des "
-#~ "Säuberungsschrittes. Wenn Sie auf Probleme stoÃen, verwenden Sie die die "
-#~ "Option 'debug' oder säubern Sie manuell mit v.clean tool=break; v."
-#~ "category step=0; v.extract -d type=area."
+#~ msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
+#~ msgstr "Die Option 'bufcol' kann Fehler enthalten während des Säuberungsschrittes. Wenn Sie auf Probleme stoÃen, verwenden Sie die die Option 'debug' oder säubern Sie manuell mit v.clean tool=break; v.category step=0; v.extract -d type=area."
#~ msgid "Name of table containing transformation parameters"
#~ msgstr "Name der Tabelle mit den Transformationsparametern"
-#~ msgid ""
-#~ "Name of table and name for output vector map must be different. Otherwise "
-#~ "the table is overwritten."
-#~ msgstr ""
-#~ "Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich "
-#~ "sein. Sonst wird die Tabelle überschrieben."
+#~ msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
+#~ msgstr "Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich sein. Sonst wird die Tabelle überschrieben."
-#~ msgid ""
-#~ "overlap;features partially or completely overlap;equals;features are "
-#~ "spatially equals (using GEOS);disjoint;features do not spatially "
-#~ "intersect (using GEOS);intersects;features spatially intersect (using "
-#~ "GEOS);touches;features spatially touches (using GEOS);crosses;features "
-#~ "spatially crosses (using GEOS);within;feature A is completely inside "
-#~ "feature B (using GEOS);contains;feature B is completely inside feature A "
-#~ "(using GEOS);overlaps;features spatially overlap (using GEOS);relate;"
-#~ "feature A is spatially related to feature B (using GEOS, requires "
-#~ "'relate' option);"
-#~ msgstr ""
-#~ "overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind "
-#~ "im Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich "
-#~ "nicht (mit GEOS);intersects;Objekte überschneiden sich räumlich (mit "
-#~ "GEOS);touches;Objekte berühren sich räumlich (mit GEOS);crosses;Objekte "
-#~ "kreuzen sich räumlich (mit GEOS);within;Objekt A ist komplett innerhalb "
-#~ "von Objekt B (mit GEOS);contains;Objekt B ist komplett innerhalb von "
-#~ "Objekt A (mit GEOS);overlaps;Objekte überlappen sich räumlich (mit GEOS);"
-#~ "relate;Objekt A besitzt einen räumlichen Bezug zu Objekt B (mit GEOS, "
-#~ "Option 'relate' erforderlich);"
+#~ msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
+#~ msgstr "overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind im Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich nicht (mit GEOS);intersects;Objekte überschneiden sich räumlich (mit GEOS);touches;Objekte berühren sich räumlich (mit GEOS);crosses;Objekte kreuzen sich räumlich (mit GEOS);within;Objekt A ist komplett innerhalb von Objekt B (mit GEOS);contains;Objekt B ist komplett innerhalb von Objekt A (mit GEOS);overlaps;Objekte überlappen sich räumlich (mit GEOS);relate;Objekt A besitzt einen räumlichen Bezug zu Objekt B (mit GEOS, Option 'relate' erforderlich);"
#~ msgid "Add points on nodes without points"
#~ msgstr "Füge Punkte an punktlose Knoten hinzu"
-#~ msgid ""
-#~ "weak;Weakly connected components;strong;Strongly connected components;"
+#~ msgid "weak;Weakly connected components;strong;Strongly connected components;"
#~ msgstr "weak;Schwach verbundene Elemente;strong;Stark verbundene Elemente;"
#~ msgid "Do not create attribute tables"
#~ msgstr "Erzeuge keine Attributtabellen."
-#~ msgid ""
-#~ "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-#~ "Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-#~ "reduction;Vertex Reduction Algorithm eliminates points close to each "
-#~ "other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking "
-#~ "Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;"
-#~ "distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;"
-#~ "Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;"
-#~ "Snakes method for line smoothing;network;Network generalization;"
-#~ "displacement;Displacement of lines close to each other;"
-#~ msgstr ""
-#~ "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker "
-#~ "Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;"
-#~ "reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht "
-#~ "beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's "
-#~ "vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender "
-#~ "Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-"
-#~ "Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit "
-#~ "kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;"
-#~ "network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die "
-#~ "dicht beieinander liegen;"
+#~ msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+#~ msgstr "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die dicht beieinander liegen;"
#~ msgid "Copy attributes"
#~ msgstr "Kopiere Attribute"
-#~ msgid ""
-#~ "attr;read values from attribute table;cat;use category values;val;use "
-#~ "value specified by value option;z;use z coordinate (points or contours "
-#~ "only);dir;output as flow direction (lines only)"
-#~ msgstr ""
-#~ "attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;"
-#~ "Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-"
-#~ "Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur "
-#~ "Linien)"
+#~ msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
+#~ msgstr "attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur Linien)"
#~ msgid "For example: 'select * from rybniky where kapri = 'hodne'"
#~ msgstr "Beispiel: 'select * from wald where baum = 'Buche'"
@@ -40649,12 +37677,8 @@
#~ msgid "Verbose module output"
#~ msgstr "Gesprächige Modulausgabe"
-#~ msgid ""
-#~ "The '-v' flag is superseded and will be removed in future. Please use '--"
-#~ "verbose' instead."
-#~ msgstr ""
-#~ "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden "
-#~ "Sie stattdessen '--verbose'."
+#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+#~ msgstr "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden Sie stattdessen '--verbose'."
#~ msgid "Entering script mode ..."
#~ msgstr "Betrete den Skriptmodus ..."
@@ -40692,12 +37716,8 @@
#~ msgid "raster3d, voxel, import"
#~ msgstr "3D-Raster, Voxel, Import"
-#~ msgid ""
-#~ "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and "
-#~ "1 time step)."
-#~ msgstr ""
-#~ "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen "
-#~ "und 1 Zeitschritt)."
+#~ msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+#~ msgstr "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen und 1 Zeitschritt)."
#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
#~ msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
@@ -40714,12 +37734,8 @@
#~ msgid "Recharge raster map in m^3/s"
#~ msgstr "Grundwasserneubildungskarte in m^3/s"
-#~ msgid ""
-#~ "The piezometric head result of the numerical calculation will be written "
-#~ "to this map"
-#~ msgstr ""
-#~ "Das resultierende piezometrisches Niveau der numerischen Berechnung wird "
-#~ "in diese Karte geschrieben."
+#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
+#~ msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
#~ msgid ""
#~ "Calculate the groundwater distance velocity vector field \n"
@@ -40730,25 +37746,17 @@
#~ "schreibe die X, Y und Z Komponenten in die Karten name_[xyz].\n"
#~ "Name ist der gemeinsame Bestandteil der neuen 3D-Rasterkarten."
-#~ msgid ""
-#~ "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr ""
-#~ "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative "
-#~ "Lösungsverfahren verfügbar."
+#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
+#~ msgstr "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative Lösungsverfahren verfügbar."
#~ msgid "raster3d, voxel"
#~ msgstr "3D-Raster, Voxel"
-#~ msgid ""
-#~ "Calculates numerically transient, confined groundwater flow in three "
-#~ "dimensions."
-#~ msgstr ""
-#~ "Berechnet transienten, beschränkten Grundwasserflusses in drei "
-#~ "Dimensionen."
+#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
+#~ msgstr "Berechnet transienten, beschränkten Grundwasserflusses in drei Dimensionen."
#~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#~ msgstr ""
-#~ "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
#~ msgid "raster3d, voxel, export"
#~ msgstr "3D-Raster, Voxel, Export"
@@ -40770,15 +37778,10 @@
#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
#~ msgstr ""
#~ "Kann keine Maskendatei erzeugen: G3D_MASK existiert bereits.\n"
-#~ "Verwenden Sie 'g.remove rast3d=G3D_MASK', um die existierende Maske zu "
-#~ "löschen."
+#~ "Verwenden Sie 'g.remove rast3d=G3D_MASK', um die existierende Maske zu löschen."
-#~ msgid ""
-#~ "Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-#~ "independent of the current region settings"
-#~ msgstr ""
-#~ "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-"
-#~ "Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
+#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+#~ msgstr "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
#~ msgid "Unable to write raster row"
#~ msgstr "Kann die Rasterzeile nicht schreiben."
@@ -40790,18 +37793,13 @@
#~ msgstr "Ungültiger Ausgabedateiname."
#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr ""
-#~ "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+#~ msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
#~ msgid "Unable to get elevation raster row"
#~ msgstr "Kann Zeile der Höhenrasterkarte nicht bekommen."
-#~ msgid ""
-#~ "Creates cross section 2D raster map from 3D raster map based on 2D "
-#~ "elevation map."
-#~ msgstr ""
-#~ "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
-#~ "Rasterkarte basierend auf 2D-Höhenkarte."
+#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+#~ msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
#~ msgid "Elevation map not found"
#~ msgstr "Höhenkarte nicht gefunden."
@@ -40813,8 +37811,7 @@
#~ msgstr "Kann die Höhenkarte nicht schlieÃen."
#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr ""
-#~ "Falscher Datentyp der 3D-Rasterkarte! Kann die Rasterkarte nicht erzeugen."
+#~ msgstr "Falscher Datentyp der 3D-Rasterkarte! Kann die Rasterkarte nicht erzeugen."
#~ msgid "Unable to close input raster map"
#~ msgstr "Kann die Eingabe-Rasterkarte nicht schlieÃen."
@@ -40826,9 +37823,7 @@
#~ msgstr "Kann die unterste Rasterzeile nicht lesen.\n"
#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr ""
-#~ "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 "
-#~ "liegen!\n"
+#~ msgstr "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 liegen!\n"
#~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
#~ msgstr "G3D Karte(n), die in das VTK-ASCII-Format konvertiert werden sollen"
@@ -40836,12 +37831,8 @@
#~ msgid "Could not open map %s"
#~ msgstr "Kann die Karte %s nicht öffnen."
-#~ msgid ""
-#~ "No 3D raster data, RGB or xyz-vector maps are provided. Will only write "
-#~ "the geometry"
-#~ msgstr ""
-#~ "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die "
-#~ "Geometrien schreiben."
+#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+#~ msgstr "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
#~ msgid "No RGB Data will be created"
#~ msgstr "RGB-Daten werden nicht erzeugt."
@@ -40855,11 +37846,8 @@
#~ msgid "Unable to close bottom raster map"
#~ msgstr "Kann die untere Rasterkarte nicht schlieÃen."
-#~ msgid ""
-#~ "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr ""
-#~ "Konvertiert eine 3D ASCII Raster Textdatei in eine (binäre) 3D-"
-#~ "Rasterkarte. "
+#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+#~ msgstr "Konvertiert eine 3D ASCII Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
#~ msgid "raster3d, voxel, statistics"
#~ msgstr "3D-Raster, Voxel, Statistik"
@@ -40903,17 +37891,11 @@
#~ msgid "Bilinear interpolation utility for raster map layers."
#~ msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und "
-#~ "Breitengrad-Gittern zugewiesen wird."
+#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+#~ msgstr "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und Breitengrad-Gittern zugewiesen wird."
#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr ""
-#~ "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp."
-#~ "interp'."
+#~ msgstr "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp.interp'."
#~ msgid "raster, statistics"
#~ msgstr "Raster, Statistik"
@@ -40963,18 +37945,13 @@
#~ msgstr "Raster, Sonnenenergie"
#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr ""
-#~ "Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' "
-#~ "Sonneneinstrahlung [-]."
+#~ msgstr "Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' Sonneneinstrahlung [-]."
#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr ""
-#~ "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' "
+#~ msgstr "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' Sonneneinstrahlung [-]."
#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr ""
-#~ "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
+#~ msgstr "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
#~ msgid "Unused"
#~ msgstr "Nicht genutzt"
@@ -41005,40 +37982,22 @@
#~ msgid ""
#~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
#~ "\n"
#~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
#~ "\n"
#~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
-#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
-#~ "map]"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
#~ msgstr ""
#~ "VERWENDUNG für Einzugsgebietskartierung:\n"
#~ "\n"
#~ "VERWENDUNG für ARMSED-Datei Erzeugung:\n"
#~ "\n"
#~ "VERWENDUNG für Hanglängenberechnung:\n"
-#~ "map]"
#~ msgid "unable to open new accum map layer."
#~ msgstr "Kann neue accum-Karte nicht öffnen."
@@ -41058,11 +38017,8 @@
#~ msgid "unable to open new S factor map layer."
#~ msgstr "Kann neue S-Faktor Karte nicht öffnen."
-#~ msgid ""
-#~ "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr ""
-#~ "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
-#~ "Standardwert 300 MB."
+#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+#~ msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
#~ msgid "unable to open flow accumulation map layer"
#~ msgstr "Kann neue Fluss-Akkumulations-Karte nicht öffnen."
@@ -41077,9 +38033,7 @@
#~ msgstr "Modul zur Analyse von Wassereinzugsgebieten."
#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr ""
-#~ "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten "
-#~ "Analyse ist."
+#~ msgstr "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten Analyse ist."
#~ msgid "Input map: locations of real depressions"
#~ msgstr "Eingabekarte mit Orten realer Senken im Gebiet."
@@ -41088,12 +38042,10 @@
#~ msgstr "Eingabekarte mit der GröÃe des Oberflächenabfluss pro Zelle."
#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr ""
-#~ "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
+#~ msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr ""
-#~ "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+#~ msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
#~ msgid "Output map: number of cells that drain through each cell"
#~ msgstr "Ausgabekarte mit Anzahl der Zellen, die durch jede Zelle abflieÃt."
@@ -41111,8 +38063,7 @@
#~ msgstr "Ausgabekarte mit Einzugsgebietshälften mit eindeutigen Wert."
#~ msgid "Output map: useful for visual display of results"
-#~ msgstr ""
-#~ "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
+#~ msgstr "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
#~ msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
@@ -41188,14 +38139,10 @@
#~ msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr ""
-#~ "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht "
-#~ "editieren! Führen Sie support für [%s] aus."
+#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht editieren! Führen Sie support für [%s] aus."
#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr ""
-#~ "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header "
-#~ "nicht editieren!"
+#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht editieren!"
#~ msgid "Cannot open raster map [%s]!"
#~ msgstr "Kann die Rasterkarte [%s] nicht öffnen!"
@@ -41234,9 +38181,7 @@
#~ msgstr "Die Datei scheint komprimiert zu sein.\n"
#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr ""
-#~ "Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich "
-#~ "möchte, dass Sie entscheiden.\n"
+#~ msgstr "Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
#~ msgid "The header for [%s] says the file is compressed. "
#~ msgstr "Der Header von [%s] sagt, dass die Datei komprimiert ist."
@@ -41244,12 +38189,8 @@
#~ msgid "The file does NOT appear to be compressed.\n"
#~ msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
-#~ msgid ""
-#~ "Header indicates %d row%s in the raster map, but the actual file format "
-#~ "indicates %d row%s"
-#~ msgstr ""
-#~ "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber "
-#~ "die aktuelle Datei hat %d Zeile%s."
+#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+#~ msgstr "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die aktuelle Datei hat %d Zeile%s."
#~ msgid "Unable to write header for [%s]."
#~ msgstr "Kann den Header für [%s] nicht schreiben."
@@ -41273,9 +38214,7 @@
#~ msgstr " FlieÃkomma-Karte"
#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr ""
-#~ "Zeilen * Spalten * Bytes* pro Zelle musse genauso groà sein wie die Datei "
-#~ "(%lu)."
+#~ msgstr "Zeilen * Spalten * Bytes* pro Zelle musse genauso groà sein wie die Datei (%lu)."
#~ msgid "If you need help figuring them out, just hit ESC"
#~ msgstr "Für Hilfe beim Herausfinden bitte ESC drücken."
@@ -41306,8 +38245,7 @@
#~ "Drücken Sie RETURN um fortzufahren -->"
#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr ""
-#~ "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+#~ msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
#~ msgid "raster, metadata"
#~ msgstr "Raster, Metadaten"
@@ -41350,12 +38288,10 @@
#~ msgid ""
#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
+#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
#~ msgstr ""
#~ "\n"
-#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen "
-#~ "mit NULL-Werten als gültige Daten angesehen werden?"
+#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen mit NULL-Werten als gültige Daten angesehen werden?"
#~ msgid "Error writing null row [%d]."
#~ msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
@@ -41391,9 +38327,7 @@
#~ msgstr "(o/i) Höhenkarte des Einzugsgebiets (mit angewandter Maske (MASK))."
#~ msgid "(o) Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr ""
-#~ "(o) Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske "
-#~ "(MASK))."
+#~ msgstr "(o) Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske (MASK))."
#~ msgid "(i) Number of topographic index classes"
#~ msgstr "(i) Anzahl der Klassen des Topgraphischen Indexes."
@@ -41417,19 +38351,13 @@
#~ msgstr "(i) OPTIONAL: Ausgabe für einen angegebenen Zeitabschnitt."
#~ msgid "(i) OPTIONAL Output for given topographic index class"
-#~ msgstr ""
-#~ "(i) OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen "
-#~ "Index."
+#~ msgstr "(i) OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen Index."
#~ msgid "Run quietly"
#~ msgstr "Arbeite schweigsam."
-#~ msgid ""
-#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
-#~ "quiet' instead."
-#~ msgstr ""
-#~ "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-#~ "ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
#~ msgid "raster, distance"
#~ msgstr "Raster, Distanz"
@@ -41460,8 +38388,7 @@
#~ msgstr "Raster, Quantisierung"
#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr ""
-#~ "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
+#~ msgstr "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
#~ msgid "Quant table not changed for %s"
#~ msgstr "Quantisierungstabelle für <%s> wurde nicht geändert."
@@ -41515,16 +38442,13 @@
#~ msgstr "RGB Rasterkarte <%s> nicht gefunden"
#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr ""
-#~ "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur "
-#~ "Verfügung [r,g,b]"
+#~ msgstr "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur Verfügung [r,g,b]"
#~ msgid "Vector cell map <%s> not found"
#~ msgstr "Vektor-Zellen-Karte <%s> nicht gefunden."
#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr ""
-#~ "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
+#~ msgstr "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
#~ msgid "Converts raster maps into the VTK-Ascii format"
#~ msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
@@ -41557,9 +38481,7 @@
#~ msgstr "%s: Kann die temporäre Datei nicht öffnen."
#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr ""
-#~ "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' "
-#~ "gewählt wurde)."
+#~ msgstr "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' gewählt wurde)."
#~ msgid "Output map <%s> ignored"
@@ -41568,8 +38490,7 @@
#~ msgstr "Noch nicht implementiert."
#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr ""
-#~ "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
+#~ msgstr "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
#~ msgid "raster, rescale"
#~ msgstr "Raster, Rescale"
@@ -41671,13 +38592,10 @@
#~ msgstr "Kann keinen Speicher für Segment fbuff == NULL reservieren."
#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr ""
-#~ "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)"
+#~ msgstr "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)"
#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Fehler beim allozieren von Speicher während des Lesens der Startpunktes "
-#~ "der Rasterkarte %s."
+#~ msgstr "Fehler beim allozieren von Speicher während des Lesens der Startpunktes der Rasterkarte %s."
#~ msgid "End of map!"
#~ msgstr "Ende der Karte!"
@@ -41712,8 +38630,7 @@
#~ msgid "raster, querying"
#~ msgstr "Raster, Abfrage"
-#~ msgid ""
-#~ "Queries raster map layers on their category values and category labels."
+#~ msgid "Queries raster map layers on their category values and category labels."
#~ msgstr "Fragt Rasterkartenwerte und Kategorielabel ab."
#~ msgid "%s: can only do up to %d raster maps, sorry\n"
@@ -41725,13 +38642,8 @@
#~ msgid "Suppress single crossing error messages"
#~ msgstr "Unterdrücke Fehlermeldungen für 'single crossing'."
-#~ msgid ""
-#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
-#~ "Please use '--quiet' instead."
-#~ msgstr ""
-#~ "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der "
-#~ "kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen "
-#~ "'--quiet'."
+#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
#~ msgid "raster, series"
#~ msgstr "Raster, Serien"
@@ -41743,8 +38655,7 @@
#~ msgstr "Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
#~ msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-#~ msgstr ""
-#~ "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
+#~ msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
#~ msgid "No (quiet) description during run"
#~ msgstr "Keine Beschreibung während der Bearbeitung."
@@ -41771,9 +38682,7 @@
#~ msgstr "Raster, Volumen"
#~ msgid "No clump map specified and MASK not set."
-#~ msgstr ""
-#~ "Keine Klumpen-Karte angegeben. AuÃerdem ist die Maske (MASK) nicht "
-#~ "gesetzt."
+#~ msgstr "Keine Klumpen-Karte angegeben. AuÃerdem ist die Maske (MASK) nicht gesetzt."
#~ msgid "Unable to find data map"
#~ msgstr "Kann die Rasterkarte nicht finden."
@@ -41803,8 +38712,7 @@
#~ msgstr "Spezifischer Ertrag [1/m]."
#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr ""
-#~ "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
+#~ msgstr "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
#~ msgid "The map storing the numerical result [m]"
#~ msgstr "Karte der numerischen Ergebnisse [m]."
@@ -41832,13 +38740,10 @@
#~ msgstr "Sicker-Koeffizient der Drainage [1/s]."
#~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr ""
-#~ "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren "
-#~ "verfügbar."
+#~ msgstr "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren verfügbar."
#~ msgid "The direct cholesky solver do not work with sparse matrices"
-#~ msgstr ""
#~ msgid "Calculation of unconfined groundwater flow loop %i\n"
#~ msgstr "Berechnung der unbeschränkten Grundwasserfluss Schleife %i\n"
@@ -41852,12 +38757,8 @@
#~ msgid "Unable to read header of raster map <%s>"
#~ msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
-#~ msgid ""
-#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-#~ "map layer."
-#~ msgstr ""
-#~ "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
-#~ "GRASS Rasterkarte."
+#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+#~ msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
#~ msgid "ARC/INFO ASCII raster file (GRID) to be imported"
#~ msgstr "ARC/INFO ASCII Rasterdatei (GRID) zum Importieren."
@@ -41892,12 +38793,8 @@
#~ msgid "Apply filter only to zero data values"
#~ msgstr "Filter nur auf 0-Werte anwenden."
-#~ msgid ""
-#~ "quiet' instead"
-#~ msgstr ""
-#~ "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft "
-#~ "entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
+#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
+#~ msgstr "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
#~ msgid "Raster map matrix filter."
#~ msgstr "Rasterkarte mit Matrix-Filter"
@@ -41935,24 +38832,14 @@
#~ msgid "No raster map specified"
#~ msgstr "Keine Rasterkarte angegeben."
-#~ msgid ""
-#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
-#~ "be specified!"
-#~ msgstr ""
-#~ "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" "
-#~ "oder \"rules\" muss angegeben werden!"
+#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+#~ msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
-#~ msgid ""
-#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
-#~ "\" options"
-#~ msgstr ""
-#~ "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules"
-#~ "\" und \"raster\"."
+#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+#~ msgstr "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" und \"raster\"."
#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr ""
-#~ "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich "
-#~ "gegenseitig aus."
+#~ msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
#~ msgid "-g and -a flags are mutually exclusive"
#~ msgstr "-g und -a schlieÃen sich gegenseitig aus."
@@ -41969,10 +38856,8 @@
#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
#~ msgstr "Farbtabelle 'grey.eq' wird für FlieÃkomma-Karten nicht unterstützt."
-#~ msgid ""
-#~ "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr ""
-#~ "Farbtabelle 'grey.log' wird für FlieÃkomma-Karten nicht unterstützt."
+#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
+#~ msgstr "Farbtabelle 'grey.log' wird für FlieÃkomma-Karten nicht unterstützt."
#~ msgid "Color table for raster map <%s> set to '%s'"
#~ msgstr "Farbtabelle der Rasterkarte für <%s> ist auf '%s' gesetzt."
@@ -41996,24 +38881,16 @@
#~ msgstr "Ein einfacher Wert des Breitengrads [in Grad]."
#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr ""
-#~ "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung "
+#~ msgstr "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr ""
-#~ "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung "
+#~ msgstr "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
#~ msgid "time and insol_time are incompatible options"
#~ msgstr "time und insol_time sind nicht kompatible Optionen."
-#~ msgid ""
-#~ "Mode 1: instantaneous solar incidence angle & irradiance given a set "
-#~ "local time"
-#~ msgstr ""
-#~ "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
-#~ "bekannter lokaler Zeit"
+#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+#~ msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
#~ msgid "elevin raster map <%s> not found"
#~ msgstr "elevin Rasterkarte <%s> nicht gefunden."
@@ -42055,9 +38932,7 @@
#~ msgstr "Raster, Interpolation"
#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr ""
-#~ "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
-#~ "Höheninformationen."
+#~ msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
#~ msgid "Name of existing raster map containing contours"
#~ msgstr "Name der existierenden Rasterkarte, die Konturlinien enthält."
@@ -42065,18 +38940,11 @@
#~ msgid "Output elevation raster map"
#~ msgstr "Name der Ausgabe-Rasterkarte, die Höheninformationen enthält."
-#~ msgid ""
-#~ "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr ""
-#~ "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Diese Feature "
-#~ "wird in der Zukunft entfernt."
+#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
+#~ msgstr "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Diese Feature wird in der Zukunft entfernt."
-#~ msgid ""
-#~ "Invoke slow, but memory frugal operation (generally not needed, will be "
-#~ "removed in future)"
-#~ msgstr ""
-#~ "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht "
-#~ "benötigt, wird in Zukunft entfernt)."
+#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+#~ msgstr "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht benötigt, wird in Zukunft entfernt)."
#~ msgid "Illegal output file name <%s>"
#~ msgstr "Ungültiger Ausgabe-Dateiname<%s>."
@@ -42085,8 +38953,7 @@
#~ msgstr "Raster, Export, PNG"
#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr ""
-#~ "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
+#~ msgstr "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
#~ msgid "Unable to read raster map row %d"
#~ msgstr "Kann die Zeile %d der Rasterkarte nicht lesen."
@@ -42119,8 +38986,7 @@
#~ msgstr "Raster, Projektion, Transformation"
#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr ""
-#~ "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+#~ msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
#~ msgid "Resolution of output map"
#~ msgstr "Auflösung der Ausgabe-Karte"
@@ -42147,9 +39013,7 @@
#~ msgstr "Ausführliche Ausgabe."
#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr ""
-#~ "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen "
-#~ "anderen Namen."
+#~ msgstr "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen Namen."
#~ msgid "Name of raster map to contain results (several new layers)"
#~ msgstr "Name der Rasterkarten mit den Ergebnissen (mehrere Karten möglich)."
@@ -42164,8 +39028,7 @@
#~ msgstr "Kann den 3D Raster Wertebereich nicht laden."
#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr ""
-#~ "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+#~ msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
#~ msgid "Name for distance output map"
#~ msgstr "Name der Distanz-Ausgabekarte."
@@ -42212,22 +39075,14 @@
#~ msgid "Stream width (in meters). Default is raster cell width"
#~ msgstr "Flussbreite in Meter (Standard ist die Rasterzellenbreite)."
-#~ msgid ""
-#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-#~ "resolution of the currently defined region."
-#~ msgstr ""
-#~ "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die "
-#~ "Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
+#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+#~ msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
#~ msgid "Verbose mode"
#~ msgstr "Gesprächiger Modus"
-#~ msgid ""
-#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
-#~ "will be rounded to integer!"
-#~ msgstr ""
-#~ "Die Rasterkarte <%s> im Mapset <%s> ist eine FlieÃkommakarte. "
-#~ "Nachkommastellen werden auf ganze Zahlen gerundet!"
+#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+#~ msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine FlieÃkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
#~ msgid "raster, null data"
#~ msgstr "Raster, NULL-Werte"
@@ -42394,12 +39249,8 @@
#~ msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
#~ msgstr "CHILD[pid = %i]: kann %s Maske nicht öffnen ... mache ohne weiter !"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the currently defined region."
-#~ msgstr ""
-#~ "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der "
-#~ "Auflösung der aktuellen Region."
+#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+#~ msgstr "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der Auflösung der aktuellen Region."
#~ msgid "raster, random, cell"
#~ msgstr "Raster, Zufall, Zelle"
@@ -42437,28 +39288,17 @@
#~ msgid "Converts a raster map into a vector map layer."
#~ msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
-#~ msgid ""
-#~ "Write raster values as z coordinate. Table is not created. Currently "
-#~ "supported only for points."
-#~ msgstr ""
-#~ "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht "
-#~ "erzeugt. Derzeit werden nur Punkte unterstützt."
+#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
+#~ msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
-#~ msgid ""
-#~ "Do not build vector topology (use with care for massive point export)"
-#~ msgstr ""
-#~ "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
-#~ "extrem groÃen Punktmengen)."
+#~ msgid "Do not build vector topology (use with care for massive point export)"
+#~ msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem groÃen Punktmengen)."
#~ msgid "Quiet - Do not show progress"
#~ msgstr "Schweigsam - keinen Fortschritt anzeigen."
-#~ msgid ""
-#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-#~ "resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-"
-#~ "Auflösung der DERZEITIG EINGESTELLTEN REGION."
+#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
#~ msgid "Sums up the raster cell values."
#~ msgstr "Summierert die Rasterzellenwerte auf."
@@ -42475,12 +39315,8 @@
#~ msgid "Cannot read row"
#~ msgstr "Kann die Zeile nicht lesen."
-#~ msgid ""
-#~ "Finds the median of values in a cover map within areas assigned the same "
-#~ "category value in a user-specified base map."
-#~ msgstr ""
-#~ "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit "
-#~ "gleichen Werten in einer benutzerdefinierten Basiskarte."
+#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+#~ msgstr "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
#~ msgid "Name of base raster map"
#~ msgstr "Name der Basis-Rasterkarte."
@@ -42525,19 +39361,13 @@
#~ msgstr "Gebe nur den Titel der Rasterkarte aus."
#~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr ""
-#~ "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:"
-#~ "Sekunde)"
+#~ msgstr "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
#~ msgid "Cannot create category file of <%s>"
#~ msgstr "Kann die Kategorie-Datei von <%s> nicht erzeugen."
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation "
-#~ "der Kategorien einer existierenden Rasterkarte basieren."
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
#~ msgid "Raster map to be reclassified"
#~ msgstr "Rasterkarte, die neu klassifiziert werden soll."
@@ -42551,19 +39381,14 @@
#~ msgid "GIS Coincidence Tabulation Facility\n"
#~ msgstr "GIS Koinzidenz-Tabellierungsanlage\n"
-#~ msgid ""
-#~ "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr ""
-#~ "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu "
-#~ "vergleichen\n"
+#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
+#~ msgstr "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu vergleichen\n"
#~ msgid "The report can be made in one of 8 units."
#~ msgstr "DerBericht kann in einer von 8 Einheiten erstellt werden."
#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr ""
-#~ "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden "
-#~ "Buchstaben:"
+#~ msgstr "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
#~ msgid " 'c': cells"
#~ msgstr " 'c': Zellen"
@@ -42605,11 +39430,8 @@
#~ msgid "'%s' being saved\n"
#~ msgstr "'%s' wird gespeichert\n"
-#~ msgid ""
-#~ "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr ""
-#~ "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) "
-#~ "[n] "
+#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+#~ msgstr "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) [n] "
#~ msgid ""
#~ "Do you wish it printed in 80 or 132 columns?\n"
@@ -42618,18 +39440,11 @@
#~ "Möchten Sie die Ausgabe in 80 oder 132 Spalten?\n"
-#~ msgid ""
-#~ "Do you wish to run this report with a different unit of measure? (y/n) "
-#~ "[y] "
+#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
#~ msgstr "Möchten Sie diesen Bericht mit einer anderen MaÃeinheit? (y/n) [y] "
-#~ msgid ""
-#~ "Negative or no data pixel found. This module is not yet able to process "
-#~ "no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr ""
-#~ "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in "
-#~ "Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit "
-#~ "dem Modul r.fillnulls oder anderen Füllalgorithmen."
+#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
+#~ msgstr "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit dem Modul r.fillnulls oder anderen Füllalgorithmen."
#~ msgid "Too many iterations to required to find %s - giving up"
#~ msgstr "Zu viele Iterationen werden benötigt um %s zu finden - gebe auf."
@@ -42689,9 +39504,7 @@
#~ msgstr "Habe die KenngröÃe #%d <%s> berechnet (56 KenngröÃen verfügbar)."
#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr ""
-#~ "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS "
-#~ "Rasterkarte."
+#~ msgstr "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS Rasterkarte."
#~ msgid "Raster file to be imported"
#~ msgstr "Zu importierende Rasterdatei."
@@ -42745,8 +39558,7 @@
#~ msgstr "Ausgabe-Rasterkarte der Transportkapazität [kg/ms]."
#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr ""
-#~ "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+#~ msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
#~ msgid "Output sediment concentration raster map [particle/m3]"
#~ msgstr "Ausgabe-Rasterkarte der Sedimentkonzentration [Partikel/m3]"
@@ -42761,9 +39573,7 @@
#~ msgstr "Raster, Abfluss, Hydrologie"
#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr ""
-#~ "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/"
-#~ "hr]."
+#~ msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
#~ msgstr "Name der Rasterkarte der AbfluÃinfiltrationsrate [mm/hr]."
@@ -42780,37 +39590,23 @@
#~ msgid "Output simulation error raster map [m]"
#~ msgstr "Ausgabe-Rasterkarte des Simulationsfehlers [m]."
-#~ msgid ""
-#~ "Threshold water depth [m] (diffusion increases after this water depth is "
-#~ "reached)"
-#~ msgstr ""
-#~ "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese "
-#~ "Wassertiefe erreicht wurde)."
+#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
+#~ msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
#~ msgid "raster, thin"
#~ msgstr "Raster, Ausdünnung"
#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr ""
-#~ "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer "
-#~ "Rasterkarte abbilden."
+#~ msgstr "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
#~ msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %f "
-#~ "will be used to represent no-data values in the input map. You can "
-#~ "specify a nodata value with the %s option."
-#~ msgstr ""
-#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
-#~ "Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu "
-#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr ""
-#~ "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
-#~ "beachten, siehe auch den Schalter -l)."
+#~ msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
#~ msgid "File type"
#~ msgstr "Dateityp"
@@ -42827,14 +39623,8 @@
#~ msgid "Range to be exported: %f - %f"
#~ msgstr "Zu exportierender Wertebereich: %f - %f"
-#~ msgid ""
-#~ "Mismatch between metadata nodata value and actual nodata value in "
-#~ "exported raster: specified nodata value %f gets converted to %d by "
-#~ "selected GDAL datatype."
-#~ msgstr ""
-#~ "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
-#~ "Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von "
-#~ "dem gewählten GDAL-Datentyp nach %d konvertiert."
+#~ msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
+#~ msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von dem gewählten GDAL-Datentyp nach %d konvertiert."
#~ msgid "Failed writing output raster map row %d"
#~ msgstr "Schreiben der Zeile <%d> der Rasterkarte fehlgeschlagen."
@@ -42842,8 +39632,7 @@
#~ msgid "Name of terrain raster map (DEM)"
#~ msgstr "Name der Terrain Rasterkarte (DEM)."
-#~ msgid ""
-#~ "Name of raster map with given starting point(s) (at least 1 cell > 0)"
+#~ msgid "Name of raster map with given starting point(s) (at least 1 cell > 0)"
#~ msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
#~ msgid "Can't create raster map <%s>"
@@ -42853,26 +39642,19 @@
#~ msgstr "Raster, Import, Konvertierung"
#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr ""
-#~ "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
+#~ msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
#~ msgid "raster, export, VRML"
#~ msgstr "Raster, Export, VRML"
#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr ""
-#~ "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language "
-#~ "(VRML)."
+#~ msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
#~ msgid "raster, DEM, fractal"
#~ msgstr "Raster, DGM, Fraktale"
-#~ msgid ""
-#~ "Finds the average of values in a cover map within areas assigned the same "
-#~ msgstr ""
-#~ "Findet den Durchschnitt der Werte in einer Ãberlagerungskarte innerhalb "
-#~ "gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
+#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+#~ msgstr "Findet den Durchschnitt der Werte in einer Ãberlagerungskarte innerhalb gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
#~ msgid "%s: ERROR running %s command"
#~ msgstr "%s: Fehler beim Ausführen des Kommandos %s."
@@ -42880,9 +39662,6 @@
#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
#~ msgstr "Exportiert eine GRASS Rasterkarte als GRIDATB.FOR (TOPMODEL) Karte."
-#~ msgid "Input map"
-#~ msgstr "Eingabekarte"
#~ msgid "Overwrite output map file"
#~ msgstr "Ãberschreibe Ausgabedatei."
@@ -42918,8 +39697,7 @@
#~ "r.mapcalc performs arithmetic on raster map layers.\n"
#~ "\n"
#~ "New raster map layers can be created which are arithmetic expressions\n"
-#~ "involving existing raster map layers, integer or floating point "
-#~ "constants,\n"
+#~ "involving existing raster map layers, integer or floating point constants,\n"
#~ "and functions.\n"
#~ " \n"
#~ "For more information use 'g.manual r.mapcalc'\n"
@@ -42939,12 +39717,8 @@
#~ msgid "Unable to get current region"
#~ msgstr "Kann die aktuelle Region nicht bekommen."
-#~ msgid ""
-#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
-#~ "densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr ""
-#~ "Erzeugt Hangkurven (flowlines), FlieÃlängen und Flussdichte (upslope "
-#~ "areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
+#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+#~ msgstr "Erzeugt Hangkurven (flowlines), FlieÃlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
#~ msgid "Input elevation raster map"
#~ msgstr "Eingabe-Rasterkarte, mit Höheninformationen"
@@ -42997,42 +39771,23 @@
#~ msgid "imagery, classification, MLC"
#~ msgstr "Bildverarbeitung, Klassifikation, MLC"
-#~ msgid ""
-#~ "Product creation date not in metadata file <%s>, input this data in the "
-#~ "command line parameters"
-#~ msgstr ""
-#~ "Erzeugungsdatum des Produkts nicht in der Metadaten-Datei <%s>. Geben Sie "
-#~ "die Daten in der Kommandozeile ein."
+#~ msgid "Product creation date not in metadata file <%s>, input this data in the command line parameters"
+#~ msgstr "Erzeugungsdatum des Produkts nicht in der Metadaten-Datei <%s>. Geben Sie die Daten in der Kommandozeile ein."
-#~ msgid ""
-#~ "Unable to read solar elevation from metadata file in metadata file <%s>, "
-#~ "input this data in the command line parameters"
-#~ msgstr ""
-#~ "Kann die Sonnenhöhe nicht aus der Metadaten-Datei <%s> lesen. Geben Sie "
-#~ "diese Daten auf der Kommandozeile ein."
+#~ msgid "Unable to read solar elevation from metadata file in metadata file <%s>, input this data in the command line parameters"
+#~ msgstr "Kann die Sonnenhöhe nicht aus der Metadaten-Datei <%s> lesen. Geben Sie diese Daten auf der Kommandozeile ein."
-#~ msgid ""
-#~ "imagery, landsat, top-of-atmosphere reflectance, dos-type simple "
-#~ "atmospheric correction"
-#~ msgstr ""
-#~ "Bildbearbeitung, Landsat, top-of-atmosphere Strahlung, dos-type einfache "
-#~ "atmosphärische Korrektion"
+#~ msgid "imagery, landsat, top-of-atmosphere reflectance, dos-type simple atmospheric correction"
+#~ msgstr "Bildbearbeitung, Landsat, top-of-atmosphere Strahlung, dos-type einfache atmosphärische Korrektion"
-#~ msgid ""
-#~ "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;mss4;Landsat-4 "
-#~ "MSS;mss5;Landsat-5 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM"
-#~ msgstr ""
+#~ msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;mss4;Landsat-4 MSS;mss5;Landsat-5 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+#~ msgstr "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;mss4;Landsat-4 MSS;mss5;Landsat-5 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
#~ msgid "Unable to open the cell map MASK."
#~ msgstr "Kann die Maske (MASK) der 'CELL'-Karte nicht öffnen."
#~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr ""
-#~ "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
+#~ msgstr "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
#~ msgid "Did not find input cell map MASK."
#~ msgstr "Kann die Maske (MASK) der Input-'CELL'-Karte nicht finden."
@@ -43053,8 +39808,7 @@
#~ msgstr "Bildverarbeitung, Kartenverwaltung"
#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
-#~ msgstr ""
-#~ "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
+#~ msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
#~ msgid "imagery, classification, supervised, MLC"
#~ msgstr "Bildverarbeitung, Klassifikation, überwacht, MLC"
@@ -43087,25 +39841,16 @@
#~ msgstr "Höhen-Rasterkarte unbekanntes Typs."
#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#~ msgstr ""
-#~ "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
+#~ msgstr "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
#~ msgid "imagery, FFT"
#~ msgstr "Bildverarbeitung, FFT"
-#~ msgid ""
-#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
-#~ "probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte "
-#~ "wurde wahrscheinlich nicht mit i.fft erstellt."
+#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+#~ msgstr "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte wurde wahrscheinlich nicht mit i.fft erstellt."
-#~ msgid ""
-#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-#~ msgstr ""
-#~ "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. "
-#~ "Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+#~ msgstr "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
#~ msgid "Power 2 values: %d rows %d columns"
#~ msgstr "'hoch zwei'-Werte: %d Zeilen %d Spalten."
@@ -43126,74 +39871,19 @@
#~ msgstr "Kann Datei im 'cell_misc' Verzeichnis nicht öffnen."
#~ msgid "QC, Quality Control, surface reflectance, Modis"
-#~ msgstr ""
-#~ "QC, Qualitätskontrolle, Oberflächenreflexion, surface reflectance, Modis"
+#~ msgstr "QC, Qualitätskontrolle, Oberflächenreflexion, surface reflectance, Modis"
-#~ msgid ""
-#~ "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-#~ "surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);"
-#~ "mod11A2;LST 1Km 8-days (Day/Night);"
-#~ msgstr ""
+#~ msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
+#~ msgstr "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
-#~ msgid ""
-#~ "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
-#~ "cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
-#~ "diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
-#~ "modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
-#~ "mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
-#~ "data_quality_flag_11A1;mod11A1: Detailed Quality Indications;"
-#~ "emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;"
-#~ "mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: "
-#~ "Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity "
-#~ "Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality "
-#~ "Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;"
-#~ "aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;"
-#~ "brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;"
-#~ "cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;"
-#~ "mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09A1s: StateQA "
-#~ "Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal "
-#~ "Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;"
-#~ "internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;"
-#~ "mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA "
-#~ "Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal "
-#~ "Snow Mask;"
-#~ msgstr ""
-#~ "Snow Mask;"
+#~ msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mo
d09A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
+#~ msgstr "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;m
od09A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
#~ msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7])"
#~ msgstr "Kanalnummer des MODIS Produkts (mod09Q1=[1,2],mod09A1=[1-7])"
-#~ msgid ""
-#~ "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: "
-#~ "Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: "
-#~ "SWIR 2;7;mod09A1 Band 7: SWIR 3;"
-#~ msgstr ""
+#~ msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
+#~ msgstr "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
#~ msgid "This flag is only available for MOD11A1 @ 1Km products"
#~ msgstr "Dieser Schalter ist nur für MOD11A1 @ 1km Produkte vorhanden"
@@ -43314,8 +40004,7 @@
#~ "Berechne lokale Kamerawinkel? "
#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr ""
-#~ "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
+#~ msgstr "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
#~ msgid "Map name <%s> is illegal"
#~ msgstr "Kartenname <%s> ist ein ungültiger Name."
@@ -43368,21 +40057,13 @@
#~ msgstr "Gruppe [%s] zielt auf Location [%s], Mapset [%s]."
#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr ""
-#~ "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden "
-#~ "soll."
+#~ msgstr "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden soll."
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr ""
-#~ "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf "
-#~ "dem Bildschirm dargestellt."
+#~ msgid "Name of image to be rectified which will be initially drawn on screen"
+#~ msgstr "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf dem Bildschirm dargestellt."
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr ""
-#~ "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm "
-#~ "dargestellt wird."
+#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgstr "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm dargestellt wird."
#~ msgid "No camera reference file selected for group [%s]"
#~ msgstr "Keine Kamerareferenzdatei ausgewählt für die Gruppe [%s]."
@@ -43394,8 +40075,7 @@
#~ msgstr "Keine Anfangs-Kameraposition für die Gruppe [%s]."
#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#~ msgstr ""
-#~ "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
+#~ msgstr "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
#~ msgid "No photo points for group [%s]"
#~ msgstr "Keine Bildpositionen für die Gruppe [%s]."
@@ -43416,9 +40096,7 @@
#~ msgstr "Bildgruppe [%s] nicht gefunden."
#~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr ""
-#~ "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe "
-#~ "verwendet werden soll."
+#~ msgstr "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe verwendet werden soll."
#~ msgid "Reading raster map <%s in %s> ..."
#~ msgstr "Lese Rasterkarte <%s in %s> ..."
@@ -43432,36 +40110,20 @@
#~ msgid "postscript, map, printing"
#~ msgstr "Postscript, Karte, Drucken"
-#~ msgid ""
-#~ "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr ""
-#~ "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten"
-#~ "(Rand) )."
+#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
-#~ msgid ""
-#~ "File containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr ""
-#~ "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie "
-#~ "input=- für eine interaktive Eingabe über die Tastatur)."
+#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+#~ msgstr "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie input=- für eine interaktive Eingabe über die Tastatur)."
#~ msgid "PostScript output file"
#~ msgstr "PostScript Ausgabedatei"
-#~ msgid ""
-#~ "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr ""
-#~ "MaÃstab der Ausgabekarte, z.B. 1:25000 (standardmäÃig: Anpassung an die "
-#~ "Seite)"
+#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
+#~ msgstr "MaÃstab der Ausgabekarte, z.B. 1:25000 (standardmäÃig: Anpassung an die Seite)"
-#~ msgid ""
-#~ "Using <%s> from the command line is depreciated. Please use the <%s> "
-#~ "mapping instruction instead. The parameter <%s> will be removed in future "
-#~ "versions of GRASS."
-#~ msgstr ""
-#~ "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte "
-#~ "verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <"
-#~ "%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
+#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
+#~ msgstr "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
#~ msgid ""
#~ "ERROR: Required parameter <%s> not set:\n"
@@ -43476,22 +40138,12 @@
#~ msgid "Data exists after final 'end' instruction!"
#~ msgstr "Weitere Daten existieren nach der beendenden 'end'-Instruktion!"
-#~ msgid ""
-#~ "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE "
-#~ "mapping instruction. This mapping instruction is superseded and will be "
-#~ "removed in future versions of GRASS. Please use --verbose instead."
-#~ msgstr ""
-#~ "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der "
-#~ "Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt "
-#~ "und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte "
-#~ "verwenden Sie stattdessen '--verbose'."
+#~ msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
+#~ msgstr "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte verwenden Sie stattdessen '--verbose'."
#~ msgid "Cannot set GRASS_VERBOSE variable."
#~ msgstr "Kann die GRASS_VERBOSE Variable nicht setzen."
-#~ msgid "PostScript file [%s] successfully written."
-#~ msgstr "Die PostScript Datei [%s] wurde erfolgreich geschrieben."
#~ msgid "display, paint labels"
#~ msgstr "Darstellung, Zeichen Label"
@@ -43522,17 +40174,8 @@
#~ msgid "display, vector"
#~ msgstr "Darstellung, Vektor"
-#~ msgid ""
-#~ "shape;Display geometry of features;cat;Display category numbers of "
-#~ "features;topo;Display topology information (nodes, edges);dir;Display "
-#~ "direction of linear features;attr;Display selected attribute based on "
-#~ "'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-#~ msgstr ""
-#~ "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern "
-#~ "der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;"
-#~ "Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten "
-#~ "Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der "
-#~ "Objekte (nur für 3D Vektorkarten)"
+#~ msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+#~ msgstr "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der Objekte (nur für 3D Vektorkarten)"
#~ msgid "Layer number (if -1, all layers are displayed)"
#~ msgstr "Layernummer (wenn -1, alle Layer werden dargestellt)."
@@ -43540,10 +40183,8 @@
#~ msgid "Type of color table (for use with -z flag)"
#~ msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
-#~ msgid ""
-#~ "Name of column for line widths (these values will be scaled by wscale)"
-#~ msgstr ""
-#~ "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+#~ msgid "Name of column for line widths (these values will be scaled by wscale)"
+#~ msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
#~ msgid "Scale factor for wcolumn"
#~ msgstr "Skalierungsfaktor für wcolumn"
@@ -43551,30 +40192,14 @@
#~ msgid "Rendering method for filled polygons"
#~ msgstr "Render-Methode für gefüllte Polygone."
-#~ msgid ""
-#~ "g;use the libgis render functions (features: clipping);r;use the raster "
-#~ "graphics library functions (features: polylines);d;use the display "
-#~ "library basic functions (features: polylines);c;use the display library "
-#~ "clipping functions (features: clipping);l;use the display library culling "
-#~ "functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "g;Verwende die Render-Funktion von libgis (Feature: abschneiden);r;"
-#~ "verwende dir Render-Funktion der Rastergrafikbibliothek (Feature: "
-#~ "Polylinien);d;Verwende die grundlegenden Funktionen der Displaybibliothek "
-#~ "(Feature: Polylinien);c;Verwende die Clipping-Funktion der "
-#~ "Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funktion "
-#~ "der der Displaybibliothek (Feature: Beschneiden, Polylinien)"
+#~ msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+#~ msgstr "g;Verwende die Render-Funktion von libgis (Feature: abschneiden);r;verwende dir Render-Funktion der Rastergrafikbibliothek (Feature: Polylinien);d;Verwende die grundlegenden Funktionen der Displaybibliothek (Feature: Polylinien);c;Verwende die Clipping-Funktion der Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funktion der der Displaybibliothek (Feature: Beschneiden, Polylinien)"
#~ msgid "Get colors from map table column (of form RRR:GGG:BBB)"
#~ msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen "
-#~ "(Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster "
-#~ "aktualisiert wird)."
+#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+#~ msgstr "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster aktualisiert wird)."
#~ msgid "Colorize polygons according to z height"
#~ msgstr "Färbe die Polygone gemäà ihrer Z-Höhe."
@@ -43583,13 +40208,10 @@
#~ msgstr "'Layer' muss > 0 sein für den Parameter 'cats'."
#~ msgid "Unable to display areas, topology not available"
-#~ msgstr ""
-#~ "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
+#~ msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr ""
-#~ "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
-#~ "vorhanden ist."
+#~ msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
#~ msgid "Unable to display topology, not available"
#~ msgstr "Kann die Topologie nicht darstellen, da sie nicht vorhanden ist."
@@ -43597,16 +40219,11 @@
#~ msgid "Color definition column not specified."
#~ msgstr "Farbspalte nicht angegeben."
-#~ msgid ""
-#~ "Error in color definition column (%s), area %d with cat %d: colorstring "
-#~ "[%s]"
-#~ msgstr ""
-#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: "
-#~ "Farbwert [%s]."
+#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: Farbwert [%s]."
#~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr ""
-#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
+#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
#~ msgid "Line width column (%s) is not numeric."
#~ msgstr "Spalte mit der Linienbreite (%s) ist nicht numerisch."
@@ -43626,22 +40243,14 @@
#~ msgid "Unable to read symbol, unable to display points"
#~ msgstr "Kann das Symbol nicht lesen; kann die Punkte nicht darstellen."
-#~ msgid ""
-#~ "Error in color definition column '%s', feature id %d with cat %d: "
-#~ "colorstring '%s'"
-#~ msgstr ""
-#~ "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d: "
-#~ "Farbwert '%s'."
+#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
+#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d: Farbwert '%s'."
#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr ""
-#~ "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d"
+#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d"
-#~ msgid ""
-#~ "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr ""
-#~ "Fehler in der SymbolgröÃen-Spalte (%s), Element %d mit cat %d: "
-#~ "SymbolgröÃe [%f]."
+#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+#~ msgstr "Fehler in der SymbolgröÃen-Spalte (%s), Element %d mit cat %d: SymbolgröÃe [%f]."
#~ msgid "Error in color definition column '%s': %d features affected"
#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', %d Feature betroffen."
@@ -43649,26 +40258,14 @@
#~ msgid "display, cartography"
#~ msgstr "Darstellung, Kartographie"
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster "
-#~ "dar."
+#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
+#~ msgstr "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster dar."
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr ""
-#~ "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht "
-#~ "angegeben ist, wird von der Standardeingabe gelesen."
+#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
+#~ msgstr "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben ist, wird von der Standardeingabe gelesen."
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
-#~ "Tripel (durch Doppelpunkte getrennt)."
+#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+#~ msgstr "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B Tripel (durch Doppelpunkte getrennt)."
#~ msgid "Monitor: interactive command in redraw"
#~ msgstr "Grafikfenster: Interaktives Kommando zum erneuten Zeichnen."
@@ -43697,30 +40294,20 @@
#~ msgid "display, distance"
#~ msgstr "Darstellung, Distanz"
-#~ msgid ""
-#~ "Displays the rhumbline joining two user-specified points, in the active "
-#~ "frame on the user's graphics monitor."
-#~ msgstr ""
-#~ "Stellt im aktiven Grafikfenster eine Linie dar, die zwei vom Benutzer "
-#~ "angegebene Punkte verbindet."
+#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
+#~ msgstr "Stellt im aktiven Grafikfenster eine Linie dar, die zwei vom Benutzer angegebene Punkte verbindet."
#~ msgid "display, position, querying"
#~ msgstr "Darstellung, Position, Abfrage"
-#~ msgid ""
-#~ "Identifies the geographic coordinates associated with point locations in "
-#~ "the active frame on the graphics monitor."
-#~ msgstr ""
-#~ "Identifiziert geographische Koordinaten an einem gegebenen Punkt im "
-#~ "Grafik-Fenster."
+#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
+#~ msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
#~ msgid "One mouse click only"
#~ msgstr "Nur ein Mausklick."
#~ msgid " Middle: toggle flash color\n"
-#~ msgstr ""
-#~ " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten "
-#~ "sollen.\n"
+#~ msgstr " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten sollen.\n"
#~ msgid "Enable flashing (slower)"
#~ msgstr "Aufleuchten anschalten (ist langsamer)."
@@ -43732,27 +40319,16 @@
#~ msgstr "Anzeige, Metadaten"
#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr ""
-#~ "Erstelle eine Liste von Kommandos zum Wiederherstellen der "
-#~ "Bildschirmgrafik."
+#~ msgstr "Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
#~ msgid "Name of frame(s) to save"
#~ msgstr "Name der Rahmen zum speichern."
-#~ msgid ""
-#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
-#~ "the last object."
-#~ msgstr ""
-#~ "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" "
-#~ "angezeigt werden. -1 steht für das letzte Objekt."
+#~ msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
+#~ msgstr "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" angezeigt werden. -1 steht für das letzte Objekt."
-#~ msgid ""
-#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
-#~ "be done first, if any."
-#~ msgstr ""
-#~ "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach"
-#~ "\"). Falls eine Option angegeben wurde, wird remove= als erstes "
-#~ "ausgeführt."
+#~ msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
+#~ msgstr "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
#~ msgid "Save current frame"
#~ msgstr "Speichere aktuellen Rahmen."
@@ -43791,15 +40367,13 @@
#~ msgstr "Darstellung, Raster, Profil"
#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr ""
-#~ "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
+#~ msgstr "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
#~ msgid "Output profile data to file(s) with prefix 'name'"
#~ msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr ""
-#~ "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
+#~ msgstr "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
#~ msgid ""
#~ "\n"
@@ -43811,8 +40385,7 @@
#~ "Verwenden Sie die Maus, um eine Aktion auszuwählen."
#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr ""
-#~ "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
+#~ msgstr "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
#~ msgid "Error opening cell-file"
#~ msgstr "Fehler beim Ãffnen der Zell-Datei."
@@ -43838,12 +40411,8 @@
#~ msgid "display, map management"
#~ msgstr "Darstellung, Kartenverwaltung"
-#~ msgid ""
-#~ "Prompts the user to select a GRASS data base file from among files "
-#~ "displayed in a menu on the graphics monitor."
-#~ msgstr ""
-#~ "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü "
-#~ "präsentierten Dateien im Grafikfenster auszuwählen."
+#~ msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
+#~ msgstr "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü präsentierten Dateien im Grafikfenster auszuwählen."
#~ msgid "Database element, one word description"
#~ msgstr "Datenbankelement, ein Wort Beschreibung"
@@ -43881,28 +40450,17 @@
#~ msgid "Use mouse to interactively place scale"
#~ msgstr "Benutze die Maus zum Interaktiven Plazieren des MaÃstabs."
-#~ msgid ""
-#~ "The screen coordinates for top-left corner of label ([0,0] is top-left of "
-#~ "frame)"
-#~ msgstr ""
-#~ "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist "
-#~ "oben links)."
+#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
+#~ msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
#~ msgid "display, setup"
#~ msgstr "Darstellung, Setup"
-#~ msgid ""
-#~ "Erase the contents of the active display frame with user defined color"
-#~ msgstr ""
-#~ "Löscht den Inhalte des aktiven Grafikfensters mit einer "
-#~ "benutzerdefinierten Farbe."
+#~ msgid "Erase the contents of the active display frame with user defined color"
+#~ msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
-#~ msgid ""
-#~ "Color to erase with, either a standard GRASS color or R:G:B triplet "
-#~ msgstr ""
-#~ "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-"
-#~ "Tripel (Semicolon als Trennzeichen)."
+#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+#~ msgstr "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-Tripel (Semicolon als Trennzeichen)."
#~ msgid "Don't add to list of commands in monitor"
#~ msgstr "Nicht zu der Kommandoliste im Monitor hinzufügen."
@@ -43928,22 +40486,14 @@
#~ msgid "No map is displayed in GRASS monitor"
#~ msgstr "Im Grafikfenster ist keine Karte dargestellt."
-#~ msgid ""
-#~ "Overlays cell category values on a raster map layer displayed to the "
-#~ "graphics monitor."
-#~ msgstr ""
-#~ "Ãberlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-"
-#~ "Fenster."
+#~ msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+#~ msgstr "Ãberlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-Fenster."
#~ msgid "No raster map exists in current window"
#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster."
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-"
-#~ "Fensters zu zeichnen."
+#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
+#~ msgstr "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters zu zeichnen."
#~ msgid "Screen position (percentage, [0,0] is bottom left)"
#~ msgstr "Koordinaten (in Prozent, [0,0] ist unten links)."
@@ -43991,8 +40541,7 @@
#~ msgstr "%s: Kann diese Schrift nicht lesen."
#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr ""
-#~ "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
+#~ msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
#~ msgid "%s: No FreeType definition file"
#~ msgstr "%s: Keine FreeType Definitionsdatei gefunden."
@@ -44031,8 +40580,7 @@
#~ msgstr "unten,oben,links,rechts"
#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr ""
-#~ "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
+#~ msgstr "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
#~ msgid "Error choosing frame [%s]\n"
#~ msgstr "Fehler beim Wählen des Fensters [%s].\n"
@@ -44096,8 +40644,7 @@
#~ msgstr "Es gibt das Grafikfenster <%s> nicht."
#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr ""
-#~ "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
+#~ msgstr "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
#~ msgid "Error - Locking mechanism failed"
#~ msgstr "Fehler - Sperrvorrichtung ist fehlgeschlagen."
@@ -44141,19 +40688,11 @@
#~ msgid "Problem selecting %s. Will try once more"
#~ msgstr "Probleme beim Auswählen von %s. Einmal versuche ich es noch..."
-#~ msgid ""
-#~ "<%s> is a floating point map. Ignoring [lines] and drawing continuous "
-#~ "color ramp"
-#~ msgstr ""
-#~ "<%s> ist eine FlieÃkommakarte. Ignoriere [lines] und zeichne einen "
-#~ "kontinuierlichen Farbverlauf."
+#~ msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
+#~ msgstr "<%s> ist eine FlieÃkommakarte. Ignoriere [lines] und zeichne einen kontinuierlichen Farbverlauf."
-#~ msgid ""
-#~ "<%s> is a floating point map. Ignoring [cols] and drawing continuous "
-#~ "color ramp"
-#~ msgstr ""
-#~ "<%s> ist eine FlieÃkommakarte. Ignoriere [cols] und zeichne einen "
+#~ msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
+#~ msgstr "<%s> ist eine FlieÃkommakarte. Ignoriere [cols] und zeichne einen kontinuierlichen Farbverlauf."
#~ msgid "R_color file for [%s] not available"
#~ msgstr "Farbdatei für [%s] nicht vorhanden."
@@ -44174,28 +40713,16 @@
#~ msgstr "Invertiere Kategorieliste."
#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr ""
-#~ "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
+#~ msgstr "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr ""
-#~ "Igniriere Kategorieliste: Karte ist ein FlieÃkommakarte (Bitte benutzen "
-#~ "Sie 'val=')."
+#~ msgstr "Igniriere Kategorieliste: Karte ist ein FlieÃkommakarte (Bitte benutzen Sie 'val=')."
#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr ""
-#~ "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie "
-#~ "'cat=')."
+#~ msgstr "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
-#~ msgid ""
-#~ "d;use the display library basic functions (features: polylines);c;use the "
-#~ "display library clipping functions (features: clipping);l;use the display "
-#~ "library culling functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "d;Verwende grundlegende Funktion der Displaybibliothek (Feature: "
-#~ "Polylinien);c;Verwende die Clipping-Funkton der Displaybibliothek "
-#~ "(Feature: abschneiden);l;Verwende die Culling-Funkton der "
-#~ "Displaybibliothek (Feature: Beschneiden, Polylinien)"
+#~ msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+#~ msgstr "d;Verwende grundlegende Funktion der Displaybibliothek (Feature: Polylinien);c;Verwende die Clipping-Funkton der Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funkton der Displaybibliothek (Feature: Beschneiden, Polylinien)"
#~ msgid "Invalid rendering method <%s>"
#~ msgstr "Ungültige Render-Methode <%s>."
@@ -44242,9 +40769,7 @@
#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster. "
#~ msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
-#~ msgstr ""
-#~ "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links "
-#~ "unten)."
+#~ msgstr "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
#~ msgid "Use mouse to size & place legend"
#~ msgstr "Benutze Maus zum Plazieren und zur GröÃeneinstellung der Legende."
@@ -44252,11 +40777,8 @@
#~ msgid "display, menu"
#~ msgstr "Darstellung, Menue"
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr ""
-#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
+#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
+#~ msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
#~ msgid "Sets the color of the menu text"
#~ msgstr "Bestimmt die Farbe für den Menütext."
@@ -44297,14 +40819,8 @@
#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
#~ msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten wxpython"
-#~ msgid ""
-#~ "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
-#~ "(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
-#~ "command line interface only"
-#~ msgstr ""
-#~ "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS "
-#~ "Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d."
-#~ "m);text;Nur Kommandozeile"
+#~ msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
+#~ msgstr "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d.m);text;Nur Kommandozeile"
#~ msgid "Name of workspace file"
#~ msgstr "Name der Workspace-Datei."
@@ -44355,9 +40871,7 @@
#~ msgstr "[%s@%s] ist die Ausgangskarte für [%s]. Löschen wurde erzwungen."
#~ msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-#~ msgstr ""
-#~ "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: "
-#~ "%s"
+#~ msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
#~ msgid "Remove base maps"
#~ msgstr "Entferne Basiskarten"
@@ -44372,9 +40886,7 @@
#~ msgstr "Kann den regulären Ausdruck nicht kompilieren %s"
#~ msgid "You must use the force flag to actually remove them. Exiting."
-#~ msgstr ""
-#~ "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. "
-#~ "Beende mich."
+#~ msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
#~ msgid "general, settings"
#~ msgstr "Allgemein, Einstellungen"
@@ -44382,11 +40894,8 @@
#~ msgid "Changes current mapset."
#~ msgstr "Ãndere aktuelles Mapset."
-#~ msgid ""
-#~ "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr ""
-#~ "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die "
-#~ "neue Location befindet)."
+#~ msgid "GIS data directory (full path to the directory where the new location is)"
+#~ msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue Location befindet)."
#~ msgid "List available mapsets"
#~ msgstr "Zeige alle verfügbaren Mapsets."
@@ -44398,24 +40907,16 @@
#~ msgstr "Sie haben nicht die Berechtigung dieses Mapset zu verwenden."
#~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr ""
-#~ "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu "
-#~ "erzeugen."
+#~ msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
-#~ msgid ""
-#~ "%s is currently running GRASS in selected mapset or lock file cannot be "
-#~ "checked"
-#~ msgstr ""
-#~ "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei "
-#~ "kann nicht überprüft werden."
+#~ msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
+#~ msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
#~ msgid "Erasing monitors..."
#~ msgstr "Lösche Monitore... "
#~ msgid "One-character output separator, newline, comma, space, or tab"
-#~ msgstr ""
-#~ "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder "
-#~ "Tabulator."
+#~ msgstr "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
#~ msgid "Mapset to list (default: current search path)"
#~ msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
@@ -44432,19 +40933,14 @@
#~ msgid "%s file(s) to be renamed"
#~ msgstr "%s Datei(en) sollen umbenannt werden."
-#~ msgid ""
-#~ "Copies available data files in the user's current mapset search path and "
-#~ "location to the appropriate element directories under the user's current "
-#~ "mapset."
+#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
#~ msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
#~ msgid "%s file(s) to be copied"
#~ msgstr "%s Dateien müssen kopiert werden."
#~ msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-#~ msgstr ""
-#~ "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D- als auch 3D-"
-#~ "Parameter)"
+#~ msgstr "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D- als auch 3D-Parameter)"
#~ msgid "Grid resolution 2D (both north-south and east-west)"
#~ msgstr "2D Rasterauflösung (Nord-Süd und Ost-West)."
@@ -44521,20 +41017,14 @@
#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
#~ msgstr "Spaltenname und -typ (z.B. INTEGER, DOUBLE PRECISION) für z Werte."
-#~ msgid ""
-#~ "If type is not given then DOUBLE PRECISION is used. Writes Z data to "
-#~ "column instead of 3D vector."
-#~ msgstr ""
-#~ "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe "
-#~ "Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
+#~ msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
+#~ msgstr "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
#~ msgid "Do not build topology"
#~ msgstr "Erzeuge keine Topologie."
#~ msgid "v.random can't create 3D vector and attribute table at same time"
-#~ msgstr ""
-#~ "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit "
-#~ "erstellen."
+#~ msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
#~ msgid "Using 'double precision' for column <%s>"
#~ msgstr "Verwende 'double precision' für die Spalte <%s>"
@@ -44581,12 +41071,8 @@
#~ msgid "vector, geometry, triangulation"
#~ msgstr "Vektor, Geometrie, Triangulation"
-#~ msgid ""
-#~ "Creates a Voronoi diagram from an input vector map containing points or "
-#~ "centroids."
-#~ msgstr ""
-#~ "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten "
-#~ "oder Zentroiden."
+#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+#~ msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
#~ msgid "Do not create attribute table"
#~ msgstr "Keine Attributtabelle erzeugen."
@@ -44606,18 +41092,11 @@
#~ msgid "Unknown column type '%s'"
#~ msgstr "Unbekannter Spalten-Typ '%s'"
-#~ msgid "Unknown column type '%s' values lost"
-#~ msgstr "Unbekannter Spalten-Typ '%s', Werte verloren"
#~ msgid "vector, kernel density"
#~ msgstr "Vektor, Kerndichte"
-#~ msgid ""
-#~ "none;No method applied at nodes with more than 2 arcs;split;Equal split "
-#~ "(Okabe 2009) applied at nodes;"
-#~ msgstr ""
-#~ "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;"
-#~ "Equal split (Okabe 2009) angewendet bei Knoten;"
+#~ msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
+#~ msgstr "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;Equal split (Okabe 2009) angewendet bei Knoten;"
#~ msgid "Verbose module output (retained for backwards compatibility)"
#~ msgstr "Gesprächige Modulausgabe (für Rückwärtskompatibilität erhalten)"
@@ -44685,12 +41164,8 @@
#~ msgid "Write centroids:"
#~ msgstr "Schreibe Zentroide:"
-#~ msgid ""
-#~ "Input data contains 3D features. Created vector is 2D only, use -z flag "
-#~ "to import 3D vector"
-#~ msgstr ""
-#~ "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur "
-#~ "2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
+#~ msgstr "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
#~ msgid "Cannot read part of geometry"
#~ msgstr "Kann Teil der Geometrie nicht lesen."
@@ -44713,19 +41188,8 @@
#~ msgid "Required for operation 'connect'"
#~ msgstr "Benötigt für die Operation 'connect'."
-#~ msgid ""
-#~ "nodes;new point is placed on each node (line end) if doesn't exist;"
-#~ "connect;connect still unconnected points to vector network by inserting "
-#~ "new line(s);report;print to standard output {line_category "
-#~ "start_point_category end_point_category};nreport;print to standard output "
-#~ "{point_category line_category[,line_category...]}"
-#~ msgstr ""
-#~ "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, "
-#~ "wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des "
-#~ "Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe "
-#~ "{line_category start_point_category end_point_category} aus;nreport;Gebe "
-#~ "auf der Standardausgabe {point_category line_category [line_category...]}"
-#~ "aus"
+#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+#~ msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
#~ msgid "Output vector map must be specified"
#~ msgstr "Ausgabe-Vektorkarte muss angegeben werden."
@@ -44748,26 +41212,14 @@
#~ msgid "vector, buffer"
#~ msgstr "Vektor, Buffer"
-#~ msgid ""
-#~ "Creates a buffer around features of given type (areas must contain "
-#~ "centroid)."
-#~ msgstr ""
-#~ "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen "
-#~ "Zentroide enthalten)."
+#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
+#~ msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
-#~ msgid ""
-#~ "This is an alias to the distance option. It is retained for backwards "
-#~ "compatibility"
-#~ msgstr ""
-#~ "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts "
-#~ "Kompatibilität erhalten"
+#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
+#~ msgstr "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts Kompatibilität erhalten"
-#~ msgid ""
-#~ "The buffer option has been replaced by the distance option and will be "
-#~ "removed in future."
-#~ msgstr ""
-#~ "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in "
-#~ "Zukunft entfernt."
+#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
+#~ msgstr "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
#~ msgid "Use the distance option instead of the buffer option."
#~ msgstr "Verwende die Distanz-Option anstelle der Buffer-Option."
@@ -44775,29 +41227,17 @@
#~ msgid "Writing buffers..."
#~ msgstr "Schreibe Buffer..."
-#~ msgid ""
-#~ "Calculates univariate statistics for attribute. Variance and standard "
-#~ "deviation is calculated only for points if specified."
-#~ msgstr ""
-#~ "Berechnet univariate Statistiken für die Attribute. Die Varianz und "
-#~ "Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+#~ msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
#~ msgid "The '-%c' flag is currently broken, please use v.distance instead."
-#~ msgstr ""
-#~ "Der Schalter '-%c' ist momentan kaputt. Bitte verwenden Sie stattdessen v."
-#~ "distance."
+#~ msgstr "Der Schalter '-%c' ist momentan kaputt. Bitte verwenden Sie stattdessen v.distance."
#~ msgid "vector, network, shortest path"
#~ msgstr "Vektor, Netzwerk, kürzester Pfad"
-#~ msgid ""
-#~ "Finds the shortest paths from a feature 'to' to every feature 'from' and "
-#~ "various information about this realtion are uploaded to the attribute "
-#~ "table."
-#~ msgstr ""
-#~ "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' "
-#~ "und zahlreiche Informationen über diese Beziehung wird in der "
-#~ "Attributtabelle abgespeichert"
+#~ msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
+#~ msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
#~ msgid "vector, LRS, networking"
#~ msgstr "Vektor, LRS, Netzwerk"
@@ -44806,21 +41246,16 @@
#~ msgstr "Erzeugt Lineares Referenzsystem"
#~ msgid "Creates stationing from input lines, and linear reference system"
-#~ msgstr ""
-#~ "Erzeuge Stationen auf Basis der Eingabelinien und dem "
-#~ "Linearenreferenzsystem."
+#~ msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
#~ msgid "got type %d"
#~ msgstr "habe Typ '%d' erhalten."
#~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr ""
-#~ "Feature hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde "
-#~ "exportiert."
+#~ msgstr "Feature hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde exportiert."
#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr ""
-#~ "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
+#~ msgstr "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
#~ msgid "Column <%s>: unsupported data type"
#~ msgstr "Spalte <%s>: nicht unterstützter Datentyp."
@@ -44829,13 +41264,10 @@
#~ msgstr "Vektor, Export"
#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr ""
-#~ "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+#~ msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr ""
-#~ "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
-#~ "Schalter '-o' angegeben ist."
+#~ msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
#~ msgid "Parameter '%s' ignored in standard mode"
#~ msgstr "Parameter '%s' wird im Standard-Modus ignoriert."
@@ -44843,11 +41275,8 @@
#~ msgid "Create parallel line to input lines"
#~ msgstr "Erzeuge eine parallele Linie zu der eingegebenen Linie."
-#~ msgid ""
-#~ "Offset in map units, positive for right side, negative for left side."
-#~ msgstr ""
-#~ "Versatz in Karteneinheiten, positiv für die rechte und negativ für die "
-#~ "linke Seite."
+#~ msgid "Offset in map units, positive for right side, negative for left side."
+#~ msgstr "Versatz in Karteneinheiten, positiv für die rechte und negativ für die linke Seite."
#~ msgid "vector, metadata"
#~ msgstr "Vektor, Metadaten"
@@ -44862,39 +41291,10 @@
#~ msgstr "Erzeugt Topologie für GRASS Vektorkarten."
#~ msgid "Name for vector map where erroneous vector features are written to"
-#~ msgstr ""
-#~ "Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben "
-#~ "werden sollen."
+#~ msgstr "Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden sollen."
-#~ msgid ""
-#~ "create;Create new (empty) vector map;add;Add new features to existing "
-#~ "vector map;delete;Delete selected features from vector map;move;Move "
-#~ "selected features in vector map;vertexmove;Move vertex of selected vector "
-#~ "lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add "
-#~ "new vertex to selected vector lines;merge;Merge selected vector lines;"
-#~ "break;Break/split vector lines;select;Select lines and print their ID's;"
-#~ "catadd;Set new categories to selected vector features for defined layer;"
-#~ "catdel;Delete categories from selected vector features for defined layer;"
-#~ "copy;Copy selected features;snap;Snap vector features in given threshold;"
-#~ "flip;Flip direction of selected vector lines;connect;Connect two lines;"
-#~ "zbulk;Z bulk-labeling (automated assignment of z coordinate to vector "
-#~ "lines);chtype;Change feature type (point<->centroid, line<->boundary)"
-#~ msgstr ""
-#~ "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Feature zu "
-#~ "einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Feature "
-#~ "von einer Vektorkarte;move;Verschiebt selektierte Feature in einer "
-#~ "Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;"
-#~ "vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;"
-#~ "Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;"
-#~ "Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;"
-#~ "Selektiert Linien und gibt ihre ID aus;catadd;Vergiebt neue Kategorien "
-#~ "für selektierte Vektorfeature eines bestimmten Layers;catdel;Löscht "
-#~ "Kategorien von selektierten Vektorfeatures eines bestimmten Layers;copy;"
-#~ "Kopiert selektierte Feature;snap;Snap Vektorfeature innerhalb des "
-#~ "angegebenen Schwellwertes;flip;Drehe die Richtung selektierter "
-#~ "Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung "
-#~ "(automatisierte Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ãndere "
-#~ "den Typ des Features(Punkt<->Zentroid, Linie<->Grenze)"
+#~ msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
+#~ msgstr "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Feature zu einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Feature von einer Vektorkarte;move;Verschiebt selektierte Feature in einer Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre ID aus;catadd;Vergiebt neue Kategorien für selektierte Vektorfeature eines bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorfeatures eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Snap Vektorfeature innerhalb des angegebenen Schwellwertes;flip;Drehe die Richtung selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung (automatisierte Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ãndere
#~ msgid "ASCII file to be converted to binary vector map"
#~ msgstr "ASCII-Datei, die in eine Vektorkarte konvertiert werden soll."
@@ -44903,15 +41303,13 @@
#~ msgstr "Lese von der Standardeingabe, wenn nicht angegeben (oder \"-\")."
#~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr ""
-#~ "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
+#~ msgstr "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
#~ msgid "vector, editing, geometry"
#~ msgstr "Vektor, Editieren, Geometrie"
#~ msgid "Creating new DB connection based on default mapset settings..."
-#~ msgstr ""
-#~ "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
+#~ msgstr "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
#~ msgid "Error reading ASCII file: '%s'"
#~ msgstr "Fehler beim Lesen der ASCII-Datei: '%s'."
@@ -45051,12 +41449,8 @@
#~ msgid "Cannot grant privileges on table:\n"
#~ msgstr "Kann Privilegien für die Tabelle nicht zuweisen:\n"
-#~ msgid ""
-#~ "Cannot add database link to vector, link for given field probably already "
-#~ "exists."
-#~ msgstr ""
-#~ "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht "
-#~ "schon eine Verknüpfung für das Feld."
+#~ msgid "Cannot add database link to vector, link for given field probably already exists."
+#~ msgstr "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht schon eine Verknüpfung für das Feld."
#~ msgid "Cannot create new record."
#~ msgstr "Kann keinen neuen Eintrag anlegen."
@@ -45098,8 +41492,7 @@
#~ msgstr "Datenbankverbindung nicht definiert.<BR>"
#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr ""
-#~ "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
+#~ msgstr "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
#~ msgid "Line %d"
#~ msgstr "Linie %d"
@@ -45107,13 +41500,8 @@
#~ msgid "No categories"
#~ msgstr "Keine Kategorien"
-#~ msgid ""
-#~ "There are no more features with category %d (layer %d) in the map, but "
-#~ "there is record in the table. Delete this record?"
-#~ msgstr ""
-#~ "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der "
-#~ "Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-"
-#~ "Einträge gelöscht werden?"
+#~ msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
+#~ msgstr "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-Einträge gelöscht werden?"
#~ msgid "Cannot delete record: %s"
#~ msgstr "Kann Eintrag nicht löschen: %s"
@@ -45127,19 +41515,14 @@
#~ msgid "Cannot open select cursor"
#~ msgstr "Kann den Select-Cursor nicht öffnen."
-#~ msgid ""
-#~ "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#~ msgstr ""
-#~ "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit "
-#~ "Treiber '%s'<BR>"
+#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+#~ msgstr "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit Treiber '%s'<BR>"
#~ msgid "Cannot fetch next record"
#~ msgstr "Kann die nächste Zeile nicht holen."
-#~ msgid ""
-#~ "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-#~ msgstr ""
-#~ "<HR> Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+#~ msgid "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+#~ msgstr "<HR> Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
#~ msgid "vector, editing, digitization"
#~ msgstr "Vektor, Editiern, Digitalisieren"
@@ -45153,12 +41536,8 @@
#~ msgid "New empty map created."
#~ msgstr "Neue, leere Karte erstellt."
-#~ msgid ""
-#~ "Map <%s> does not exist in current mapset. Add flag -n to create a new "
-#~ "map."
-#~ msgstr ""
-#~ "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den "
-#~ "Schalter -n, um eine neue Karte zu erzeugen."
+#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+#~ msgstr "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den Schalter -n, um eine neue Karte zu erzeugen."
#~ msgid "Select tool"
#~ msgstr "Selektionswerkzeug"
@@ -45208,20 +41587,11 @@
#~ msgid "Allocate subnets for nearest centres (direction from centre)."
#~ msgstr "Sammle Teilnetze für nächste Zentren (Richtung: vom Zentrum)."
-#~ msgid ""
-#~ "Centre node must be opened (costs >= 0). Costs of centre node are used in "
-#~ "calculation"
-#~ msgstr ""
-#~ "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
-#~ "Knoten gehen im die Berechnung mit ein."
+#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+#~ msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
-#~ msgid ""
-#~ "Categories of centres (points on nodes) to which net will be allocated, "
-#~ "layer for this categories is given by nlayer option"
-#~ msgstr ""
-#~ "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
-#~ "wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option "
-#~ "angegeben."
+#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+#~ msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegeben."
#~ msgid "Number of centres: [%d] (nlayer: [%d])"
#~ msgstr "Zahl der Zentren: [%d] (nlayer: [%d])."
@@ -45235,39 +41605,23 @@
#~ msgid "vector, extract"
#~ msgstr "Vektor, extrahieren"
-#~ msgid ""
-#~ "Selects vector objects from an existing vector map and creates a new map "
-#~ "containing only the selected objects."
-#~ msgstr ""
-#~ "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
-#~ "neue Karte nur mit den selektierten Objekten."
+#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+#~ msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
#~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr ""
-#~ "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+#~ msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
-#~ msgid ""
-#~ "Layer number (if -1, all features in all layers of given type are "
-#~ "extracted)"
-#~ msgstr ""
-#~ "Layernummer (wenn -1, dann werden alle Feature in allen Layern des "
-#~ "angegebenen Typs extrahiert)."
+#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+#~ msgstr "Layernummer (wenn -1, dann werden alle Feature in allen Layern des angegebenen Typs extrahiert)."
-#~ msgid ""
-#~ "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr ""
-#~ "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der "
-#~ "erwünschte NEUE Kategoriewert."
+#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
+#~ msgstr "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der erwünschte NEUE Kategoriewert."
#~ msgid "If new >= 0, table is not copied"
#~ msgstr "Wenn neu >= 0, wird die Tabelle nicht kopiert."
-#~ msgid ""
-#~ "List, file, where and random options are exclusive. Please specify only "
-#~ "one of them"
-#~ msgstr ""
-#~ "Die Optionen list, file, where und random schlieÃen sich gegenseitig aus. "
-#~ "Bitte geben Sie nur eine von diesen an."
+#~ msgid "List, file, where and random options are exclusive. Please specify only one of them"
+#~ msgstr "Die Optionen list, file, where und random schlieÃen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
#~ msgid "Layer 0 not supported"
#~ msgstr "Layer 0 wird nicht unterstützt."
@@ -45278,12 +41632,8 @@
#~ msgid "%d categories loaded from table <%s>"
#~ msgstr "%d Kategorien von der Tabelle <%s> geladen."
-#~ msgid ""
-#~ "Random category count is larger or equal to uniq \"%s\" feature category "
-#~ "count %d"
-#~ msgstr ""
-#~ "Die Zahl der zufälligen Kategorien ist gröÃer oder gleich der Zahl der "
-#~ "eindeutigen \"%s\" Feature Kategorien %d."
+#~ msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
+#~ msgstr "Die Zahl der zufälligen Kategorien ist gröÃer oder gleich der Zahl der eindeutigen \"%s\" Feature Kategorien %d."
#~ msgid "vector, database, attribute table"
#~ msgstr "Vektor, Datenbank, Attributtabelle"
@@ -45292,8 +41642,7 @@
#~ msgstr "Name der Schlüsselspalte."
#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr ""
-#~ "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+#~ msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
#~ msgid "When printing, limit to layer specified by the layer option"
#~ msgstr "Beim Druck auf die Layer in der Layer-Option beschränken"
@@ -45305,14 +41654,10 @@
#~ msgstr "Berechne Flächenzentroide..."
#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr ""
-#~ "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-"
-#~ "Vektordatei."
+#~ msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr ""
-#~ "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von "
-#~ "der Standardeingabe gelesen."
+#~ msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von der Standardeingabe gelesen."
#~ msgid ""
#~ "Unexpected data in vector head:\n"
@@ -45352,8 +41697,7 @@
#~ msgstr "Vektordatei die Beispielpunkte enthält."
#~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr ""
-#~ "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+#~ msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
#~ msgid "Vector map to store differences"
#~ msgstr "Vektorkarte, die die Unterschiede beinhalten soll."
@@ -45361,24 +41705,17 @@
#~ msgid "Raster map to be sampled"
#~ msgstr "Rasterkarte, die abgefragt wird."
-#~ msgid ""
-#~ "Option scaling factor for values read from raster map. Sampled values "
-#~ "will be multiplied by this factor"
-#~ msgstr ""
-#~ "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
-#~ "diesem Faktor multipliziert."
+#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
+#~ msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
#~ msgid "Bilinear interpolation (default is nearest neighbor)"
#~ msgstr "Bilineare Interpolation (Standard: Nächster Nachbar)."
#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr ""
-#~ "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
+#~ msgstr "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
#~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#~ msgstr ""
-#~ "Die Schalter -b und -c schlieÃen sich gegenseitig aus. Bitte wählen Sie "
-#~ "nur Einen."
+#~ msgstr "Die Schalter -b und -c schlieÃen sich gegenseitig aus. Bitte wählen Sie nur Einen."
#~ msgid "Checking vector points..."
#~ msgstr "Prüfe Vektorpunkte..."
@@ -45389,11 +41726,8 @@
#~ msgid "Layer number (to)"
#~ msgstr "Layer-Nummer (to)."
-#~ msgid ""
-#~ "Name of table created for output when the distance to all flag is used"
-#~ msgstr ""
-#~ "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu "
-#~ "Allen' gesetzt wurde."
+#~ msgid "Name of table created for output when the distance to all flag is used"
+#~ msgstr "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
#~ msgid "Finding nearest lines..."
#~ msgstr "Finde nächste Linien..."
@@ -45404,15 +41738,11 @@
#~ msgid "Query layer number (read from)"
#~ msgstr "Abfragelayernummer (lesen)"
-#~ msgid ""
-#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d"
-#~ "(egrees)"
-#~ msgstr ""
-#~ "mi(len),f(uÃ),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
+#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+#~ msgstr "mi(len),f(uÃ),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr ""
-#~ "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+#~ msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
#~ msgid "region;current region;coor;use 'coor' and 'box' options"
#~ msgstr "region;aktuelle Region;coor;Verwende die 'coor' und 'box' Optionen"
@@ -45430,9 +41760,7 @@
#~ msgstr "Vektorkarte mit Stichprobenpunkten."
#~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr ""
-#~ "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
-#~ "ausgegeben."
+#~ msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
#~ msgid "Counting sites in quadrats..."
#~ msgstr "Zähle Sites in den Quadraten..."
@@ -45441,23 +41769,8 @@
#~ msgstr "Vektor, Kategorie "
#~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr ""
-#~ "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+#~ msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
-#~ msgid ""
-#~ "add;add a new category;del;delete all categories of given layer;chlayer;"
-#~ "change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add "
-#~ "the value specified by cat option to the current category value;report;"
-#~ "print report (statistics), in shell style: layer type count min max;print;"
-#~ "print category values, more cats in the same layer are separated by '/'"
-#~ msgstr ""
-#~ "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines "
-#~ "gegebenen Layers;chlayer;Ãndere die Layer-Nummer (z.B. layer=3,1 ändert "
-#~ "von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option "
-#~ "'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht "
-#~ "(Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe "
-#~ "Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
#~ msgid "vector, network, flow"
#~ msgstr "Vektor, Netzwerk, Fluss"
@@ -45489,8 +41802,7 @@
#~ msgstr "Linien-Buffer... "
#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr ""
-#~ "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
+#~ msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
#~ msgid "Areas buffers... "
#~ msgstr "Flächen-Buffer ..."
@@ -45523,8 +41835,7 @@
#~ msgstr "Ausgabekarte mit mittlerer Wölbung."
#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr ""
-#~ "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
+#~ msgstr "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
#~ msgid "Output vector map showing quadtree segmentation"
#~ msgstr "Ausgabe-Vektorkarte mit der 'quadtree'-Segmentierung."
@@ -45532,22 +41843,14 @@
#~ msgid "Output vector map showing overlapping windows"
#~ msgstr "Ausgabe-Vektordatei, die die überlappenden Segmente beinhaltet."
-#~ msgid ""
-#~ "Name of the attribute column with values to be used for approximation (if "
-#~ "layer>0)"
-#~ msgstr ""
-#~ "Name der Attributspalte mit Werten, die für die Approximation verwendet "
-#~ "werden (wen der Layer >0)."
+#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
+#~ msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
#~ msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
-#~ msgstr ""
-#~ "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist "
-#~ "erlaubt."
+#~ msgstr "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist erlaubt."
#~ msgid "Only smoothing column defined, zcol or -z flag is missing"
-#~ msgstr ""
-#~ "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z "
-#~ "fehlt."
+#~ msgstr "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z fehlt."
#~ msgid ""
#~ "Processing all selected output files\n"
@@ -45557,9 +41860,7 @@
#~ "Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
#~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr ""
-#~ "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu "
-#~ "erhöhen."
+#~ msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
#~ msgid "Reading coordinates from file."
#~ msgstr "Lese Koordinaten aus Datei."
@@ -45591,42 +41892,23 @@
#~ msgid "Suppress display of residuals or other information"
#~ msgstr "Unterdrücke die Darstellung der Residuen oder anderer Informationen"
-#~ msgid ""
-#~ "Instead of points use transformation parameters (xshift, yshift, zshift, "
-#~ "xscale, yscale, zscale, zrot)"
-#~ msgstr ""
-#~ "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, "
-#~ "zshift, xscale, yscale, zscale, zrot)."
+#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
+#~ msgstr "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
#~ msgid "ASCII file holding transform coordinates"
#~ msgstr "ASCII-Datei mit den Transformationskoordinaten"
-#~ msgid ""
-#~ "If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-#~ "yscale, zscale, zrot) are used instead"
-#~ msgstr ""
-#~ "Wenn nicht gegeben, verwende verwende stattdessen "
-#~ "Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, "
-#~ "zrot)."
+#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
+#~ msgstr "Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
-#~ msgid ""
-#~ "The '%c' flag is deprecated and will be removed in future. Transformation "
-#~ "parameters are used automatically when no pointsfile is given."
-#~ msgstr ""
-#~ "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden "
-#~ "sein. Transformationsparameter werden automatisch verwendet wenn kein "
-#~ "pointsfile angegeben wurde."
+#~ msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
+#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Transformationsparameter werden automatisch verwendet wenn kein pointsfile angegeben wurde."
-#~ msgid ""
-#~ "The '%c' flag is deprecated and will be removed in future. Please use '--"
-#~ "quiet' instead."
-#~ msgstr ""
-#~ "sein. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Bitte verwenden Sie stattdessen '--quiet'."
#~ msgid "Column names are not defined. Please use '%s' parameter."
-#~ msgstr ""
-#~ "Spaltennamen sind nicht definiert. Bitte verwenden Sie den Parameter '%s'."
+#~ msgstr "Spaltennamen sind nicht definiert. Bitte verwenden Sie den Parameter '%s'."
#~ msgid "Please specify a valid layer with '%s' parameter."
#~ msgstr "Bitte geben Sie mit dem Parameter '%s' einen gültigen Layer an."
@@ -45660,33 +41942,22 @@
#~ msgstr "Entmischung fehlgeschlagen."
#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr ""
-#~ "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn "
-#~ "layer > 0)."
+#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn layer > 0)."
#~ msgid "Need either 3D vector or layer and column with z values"
-#~ msgstr ""
-#~ "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
+#~ msgstr "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
#~ msgid "Layer but not column with z values given"
#~ msgstr "Ein Layer aber keine Spalte mit Z-Werten erhalten."
-#~ msgid ""
-#~ "Sorry, <%s> driver is not allowed for vector output in this module. Try "
-#~ "with a raster output or other driver."
-#~ msgstr ""
-#~ "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
-#~ "erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
+#~ msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
+#~ msgstr "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
#~ msgid "Cannot read field info"
#~ msgstr "Kann Feld-Information nicht lesen."
-#~ msgid ""
-#~ "Cannot allocate memory for auxiliar matrix.Consider changing region "
-#~ "resolution"
-#~ msgstr ""
-#~ "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die "
-#~ "Auflösung der Region zu ändern."
+#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
+#~ msgstr "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die Auflösung der Region zu ändern."
#~ msgid "vector, reclass, attributes"
#~ msgstr "Vektor, Re-Klassifizierung, Attribute"
@@ -45722,23 +41993,17 @@
#~ msgstr "Vektor, External, Import"
#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr ""
-#~ "Erzeugt eine neue Vektorkarte als einen ausschlieÃlich lesbaren Link zu "
-#~ "einem OGR-Layer."
+#~ msgstr "Erzeugt eine neue Vektorkarte als einen ausschlieÃlich lesbaren Link zu einem OGR-Layer."
#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr ""
-#~ "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer "
-#~ "lediglichangezeigt."
+#~ msgstr "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer lediglichangezeigt."
#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. "
-#~ "Examples:\n"
+#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
#~ "\t\tESRI Shapefile: shapefile name\n"
#~ "\t\tMapInfo File: mapinfo file name"
#~ msgstr ""
-#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen "
-#~ "lediglich angezeigt. Beispiele:\n"
+#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen lediglich angezeigt. Beispiele:\n"
#~ "\t\tESRI Shapefile: Name des Shapefiles\n"
#~ "\t\tMapInfo File: Name der MapInfo-Datei"
@@ -45754,27 +42019,17 @@
#~ msgid "Doing log transformation"
#~ msgstr "Führe log Transformation aus."
-#~ msgid ""
-#~ "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr ""
-#~ "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
+#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgstr "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
-#~ msgid ""
-#~ "Feature type(s). Combinations not supported by all output formats. "
-#~ "Default: first type found in input."
-#~ msgstr ""
-#~ "Feature-Typ(en): Kombinationen der Typen wird nicht von allen Formaten "
-#~ "unterstützt. Standard: der erste in der Eingabe gefundene Typ."
+#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
+#~ msgstr "Feature-Typ(en): Kombinationen der Typen wird nicht von allen Formaten unterstützt. Standard: der erste in der Eingabe gefundene Typ."
#~ msgid "OGR format"
#~ msgstr "OGR-Format."
-#~ msgid ""
-#~ "Export features with category (labeled) only. Otherwise all features are "
-#~ "exported"
-#~ msgstr ""
-#~ "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten "
-#~ "werden alle Objekte exportiert."
+#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
+#~ msgstr "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
#~ msgid "Skipping all boundaries that are not part of an area."
#~ msgstr "Ãberspringe alle Grenzen, die nicht zu einer Fläche gehören."
@@ -45785,97 +42040,44 @@
#~ msgid "Could not determine input map's feature type(s)."
#~ msgstr "Der Objekttyp der Eingabekarte konnte nicht bestimmt werden."
-#~ msgid ""
-#~ "The map contains islands. To preserve them in the output map, use the -c "
-#~ "flag"
-#~ msgstr ""
-#~ "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der "
-#~ "Ausgabe-Karte zu erhalten."
+#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
+#~ msgstr "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der Ausgabe-Karte zu erhalten."
-#~ msgid ""
-#~ "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr ""
-#~ "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
-#~ "Ãberprüfen Sie bitte den 'type'-Parameter."
+#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
+#~ msgstr "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie bitte den 'type'-Parameter."
-#~ msgid ""
-#~ "%d kernel(s) found, but not requested to be exported. Verify 'type' "
-#~ "parameter."
-#~ msgstr ""
-#~ "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. "
-#~ "Ãberprüfen Sie den Parameter 'type'."
+#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
+#~ msgstr "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. Ãberprüfen Sie den Parameter 'type'."
-#~ msgid ""
-#~ "No points found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Punkte gefunden, die allerdings exportiert werden sollen. "
-#~ "Ãberspringe diesen Geometrie-Typ."
+#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Punkte gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometrie-Typ."
-#~ msgid ""
-#~ "No lines found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Linien gefunden, die allerdings exportiert werden sollen. "
-#~ "Ãberspringe diesen Geometry-Typ."
+#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Linien gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No boundaries found, but requested to be exported. Will skip this "
-#~ "geometry type."
-#~ msgstr ""
-#~ "Keine Grenzen gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Grenzen gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No areas found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Flächen gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Flächen gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No centroids found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Zentroide gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Zentroide gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No faces found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Faces gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Faces gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No kernels found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Kerne gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Kerne gefunden, die allerdings exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No volumes found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Ãberspringe "
-#~ "diesen Geometry-Typ."
+#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Ãberspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "Vector map <%s> is 3D. Use format specific layer creation options "
-#~ "(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#~ msgstr ""
-#~ "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
-#~ "Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und "
-#~ "nicht 2D (Standard) zu exportieren"
+#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und nicht 2D (Standard) zu exportieren"
-#~ msgid ""
-#~ "(parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr ""
-#~ "Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D "
-#~ "(Standard) zu exportieren."
+#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
+#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
#~ msgid "Key column '%s' not found"
#~ msgstr "Schlüsselspalte '%s' nicht gefunden."
@@ -45887,8 +42089,7 @@
#~ msgstr "Exportiere %i 3D-Flächen (kann eine Weile dauern)..."
#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr ""
-#~ "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
+#~ msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
#~ msgid "Patching vector map <%s@%s>..."
#~ msgstr "Kombiniere Vektorkarte <%s@%s>..."
@@ -45925,54 +42126,13 @@
#~ "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
#~ msgstr ""
#~ "\n"
-#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, "
-#~ "z.B. %.2f %%"
+#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
-#~ msgid ""
-#~ "break;break lines at each intersection;rmdupl;remove duplicate geometry "
-#~ "features (pay attention to categories!);rmdangle;remove dangles, "
-#~ "threshold ignored if < 0;chdangle;change the type of boundary dangle to "
-#~ "line, threshold ignored if < 0, input line type is ignored;rmbridge;"
-#~ "remove bridges connecting area and island or 2 islands;chbridge;change "
-#~ "the type of bridges connecting area and island or 2 islands from boundary "
-#~ "to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate "
-#~ "area centroids ('type' option ignored);bpol;break (topologically clean) "
-#~ "polygons (imported from non topological format, like ShapeFile). "
-#~ "Boundaries are broken on each point shared between 2 and more polygons "
-#~ "where angles of segments are different;prune;remove vertices in threshold "
-#~ "from lines and boundaries, boundary is pruned only if topology is not "
-#~ "damaged (new intersection, changed attachement of centroid), first and "
-#~ "last segment of the boundary is never changed;rmarea;remove small areas, "
-#~ "the longest boundary with adjacent area is removed;rmline;remove all "
-#~ "lines or boundaries of zero length, threshold is ignored;rmsa;remove "
-#~ "small angles between lines at nodes"
-#~ msgstr ""
-#~ "break;Teilt Linien an jeder Ãberschneidung;rmdupl;Entfernt doppelte "
-#~ "Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt "
-#~ "Ãberstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ãndert "
-#~ "den Typ eines Ãberstands (dangle) zu einer Linie, Schwellwert wird "
-#~ "ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt "
-#~ "Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;"
-#~ "Ãndert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln "
-#~ "verbindet von Grenze zu Linie;snap;Snapped Linien auf Vertices innerhalb "
-#~ "des Schwellwertes;rmdac;Entfernt doppelte Zentroide (Option 'type' wird "
-#~ "ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht "
-#~ "topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem "
-#~ "Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der "
-#~ "Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des "
-#~ "Schwellwertes von Linien und Grenzen. Grenzen werden nur gesäubert, wenn "
-#~ "die Topologie nicht beschädigt wird (neue Ãberschneidungen, veränderte "
-#~ "Zuordnung von Zentroiden), das erste und letzte Segment einer Grenze wird "
-#~ "nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer "
-#~ "benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen "
-#~ "mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze "
-#~ "Winkel zwischen Linien an einem Knoten"
+#~ msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove smal
l areas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
+#~ msgstr "break;Teilt Linien an jeder Ãberschneidung;rmdupl;Entfernt doppelte Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt Ãberstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ãndert den Typ eines Ãberstands (dangle) zu einer Linie, Schwellwert wird ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;Ãndert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln verbindet von Grenze zu Linie;snap;Snapped Linien auf Vertices innerhalb des Schwellwertes;rmdac;Entfernt doppelte Zentroide (Option 'type' wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von Linien und Grenzen. Grenze
n werden nur gesäubert, wenn die Topologie nicht beschädigt wird (neue Ãberschneidungen, veränderte Zuordnung von Zentroiden), das erste und letzte Segment einer Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien an einem Knoten"
-#~ msgid ""
-#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr ""
-#~ "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug "
-#~ "(Standard: 0.0[,0.0,...])."
+#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
#~ msgid "Copying vector lines..."
#~ msgstr "Kopiere Vektorlinien..."
@@ -45995,18 +42155,11 @@
#~ msgid "Vector points to be spatially perturbed"
#~ msgstr "Vektorpunkte die räumlich gestört werden sollen."
-#~ msgid ""
-#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
-#~ "parameter, the maximum, is needed. For a normal distribution, two "
-#~ "parameters, the mean and standard deviation, are required."
-#~ msgstr ""
-#~ "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
-#~ "nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
-#~ "zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+#~ msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
#~ msgid "New points are excluded from shortest path calculations."
-#~ msgstr ""
-#~ "Neue Punkte werden aus der Berechnung der kürzesten Pfade ausgeschlossen."
+#~ msgstr "Neue Punkte werden aus der Berechnung der kürzesten Pfade ausgeschlossen."
#~ msgid "vector, metadata, history"
#~ msgstr "Vektor, Metadaten, history"
@@ -46017,10 +42170,8 @@
#~ msgid "Print vector history instead of info"
#~ msgstr "Gebe den Werdegang anstelle einer Info aus."
-#~ msgid ""
-#~ "Print types/names of table columns for specified layer instead of info"
-#~ msgstr ""
-#~ "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+#~ msgid "Print types/names of table columns for specified layer instead of info"
+#~ msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
#~ msgid "Print topology information only"
#~ msgstr "Gebe nur Informationen zur Topologie aus."
@@ -46113,8 +42264,7 @@
#~ msgstr "Vektor, Raster, Attributtabelle"
#~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr ""
-#~ "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+#~ msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
#~ msgid "Column name (will be updated by raster values)"
#~ msgstr "Spaltenname (die mit den Rasterwerten aktualisiert wird)."
@@ -46126,9 +42276,7 @@
#~ msgstr "Zielknoten [%d] ist nicht erreichbar von Knoten [%d]."
#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr ""
-#~ "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
-#~ "Layern."
+#~ msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
#~ msgid "Output vector map where points will be written"
#~ msgstr "Ausgabe-Vektorkarte, in welche die Punkten geschrieben werden"
@@ -46152,8 +42300,7 @@
#~ msgstr "Presse Vektor Primitive..."
#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr ""
-#~ "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
+#~ msgstr "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
#~ msgid "Type: %s"
#~ msgstr "Typ: %s"
@@ -46167,12 +42314,8 @@
#~ msgid "If not given reads from standard input"
#~ msgstr "Wenn nicht gegeben, lese von der Standardeingabe"
-#~ msgid ""
-#~ "vector, generalization, simplification, smoothing, displacement, network "
-#~ "generalization"
-#~ msgstr ""
-#~ "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-"
-#~ "Generalisierung"
+#~ msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
+#~ msgstr "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-Generalisierung"
#~ msgid "Vector based generalization."
#~ msgstr "Vektorbasierte Generalisierung."
@@ -46186,11 +42329,8 @@
#~ msgid "vector, volume, conversion"
#~ msgstr "Vektor, Volumen, Konvertierung"
-#~ msgid ""
-#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-#~ "raster map layer."
-#~ msgstr ""
-#~ "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D-Rasterkarte. "
+#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+#~ msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D-Rasterkarte. "
#~ msgid "Column name (type must be numeric)"
#~ msgstr "Spaltenname (Spaltentyp muss numerisch sein)."
@@ -46198,20 +42338,11 @@
#~ msgid "Cannot allocate %d bytes of memory"
#~ msgstr "Kann nicht %d Byte Speicher reservieren."
-#~ msgid ""
-#~ "Cannot load overlap weights. Column %s is not of numeric type in table <"
-#~ "%s>"
-#~ msgstr ""
-#~ "Kann die Ãberlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <"
-#~ "%s> ist nicht numerisch."
+#~ msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+#~ msgstr "Kann die Ãberlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%s> ist nicht numerisch."
-#~ msgid ""
-#~ "Numeric column to give precedence in case of overlapping labels. The "
-#~ "label with a smaller weight is hidden."
-#~ msgstr ""
-#~ "Numerische Spalte mit Werten, um den Vorrang bei überlappenden "
-#~ "Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird "
-#~ "verdeckt."
+#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
+#~ msgstr "Numerische Spalte mit Werten, um den Vorrang bei überlappenden Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird verdeckt."
#~ msgid "%s: Unable to read font definition file; use the default"
#~ msgstr "%s: Kann die Font Definitionsdatei nicht lesen; nehme den Standard."
@@ -46223,9 +42354,7 @@
#~ msgstr "Vektor, Import, Datenbank, Punkte"
#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr ""
-#~ "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-"
-#~ "Vektoren)."
+#~ msgstr "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
#~ msgid "Attribute table column with values to interpolate"
#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
@@ -46233,11 +42362,8 @@
#~ msgid "Required if layer > 0"
#~ msgstr "Erfordert wenn Layer >0"
-#~ msgid ""
-#~ "Power parameter; greater values assign greater influence to closer points"
-#~ msgstr ""
-#~ "Power-Parameter; gröÃere Werte geben ein näheren Punkten ein stärkeres "
-#~ "Gewicht."
+#~ msgid "Power parameter; greater values assign greater influence to closer points"
+#~ msgstr "Power-Parameter; gröÃere Werte geben ein näheren Punkten ein stärkeres Gewicht."
#~ msgid "No data points found"
#~ msgstr "Keine Datenpunkte gefunden."
@@ -46246,9 +42372,7 @@
#~ msgstr "Liest die Vertices einer Vektorlinie"
#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr ""
-#~ "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. "
-#~ "Beende mich."
+#~ msgstr "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. Beende mich."
#~ msgid "Exports GRASS vector map layers to DXF file format."
#~ msgstr "Exportiert GRASS Vektorkarten in das DXF-Dateiformat."
@@ -46262,11 +42386,8 @@
#~ msgid "Layer is only used for WHERE SQL statement"
#~ msgstr "Layer wird nur für WHERE SQL Ausdrücke verwendet."
-#~ msgid ""
-#~ "No features drapped. Check Your computational region and input raster map."
-#~ msgstr ""
-#~ "Keine Feature wurden drapiert. Ãberprüfen Sie die aktuelle Region und die "
-#~ "Eingabe-Rasterkarte."
+#~ msgid "No features drapped. Check Your computational region and input raster map."
+#~ msgstr "Keine Feature wurden drapiert. Ãberprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
#~ msgid "vector, network, connectivity"
#~ msgstr "Vektor, Netzwerk, Konnektivität"
@@ -46311,8 +42432,7 @@
#~ msgstr "Kann nicht zu MySQL verbinden."
#~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr ""
-#~ "Kann den Name der eingebetteten MySQL-Datenbank nicht interpretieren."
+#~ msgstr "Kann den Name der eingebetteten MySQL-Datenbank nicht interpretieren."
#~ msgid "Cannot connect to MySQL embedded server: "
#~ msgstr "Kann mich nicht mit dem eingebetteten MySQL-Server verbinden."
@@ -46341,11 +42461,8 @@
#~ msgid "Cannot recognize boolean value"
#~ msgstr "Kann den Boolean-Wert nicht erkennen."
-#~ msgid ""
-#~ "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
-#~ msgstr ""
-#~ "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht "
-#~ "konvertiert."
+#~ msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
+#~ msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht konvertiert."
#~ msgid "pg driver: column '%s', type %d is not supported"
#~ msgstr "PG-Treiber: Spalte '%s', Typ %d wird nicht unterstützt."
@@ -46363,16 +42480,10 @@
#~ msgstr "Datenbank, Attributtabelle, Verbindungseinstellungen"
#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr ""
-#~ "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
-#~ "beendet sich."
+#~ msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
-#~ msgid ""
-#~ "Do not use this option if schemas are not supported by driver/database "
-#~ "server"
-#~ msgstr ""
-#~ "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre "
-#~ "Datenbank / Server unterstützt werden."
+#~ msgid "Do not use this option if schemas are not supported by driver/database server"
+#~ msgstr "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre Datenbank / Server unterstützt werden."
#~ msgid "Error trying to read dbmscap file"
#~ msgstr "Fehler beim Lesen der dbmscap Datei"
@@ -46393,9 +42504,7 @@
#~ msgstr "Name der Datei, die SQL-Befehle enthält"
#~ msgid "Selects data from attribute table (performs SQL query statement(s))."
-#~ msgstr ""
-#~ "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) "
-#~ "aus)."
+#~ msgstr "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) aus)."
#~ msgid "database, connection settings"
#~ msgstr "Datenbank, Verbindungseinstellungen"
@@ -46445,12 +42554,8 @@
#~ msgid "general, manual, help"
#~ msgstr "Allgemein, Handbuch, Hilfe"
-#~ msgid ""
-#~ "Calculates univariate statistics from a raster map based on vector "
-#~ "polygons and uploads statistics to new attribute columns."
-#~ msgstr ""
-#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
-#~ "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+#~ msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
#~ msgid "vector, raster, statistics"
#~ msgstr "Vektor, Raster, Statistik"
@@ -46458,19 +42563,14 @@
#~ msgid "Name of vector polygon map"
#~ msgstr "Name der Vektorkarte (Polygone)."
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use"
-#~ msgstr ""
-#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
+#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#~ msgid "Name of raster map to calculate statistics from"
#~ msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr ""
-#~ "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
+#~ msgstr "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
#~ msgid "display, export, GPS"
#~ msgstr "Anzeige, Export, GPS"
@@ -46482,8 +42582,7 @@
#~ msgstr "Erstelle ein JPEG anstelle des PNG Bildes."
#~ msgid "Base name for red, green and blue output maps containing the blend"
-#~ msgstr ""
-#~ "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+#~ msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
#~ msgid "display, vector, thematic, legend"
#~ msgstr "Darstellung, Vektor, thematisch, Legende"
@@ -46513,18 +42612,13 @@
#~ msgstr "Zeichnen aller Fenster erneut."
#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr ""
-#~ "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
+#~ msgstr "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
#~ msgid "Set color rules based on stddev from a map's mean value."
#~ msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
-#~ msgid ""
-#~ "The database must be in form printed by v.db.connect -g, i.e. with "
-#~ "substituted variables"
-#~ msgstr ""
-#~ "Die Datenbank muà in der Form angegeben werden , wie sie von v.db.connect "
-#~ "-g ausgegeben wird, z.B mit ersetzten Variablen."
+#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+#~ msgstr "Die Datenbank muà in der Form angegeben werden , wie sie von v.db.connect -g ausgegeben wird, z.B mit ersetzten Variablen."
#~ msgid "Old schema"
#~ msgstr "Altes Schema"
@@ -46533,9 +42627,7 @@
#~ msgstr "Neues Schema"
#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr ""
-#~ "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im "
-#~ "Heimat-Verzeichnis."
+#~ msgstr "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im Heimat-Verzeichnis."
#~ msgid "display, export"
#~ msgstr "Anzeige, Export"
@@ -46565,12 +42657,10 @@
#~ msgstr "Name der optionalen EPS-Ausgabedatei."
#~ msgid "Join column in map table"
-#~ msgstr ""
-#~ "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
+#~ msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
#~ msgid "Join column in other table"
-#~ msgstr ""
-#~ "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
+#~ msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
#~ msgid "raster, mask"
#~ msgstr "Raster, Maske"
@@ -46579,9 +42669,7 @@
#~ msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr ""
-#~ "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 "
+#~ msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
#~ msgid "Create inverse MASK from specified 'maskcats' list"
#~ msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste."
@@ -46598,23 +42686,17 @@
#~ msgid "Region sensitive output"
#~ msgstr "Regionsensitive Ausgabe"
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed"
-#~ msgstr ""
-#~ "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
-#~ "Optionen angegeben werden."
+#~ msgid "Creation option to the output format driver. Multiple options may be listed"
+#~ msgstr "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere Optionen angegeben werden."
#~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr ""
-#~ "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
+#~ msgstr "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
#~ msgid "Name of data table"
#~ msgstr "Name der Datentabelle"
#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr ""
-#~ "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+#~ msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
#~ msgid "Database/directory for table"
#~ msgstr "Datenbank/Verzeichnis welches die Tabelle enthält."
@@ -46641,9 +42723,7 @@
#~ msgstr "Zeige eher Vektorkarten als Rasterkarten."
#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr ""
-#~ "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten "
-#~ "anzusehen."
+#~ msgstr "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten anzusehen."
#~ msgid "Map number show across the monitor"
#~ msgstr "Zeige die Kartenummer waagerecht im Grafikfenster."
@@ -46652,9 +42732,7 @@
#~ msgstr "Zeige die Kartenummer senkrecht im Grafikfenster."
#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr ""
-#~ "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt "
-#~ "an."
+#~ msgstr "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt an."
#~ msgid "Number of seconds to pause between slides"
#~ msgstr "Pause zwischen den Bildern in Sekunden."
@@ -46749,8 +42827,7 @@
#~ msgid "Select multiple points"
#~ msgstr "Selektiere mehrere Punkte."
-#~ msgid ""
-#~ "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
#~ msgstr "."
#~ msgid "Name of raster plane to be created"
@@ -46763,8 +42840,7 @@
#~ msgstr "Ausrichtung der Ebene. Wert muà zwischen 0 und 360 Grad liegen"
#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr ""
-#~ "Selektiert/Startet das angegebene Grafikfenster in der angegebenen GröÃe."
+#~ msgstr "Selektiert/Startet das angegebene Grafikfenster in der angegebenen GröÃe."
#~ msgid "Display monitor to start"
#~ msgstr "Grafikfensters, das gestartet werden soll."
@@ -46781,12 +42857,8 @@
#~ msgid "Uncompressed geonames file from (with .txt extension)"
#~ msgstr "Unkomprimierte geonames-Datei (mit der Dateiendung .txt)."
-#~ msgid ""
-#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-#~ "vector map."
-#~ msgstr ""
-#~ "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine "
-#~ "Vektorkarte."
+#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+#~ msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine Vektorkarte."
#~ msgid "vector, import, GPS"
#~ msgstr "Vektor, Import, GPS"
@@ -46815,22 +42887,14 @@
#~ msgid "Port Garmin receiver is connected to"
#~ msgstr "Das Garmin-Gerät ist verbunden mit Port "
-#~ msgid ""
-#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-#~ "using gdalwarp."
-#~ msgstr ""
-#~ "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und "
-#~ "relative DGMs mit Hilfe von gdalwarp."
+#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+#~ msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
#~ msgid "Input ASTER image to be georeferenced & rectified"
#~ msgstr "Eingabe-ASTER-Bild, das georeferenziert und rektifiziert wird."
-#~ msgid ""
-#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-#~ "single band"
-#~ msgstr ""
-#~ "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
-#~ "einzelnen Kanal umrechnen."
+#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+#~ msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
#~ msgid "Table to drop"
#~ msgstr "Tabelle die gelöscht werden soll."
@@ -46845,8 +42909,7 @@
#~ msgstr "Ausgabe-Rasterkarte (Standard: Eingabekachel)."
#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr ""
-#~ "Speichert den Inhalte des aktiven Grafikfensters in einer Grafikdatei."
+#~ msgstr "Speichert den Inhalte des aktiven Grafikfensters in einer Grafikdatei."
#~ msgid "Name for output file (do NOT add extension)"
#~ msgstr "Name für die Ausgabedatei (Fügen Sie keine Dateiendung an)."
@@ -46861,17 +42924,13 @@
#~ msgstr "Bilder"
#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr ""
-#~ "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der "
-#~ "Auflösung)."
+#~ msgstr "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der Auflösung)."
#~ msgid "Compression for PNG files"
#~ msgstr "Komprimierung für PNG-Dateien."
#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr ""
-#~ "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. "
-#~ "DateigröÃe)."
+#~ msgstr "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. DateigröÃe)."
#~ msgid "File size/quality for JPEG files"
#~ msgstr "DateigröÃe/-qualität für JPEG-Dateien."
@@ -46897,11 +42956,8 @@
#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
#~ msgstr "GeoTIFF Metadaten Schlüsselwort(e) und Wert(e)"
-#~ msgid ""
-#~ "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr ""
-#~ "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas "
-#~ "voneinander."
+#~ msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+#~ msgstr "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas voneinander."
#~ msgid "Set background color to black (white default)"
#~ msgstr "Setze die Hintergrundfarbe auf schwarz (Standard: weiÃ)."
@@ -46913,9 +42969,7 @@
#~ msgstr "Verwende der Cairo-Treiber um das Bild zu rendern."
#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr ""
-#~ "Stelle die Orientierung der Seite auf Querformat (für die PostScript-"
-#~ "Ausgabe)."
+#~ msgstr "Stelle die Orientierung der Seite auf Querformat (für die PostScript-Ausgabe)."
#~ msgid "Do not crop away margins"
#~ msgstr "Schneide die Ränder nicht ab."
@@ -46926,12 +42980,8 @@
#~ msgid "Name of vector map for which to edit attribute table"
#~ msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
-#~ msgid ""
-#~ "number determines which table to use."
-#~ msgstr ""
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
#~ msgid "Vector map to edit the attribute table for"
#~ msgstr "Vektorkarte deren Attributtabelle edtiert werden soll."
@@ -46942,31 +42992,20 @@
#~ msgid "Column to update"
#~ msgstr "Spalte, die aktualisiert werden soll"
-#~ msgid ""
-#~ "Value to update the column with (varchar values have to be in single "
-#~ "quotes, e.g. 'grass')"
-#~ msgstr ""
-#~ "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
-#~ "einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+#~ msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
+#~ msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
#~ msgid "Column to query"
#~ msgstr "Spalte, die abgefragt werden soll"
-#~ msgid ""
-#~ "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-#~ "col2>1)"
-#~ msgstr ""
-#~ "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z."
-#~ "B. cat=1 or col1/col2>1)."
+#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
+#~ msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
#~ msgid "GRASS table name"
#~ msgstr "GRASS Tabellenname"
-#~ msgid ""
-#~ "Set color rules for features in a vector using a numeric attribute column."
-#~ msgstr ""
-#~ "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
-#~ "numerischen Spalte der Attributtabelle."
+#~ msgid "Set color rules for features in a vector using a numeric attribute column."
+#~ msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
#~ msgid "vector, color table"
#~ msgstr "Vektor, Farbtabellen"
@@ -47020,18 +43059,13 @@
#~ msgstr "Vektor, Zentroid, Fläche"
#~ msgid "Vector map for which to add new attribute table"
-#~ msgstr ""
-#~ "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
+#~ msgstr "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
#~ msgid "Layer where to add new attribute table"
#~ msgstr "Layer in dem die neue Attributtabelle hinzugefügt werden soll."
-#~ msgid ""
-#~ "Name and type of the new column(s) (types depend on database backend, but "
-#~ "all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr ""
-#~ "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank "
-#~ "ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
+#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+#~ msgstr "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
#~ msgid "Vector map for which to rename attribute column"
#~ msgstr "Vektorkarte, für die eine Spalte umbenannt werden soll."
@@ -47103,9 +43137,7 @@
#~ msgstr "Position der vertikalen Legenden Trennelemente (in Prozent)."
#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr ""
-#~ "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
-#~ "Frontend)."
+#~ msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
#~ msgid "miscellaneous, projection"
#~ msgstr "Verschiedenes, Projektion"
@@ -47114,27 +43146,19 @@
#~ msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
#~ msgid "Output coordinate file (omit to send to stdout)"
-#~ msgstr ""
-#~ "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben "
-#~ "werden soll)."
+#~ msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
-#~ msgid ""
-#~ "Script style output in CSV format respecting the field separator settings"
-#~ msgstr ""
-#~ "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-"
-#~ "Einstellungen."
+#~ msgid "Script style output in CSV format respecting the field separator settings"
+#~ msgstr "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-Einstellungen."
#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr ""
-#~ "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr "
-#~ "aus)."
+#~ msgstr "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr aus)."
#~ msgid "raster, imagery, statistics"
#~ msgstr "Raster, Bildverarbeitung, Statistik"
#~ msgid "Vector map for which to drop attribute column"
-#~ msgstr ""
-#~ "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
+#~ msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
#~ msgid "Layer where to drop column"
#~ msgstr "Layer, in dem eine Spalte gelöscht werden soll."
@@ -47146,8 +43170,7 @@
#~ msgstr "Vektorkarte, von der die Attributtabelle gelöscht werden soll."
#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr ""
-#~ "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
+#~ msgstr "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
#~ msgid "Layer from which to drop linked attribute table"
#~ msgstr "Layer aus dem die Attributtabelle gelöscht werden soll."
@@ -47161,12 +43184,8 @@
#~ msgid "Split horizontally not vertically"
#~ msgstr "Teile horizontal und nicht vertikal."
-#~ msgid ""
-#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-#~ "file into a vector map."
-#~ msgstr ""
-#~ "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer "
-#~ "GPS-Download-Datei in eine Vektorkarte. "
+#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+#~ msgstr "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-Download-Datei in eine Vektorkarte. "
#~ msgid "Import waypoints"
#~ msgstr "Importiere Wegpunkte"
@@ -47184,23 +43203,13 @@
#~ msgstr "Gerät oder Datei, von der Daten importiert werden sollen.ei."
#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr ""
-#~ "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte "
-#~ "Formate)."
+#~ msgstr "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
-#~ msgid ""
-#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
-#~ "assumed"
-#~ msgstr ""
-#~ "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/"
-#~ "Lon WGS84 angenommen."
+#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+#~ msgstr "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon WGS84 angenommen."
-#~ msgid ""
-#~ "Exports a vector map to a GPS receiver or file format supported by "
-#~ "GpsBabel."
-#~ msgstr ""
-#~ "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, "
-#~ "das von GpsBabel unterstützt wird."
+#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+#~ msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
#~ msgid "GpsBabel supported output format"
#~ msgstr "GpsBabel unterstütze Ausgabeformate. "
@@ -47215,9 +43224,7 @@
#~ msgstr "Eingabe-Rasterkarte"
#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr ""
-#~ "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *."
-#~ "mosaic-Karten."
+#~ msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
#~ msgid "raster, imagery, mosaicking"
#~ msgstr "Raster, Bildverarbeitung, Mosaikieren"
@@ -47300,25 +43307,17 @@
#~ msgid "raster output TC maps prefix"
#~ msgstr "Präfix für Ausgabe TC-Rasterkarten"
-#~ msgid ""
-#~ "Divides active display into two frames & displays maps/executes commands "
-#~ "in each frame."
-#~ msgstr ""
-#~ "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt "
-#~ "Befehle in beiden Fenstern aus."
+#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+#~ msgstr "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt Befehle in beiden Fenstern aus."
#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr ""
-#~ "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden "
-#~ "soll."
+#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden soll."
#~ msgid "Enter command to execute in 1st frame"
#~ msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr ""
-#~ "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden "
-#~ "soll."
+#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden soll."
#~ msgid "Enter command to execute in 2nd frame"
#~ msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
@@ -47326,11 +43325,8 @@
#~ msgid "How to split display"
#~ msgstr "Wie das Fenster geteilt werden soll"
-#~ msgid ""
-#~ "Brovey transform to merge multispectral and high-res panchromatic channels"
-#~ msgstr ""
-#~ "Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
-#~ "panchromatischer Kanäle."
+#~ msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+#~ msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
#~ msgid "imagery, fusion, Brovey"
#~ msgstr "Bildverarbeitung, Fusion, Brovery"
@@ -47345,9 +43341,7 @@
#~ msgstr "Präfix für die Ausgabe-Rasterkarten (z.B. 'brov')."
#~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr ""
-#~ "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu "
-#~ "verwalten."
+#~ msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
#~ msgid "general, extensions"
#~ msgstr "Allgemein, Erweiterungen"
@@ -47374,14 +43368,10 @@
#~ msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer ausgewählt."
#~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr ""
-#~ "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet "
-#~ "werden soll."
+#~ msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
#~ msgid "Drapes a color raster over a shaded relief map using d.his"
-#~ msgstr ""
-#~ "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
-#~ "Verwendung von d.his."
+#~ msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
#~ msgid "Name of shaded relief or aspect map"
#~ msgstr "Name der Schummerungs- oder Expositionskarte."
@@ -47389,29 +43379,17 @@
#~ msgid "Name of raster to drape over relief map"
#~ msgstr "Name der Rasterkarte die über das Relief drapiertwird."
-#~ msgid ""
-#~ "Converts co-ordinate system descriptions (i.e. projection information) "
-#~ "between various formats (including GRASS format)."
-#~ msgstr ""
-#~ "Konvertiert Beschreibungen von Koordinatensystemen (z.B. "
-#~ "Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-"
-#~ "Formats)."
+#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+#~ msgstr "Konvertiert Beschreibungen von Koordinatensystemen (z.B. Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-Formats)."
#~ msgid "Create/Edit"
#~ msgstr "Erzeuge/Editiere"
-#~ msgid ""
-#~ "Create new projection files (modifies current location unless 'location' "
-#~ "option specified)"
-#~ msgstr ""
-#~ "Erzeuge neue Projektionsdateien. Dies modifiziert die "
-#~ "Projektionsinformationen der aktuellen Location, solange nicht der "
-#~ "Parameter 'location' angegeben ist."
+#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
+#~ msgstr "Erzeuge neue Projektionsdateien. Dies modifiziert die Projektionsinformationen der aktuellen Location, solange nicht der Parameter 'location' angegeben ist."
#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr ""
-#~ "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
-#~ "Befehlszeile)."
+#~ msgstr "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der Befehlszeile)."
#~ msgid "Location %s created!"
#~ msgstr "Location '%s' erstellt!"
@@ -47423,13 +43401,10 @@
#~ msgstr ""
#~ "\n"
#~ "\n"
-#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert "
-#~ "bereits!\n"
+#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert bereits!\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
+#~ msgid "Would you still like to overwrite the current projection information "
+#~ msgstr "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
#~ msgid "Error writing PROJ_INFO"
#~ msgstr "Fehler beim Schreiben der Datei PROJ_INFO."
@@ -47446,12 +43421,8 @@
#~ msgid "Use G3D mask (if exists) with input map"
#~ msgstr "Benutzt G3D Maske (falls existent) mit der Eingabekarte"
-#~ msgid ""
-#~ "No vector map of sparse points to interpolate was specified. "
-#~ "Interpolation will be done with <%s> vector map"
-#~ msgstr ""
-#~ "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die "
-#~ "Interpolation erfolgt mit der <%s> Vektorkarte"
+#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
+#~ msgstr "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die Interpolation erfolgt mit der <%s> Vektorkarte"
#~ msgid "Title, in quotes"
#~ msgstr "Titel, in GänsefüÃchen"
@@ -47525,12 +43496,8 @@
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
-#~ msgid ""
-#~ "The 2d and 3d region settings are different. The g3d settings are used to "
-#~ "adjust the 2d region."
-#~ msgstr ""
-#~ "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter "
-#~ "werden verwendet, um die 2D Region anzupassen."
+#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
+#~ msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter werden verwendet, um die 2D Region anzupassen."
#~ msgid "unable to close input 3d raster map"
#~ msgstr "Kann die Eingabe-3D-Rasterkarte nicht schlieÃen."
@@ -47605,16 +43572,10 @@
#~ msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
#~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr ""
-#~ "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert "
-#~ "haben."
+#~ msgstr "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert haben."
-#~ msgid ""
-#~ "Areas may have disappeared and/or area attribute attachment may have "
-#~ "changed"
-#~ msgstr ""
-#~ "Flächen können verschwunden sein und/oder die Zuordnung der Attribute "
-#~ "kann sich geändert haben."
+#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
+#~ msgstr "Flächen können verschwunden sein und/oder die Zuordnung der Attribute kann sich geändert haben."
#~ msgid "Try v.clean tool=prune thresh=%f"
#~ msgstr "Versuchen Sie v.clean tool=prune thresh=%f"
@@ -47635,9 +43596,7 @@
#~ msgstr " %.1f Zellen pro Minute\n"
#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr ""
-#~ "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> "
-#~ "gespeichert."
+#~ msgstr "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> gespeichert."
#, fuzzy
#~ msgid "Cannot open file [%s] in mapset [%s]"
@@ -47716,8 +43675,7 @@
#~ "Sie müssen zumindest [north= south= east= west=] OR [r=\tc=] angeben."
#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr ""
-#~ "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
+#~ msgstr "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
#~ msgid "Illegal number of rows <%s>"
#~ msgstr "Ungültiger Zeilenanzahl <%s>."
@@ -47761,18 +43719,11 @@
#~ msgid "Unable to write row %d"
#~ msgstr "Kann die Zeile %d nicht schreiben."
-#~ msgid ""
-#~ "Unable to write raster map. You might want to check available disk space "
-#~ "and write permissions."
-#~ msgstr ""
-#~ "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren "
-#~ "Plattenplatz und die Schreibberechtigungen überprüfen."
+#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
+#~ msgstr "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren Plattenplatz und die Schreibberechtigungen überprüfen."
-#~ msgid ""
-#~ "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr ""
-#~ "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie "
-#~ "eine Ausgabedatei benennen."
+#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
+#~ msgstr "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie eine Ausgabedatei benennen."
#~ msgid "%s@%s: projection doesn't match current settings"
#~ msgstr "%s@%s: Projektion passt nicht zu den aktuellen Einstellungen."
@@ -47793,8 +43744,7 @@
#~ msgstr "Mapset der Eingabe-Rasterkarte."
#~ msgid "You have to use a different location for input than the current"
-#~ msgstr ""
-#~ "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
+#~ msgstr "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
#~ msgid "Checking location <%s>, mapset <%s>..."
#~ msgstr "Prüfe Location <%s>, Mapset <%s>..."
@@ -47833,8 +43783,7 @@
#~ msgstr "Zero (0) ist eine reale Höhenangabe"
#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr ""
-#~ " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
+#~ msgstr " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
#~ msgid " long: %f, lat: %f, timezone: %f\n"
#~ msgstr "geogr. Länge: %f, geogr. Breite: %f, Zeitzone: %f\n"
@@ -47901,12 +43850,8 @@
#~ msgid "New MAPSET name"
#~ msgstr "Neuer Mapset Name."
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr ""
-#~ "Stellt Rasterkarten im aktiven Grafikfenster dar. Ãberlagerung ist auch "
-#~ "möglich."
+#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+#~ msgstr "Stellt Rasterkarten im aktiven Grafikfenster dar. Ãberlagerung ist auch möglich."
#~ msgid "Displays vector data in the active frame on the graphics monitor."
#~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafikfenster dar."
@@ -47920,11 +43865,8 @@
#~ msgid "Island size [%.1e], island not imported"
#~ msgstr "InselgröÃe [%.1e], Insel nicht importiert."
-#~ msgid ""
-#~ "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr ""
-#~ "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1) für den "
-#~ "Punkt-Modus genutzt wird."
+#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
+#~ msgstr "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1) für den Punkt-Modus genutzt wird."
#~ msgid "Duplicate area centroids"
#~ msgstr "Doppelte Zentroide"
@@ -47935,14 +43877,8 @@
#~ msgid "Failed in attempt to open %s"
#~ msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-#~ "Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition "
-#~ "werden vom Osten gegen den Uhrzeigersinn berechnet."
+#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+#~ msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition werden vom Osten gegen den Uhrzeigersinn berechnet."
#~ msgid "Raster elevation file name"
#~ msgstr "Rasterkarte mit Höheninformationen."
@@ -47957,12 +43893,10 @@
#~ msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr ""
-#~ "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr ""
-#~ "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
#~ msgid "Output second order partial derivative dxx filename"
#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
@@ -48009,14 +43943,8 @@
#~ msgid "DXY [%s] COMPLETE"
#~ msgstr "DXY [%s] KOMPLETT"
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %g "
-#~ "was used to represent no-data values in the input map. You can specify "
-#~ "nodata value by %s parameter."
-#~ msgstr ""
-#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
-#~ "Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu "
-#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
+#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
#~ msgid "raster, terrain analysis"
#~ msgstr "Raster, Geländeanalyse"
@@ -48040,9 +43968,7 @@
#~ msgstr "Kann die Maske (MASK) nicht öffnen."
#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer "
-#~ "Hülle zu erzeugen."
+#~ msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
#~ msgid "Name of output vector area map"
#~ msgstr "Name der Ausgabe-Vektorkarte mit Flächen."
@@ -48053,22 +43979,14 @@
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "Kann <Auxiliar_outlier_table> nicht erzeugen"
-#~ msgid ""
-#~ "It was not possible to drop <%s> table. Nothing will be done. Try to drop "
-#~ "it manually."
-#~ msgstr ""
-#~ "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird "
-#~ "unternommen. Versuchen Sie die Tabelle manuell zu löschen."
+#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
+#~ msgstr "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird unternommen. Versuchen Sie die Tabelle manuell zu löschen."
#~ msgid "Cross Validation was success!"
#~ msgstr "Die Kreuzvalidierung war erfolgreich."
-#~ msgid ""
-#~ "Interpolation: The region resolution is too high: %d cells. Consider to "
-#~ "change it."
-#~ msgstr ""
-#~ "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Ãberlegen "
-#~ "Sie die Auflösung zu ändern."
+#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
+#~ msgstr "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Ãberlegen Sie die Auflösung zu ändern."
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "Erstelle Hilfstabelle um überlappende Zonen zu archivieren"
@@ -48099,9 +44017,392 @@
#~ msgstr "Richtungskarte gefunden <%s>."
#~ msgid "All non-NULL and non-zero cells are considered as blocking terrain"
-#~ msgstr ""
-#~ "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als "
-#~ "echte Hindernis aufgefasst."
+#~ msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
#~ msgid "It was impossible to open table"
#~ msgstr "Es war unmöglich die Tabelle zu öffnen."
+#~ msgid "Name of output display file"
+#~ msgstr "Name des Ausgabedisplays."
+#~ msgid "Unable to open elevation map"
+#~ msgstr "Kann die Höhenkarte nicht öffnen."
+#~ msgid "Input_options"
+#~ msgstr "Eingabe Optionen"
+#~ msgid "Output_options"
+#~ msgstr "Ausgabe Optionen"
+#~ msgid "Incorporate the shadowing effect of terrain"
+#~ msgstr "Berücksichtige den Schatteneffekt der Oberfläche."
+#~ msgid "Traces a flow through an elevation model on a raster map."
+#~ msgstr "Verfolgt einen Fluss durch ein Höhenmodell auf einer Rasterkarte."
+#~ msgid "Name of movement direction map associated with the cost surface"
+#~ msgstr "Name der Bewegungsrichtungskarte verbunden mit der Kostenkarte."
+#~ msgid "Output drain vector map (recommended for cost surface made using knight's move)"
+#~ msgstr "Ausgabe AbfluÃvektorkarte (empfohlen für Kostenkarten erstellt mittels Rösselsprung)."
+#~ msgid "Map coordinates of starting point(s) (E,N)"
+#~ msgstr "Koordinaten von Startpunkt(en) (O,N)"
+#~ msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
+#~ msgstr "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muà auch eine Richtungskarte angegeben werden)."
+#~ msgid "Directional drain selected... checking for direction raster"
+#~ msgstr "gerichteter Abfluà ausgewählt... prüfe die Richtungskarte"
+#~ msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
+#~ msgstr "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, muà eine Richtungskarte angegeben werden."
+#~ msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
+#~ msgstr "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluà nicht angegeben werden."
+#~ msgid "Maps for computing inter-class distances"
+#~ msgstr "Karten für die Berechnung von Inter-class-Entfernungen"
+#~ msgid "One or more input raster maps not found"
+#~ msgstr "Eine oder mehrere Rasterkarte nicht gefunden."
+#~ msgid "Name of raster map containing grid cell cost information"
+#~ msgstr "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
+#~ msgid "Name of output raster map to contain movement directions"
+#~ msgstr "Name der Ausgabe-Rasterkarte mit Bewegungsrichtungen."
+#~ msgid "Name of stop vector points map"
+#~ msgstr "Name der Eingabe-Vektorkarte mit Stopppunkten."
+#~ msgid "Optional maximum cumulative cost"
+#~ msgstr "Optionales kumulatives Kostenmaximum."
+#~ msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+#~ msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
+#~ msgid "Stop points vector map"
+#~ msgstr "Vektorkarte mit den Stopp-Punkten"
+#~ msgid "wtrshed pass %d"
+#~ msgstr "Einzugsgebiet Durchgang %d"
+#, fuzzy
+#~ msgid "Name for output ARC-GRID map (use out=- for stdout)"
+#~ msgstr "Name der Ausgabe ARCGRID-Datei (verwende out=- für stdout)"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Erzeugt/verändert die Farbtabelle einer Rasterkarte."
+#~ msgid "Import a binary raster file into a GRASS raster map."
+#~ msgstr "Importiert eine binäre Rasterdatei in eine GRASS Rasterkarte."
+#~ msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+#~ msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
+#~ msgid "Not enough disk space -- cannot write files"
+#~ msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
+#~ msgid "Name for output raster map (default: input)"
+#~ msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#~ msgstr "Kann die Vektorkarte <%s> in <%s> nicht öffnen."
+#~ msgid "Name for the output binary MAT-File"
+#~ msgstr "Name der binären MAT-Ausgabedatei."
+#~ msgid "Exports a GRASS raster map to a binary array."
+#~ msgstr "Exportiert eine GRASS Rasterkarte als binäres Array."
+#~ msgid "Name of an existing MAT-File(v4)"
+#~ msgstr "Name der MAT-Datei (v4)"
+#~ msgid "Name for the output raster map (override)"
+#~ msgstr "Name der Ausgabe-Rasterkarte (wird überschrieben)."
+#~ msgid "Method %s not compatible with Gaussian filter"
+#~ msgstr "Methode %s ist nicht kompatibel mit GauÃ'schem Filter."
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Name der Ausgabe-Rasterkarte mit See."
+#~ msgid "Input map"
+#~ msgstr "Eingabekarte"
+#~ msgid "Precomputing: e/w distances"
+#~ msgstr "Vorberechnung: o/w Distanzen."
+#~ msgid "Precomputing: quantization tolerances"
+#~ msgstr "Vorberechnung: Diskretisierungstoleranz."
+#~ msgid "Precomputing: inverted elevations"
+#~ msgstr "Vorberechnung: invertierte Höhenwerte."
+#~ msgid "Precomputing: interpolated border elevations"
+#~ msgstr "Vorberechnung: interpolierte Grenzhöhen."
+#~ msgid "Precomputing: re-oriented aspects"
+#~ msgstr "Vorberechnung: neuorientierte Expositionen."
+#~ msgid "Precomputing: aspects"
+#~ msgstr "Vorberechnung: Expositionen."
+#~ msgid "Elevation file's resolution differs from current region resolution"
+#~ msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
+#~ msgid "Name of file containing signatures"
+#~ msgstr "Name der Datei mit den Signaturen."
+#~ msgid "Generated by either i.cluster, i.class, or i.gensig"
+#~ msgstr "Erzeugt von i.cluster, i.class, oder i.gensig."
+#~ msgid "Name for raster map holding classification results"
+#~ msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
+#~ msgid "Name for raster map holding reject threshold results"
+#~ msgstr "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
+#~ msgid "Solar elevation in degrees"
+#~ msgstr "Sonnenhöhe in Grad"
+#~ msgid "Remove selected files from specified group"
+#~ msgstr "Lösche die ausgewählten Dateien aus der angegebenen Gruppe."
+#~ msgid "List files from specified (sub)group (fancy)"
+#~ msgstr "Liste Dateien der angegebenen (Unter-)gruppe auf (extravagant)."
+#~ msgid "Interactively select or modify the target elevation model."
+#~ msgstr "Wähle oder Ãndere das Ziel-Höhenmodell interaktiv."
+#~ msgid "Mapset [%s] in target location [%s] - "
+#~ msgstr "Mapset [%s] in Ziel-Location [%s] - "
+#~ msgid "Please select a target for group"
+#~ msgstr "Bitte wählen Sie ein Ziel für die Gruppe"
+#~ msgid "Interactively select and modify the imagery group camera reference file."
+#~ msgstr "Wähle und ändere die Kamerareferenzdatei der Bildgruppe interaktiv."
+#~ msgid "Name of camera reference file to use"
+#~ msgstr "Name der zu verwendenden Kamerareferenzdatei."
+#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
+#~ msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
+#~ msgid "Optional display raster"
+#~ msgstr "optionale Ansichts-Rasterkarte"
+#~ msgid "Size of grid to be drawn"
+#~ msgstr "GröÃe des Gitters."
+#~ msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+#~ msgstr "In Karteneinheiten oder im DDD:MM:SS Format. Beispiel: \"1000\" oder \"0:10\""
+#~ msgid "Sets the color of the menu background"
+#~ msgstr "Bestimmt die Farbe des Menü Hintergrunds."
+#~ msgid "Displays version and copyright information."
+#~ msgstr "Zeigt Versions- und Copyright-Informationen."
+#~ msgid "Print also the GRASS build information"
+#~ msgstr "Gebe auch die GRASS 'Build'-Informationen aus"
+#~ msgid "Print also the GIS library revision number and time"
+#~ msgstr "Gebe die Revisionsnummer und Zeit der GIS-Bibliothek aus"
+#~ msgid "Names of input files"
+#~ msgstr "Namen der Eingabedateien."
+#~ msgid "Name(s) of existing mapset(s) to remove from search path"
+#~ msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+#~ msgid "Reading sites..."
+#~ msgstr "Lese sites..."
+#~ msgid "Writing sites to output..."
+#~ msgstr "Schreibe sites in die Ausgabe..."
+#~ msgid "Rebuilding topology..."
+#~ msgstr "Baue Topologie neu auf..."
+#~ msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+#~ msgstr "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem Vektornetzwerk erstellt werden."
+#~ msgid "In network mode, multiply the result by number of input points."
+#~ msgstr "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-Punkte."
+#~ msgid ""
+#~ "\n"
+#~ "Writing output vector map using smooth parameter=%f."
+#~ msgstr ""
+#~ "\n"
+#~ "Schreibe Ausgabevektordatei mit dem Glättungsparameter=%f."
+#~ msgid ""
+#~ "\n"
+#~ "Normalising factor=%f."
+#~ msgstr ""
+#~ "\n"
+#~ "Normalisierungsfaktor=%f."
+#~ msgid ""
+#~ "\n"
+#~ "Writing output raster map using smooth parameter=%f."
+#~ msgstr ""
+#~ "\n"
+#~ "Schreibe Ausgabe-Rasterkarte mit Glättungsparameter=%f."
+#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
+#~ msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
+#~ msgid "Name of input point vector map"
+#~ msgstr "Name der Eingabe-Punktvektorkarte."
+#~ msgid "%d points found: %.3lf %.3lf %.3lf line category: %d"
+#~ msgstr "%d Punkte gefunden: %.3lf %.3lf %.3lf Kategorie der Linie: %d"
+#~ msgid "Reprojecting primitives: "
+#~ msgstr "Reprojeziere Primitive:"
+#~ msgid "Buffer distance in map units"
+#~ msgstr "Bufferdistanz in Karteneinheiten"
+#~ msgid "Buffering lines..."
+#~ msgstr "Buffere Linien..."
+#~ msgid "Column name"
+#~ msgstr "Spaltenname"
+#~ msgid "Build topology or dump topology or spatial index to stdout"
+#~ msgstr "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach stdout."
+#~ msgid "Display categories:"
+#~ msgstr "Zeige Kategorien:"
+#~ msgid "No database record"
+#~ msgstr "Kein Datenbankeintrag"
+#~ msgid "Unparsable longitude value in column <%d>: %s"
+#~ msgstr "Nicht interpretierbarer Längengrad in Spalte <%d>: %s"
+#~ msgid "Unparsable latitude value in column <%d>: %s"
+#~ msgstr "Nicht interpretierbarer Breitengrad in Spalte <%d>: %s"
+#~ msgid "Populates database values from vector features."
+#~ msgstr "Füllt die Datenbank mit Werten der Vektor-Feature."
+#~ msgid "In print mode prints totals for options: length,area,count"
+#~ msgstr "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
+#~ msgid "%d lines or boundaries found in vector map <%s@%s>"
+#~ msgstr "%d Linien oder Grenzen in der Vektorkarte <%s@%s> gefunden."
+#~ msgid "%d polylines stored in vector map <%s@%s>"
+#~ msgstr "%d Polylinien in der Vektorkarte <%s@%s> gespeichert."
+#, fuzzy
+#~ msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/';layers;print only layer numbers"
+#~ msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ãndere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option 'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht (Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
+#~ msgid "Name of the raster map used as mask"
+#~ msgstr "Name der Rasterkarte, die als Maske benutzt werden soll"
+#~ msgid "<%s> created in database."
+#~ msgstr "<%s> in Datenbank erzeugt."
+#~ msgid "Name of input vector map of sparse points"
+#~ msgstr "Eingabe Vektorkarte mit wenigen Punkten."
+#~ msgid "vector, import, conversion"
+#~ msgstr "Vektor, Import, Konvertierung"
+#, fuzzy
+#~ msgid "Count points in areas, calculate statistics."
+#, fuzzy
+#~ msgid "creating spatial index"
+#~ msgstr "Erzeuge räumlichen Index..."
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Namde der Eingabe-Vektorkarte mit Linien."
+#~ msgid "Name of the surface raster map for cross-section"
+#~ msgstr "Name der Oberflächen-Rasterkarte für Querschnitte"
+#~ msgid "Name of the column containing w attribute to interpolate"
+#~ msgstr "Name der Spalte mit dem zu interpolierenden w-Attribut"
+#~ msgid "Name of the column with smoothing parameters"
+#~ msgstr "Name der Attributspalte mit den Glättungs-Parametern"
+#~ msgid "Both crossvalidation options (-c, cvdev) must be specified"
+#~ msgstr "Beide Kreuzvalidierungsoptionen (-c, cvdev) müssen angegeben werden"
+#~ msgid "Both crossvalidation and deviations file specified"
+#~ msgstr "Kreuzvalidierungs- und Abweichungsdatei angegeben"
+#~ msgid "Produces a convex hull for a given vector map."
+#~ msgstr "Erzeugt eine konvexe Hülle für eine Vektorkarte."
+#~ msgid "Name of input vector map"
+#~ msgstr "Name der Eingabe-Vektorkarte"
+#~ msgid "Unable to open database: "
+#~ msgstr "Kann Datenbank nicht öffnen:"
+#~ msgid "Removes a database."
+#~ msgstr "Entfernt eine Datenbank."
+#~ msgid "List all databases for a given driver and location."
+#~ msgstr "Listet alle Datenbanken für den angegebenen Treiber und Location auf."
+#~ msgid "Name for output vector map"
+#~ msgstr "Name für die Ausgabe-Vektorkarte"
+#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
+#~ msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
+#~ msgid "Name of old database"
+#~ msgstr "Name der alten Datenbank."
+#~ msgid "Name of new database"
+#~ msgstr "Name der neuen Datenbank."
+#~ msgid "Calculate new raster map from a r.mapcalc expression."
+#~ msgstr "Berechne eine neue Rasterkarte mit einem r.mapcalc-Ausdruck. "
+#~ msgid "Type of the raster map to be created"
+#~ msgstr "Art der zu erstellenden Rasterkarte."
+#~ msgid "GetFeature URL starting with 'http'"
+#~ msgstr "GetFeature URL beginnend mit 'http'"
+#~ msgid "vector, export, GPS"
+#~ msgstr "Vektor, Export, GPS"
+#~ msgid "Percentile to calculate (requires -e flag)"
+#~ msgstr "Zu berechnendes Perzentil (erfordert den Schalter -e)."
+#~ msgid "Downloads and imports data from WMS servers."
+#~ msgstr "Läd Daten von einem WMS Server herunter und importiert sie."
+#~ msgid "Layers to request from map server"
+#~ msgstr "Layer, die vom Server angefragt werden."
+#~ msgid "Addition query options for server"
+#~ msgstr "Weitere Abfrageoptionen für den Server."
+#~ msgid "Current window size:"
+#~ msgstr "Aktuelle FenstergröÃe:"
+#~ msgid "File Size %d ... Total Bytes %d"
+#~ msgstr "DateigröÃe %d ... Gesamt-Bytes %d"
+#~ msgid "vector, projection"
+#~ msgstr "Vektor, Projektion"
+#~ msgid "Name of input vector points map"
+#~ msgstr "Name der Eingabe-Vektorkarte mit Punkten."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grassmods_el.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grassmods_el\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-02-18 14:05+0100\n"
+"POT-Creation-Date: 2013-02-26 14:45+0100\n"
"PO-Revision-Date: 2009-02-19 10:29+0200\n"
"Last-Translator: Vasilios Antoniou <vantoniou at gmail.com>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -229,7 +229,7 @@
#: ../vector/v.distance/main.c:87 ../vector/v.to.db/main.c:36
#: ../vector/v.mkgrid/main.c:70 ../vector/v.net.bridge/main.c:47
#: ../vector/v.build.polylines/main.c:112 ../vector/v.delaunay/main.c:85
-#: ../vector/v.qcount/main.c:60 ../vector/v.category/main.c:74
+#: ../vector/v.qcount/main.c:60 ../vector/v.category/main.c:75
#: ../vector/v.net.flow/main.c:58 ../vector/v.in.region/main.c:38
#: ../vector/v.buffer/main.c:223 ../vector/v.surf.rst/main.c:142
#: ../vector/v.transform/main.c:70 ../vector/v.reclass/main.c:67
@@ -475,7 +475,7 @@
"Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
#: ../doc/vector/v.example/main.c:126 ../display/d.vect/opt.c:147
-#: ../display/d.thematic.area/main.c:205 ../vector/v.edit/select.c:506
+#: ../display/d.thematic.area/main.c:204 ../vector/v.edit/select.c:506
#: ../vector/v.db.connect/main.c:215 ../vector/v.db.connect/main.c:281
#: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
#: ../vector/v.drape/main.c:250 ../vector/v.out.vtk/writeVTK.c:644
@@ -3459,7 +3459,7 @@
msgid "One coordinate pair per line, please"
msgstr ""
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:75
+#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
msgid "category"
msgstr ""
@@ -5407,8 +5407,9 @@
#: ../raster/r.spread/main.c:136 ../raster/r.spread/main.c:145
#: ../raster/r.spread/main.c:153 ../raster/r.spread/main.c:161
#: ../raster/r.spread/main.c:169
-msgid "Input_maps"
-msgstr ""
+#, fuzzy
+msgid "Input maps"
+msgstr "ÁðïôÝëåóìá:"
#: ../raster/r.spread/main.c:120
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
@@ -5464,8 +5465,9 @@
#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
#: ../raster/r.spread/main.c:230
-msgid "Output_maps"
-msgstr ""
+#, fuzzy
+msgid "Output maps"
#: ../raster/r.spread/main.c:216
msgid "Name of raster map to contain OUTPUT spread time (min)"
@@ -8488,8 +8490,9 @@
#: ../raster/r.horizon/main.c:255 ../raster/r.horizon/main.c:263
#: ../raster/simwe/r.sim.sediment/main.c:175
#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Input_options"
-msgstr ""
+#, fuzzy
+msgid "Input options"
#: ../raster/r.sun/main.c:257
msgid ""
@@ -8569,8 +8572,9 @@
#: ../raster/r.horizon/main.c:272 ../raster/r.horizon/main.c:282
#: ../raster/r.horizon/main.c:290 ../raster/simwe/r.sim.sediment/main.c:168
#: ../raster/simwe/r.sim.water/main.c:216
-msgid "Output_options"
-msgstr ""
+#, fuzzy
+msgid "Output options"
#: ../raster/r.sun/main.c:393
msgid ""
@@ -8629,114 +8633,114 @@
msgstr ""
#: ../raster/r.sun/main.c:504
-msgid "Incorporate the shadowing effect of terrain"
+msgid "Do not incorporate the shadowing effect of terrain"
msgstr ""
#: ../raster/r.sun/main.c:509
msgid "Use the low-memory version of the program"
msgstr ""
-#: ../raster/r.sun/main.c:556
+#: ../raster/r.sun/main.c:550
msgid "You must give the longitude raster if you use civil time"
msgstr ""
-#: ../raster/r.sun/main.c:559
+#: ../raster/r.sun/main.c:553
#, fuzzy
msgid "Error reading civil time zone value"
msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
-#: ../raster/r.sun/main.c:562
+#: ../raster/r.sun/main.c:556
#, fuzzy
msgid "Invalid civil time zone value"
msgstr "ËÜèïò ðáñÜìåôñïé"
-#: ../raster/r.sun/main.c:587
+#: ../raster/r.sun/main.c:581
msgid "insol_time and incidout are incompatible options"
msgstr ""
-#: ../raster/r.sun/main.c:592
+#: ../raster/r.sun/main.c:586
#, fuzzy
msgid "Error reading time step size"
-#: ../raster/r.sun/main.c:594
+#: ../raster/r.sun/main.c:588
#, fuzzy
msgid "Invalid time step size"
-#: ../raster/r.sun/main.c:598
+#: ../raster/r.sun/main.c:592
#, fuzzy
msgid "Error reading horizon step size"
-#: ../raster/r.sun/main.c:602
+#: ../raster/r.sun/main.c:596
msgid "The horizon step size must be greater than 0."
msgstr ""
-#: ../raster/r.sun/main.c:605
+#: ../raster/r.sun/main.c:599
msgid ""
"If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr ""
-#: ../raster/r.sun/main.c:611
+#: ../raster/r.sun/main.c:605
msgid "Time and insol_time are incompatible options"
msgstr ""
-#: ../raster/r.sun/main.c:613
+#: ../raster/r.sun/main.c:607
msgid ""
"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
"time"
msgstr ""
-#: ../raster/r.sun/main.c:618
+#: ../raster/r.sun/main.c:612
msgid "incidout requires time parameter to be set"
msgstr ""
-#: ../raster/r.sun/main.c:620
+#: ../raster/r.sun/main.c:614
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr ""
-#: ../raster/r.sun/main.c:666
+#: ../raster/r.sun/main.c:660
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
-#: ../raster/r.sun/main.c:679
+#: ../raster/r.sun/main.c:673
msgid ""
"If you want to save memory and to use shadows, you must use pre-calculated "
"horizons."
msgstr ""
-#: ../raster/r.sun/main.c:724 ../display/d.where/main.c:107
+#: ../raster/r.sun/main.c:718 ../display/d.where/main.c:107
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
msgstr ""
-#: ../raster/r.sun/main.c:728 ../raster/r.horizon/main.c:476
+#: ../raster/r.sun/main.c:722 ../raster/r.horizon/main.c:476
#: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:250
#: ../general/g.region/printwindow.c:506 ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
msgstr ""
-#: ../raster/r.sun/main.c:732 ../raster/r.horizon/main.c:480
+#: ../raster/r.sun/main.c:726 ../raster/r.horizon/main.c:480
#: ../ps/ps.map/do_geogrid.c:272 ../display/d.where/main.c:113
#: ../display/d.grid/plot.c:335 ../general/g.region/printwindow.c:253
#: ../general/g.region/printwindow.c:509 ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
msgstr ""
-#: ../raster/r.sun/main.c:742 ../raster/r.horizon/main.c:490
+#: ../raster/r.sun/main.c:736 ../raster/r.horizon/main.c:490
#: ../imagery/i.latlong/main.c:114 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
#: ../display/d.grid/plot.c:342 ../display/d.grid/plot.c:369
msgid "Unable to set up lat/long projection parameters"
msgstr ""
-#: ../raster/r.sun/main.c:746
+#: ../raster/r.sun/main.c:740
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
msgstr ""
-#: ../raster/r.sun/main.c:751
+#: ../raster/r.sun/main.c:745
msgid "Both latin and longin raster maps must be given, or neither"
msgstr ""
@@ -18726,7 +18730,7 @@
msgid "illegal maploc request"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:219
+#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
msgid "illegal copies request"
msgstr ""
@@ -19044,12 +19048,12 @@
msgid "Number of copies to print"
msgstr ""
-#: ../ps/ps.map/main.c:204
+#: ../ps/ps.map/main.c:205
#, fuzzy, c-format
msgid "Unable to open file '%s': %s"
msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
-#: ../ps/ps.map/main.c:212 ../ps/ps.map/main.c:231
+#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
#: ../vector/v.univar/main.c:139 ../vector/v.to.db/parse.c:141
#: ../vector/v.to.db/parse.c:144
#, fuzzy, c-format
@@ -19058,7 +19062,7 @@
"\t(%s)"
msgstr "Ïé áðáéôïýìåíåò ðáñÜìåôñïé <%s> äåí Ý÷ïõí äïèåß"
-#: ../ps/ps.map/main.c:272
+#: ../ps/ps.map/main.c:273
#, c-format
msgid "PostScript file '%s' successfully written."
msgstr ""
@@ -19174,7 +19178,7 @@
#: ../display/d.grid/main.c:233 ../display/d.his/main.c:118
#: ../display/d.geodesic/main.c:96 ../display/d.labels/main.c:117
#: ../display/d.colortable/main.c:141 ../display/d.rast/main.c:97
-#: ../display/d.thematic.area/main.c:371 ../display/d.fontlist/main.c:54
+#: ../display/d.thematic.area/main.c:370 ../display/d.fontlist/main.c:54
#: ../display/d.graph/main.c:98 ../display/d.rgb/main.c:82
#: ../display/d.path/main.c:154 ../display/d.rast.arrow/main.c:224
#: ../display/d.legend/main.c:294 ../display/d.font/main.c:86
@@ -19187,12 +19191,12 @@
msgstr ""
#: ../display/d.vect/opt.c:143 ../display/d.what.vect/what.c:413
-#: ../display/d.thematic.area/main.c:201 ../vector/v.db.connect/main.c:175
+#: ../display/d.thematic.area/main.c:200 ../vector/v.db.connect/main.c:175
#, c-format
msgid "Database connection not defined"
msgstr ""
-#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:210
+#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:209
#: ../vector/v.convert/att.c:74 ../db/db.select/main.c:73
#: ../db/db.execute/main.c:76 ../db/db.tables/main.c:47
#: ../db/db.describe/main.c:56
@@ -19264,8 +19268,8 @@
#: ../display/d.vect/main.c:80 ../display/d.vect/main.c:105
#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
#: ../display/d.vect/main.c:314 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:135
-#: ../display/d.thematic.area/main.c:138 ../vector/v.net.centrality/main.c:121
+#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:137 ../vector/v.net.centrality/main.c:121
#: ../vector/v.net.centrality/main.c:123 ../vector/v.in.ogr/main.c:146
#: ../vector/v.in.ogr/main.c:159 ../vector/v.in.ogr/main.c:164
#: ../vector/v.in.ogr/main.c:173 ../vector/v.in.ogr/main.c:189
@@ -19280,8 +19284,8 @@
#: ../vector/v.extract/main.c:100 ../vector/v.extract/main.c:106
#: ../vector/v.extract/main.c:109 ../vector/v.extract/main.c:112
#: ../vector/v.extract/main.c:122 ../vector/v.extract/main.c:132
-#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:83
-#: ../vector/v.category/main.c:86 ../vector/v.category/main.c:90
+#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:84
+#: ../vector/v.category/main.c:87 ../vector/v.category/main.c:91
#: ../vector/v.buffer/main.c:232 ../vector/v.buffer/main.c:235
#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:243
#: ../vector/v.surf.rst/main.c:173 ../vector/v.surf.rst/main.c:185
@@ -20209,7 +20213,7 @@
msgid "Maximum value used for bar plot reference"
msgstr ""
-#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:164
+#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:163
msgid "Create legend information and send to stdout"
msgstr ""
@@ -20918,121 +20922,121 @@
msgid "Colors (one per class)."
msgstr ""
-#: ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:133
msgid "Layer number. If -1, all layers are displayed."
msgstr ""
-#: ../display/d.thematic.area/main.c:144 ../display/d.thematic.area/main.c:152
+#: ../display/d.thematic.area/main.c:143 ../display/d.thematic.area/main.c:151
msgid "Boundaries"
msgstr ""
-#: ../display/d.thematic.area/main.c:145
+#: ../display/d.thematic.area/main.c:144
msgid "Boundary width"
msgstr ""
-#: ../display/d.thematic.area/main.c:151
+#: ../display/d.thematic.area/main.c:150
msgid "Boundary color"
msgstr ""
-#: ../display/d.thematic.area/main.c:158
+#: ../display/d.thematic.area/main.c:157
msgid "File in which to save d.graph instructions for legend display"
msgstr ""
-#: ../display/d.thematic.area/main.c:169
+#: ../display/d.thematic.area/main.c:168
msgid ""
"When printing legend info , include extended statistical info from "
"classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:173
+#: ../display/d.thematic.area/main.c:172
msgid "Do not draw map, only output the legend"
msgstr ""
-#: ../display/d.thematic.area/main.c:192
+#: ../display/d.thematic.area/main.c:191
#, c-format
msgid "%s: You must build topology on vector map. Run v.build."
msgstr ""
-#: ../display/d.thematic.area/main.c:199
+#: ../display/d.thematic.area/main.c:198
msgid "'layer' must be > 0"
msgstr ""
-#: ../display/d.thematic.area/main.c:225
+#: ../display/d.thematic.area/main.c:224
#, c-format
msgid "Data (%s) not numeric. Column must be numeric."
msgstr ""
-#: ../display/d.thematic.area/main.c:229
+#: ../display/d.thematic.area/main.c:228
#: ../display/d.thematic.area/plot1.c:134
#: ../display/d.thematic.area/plot1.c:162
#, c-format
msgid "Cannot select data (%s) from table"
msgstr ""
-#: ../display/d.thematic.area/main.c:292
+#: ../display/d.thematic.area/main.c:291
#, c-format
msgid "Unknown color: [%s]"
msgstr ""
-#: ../display/d.thematic.area/main.c:303
+#: ../display/d.thematic.area/main.c:302
msgid ""
"You gave both manual breaks and a classification algorithm or a number of "
"classes. The manual breaks have precedence and will thus be used."
msgstr ""
-#: ../display/d.thematic.area/main.c:340
+#: ../display/d.thematic.area/main.c:339
msgid "You must either give classbreaks or a classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:353
+#: ../display/d.thematic.area/main.c:352
#, c-format
msgid ""
"Not enough colors or error in color specifications.\n"
"Need %i colors."
msgstr ""
-#: ../display/d.thematic.area/main.c:358
+#: ../display/d.thematic.area/main.c:357
#, c-format
msgid "Error interpreting color %s"
msgstr ""
-#: ../display/d.thematic.area/main.c:377
+#: ../display/d.thematic.area/main.c:376
msgid "Plotting ..."
msgstr ""
-#: ../display/d.thematic.area/main.c:384
+#: ../display/d.thematic.area/main.c:383
msgid ""
"The bounding box of the map is outside the current region, nothing drawn."
msgstr ""
-#: ../display/d.thematic.area/main.c:434
+#: ../display/d.thematic.area/main.c:433
#, c-format
msgid ""
"\n"
"Total number of records: %.0f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:436
+#: ../display/d.thematic.area/main.c:435
#, c-format
msgid "Classification of %s into %i classes\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:438 ../vector/v.class/main.c:202
+#: ../display/d.thematic.area/main.c:437 ../vector/v.class/main.c:202
#, c-format
msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:440 ../vector/v.class/main.c:203
+#: ../display/d.thematic.area/main.c:439 ../vector/v.class/main.c:203
#, c-format
msgid "Mean: %f\tStandard deviation = %f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:444
+#: ../display/d.thematic.area/main.c:443
#, c-format
msgid "Last chi2 = %f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:447 ../vector/v.class/main.c:210
+#: ../display/d.thematic.area/main.c:446 ../vector/v.class/main.c:210
#, c-format
msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
@@ -21459,14 +21463,14 @@
msgid "Input map contains no data"
msgstr ""
-#: ../display/d.legend/main.c:381 ../display/d.legend/main.c:541
+#: ../display/d.legend/main.c:381
#, fuzzy
-msgid "Color range exceeds lower limit of actual data"
+msgid "Requested range exceeds lower limit of actual data"
msgstr "×ñþìá"
-#: ../display/d.legend/main.c:387 ../display/d.legend/main.c:545
+#: ../display/d.legend/main.c:387
#, fuzzy
-msgid "Color range exceeds upper limit of actual data"
+msgid "Requested range exceeds upper limit of actual data"
msgstr "×ñþìá"
#: ../display/d.legend/main.c:446
@@ -21482,6 +21486,16 @@
msgid "Forcing a smooth legend: too many categories for current window height"
msgstr ""
+#: ../display/d.legend/main.c:541
+#, fuzzy
+msgid "Color range exceeds lower limit of actual data"
+msgstr "×ñþìá"
+#: ../display/d.legend/main.c:545
+#, fuzzy
+msgid "Color range exceeds upper limit of actual data"
+msgstr "×ñþìá"
#: ../display/d.legend/main.c:552
#, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
@@ -23684,7 +23698,7 @@
#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:152
#: ../vector/v.proj/main.c:411 ../vector/v.kcv/main.c:142
-#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:719
+#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:750
#: ../vector/v.transform/main.c:286 ../vector/v.rectify/main.c:285
#, fuzzy
msgid "Failed to copy attribute table to output map"
@@ -24565,7 +24579,7 @@
msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
#: ../vector/v.in.ogr/main.c:1208 ../vector/v.delaunay/main.c:171
-#: ../vector/v.category/main.c:326
+#: ../vector/v.category/main.c:357
msgid "Unable to calculate area centroid"
msgstr ""
@@ -25112,6 +25126,7 @@
#: ../vector/v.net.distance/main.c:98 ../vector/v.net.distance/main.c:103
#: ../vector/v.net.distance/main.c:109 ../vector/v.distance/main.c:97
#: ../vector/v.distance/main.c:102 ../vector/v.distance/main.c:109
+#: ../vector/v.distance/main.c:188
msgid "From"
msgstr ""
@@ -26611,7 +26626,8 @@
msgid "Use drand48() (ignored)"
msgstr ""
-#: ../vector/v.kcv/main.c:119
+#: ../vector/v.kcv/main.c:119 ../vector/v.category/main.c:181
+#: ../vector/v.category/main.c:243 ../vector/v.category/main.c:251
#, c-format
msgid "Unable to open vector map <%s> at topological level %d"
msgstr ""
@@ -27652,10 +27668,6 @@
"Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
-#: ../vector/v.distance/main.c:188
-msgid "From_map"
-msgstr ""
#: ../vector/v.distance/main.c:193
msgid "Column name of nearest feature (used with upload=to_attr)"
msgstr ""
@@ -28281,167 +28293,167 @@
msgid "Counting points quadrats..."
msgstr "ÅããñáöÞ %s áðü %s..."
-#: ../vector/v.category/main.c:77
+#: ../vector/v.category/main.c:78
msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:90
msgid "Feature ids (by default all features are processed)"
msgstr ""
-#: ../vector/v.category/main.c:101
+#: ../vector/v.category/main.c:102
msgid "Action to be done"
msgstr ""
-#: ../vector/v.category/main.c:111
+#: ../vector/v.category/main.c:113
msgid "add a new category"
msgstr ""
-#: ../vector/v.category/main.c:112
+#: ../vector/v.category/main.c:114
msgid "delete category (-1 to delete all categories of given layer)"
msgstr ""
-#: ../vector/v.category/main.c:113
+#: ../vector/v.category/main.c:115
msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
msgstr ""
-#: ../vector/v.category/main.c:114
+#: ../vector/v.category/main.c:116
msgid "add the value specified by cat option to the current category value"
msgstr ""
-#: ../vector/v.category/main.c:115
+#: ../vector/v.category/main.c:117
msgid ""
"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
"layer 1 to layer 2 and 3)"
msgstr ""
-#: ../vector/v.category/main.c:116
+#: ../vector/v.category/main.c:118
msgid "print report (statistics), in shell style: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:117
+#: ../vector/v.category/main.c:119
msgid "print category values, more cats in the same layer are separated by '/'"
msgstr ""
-#: ../vector/v.category/main.c:129
+#: ../vector/v.category/main.c:120
+#, fuzzy
+msgid "print only layer numbers"
+msgstr "Íïýìåñï åðéðÝäïõ"
+#: ../vector/v.category/main.c:132
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
msgid "Category increment"
msgstr ""
-#: ../vector/v.category/main.c:133
+#: ../vector/v.category/main.c:136
msgid "Shell script style, currently only for report"
msgstr ""
-#: ../vector/v.category/main.c:134
+#: ../vector/v.category/main.c:137
msgid "Format: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:152
+#: ../vector/v.category/main.c:155
msgid ""
"Database connection and attribute tables for concerned layers are not changed"
msgstr ""
-#: ../vector/v.category/main.c:173
+#: ../vector/v.category/main.c:203
msgid ""
"Invalid category number (must be equal to or greater than 0). Normally "
"category number starts at 1."
msgstr ""
-#: ../vector/v.category/main.c:182
+#: ../vector/v.category/main.c:212
#, c-format
msgid "%d errors in id option"
msgstr ""
-#: ../vector/v.category/main.c:191
+#: ../vector/v.category/main.c:221
msgid "Output vector wasn't entered"
msgstr ""
-#: ../vector/v.category/main.c:212 ../vector/v.category/main.c:220
-#, fuzzy, c-format
-msgid "Can not open vector <%s> on level %d"
-msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../vector/v.category/main.c:237
+#: ../vector/v.category/main.c:268
msgid "Too many layers for this operation"
msgstr ""
-#: ../vector/v.category/main.c:240 ../vector/v.category/main.c:243
+#: ../vector/v.category/main.c:271 ../vector/v.category/main.c:274
msgid "2 layers must be specified"
msgstr ""
-#: ../vector/v.category/main.c:251
+#: ../vector/v.category/main.c:282
#, fuzzy, c-format
msgid "Categories already exist in layer %d"
msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
-#: ../vector/v.category/main.c:294 ../vector/v.select/select.c:40
+#: ../vector/v.category/main.c:325 ../vector/v.select/select.c:40
msgid "Processing features..."
msgstr ""
-#: ../vector/v.category/main.c:340
+#: ../vector/v.category/main.c:371
#, c-format
msgid "%d new centroids placed in output map"
msgstr ""
-#: ../vector/v.category/main.c:629
+#: ../vector/v.category/main.c:660
msgid "Layer/table"
msgstr ""
-#: ../vector/v.category/main.c:633
+#: ../vector/v.category/main.c:664
msgid "Layer"
msgstr ""
-#: ../vector/v.category/main.c:635
+#: ../vector/v.category/main.c:666
#, c-format
msgid "type count min max\n"
msgstr ""
-#: ../vector/v.category/main.c:636
+#: ../vector/v.category/main.c:667
msgid "point"
msgstr ""
-#: ../vector/v.category/main.c:640
+#: ../vector/v.category/main.c:671
msgid "line"
msgstr ""
-#: ../vector/v.category/main.c:644
+#: ../vector/v.category/main.c:675
msgid "boundary"
msgstr ""
-#: ../vector/v.category/main.c:648
+#: ../vector/v.category/main.c:679
#: ../locale/scriptstrings/v.centroids_to_translate.c:3
msgid "centroid"
msgstr ""
-#: ../vector/v.category/main.c:652
+#: ../vector/v.category/main.c:683
#: ../locale/scriptstrings/v.centroids_to_translate.c:4
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
msgid "area"
msgstr ""
-#: ../vector/v.category/main.c:656
+#: ../vector/v.category/main.c:687
msgid "face"
msgstr ""
-#: ../vector/v.category/main.c:660
+#: ../vector/v.category/main.c:691
msgid "kernel"
msgstr ""
-#: ../vector/v.category/main.c:664
+#: ../vector/v.category/main.c:695
msgid "all"
msgstr ""
-#: ../vector/v.category/main.c:717 ../vector/v.rectify/main.c:283
+#: ../vector/v.category/main.c:748 ../vector/v.rectify/main.c:283
#, fuzzy
msgid "Copying attribute table(s)..."
msgstr "ÁíôéãñÜöåé Ýíá ðßíáêá"
-#: ../vector/v.category/main.c:725
+#: ../vector/v.category/main.c:756
#, c-format
msgid "Categories copied from layer %d to layer %d"
msgstr ""
-#: ../vector/v.category/main.c:727
+#: ../vector/v.category/main.c:758
#, c-format
msgid "%d features modified."
msgstr ""
@@ -37238,6 +37250,10 @@
msgstr ""
#, fuzzy
+#~ msgid "Can not open vector <%s> on level %d"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
+#, fuzzy
#~ msgid "Name of raster map(s) for Color"
#~ msgstr "×ñþìá"
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grassmods_es.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grassmods_es\n"
"PO-Revision-Date: 2011-05-17 16:53+0100\n"
"Last-Translator: Joana Palahí <joana at sigte.udg.edu>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -234,7 +234,7 @@
@@ -481,7 +481,7 @@
msgstr "La conexión a la base de datos no ha sido definida para la capa %d"
@@ -3600,7 +3600,7 @@
msgstr "Una par de coordenadas por línea, por favor"
#, fuzzy
msgid "category"
msgstr "vectorial, geometría"
@@ -5727,7 +5727,8 @@
-msgid "Input_maps"
+#, fuzzy
+msgid "Input maps"
msgstr "Mapa de entrada"
@@ -5796,8 +5797,9 @@
-msgstr "Mapas de salida"
+#, fuzzy
+msgstr "Mapa de salida"
@@ -9000,7 +9002,8 @@
+#, fuzzy
msgstr "Opciones de entrada"
@@ -9088,7 +9091,8 @@
+#, fuzzy
msgstr "Opciones de salida"
@@ -9162,58 +9166,59 @@
"solar"
+#, fuzzy
msgstr "Incorporar el efecto de sombreo del terreno"
msgstr "Utilizar la versión de baja-memoria del programa"
msgstr "Debes utilizar la longitud raster si utilizas la hora local"
#, fuzzy
msgstr "Error leyendo el archivo de segmentos"
#, fuzzy
msgstr "Valor no válido para scalex"
msgstr "insol_time e incidout son opciones incompatibles"
msgstr ""
#, fuzzy
msgstr "Marca de tiempo no válida"
msgstr "Error leyendo el tamaño de paso del horizonte"
msgstr "El tamaño de paso del horizonte tiene que ser mayor que 0."
msgid ""
msgstr ""
msgstr "El timpo e insol_tiempo son opciones incompatibles"
msgid ""
"time"
@@ -9221,21 +9226,21 @@
"Modo 1: ángulo de incidencia solar instantáneo e irradiancia utilizando una "
"hora local establecida"
msgstr "incidout requiere que se establezca el parámetro hora local (time)"
msgstr "Modo 2: irradiación diaria integrada para un día determinado del año"
msgstr ""
"Si se utiliza -s y no se usan horizontes raster, les particiones numéricas "
"deben ser = 1"
msgid ""
"horizons."
@@ -9243,21 +9248,21 @@
"Si quieres guardar memoria y usar sombras, tienes que utilizar horizontes "
"pre-calculados."
msgstr ""
"No se puede obtener información de la proyección de la localización actual"
msgstr ""
"No se pueden obtener unidades de la proyección de la localización actual"
@@ -9266,7 +9271,7 @@
"No se pueden obtener los valores clave de la proyección de la localización "
"actual"
@@ -9274,11 +9279,11 @@
msgstr ""
"No se pueden establecer los parámetros de la proyección latitud/longitud"
msgstr ""
msgstr ""
@@ -19840,7 +19845,7 @@
msgstr "Solicitud de borrado no permitida"
#, fuzzy
@@ -20197,12 +20202,12 @@
msgstr "Número de copias a imprimir"
#, fuzzy, c-format
msgstr "No se puede abrir el archivo <%s>"
#, c-format
@@ -20213,7 +20218,7 @@
"Parámetro requerido <%s> requerido no establecido:\n"
"\t(%s)"
#, fuzzy, c-format
msgstr "Archivo PostScript [%s] escrito con éxito."
@@ -20341,7 +20346,7 @@
@@ -20354,12 +20359,12 @@
msgstr "Color desconocido: <%s>"
#, c-format
msgstr "Conexión a la base de datos no definida"
@@ -20436,8 +20441,8 @@
@@ -20452,8 +20457,8 @@
@@ -21454,7 +21459,7 @@
msgstr "Valor máximo usado para para referencia de trazado de barras"
msgstr "Crear información de leyenda y enviar a stdout"
@@ -22216,29 +22221,29 @@
msgstr "Colores (uno por clase)"
msgstr "Número de capa. Si es -1 se muestran todas las capas."
msgid "Boundaries"
msgstr "Bordes"
msgstr "Anchura de contorno"
msgstr "Color de borde"
msgstr ""
"Archivo en el que guardar las instrucciones d.graph para visualizar la "
"leyenda"
msgid ""
@@ -22246,48 +22251,48 @@
"Cuando se implrima la información de la leyenda, incluir información "
"estadística ampliada del algoritmo de clasificación"
msgstr "No dibujar el mapa, solo producir la leyenda"
#, c-format
msgstr ""
"%s: Debe construir la topología en mapa vectorial. Ejecutar v.construir."
msgstr "'layer' tiene que ser > 0"
#, c-format
msgstr "Dato (%s) no numérico. La columna tiene que ser numérica "
#, c-format
msgstr "No se pueden seleccionar datos (%s) de la tabla"
#, c-format
msgstr "Color desconocido: [%s]"
msgid ""
msgstr ""
msgstr "Clasificación de puntos"
#, c-format
msgid ""
@@ -22297,22 +22302,22 @@
"color .\n"
"Se necesitan %i colors."
#, c-format
msgstr "Error interpretando color %s"
msgstr "Imprimiendo ..."
msgid ""
msgstr ""
"Los limites del mapa están fuera de la región actual, no se muestra nada."
#, c-format
msgid ""
"\n"
@@ -22321,27 +22326,27 @@
"\n"
"Número total de registros: %.0f\n"
#, c-format
msgstr "Clasificación de %s en %i classes\n"
#, c-format
msgstr "Utilizando algoritmo: *** %s ***\n"
#, c-format
msgstr "Media: %f\tStandard deviation = %f\n"
#, c-format
msgstr "Última chi2 = %f\n"
#, c-format
msgstr "Stdev multiplicado por %.4f para definir paso\n"
@@ -22801,12 +22806,14 @@
msgstr "El mapa de entrada no contiene datos"
+#, fuzzy
msgstr "El rango de color excede el límite inferior de los datos reales"
+#, fuzzy
msgstr "El rango de color excede el límite superior de los datos reales"
@@ -22825,6 +22832,14 @@
"Forzando una leyenda suave: demasiadas categorías para la altura de la "
"ventana actual"
+msgstr "El rango de color excede el límite inferior de los datos reales"
+msgstr "El rango de color excede el límite superior de los datos reales"
#, c-format
@@ -25189,7 +25204,7 @@
msgstr "Error al copia tabla de atributos al mapa de salida"
@@ -26135,7 +26150,7 @@
msgstr "Eliminar puentes"
msgstr "No es posible calcular el centroide de área"
@@ -26720,6 +26735,7 @@
msgid "From"
msgstr "Desde"
@@ -28323,7 +28339,8 @@
msgstr "Usar drand48()"
#, c-format
msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico %d"
@@ -29442,10 +29459,6 @@
"Nombre(s) de columna donde se cargarán los valores especificados por la "
"opción 'upload'"
-msgid "From_map"
-msgstr "Desde_mapa"
msgstr ""
@@ -30109,76 +30122,81 @@
msgstr "lugares."
#, fuzzy
msgstr ""
"Acjuntar, borrar o informar categorías del vectorial a la geometría del mapa."
msgstr "Elementos ids (por defecto todos los elementos son procesados)"
msgstr "Acción a realizar"
#, fuzzy
msgstr "La línea %d no tiene categoría"
#, fuzzy
msgstr ""
"Imprimir la extensión mínima de la región de los elementos vectoriales "
"seleccionados en lugar de los atributos"
msgstr ""
msgstr ""
msgid ""
msgstr ""
#, fuzzy
msgstr "Formato: capa tipo cuenta mínimo máximo"
msgstr ""
+#, fuzzy
+msgstr "No mostrar números de categoría"
msgstr "Incremento de categoría"
msgstr "Estilo de script de consola, actualmente sólo para informes"
msgid ""
msgstr ""
"La conexión a base de datos y las tablas de atributos para las capas "
"afectadas no se cambian"
msgid ""
@@ -30186,102 +30204,97 @@
"Número de categoría no válido (debe ser igual o mayor que 0). Normalmente el "
"número de categoría empieza por el 1."
#, c-format
msgstr "%d errores en la opción id"
msgstr "No se indicó el vectorial de salida"
-#, fuzzy, c-format
-msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
msgstr "Demasiadas capas para esta operación"
msgstr "2 capas deben ser especificadas"
#, fuzzy, c-format
msgstr "%d categorías leídas del mapa vectorial (capa %d)"
msgstr "Procesando elementos..."
#, c-format
msgstr "%d centroides nuevos colocados en el mapa de salida"
msgid "Layer/table"
msgstr "Capa/tabla"
msgid "Layer"
msgstr "Capa"
#, c-format
msgstr "tipo contar min max\n"
msgid "point"
msgstr "punto"
msgid "line"
msgstr "línea"
msgid "boundary"
msgstr "límite"
msgid "centroid"
msgstr "centroide"
msgid "area"
msgstr "área"
#, fuzzy
msgid "face"
msgstr "Varianza de la suma"
#, fuzzy
msgid "kernel"
msgstr "general"
msgid "all"
msgstr "todo"
msgstr "Copiando tabla(s) de atributos..."
#, fuzzy, c-format
#, c-format
msgstr "%d elementos modificados."
@@ -39692,6 +39705,16 @@
msgid "Percent to brighten"
msgstr "Porcentaje para aumentar el brilloConvergencia porcentual"
+#~ msgid "Output_maps"
+#~ msgstr "Mapas de salida"
+#~ msgid "From_map"
+#~ msgstr "Desde_mapa"
+#, fuzzy
+#~ msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
#~ msgid "nviz - Visualization and animation tool for GRASS data."
#~ msgstr ""
#~ "nviz - Herramienta de visualización y animación para datos de GRASS."
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2013-02-27 14:58:14 UTC (rev 55243)
+++ grass/trunk/locale/po/grassmods_fr.po 2013-02-27 19:12:34 UTC (rev 55244)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grassmods_fr\n"
"PO-Revision-Date: 2013-01-27 09:31+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: Français <grass-translations at lists.osgeo.org>\n"
@@ -234,7 +234,7 @@
@@ -331,8 +331,7 @@
#: ../visualization/ximgview/color.c:269
msgid "Using private colormap for DirectColor visual."
-msgstr ""
-"Utilisation d'une table de couleur privée pour la visualisation DirectColor"
+msgstr "Utilisation d'une table de couleur privée pour la visualisation DirectColor"
#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
msgid "keyword2"
@@ -482,12 +481,11 @@
#: ../vector/v.to.rast/support.c:436
#, fuzzy, c-format
msgid "Database connection not defined for layer %d"
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
# c-format
@@ -1088,8 +1086,7 @@
msgstr "Statistiques de transition de classe."
#: ../raster3d/r3.retile/main.c:104
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
msgstr ""
#: ../raster3d/r3.retile/main.c:118 ../misc/m.nviz.image/volume.c:42
@@ -1116,9 +1113,7 @@
#: ../raster3d/r3.timestamp/r3.timestamp.main.c:46
#, fuzzy
msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster 3D"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster 3D"
#: ../raster3d/r3.timestamp/r3.timestamp.main.c:55
msgid "Datetime, datetime1/datetime2, or none"
@@ -1148,9 +1143,7 @@
#: ../raster3d/r3.null/main.c:121
msgid "modifyNull: error opening tmp file"
-msgstr ""
-"modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier "
-"temporaire"
+msgstr "modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier temporaire"
#: ../raster3d/r3.null/main.c:155
msgid "modifyNull: error flushing tiles in cube"
@@ -1168,9 +1161,7 @@
#: ../raster3d/r3.null/main.c:170
#, fuzzy
msgid "modifyNull: Unable to close tmp file"
-msgstr ""
-"modifyNull (modification des valeurs nulles) : erreur dans la fermeture du "
-"fichier temporaire"
+msgstr "modifyNull (modification des valeurs nulles) : erreur dans la fermeture du fichier temporaire"
#: ../raster3d/r3.null/main.c:188
msgid "Explicitly create the 3D NULL-value bitmap file."
@@ -1193,9 +1184,7 @@
#: ../raster3d/r3.info/r3.info.main.c:79
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-"Obtenir des informations générales à propos d'une couche raster 3D spécifiée "
-"par l'utilisateur."
+msgstr "Obtenir des informations générales à propos d'une couche raster 3D spécifiée par l'utilisateur."
#: ../raster3d/r3.info/r3.info.main.c:85
#, fuzzy
@@ -1248,9 +1237,7 @@
#: ../raster3d/r3.info/r3.info.main.c:381 ../raster/r.info/main.c:285
#: ../raster/r.info/main.c:408
msgid "Cannot allocate memory for string"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../raster3d/r3.info/r3.info.main.c:327
#: ../raster3d/r3.info/r3.info.main.c:443
@@ -1288,11 +1275,8 @@
#: ../raster3d/r3.support/main.c:51
#, fuzzy
-msgid ""
-"Allows creation and/or modification of raster3d map layer support files."
-msgstr ""
-"Permet la création et/ou la modification des fichiers de gestion des couches "
-"rasters"
+msgid "Allows creation and/or modification of raster3d map layer support files."
+msgstr "Permet la création et/ou la modification des fichiers de gestion des couches rasters"
#: ../raster3d/r3.support/main.c:61 ../raster/r.support/main.c:67
#, fuzzy
@@ -1301,8 +1285,7 @@
#: ../raster3d/r3.support/main.c:69 ../raster/r.support/main.c:75
msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
-"Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
+msgstr "Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
#: ../raster3d/r3.support/main.c:75
#, fuzzy
@@ -1388,34 +1371,25 @@
#: ../raster3d/r3.gwflow/main.c:54
msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr ""
-"Carte raster 3D d'entrée avec les niveaux piezométriques initiaux en [m]"
+msgstr "Carte raster 3D d'entrée avec les niveaux piezométriques initiaux en [m]"
#: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:65
#, fuzzy
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
msgstr "couche raster de surface 2D (couche inférieure)"
#: ../raster3d/r3.gwflow/main.c:70
#, fuzzy
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
#: ../raster3d/r3.gwflow/main.c:75
#, fuzzy
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
#: ../raster3d/r3.gwflow/main.c:80
@@ -1435,36 +1409,27 @@
#: ../raster3d/r3.gwflow/main.c:93
#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
msgstr "Titre du fichier raster de sortie"
#: ../raster3d/r3.gwflow/main.c:99
#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
#: ../raster3d/r3.gwflow/main.c:105
#, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
#: ../raster3d/r3.gwflow/main.c:111
#, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
#: ../raster3d/r3.gwflow/main.c:117
#, fuzzy
-msgid ""
-"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
+msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
#: ../raster3d/r3.gwflow/main.c:127
@@ -1473,9 +1438,7 @@
msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
msgstr ""
#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:206
@@ -1496,9 +1459,7 @@
msgstr ""
#: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
msgstr ""
#: ../raster3d/r3.gwflow/main.c:180
@@ -1522,12 +1483,8 @@
msgstr "Erreur de fermeture du fichier VTK-ASCII"
#: ../raster3d/r3.mkdspf/main.c:82
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Crée un affichage à partir d'une couche raster 3D existante à partir de "
-"seuils de valeur spécifiée"
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Crée un affichage à partir d'une couche raster 3D existante à partir de seuils de valeur spécifiée"
#: ../raster3d/r3.mkdspf/main.c:90
msgid "Name of an existing 3d raster map"
@@ -1552,8 +1509,7 @@
#: ../raster3d/r3.mkdspf/main.c:120
msgid "Positive increment between isosurface levels"
-msgstr ""
-"Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
+msgstr "Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
#: ../raster3d/r3.mkdspf/main.c:127
msgid "Number of isosurface threshold levels"
@@ -1718,9 +1674,7 @@
msgstr "Racine du nom des tranches rasters créées"
#: ../raster3d/r3.to.rast/main.c:96
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
msgstr ""
#: ../raster3d/r3.to.rast/main.c:207 ../raster/r.to.rast3/main.c:198
@@ -1749,12 +1703,8 @@
msgstr ""
#: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:450
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Les réglages de région 2D et 3D sont différents. Utilisation des réglages de "
-"la fenêtre 2D pour ajuster la partie 2D de la région 3D."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de la fenêtre 2D pour ajuster la partie 2D de la région 3D."
#: ../raster3d/r3.to.rast/main.c:295 ../raster/r.to.rast3/main.c:244
#: ../raster/r.li/r.li.daemon/list.c:49 ../imagery/i.smap/multialloc.c:115
@@ -1803,11 +1753,8 @@
#: ../raster3d/r3.to.rast/main.c:308
#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà . Ce fichier va être "
-"écrasé!\n"
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr "Couche raster %i le nom de fichier %s existe déjà . Ce fichier va être écrasé!\n"
#: ../raster3d/r3.cross.rast/main.c:90
msgid "Input 3D raster map for cross section."
@@ -1829,20 +1776,12 @@
#: ../raster3d/r3.cross.rast/main.c:233
#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
-msgstr ""
-"Crée une couche raster de coupe 2D à partir du raster volumique RASTER3D à "
-"partir d'une couche de relief 2D"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr "Crée une couche raster de coupe 2D à partir du raster volumique RASTER3D à partir d'une couche de relief 2D"
#: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"carte 3D pour ajuster la région 2D."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de carte 3D pour ajuster la région 2D."
#: ../raster3d/r3.cross.rast/main.c:302
#, fuzzy
@@ -1852,8 +1791,7 @@
#: ../raster3d/r3.cross.rast/main.c:338
#, fuzzy
msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr ""
-"Erreur sur le type de raster RASTER3D! Impossible de créer la couche raster."
+msgstr "Erreur sur le type de raster RASTER3D! Impossible de créer la couche raster."
#: ../raster3d/r3.out.vtk/errorHandling.c:105
msgid "Unable to close input raster maps"
@@ -1871,18 +1809,12 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:335
#, fuzzy, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"writeVTKData : écriture des données de cellules %s de dimensions ligne %i "
-"colonnes %i et profondeur %i au format vtk-ascii"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "writeVTKData : écriture des données de cellules %s de dimensions ligne %i colonnes %i et profondeur %i au format vtk-ascii"
#: ../raster3d/r3.out.vtk/writeVTKData.c:441
msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valeurs de couches RASTER3D erronées! Les valeurs doivent être comprises "
-"entre 0 et 255!\n"
+msgstr "Valeurs de couches RASTER3D erronées! Les valeurs doivent être comprises entre 0 et 255!\n"
#: ../raster3d/r3.out.vtk/parameters.c:30
msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
@@ -1898,9 +1830,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Créer des données points VTK à la place de données cellules VTK (par défaut, "
-"cellules)"
+msgstr "Créer des données points VTK à la place de données cellules VTK (par défaut, cellules)"
#: ../raster3d/r3.out.vtk/parameters.c:56
msgid "top surface 2D raster map"
@@ -1911,27 +1841,18 @@
#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Crée une sortie 3D en relief à partir de surface de dessus et de fond, les "
-"deux couches rasters sont requises."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Crée une sortie 3D en relief à partir de surface de dessus et de fond, les deux couches rasters sont requises."
#: ../raster3d/r3.out.vtk/parameters.c:82
#, fuzzy
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
-"greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,greenmap,bluemap]"
#: ../raster3d/r3.out.vtk/parameters.c:92
#, fuzzy
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:98 ../raster/r.out.vtk/parameters.c:88
#: ../vector/v.out.vtk/main.c:73
@@ -1961,9 +1882,7 @@
msgstr "Corriger les coordonnés pour correspondre à la précision VTK-OpenGL"
#: ../raster3d/r3.out.vtk/parameters.c:133
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
msgstr ""
#: ../raster3d/r3.out.vtk/main.c:117
@@ -2003,19 +1922,13 @@
#: ../raster3d/r3.out.vtk/main.c:175
#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
-msgstr ""
-"Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On "
-"écrira uniquement la géométrie."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
+msgstr "Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On écrira uniquement la géométrie."
#: ../raster3d/r3.out.vtk/main.c:209
#, fuzzy
msgid "No RGB Data will be created."
-msgstr ""
-"Erreur d'ouverture du fichier RASTER3D <%s>. Aucune données RGB ne sera "
-"créée."
+msgstr "Erreur d'ouverture du fichier RASTER3D <%s>. Aucune données RGB ne sera créée."
#: ../raster3d/r3.out.vtk/main.c:294
#, fuzzy
@@ -2038,9 +1951,7 @@
#: ../raster3d/r3.out.vtk/main.c:541
#, fuzzy
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Erreur de fermeture de la couche de données G3D, le fichier VTK risque "
-"d'être incomplet."
+msgstr "Erreur de fermeture de la couche de données G3D, le fichier VTK risque d'être incomplet."
# c-format
#: ../raster3d/r3.out.vtk/main.c:556
@@ -2071,9 +1982,7 @@
#: ../raster3d/r3.in.ascii/main.c:94
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes "
-"les valeurs sont définies)"
+msgstr "Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes les valeurs sont définies)"
#: ../raster3d/r3.in.ascii/main.c:184
#, fuzzy, c-format
@@ -2096,11 +2005,8 @@
#: ../raster3d/r3.in.ascii/main.c:289
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"Des données subsistent dans le fichier en entrée après l'importation "
-"complète des données attendues. [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Des données subsistent dans le fichier en entrée après l'importation complète des données attendues. [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:325
#, fuzzy
@@ -2151,9 +2057,7 @@
#: ../raster3d/r3.stats/main.c:581
#, fuzzy
msgid "Number of subranges to collect stats from"
-msgstr ""
-"Nombres de chiffres après la virgule à prendre en compte pour constituer les "
-"statistiques"
+msgstr "Nombres de chiffres après la virgule à prendre en compte pour constituer les statistiques"
#: ../raster3d/r3.stats/main.c:587
msgid "Calculate statistics based on equal value groups"
@@ -2253,12 +2157,8 @@
msgstr ""
#: ../misc/m.nviz.script/main.c:440
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Ce point est ignoré, il est en dehors de la région. Peut-être que la "
-"distance focale de la caméra le place au-delà du bord?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Ce point est ignoré, il est en dehors de la région. Peut-être que la distance focale de la caméra le place au-delà du bord?"
#: ../misc/m.nviz.image/args.c:51
msgid "Use draw mode for all loaded surfaces"
@@ -2414,9 +2314,7 @@
#: ../misc/m.nviz.image/args.c:350 ../misc/m.nviz.image/args.c:459
#, fuzzy
msgid "Name of color definition column"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../misc/m.nviz.image/args.c:361
msgid "Vector line display mode"
@@ -2659,9 +2557,7 @@
msgstr ""
#: ../misc/m.nviz.image/args.c:860
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
msgstr ""
#: ../misc/m.nviz.image/args.c:862 ../misc/m.nviz.image/args.c:871
@@ -2776,24 +2672,18 @@
msgstr ""
#: ../misc/m.nviz.image/main.c:56
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Restitue en 3D des surfaces (données raster), des données vecteur 2D/3D, et "
-"des volumes (données raster 3D)."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Restitue en 3D des surfaces (données raster), des données vecteur 2D/3D, et des volumes (données raster 3D)."
#: ../misc/m.nviz.image/main.c:139
#, c-format
msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-"Exagération verticale non fournie, utilisation de la valeur calculée %.0f"
+msgstr "Exagération verticale non fournie, utilisation de la valeur calculée %.0f"
#: ../misc/m.nviz.image/main.c:151
#, c-format
msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Hauteur de point de vue non fournie, utilisation de la valeur calculée %.0f"
+msgstr "Hauteur de point de vue non fournie, utilisation de la valeur calculée %.0f"
#: ../misc/m.nviz.image/main.c:233
msgid "Unsupported output format"
@@ -2865,12 +2755,8 @@
msgstr "Zone(s) de distance"
#: ../misc/m.cogo/main.c:227
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Un utilitaire simple pour convertir des mesures de gisement et distance en "
-"coordonnées et vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Un utilitaire simple pour convertir des mesures de gisement et distance en coordonnées et vice versa."
#: ../misc/m.cogo/main.c:229
msgid "It assumes a cartesian coordinate system"
@@ -2989,9 +2875,7 @@
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
#, fuzzy
msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../misc/m.transform/main.c:329
#, fuzzy
@@ -3131,12 +3015,8 @@
#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:362
#, fuzzy
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "Impossible de convertir l'information de projection de la couche de données au format GRASS pour vérification"
#: ../raster/r.external/proj.c:34 ../raster/r.in.lidar/main.c:296
#: ../raster/r.in.gdal/main.c:378 ../vector/v.in.ogr/main.c:650
@@ -3171,20 +3051,15 @@
#, fuzzy
msgid ""
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
#: ../raster/r.external/proj.c:110 ../raster/r.in.gdal/main.c:456
#, fuzzy
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' des données en entrée.\n"
#: ../raster/r.external/proj.c:115 ../raster/r.in.lidar/main.c:379
#: ../raster/r.in.gdal/main.c:461 ../vector/v.in.ogr/main.c:733
@@ -3192,18 +3067,13 @@
#, fuzzy
msgid "Projection of input dataset and current location appear to match"
msgstr ""
-"La projection des données en entrée et le Secteur (location) courant "
-"semblent correspondre.\n"
+"La projection des données en entrée et le Secteur (location) courant semblent correspondre.\n"
"Poursuite de la procédure d'importation...\n"
#: ../raster/r.external/window.c:23
#, fuzzy
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"La carte raster en entrée est pivotée - importation impossible. Vous pouvez "
-"utiliser 'gdalwarp' pour transformer la carte en \"North up\""
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "La carte raster en entrée est pivotée - importation impossible. Vous pouvez utiliser 'gdalwarp' pour transformer la carte en \"North up\""
#: ../raster/r.external/window.c:26
msgid "Applying horizontal flip"
@@ -3399,9 +3269,7 @@
#: ../raster/r.external/main.c:148
#, fuzzy, c-format
msgid "Option <%s> and <%s> are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../raster/r.external/main.c:177 ../raster/r.in.gdal/main.c:467
#, fuzzy
@@ -3549,12 +3417,8 @@
msgstr "Importation vecteur complète"
#: ../raster/r.mode/main.c:58
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Trouve la mode des valeurs d'une couche de couverture pour les zones "
-"définies par les catégories d'une couche de base."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la mode des valeurs d'une couche de couverture pour les zones définies par les catégories d'une couche de base."
#: ../raster/r.mode/main.c:64
msgid "Base map to be reclassified"
@@ -3579,14 +3443,11 @@
#: ../raster/r.profile/main.c:53
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Sort les valeurs de la couche raster à partir de ligne(s) définies par "
-"l'utilisateur"
+msgstr "Sort les valeurs de la couche raster à partir de ligne(s) définies par l'utilisateur"
#: ../raster/r.profile/main.c:61
msgid "Name of file for output (use output=- for stdout)"
-msgstr ""
-"Nom du fichier en sortie (utilisez output=- pour le flux de sortie stdout)"
+msgstr "Nom du fichier en sortie (utilisez output=- pour le flux de sortie stdout)"
#: ../raster/r.profile/main.c:69 ../display/d.profile/main.c:206
#, fuzzy
@@ -3595,9 +3456,7 @@
#: ../raster/r.profile/main.c:76
msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-"Résolution utilisée pour le profil (par défaut = la résolution de la région "
-"courante)"
+msgstr "Résolution utilisée pour le profil (par défaut = la résolution de la région courante)"
#: ../raster/r.profile/main.c:83
msgid "Character to represent no data cell"
@@ -3605,9 +3464,7 @@
#: ../raster/r.profile/main.c:88 ../raster/r.transect/main.c:130
msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-"Sortie X et Y dans les deux premières colonnes d'un tableau de sortie à "
-"quatre colonnes"
+msgstr "Sortie X et Y dans les deux premières colonnes d'un tableau de sortie à quatre colonnes"
#: ../raster/r.profile/main.c:93
msgid "Output RRR:GGG:BBB color values for each profile point"
@@ -3665,7 +3522,7 @@
msgstr "Un couple de coordonnées par ligne, svp."
#, fuzzy
msgid "category"
msgstr ""
@@ -3674,12 +3531,8 @@
#: ../raster/r.category/main.c:55
#, fuzzy
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Afficher les étiquettes et valeurs de catégorie associées avec les couches "
-"raster demandées."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Afficher les étiquettes et valeurs de catégorie associées avec les couches raster demandées."
#: ../raster/r.category/main.c:68
#, fuzzy
@@ -3735,9 +3588,7 @@
#: ../raster/r.category/main.c:253
msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"La couche est en valeurs flottantes! La liste des cats est ignorée, la liste "
-"des vals est utilisée à la place"
+msgstr "La couche est en valeurs flottantes! La liste des cats est ignorée, la liste des vals est utilisée à la place"
#: ../raster/r.category/main.c:270
msgid "vals argument is required for floating point map!"
@@ -3761,8 +3612,7 @@
msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr ""
"\n"
-"SECTION 1b (de %1d): Détermination du courant hors carte. Achevé "
-"(pourcentage): "
+"SECTION 1b (de %1d): Détermination du courant hors carte. Achevé (pourcentage): "
#: ../raster/r.watershed/ram/sg_factor.c:14
#, fuzzy
@@ -3837,44 +3687,21 @@
#, fuzzy, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
"\n"
msgstr ""
"USAGE pour la délimitation du bassin versant:\n"
-"%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] "
-"[dr=couche_direction_drainage] [de=couche_depression] "
-"[ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant "
-"[se=couche_segment_cours_d_eau]\n"
+"%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant [se=couche_segment_cours_d_eau]\n"
"\n"
"USAGE pour la création du fichier ARMSED:\n"
-"%s [-4] el=couche_altitude t=seuil_depression_marecageuse "
-"[ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] "
-"[ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] "
-"[se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
+"%s [-4] el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] [se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
"\n"
"USAGE pour la détermination de longueur de pentes:\n"
-"[ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] "
-"[ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes "
-"[r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
+"%s [-4] el=couche_altitude t=seuil_depression_marecageuse [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] [ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes [r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
#: ../raster/r.watershed/ram/do_flatarea.c:56
msgid "Beautify flat areas: priority queue error"
@@ -3961,8 +3788,7 @@
msgid "SECTION 1b: Determining Offmap Flow."
msgstr ""
"\n"
-"(pourcentage): "
#: ../raster/r.watershed/seg/sg_factor.c:14
#, fuzzy
@@ -4048,13 +3874,11 @@
#: ../raster/r.watershed/shed/com_line.c:30
msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-"En mode express, l'ordinateur bouclera l'exécution environ 10 fois plus vite"
+msgstr "En mode express, l'ordinateur bouclera l'exécution environ 10 fois plus vite"
#: ../raster/r.watershed/shed/com_line.c:31
msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-"qu'en mode lent, mais il ne permettra pas l'exécution d'autres programmes"
+msgstr "qu'en mode lent, mais il ne permettra pas l'exécution d'autres programmes"
#: ../raster/r.watershed/shed/com_line.c:32
msgid "at the same time. The fast mode also places all of the data into"
@@ -4062,26 +3886,19 @@
#: ../raster/r.watershed/shed/com_line.c:33
msgid "RAM, which limits the size of window that can be run. The slow"
-msgstr ""
-"RAM, ce qui limite la taille de la fenêtre que l'on peut utiliser. Le mode "
-"lent"
+msgstr "RAM, ce qui limite la taille de la fenêtre que l'on peut utiliser. Le mode lent"
#: ../raster/r.watershed/shed/com_line.c:34
msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"utilise l'espace disque sur la même partition du disque dur que celle où "
-"GRASS est"
+msgstr "utilise l'espace disque sur la même partition du disque dur que celle où GRASS est"
#: ../raster/r.watershed/shed/com_line.c:35
msgid "stored. Thus, if the program does not work in the slow mode, you will"
-msgstr ""
-"installé. Par conséquent, si le programme ne fonctionne pas bien en mode "
-"lent, vous devrez"
+msgstr "installé. Par conséquent, si le programme ne fonctionne pas bien en mode lent, vous devrez"
#: ../raster/r.watershed/shed/com_line.c:36
msgid "need to remove unnecessary files from that partition. The slow mode"
-msgstr ""
-"enlever tous les fichiers superflus stockés sur cette partition. Le mode lent"
+msgstr "enlever tous les fichiers superflus stockés sur cette partition. Le mode lent"
#: ../raster/r.watershed/shed/com_line.c:37
#, c-format
@@ -4113,41 +3930,28 @@
"Une des options de %s est une cartes de dépressions. Une"
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
-msgstr ""
-"carte de dépressions indique tous les endroits dans la fenêtre courante où"
+msgid "depression map indicates all the locations in the current map window where"
+msgstr "carte de dépressions indique tous les endroits dans la fenêtre courante où"
#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr ""
-"l'eau s'accumule et n'est pas draînée sur un des bords de la carte. Les lacs "
-"sans"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+msgstr "l'eau s'accumule et n'est pas draînée sur un des bords de la carte. Les lacs sans"
#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
-msgstr ""
-"cours d'eau de sortie ni drainage souterrain sont des exemples de "
-"'dépressions'. Si vous souhaitez"
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgstr "cours d'eau de sortie ni drainage souterrain sont des exemples de 'dépressions'. Si vous souhaitez"
#: ../raster/r.watershed/shed/com_line.c:86
msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-"construire une carte de dépressions, préparez une carte où les valeurs non "
-"nulles indiquent les"
+msgstr "construire une carte de dépressions, préparez une carte où les valeurs non nulles indiquent les"
#: ../raster/r.watershed/shed/com_line.c:87
msgid "locations where depressions occur.\n"
msgstr "emplacement des dépressions réelles.\n"
#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-"Tapez juste <entrée> pour la question suivante s'il n'y a pas de carte de "
-"dépressions."
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr "Tapez juste <entrée> pour la question suivante s'il n'y a pas de carte de dépressions."
#: ../raster/r.watershed/shed/com_line.c:99
#, c-format
@@ -4159,81 +3963,50 @@
"Le programme %s divisera la couche de relief en une série de"
#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
-msgstr ""
-"bassins versants. Le nombre de bassins versants est déterminé de façon "
-"indirecte"
+msgid "watershed basins. The number of watershed basins is indirectly determined"
+msgstr "bassins versants. Le nombre de bassins versants est déterminé de façon indirecte"
#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
-msgstr ""
-"par la valeur de `seuil de bassin'. Le seuil de bassin correspond à la "
-"valeur nécessaire pour"
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
+msgstr "par la valeur de `seuil de bassin'. Le seuil de bassin correspond à la valeur nécessaire pour"
#: ../raster/r.watershed/shed/com_line.c:103
#, c-format
msgid "%s to define a unique watershed basin. This area only applies to"
-msgstr ""
-"que %s définisse un unique bassin versant. Cette zone s'applique uniquement "
-"aux"
+msgstr "que %s définisse un unique bassin versant. Cette zone s'applique uniquement aux"
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
-msgstr ""
-"'bassins de drainage exogènes'. Un bassin de drainage exogène ne possède "
-"aucun autre"
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
+msgstr "'bassins de drainage exogènes'. Un bassin de drainage exogène ne possède aucun autre"
#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
-msgstr ""
-"bassin de drainage interconnecté avec lui. La taille d'un bassin de drainage "
-"intérieur est déterminée"
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
+msgstr "bassin de drainage interconnecté avec lui. La taille d'un bassin de drainage intérieur est déterminée"
#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-"par le courant de surface dans les tronçons de cours d'eau entre les "
-"confluences."
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr "par le courant de surface dans les tronçons de cours d'eau entre les confluences."
#: ../raster/r.watershed/shed/com_line.c:108
#, c-format
msgid "Thus interior drainage basins can be of any size. The %s program"
-msgstr ""
-"Par conséquent, les bassins de drainage peuvent être de taille quelconque. "
-"Le programme %s"
+msgstr "Par conséquent, les bassins de drainage peuvent être de taille quelconque. Le programme %s"
#: ../raster/r.watershed/shed/com_line.c:110
msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-"permet aussi à l'utilisateur de mette en relation la taille du bassin au "
-"courant terrestre potentiel"
+msgstr "permet aussi à l'utilisateur de mette en relation la taille du bassin au courant terrestre potentiel"
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-"(i.e., les zones avec de faibles capacités d'infiltration auront besoin de "
-"zones plus petites pour"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr "(i.e., les zones avec de faibles capacités d'infiltration auront besoin de zones plus petites pour"
#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-"développer des cours d'eau que les zones voisines possédant des taux élevés "
-"d'infiltration)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr "développer des cours d'eau que les zones voisines possédant des taux élevés d'infiltration)."
#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"L'utilisateur peut créer une couche avec des valeurs de courant "
-"potentielles, et"
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "L'utilisateur peut créer une couche avec des valeurs de courant potentielles, et"
#: ../raster/r.watershed/shed/com_line.c:114
#, c-format
@@ -4263,8 +4036,7 @@
"How large an area (or how many overland flow units) must a drainage basin"
msgstr ""
"\n"
-"De quelle dimension (ou de combien d'unités de débit) doit être un bassin de "
-"drainage"
+"De quelle dimension (ou de combien d'unités de débit) doit être un bassin de drainage"
#: ../raster/r.watershed/shed/com_line.c:132
#, c-format
@@ -4362,8 +4134,7 @@
msgstr "une représentation de la couche d'accumulation). %s peut aussi"
#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
msgstr "générer différentes variables dans le Revised Universal Soil Loss"
#: ../raster/r.watershed/shed/com_line.c:297
@@ -4381,22 +4152,15 @@
#: ../raster/r.watershed/shed/com_line.c:349
#, c-format
msgid "disturbed land. %s reflects this with an optional map layer or value"
-msgstr ""
-"un terrain accidenté. %s tient compte de cela grâce à une couche optionnelle "
-"ou une valeur"
+msgstr "un terrain accidenté. %s tient compte de cela grâce à une couche optionnelle ou une valeur"
#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-"dans laquelle la valeur indique le pourcentage de terrain accidenté à "
-"l'intérieur de cette cellule."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr "dans laquelle la valeur indique le pourcentage de terrain accidenté à l'intérieur de cette cellule."
#: ../raster/r.watershed/shed/com_line.c:352
msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
-"Tapez <entrée> si vous ne disposez pas d'une couche montrant la topographie"
+msgstr "Tapez <entrée> si vous ne disposez pas d'une couche montrant la topographie"
#: ../raster/r.watershed/shed/com_line.c:364
msgid ""
@@ -4404,8 +4168,7 @@
"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
"\n"
-"Tapez la valeur indiquant le pourcentage de terrain accidenté. Cette valeur "
-"va"
+"Tapez la valeur indiquant le pourcentage de terrain accidenté. Cette valeur va"
#: ../raster/r.watershed/shed/com_line.c:365
msgid "be used for every cell in the current region."
@@ -4426,32 +4189,25 @@
"Overland surface flow only occurs for a set distance before swales form."
msgstr ""
"\n"
-"Le courant de surface ne parcourt qu'une distance définie avant que ne se "
-"forment des dépressions marécageuses."
+"Le courant de surface ne parcourt qu'une distance définie avant que ne se forment des dépressions marécageuses."
#: ../raster/r.watershed/shed/com_line.c:380
#, c-format
msgid "Because of digital terrain model limitations, %s cannot pick up"
-msgstr ""
-"A cause d'insuffisances du Modèle Numérique de Terrain, %s ne peut distinguer"
+msgstr "A cause d'insuffisances du Modèle Numérique de Terrain, %s ne peut distinguer"
#: ../raster/r.watershed/shed/com_line.c:382
#, c-format
msgid "these swales. %s allows for an input (warning: kludge factor)"
-msgstr ""
-"ces dépressions marécageuses. %s permet d'ajouter une entrée (attention : "
-"facteur kludge)"
+msgstr "ces dépressions marécageuses. %s permet d'ajouter une entrée (attention : facteur kludge)"
#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr "qui empêche le parcours du courant d'être trop long. Normalement,"
#: ../raster/r.watershed/shed/com_line.c:385
msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr ""
-"la longueur maximale de la pente est d'environ 600 pieds (soit à peu près "
-"183 mètres)."
+msgstr "la longueur maximale de la pente est d'environ 600 pieds (soit à peu près 183 mètres)."
#: ../raster/r.watershed/shed/com_line.c:400
msgid ""
@@ -4459,26 +4215,19 @@
"Roads, ditches, changes in ground cover, and other factors will stop"
msgstr ""
"\n"
-"Les routes, fossés, changements dans la couverture végétale, et d'autres "
-"facteurs vont interrompre"
+"Les routes, fossés, changements dans la couverture végétale, et d'autres facteurs vont interrompre"
#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
-msgstr ""
-"la pente. Vous pouvez inclure une couche raster contenant les emplacements "
-"de ces"
+msgid "slope length. You may input a raster map indicating the locations of these"
+msgstr "la pente. Vous pouvez inclure une couche raster contenant les emplacements de ces"
#: ../raster/r.watershed/shed/com_line.c:402
msgid "blocking factors.\n"
msgstr "différents facteurs d'interruption.\n"
#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-"Tapez juste <entrée> à la question suivante s'il n'y a pas de couche "
-"contenant des éléments d'interruption de pente."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr "Tapez juste <entrée> à la question suivante s'il n'y a pas de couche contenant des éléments d'interruption de pente."
#: ../raster/r.watershed/shed/basin_maps.c:12
msgid ""
@@ -4492,20 +4241,16 @@
#: ../raster/r.watershed/shed/basin_maps.c:13
msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
-msgstr ""
-"dans le modèle d'érosion sols/hydrologie. Poursuivez le chargement de "
-"couches raster"
+msgstr "dans le modèle d'érosion sols/hydrologie. Poursuivez le chargement de couches raster"
#: ../raster/r.watershed/shed/basin_maps.c:14
msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-"une par une, jusqu'à ce que toutes les couches nécessaires soient chargées."
+msgstr "une par une, jusqu'à ce que toutes les couches nécessaires soient chargées."
#: ../raster/r.watershed/shed/basin_maps.c:15
#, c-format
msgid "You can have %s include a list of categories in each."
-msgstr ""
-"%s peut vous fournir une liste des catégories de chacune d'entre elles."
+msgstr "%s peut vous fournir une liste des catégories de chacune d'entre elles."
#: ../raster/r.watershed/shed/basin_maps.c:17
#, c-format
@@ -4527,15 +4272,11 @@
#: ../raster/r.watershed/shed/basin_maps.c:38
msgid "basins. There are two possible methods of tabulating the information:"
-msgstr ""
-"bassins versants. Il existe deux méthodes possibles de mise en table de "
-"l'information :"
+msgstr "bassins versants. Il existe deux méthodes possibles de mise en table de l'information :"
#: ../raster/r.watershed/shed/basin_maps.c:39
msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-"1) en incluant seulement les données appartenant au bassin lui-même, ou 2) "
-"en utilisant"
+msgstr "1) en incluant seulement les données appartenant au bassin lui-même, ou 2) en utilisant"
#: ../raster/r.watershed/shed/basin_maps.c:40
msgid "data from the basin, and all basins upstream of it."
@@ -4594,9 +4335,7 @@
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-"%s permet aussi à l'utilisateur de préparer un rapport sous forme de couches "
-"de données pour chaque"
+msgstr "%s permet aussi à l'utilisateur de préparer un rapport sous forme de couches de données pour chaque"
#: ../raster/r.watershed/shed/intro.c:12
#, c-format
@@ -4611,8 +4350,7 @@
#: ../raster/r.watershed/shed/intro.c:16
#, c-format
msgid "%s program. %s will then ask for map layers that will be"
-msgstr ""
-"programme %s. %s demandera alors les couches de données qui seront affectées"
+msgstr "programme %s. %s demandera alors les couches de données qui seront affectées"
#: ../raster/r.watershed/shed/intro.c:18
#, c-format
@@ -4629,8 +4367,7 @@
#: ../raster/r.watershed/shed/main.c:41
msgid "Slow version of water analysis program starting now"
-msgstr ""
-"Début de l'exécution du programme d'analyse hydrologique en version lente"
+msgstr "Début de l'exécution du programme d'analyse hydrologique en version lente"
#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
#, c-format
@@ -4684,8 +4421,7 @@
msgstr "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
#: ../raster/r.watershed/front/main.c:104
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
msgstr ""
#: ../raster/r.watershed/front/main.c:111
@@ -4696,8 +4432,7 @@
#: ../raster/r.watershed/front/main.c:119
#, fuzzy
msgid "Maximum length of surface flow in map units"
-msgstr ""
-"Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
+msgstr "Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
#: ../raster/r.watershed/front/main.c:128
#, fuzzy
@@ -4711,8 +4446,7 @@
#: ../raster/r.watershed/front/main.c:130
#, fuzzy
msgid "Number of cells that drain through each cell"
-msgstr ""
-"Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
+msgstr "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
#: ../raster/r.watershed/front/main.c:132
#: ../raster/r.watershed/front/main.c:139
@@ -4800,9 +4534,7 @@
#: ../raster/r.watershed/front/main.c:173
#, fuzzy
msgid "Slope length and steepness (LS) factor for USLE"
-msgstr ""
-"Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) "
-"pour USLE"
+msgstr "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) pour USLE"
#: ../raster/r.watershed/front/main.c:179
#, fuzzy
@@ -4848,24 +4580,16 @@
msgstr "Activer l'option de mémoire étendue : le calcul est lent"
#: ../raster/r.watershed/front/main.c:216
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"Seulement nécessaire si les besoins de mémoire excèdent la RAM disponible ; "
-"voir le manuel pour calculer les besoins mémoire"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Seulement nécessaire si les besoins de mémoire excèdent la RAM disponible ; voir le manuel pour calculer les besoins mémoire"
#: ../raster/r.watershed/front/main.c:221
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-"Utiliser une accumulation d'écoulement positive même pour les sous-"
-"estimations manifestes"
+msgstr "Utiliser une accumulation d'écoulement positive même pour les sous-estimations manifestes"
#: ../raster/r.watershed/front/main.c:223
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-"Voir le manuel pour une description détaillée de la sortie d'accumulation "
-"d'écoulement"
+msgstr "Voir le manuel pour une description détaillée de la sortie d'accumulation d'écoulement"
#: ../raster/r.watershed/front/main.c:228
msgid "Beautify flat areas"
@@ -4891,8 +4615,7 @@
msgstr ""
"\n"
"Désolé, si aucune des options suivantes n'est fixée:\n"
-"\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), "
-"ou 1s\n"
+"\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), ou 1s\n"
"\tvous DEVEZ fournir une valeur pour le seuil du bassin (basin.threshold)."
#: ../raster/r.watershed/front/main.c:289
@@ -4966,8 +4689,7 @@
#: ../raster/r.drain/main.c:111
#, fuzzy
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
msgstr "Dessiner un écoulement sur un modèle de terrain raster."
#: ../raster/r.drain/main.c:114
@@ -5030,9 +4752,7 @@
msgstr "Compter le nombre de cellules traversées"
#: ../raster/r.drain/main.c:161
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
msgstr ""
#: ../raster/r.drain/main.c:173
@@ -5045,16 +4765,12 @@
#: ../raster/r.drain/main.c:181
#, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
msgstr ""
#: ../raster/r.drain/main.c:188
#, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
msgstr ""
#: ../raster/r.drain/main.c:207
@@ -5099,9 +4815,7 @@
#: ../raster/r.drain/main.c:304
#, fuzzy, c-format
msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"La couche vectorielle de départ %s ne contient aucun point dans la région "
-"courante"
+msgstr "La couche vectorielle de départ %s ne contient aucun point dans la région courante"
#: ../raster/r.drain/main.c:312
msgid "No start/stop point(s) specified"
@@ -5153,14 +4867,8 @@
#: ../raster/r.param.scale/interface.c:57
#, fuzzy
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Extrait les paramètres de terrain d'un Modèle Numérique d'Elévation (MNE). "
-"Utilise une approche multi-échelle en prenant des paramètres quadratiques "
-"sur une fenêtre de dimensions quelconques (par la méthode des moindres "
-"carrés)"
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Extrait les paramètres de terrain d'un Modèle Numérique d'Elévation (MNE). Utilise une approche multi-échelle en prenant des paramètres quadratiques sur une fenêtre de dimensions quelconques (par la méthode des moindres carrés)"
#: ../raster/r.param.scale/interface.c:75
msgid "Output raster layer containing morphometric parameter"
@@ -5193,8 +4901,7 @@
#: ../raster/r.param.scale/interface.c:121
msgid "Constrain model through central window cell"
-msgstr ""
-"Contrainte du modèle pour la cellule centrale de la fenêtre de traitement"
+msgstr "Contrainte du modèle pour la cellule centrale de la fenêtre de traitement"
#: ../raster/r.param.scale/interface.c:164
#, fuzzy
@@ -5207,8 +4914,7 @@
#: ../raster/r.in.gridatb/main.c:48
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importer des fichiers GRIDATB.FOR (TOPMODEL) dans des couches raster GRASS"
+msgstr "Importer des fichiers GRIDATB.FOR (TOPMODEL) dans des couches raster GRASS"
#: ../raster/r.in.gridatb/main.c:52
msgid "GRIDATB i/o map file"
@@ -5245,9 +4951,7 @@
#: ../raster/r.support/main.c:57
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"rasters"
#: ../raster/r.support/main.c:81
#, fuzzy
@@ -5337,8 +5041,7 @@
#: ../raster/r.topmodel/main.c:89 ../raster/r.fill.dir/main.c:100
#, fuzzy
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
msgstr "(o) Couche de gradient à partir d'une couche d'altitudes positives"
#: ../raster/r.topmodel/main.c:95
@@ -5403,8 +5106,7 @@
#: ../raster/r.topmodel/main.c:128
#, fuzzy
msgid "Name of rainfall and potential evapotranspiration data file"
-msgstr ""
-"(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
+msgstr "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
#: ../raster/r.topmodel/main.c:131 ../raster/r.out.mpeg/main.c:122
msgid "Name for output file"
@@ -5509,12 +5211,8 @@
msgstr "%s : ÃTAPE 1..."
#: ../raster/r.cross/main.c:76
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Crée le produit cartésien des valeurs de catégorie de plusieurs couches "
-"raster."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Crée le produit cartésien des valeurs de catégorie de plusieurs couches raster."
#: ../raster/r.cross/main.c:85
#, c-format
@@ -5601,8 +5299,7 @@
#: ../raster/r.distance/main.c:41
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Trouve les points les plus proches entre objets dans deux couches raster"
+msgstr "Trouve les points les plus proches entre objets dans deux couches raster"
#: ../raster/r.distance/parse.c:33
#, fuzzy
@@ -5724,13 +5421,8 @@
msgstr "Couche vecteur à supprimer"
#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Crée une couche raster composite en utilisant des valeurs de catégories "
-"connues pour une (ou davantage) de couches raster afin de renseigner les "
-"zones de \"données nulles\" dans une autre couche raster"
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crée une couche raster composite en utilisant des valeurs de catégories connues pour une (ou davantage) de couches raster afin de renseigner les zones de \"données nulles\" dans une autre couche raster"
#: ../raster/r.patch/main.c:62
msgid "Name of raster maps to be patched together"
@@ -5742,8 +5434,7 @@
#: ../raster/r.patch/main.c:72
msgid "Use zero (0) for transparency instead of NULL"
-msgstr ""
-"Utiliser la valeur zéro (0) pour la transparence à la place de la valeur NULL"
+msgstr "Utiliser la valeur zéro (0) pour la transparence à la place de la valeur NULL"
#: ../raster/r.patch/main.c:88
#, fuzzy
@@ -5771,9 +5462,7 @@
#: ../raster/r.quant/main.c:51
#, fuzzy
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Cette routine produit un fichier de quantification pour une couche raster en "
-"virgule flottante."
+msgstr "Cette routine produit un fichier de quantification pour une couche raster en virgule flottante."
#: ../raster/r.quant/main.c:59
msgid "Raster map(s) to be quantized"
@@ -5807,9 +5496,7 @@
#: ../raster/r.quant/main.c:111
#, fuzzy
msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.quant/main.c:119
#, fuzzy
@@ -5922,21 +5609,11 @@
#: ../raster/r.spread/main.c:105
#, fuzzy
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simule une propagation elliptique anisotropique sur une fenêtre graphique et "
-"génère une couche raster pour le temps cumulé de propagation, à partir de "
-"couches rasters contenant des taux de propagation (ROS), les directions ROS, "
-"et l'origine du foyer. En option, produit des couches raster contenant des "
-"coordonnées UTM pour retracer le parcours de propagation du feu"
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster pour le temps cumulé de propagation, à partir de couches rasters contenant des taux de propagation (ROS), les directions ROS, et l'origine du foyer. En option, produit des couches raster contenant des coordonnées UTM pour retracer le parcours de propagation du feu"
#: ../raster/r.spread/main.c:110
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
msgstr ""
#: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
@@ -5944,13 +5621,12 @@
#: ../raster/r.spread/main.c:153 ../raster/r.spread/main.c:161
#: ../raster/r.spread/main.c:169
#, fuzzy
-msgid "Input_maps"
+msgid "Input maps"
msgstr "couche source"
#: ../raster/r.spread/main.c:120
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-"Nom de la couche raster de taux de propagation MAXimal (ROS) (en cm/min)"
+msgstr "Nom de la couche raster de taux de propagation MAXimal (ROS) (en cm/min)"
#: ../raster/r.spread/main.c:129
msgid "Name of raster map containing DIRections of max ROS (degree)"
@@ -5965,37 +5641,24 @@
msgstr "Nom de la couche raster des foyers de départ de feu"
#: ../raster/r.spread/main.c:155
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster de DISTance maximale d'ESSAIMAGE (en m) (nécessite "
-"w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "Nom de la couche raster de DISTance maximale d'ESSAIMAGE (en m) (nécessite w/ -s)"
#: ../raster/r.spread/main.c:163
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster de VITESSE du Vent au sol (en pieds/min) (nécessite "
-"w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr "Nom de la couche raster de VITESSE du Vent au sol (en pieds/min) (nécessite w/ -s)"
#: ../raster/r.spread/main.c:171
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible de la cellule "
-"recevant un brandon de départ de foyer secondaire (%) (nécessite w/ -s) "
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible de la cellule recevant un brandon de départ de foyer secondaire (%) (nécessite w/ -s) "
#: ../raster/r.spread/main.c:179
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-"TAILLE de la fenêtre d'échantillonnage de base pour atteindre une précision "
-"suffisante (3)"
+msgstr "TAILLE de la fenêtre d'échantillonnage de base pour atteindre une précision suffisante (3)"
#: ../raster/r.spread/main.c:186
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"Echantillonnage de DENSité pour des CALCULS supplémentaires (0.0 - 1.0 (0.5))"
+msgstr "Echantillonnage de DENSité pour des CALCULS supplémentaires (0.0 - 1.0 (0.5))"
#: ../raster/r.spread/main.c:193
msgid "INITial TIME for current simulation (0) (min)"
@@ -6012,13 +5675,12 @@
#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
#: ../raster/r.spread/main.c:230
#, fuzzy
-msgid "Output_maps"
+msgid "Output maps"
msgstr "couche de sortie"
#: ../raster/r.spread/main.c:216
msgid "Name of raster map to contain OUTPUT spread time (min)"
-msgstr ""
-"Nom de la couche raster en SORTIE pour le temps de propagation (en min)"
+msgstr "Nom de la couche raster en SORTIE pour le temps de propagation (en min)"
#: ../raster/r.spread/main.c:224
#, fuzzy
@@ -6040,9 +5702,7 @@
#: ../raster/r.spread/main.c:244
msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-"Pour les feux de forêts : prendre en compte l'ESSAIMAGE du foyer initial en "
-"foyers secondaires"
+msgstr "Pour les feux de forêts : prendre en compte l'ESSAIMAGE du foyer initial en foyers secondaires"
# c-format
#: ../raster/r.spread/main.c:256
@@ -6070,14 +5730,8 @@
#: ../raster/r.cost/main.c:141
#, fuzzy
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Produit une couche raster montrant le coût cumulé d'un déplacement entre "
-"différentes positions géographiques à partir d'une couche raster où la "
-"valeur de catégorie des cellules représente le coût."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Produit une couche raster montrant le coût cumulé d'un déplacement entre différentes positions géographiques à partir d'une couche raster où la valeur de catégorie des cellules représente le coût."
#: ../raster/r.cost/main.c:148
#, fuzzy
@@ -6142,8 +5796,7 @@
#: ../raster/r.cost/main.c:214 ../raster/r.walk/main.c:254
msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
+msgstr "Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
#: ../raster/r.cost/main.c:215 ../raster/r.cost/main.c:235
#: ../raster/r.walk/main.c:255 ../raster/r.walk/main.c:305
@@ -6158,9 +5811,7 @@
#: ../raster/r.cost/main.c:230 ../raster/r.walk/main.c:300
msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-"Utiliser le \"mouvement du cavalier (aux échecs)\"; plus lent, mais plus "
-"précis"
+msgstr "Utiliser le \"mouvement du cavalier (aux échecs)\"; plus lent, mais plus précis"
#: ../raster/r.cost/main.c:234
#, fuzzy
@@ -6178,9 +5829,7 @@
#: ../raster/r.cost/main.c:294 ../raster/r.walk/main.c:363
msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Vous devez précisément exactement des points de départ, un raster de départ "
-"ou des coordonnées"
+msgstr "Vous devez précisément exactement des points de départ, un raster de départ ou des coordonnées"
#: ../raster/r.cost/main.c:299 ../raster/r.cost/main.c:705
#: ../raster/r.walk/main.c:368
@@ -6200,9 +5849,7 @@
#: ../raster/r.cost/main.c:328
#, fuzzy
msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Attention : coût négatif assigné aux cellules vides. Les cellules vides sont "
-"ignorées"
+msgstr "Attention : coût négatif assigné aux cellules vides. Les cellules vides sont ignorées"
#: ../raster/r.cost/main.c:406 ../raster/r.cost/main.c:415
#: ../raster/r.walk/main.c:557 ../raster/r.walk/main.c:567
@@ -6236,9 +5883,7 @@
#: ../raster/r.cost/main.c:479
#, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
msgstr ""
#: ../raster/r.cost/main.c:496
@@ -6281,8 +5926,7 @@
#: ../raster/r.cost/main.c:719 ../raster/r.walk/main.c:909
#, fuzzy
msgid "Specified starting location outside database window"
-msgstr ""
-"Secteur de départ spécifié en dehors de la fenêtre de la base de donnée"
+msgstr "Secteur de départ spécifié en dehors de la fenêtre de la base de donnée"
#: ../raster/r.cost/main.c:740
#, fuzzy
@@ -6329,8 +5973,7 @@
#: ../raster/r.cost/main.c:1229 ../raster/r.walk/main.c:1557
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
-msgstr ""
-"Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
+msgstr "Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
#: ../raster/r.out.vtk/writeascii.c:75
#, fuzzy
@@ -6378,9 +6021,7 @@
#: ../raster/r.out.vtk/writeascii.c:412
msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et "
-"255!\n"
+msgstr "Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et 255!\n"
#: ../raster/r.out.vtk/writeascii.c:442
#, fuzzy
@@ -6404,26 +6045,18 @@
#: ../raster/r.out.vtk/parameters.c:61
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Crée des données points VTK à la place des données cellules VTK (si aucune "
-"couche d'altitude n'est donnée)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Crée des données points VTK à la place des données cellules VTK (si aucune couche d'altitude n'est donnée)"
#: ../raster/r.out.vtk/parameters.c:71
#, fuzzy
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
#: ../raster/r.out.vtk/parameters.c:81
#, fuzzy
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
#: ../raster/r.out.vtk/parameters.c:106
msgid "Use structured grid for elevation (not recommended)"
@@ -6431,21 +6064,15 @@
#: ../raster/r.out.vtk/parameters.c:112
msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
-"Utiliser une triangulation-polydonnées pour la création de la grille "
-"d'altitude"
+msgstr "Utiliser une triangulation-polydonnées pour la création de la grille d'altitude"
#: ../raster/r.out.vtk/parameters.c:118
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-"Utiliser des arcs-polydonnées pour la création d'une grille d'altitude (afin "
-"d'utiliser vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr "Utiliser des arcs-polydonnées pour la création d'une grille d'altitude (afin d'utiliser vtkDelauny2D)"
#: ../raster/r.out.vtk/parameters.c:124
msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-"Facteur d'échelle à l'origine (si aucune couche d'altitude n'est donnée)"
+msgstr "Facteur d'échelle à l'origine (si aucune couche d'altitude n'est donnée)"
#: ../raster/r.out.vtk/main.c:61
#, fuzzy
@@ -6453,9 +6080,7 @@
msgstr "Convertit une couche raster au format VTK-Ascii"
#: ../raster/r.out.vtk/main.c:72
-msgid ""
-"No input maps specified. You need to specify at least one input map or three "
-"vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
msgstr ""
# c-format
@@ -6471,9 +6096,7 @@
#: ../raster/r.out.vtk/main.c:231
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Couches RGB erronées. Les couches doivent être de même type! La sortie RGB "
-"n'est pas créée!"
+msgstr "Couches RGB erronées. Les couches doivent être de même type! La sortie RGB n'est pas créée!"
#: ../raster/r.out.vtk/main.c:260
msgid "Writing VTK Vector Data\n"
@@ -6481,11 +6104,8 @@
#: ../raster/r.out.vtk/main.c:270
#, fuzzy
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"n'est pas créée!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
#: ../raster/r.out.vtk/main.c:282
msgid "Error closing VTK-ASCII file"
@@ -6626,15 +6246,11 @@
#: ../raster/r.statistics/main.c:86 ../raster/r.statistics2/main.c:143
msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-"Valeurs de la couche de couverture extraites des étiquettes de catégorie de "
-"la couche de couverture"
+msgstr "Valeurs de la couche de couverture extraites des étiquettes de catégorie de la couche de couverture"
#: ../raster/r.statistics/main.c:92 ../raster/r.statistics/main.c:95
msgid "This module currently only works for integer (CELL) maps"
-msgstr ""
-"Pour le moment ce module ne fonctionne qu'avec des cartes de valeurs(CELL) "
-"entières"
+msgstr "Pour le moment ce module ne fonctionne qu'avec des cartes de valeurs(CELL) entières"
#: ../raster/r.statistics/main.c:106 ../raster/r.statistics2/main.c:164
#: ../raster/r.proj/main.c:242 ../imagery/i.rectify/main.c:163
@@ -6660,12 +6276,8 @@
#: ../raster/r.rescale.eq/main.c:55
#, fuzzy
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Rééchelonne l'histogramme (ajusté sur l'étendue des valeurs de catégories) "
-"de la couche de données raster"
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Rééchelonne l'histogramme (ajusté sur l'étendue des valeurs de catégories) de la couche de données raster"
#: ../raster/r.rescale.eq/main.c:65 ../raster/r.rescale/main.c:60
msgid "The name of the raster map to be rescaled"
@@ -6673,9 +6285,7 @@
#: ../raster/r.rescale.eq/main.c:73 ../raster/r.rescale/main.c:68
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Intervalle de données à rééchelonner en entrée (par défaut : l'ensemble de "
-"la couche en entrée)"
+msgstr "Intervalle de données à rééchelonner en entrée (par défaut : l'ensemble de la couche en entrée)"
#: ../raster/r.rescale.eq/main.c:80 ../raster/r.rescale/main.c:75
msgid "The resulting raster map name"
@@ -6804,11 +6414,8 @@
msgstr ""
#: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Problème pour obtenir les paramètres de l'ellipsoïde courant, utilisation "
-"d'une sphère (6370997.0)"
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Problème pour obtenir les paramètres de l'ellipsoïde courant, utilisation d'une sphère (6370997.0)"
#: ../raster/r.los/main.c:250
#, fuzzy, c-format
@@ -6834,12 +6441,8 @@
#: ../raster/r.his/main.c:67
#, fuzzy
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Générer des couches raster de couche rouge, verte et bleue en combinant des "
-"couches raster de teinte, intensité et saturation."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Générer des couches raster de couche rouge, verte et bleue en combinant des couches raster de teinte, intensité et saturation."
#: ../raster/r.his/main.c:76 ../display/d.his/main.c:77
msgid "Name of layer to be used for HUE"
@@ -6895,12 +6498,8 @@
#: ../raster/r.buffer/main.c:69
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Créer une couche raster montrant des zones tampons entourant les cellules "
-"qui contiennent des valeurs de catégorie non NULL"
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Créer une couche raster montrant des zones tampons entourant les cellules qui contiennent des valeurs de catégorie non NULL"
#: ../raster/r.buffer/main.c:81
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
@@ -6915,9 +6514,7 @@
#: ../raster/r.buffer/main.c:94
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-"Ignore les cellules contenant la valeur zéro (0) au lieu des cellules "
-"contenant NULL"
+msgstr "Ignore les cellules contenant la valeur zéro (0) au lieu des cellules contenant NULL"
#: ../raster/r.buffer/main.c:131
#, fuzzy
@@ -6986,9 +6583,7 @@
#: ../raster/r.circle/main.c:54
#, fuzzy
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Crée une couche raster contenant des cercles concentriques autour d'un point "
-"donné"
+msgstr "Crée une couche raster contenant des cercles concentriques autour d'un point donné"
#: ../raster/r.circle/main.c:64
msgid "The coordinate of the center (east,north)"
@@ -7032,17 +6627,8 @@
#: ../raster/r.walk/main.c:185
#, fuzzy
-msgid ""
-"Computes anisotropic cumulative cost of moving between different geographic "
-"locations on an input elevation raster map whose cell category values "
-"represent elevation combined with an input raster map layer whose cell "
-"values represent friction cost."
-msgstr ""
-"Produit une couche raster montrant le coût cumulé anisotropique d'un "
-"déplacement entre différentes positions géographiques à partir d'une couche "
-"raster d'altitude où la valeur de catégorie des cellules représente "
-"l'altitude combinée avec une couche raster dont la valeur correspond au coût "
-"de rugosité."
+msgid "Computes anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Produit une couche raster montrant le coût cumulé anisotropique d'un déplacement entre différentes positions géographiques à partir d'une couche raster d'altitude où la valeur de catégorie des cellules représente l'altitude combinée avec une couche raster dont la valeur correspond au coût de rugosité."
#: ../raster/r.walk/main.c:196
msgid "Name of input raster map containing friction costs"
@@ -7059,14 +6645,11 @@
#: ../raster/r.walk/main.c:284
msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Coefficients lambda pour combiner l'énergie de marche et le coût de rugosité"
+msgstr "Coefficients lambda pour combiner l'énergie de marche et le coût de rugosité"
#: ../raster/r.walk/main.c:294
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Facteur de pente qui détermine le coût d'énergie du déplacement en fonction "
-"d'un pas de hauteur"
+msgstr "Facteur de pente qui détermine le coût d'énergie du déplacement en fonction d'un pas de hauteur"
#: ../raster/r.walk/main.c:304
msgid "Keep null values in output map"
@@ -7103,9 +6686,7 @@
#: ../raster/r.walk/main.c:422
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"ignorées"
#: ../raster/r.walk/main.c:607
#, fuzzy, c-format
@@ -7148,7 +6729,7 @@
#: ../raster/r.walk/main.c:1477
#, fuzzy, c-format
msgid "Writing movement direction file %s..."
-msgstr "Ãcrire les sommets de lignes."
+msgstr "Ãcriture du nouveau fichier...\n"
#: ../raster/r.what/main.c:98 ../raster/r.what.color/main.c:89
#: ../display/d.where/main.c:46 ../display/d.what.vect/main.c:59
@@ -7170,9 +6751,7 @@
#: ../raster/r.what/main.c:101
#, fuzzy
msgid "Queries raster maps on their category values and category labels."
-msgstr ""
-"Requète les couches raster sur les valeurs des catégories et les étiquettes "
-"des catégories"
+msgstr "Requète les couches raster sur les valeurs des catégories et les étiquettes des catégories"
#: ../raster/r.what/main.c:104
msgid "Name of existing raster map(s) to query"
@@ -7223,8 +6802,7 @@
#: ../raster/r.what/main.c:153
msgid "Output integer category values, not cell values"
-msgstr ""
-"Produire des valeurs de catégorie entières au lieu de valeurs de cellule"
+msgstr "Produire des valeurs de catégorie entières au lieu de valeurs de cellule"
#: ../raster/r.what/main.c:158
msgid "Turn on cache reporting"
@@ -7275,8 +6853,7 @@
#: ../raster/r.contour/main.c:90
#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../raster/r.contour/main.c:101
msgid "List of contour levels"
@@ -7417,17 +6994,11 @@
msgstr "couche raster à échantillonner"
#: ../raster/r.series/main.c:137
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Calcule chaque valeur de cellule en sortie comme une fonction des valeurs "
-"des cellules correspondantes dans les couches d'entrée."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Calcule chaque valeur de cellule en sortie comme une fonction des valeurs des cellules correspondantes dans les couches d'entrée."
#: ../raster/r.series/main.c:146
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
msgstr ""
#: ../raster/r.series/main.c:157
@@ -7435,8 +7006,7 @@
msgstr "Opération d'agrégation"
#: ../raster/r.series/main.c:172
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
msgstr ""
#: ../raster/r.series/main.c:179
@@ -7452,9 +7022,7 @@
#: ../raster/r.series/main.c:198
#, fuzzy
msgid "input= and file= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.series/main.c:201
#, fuzzy
@@ -7551,8 +7119,7 @@
#: ../raster/r.random.surface/main.c:61
msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-"Générer des valeurs de surface aléatoire ayant une interdépendance spatiale"
+msgstr "Générer des valeurs de surface aléatoire ayant une interdépendance spatiale"
#: ../raster/r.random.surface/main.c:68
#, fuzzy
@@ -7687,16 +7254,12 @@
#: ../raster/r.statistics3/main.c:445
#, fuzzy
msgid "-p and output= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.statistics3/main.c:469
#, fuzzy, c-format
msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-"Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)"
-"de la source."
+msgstr "Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)de la source."
# c-format
#: ../raster/r.statistics3/main.c:478 ../raster/r.statistics2/main.c:180
@@ -7724,8 +7287,7 @@
#: ../raster/r.shaded.relief2/main.c:108
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crée une couche de relief estompé à partir d'une couche d'altitude (MNT)."
+msgstr "Crée une couche de relief estompé à partir d'une couche d'altitude (MNT)."
#: ../raster/r.shaded.relief2/main.c:114
#, fuzzy
@@ -7758,8 +7320,7 @@
#: ../raster/r.shaded.relief2/main.c:147
#, fuzzy
msgid "Scale factor for converting meters to elevation units"
-msgstr ""
-"Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
+msgstr "Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
#: ../raster/r.shaded.relief2/main.c:154
#, fuzzy
@@ -7805,9 +7366,7 @@
msgstr ""
#: ../raster/r.in.xyz/main.c:164
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
msgstr ""
#: ../raster/r.in.xyz/main.c:168
@@ -7840,9 +7399,7 @@
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
#, fuzzy
msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
#: ../raster/r.in.xyz/main.c:207
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
@@ -7855,9 +7412,7 @@
msgstr "Numéro de colonne pour les valeurs dans le fichier en entrée"
#: ../raster/r.in.xyz/main.c:217
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
msgstr ""
#: ../raster/r.in.xyz/main.c:226 ../raster/r.in.lidar/main.c:195
@@ -7902,9 +7457,7 @@
#: ../raster/r.in.xyz/main.c:286 ../raster/r.in.lidar/main.c:228
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
msgstr ""
#: ../raster/r.in.xyz/main.c:291 ../raster/r.in.lidar/main.c:238
@@ -7950,17 +7503,12 @@
#: ../raster/r.in.xyz/main.c:485 ../raster/r.in.lidar/main.c:528
#, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
-"value lower than 100."
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
msgstr ""
#: ../raster/r.in.xyz/main.c:537
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Si l'entrée ne provient pas d'un fichier, il n'est possible de réaliser "
-"qu'une seule passe."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Si l'entrée ne provient pas d'un fichier, il n'est possible de réaliser qu'une seule passe."
#: ../raster/r.in.xyz/main.c:543
msgid "Range filters will not be taken into account during scan"
@@ -7981,12 +7529,10 @@
#: ../raster/r.in.xyz/main.c:1172 ../raster/r.in.xyz/main.c:1180
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"Pas assez de colonnes de données. Séparateur ou nombre de colonne "
-"incorrect ? trouvé les caractères suivants dans la ligne %lu:\n"
+"Pas assez de colonnes de données. Séparateur ou nombre de colonne incorrect ? trouvé les caractères suivants dans la ligne %lu:\n"
"[%s]"
#: ../raster/r.in.xyz/main.c:661 ../raster/r.in.xyz/main.c:1176
@@ -8044,10 +7590,8 @@
#: ../raster/r.composite/main.c:75
#, fuzzy
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Combiner des couches rouges, vertes et bleues en une seule couche composite."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Combiner des couches rouges, vertes et bleues en une seule couche composite."
#: ../raster/r.composite/main.c:89 ../raster/r.out.ppm3/main.c:63
#, c-format
@@ -8103,9 +7647,7 @@
msgstr ""
#: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
msgstr ""
#: ../raster/r.solute.transport/main.c:85
@@ -8129,14 +7671,11 @@
msgstr ""
#: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
msgstr ""
#: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
msgstr ""
#: ../raster/r.solute.transport/main.c:117
@@ -8157,21 +7696,15 @@
msgstr "couche raster de surface 2D (couche inférieure)"
#: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
msgstr ""
#: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
msgstr ""
#: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
msgstr ""
#: ../raster/r.solute.transport/main.c:161
@@ -8183,9 +7716,7 @@
msgstr ""
#: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
msgstr ""
#: ../raster/r.solute.transport/main.c:187
@@ -8202,9 +7733,7 @@
msgstr "Nombre de points d'interpolation"
#: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
msgstr ""
#: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:219
@@ -8243,8 +7772,7 @@
#: ../raster/r.solute.transport/main.c:385
#, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
msgstr ""
#: ../raster/r.solute.transport/main.c:397
@@ -8264,18 +7792,12 @@
msgstr "colonne(s)"
#: ../raster/r.volume/main.c:61
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcul le volume de données \"flaques\" et produit (en option) une couche "
-"vectorielle point GRASS contenant les centroïdes de ces 'flaques'"
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcul le volume de données \"flaques\" et produit (en option) une couche vectorielle point GRASS contenant les centroïdes de ces 'flaques'"
#: ../raster/r.volume/main.c:67
msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-"Couche de données raster existante représentant les données à additionner à "
-"l'intérieur des 'flaques'"
+msgstr "Couche de données raster existante représentant les données à additionner à l'intérieur des 'flaques'"
#: ../raster/r.volume/main.c:73
msgid "Existing raster map, preferably the output of r.clump"
@@ -8283,8 +7805,7 @@
#: ../raster/r.volume/main.c:78
msgid "Vector points map to contain clump centroids"
-msgstr ""
-"Couche vectoriel de points qui doit contenir les centroïdes de 'flaques'"
+msgstr "Couche vectoriel de points qui doit contenir les centroïdes de 'flaques'"
#: ../raster/r.volume/main.c:82
msgid "Generate unformatted report"
@@ -8305,23 +7826,17 @@
msgstr "Aucune couche spécifiée en entrée."
#: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing Boundary condition status: 0-inactive, 1-"
-"active, 2-dirichlet"
+msgid "Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
msgstr ""
#: ../raster/r.gwflow/main.c:67
#, fuzzy
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
#: ../raster/r.gwflow/main.c:72
#, fuzzy
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
#: ../raster/r.gwflow/main.c:77
@@ -8330,9 +7845,7 @@
#: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity "
-"for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
msgstr ""
#: ../raster/r.gwflow/main.c:86
@@ -8347,14 +7860,12 @@
#: ../raster/r.gwflow/main.c:92
#, fuzzy
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
#: ../raster/r.gwflow/main.c:96
#, fuzzy
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
#: ../raster/r.gwflow/main.c:100
@@ -8364,16 +7875,12 @@
#: ../raster/r.gwflow/main.c:106
#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
msgstr "Titre du fichier raster de sortie"
#: ../raster/r.gwflow/main.c:112
#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
#: ../raster/r.gwflow/main.c:118
@@ -8391,41 +7898,30 @@
msgstr "Nom de(s) (la) couche(s) raster(s) en entrée"
#: ../raster/r.gwflow/main.c:140
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
msgstr ""
#: ../raster/r.gwflow/main.c:147
#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
#: ../raster/r.gwflow/main.c:155
#, fuzzy
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
#: ../raster/r.gwflow/main.c:162
#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
#: ../raster/r.gwflow/main.c:173
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear "
-"equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
msgstr ""
#: ../raster/r.gwflow/main.c:209
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
msgstr ""
#: ../raster/r.gwflow/main.c:234
@@ -8439,9 +7935,7 @@
msgstr "Veuillez indiquer trois couches g3d RGB"
#: ../raster/r.gwflow/main.c:258
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full "
-"filled quadratic matrix, flag -f."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
msgstr ""
#: ../raster/r.gwflow/main.c:288
@@ -8474,16 +7968,11 @@
#: ../raster/r.topidx/main.c:42
#, fuzzy
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche "
-"d'altitude."
+msgstr "Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche d'altitude."
#: ../raster/r.topidx/file_io.c:35
#, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
msgstr ""
#: ../raster/r.topidx/file_io.c:42
@@ -8502,16 +7991,8 @@
msgstr "Génère des statistiques zonales pour des couches rasters"
#: ../raster/r.ros/main.c:215
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Génère trois ou quatre couches raster montrant 1) la base (orthogonale) de "
-"la 'vitesse de propagation du feu' (ROS), 2)le ROS maximum (progression du "
-"feu), 3) la direction du ROS maximum et en option 4) la distance maximale "
-"prévue pour l'essaimage du foyer initial (c.f. escarbilles/brandons)"
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Génère trois ou quatre couches raster montrant 1) la base (orthogonale) de la 'vitesse de propagation du feu' (ROS), 2)le ROS maximum (progression du feu), 3) la direction du ROS maximum et en option 4) la distance maximale prévue pour l'essaimage du foyer initial (c.f. escarbilles/brandons)"
#: ../raster/r.ros/main.c:222
msgid "Name of raster map containing fuel MODELs"
@@ -8519,18 +8000,15 @@
#: ../raster/r.ros/main.c:228
msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 1 heure (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 1 heure (%)"
#: ../raster/r.ros/main.c:234
msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 10 heures (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 10 heures (%)"
#: ../raster/r.ros/main.c:240
msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 100 heures (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 100 heures (%)"
#: ../raster/r.ros/main.c:245
msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
@@ -8550,9 +8028,7 @@
#: ../raster/r.ros/main.c:269
msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-"Nom de la couche raster d'ASPECT (en degrés, dans le sens anti-horaire en "
-"partant de l'E)"
+msgstr "Nom de la couche raster d'ASPECT (en degrés, dans le sens anti-horaire en partant de l'E)"
#: ../raster/r.ros/main.c:274
msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
@@ -8572,23 +8048,17 @@
msgstr "Donne aussi la distance maximum d'ESSAIMAGE DU FOYER"
#: ../raster/r.ros/main.c:296
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
msgstr ""
#: ../raster/r.ros/main.c:320
#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
msgstr ""
#: ../raster/r.ros/main.c:325
#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
msgstr ""
#: ../raster/r.ros/main.c:339
@@ -8618,10 +8088,8 @@
#: ../raster/r.in.arc/main.c:63
#, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr ""
-"Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr "Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
#: ../raster/r.in.arc/main.c:67
#, fuzzy
@@ -8696,12 +8164,8 @@
#: ../raster/r.fill.dir/main.c:89
#, fuzzy
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
-"direction d'écoulement depuis une couche d'altitude donnée"
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée"
#: ../raster/r.fill.dir/main.c:105
#, fuzzy
@@ -8875,9 +8339,7 @@
#: ../raster/r.statistics2/main.c:104
#, fuzzy
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
msgstr "Statistiques sur catégories ou objets"
#: ../raster/r.statistics2/main.c:177
@@ -8948,12 +8410,8 @@
#: ../raster/r.clump/main.c:50
#, fuzzy
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Reclasser les données dans une couche raster en regroupant les cellules qui "
-"forment des zones physiques discrètes."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
#: ../raster/r.clump/main.c:96
#, fuzzy, c-format
@@ -8981,9 +8439,7 @@
msgstr "Couche en entrée contenant les lignes"
#: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
msgstr ""
#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
@@ -9046,8 +8502,7 @@
#: ../raster/r.colors/edit_colors.c:121 ../vector/v.colors/main.c:114
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
msgid "Only write new color table if one doesn't already exist"
-msgstr ""
-"N'écrire une nouvelle table de couleur que s'il n'en existe pas déjà une"
+msgstr "N'écrire une nouvelle table de couleur que s'il n'en existe pas déjà une"
#: ../raster/r.colors/edit_colors.c:125 ../vector/v.colors/main.c:118
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
@@ -9079,35 +8534,27 @@
#: ../raster/r.colors/edit_colors.c:164 ../raster/r.colors/edit_colors.c:172
#, fuzzy, c-format
msgid "Options <%s> and <%s> options are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../raster/r.colors/edit_colors.c:168
#, fuzzy, c-format
msgid "Options <%s> or <%s> must be specified"
-msgstr ""
-"L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
+msgstr "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
#: ../raster/r.colors/edit_colors.c:181
#, fuzzy, c-format
msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
#: ../raster/r.colors/edit_colors.c:186
#, fuzzy, c-format
msgid "Options <%s>, <%s>, and <%s> options are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.colors/edit_colors.c:191 ../vector/v.colors/main.c:189
#, fuzzy, c-format
msgid "Flags -%c and -%c flags are mutually exclusive"
-msgstr ""
-"qu'un seul."
# c-format
#: ../raster/r.colors/edit_colors.c:204 ../raster/r.series.interp/main.c:170
@@ -9147,23 +8594,17 @@
#: ../raster/r.colors/edit_colors.c:376
#, fuzzy, c-format
msgid "Color table 'random' is not supported for floating point %s map"
-msgstr ""
-"Impossible de construire une table de couleurs aléatoire pour les couches en "
-"valeurs flottantes"
+msgstr "Impossible de construire une table de couleurs aléatoire pour les couches en valeurs flottantes"
#: ../raster/r.colors/edit_colors.c:380
#, fuzzy, c-format
msgid "Color table 'grey.eq' is not supported for floating point %s map"
-msgstr ""
-"Impossible de construire une table en valeurs de gris pour les couches en "
+msgstr "Impossible de construire une table en valeurs de gris pour les couches en valeurs flottantes"
#: ../raster/r.colors/edit_colors.c:386
#, fuzzy, c-format
msgid "Color table 'grey.log' is not supported for floating point %s map"
-msgstr ""
#: ../raster/r.colors/edit_colors.c:394
#, fuzzy, c-format
@@ -9190,9 +8631,7 @@
#: ../raster/r.colors/rules.c:40
#, c-format
msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-"Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez "
-"besoin.\n"
+msgstr "Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez besoin.\n"
#: ../raster/r.colors/rules.c:49
#, fuzzy, c-format
@@ -9302,25 +8741,17 @@
#: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-"Les réglages de région 2D et 3D sont différents. Utilisation des réglages de "
-"carte 3D pour ajuster la région 2D."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de carte 3D pour ajuster la région 2D."
#: ../raster/r.to.rast3/main.c:262
#, c-format
msgid "Open raster map %s - one time for each depth (%d/%d)"
-msgstr ""
-"Ouvrir la couche raster %s - une couche pour chaque niveau de profondeur (%d/"
-"%d)"
+msgstr "Ouvrir la couche raster %s - une couche pour chaque niveau de profondeur (%d/%d)"
#: ../raster/r.to.rast3/main.c:275
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"Les couches en entrée doivent être composées du même type de données : soit "
-"CELL, FCELL ou DCELL!"
+msgstr "Les couches en entrée doivent être composées du même type de données : soit CELL, FCELL ou DCELL!"
#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
#, fuzzy
@@ -9346,28 +8777,14 @@
msgstr ""
#: ../raster/r.sun/main.c:234
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi "
-"pour un jour donné, une latitude; des propriétés de surface et des "
-"conditions atmosphériques. Les paramètres solaires (par exemple, le lever du "
-"soleil, le coucher du soleil, la déclinaison, les radiations extra-"
-"terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. "
-"Sinon, une heure locale peut être indiquée pour calculer des angles "
-"d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres "
-"portées par la topographie peuvent être pris en compte de façon optionnelle."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi pour un jour donné, une latitude; des propriétés de surface et des conditions atmosphériques. Les paramètres solaires (par exemple, le lever du soleil, le coucher du soleil, la déclinaison, les radiations extra-terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. Sinon, une heure locale peut être indiquée pour calculer des angles d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres portées par la topographie peuvent être pris en compte de façon optionnelle."
#: ../raster/r.sun/main.c:248 ../raster/r.horizon/main.c:197
msgid "Name of the input elevation raster map [meters]"
msgstr "Nom de la couche raster d'altitude (mètres)"
+# c-format
#: ../raster/r.sun/main.c:249 ../raster/r.sun/main.c:258
#: ../raster/r.sun/main.c:267 ../raster/r.sun/main.c:276
#: ../raster/r.sun/main.c:284 ../raster/r.sun/main.c:293
@@ -9382,39 +8799,29 @@
#: ../raster/r.horizon/main.c:255 ../raster/r.horizon/main.c:263
#: ../raster/simwe/r.sim.sediment/main.c:175
#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Input_options"
-msgstr ""
+#, fuzzy
+msgid "Input options"
+msgstr "Secteur : %s\n"
#: ../raster/r.sun/main.c:257
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau "
-"solaire) [degrés décimaux]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun/main.c:266
msgid "A single value of the orientation (aspect), 270 is south"
msgstr ""
#: ../raster/r.sun/main.c:275
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Nom de la couche raster source de pente (pente du terrain ou inclinaison du "
-"panneau solaire) [degrés décimaux]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Nom de la couche raster source de pente (pente du terrain ou inclinaison du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun/main.c:283
msgid "A single value of inclination (slope)"
msgstr ""
#: ../raster/r.sun/main.c:292
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Nom de la couche raster source pour le coefficient atmosphérique d'opacité "
-"de Linke"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Nom de la couche raster source pour le coefficient atmosphérique d'opacité de Linke"
#: ../raster/r.sun/main.c:302
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -9439,15 +8846,12 @@
#: ../raster/r.sun/main.c:350
#, fuzzy
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
#: ../raster/r.sun/main.c:359
#, fuzzy
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
msgstr "Couche raster du coefficient de rayonnement diffus en plein ciel [-]"
#: ../raster/r.sun/main.c:367
@@ -9469,47 +8873,30 @@
#: ../raster/r.horizon/main.c:272 ../raster/r.horizon/main.c:282
#: ../raster/r.horizon/main.c:290 ../raster/simwe/r.sim.sediment/main.c:168
#: ../raster/simwe/r.sim.water/main.c:216
-msgid "Output_options"
-msgstr ""
+#, fuzzy
+msgid "Output options"
+msgstr "couche de sortie"
#: ../raster/r.sun/main.c:393
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou "
-"l'irradiation [Wh.m-2.day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou l'irradiation [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun/main.c:402
msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr ""
-"Couche raster en sortie pour la durée d'ensoleillement [h] (mode 2 "
-"uniquement)"
+msgstr "Couche raster en sortie pour la durée d'ensoleillement [h] (mode 2 uniquement)"
#: ../raster/r.sun/main.c:411
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Couche raster en sortie pour le rayonnement diffus [W.m-2] (mode 1) ou "
-"l'irradiation diffuse [Wh.m-2.day-1] (mode 2)"
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement diffus [W.m-2] (mode 1) ou l'irradiation diffuse [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun/main.c:420
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Couche raster en sortie pour le rayonnement réfléchi [W.m-2] (mode 1) ou "
-"l'irradiation réfléchie [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement réfléchi [W.m-2] (mode 1) ou l'irradiation réfléchie [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun/main.c:429
#, fuzzy
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun/main.c:436
msgid "No. of day of the year (1-365)"
@@ -9517,21 +8904,15 @@
#: ../raster/r.sun/main.c:445
msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Pas temporel pour calculer le rayonnement total sur une journée [heures "
-"décimales]"
+msgstr "Pas temporel pour calculer le rayonnement total sur une journée [heures décimales]"
#: ../raster/r.sun/main.c:452
msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Valeur de la déclinaison (écrase la valeur calculée de façon interne) "
-"[radians]"
+msgstr "Valeur de la déclinaison (écrase la valeur calculée de façon interne) [radians]"
#: ../raster/r.sun/main.c:460
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Temps (solaire) local (Ã indiquer pour le mode 1 seulement) [heures "
-"décimales]"
+msgstr "Temps (solaire) local (à indiquer pour le mode 1 seulement) [heures décimales]"
#: ../raster/r.sun/main.c:483 ../raster/r.horizon/main.c:289
msgid "Sampling distance step coefficient (0.5-1.5)"
@@ -9546,144 +8927,123 @@
msgstr ""
#: ../raster/r.sun/main.c:504
-msgid "Incorporate the shadowing effect of terrain"
+#, fuzzy
+msgid "Do not incorporate the shadowing effect of terrain"
msgstr "Intègre les effets d'ombres portées du relief"
#: ../raster/r.sun/main.c:509
msgid "Use the low-memory version of the program"
msgstr "Utiliser la version basse-mémoire du programme"
-#: ../raster/r.sun/main.c:556
+#: ../raster/r.sun/main.c:550
msgid "You must give the longitude raster if you use civil time"
msgstr ""
-#: ../raster/r.sun/main.c:559
+#: ../raster/r.sun/main.c:553
#, fuzzy
msgid "Error reading civil time zone value"
msgstr "Erreur de lecture de la couche %s"
-#: ../raster/r.sun/main.c:562
+#: ../raster/r.sun/main.c:556
#, fuzzy
msgid "Invalid civil time zone value"
msgstr "Valeur invalide de scalex"
-#: ../raster/r.sun/main.c:587
+#: ../raster/r.sun/main.c:581
msgid "insol_time and incidout are incompatible options"
msgstr "insol_time et incidout ne sont pas compatibles"
-#: ../raster/r.sun/main.c:592
+#: ../raster/r.sun/main.c:586
#, fuzzy
msgid "Error reading time step size"
# c-format
-#: ../raster/r.sun/main.c:594
+#: ../raster/r.sun/main.c:588
#, fuzzy
msgid "Invalid time step size"
msgstr "Etiquette date&heure invalide"
-#: ../raster/r.sun/main.c:598
+#: ../raster/r.sun/main.c:592
#, fuzzy
msgid "Error reading horizon step size"
msgstr "Erreur de lecture des cellules de données"
-#: ../raster/r.sun/main.c:602
+#: ../raster/r.sun/main.c:596
#, fuzzy
msgid "The horizon step size must be greater than 0."
msgstr "%s = %s -- doit être supérieur à zéro"
-#: ../raster/r.sun/main.c:605
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Si vous utilisez l'option horizon vous devez aussi fournir le paramètre "
-"'horizonstep'"
+#: ../raster/r.sun/main.c:599
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Si vous utilisez l'option horizon vous devez aussi fournir le paramètre 'horizonstep'"
-#: ../raster/r.sun/main.c:611
+#: ../raster/r.sun/main.c:605
#, fuzzy
msgid "Time and insol_time are incompatible options"
msgstr "time et insol_time ne sont pas compatibles"
-#: ../raster/r.sun/main.c:613
+#: ../raster/r.sun/main.c:607
#, fuzzy
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure "
-"locale donnée"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure locale donnée"
-#: ../raster/r.sun/main.c:618
+#: ../raster/r.sun/main.c:612
msgid "incidout requires time parameter to be set"
msgstr "incidout demande de fixer le paramètre d'heure"
-#: ../raster/r.sun/main.c:620
+#: ../raster/r.sun/main.c:614
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr "Mode 2 : irradiation journalière cumulée pour un jour donné de l'année"
-#: ../raster/r.sun/main.c:666
+#: ../raster/r.sun/main.c:660
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
-#: ../raster/r.sun/main.c:679
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Si vous souhaitez économiser de la mémoire et utiliser les ombres, vous "
-"devez utiliser des horizons pré-calculés."
+#: ../raster/r.sun/main.c:673
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Si vous souhaitez économiser de la mémoire et utiliser les ombres, vous devez utiliser des horizons pré-calculés."
-#: ../raster/r.sun/main.c:724 ../display/d.where/main.c:107
+#: ../raster/r.sun/main.c:718 ../display/d.where/main.c:107
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
-msgstr ""
-"Impossible d'obtenir les informations de projection pour le Secteur "
-"(location) courant"
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
-#: ../raster/r.sun/main.c:728 ../raster/r.horizon/main.c:476
+#: ../raster/r.sun/main.c:722 ../raster/r.horizon/main.c:476
#: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:250
#: ../general/g.region/printwindow.c:506 ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
-#: ../raster/r.sun/main.c:732 ../raster/r.horizon/main.c:480
+#: ../raster/r.sun/main.c:726 ../raster/r.horizon/main.c:480
#: ../ps/ps.map/do_geogrid.c:272 ../display/d.where/main.c:113
#: ../display/d.grid/plot.c:335 ../general/g.region/printwindow.c:253
#: ../general/g.region/printwindow.c:509 ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
-msgstr ""
-"Impossible d'obtenir les valeurs clefs de projection pour le Secteur "
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
-#: ../raster/r.sun/main.c:742 ../raster/r.horizon/main.c:490
+#: ../raster/r.sun/main.c:736 ../raster/r.horizon/main.c:490
#: ../imagery/i.latlong/main.c:114 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
#: ../display/d.grid/plot.c:342 ../display/d.grid/plot.c:369
msgid "Unable to set up lat/long projection parameters"
msgstr "Impossible de fixer les paramètres de projection longitude/latitude"
-#: ../raster/r.sun/main.c:746
+#: ../raster/r.sun/main.c:740
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
msgstr ""
-#: ../raster/r.sun/main.c:751
+#: ../raster/r.sun/main.c:745
msgid "Both latin and longin raster maps must be given, or neither"
msgstr ""
#: ../raster/r.le/r.le.patch/main.c:50
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
#: ../raster/r.le/r.le.trace/main.c:57
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
msgstr ""
# c-format
@@ -9716,9 +9076,7 @@
msgstr "Nom du fichier où stocker le résultat"
#: ../raster/r.le/r.le.setup/main.c:59
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
msgstr ""
#: ../raster/r.le/r.le.setup/main.c:63
@@ -9736,9 +9094,7 @@
msgstr "Impossible de lire la couche vecteur"
#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
msgstr ""
#: ../raster/r.digit/get_label.c:31
@@ -9756,19 +9112,12 @@
msgstr "C'est bon?"
#: ../raster/r.digit/main.c:46
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Outil interactif pour dessiner et sauvegarder des objets vecteurs à l'écran "
-"en utilisant un périphérique de pointage (souris) et de sauvegarder une "
-"couche vectorielle."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Outil interactif pour dessiner et sauvegarder des objets vecteurs à l'écran en utilisant un périphérique de pointage (souris) et de sauvegarder une couche vectorielle."
#: ../raster/r.digit/main.c:55
msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-"Commandes d'affichage à utiliser pour l'arrière-plan de numérisation "
-"(séparée par ';')"
+msgstr "Commandes d'affichage à utiliser pour l'arrière-plan de numérisation (séparée par ';')"
#: ../raster/r.digit/main.c:78
msgid "No graphics device selected!"
@@ -9852,8 +9201,7 @@
#: ../raster/r.in.bin/main.c:248
#, fuzzy
msgid "Import as double-precision floating-point data (default: integer)"
-msgstr ""
-"Importer comme virgule flottante en double précision (par défaut : entier)"
+msgstr "Importer comme virgule flottante en double précision (par défaut : entier)"
#: ../raster/r.in.bin/main.c:257
msgid "Byte Swap the Data During Import"
@@ -9876,16 +9224,12 @@
#: ../raster/r.in.bin/main.c:366
#, fuzzy
msgid "order= and -b are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.in.bin/main.c:381
#, fuzzy
msgid "-f and -d are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.in.bin/main.c:385
#, c-format
@@ -9913,9 +9257,7 @@
#: ../raster/r.in.bin/main.c:464
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
msgstr ""
#: ../raster/r.in.bin/main.c:487
@@ -9943,12 +9285,8 @@
#: ../raster/r.kappa/main.c:72
#, fuzzy
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Calculer la matrice d'erreur et le paramètre kappa pour estimer la précision "
-"de la classification obtenue."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Calculer la matrice d'erreur et le paramètre kappa pour estimer la précision de la classification obtenue."
#: ../raster/r.kappa/main.c:78
#, fuzzy
@@ -9968,9 +9306,7 @@
#: ../raster/r.kappa/main.c:89
#, fuzzy
msgid "If not given, print to startdard output"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../raster/r.kappa/main.c:90 ../raster/r.kappa/main.c:98
#: ../raster/r.report/parse.c:59 ../raster/r.report/parse.c:95
@@ -9982,7 +9318,7 @@
#: ../locale/scriptstrings/r.unpack_to_translate.c:9
#, fuzzy
msgid "Output settings"
-msgstr "couche de sortie"
+msgstr "Afficher également les paramètres 3D"
#: ../raster/r.kappa/main.c:96
msgid "Title for error matrix and kappa"
@@ -10096,14 +9432,8 @@
#: ../raster/r.resamp.rst/main.c:151
#, fuzzy
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Ré-interpole et fait une analyse topographique depuis une couche raster vers "
-"une nouvelle couche raster (probablement avec une résolution différente) en "
-"utilisant des splines régularisées avec tension et lissage."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Ré-interpole et fait une analyse topographique depuis une couche raster vers une nouvelle couche raster (probablement avec une résolution différente) en utilisant des splines régularisées avec tension et lissage."
#: ../raster/r.resamp.rst/main.c:162
msgid "Desired east-west resolution"
@@ -10176,8 +9506,7 @@
#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:166
msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-"Affiche les dérivées partielles à la place des paramètres topographiques"
+msgstr "Affiche les dérivées partielles à la place des paramètres topographiques"
#: ../raster/r.resamp.rst/main.c:313
#, fuzzy
@@ -10211,9 +9540,7 @@
#: ../raster/r.resamp.rst/main.c:335
msgid "When using anisotropy both theta and scalex must be specified"
-msgstr ""
-"Quand vous utilisez l'anisotropie, les paramètres theta et scalex doivent "
-"être spécifiés"
+msgstr "Quand vous utilisez l'anisotropie, les paramètres theta et scalex doivent être spécifiés"
#: ../raster/r.resamp.rst/main.c:375
#, fuzzy, c-format
@@ -10226,9 +9553,7 @@
#: ../raster/r.resamp.rst/main.c:389
msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-"Résolution de la couche en entrée ne correspond pas à la résolution de la "
-"région courante!"
+msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
#: ../raster/r.resamp.rst/main.c:407
msgid "Processing all selected output files will require"
@@ -10287,9 +9612,7 @@
#: ../raster/r.resamp.rst/main.c:526
#, fuzzy
msgid "Unable to write raster maps -- try increasing cell size"
-msgstr ""
-"Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la "
-"résolution"
+msgstr "Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la résolution"
#: ../raster/r.resamp.rst/main.c:558 ../vector/v.surf.rst/main.c:826
#, fuzzy, c-format
@@ -10432,25 +9755,17 @@
msgstr "Fichier d'historique pour [%s] mis à jour"
#: ../raster/r.spreadpath/main.c:93
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Trace de façon récursive le plus court chemin vers les cellules pour lequel "
-"le coût cumulé est déterminé"
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequel le coût cumulé est déterminé"
#: ../raster/r.spreadpath/main.c:102
msgid "Name of raster map containing back-path easting information"
-msgstr ""
-"Nom de la couche raster pour les informations X de plus court chemin pour la "
-"propagation du foyer"
+msgstr "Nom de la couche raster pour les informations X de plus court chemin pour la propagation du foyer"
#: ../raster/r.spreadpath/main.c:110
#, fuzzy
msgid "Name of raster map containing back-path northing information"
-msgstr ""
-"Nom de la couche raster pour les informations Y de plus court chemin pour la "
+msgstr "Nom de la couche raster pour les informations Y de plus court chemin pour la propagation du foyer"
#: ../raster/r.spreadpath/main.c:118
msgid "The map E and N grid coordinates of starting points"
@@ -10522,12 +9837,8 @@
#: ../raster/r.random/main.c:56
#, fuzzy
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crée une couche raster et une couche vectorielle contenant des points placés "
-"au hasard."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
#: ../imagery/i.zc/main.c:65
@@ -10610,9 +9921,7 @@
#: ../raster/r.grow.distance/main.c:152
#, fuzzy
msgid "Generates a raster map of distance to features in input raster map."
-msgstr ""
-"Produit une couche raster où les aires contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
#: ../raster/r.grow.distance/main.c:159
#, fuzzy
@@ -10722,15 +10031,11 @@
#: ../raster/r.report/parse.c:94
#, fuzzy
msgid "If no output given report is printed to standard output"
-msgstr ""
#: ../raster/r.report/parse.c:104 ../raster/r.stats/main.c:134
msgid "Number of fp subranges to collect stats from"
-msgstr ""
-"Nombres de chiffres après la virgule à prendre en compte pour constituer les "
-"statistiques"
+msgstr "Nombres de chiffres après la virgule à prendre en compte pour constituer les statistiques"
#: ../raster/r.report/parse.c:105 ../raster/r.report/parse.c:133
#: ../raster/r.report/parse.c:139
@@ -10759,15 +10064,11 @@
#: ../raster/r.report/parse.c:132 ../raster/r.stats/main.c:194
msgid "Report for cats fp ranges (fp maps only)"
-msgstr ""
-"Examen des catégories en nombres à virgule flottante (couches en virgule "
-"flottante uniquement)"
+msgstr "Examen des catégories en nombres à virgule flottante (couches en virgule flottante uniquement)"
#: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:198
msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Lire une couche en virgule flottante comme une couche de valeurs entières "
-"(en utilisant les règles de quantification de la couche)"
+msgstr "Lire une couche en virgule flottante comme une couche de valeurs entières (en utilisant les règles de quantification de la couche)"
#: ../raster/r.report/parse.c:181
#, fuzzy
@@ -10830,8 +10131,7 @@
#: ../raster/r.out.pov/main.c:180
#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-"La couche raster est trop grande! Elle dépasse %d colonnes ou %d lignes"
+msgstr "La couche raster est trop grande! Elle dépasse %d colonnes ou %d lignes"
#: ../raster/r.out.pov/main.c:201
msgid "Negative elevation values in input"
@@ -10870,8 +10170,7 @@
msgid ""
"Warning, ignoring point outside window: \n"
" %.4f,%.4f\n"
-msgstr ""
-"Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
+msgstr "Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
#: ../raster/r.carve/raster.c:13 ../raster/r.texture/main.c:291
#: ../imagery/i.zc/main.c:152
@@ -10894,17 +10193,12 @@
msgstr "Traitement des lignes..."
#: ../raster/r.carve/enforce_ds.c:174
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Le vecteur sort et ré-entre dans la région - ce cas particulier n'est pas "
-"encore implémenté."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "Le vecteur sort et ré-entre dans la région - ce cas particulier n'est pas encore implémenté."
#: ../raster/r.carve/lobf.c:74
msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"Tentative de division par zéro... pas de solution unique pour le modèle... "
-"on passe..."
+msgstr "Tentative de division par zéro... pas de solution unique pour le modèle... on passe..."
#: ../raster/r.carve/main.c:76
msgid "Generates stream channels."
@@ -10912,12 +10206,8 @@
#: ../raster/r.carve/main.c:77
#, fuzzy
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Prends les données vectorielles de cours d'eau, les transforme en raster, et "
-"soustrait la profondeur du modèle de terrain en sortie"
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Prends les données vectorielles de cours d'eau, les transforme en raster, et soustrait la profondeur du modèle de terrain en sortie"
#: ../raster/r.carve/main.c:82
msgid "Name of input raster elevation map"
@@ -10968,8 +10258,7 @@
#: ../raster/r.out.tiff/main.c:94
#, fuzzy
msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
-msgstr ""
-"Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
+msgstr "Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
#: ../raster/r.out.tiff/main.c:101
#, fuzzy
@@ -10994,20 +10283,12 @@
#: ../raster/r.out.tiff/main.c:174
#, fuzzy, c-format
-msgid ""
-"Raster map <%s>> is a floating point map. Fractional values will be rounded "
-"to integer"
-msgstr ""
-"La couche <%s> du jeu de données <%s> est une couche en point flottant. Les "
-"valeurs décimales seront arrondies à l'entier!"
+msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
+msgstr "La couche <%s> du jeu de données <%s> est une couche en point flottant. Les valeurs décimales seront arrondies à l'entier!"
#: ../raster/r.out.tiff/main.c:180
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"La table de couleur pour la palette doit compter moins de 256 couleurs pour "
-"l'intervalle disponible de données"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "La table de couleur pour la palette doit compter moins de 256 couleurs pour l'intervalle disponible de données"
# c-format
#: ../raster/r.out.tiff/main.c:194
@@ -11074,9 +10355,7 @@
#: ../raster/r.null/main.c:125
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
msgstr ""
#: ../raster/r.null/main.c:131
@@ -11198,11 +10477,8 @@
#: ../raster/r.surf.idw2/main.c:84
#, fuzzy
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Les bases de données en latitude/longitude ne sont pas supportées par r."
-"flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Les bases de données en latitude/longitude ne sont pas supportées par r.flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
#: ../raster/r.surf.idw2/main.c:88
#, c-format
@@ -11253,8 +10529,7 @@
#: ../raster/r.stats/main.c:160
msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Affiche des pourcentages APPROCHÃS (le total peut être différent de 100%)"
+msgstr "Affiche des pourcentages APPROCHÃS (le total peut être différent de 100%)"
#: ../raster/r.stats/main.c:165
msgid "Print category labels"
@@ -11270,9 +10545,7 @@
#: ../raster/r.stats/main.c:180
msgid "Print raw indexes of fp ranges (fp maps only)"
-msgstr ""
-"Affiche les index brutes de valeurs en nombres à virgule flottante (couches "
-"en nombre à virgule flottante uniquement)"
+msgstr "Affiche les index brutes de valeurs en nombres à virgule flottante (couches en nombre à virgule flottante uniquement)"
#: ../raster/r.stats/main.c:185 ../raster/r.describe/main.c:90
msgid "Suppress reporting of any NULLs"
@@ -11280,8 +10553,7 @@
#: ../raster/r.stats/main.c:190
msgid "Suppress reporting of NULLs when all values are NULL"
-msgstr ""
-"Supprime l'affichage des valeurs NULL lorsque toutes les valeurs sont NULL"
+msgstr "Supprime l'affichage des valeurs NULL lorsque toutes les valeurs sont NULL"
# c-format
#: ../raster/r.stats/main.c:206 ../raster/r.univar/r.univar_main.c:114
@@ -11299,30 +10571,18 @@
#: ../raster/r.stats/main.c:277
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"%s: -i signifie lire %s comme entier! le drapeau -C et/ou l'option nsteps "
-"vont être ignorés."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "%s: -i signifie lire %s comme entier! le drapeau -C et/ou l'option nsteps vont être ignorés."
#: ../raster/r.stats/main.c:293
#, fuzzy, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"%s: cats de %s sont soit manquantes ou n'ont pas d'étiquette explicite. "
-"Utilisation de nsteps=%d"
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "%s: cats de %s sont soit manquantes ou n'ont pas d'étiquette explicite. Utilisation de nsteps=%d"
#: ../raster/r.stats/main.c:299
#, fuzzy, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"%s: le drapeau -C a été spécifié, utilisation cats fp (valeurs flottantes) "
-"intervalle de %s, l'option nsteps est ignorée"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "%s: le drapeau -C a été spécifié, utilisation cats fp (valeurs flottantes) intervalle de %s, l'option nsteps est ignorée"
#: ../raster/r.region/main.c:54
msgid "Sets the boundary definitions for a raster map."
@@ -11429,11 +10689,8 @@
msgstr ""
#: ../raster/r.univar/r.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Calcule des statistiques univariées à partir des cellules non vides d'une "
-"couche raster."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Calcule des statistiques univariées à partir des cellules non vides d'une couche raster."
#: ../raster/r.univar/r3.univar_main.c:37
msgid "3D Raster map used for zoning, must be of type CELL"
@@ -11441,18 +10698,12 @@
#: ../raster/r.univar/r3.univar_main.c:101
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"couche raster."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
#: ../raster/r.describe/main.c:57
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Affiche une liste succinte des valeurs de catégorie trouvées dans une couche "
-"raster."
+msgstr "Affiche une liste succinte des valeurs de catégorie trouvées dans une couche raster."
#: ../raster/r.describe/main.c:76
#, fuzzy
@@ -11488,8 +10739,7 @@
#: ../raster/r.out.mat/main.c:64
msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr ""
#: ../raster/r.out.mat/main.c:73
#, fuzzy
@@ -11592,12 +10842,8 @@
#: ../raster/r.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:635
#: ../vector/v.in.lidar/main.c:363
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "Impossible de convertir l'information de projection de la couche de données au format GRASS pour vérification"
# c-format
#: ../raster/r.in.lidar/main.c:311 ../vector/v.in.ogr/main.c:665
@@ -11619,12 +10865,8 @@
#: ../raster/r.in.lidar/main.c:374 ../vector/v.in.ogr/main.c:728
#: ../vector/v.in.lidar/main.c:456
#, fuzzy
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' des données en entrée.\n"
#: ../raster/r.in.lidar/main.c:567
msgid "zrange will not be taken into account during scan"
@@ -11637,42 +10879,28 @@
msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"Impossible de calculer la position du soleil sur des secteur non projetés. "
-"Spécifier directement la position du soleil."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "Impossible de calculer la position du soleil sur des secteur non projetés. Spécifier directement la position du soleil."
#: ../raster/r.sunmask/g_solposition.c:88
#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-"Le point spécifié %f, %f est en dehors de la région courante, est-ce "
-"intentionnel ? Quoi qu'il en soit il sera utilisé."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "Le point spécifié %f, %f est en dehors de la région courante, est-ce intentionnel ? Quoi qu'il en soit il sera utilisé."
#: ../raster/r.sunmask/g_solposition.c:98 ../imagery/i.latlong/main.c:101
#, fuzzy
msgid "Unable to get projection info of current location"
-msgstr ""
#: ../raster/r.sunmask/g_solposition.c:101 ../imagery/i.latlong/main.c:103
#, fuzzy
msgid "Unable to get projection units of current location"
-msgstr ""
-"courant"
#: ../raster/r.sunmask/g_solposition.c:104 ../imagery/i.latlong/main.c:105
#, fuzzy
msgid "Unable to get projection key values of current location"
-msgstr ""
#: ../raster/r.sunmask/g_solposition.c:127
#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
@@ -11691,19 +10919,13 @@
#: ../raster/r.sunmask/main.c:119
#, fuzzy
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
msgstr "Calcule un <simple> index sur un fichier raster"
#: ../raster/r.sunmask/main.c:120
#, fuzzy
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Calculer des zones d'ombre portée à partir de la position du soleil et d'un "
-"MNT. A : la position exacte du soleil est donnée. B : date/heure pour "
-"calculer la position du soleil grâce à r.sunmask."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Calculer des zones d'ombre portée à partir de la position du soleil et d'un MNT. A : la position exacte du soleil est donnée. B : date/heure pour calculer la position du soleil grâce à r.sunmask."
#: ../raster/r.sunmask/main.c:134
#, fuzzy
@@ -11812,28 +11034,18 @@
#: ../raster/r.sunmask/main.c:280
#, fuzzy
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"Ni la position du soleil, ni les coordonnées E/N, ni la date/heure/fuseau "
-"n'ont été entièrement définies."
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "Ni la position du soleil, ni les coordonnées E/N, ni la date/heure/fuseau n'ont été entièrement définies."
#: ../raster/r.sunmask/main.c:284
#, fuzzy, c-format
msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-"Calcul de la position du soleil en cours... (utilisation de solpos (V. %s) "
-"de NREL)\n"
+msgstr "Calcul de la position du soleil en cours... (utilisation de solpos (V. %s) de NREL)\n"
#: ../raster/r.sunmask/main.c:289
#, fuzzy
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-"Utilisation de données d'azimut et d'altitude du soleil (ignore d'autres "
-"données éventuelles)\n"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr "Utilisation de données d'azimut et d'altitude du soleil (ignore d'autres données éventuelles)\n"
#: ../raster/r.sunmask/main.c:397
#, fuzzy
@@ -11843,8 +11055,7 @@
#: ../raster/r.sunmask/main.c:411
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr ""
-"L'heure (%02i:%02i:%02i) est avant le lever du soleil (%02d:%02d:%02d) !\n"
+msgstr "L'heure (%02i:%02i:%02i) est avant le lever du soleil (%02d:%02d:%02d) !\n"
#: ../raster/r.sunmask/main.c:415
#, fuzzy, c-format
@@ -11858,8 +11069,7 @@
#: ../raster/r.sunmask/main.c:422
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr ""
-"L'heure (%02i:%02i:%02i) est après le coucher du soleil (%02d:%02d:%02d) !\n"
+msgstr "L'heure (%02i:%02i:%02i) est après le coucher du soleil (%02d:%02d:%02d) !\n"
#: ../raster/r.sunmask/main.c:426
#, fuzzy, c-format
@@ -11991,12 +11201,8 @@
msgstr "Couche pour le coefficient y"
#: ../raster/r.regression.line/main.c:64
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"fichier ASCII où stocker les coefficients de régression (sortie à l'écran si "
-"aucun fichier n'est spécifié)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "fichier ASCII où stocker les coefficients de régression (sortie à l'écran si aucun fichier n'est spécifié)."
#: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:141
#: ../locale/scriptstrings/i.oif_to_translate.c:11
@@ -12050,16 +11256,12 @@
#: ../raster/r.out.bin/main.c:367
#, fuzzy
msgid "order= and -s are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.out.bin/main.c:376
#, fuzzy
msgid "-i and -f are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.out.bin/main.c:413
msgid "GMT grid doesn't support 64-bit integers"
@@ -12101,12 +11303,8 @@
#: ../raster/r.surf.random/main.c:40
#, fuzzy
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Produit una couche raster de données aléatoires uniformément réparties dans "
-"un rang donné par l'utilisateur."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Produit una couche raster de données aléatoires uniformément réparties dans un rang donné par l'utilisateur."
#: ../raster/r.surf.random/main.c:47
msgid "Minimum random value"
@@ -12322,11 +11520,8 @@
#: ../raster/r.li/r.li.patchnum/main.c:35
#, fuzzy
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Calcule un index de densité de patch sur un fichier raster, en utilisant un "
-"algorithme de voisinage quatre"
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Calcule un index de densité de patch sur un fichier raster, en utilisant un algorithme de voisinage quatre"
#: ../raster/r.li/r.li.simpson/simpson.c:38
#, fuzzy
@@ -12355,12 +11550,8 @@
#: ../raster/r.li/r.li.mps/mps.c:39
#, fuzzy
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.li/r.li.shannon/shannon.c:37
#, fuzzy
@@ -12382,11 +11573,8 @@
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
#, fuzzy
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.li/r.li.padrange/padrange.c:38
#, fuzzy
@@ -12440,9 +11628,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:365
#, c-format
msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-"Le fichier de configuration peut seulement être utilisé avec les fichiers "
-"raster \t\t\t%s"
+msgstr "Le fichier de configuration peut seulement être utilisé avec les fichiers raster \t\t\t%s"
#: ../raster/r.li/r.li.daemon/daemon.c:372
msgid "Illegal configuration file (sample area)"
@@ -12485,11 +11671,8 @@
#: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.out.ppm/main.c:55
#, fuzzy
@@ -12545,8 +11728,7 @@
#: ../raster/r.random.cells/main.c:49
msgid "Generates random cell values with spatial dependence."
-msgstr ""
-"Générer des valeurs de cellules aléatoires ayant une interdépendance spatiale"
+msgstr "Générer des valeurs de cellules aléatoires ayant une interdépendance spatiale"
#: ../raster/r.random.cells/main.c:59
#, fuzzy
@@ -12566,15 +11748,11 @@
#: ../raster/r.timestamp/main.c:38
#, fuzzy
msgid "Modifies a timestamp for a raster map."
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster"
#: ../raster/r.timestamp/main.c:39
msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-"couche raster"
#: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:49
#, fuzzy
@@ -12605,12 +11783,8 @@
msgstr "Nom de la couche ASCII à créer (utiliser out=- pour stdout)"
#: ../raster/r.out.ascii/main.c:90
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-"Nombre de valeurs à produire avant de passer à la ligne (seulement pour les "
-"formats SURFER ou MODFLOW)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr "Nombre de valeurs à produire avant de passer à la ligne (seulement pour les formats SURFER ou MODFLOW)"
#: ../raster/r.out.ascii/main.c:98
msgid "String to represent null cell (GRASS grid only)"
@@ -12660,21 +11834,13 @@
#: ../raster/r.slope.aspect/main.c:153
#, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Produit des couches raster de pente, aspect, courbures et dérivées "
-"partielles à partir d'une couche raster de valeurs réelles d'altitude. "
-"L'aspect est calculé dans le sens contraire des aiguilles d'une montre à "
-"partir de l'est."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Produit des couches raster de pente, aspect, courbures et dérivées partielles à partir d'une couche raster de valeurs réelles d'altitude. L'aspect est calculé dans le sens contraire des aiguilles d'une montre à partir de l'est."
#: ../raster/r.slope.aspect/main.c:155
#, fuzzy
msgid "Aspect is calculated counterclockwise from east."
-msgstr ""
-"Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en "
-"partant de l'Est)"
+msgstr "Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en partant de l'Est)"
#: ../raster/r.slope.aspect/main.c:162 ../vector/v.surf.rst/main.c:196
#, fuzzy
@@ -12714,19 +11880,13 @@
#: ../raster/r.slope.aspect/main.c:207
#, fuzzy
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx "
-"(gradient E-W)"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx (gradient E-W)"
#: ../raster/r.slope.aspect/main.c:214
#, fuzzy
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy "
-"(gradient N-S)"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy (gradient N-S)"
#: ../raster/r.slope.aspect/main.c:221
#, fuzzy
@@ -12749,9 +11909,7 @@
#: ../raster/r.slope.aspect/main.c:250
msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-"Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être "
-"calculé"
+msgstr "Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être calculé"
#: ../raster/r.slope.aspect/main.c:259
msgid "Do not align the current region to the elevation layer"
@@ -12759,12 +11917,8 @@
#: ../raster/r.slope.aspect/main.c:334
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Vous devez spécifier au moins un des paramètres : <%s>, <%s>, <%s>, <%s>, <"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Vous devez spécifier au moins un des paramètres : <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
# c-format
#: ../raster/r.slope.aspect/main.c:356
@@ -12937,9 +12091,7 @@
#: ../raster/r.to.vect/main.c:98
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Utiliser les valeurs raster comme catégories à la place d'une séquence "
-"unique (uniquement pour les CELL)"
+msgstr "Utiliser les valeurs raster comme catégories à la place d'une séquence unique (uniquement pour les CELL)"
#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
#: ../vector/v.overlay/main.c:128 ../vector/v.overlay/main.c:138
@@ -12961,9 +12113,7 @@
#: ../raster/r.to.vect/main.c:104
#, fuzzy
msgid "Table is not created. Currently supported only for points."
-msgstr ""
-"Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. "
-"Pour le moment n'existe que pour les points."
+msgstr "Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. Pour le moment n'existe que pour les points."
#: ../raster/r.to.vect/main.c:110
#, fuzzy
@@ -12981,9 +12131,7 @@
msgstr "Lister les formats gérés en sor"
#: ../raster/r.to.vect/main.c:131
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
msgstr ""
# c-format
@@ -13036,22 +12184,16 @@
msgstr "Ãcriture %s..."
#: ../raster/r.series.interp/main.c:68
-msgid ""
-"Interpolate raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolate raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
msgstr ""
#: ../raster/r.series.interp/main.c:78
#, fuzzy
msgid "Data point position for each input map"
-msgstr ""
#: ../raster/r.series.interp/main.c:83
-msgid ""
-"Input file with an input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with an input raster map name and data point position per line, field separator between name and sample point is |"
msgstr ""
#: ../raster/r.series.interp/main.c:95
@@ -13060,9 +12202,7 @@
msgstr "Calcul des moyennes de classes..."
#: ../raster/r.series.interp/main.c:99
-msgid ""
-"Input infile with an output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input infile with an output raster map name and sample point position per line, field separator between name and sample point is |"
msgstr ""
#: ../raster/r.series.interp/main.c:109
@@ -13073,16 +12213,12 @@
#: ../raster/r.series.interp/main.c:116
#, fuzzy
msgid "output= and outfile= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.series.interp/main.c:119
#, fuzzy
msgid "samplingpos= and outfile= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.series.interp/main.c:122
#, fuzzy
@@ -13097,16 +12233,12 @@
#: ../raster/r.series.interp/main.c:128
#, fuzzy
msgid "input= and infile= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.series.interp/main.c:131
#, fuzzy
msgid "datapos= and infile= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.series.interp/main.c:134
#, fuzzy
@@ -13151,17 +12283,13 @@
#: ../raster/r.series.interp/main.c:289
#, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
msgstr ""
#: ../raster/r.series.interp/main.c:309
#, fuzzy
msgid "At least 2 input maps are required for linear interpolation"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../raster/r.series.interp/main.c:327
#, c-format
@@ -13171,9 +12299,7 @@
#: ../raster/r.out.ppm3/main.c:58
#, fuzzy
msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-"Convertit trois couches raster R,G,B en un fichier image au format PPM, avec "
-"la résolution de la région actuelle."
+msgstr "Convertit trois couches raster R,G,B en un fichier image au format PPM, avec la résolution de la région actuelle."
#: ../raster/r.out.ppm3/main.c:83
msgid "Name for new PPM file. (use out=- for stdout)"
@@ -13189,9 +12315,7 @@
msgstr "Traçage ... "
#: ../raster/r.resamp.bspline/main.c:85 ../vector/v.surf.bspline/main.c:95
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr ""
#: ../raster/r.resamp.bspline/main.c:93
@@ -13209,14 +12333,11 @@
msgstr ""
#: ../raster/r.resamp.bspline/main.c:107
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
msgstr ""
#: ../raster/r.resamp.bspline/main.c:115
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
msgstr ""
#: ../raster/r.resamp.bspline/main.c:122 ../vector/v.surf.bspline/main.c:159
@@ -13234,9 +12355,7 @@
msgstr "Garder les valeurs nulles dans la couche de sortie"
#: ../raster/r.resamp.bspline/main.c:143 ../vector/v.surf.bspline/main.c:100
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
msgstr ""
#: ../raster/r.resamp.bspline/main.c:150
@@ -13342,9 +12461,7 @@
#: ../raster/r.resamp.bspline/crosscorr.c:160
#, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
msgstr ""
# c-format
@@ -13361,8 +12478,7 @@
#: ../raster/r.resamp.bspline/crosscorr.c:193
#: ../vector/v.surf.bspline/crosscorr.c:151
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
msgstr ""
#: ../raster/r.resamp.bspline/crosscorr.c:211
@@ -13384,16 +12500,13 @@
#: ../raster/r.resamp.bspline/crosscorr.c:313
#: ../vector/v.surf.bspline/crosscorr.c:313
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
msgstr ""
#: ../raster/r.resamp.bspline/crosscorr.c:315
#: ../vector/v.surf.bspline/crosscorr.c:315
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
msgstr ""
#: ../raster/r.resamp.bspline/crosscorr.c:323
@@ -13432,11 +12545,8 @@
msgstr "Importation vecteur complète"
#: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Donne en sortie les valeurs de la couche raster situées le long du transect "
-"défini"
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Donne en sortie les valeurs de la couche raster situées le long du transect défini"
#: ../raster/r.transect/main.c:110
msgid "Raster map to be queried"
@@ -13524,9 +12634,7 @@
#: ../raster/r.grow/main.c:125 ../locale/scriptstrings/r.grow_to_translate.c:1
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"cellule."
#: ../raster/r.grow/main.c:136 ../locale/scriptstrings/r.grow_to_translate.c:4
msgid "Radius of buffer in raster cells"
@@ -13557,19 +12665,12 @@
msgstr "Erreur de lecture du fichier colr de <%s>"
#: ../raster/r.neighbors/main.c:145
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Calcule pour chaque cellule une fonction des valeurs des cellules "
-"adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche "
-"raster de sortie."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Calcule pour chaque cellule une fonction des valeurs des cellules adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche raster de sortie."
#: ../raster/r.neighbors/main.c:155
#, fuzzy
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
msgstr "couche raster où écrire les résultats rejetés du seuillage"
#: ../raster/r.neighbors/main.c:174 ../vector/v.neighbors/main.c:71
@@ -13620,28 +12721,21 @@
#: ../raster/r.neighbors/main.c:233
#, fuzzy
msgid "weight= and -c are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../raster/r.neighbors/main.c:236
#, fuzzy
msgid "weight= and gauss= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.neighbors/main.c:296
#, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+msgid "Method %s not compatible with weighing window, using weight mask instead"
msgstr ""
#: ../raster/r.neighbors/main.c:304
#, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
msgstr ""
# c-format
@@ -13717,9 +12811,7 @@
#: ../raster/r.proj/main.c:148
#, fuzzy
msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-"Re-projeter une couche raster depuis un Secteur (location) vers le Secteur "
-"courant."
+msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
#: ../raster/r.proj/main.c:151
#, fuzzy
@@ -13796,10 +12888,8 @@
#: ../raster/r.proj/main.c:224
#, fuzzy
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Affiche les paramètres de la région courante (à la façon d'un script shell)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Affiche les paramètres de la région courante (à la façon d'un script shell)"
#: ../raster/r.proj/main.c:250 ../vector/v.proj/main.c:143
#: ../vector/v.external/main.c:140
@@ -13819,23 +12909,17 @@
#: ../raster/r.proj/main.c:268
#, fuzzy
msgid "Unable to get projection info of output raster map"
-msgstr ""
#: ../raster/r.proj/main.c:271
#, fuzzy
msgid "Unable to get projection units of output raster map"
-msgstr ""
-"courant"
#: ../raster/r.proj/main.c:274
#, fuzzy
msgid "Unable to get projection key values of output raster map"
-msgstr ""
#: ../raster/r.proj/main.c:283
#, fuzzy, c-format
@@ -13881,23 +12965,17 @@
#: ../raster/r.proj/main.c:315
#, fuzzy
msgid "Unable to get projection info of input map"
-msgstr ""
#: ../raster/r.proj/main.c:318
#, fuzzy
msgid "Unable to get projection units of input map"
-msgstr ""
-"courant"
#: ../raster/r.proj/main.c:321
#, fuzzy
msgid "Unable to get projection key values of input map"
-msgstr ""
#: ../raster/r.proj/main.c:336
msgid "Unable to work with unprojected data (xy location)"
@@ -14028,18 +13106,12 @@
#: ../raster/r.reclass/main.c:52
#, fuzzy
msgid "Reclassify raster map based on category values."
-msgstr ""
-"Requète les couches raster sur les valeurs des catégories et les étiquettes "
-"des catégories"
+msgstr "Requète les couches raster sur les valeurs des catégories et les étiquettes des catégories"
#: ../raster/r.reclass/main.c:54
#, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Crée une nouvelle couche dont les catégories sont basées sur la "
-"reclassification des catégories d'une couche raster existante."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Crée une nouvelle couche dont les catégories sont basées sur la reclassification des catégories d'une couche raster existante."
#: ../raster/r.reclass/main.c:59
#, fuzzy
@@ -14069,9 +13141,7 @@
#: ../raster/r.reclass/main.c:103
#, fuzzy, c-format
msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez "
-"besoin.\n"
+msgstr "Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez besoin.\n"
#: ../raster/r.reclass/main.c:105
#, fuzzy, c-format
@@ -14131,9 +13201,7 @@
#: ../raster/r.coin/main.c:69
#, fuzzy
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
msgstr "Rééchelonne l'étendue des valeurs de catégories pour une couche raster"
#: ../raster/r.coin/main.c:77
@@ -14152,9 +13220,7 @@
msgstr "Unités de distance"
#: ../raster/r.coin/main.c:92
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
#: ../raster/r.coin/main.c:99
@@ -14194,12 +13260,8 @@
#: ../raster/r.texture/h_measure.c:123
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Trop de catégories (trouvées: %i, max: %i). Essaye de rééchelonner ou de "
-"refaire la classification de la couche"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "Trop de catégories (trouvées: %i, max: %i). Essaye de rééchelonner ou de refaire la classification de la couche"
#: ../raster/r.texture/main.c:67
#, fuzzy, c-format
@@ -14288,14 +13350,10 @@
#: ../raster/r.in.gdal/main.c:111
msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Nom du Secteur (location) où lire la projection pour la transformation des "
-"points de calage"
+msgstr "Nom du Secteur (location) où lire la projection pour la transformation des points de calage"
#: ../raster/r.in.gdal/main.c:127
-msgid ""
-"The offset will be added to the band number while output raster map name "
-"creation"
+msgid "The offset will be added to the band number while output raster map name creation"
msgstr ""
#: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:203
@@ -14310,14 +13368,10 @@
#: ../raster/r.in.gdal/main.c:162
msgid "Keep band numbers instead of using band color names"
-msgstr ""
-"Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des "
-"bandes"
+msgstr "Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des bandes"
#: ../raster/r.in.gdal/main.c:167
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
msgstr ""
#: ../raster/r.in.gdal/main.c:192
@@ -14350,33 +13404,21 @@
msgstr "ERREUR: <%s> existe déjà \n"
#: ../raster/r.in.gdal/main.c:261
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
msgstr ""
#: ../raster/r.in.gdal/main.c:282
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
msgstr ""
#: ../raster/r.in.gdal/main.c:323
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
msgstr ""
#: ../raster/r.in.gdal/main.c:343 ../vector/v.in.ogr/main.c:613
#: ../vector/v.in.lidar/main.c:338
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Impossible de convertir la projection de la couche en entrée au format "
-"GRASS ; impossible de créer le nouveau Secteur"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
# c-format
#: ../raster/r.in.gdal/main.c:349 ../general/g.proj/create.c:15
@@ -14389,8 +13431,7 @@
#, fuzzy
msgid ""
"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
@@ -14433,30 +13474,22 @@
#: ../raster/r.in.gdal/main.c:680
#, fuzzy
msgid "Unable to translate projection key values of input GCPs"
-msgstr ""
#: ../raster/r.in.gdal/main.c:696
#, fuzzy
msgid "Unable to get projection info of target location"
-msgstr ""
#: ../raster/r.in.gdal/main.c:698
#, fuzzy
msgid "Unable to get projection units of target location"
-msgstr ""
-"courant"
#: ../raster/r.in.gdal/main.c:700
#, fuzzy
msgid "Unable to get projection key values of target location"
-msgstr ""
#: ../raster/r.in.gdal/main.c:703 ../imagery/i.rectify/target.c:32
#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
@@ -14480,14 +13513,7 @@
msgstr ""
#: ../raster/r.horizon/main.c:183
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
msgstr ""
#: ../raster/r.horizon/main.c:206
@@ -14495,33 +13521,23 @@
msgstr ""
#: ../raster/r.horizon/main.c:222
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
msgstr ""
#: ../raster/r.horizon/main.c:230
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:238
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:246
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:254
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:262
@@ -14594,12 +13610,8 @@
msgstr "Impossible de lire le fichier d'intervalle"
#: ../raster/r.horizon/main.c:472
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"Impossible de récupérer les infos de projection du Secteur courant : "
-"veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Impossible de récupérer les infos de projection du Secteur courant : veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
#: ../raster/r.horizon/main.c:787 ../raster/r.horizon/main.c:805
#: ../imagery/i.latlong/main.c:133 ../ps/ps.map/do_geogrid.c:86
@@ -14633,9 +13645,7 @@
msgstr "Projection source"
#: ../raster/simwe/r.sim.sediment/main.c:117
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
msgstr ""
#: ../raster/simwe/r.sim.sediment/main.c:124
@@ -14698,9 +13708,7 @@
msgstr "Nom de la couche vecteur 2D source"
#: ../raster/simwe/r.sim.sediment/main.c:181
-msgid ""
-"Name of the sampling points output text file. For each observation vector "
-"point the time series of sediment transport is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
msgstr ""
#: ../raster/simwe/r.sim.sediment/main.c:187
@@ -14818,9 +13826,7 @@
msgstr "Nom du fichier raster source"
#: ../raster/simwe/r.sim.water/main.c:190
-msgid ""
-"point the time series of water depth is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
msgstr ""
#: ../raster/simwe/r.sim.water/main.c:196
@@ -14896,9 +13902,7 @@
#: ../raster/simwe/simlib/input.c:58
#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
msgstr ""
#: ../raster/simwe/simlib/input.c:171
@@ -14966,9 +13970,7 @@
#: ../raster/r.thin/main.c:59
msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr ""
-"'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des "
-"entités linéaires dans une couche raster"
+msgstr "'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des entités linéaires dans une couche raster"
#: ../raster/r.thin/main.c:71
msgid "Maximal number of iterations"
@@ -15038,11 +14040,8 @@
msgstr ""
#: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Produit une matrice de covariance/correlation pour la couche raster choisie."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Produit une matrice de covariance/correlation pour la couche raster choisie."
#: ../raster/r.covar/main.c:61
msgid "Print correlation matrix"
@@ -15061,38 +14060,26 @@
#: ../raster/r.out.gdal/export_band.c:346
#, fuzzy
msgid "Unable to allocate buffer for reading raster map"
-msgstr ""
-"mémoire)"
#: ../raster/r.out.gdal/export_band.c:160
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:165
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:175
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:182
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
msgstr ""
# c-format
@@ -15223,9 +14210,7 @@
#: ../raster/r.out.gdal/main.c:190
#, fuzzy
msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-"option de création du pilote de format de sortie. De multiples options "
-"peuvent être disponibles"
+msgstr "option de création du pilote de format de sortie. De multiples options peuvent être disponibles"
#: ../raster/r.out.gdal/main.c:192
msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
@@ -15236,9 +14221,7 @@
msgstr ""
#: ../raster/r.out.gdal/main.c:202
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
msgstr ""
#: ../raster/r.out.gdal/main.c:212
@@ -15264,17 +14247,13 @@
#: ../raster/r.out.gdal/main.c:266
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../raster/r.out.gdal/main.c:271
#, fuzzy
msgid "Unable to get in-memory raster driver"
-msgstr ""
-"mémoire)"
#: ../raster/r.out.gdal/main.c:275
#, c-format
@@ -15298,23 +14277,17 @@
#: ../raster/r.out.gdal/main.c:433
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
msgstr ""
#: ../raster/r.out.gdal/main.c:444
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
msgstr ""
#: ../raster/r.out.gdal/main.c:452
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
msgstr ""
# c-format
@@ -15395,10 +14368,7 @@
#: ../raster/r.out.gdal/main.c:742 ../raster/r.out.gdal/main.c:755
#: ../raster/r.out.gdal/main.c:770
#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:718 ../raster/r.out.gdal/main.c:745
@@ -15414,10 +14384,7 @@
#: ../raster/r.out.gdal/main.c:784
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:787
@@ -15440,14 +14407,12 @@
#: ../raster/r.lake/main.c:177
#, fuzzy
-msgid ""
-"Name of input raster map with given starting point(s) (at least 1 cell > 0)"
+msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
msgstr "Couche raster avec le germe (au moins 1 cellule > 0)"
#: ../raster/r.lake/main.c:183
msgid "Use negative depth values for lake raster map"
-msgstr ""
-"Utiliser des valeurs de profondeur négatives pour la couche raster du lac"
+msgstr "Utiliser des valeurs de profondeur négatives pour la couche raster du lac"
#: ../raster/r.lake/main.c:188
msgid "Overwrite seed map with result (lake) map"
@@ -15464,8 +14429,7 @@
#: ../raster/r.lake/main.c:200
msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
-"Les coordonnées des germes et la couche de sortie= doivent être fixées!"
+msgstr "Les coordonnées des germes et la couche de sortie= doivent être fixées!"
#: ../raster/r.lake/main.c:203
#, fuzzy
@@ -15488,9 +14452,7 @@
msgstr "get_img : mémoire insuffisante."
#: ../raster/r.lake/main.c:269
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
msgstr ""
#: ../raster/r.lake/main.c:348
@@ -15515,18 +14477,12 @@
#: ../raster/r.surf.gauss/main.c:42
#, fuzzy
msgid "Generates a raster map using gaussian random number generator."
-msgstr ""
-"cellule."
#: ../raster/r.surf.gauss/main.c:44
#, fuzzy
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
-msgstr ""
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
#: ../raster/r.surf.gauss/main.c:51
msgid "Distribution mean"
@@ -15555,9 +14511,7 @@
#: ../raster/r.in.poly/main.c:32
#, fuzzy
msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-"Créer des couches raster à partir de fichiers de données polygones/lignes "
-"dans le répertoire courant."
+msgstr "Créer des couches raster à partir de fichiers de données polygones/lignes dans le répertoire courant."
#: ../raster/r.in.poly/main.c:36
#, fuzzy
@@ -15581,9 +14535,7 @@
#: ../raster/r.in.ascii/main.c:79
#, fuzzy
msgid "-' for standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../raster/r.in.ascii/main.c:89
#, fuzzy
@@ -15739,14 +14691,12 @@
#: ../raster/r.out.vrml/main.c:95
#, fuzzy, c-format
msgid "Range info for [%s] not available (run r.support)"
-msgstr ""
-"Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
+msgstr "Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
#: ../raster/r.out.vrml/main.c:104
#, fuzzy, c-format
msgid "Range info for <%s> not available (run r.support)"
-msgstr ""
#: ../raster/r.out.vrml/main.c:136
#, c-format
@@ -15766,9 +14716,7 @@
#: ../raster/r.surf.fractal/process.c:54
#, fuzzy
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"mémoire)"
#: ../raster/r.surf.fractal/main.c:40
#, fuzzy
@@ -15835,9 +14783,7 @@
#: ../raster/r.resamp.filter/main.c:431
#, fuzzy
msgid "radius= and x_radius=/y_radius= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.resamp.filter/main.c:435
msgid "Either radius= or x_radius=/y_radius= required"
@@ -15890,9 +14836,7 @@
#: ../raster/r.to.rast3elev/main.c:366
#, fuzzy
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir "
-"d'une couche de relief 2D"
+msgstr "Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir d'une couche de relief 2D"
#: ../raster/r.to.rast3elev/main.c:400
#, fuzzy
@@ -16019,9 +14963,7 @@
#: ../raster/r.mapcalc/main.c:145
#, fuzzy
msgid "file= and expression= are mutually exclusive"
-msgstr ""
-"qu'un seul."
# c-format
#: ../raster/r.mapcalc/main.c:155
@@ -16136,13 +15078,8 @@
#: ../raster/r.flow/main.c:426
#, fuzzy
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
-msgstr ""
-"Constructon de courbes de terrain (lignes du courant), longueur des "
-"courants, et densité de lignes de courants (zones amont) à partir d'un "
-"modèle numérique de terrain (MNT) raster"
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+msgstr "Constructon de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique de terrain (MNT) raster"
#: ../raster/r.flow/main.c:435
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
@@ -16184,9 +15121,7 @@
#: ../raster/r.flow/main.c:472
msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr ""
-"Calculer les courants ascendants plutôt que les courants descendants par "
-"défaut"
+msgstr "Calculer les courants ascendants plutôt que les courants descendants par défaut"
#: ../raster/r.flow/main.c:476
#, fuzzy
@@ -16199,31 +15134,22 @@
#: ../raster/r.flow/main.c:535
msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"Vous devez sélectionner une couche de sortie ou plus (flout, lgout, dsout)"
+msgstr "Vous devez sélectionner une couche de sortie ou plus (flout, lgout, dsout)"
#: ../raster/r.flow/main.c:551
#, fuzzy
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
#: ../raster/r.flow/io.c:87
#, fuzzy
msgid "Elevation raster map resolution differs from current region resolution"
-msgstr ""
-"Résolution de la couche en entrée ne correspond pas à la résolution de la "
-"région courante!"
+msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
#: ../raster/r.flow/io.c:104
#, fuzzy
msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"région courante!"
#: ../raster/r.flow/io.c:121
msgid "Reading input files: barrier"
@@ -16295,9 +15221,7 @@
msgstr "Nombre de points d'interpolation"
#: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Prestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
msgstr ""
#: ../imagery/i.evapo.pt/main.c:75
@@ -16470,8 +15394,7 @@
#: ../imagery/i.gensig/openfiles.c:19 ../imagery/i.gensigset/openfiles.c:18
#, fuzzy, c-format
msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr ""
-"Impossible de lire le fichier REF du sous-groupe [%s] dans le groupe [%s]"
+msgstr "Impossible de lire le fichier REF du sous-groupe [%s] dans le groupe [%s]"
#: ../imagery/i.smap/read_sig.c:17 ../imagery/i.smap/openfiles.c:22
#, fuzzy, c-format
@@ -16517,12 +15440,8 @@
msgstr ""
#: ../imagery/i.smap/main.c:43
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Effectue une classification contextuelle de l'image en utilisant une "
-"estimation séquentielle maximum a posteriori (SMAP)."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Effectue une classification contextuelle de l'image en utilisant une estimation séquentielle maximum a posteriori (SMAP)."
# c-format
#: ../imagery/i.smap/write_img.c:15
@@ -16556,9 +15475,7 @@
#: ../imagery/i.smap/parse.c:45
msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr ""
-"Utiliser l'estimation plus grande ressemblance 'maximum likelihood' (Ã la "
-"place de l'estimation SMAP)"
+msgstr "Utiliser l'estimation plus grande ressemblance 'maximum likelihood' (Ã la place de l'estimation SMAP)"
# c-format
#: ../imagery/i.smap/parse.c:61 ../imagery/i.maxlik/open.c:17
@@ -16647,8 +15564,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
msgstr ""
#: ../imagery/i.vi/main.c:101
@@ -16700,8 +15616,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:120
-msgid ""
-"Infrared Percentage Vegetation IndexInfrared Percentage Vegetation Index"
+msgid "Infrared Percentage Vegetation IndexInfrared Percentage Vegetation Index"
msgstr ""
#: ../imagery/i.vi/main.c:121
@@ -16803,9 +15718,7 @@
msgstr "Rayon maximal pour le cercle/l'anneau (en mètres)"
#: ../imagery/i.vi/main.c:202
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
-"for Landsat -> [0-255])"
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
msgstr ""
#: ../imagery/i.vi/main.c:227
@@ -16841,8 +15754,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:253
-msgid ""
-"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi2 index requires red and nir maps, and 3 parameters related to soil line"
msgstr ""
#: ../imagery/i.vi/main.c:256
@@ -16875,9 +15787,7 @@
#: ../imagery/i.landsat.acca/main.c:70
#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:104
@@ -16943,8 +15853,7 @@
msgstr ""
#: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:164
@@ -17080,21 +15989,13 @@
#: ../imagery/i.maxlik/main.c:67
#, fuzzy
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Fonction d'imagerie qui fait une classification des réflectances spectrales "
-"des cellules de données images à partir des informations de signatures "
-"spectrales générées soit par i.cluster, i.class, ou i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "Fonction d'imagerie qui fait une classification des réflectances spectrales des cellules de données images à partir des informations de signatures spectrales générées soit par i.cluster, i.class, ou i.gensig."
#: ../imagery/i.maxlik/main.c:81
#, fuzzy
msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
-msgstr ""
#: ../imagery/i.maxlik/main.c:91
#, fuzzy
@@ -17109,18 +16010,14 @@
#: ../imagery/i.maxlik/open.c:27
#, fuzzy, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
msgstr ""
"Le sous-groupe [%s] du groupe [%s] ne contient aucun fichier.\n"
"Le sous-groupe doit contenir au moins 2 fichiers."
#: ../imagery/i.maxlik/open.c:30
#, fuzzy, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
msgstr ""
"Le sous-groupe [%s] du groupe [%s] ne contient qu'un fichier.\n"
@@ -17152,9 +16049,7 @@
msgstr "fichier 3dview <%s> non trouvé"
#: ../imagery/i.landsat.toar/main.c:67
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
msgstr ""
#: ../imagery/i.landsat.toar/main.c:69 ../imagery/i.aster.toar/main.c:98
@@ -17383,8 +16278,7 @@
#: ../imagery/i.class/signature.c:113
#, c-format
msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-"prepare_signature : la ligne de scan %d a un nombre de points aberrant."
+msgstr "prepare_signature : la ligne de scan %d a un nombre de points aberrant."
#: ../imagery/i.class/signature.c:123
msgid "signature: perimeter points out of order."
@@ -17401,8 +16295,7 @@
#: ../imagery/i.class/add_point.c:22
#, c-format
msgid "Can't mark another point. Only %d points allowed. Sorry."
-msgstr ""
-"Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
+msgstr "Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
#: ../imagery/i.class/draw_reg.c:89
#, c-format
@@ -17445,21 +16338,13 @@
msgstr "Erreur de suppression de l'ancienne couche MASK."
#: ../imagery/i.class/main.c:94
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
msgstr ""
#: ../imagery/i.class/main.c:97
#, fuzzy
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"Une fonction de traitement d'images qui génère des signatures spectrales "
-"pour une image en permettant à l'utilisateur de sélectionner des zones "
-"d'intérêt. Le fichier de signatures en sortie peut être utilisé en entrée de "
-"i.maxlik ou comme fichier germe pour i.cluster."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "Une fonction de traitement d'images qui génère des signatures spectrales pour une image en permettant à l'utilisateur de sélectionner des zones d'intérêt. Le fichier de signatures en sortie peut être utilisé en entrée de i.maxlik ou comme fichier germe pour i.cluster."
#: ../imagery/i.class/main.c:101 ../display/d.rast/main.c:61
#, fuzzy
@@ -17571,8 +16456,7 @@
#: ../imagery/i.class/complete_reg.c:12
msgid "Too few points for region. Must have at least 3 points."
-msgstr ""
-"Trop peu de points pour cette région. Vous devez entrer au moins 3 points."
+msgstr "Trop peu de points pour cette région. Vous devez entrer au moins 3 points."
#: ../imagery/i.class/complete_reg.c:14
msgid "Area already completed."
@@ -17714,9 +16598,7 @@
msgstr ""
#: ../imagery/i.aster.toar/main.c:104
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN.\n"
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
msgstr ""
#: ../imagery/i.aster.toar/main.c:108
@@ -17815,9 +16697,7 @@
#: ../imagery/i.gensig/get_train.c:55 ../imagery/i.gensigset/get_train.c:58
#, fuzzy, c-format
msgid "Training class %d only has one cell - this class will be ignored"
-msgstr ""
-"La classe d'apprentissage [%d] n'a qu'une cellule - cette classe sera "
-"ignorée."
+msgstr "La classe d'apprentissage [%d] n'a qu'une cellule - cette classe sera ignorée."
#: ../imagery/i.gensig/get_train.c:60 ../imagery/i.gensigset/get_train.c:63
#, fuzzy
@@ -17862,9 +16742,7 @@
msgstr "Le sous-groupe [%s] du groupe [%s] ne contient pas de fichier."
#: ../imagery/i.his.rgb/main.c:51
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
msgstr ""
#: ../imagery/i.his.rgb/main.c:57
@@ -17910,9 +16788,7 @@
"Nom de la couche raster de sortie"
#: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
msgstr ""
#: ../imagery/i.evapo.mh/main.c:78
@@ -18005,12 +16881,8 @@
#: ../imagery/i.rectify/main.c:97
#, fuzzy
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../imagery/i.rectify/main.c:111
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
@@ -18036,11 +16908,8 @@
#: ../imagery/i.rectify/main.c:148
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
#, fuzzy
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-"Utiliser les paramètres de la région courante dans le Secteur en sortie (déf."
-"= calculer la plus petite surface)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr "Utiliser les paramètres de la région courante dans le Secteur en sortie (déf.= calculer la plus petite surface)"
#: ../imagery/i.rectify/main.c:152
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
@@ -18218,8 +17087,7 @@
#: ../vector/v.rectify/target.c:18
#, fuzzy, c-format
msgid "Target information for group <%s> missing"
-msgstr ""
-"Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
+msgstr "Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
#: ../imagery/i.rectify/target.c:20
#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
@@ -18246,8 +17114,7 @@
#: ../imagery/i.target/main.c:68
msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
-"Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
+msgstr "Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
#: ../imagery/i.target/main.c:116
@@ -18267,8 +17134,7 @@
" OR\n"
" manually enter the variables"
msgstr ""
-"Vous devez utiliser le drapeau pour utiliser le jeu de données et le Secteur "
-"courants(-c)\n"
+"Vous devez utiliser le drapeau pour utiliser le jeu de données et le Secteur courants(-c)\n"
" OU\n"
" entrer les variables à la main."
@@ -18278,9 +17144,7 @@
msgstr "Impossible de lire le symbole, impossible d'afficher les points"
#: ../imagery/i.vpoints/main.c:97
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
msgstr ""
#: ../imagery/i.eb.h_sebal01/main.c:85 ../imagery/i.eb.evapfr/main.c:49
@@ -18507,9 +17371,7 @@
msgstr ""
#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
msgstr ""
#: ../imagery/i.albedo/main.c:127
@@ -18581,9 +17443,7 @@
#: ../imagery/i.fft/main.c:106
msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"MASK raster trouvé, penser à le supprimer (voir la page du manuel). "
-"Poursuite..."
+msgstr "MASK raster trouvé, penser à le supprimer (voir la page du manuel). Poursuite..."
#: ../imagery/i.fft/main.c:129
#, fuzzy, c-format
@@ -18795,8 +17655,7 @@
msgstr ""
#: ../imagery/i.modis.qc/main.c:256
-msgid ""
-"Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
+msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
msgstr ""
#: ../imagery/i.modis.qc/main.c:260
@@ -18987,8 +17846,7 @@
#: ../imagery/i.cca/main.c:88
msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Programme de traitement d'image en analyse en composante canonique (cca)"
+msgstr "Programme de traitement d'image en analyse en composante canonique (cca)"
#: ../imagery/i.cca/main.c:102
#, fuzzy
@@ -19018,15 +17876,12 @@
#: ../imagery/i.cca/main.c:131
msgid "Need at least two signatures in signature file."
-msgstr ""
-"Il faut au moins deux signatures dans le fichier de signatures spectrales."
+msgstr "Il faut au moins deux signatures dans le fichier de signatures spectrales."
#: ../imagery/i.cca/main.c:225
#, fuzzy, c-format
msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr ""
-"La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle "
-"0-255.\n"
+msgstr "La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle 0-255.\n"
#: ../imagery/i.cca/transform.c:24
msgid "Unable to allocate cell buffers."
@@ -19174,21 +18029,13 @@
msgstr "Type de donnée vectorielle"
#: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
msgstr ""
#: ../imagery/i.cluster/main.c:82
#, fuzzy
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"Fonction de traitement d'image qui génère des signatures spectrales pour les "
-"types de couverture du sol dans une image en utilisant un algorithme à "
-"cluster. Le fichier de signature résultat est utilisé en entrée pour i."
-"maxlik, pour générer une classification d'image non-supervisée."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Fonction de traitement d'image qui génère des signatures spectrales pour les types de couverture du sol dans une image en utilisant un algorithme à cluster. Le fichier de signature résultat est utilisé en entrée pour i.maxlik, pour générer une classification d'image non-supervisée."
#: ../imagery/i.cluster/main.c:101
msgid "Initial number of classes"
@@ -19201,9 +18048,7 @@
#: ../imagery/i.cluster/main.c:117
msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr ""
-"Intervalle d'échantillonnage (par ligne et colonne); par défaut: ~10,000 "
-"pixels"
+msgstr "Intervalle d'échantillonnage (par ligne et colonne); par défaut: ~10,000 pixels"
#: ../imagery/i.cluster/main.c:124 ../imagery/i.segment/parse_args.c:101
msgid "Maximum number of iterations"
@@ -19398,8 +18243,7 @@
#: ../imagery/i.cluster/main.c:286
#, fuzzy
msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-"Mémoire insuffisante. Rééxécuter en choisissant un échantillon plus petit."
+msgstr "Mémoire insuffisante. Rééxécuter en choisissant un échantillon plus petit."
#: ../imagery/i.cluster/main.c:292
#, c-format
@@ -19408,19 +18252,13 @@
#: ../imagery/i.cluster/main.c:295
#, fuzzy
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"Points échantillonnées insuffisants. Rééxécuter en choisissant un plus large "
-"échantillon."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "Points échantillonnées insuffisants. Rééxécuter en choisissant un plus large échantillon."
#: ../imagery/i.cluster/main.c:299
#, fuzzy
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"Echantillon insuffisant de points de données non-nuls. Vérifiez votre région "
-"courante (et le masque appliqué)"
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "Echantillon insuffisant de points de données non-nuls. Vérifiez votre région courante (et le masque appliqué)"
#: ../imagery/i.cluster/main.c:312
#, c-format
@@ -19439,9 +18277,7 @@
#: ../imagery/i.cluster/main.c:324
#, fuzzy, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"Impossible d'écrire le fichier de signature <%s> pour le groupe <%s>, sous-"
-"groupe <%s>"
+msgstr "Impossible d'écrire le fichier de signature <%s> pour le groupe <%s>, sous-groupe <%s>"
#: ../imagery/i.cluster/main.c:329
#, c-format
@@ -19606,9 +18442,7 @@
#: ../imagery/i.eb.netrad/main.c:89
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
msgstr ""
#: ../imagery/i.eb.netrad/main.c:90
@@ -19675,9 +18509,7 @@
msgstr "Impossible d'ouvrir le fichier de sortie"
#: ../imagery/i.eb.evapfr/main.c:53
-msgid ""
-"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
-"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
msgstr ""
#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
@@ -19718,9 +18550,7 @@
msgstr ""
#: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
msgstr ""
#: ../imagery/i.evapo.time/main.c:86
@@ -19835,8 +18665,7 @@
msgstr "Nom de la couche raster source"
#: ../imagery/i.segment/parse_args.c:117
-msgid ""
-"Must be integer values, each area will be segmented independent of the others"
+msgid "Must be integer values, each area will be segmented independent of the others"
msgstr ""
#: ../imagery/i.segment/parse_args.c:123
@@ -19845,9 +18674,7 @@
msgstr "Nom du fichier raster en sortie pour la courbure de profil"
#: ../imagery/i.segment/parse_args.c:128
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
msgstr ""
#: ../imagery/i.segment/parse_args.c:134
@@ -19930,9 +18757,7 @@
#: ../imagery/i.segment/create_isegs.c:493
#, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
msgstr ""
#: ../imagery/i.segment/create_isegs.c:495
@@ -19976,8 +18801,7 @@
#: ../imagery/i.segment/create_isegs.c:1479
#, fuzzy, c-format
msgid "Region size is larger than 2: %d"
-msgstr ""
-"La taille de la région est plus petite que minreg, rien n'a été affiché."
+msgstr "La taille de la région est plus petite que minreg, rien n'a été affiché."
#: ../imagery/i.segment/create_isegs.c:1564
#, c-format
@@ -20101,8 +18925,7 @@
#: ../imagery/i.pca/main.c:72
#, fuzzy
msgid "Principal components analysis (PCA) for image processing."
-msgstr ""
#: ../imagery/i.pca/main.c:77
#, fuzzy
@@ -20197,9 +19020,7 @@
#: ../imagery/i.rgb.his/main.c:51
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
msgstr ""
#: ../imagery/i.rgb.his/main.c:57
@@ -20241,9 +19062,7 @@
msgstr "Titre du fichier raster de sortie"
#: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
msgstr ""
#: ../imagery/i.evapo.pm/main.c:65
@@ -20367,8 +19186,7 @@
#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
#, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
msgstr ""
#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -20470,9 +19288,8 @@
msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
-#, fuzzy
msgid "permission denied\n"
-msgstr "permission refusée"
+msgstr ""
# c-format
@@ -20498,9 +19315,7 @@
msgstr "Echec de la conversion de données à la ligne %d, colonne %d"
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
msgstr ""
#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
@@ -20599,9 +19414,7 @@
msgstr ""
#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
msgstr ""
#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
@@ -20800,9 +19613,7 @@
#: ../ps/ps.map/ps_vlines.c:125
#, fuzzy, c-format
msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), entité surfacique %d "
-"avec la catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
#: ../ps/ps.map/r_instructions.c:62
#, fuzzy
@@ -20824,9 +19635,10 @@
msgid "illegal maploc request"
msgstr "Coordonnées Est <%s> illégale"
-#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:219
+#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
+#, fuzzy
msgid "illegal copies request"
-msgstr ""
+msgstr "Coordonnées Est <%s> illégale"
#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
#, fuzzy
@@ -20918,9 +19730,7 @@
#: ../vector/v.label.sa/labels.c:74
#, fuzzy
msgid "Unable to get layer info for vector map"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
# c-format
#: ../ps/ps.map/catval.c:63
@@ -21046,9 +19856,7 @@
#: ../ps/ps.map/ps_fclrtbl.c:64
#, fuzzy
msgid "A floating point colortable must contain a range of values"
-msgstr ""
-"Une table de couleurs en valeurs flottante doit contenir un ensemble de "
-"valeurs"
+msgstr "Une table de couleurs en valeurs flottante doit contenir un ensemble de valeurs"
#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
msgid "Unable to read colors for colorbar"
@@ -21057,16 +19865,12 @@
#: ../ps/ps.map/ps_fclrtbl.c:93 ../ps/ps.map/ps_fclrtbl.c:98
#: ../ps/ps.map/ps_clrtbl.c:69
msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Emplacement vertical (y) de la légende couleur en dehors des limites de la "
-"page. Ajustement automatique."
+msgstr "Emplacement vertical (y) de la légende couleur en dehors des limites de la page. Ajustement automatique."
#: ../ps/ps.map/ps_fclrtbl.c:104 ../ps/ps.map/ps_fclrtbl.c:109
#: ../ps/ps.map/ps_clrtbl.c:75
msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Emplacement horizontal (x) de la légende couleur en dehors des limites de la "
+msgstr "Emplacement horizontal (x) de la légende couleur en dehors des limites de la page. Ajustement automatique."
#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
#, fuzzy
@@ -21081,12 +19885,12 @@
#: ../ps/ps.map/getgrid.c:132
#, fuzzy
msgid "illegal request (grid)"
-msgstr "Coordonnées Est <%s> illégale"
+msgstr "Nom du fichier de sortie illégal"
#: ../ps/ps.map/getgrid.c:240
#, fuzzy
msgid "illegal request (geogrid)"
# c-format
#: ../ps/ps.map/r_plt.c:173
@@ -21118,8 +19922,7 @@
#: ../ps/ps.map/do_labels.c:44
#, c-format
msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-"impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
+msgstr "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
# c-format
#: ../ps/ps.map/do_labels.c:48
@@ -21140,9 +19943,7 @@
#: ../ps/ps.map/do_labels.c:162
msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr ""
-"Etiquettes texte : 'fontsize' (taille de police) spécifiée, on ignore donc "
-"le paramètre 'size'"
+msgstr "Etiquettes texte : 'fontsize' (taille de police) spécifiée, on ignore donc le paramètre 'size'"
#: ../ps/ps.map/main.c:93
#, fuzzy
@@ -21167,9 +19968,7 @@
#: ../ps/ps.map/main.c:105
#, fuzzy
msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Afficher le format papier (nom largeur hauteur gauche droite haut bas "
-"(marges) )"
+msgstr "Afficher le format papier (nom largeur hauteur gauche droite haut bas (marges) )"
#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
msgid "Utility"
@@ -21177,19 +19976,16 @@
#: ../ps/ps.map/main.c:112
msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr ""
-"Créer un EPS (Encapsulated PostScript) à la place du fichier PostScript"
+msgstr "Créer un EPS (Encapsulated PostScript) à la place du fichier PostScript"
#: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
msgstr ""
#: ../ps/ps.map/main.c:123
#, fuzzy
msgid "File containing mapping instructions"
-msgstr "Fichier contenant les signatures initiales"
+msgstr "Fichier contenant les requêtes SQL"
#: ../ps/ps.map/main.c:124
msgid "Use '-' to enter instructions from keyboard)"
@@ -21205,12 +20001,12 @@
msgstr "Nombre de copies à imprimer"
# c-format
-#: ../ps/ps.map/main.c:204
+#: ../ps/ps.map/main.c:205
#, fuzzy, c-format
msgid "Unable to open file '%s': %s"
msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#: ../ps/ps.map/main.c:212 ../ps/ps.map/main.c:231
+#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
#: ../vector/v.univar/main.c:139 ../vector/v.to.db/parse.c:141
#: ../vector/v.to.db/parse.c:144
#, fuzzy, c-format
@@ -21219,7 +20015,7 @@
"\t(%s)"
msgstr "incidout demande de fixer le paramètre d'heure"
-#: ../ps/ps.map/main.c:272
+#: ../ps/ps.map/main.c:273
#, c-format
msgid "PostScript file '%s' successfully written."
msgstr ""
@@ -21264,15 +20060,8 @@
#: ../ps/ps.map/ps_clrtbl.c:54
#, fuzzy
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"Votre fichier cats/ est invalide. Un fichier cats/ avec catégories et "
-"étiquettes est requis pour la table de couleurs en utilisant les rasters "
-"CELL. Aucune table de couleurs ne seraassignée au fichier postscript en "
-"sortie."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "Votre fichier cats/ est invalide. Un fichier cats/ avec catégories et étiquettes est requis pour la table de couleurs en utilisant les rasters CELL. Aucune table de couleurs ne seraassignée au fichier postscript en sortie."
#: ../ps/ps.map/do_plt.c:38
#, fuzzy
@@ -21285,12 +20074,8 @@
msgstr "Afficher l'index"
#: ../display/d.histogram/main.c:88
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"Affiche un histogramme sous forme de diagramme en barre ou d'un diagramme "
-"camembert pour un fichier raster spécifié par l'utilisateur."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "Affiche un histogramme sous forme de diagramme en barre ou d'un diagramme camembert pour un fichier raster spécifié par l'utilisateur."
#: ../display/d.histogram/main.c:92
msgid "Raster map for which histogram will be displayed"
@@ -21298,8 +20083,7 @@
#: ../display/d.histogram/main.c:96
msgid "Indicate if a pie or bar chart is desired"
-msgstr ""
-"Indique si l'on a besoin d'un diagramme en barre ou d'un diagramme camembert"
+msgstr "Indique si l'on a besoin d'un diagramme en barre ou d'un diagramme camembert"
#: ../display/d.histogram/main.c:105
#, fuzzy
@@ -21312,9 +20096,7 @@
#: ../display/d.histogram/main.c:123
msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-"Nombre d'étapes pour la division des intervalles de données (couches en "
-"points flottants seulement)"
+msgstr "Nombre d'étapes pour la division des intervalles de données (couches en points flottants seulement)"
#: ../display/d.histogram/main.c:130
msgid "Display information for null cells"
@@ -21326,9 +20108,7 @@
#: ../display/d.histogram/main.c:139
msgid "Report for ranges defined in cats file (fp maps only)"
-msgstr ""
-"Examen des catégories en nombres à virgule flottante (couches en virgule "
-"flottante uniquement)"
+msgstr "Examen des catégories en nombres à virgule flottante (couches en virgule flottante uniquement)"
#: ../display/d.histogram/main.c:163
#, c-format
@@ -21342,8 +20122,7 @@
#: ../display/d.histogram/main.c:180 ../display/d.legend/main.c:527
#, fuzzy, c-format
msgid "Range information for <%s> not available"
-msgstr ""
#: ../display/d.histogram/main.c:190 ../display/d.vect/main.c:335
#: ../display/d.rhumbline/main.c:96 ../display/d.where/main.c:170
@@ -21354,7 +20133,7 @@
#: ../display/d.grid/main.c:233 ../display/d.his/main.c:118
#: ../display/d.geodesic/main.c:96 ../display/d.labels/main.c:117
#: ../display/d.colortable/main.c:141 ../display/d.rast/main.c:97
-#: ../display/d.thematic.area/main.c:371 ../display/d.fontlist/main.c:54
+#: ../display/d.thematic.area/main.c:370 ../display/d.fontlist/main.c:54
#: ../display/d.graph/main.c:98 ../display/d.rgb/main.c:82
#: ../display/d.path/main.c:154 ../display/d.rast.arrow/main.c:224
#: ../display/d.legend/main.c:294 ../display/d.font/main.c:86
@@ -21369,13 +20148,13 @@
msgstr "Couleur inconnue : [%s]"
#: ../display/d.vect/opt.c:143 ../display/d.what.vect/what.c:413
-#: ../display/d.thematic.area/main.c:201 ../vector/v.db.connect/main.c:175
+#: ../display/d.thematic.area/main.c:200 ../vector/v.db.connect/main.c:175
#, c-format
msgid "Database connection not defined"
msgstr "La connexion à la base de données n'a pas été définie"
# c-format
-#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:210
+#: ../display/d.vect/opt.c:152 ../display/d.thematic.area/main.c:209
#: ../vector/v.convert/att.c:74 ../db/db.select/main.c:73
#: ../db/db.execute/main.c:76 ../db/db.tables/main.c:47
#: ../db/db.describe/main.c:56
@@ -21390,9 +20169,7 @@
#: ../display/d.vect/lines.c:121
#, fuzzy
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
msgstr "Impossible d'afficher les lignes par id, topologie non disponible"
#: ../display/d.vect/lines.c:169
@@ -21441,23 +20218,19 @@
msgstr "Aucun enregistrement pour la ligne (cat = %d)"
#: ../display/d.vect/topo.c:17
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
msgstr ""
#: ../display/d.vect/main.c:74
#, fuzzy
msgid "Displays user-specified vector map in the active graphics frame."
-msgstr ""
-"Afficher trois couches rasters spécifiées par l'utilisateur comme calques "
-"rouge, vert, bleu superposés dans le moniteur actif."
+msgstr "Afficher trois couches rasters spécifiées par l'utilisateur comme calques rouge, vert, bleu superposés dans le moniteur actif."
#: ../display/d.vect/main.c:80 ../display/d.vect/main.c:105
#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
#: ../display/d.vect/main.c:314 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:135
-#: ../display/d.thematic.area/main.c:138 ../vector/v.net.centrality/main.c:121
+#: ../display/d.rast/main.c:87 ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:137 ../vector/v.net.centrality/main.c:121
#: ../vector/v.net.centrality/main.c:123 ../vector/v.in.ogr/main.c:146
#: ../vector/v.in.ogr/main.c:159 ../vector/v.in.ogr/main.c:164
#: ../vector/v.in.ogr/main.c:173 ../vector/v.in.ogr/main.c:189
@@ -21472,8 +20245,8 @@
#: ../vector/v.extract/main.c:100 ../vector/v.extract/main.c:106
#: ../vector/v.extract/main.c:109 ../vector/v.extract/main.c:112
#: ../vector/v.extract/main.c:122 ../vector/v.extract/main.c:132
-#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:83
-#: ../vector/v.category/main.c:86 ../vector/v.category/main.c:90
+#: ../vector/v.to.db/parse.c:45 ../vector/v.category/main.c:84
+#: ../vector/v.category/main.c:87 ../vector/v.category/main.c:91
#: ../vector/v.buffer/main.c:232 ../vector/v.buffer/main.c:235
#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:243
#: ../vector/v.surf.rst/main.c:173 ../vector/v.surf.rst/main.c:185
@@ -21560,9 +20333,7 @@
#: ../display/d.vect/main.c:234 ../display/d.vect/main.c:244
#, fuzzy
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-"Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, "
-"soit aucune \"none\""
+msgstr "Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, soit aucune \"none\""
#: ../display/d.vect/main.c:129
msgid "Area fill color"
@@ -21570,16 +20341,12 @@
#: ../display/d.vect/main.c:138
msgid "Name of color definition column (for use with -a flag)"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../display/d.vect/main.c:143
#, fuzzy
msgid "Name of color table (for use with -z flag)"
-msgstr ""
-"a)"
#: ../display/d.vect/main.c:152 ../display/d.vect/main.c:157
#: ../display/d.vect/main.c:165
@@ -21598,9 +20365,7 @@
#: ../display/d.vect/main.c:159
#, fuzzy
msgid "These values will be scaled by width_scale"
-msgstr ""
-"Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à "
-"l'échelle par wscale)"
+msgstr "Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à l'échelle par wscale)"
#: ../display/d.vect/main.c:166
#, fuzzy
@@ -21695,32 +20460,21 @@
msgstr "Justification verticale des étiquettes"
#: ../display/d.vect/main.c:286
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-"Taille minimum de la région (hauteur et largeur moyenne) quand la couche est "
-"affichée"
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr "Taille minimum de la région (hauteur et largeur moyenne) quand la couche est affichée"
#: ../display/d.vect/main.c:294
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-"Taille maximum de la région (hauteur et largeur moyenne) quand la couche est "
-"affichée"
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr "Taille maximum de la région (hauteur et largeur moyenne) quand la couche est affichée"
#: ../display/d.vect/main.c:302
#, fuzzy
msgid "Get colors from attribute table (see 'rgb_column' option)"
-msgstr ""
-"Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
+msgstr "Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
#: ../display/d.vect/main.c:308
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"Couleurs aléatoires en fonction du code de catégorie (ou du code de la "
-"couche si 'layer=-1' "
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "Couleurs aléatoires en fonction du code de catégorie (ou du code de la couche si 'layer=-1' "
#: ../display/d.vect/main.c:315
#, fuzzy
@@ -21736,27 +20490,21 @@
msgstr ""
#: ../display/d.vect/main.c:326
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
msgstr ""
#: ../display/d.vect/main.c:346
#, fuzzy
msgid "Region size is lower than minreg, nothing displayed"
-msgstr ""
#: ../display/d.vect/main.c:354
#, fuzzy
msgid "Region size is greater than maxreg, nothing displayed"
-msgstr ""
-"La taille de la région est plus grande que maxreg, rien n'a été affiché."
+msgstr "La taille de la région est plus grande que maxreg, rien n'a été affiché."
#: ../display/d.vect/main.c:368
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
msgstr ""
# c-format
@@ -21777,11 +20525,8 @@
#: ../display/d.vect/main.c:424
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
-msgstr ""
-"Les limites de la couche sont en-dehors de la région courante, rien n'a été "
-"affiché.\n"
+msgid "The bounding box of the map is outside the current region, nothing drawn"
+msgstr "Les limites de la couche sont en-dehors de la région courante, rien n'a été affiché.\n"
# c-format
#: ../display/d.vect/main.c:487
@@ -21791,11 +20536,8 @@
#: ../display/d.vect/area.c:37
#, fuzzy
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
-msgstr ""
-"Impossible d'afficher les entités surfaciques, topologie non disponible"
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgstr "Impossible d'afficher les entités surfaciques, topologie non disponible"
#: ../display/d.vect/area.c:137
#, fuzzy, c-format
@@ -21819,14 +20561,8 @@
#: ../display/d.vect/shape.c:68
#, fuzzy, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
-msgstr ""
-"La colonne de définition de couleur (%s) n'est pas une chaîne de caractère."
-"La colonne doit être de la forme RRR:GGG:BBB ou les valeurs RGB sont "
-"comprises dans l'intervalle 0-255."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+msgstr "La colonne de définition de couleur (%s) n'est pas une chaîne de caractère.La colonne doit être de la forme RRR:GGG:BBB ou les valeurs RGB sont comprises dans l'intervalle 0-255."
#: ../display/d.vect/shape.c:75 ../display/d.vect/shape.c:98
#: ../display/d.vect/shape.c:129 ../display/d.vect/shape.c:160
@@ -21865,23 +20601,18 @@
msgstr "Nom de la colonne (le type doit être numérique)"
#: ../display/d.vect/shape.c:183
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
msgstr ""
#: ../display/d.vect/shape.c:254 ../display/d.vect/shape.c:259
#, fuzzy, c-format
msgid "Error in color definition (%s) - feature %d with category %d"
-msgstr ""
#: ../display/d.vect/shape.c:325
#, fuzzy, c-format
msgid "Invalid negative value - feature %d with category %d"
-msgstr ""
-"vectorielle"
#: ../display/d.rhumbline/main.c:46
msgid "Displays the rhumbline joining two longitude/latitude coordinates."
@@ -21926,12 +20657,8 @@
#: ../display/d.where/main.c:48
#, fuzzy
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
-msgstr ""
-"Identifie les coordonnées géographiques associées à l'emplacement d'un point "
-"dans le moniteur actif."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
+msgstr "Identifie les coordonnées géographiques associées à l'emplacement d'un point dans le moniteur actif."
#: ../display/d.where/main.c:58
#, fuzzy
@@ -21952,12 +20679,8 @@
msgstr "Sortie latitude/longitude référencée sur l'ellipsoïde courant"
#: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"Sortie de latitude/longitude référencée sur l'ellipsoïde WGS84 en utilisant "
-"les paramètres de transformation de datum du Secteur courant (si disponible)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "Sortie de latitude/longitude référencée sur l'ellipsoïde WGS84 en utilisant les paramètres de transformation de datum du Secteur courant (si disponible)"
#: ../display/d.where/main.c:83
msgid "Output frame coordinates of current display monitor (percentage)"
@@ -22121,12 +20844,8 @@
msgstr "attention: %s - fichier de vecteur introuvable\n"
#: ../display/d.what.vect/main.c:61
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"Permet à l'utilisateur de requêter de façon interactive la couche vectoriel "
-"sur des lieux choisis dans la région géographique courante."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "Permet à l'utilisateur de requêter de façon interactive la couche vectoriel sur des lieux choisis dans la région géographique courante."
#: ../display/d.what.vect/main.c:68 ../display/d.what.rast/main.c:80
msgid "Identify just one location"
@@ -22174,9 +20893,7 @@
msgstr "affichage, cartoraphie"
#: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
msgstr "Trace du texte dans le moniteur actif en utilisant la police courante"
#: ../display/d.text/main.c:148
@@ -22201,12 +20918,8 @@
msgstr "Numéro de ligne de l'écran sur laquelle on va tracer le début du texte"
#: ../display/d.text/main.c:190
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"Position de l'écran à partir de laquelle on va commencer à tracer le texte "
-"(en pourcentage, [0,0] est en bas à gauche)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "Position de l'écran à partir de laquelle on va commencer à tracer le texte (en pourcentage, [0,0] est en bas à gauche)"
#: ../display/d.text/main.c:198
msgid "Text alignment"
@@ -22214,8 +20927,7 @@
#: ../display/d.text/main.c:206
msgid "Rotation angle in degrees (counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../display/d.text/main.c:213
msgid "Line spacing"
@@ -22250,8 +20962,7 @@
#: ../display/d.text/main.c:252
msgid "Use radians instead of degrees for rotation"
-msgstr ""
-"Utilisez des radians à la place de degrés pour définir l'angle de rotation"
+msgstr "Utilisez des radians à la place de degrés pour définir l'angle de rotation"
#: ../display/d.text/main.c:256 ../display/d.legend/main.c:212
msgid "Font size is height in pixels"
@@ -22286,12 +20997,8 @@
#: ../display/d.linegraph/main.c:122
#, fuzzy
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
-"Génére et affiche des graphiques sur les couches de données affichées dans "
-"le moniteur actif."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+msgstr "Génére et affiche des graphiques sur les couches de données affichées dans le moniteur actif."
#: ../display/d.linegraph/main.c:126
#, fuzzy
@@ -22396,14 +21103,8 @@
msgstr "Vous cliquez en dehors de la couche"
#: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"Permet à l'utilisateur de requêter de façon interactive les contenus de "
-"catégories de multiples couches rasters sur des lieux choisis par "
-"l'utilisateur dans la région géographique courante."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "Permet à l'utilisateur de requêter de façon interactive les contenus de catégories de multiples couches rasters sur des lieux choisis par l'utilisateur dans la région géographique courante."
#: ../display/d.what.rast/main.c:75
msgid "Field separator (terse mode only)"
@@ -22411,9 +21112,7 @@
#: ../display/d.what.rast/main.c:89
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-"Affiche la colonne/ligne pour la couche entière en fonction de la résolution "
-"de la région"
+msgstr "Affiche la colonne/ligne pour la couche entière en fonction de la résolution de la région"
#: ../display/d.info/main.c:33 ../display/d.erase/main.c:31
#: ../display/d.mon/main.c:39
@@ -22462,10 +21161,8 @@
#: ../display/d.vect.chart/main.c:66
#, fuzzy
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
-"Afficher des diagrammes de données vectorielles GRASS dans le moniteur actif"
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgstr "Afficher des diagrammes de données vectorielles GRASS dans le moniteur actif"
#: ../display/d.vect.chart/main.c:83
msgid "Chart type"
@@ -22489,9 +21186,7 @@
#: ../display/d.vect.chart/main.c:105
msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-"Taille du diagramme (diamètre pour le diagramme camembert, largeur totale "
-"pour le diagramme en barres)"
+msgstr "Taille du diagramme (diamètre pour le diagramme camembert, largeur totale pour le diagramme en barres)"
#: ../display/d.vect.chart/main.c:112
msgid "Scale for size (to get size in pixels)"
@@ -22513,7 +21208,7 @@
msgid "Maximum value used for bar plot reference"
msgstr "Valeur maximale utilisée pour le diagramme en barres"
-#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:164
+#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:163
msgid "Create legend information and send to stdout"
msgstr ""
@@ -22528,9 +21223,7 @@
#: ../display/d.barscale/main.c:63
msgid "Draw a line scale instead of a bar scale"
-msgstr ""
-"Afficher une échelle graphique sous forme de ligne, plutôt que sous forme de "
-"barre"
+msgstr "Afficher une échelle graphique sous forme de ligne, plutôt que sous forme de barre"
#: ../display/d.barscale/main.c:67
msgid "Write text on top of the scale, not to the right"
@@ -22546,12 +21239,8 @@
#: ../display/d.barscale/main.c:92
#, fuzzy
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is lower-left of "
-"frame)"
-msgstr ""
-"Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] "
-"est le coin supérieurgauche du cadre graphique)"
+msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
+msgstr "Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] est le coin supérieurgauche du cadre graphique)"
#: ../display/d.barscale/main.c:100
#, fuzzy
@@ -22574,11 +21263,8 @@
#: ../display/d.erase/main.c:34
#, fuzzy
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
-msgstr ""
-"Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
+msgid "Erases the contents of the active graphics display frame with user defined color."
+msgstr "Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
#: ../display/d.erase/main.c:40
msgid "Remove all frames and erase the screen"
@@ -22589,12 +21275,8 @@
msgstr ""
#: ../display/d.zoom/main.c:64
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"Permet à l'utilisateur de changer les réglages de la région géographique "
-"courante de manière interactive, à l'aide de la souris."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "Permet à l'utilisateur de changer les réglages de la région géographique courante de manière interactive, à l'aide de la souris."
#: ../display/d.zoom/main.c:76 ../display/d.legend/main.c:92
msgid "Name of raster map"
@@ -22684,8 +21366,7 @@
#: ../display/d.zoom/zoom.c:41
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Note: lancer 'd.erase' pour la nouvelle région pour modifier l'affichage.\n"
+msgstr "Note: lancer 'd.erase' pour la nouvelle région pour modifier l'affichage.\n"
#: ../display/d.zoom/pan.c:17
#, fuzzy, c-format
@@ -22704,12 +21385,8 @@
#: ../display/d.rast.num/main.c:79
#, fuzzy
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
-msgstr ""
-"Superpose les valeurs de catégorie des cellules sur la couche raster "
-"affichée dans lemoniteur."
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
+msgstr "Superpose les valeurs de catégorie des cellules sur la couche raster affichée dans lemoniteur."
#: ../display/d.rast.num/main.c:87
msgid "Color for drawing grid, or \"none\""
@@ -22726,20 +21403,16 @@
#: ../display/d.rast.num/main.c:110
msgid "Get text color from cell color value"
-msgstr ""
-"Choisir la couleur du texte en fonction de la valeur de couleur de la cellule"
+msgstr "Choisir la couleur du texte en fonction de la valeur de couleur de la cellule"
#: ../display/d.rast.num/main.c:175
#, fuzzy, c-format
msgid ""
"Current region size: %d rows X %d cols\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
msgstr ""
"\n"
-"Votre fenêtre courante semble trop grande. Les cellules affichées dans votre "
-"moniteur graphique risque d'être trop petites pour que le code de catégorie "
-"soit visible."
+"Votre fenêtre courante semble trop grande. Les cellules affichées dans votre moniteur graphique risque d'être trop petites pour que le code de catégorie soit visible."
#: ../display/d.rast.num/main.c:182
msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
@@ -22775,12 +21448,8 @@
msgstr "Erreur dans pj_do_proj6"
#: ../display/d.grid/main.c:53
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
-msgstr ""
-"Superpose une grille dont le pas est spécifié par l'utilisateur dans le "
-"moniteuractif."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
+msgstr "Superpose une grille dont le pas est spécifié par l'utilisateur dans le moniteuractif."
#: ../display/d.grid/main.c:61
#, fuzzy
@@ -22788,9 +21457,7 @@
msgstr "Taille de la grille à tracer"
#: ../display/d.grid/main.c:62
-msgid ""
-"0 for north-south resolution of the current region. In map units or DDD:MM:"
-"SS format. Example: \"1000\" or \"0:10\""
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
msgstr ""
#: ../display/d.grid/main.c:70
@@ -22846,23 +21513,17 @@
#: ../display/d.grid/main.c:120
#, fuzzy
msgid "Draw '+' marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:125
#, fuzzy
msgid "Draw '.' marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:130
#, fuzzy
msgid "Draw fiducial marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:135
msgid "Disable grid drawing"
@@ -22924,21 +21585,15 @@
#: ../display/d.his/main.c:68
#, fuzzy
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"Générer des couches raster de couche rouge, verte et bleue en combinant des "
-"couches raster de teinte, intensité et saturation."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "Générer des couches raster de couche rouge, verte et bleue en combinant des couches raster de teinte, intensité et saturation."
#: ../display/d.his/main.c:96
msgid "Percent to brighten intensity channel"
msgstr ""
#: ../display/d.geodesic/main.c:46
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
msgstr ""
#: ../display/d.geodesic/main.c:69
@@ -22958,11 +21613,8 @@
msgstr "Requêter la couche"
#: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
-msgstr ""
-"Affiche des étiquettes de texte (créées avec v.label) dans le moniteur actif"
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+msgstr "Affiche des étiquettes de texte (créées avec v.label) dans le moniteur actif"
#: ../display/d.labels/main.c:52
msgid "Ignore rotation setting and draw horizontally"
@@ -22974,13 +21626,11 @@
#: ../display/d.labels/main.c:66
msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr ""
-"Taille minimum de la région (diagonale) quand les étiquettes sont affichées"
+msgstr "Taille minimum de la région (diagonale) quand les étiquettes sont affichées"
#: ../display/d.labels/main.c:73
msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr ""
-"Taille maximum de la région (diagonale) quand les étiquettes sont affichées"
+msgstr "Taille maximum de la région (diagonale) quand les étiquettes sont affichées"
# c-format
#: ../display/d.labels/main.c:85
@@ -22990,13 +21640,11 @@
#: ../display/d.labels/main.c:97
msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
#: ../display/d.labels/main.c:105
msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
# c-format
#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
@@ -23197,14 +21845,12 @@
#: ../display/d.colortable/main.c:114
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:128
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:139
@@ -23215,9 +21861,7 @@
#: ../display/d.rast/main.c:56
#, fuzzy
msgid "Displays user-specified raster map in the active graphics frame."
-msgstr ""
#: ../display/d.rast/main.c:69
#, fuzzy
@@ -23258,9 +21902,7 @@
#: ../display/d.thematic.area/main.c:80
#, fuzzy
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
#: ../display/d.thematic.area/main.c:90
@@ -23304,56 +21946,54 @@
msgid "Colors (one per class)."
msgstr ""
-#: ../display/d.thematic.area/main.c:134
+#: ../display/d.thematic.area/main.c:133
msgid "Layer number. If -1, all layers are displayed."
msgstr "Code de couche. Si fixé à -1, toutes les couches sont affichées."
-#: ../display/d.thematic.area/main.c:144 ../display/d.thematic.area/main.c:152
+#: ../display/d.thematic.area/main.c:143 ../display/d.thematic.area/main.c:151
#, fuzzy
msgid "Boundaries"
msgstr "Limites"
-#: ../display/d.thematic.area/main.c:145
+#: ../display/d.thematic.area/main.c:144
#, fuzzy
msgid "Boundary width"
msgstr "Epaisseur de ligne"
-#: ../display/d.thematic.area/main.c:151
+#: ../display/d.thematic.area/main.c:150
#, fuzzy
msgid "Boundary color"
msgstr "Couleur de la bordure"
-#: ../display/d.thematic.area/main.c:158
+#: ../display/d.thematic.area/main.c:157
msgid "File in which to save d.graph instructions for legend display"
msgstr ""
-#: ../display/d.thematic.area/main.c:169
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+#: ../display/d.thematic.area/main.c:168
+msgid "When printing legend info , include extended statistical info from classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:173
+#: ../display/d.thematic.area/main.c:172
#, fuzzy
msgid "Do not draw map, only output the legend"
msgstr "N'aligne pas la sortie sur la source"
-#: ../display/d.thematic.area/main.c:192
+#: ../display/d.thematic.area/main.c:191
#, fuzzy, c-format
msgid "%s: You must build topology on vector map. Run v.build."
msgstr "%s: vous devez construire la topologie du fichier vectorielle"
-#: ../display/d.thematic.area/main.c:199
+#: ../display/d.thematic.area/main.c:198
#, fuzzy
msgid "'layer' must be > 0"
msgstr "'layer' doit être >0 pour 'cats'."
-#: ../display/d.thematic.area/main.c:225
+#: ../display/d.thematic.area/main.c:224
#, fuzzy, c-format
msgid "Data (%s) not numeric. Column must be numeric."
msgstr "La clef primaire doit être un entier"
-#: ../display/d.thematic.area/main.c:229
+#: ../display/d.thematic.area/main.c:228
#: ../display/d.thematic.area/plot1.c:134
#: ../display/d.thematic.area/plot1.c:162
#, c-format
@@ -23361,87 +22001,77 @@
msgstr "Impossible de sélectionner des données (%s) dans la table"
# c-format
-#: ../display/d.thematic.area/main.c:292
+#: ../display/d.thematic.area/main.c:291
#, c-format
msgid "Unknown color: [%s]"
-#: ../display/d.thematic.area/main.c:303
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+#: ../display/d.thematic.area/main.c:302
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
msgstr ""
-#: ../display/d.thematic.area/main.c:340
+#: ../display/d.thematic.area/main.c:339
msgid "You must either give classbreaks or a classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:353
+#: ../display/d.thematic.area/main.c:352
#, c-format
msgid ""
"Not enough colors or error in color specifications.\n"
"Need %i colors."
msgstr ""
-#: ../display/d.thematic.area/main.c:358
+#: ../display/d.thematic.area/main.c:357
#, fuzzy, c-format
msgid "Error interpreting color %s"
msgstr "Erreur de lecture du fichier colr de <%s>"
-#: ../display/d.thematic.area/main.c:377
+#: ../display/d.thematic.area/main.c:376
#, fuzzy
msgid "Plotting ..."
msgstr "Traçage ... "
-#: ../display/d.thematic.area/main.c:384
+#: ../display/d.thematic.area/main.c:383
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"affiché.\n"
+msgid "The bounding box of the map is outside the current region, nothing drawn."
-#: ../display/d.thematic.area/main.c:434
+#: ../display/d.thematic.area/main.c:433
#, fuzzy, c-format
msgid ""
"\n"
"Total number of records: %.0f\n"
msgstr "Nombre invalide d'étapes: %s"
-#: ../display/d.thematic.area/main.c:436
+#: ../display/d.thematic.area/main.c:435
#, c-format
msgid "Classification of %s into %i classes\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:438 ../vector/v.class/main.c:202
+#: ../display/d.thematic.area/main.c:437 ../vector/v.class/main.c:202
#, c-format
msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:440 ../vector/v.class/main.c:203
+#: ../display/d.thematic.area/main.c:439 ../vector/v.class/main.c:203
#, fuzzy, c-format
msgid "Mean: %f\tStandard deviation = %f\n"
msgstr "Ãcart-type"
-#: ../display/d.thematic.area/main.c:444
+#: ../display/d.thematic.area/main.c:443
#, c-format
msgid "Last chi2 = %f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:447 ../vector/v.class/main.c:210
+#: ../display/d.thematic.area/main.c:446 ../vector/v.class/main.c:210
#, c-format
msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
#: ../display/d.thematic.area/plot1.c:129
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
#: ../display/d.thematic.area/plot1.c:147
msgid "Line width column not specified."
@@ -23463,27 +22093,18 @@
#: ../display/d.thematic.area/plot1.c:278
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), élément %d avec la "
-"catégorie %d: code couleur [%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: code couleur [%s]"
#: ../display/d.thematic.area/plot1.c:285
#, c-format
msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr ""
-"catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d"
#: ../display/d.thematic.area/plot1.c:353
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-"catégorie %d: largeur de ligne [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: largeur de ligne [%d]"
#: ../display/d.fontlist/main.c:40
#, fuzzy
@@ -23518,25 +22139,16 @@
msgstr "Problem pour interpréter la commande [%s]"
#: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-"Programme pour générer et afficher de simples graphiques dans le moniteur "
-"actif."
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr "Programme pour générer et afficher de simples graphiques dans le moniteur actif."
#: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../display/d.graph/main.c:73
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Couleur pour le traçage, soit une couleur GRASS standard, soit un triplet R:"
-"G:B"
+msgstr "Couleur pour le traçage, soit une couleur GRASS standard, soit un triplet R:G:B"
#: ../display/d.graph/main.c:80
msgid "Coordinates are given in map units"
@@ -23550,12 +22162,8 @@
#: ../display/d.rgb/main.c:58
#, fuzzy
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
#: ../display/d.rgb/main.c:69
#, fuzzy, c-format
@@ -23701,12 +22309,8 @@
msgstr " Distance jusqu'au réseau = %f, distance depuis le réseau = %f\n"
#: ../display/d.rast.arrow/main.c:99
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"Tracer des flèches représentant la direction d'aspect des cellules pour une "
-"couche rastercontenant des données d'aspect."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "Tracer des flèches représentant la direction d'aspect des cellules pour une couche rastercontenant des données d'aspect."
#: ../display/d.rast.arrow/main.c:103
msgid "Name of raster aspect map to be displayed"
@@ -23740,8 +22344,7 @@
#: ../display/d.rast.arrow/main.c:162
msgid "Raster map containing values used for arrow length"
-msgstr ""
-"Couche raster contenant les valeurs utilisées pour la longueur des flèches"
+msgstr "Couche raster contenant les valeurs utilisées pour la longueur des flèches"
#: ../display/d.rast.arrow/main.c:169
msgid "Scale factor for arrows (magnitude map)"
@@ -23777,21 +22380,15 @@
#: ../display/d.extract/extract.c:44
msgid " - L: draw box with left mouse button to select"
-msgstr ""
-" - L : dessiner la boîte avec le bouton gauche de la souris pour la "
-"sélectionner"
+msgstr " - L : dessiner la boîte avec le bouton gauche de la souris pour la sélectionner"
#: ../display/d.extract/extract.c:45
msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-" - M : dessiner la boîte avec le bouton du milieu de la souris pour la "
-"supprimer de l'affichage"
+msgstr " - M : dessiner la boîte avec le bouton du milieu de la souris pour la supprimer de l'affichage"
#: ../display/d.extract/extract.c:46
msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-" - R : quitter et enregistrer les couches vectorielles sélectionnées dans "
-"une nouvelle zone d'affichage\n"
+msgstr " - R : quitter et enregistrer les couches vectorielles sélectionnées dans une nouvelle zone d'affichage\n"
#: ../display/d.extract/extract.c:48
#, fuzzy
@@ -23800,9 +22397,7 @@
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-"Sélectionne et extraits des couches vectorielles avec la souris dans une "
-"nouvelle couche vectorielle."
+msgstr "Sélectionne et extraits des couches vectorielles avec la souris dans une nouvelle couche vectorielle."
#: ../display/d.extract/main.c:117
#, fuzzy
@@ -23815,9 +22410,7 @@
msgstr "Impossible de lire les informations de liaison à la base de données"
#: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
msgstr "Affiche la légende de la couche raster du moniteur actif."
#: ../display/d.legend/main.c:96 ../display/d.legend/main.c:158
@@ -23829,15 +22422,11 @@
#: ../display/d.legend/main.c:104
msgid "Number of text lines (useful for truncating long legends)"
-msgstr ""
-"Nombre de lignes de texte (pratique pour tronquer les longs textes de "
-"légende)"
+msgstr "Nombre de lignes de texte (pratique pour tronquer les longs textes de légende)"
#: ../display/d.legend/main.c:113
msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr ""
-"Facteur de discrétisation (thinning) (thin=10 donne les catégories "
-"0,10,20...)"
+msgstr "Facteur de discrétisation (thinning) (thin=10 donne les catégories 0,10,20...)"
#: ../display/d.legend/main.c:121
msgid "Number of text labels for smooth gradient legend"
@@ -23849,8 +22438,7 @@
msgstr "Variance"
#: ../display/d.legend/main.c:131
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
msgstr ""
#: ../display/d.legend/main.c:140
@@ -23865,9 +22453,7 @@
#: ../display/d.legend/main.c:150
msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-"Utiliser un sous-ensemble de l'intervalle des valeurs de la carte pour la "
-"légende (min, max)"
+msgstr "Utiliser un sous-ensemble de l'intervalle des valeurs de la carte pour la légende (min, max)"
#: ../display/d.legend/main.c:167
#, fuzzy
@@ -23898,74 +22484,67 @@
#: ../display/d.legend/main.c:348
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"Le cartouche de légende dépasse du cadre. Il est possible que le texte ne "
-"s'affiche pas correctement"
+msgstr "Le cartouche de légende dépasse du cadre. Il est possible que le texte ne s'affiche pas correctement"
#: ../display/d.legend/main.c:352
#, fuzzy
msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-"Disposition horizontale de la légende car la largeur du cartouche dépasse la "
-"hauteur.\n"
+msgstr "Disposition horizontale de la légende car la largeur du cartouche dépasse la hauteur.\n"
#: ../display/d.legend/main.c:363
#, fuzzy, c-format
msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-"Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
+msgstr "Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
#: ../display/d.legend/main.c:368
#, fuzzy
msgid "Input map contains no data"
msgstr "Le tableau ne contient pas de données"
-#: ../display/d.legend/main.c:381 ../display/d.legend/main.c:541
-msgid "Color range exceeds lower limit of actual data"
-msgstr ""
-"Les valeurs de couleurs excède la limite plancher des données actuelles"
+#: ../display/d.legend/main.c:381
+#, fuzzy
+msgid "Requested range exceeds lower limit of actual data"
+msgstr "Les valeurs de couleurs excède la limite plancher des données actuelles"
-#: ../display/d.legend/main.c:387 ../display/d.legend/main.c:545
-msgid "Color range exceeds upper limit of actual data"
-msgstr ""
-"Les valeurs de couleurs dépassent la limite plafond des données actuelles"
+#: ../display/d.legend/main.c:387
+#, fuzzy
+msgid "Requested range exceeds upper limit of actual data"
+msgstr "Les valeurs de couleurs dépassent la limite plafond des données actuelles"
#: ../display/d.legend/main.c:446
#, fuzzy, c-format
msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
-"utilisation=%s hors de l'intervalle [%d,%d]. (étendre à l'intervalle= ?)"
+msgstr "utilisation=%s hors de l'intervalle [%d,%d]. (étendre à l'intervalle= ?)"
#: ../display/d.legend/main.c:487
msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-"Rien à dessiner! (pas de catégories liées aux étiquettes? valeurs hors "
-"intervalles?"
+msgstr "Rien à dessiner! (pas de catégories liées aux étiquettes? valeurs hors intervalles?"
#: ../display/d.legend/main.c:497
#, fuzzy
msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"Utilisation forcée d'une légende simplifiée : trop de catégories pour la "
-"taille courante de la fenêtre.\n"
+msgstr "Utilisation forcée d'une légende simplifiée : trop de catégories pour la taille courante de la fenêtre.\n"
+#: ../display/d.legend/main.c:541
+msgid "Color range exceeds lower limit of actual data"
+#: ../display/d.legend/main.c:545
+msgid "Color range exceeds upper limit of actual data"
#: ../display/d.legend/main.c:552
#, fuzzy, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-msgstr ""
-"utilisation=%s hors de l'intervalle [%.3f, %.3f]. (étendre à l'intervalle= ?)"
+msgstr "utilisation=%s hors de l'intervalle [%.3f, %.3f]. (étendre à l'intervalle= ?)"
#: ../display/d.legend/main.c:926
msgid "Nothing to draw! (no categories with labels?)"
msgstr "Rien à dessiner! (pas de catégories liées aux étiquettes?)"
#: ../display/d.measure/main.c:49
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
-msgstr ""
-"Mesure les longueurs et les surfaces des objets dessinés par l'utilisateur "
-"dans le cadre actif du moniteur graphique."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
+msgstr "Mesure les longueurs et les surfaces des objets dessinés par l'utilisateur dans le cadre actif du moniteur graphique."
#: ../display/d.measure/main.c:55
msgid "Line color 1"
@@ -23988,8 +22567,7 @@
msgstr "Sortie en kilomètres également"
#: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
#: ../display/d.title/main.c:63
@@ -24025,12 +22603,8 @@
msgstr "Aucune couche de données spécifiée"
#: ../display/d.font/main.c:49
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Sélectionnez la police à utiliser pour afficher le texte sur le moniteur "
-"graphique."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Sélectionnez la police à utiliser pour afficher le texte sur le moniteur graphique."
#: ../display/d.font/main.c:57
#, fuzzy
@@ -24063,8 +22637,7 @@
#: ../display/d.font/main.c:127
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
msgstr ""
#: ../general/g.filename/main.c:41
@@ -24282,9 +22855,7 @@
#: ../general/g.findfile/main.c:97
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
msgstr ""
# c-format
@@ -24299,11 +22870,10 @@
msgid "Datum set to <%s>"
msgstr "Impossible d'écrire dans : %s"
-# c-format
#: ../general/g.proj/datumtrans.c:79
-#, fuzzy, c-format
+#, c-format
msgid "Ellipsoid set to <%s>"
-msgstr "Impossible d'écrire dans : %s"
+msgstr ""
#: ../general/g.proj/create.c:17
#, fuzzy, c-format
@@ -24328,18 +22898,11 @@
#: ../general/g.proj/create.c:36
#, fuzzy, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour "
-"la projectiondu Secteur courant. (Le jeu de données courant est %s)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour la projectiondu Secteur courant. (Le jeu de données courant est %s)"
#: ../general/g.proj/create.c:62
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
msgstr ""
#: ../general/g.proj/create.c:66
@@ -24357,9 +22920,7 @@
#: ../general/g.proj/main.c:68
#, fuzzy
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
msgstr "Affiche et manipule les fichiers d'information de projection GRASS"
#: ../general/g.proj/main.c:71
@@ -24383,19 +22944,15 @@
#: ../general/g.proj/main.c:93
msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Vérifier l'information de datum et afficher les paramètres de transformation"
+msgstr "Vérifier l'information de datum et afficher les paramètres de transformation"
#: ../general/g.proj/main.c:99
msgid "Print projection information in PROJ.4 format"
msgstr "Afficher l'information de projection au format PROJ.4"
#: ../general/g.proj/main.c:105
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Afficher une sortie 'à plat' sans sauts de ligne (s'applique à la sortie WKT "
-"et PROJ.4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Afficher une sortie 'à plat' sans sauts de ligne (s'applique à la sortie WKT et PROJ.4)"
#: ../general/g.proj/main.c:115
msgid "Print projection information in WKT format"
@@ -24419,18 +22976,14 @@
#: ../general/g.proj/main.c:138
#, fuzzy
msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-"Fichier ASCII contenant une description de projection WKT en une ligne (- "
-"pour stdin)"
+msgstr "Fichier ASCII contenant une description de projection WKT en une ligne (- pour stdin)"
#: ../general/g.proj/main.c:140 ../general/g.proj/main.c:149
#: ../vector/v.segment/main.c:69 ../db/db.select/main.c:199
#: ../db/db.execute/main.c:139
#, fuzzy
msgid "'-' for standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../general/g.proj/main.c:148
#, fuzzy
@@ -24458,25 +23011,20 @@
#: ../general/g.proj/main.c:180
#, fuzzy
msgid "Index number of datum transform parameters"
-msgstr ""
#: ../general/g.proj/main.c:181
msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
#: ../general/g.proj/main.c:187
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
msgstr ""
#: ../general/g.proj/main.c:193
#, fuzzy
msgid "Create new projection files (modifies current location)"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
#: ../general/g.proj/main.c:201 ../general/g.mapset/main.c:83
#: ../locale/scriptstrings/r.mask_to_translate.c:17
@@ -24547,17 +23095,12 @@
#: ../general/g.proj/input.c:254
#, fuzzy, c-format
msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-"Impossible de lire le fichier géoréférencé %s à l'aide de GDAL ni d'OGR"
+msgstr "Impossible de lire le fichier géoréférencé %s à l'aide de GDAL ni d'OGR"
#: ../general/g.proj/input.c:259
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"La lecture du fichier %s a fonctionné, mais elle ne contenait pas "
-"d'information de projection. 'XY (sans projection)' va être utilisé"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "La lecture du fichier %s a fonctionné, mais elle ne contenait pas d'information de projection. 'XY (sans projection)' va être utilisé"
#: ../general/g.proj/output.c:181
#, c-format
@@ -24593,12 +23136,8 @@
#: ../general/g.mremove/main.c:66
#, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using regular "
-"expressions."
-msgstr ""
-"Supprimer les fichiers éléments de base de données du jeu de données courant "
-"de l'utilisateur"
+msgid "Removes data base element files from the user's current mapset using regular expressions."
+msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:102
#, fuzzy
@@ -24635,9 +23174,7 @@
#: ../general/g.mremove/main.c:100
#, fuzzy, c-format
msgid "-%c and -%c are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../general/g.mremove/main.c:104
msgid "The following data base element files would be deleted:"
@@ -24660,8 +23197,7 @@
msgstr "Sauvegarder cadre graphique actif"
#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
msgstr ""
#: ../general/g.mapset/main.c:56
@@ -24709,8 +23245,7 @@
#: ../general/g.mapset/main.c:168
#, fuzzy, c-format
msgid "Mapset <%s> does not exist. Use -c flag to create it."
-msgstr ""
-"La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
+msgstr "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
#: ../general/g.mapset/main.c:178
#, fuzzy
@@ -24919,19 +23454,13 @@
#: ../general/g.mlist/main.c:66
#, fuzzy
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Lister les fichiers de base de données GRASS disponibles du type spécifié "
-"par l'utilisateur vers la sortie standard."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur vers la sortie standard."
#: ../general/g.mlist/main.c:81
#, fuzzy
msgid "Map name search pattern (default: all)"
-msgstr ""
-"motif à recherche dans le nom de couche, doit être entre simples guillemets "
-"(par défaut: tous)"
+msgstr "motif à recherche dans le nom de couche, doit être entre simples guillemets (par défaut: tous)"
#: ../general/g.mlist/main.c:82 ../general/g.mlist/main.c:90
#: ../general/g.mlist/main.c:103 ../general/g.mlist/main.c:109
@@ -24942,9 +23471,7 @@
#: ../general/g.mlist/main.c:89
#, fuzzy
msgid "Map name exclusion pattern (default: none)"
-msgstr ""
#: ../general/g.mlist/main.c:94
#, fuzzy
@@ -24973,9 +23500,7 @@
#: ../general/g.mlist/main.c:135
#, fuzzy
msgid "-r and -e are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../general/g.mlist/main.c:258
#, fuzzy, c-format
@@ -25113,9 +23638,7 @@
#: ../general/g.gisenv/main.c:42
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Affiche et modifie les réglages actuels de l'utilisateur pour les variables "
-"GRASS"
+msgstr "Affiche et modifie les réglages actuels de l'utilisateur pour les variables GRASS"
#: ../general/g.gisenv/main.c:43
msgid "Prints all defined GRASS variables if no option is given."
@@ -25171,22 +23694,17 @@
#: ../general/g.gisenv/main.c:92
#, fuzzy, c-format
msgid "Flags -%c and -%c are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../general/g.gisenv/main.c:126 ../vector/v.colors/main.c:184
#, fuzzy, c-format
msgid "Options <%s>, <%s>, and <%s> are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../general/g.region/main.c:66
#, fuzzy
msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-"Définition de l'emprise de la région géographique pour une couche raster."
+msgstr "Définition de l'emprise de la région géographique pour une couche raster."
#: ../general/g.region/main.c:73 ../general/g.region/main.c:78
#: ../general/g.region/main.c:166 ../general/g.region/main.c:173
@@ -25207,9 +23725,7 @@
#: ../general/g.region/main.c:87
#, fuzzy
msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Afficher la région courante en latitude/longitude à partir de l'ellipsoïde/"
-"datum courants"
+msgstr "Afficher la région courante en latitude/longitude à partir de l'ellipsoïde/datum courants"
#: ../general/g.region/main.c:93
msgid "Print the current region extent"
@@ -25238,9 +23754,7 @@
msgstr ""
#: ../general/g.region/main.c:124
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
msgstr ""
#: ../general/g.region/main.c:130
@@ -25250,18 +23764,12 @@
#: ../general/g.region/main.c:136
#, fuzzy
msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-"Affiche la boîte englobante maximale en latitude/longitude en WGS84 "
-"(seulement en mode -g)"
+msgstr "Affiche la boîte englobante maximale en latitude/longitude en WGS84 (seulement en mode -g)"
#: ../general/g.region/main.c:147
#, fuzzy
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Ajuster la région à la résolution (par défaut, alignement sur les limites de "
-"l'emprise,fonctionne seulement pour la résolution 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Ajuster la région à la résolution (par défaut, alignement sur les limites de l'emprise,fonctionne seulement pour la résolution 2D)"
#: ../general/g.region/main.c:153
msgid "Do not update the current region"
@@ -25285,9 +23793,7 @@
#: ../general/g.region/main.c:180
#, fuzzy
msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
-msgstr ""
-"Ajuster l'emprise de la région sur cette couche raster 3D (pour les valeurs "
-"2D et 3D)"
+msgstr "Ajuster l'emprise de la région sur cette couche raster 3D (pour les valeurs 2D et 3D)"
#: ../general/g.region/main.c:188
#, fuzzy
@@ -25425,19 +23931,12 @@
msgstr ""
#: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
msgstr ""
#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Impossible de projeter les données en WGS84 étant donné que ce Secteur ne "
-"possède pas deparamètres de transformation de datume. Essayez de lancer g."
-"setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Impossible de projeter les données en WGS84 étant donné que ce Secteur ne possède pas deparamètres de transformation de datume. Essayez de lancer g.setproj."
#: ../general/g.region/printwindow.c:783
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -25446,14 +23945,10 @@
#: ../general/g.list/main.c:48
#, fuzzy
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
#: ../general/g.mkfontcap/main.c:72
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+msgid "Generates the font configuration file by scanning various directories for fonts."
msgstr ""
#: ../general/g.mkfontcap/main.c:78
@@ -25461,8 +23956,7 @@
msgstr ""
#: ../general/g.mkfontcap/main.c:83
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
msgstr ""
#: ../general/g.mkfontcap/main.c:90
@@ -25470,23 +23964,16 @@
msgstr ""
#: ../general/g.mkfontcap/main.c:92
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
msgstr ""
#: ../general/g.mkfontcap/main.c:109
#, fuzzy, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà . Ce fichier va être "
-"écrasé!\n"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgstr "Couche raster %i le nom de fichier %s existe déjà . Ce fichier va être écrasé!\n"
#: ../general/g.mkfontcap/main.c:121
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
msgstr ""
# c-format
@@ -25569,8 +24056,7 @@
#: ../general/g.setproj/main.c:217
#, fuzzy
msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
#: ../general/g.setproj/main.c:225
#, fuzzy
@@ -25627,10 +24113,7 @@
msgstr "Les informations de projection ne seront pas mises à jour."
#: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
msgstr ""
#: ../general/g.setproj/main.c:461
@@ -25738,9 +24221,7 @@
#: ../general/g.remove/main.c:105
msgid "Removes data base element files from the user's current mapset."
-msgstr ""
-"de l'utilisateur"
#: ../general/g.remove/main.c:110
#, fuzzy
@@ -25823,8 +24304,7 @@
msgstr "couche PostScript en sortie"
#: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr ""
#: ../general/g.message/main.c:39
@@ -25917,13 +24397,8 @@
#: ../general/g.mapsets/main.c:67
#, fuzzy
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"Copier les fichiers de données disponibles dans le chemin de recherche et le "
-"Secteur vers le répertoire approprié sous le jeu de données courant de "
-"l'utilisateur."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr "Copier les fichiers de données disponibles dans le chemin de recherche et le Secteur vers le répertoire approprié sous le jeu de données courant de l'utilisateur."
#: ../general/g.mapsets/main.c:75
#, fuzzy
@@ -26000,9 +24475,7 @@
#: ../general/g.rename/main.c:47
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renommer les fichiers éléments de la base de données dans le jeu de données "
-"courant de l'utilisateur"
+msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
#: ../general/g.rename/main.c:53
#, fuzzy
@@ -26023,9 +24496,7 @@
#: ../general/g.rename/main.c:84
#, fuzzy, c-format
msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-"%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les "
-"renommer\n"
+msgstr "%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les renommer\n"
# c-format
#: ../general/g.rename/main.c:94
@@ -26039,13 +24510,8 @@
#: ../general/g.copy/main.c:45
#, fuzzy
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
-msgstr ""
-"l'utilisateur."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
#: ../general/g.copy/main.c:52
#, fuzzy
@@ -26061,9 +24527,7 @@
#: ../general/g.copy/main.c:72
#, fuzzy, c-format
msgid "%s=%s,%s: files are the same, no copy required"
-msgstr ""
-"copier\n"
+msgstr "%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les copier\n"
#: ../general/g.copy/main.c:77
#, fuzzy, c-format
@@ -26098,9 +24562,7 @@
msgstr "Hauteur z maximum (requiert le drapeau -z)"
#: ../vector/v.random/main.c:122
-msgid ""
-"The seed to initialize the random generator. If not set the process id is "
-"used."
+msgid "The seed to initialize the random generator. If not set the process id is used."
msgstr ""
#: ../vector/v.random/main.c:125
@@ -26138,9 +24600,7 @@
msgstr ""
#: ../vector/v.random/main.c:236
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
msgstr ""
# c-format
@@ -26159,10 +24619,7 @@
msgstr "Type de couche vecteur"
#: ../vector/v.net.iso/main.c:76
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
msgstr ""
#: ../vector/v.net.iso/main.c:100 ../vector/v.net.centrality/main.c:129
@@ -26194,9 +24651,7 @@
msgstr "Nombre de colonnes"
#: ../vector/v.net.iso/main.c:114
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
msgstr ""
#: ../vector/v.net.iso/main.c:123
@@ -26259,9 +24714,7 @@
msgstr "Calcul des moyennes de classes..."
#: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
msgstr ""
#: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
@@ -26392,7 +24845,7 @@
# c-format
#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:152
#: ../vector/v.proj/main.c:411 ../vector/v.kcv/main.c:142
-#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:719
+#: ../vector/v.build.polylines/main.c:234 ../vector/v.category/main.c:750
#: ../vector/v.transform/main.c:286 ../vector/v.rectify/main.c:285
#, fuzzy
msgid "Failed to copy attribute table to output map"
@@ -26413,8 +24866,7 @@
#: ../vector/v.to.rast/vect2rast.c:53
#, fuzzy, c-format
msgid "Database connection not defined for layer <%s>"
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
# c-format
#: ../vector/v.colors.out/make_colors.c:40 ../vector/v.colors/scan_attr.c:36
@@ -26479,12 +24931,8 @@
#: ../vector/v.voronoi/main.c:123
#, fuzzy
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
-msgstr ""
-"Crée une couche raster et une couche vectorielle contenant des points placés "
-"au hasard."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
#: ../vector/v.voronoi/main.c:127 ../vector/v.sample/main.c:82
#: ../vector/v.surf.bspline/main.c:114
@@ -26551,9 +24999,7 @@
msgstr ""
#: ../vector/v.net.steiner/main.c:351
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
msgstr ""
#: ../vector/v.net.steiner/main.c:371
@@ -26589,8 +25035,7 @@
#: ../vector/v.net.steiner/main.c:529
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
msgstr ""
#: ../vector/v.net.steiner/main.c:534
@@ -26722,15 +25167,9 @@
#: ../vector/v.overlay/main.c:103
#, fuzzy
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
msgstr ""
-"Opérateur qui définit la relation requise entre objets. Un objet est écrit "
-"dansla couche de sortie si le résultat de l'opération 'ainput opérateur "
-"binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de "
-"la couche est définie.\n"
+"Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
"\t recouvrement : les objets se recouvrent totalement ou partiellement"
#: ../vector/v.overlay/main.c:110
@@ -26746,9 +25185,7 @@
msgstr ""
#: ../vector/v.overlay/main.c:113
-msgid ""
-"features from either ainput or binput but not those from ainput overlayed by "
-"binput (only for atype=area)"
+msgid "features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
msgstr ""
#: ../vector/v.overlay/main.c:124
@@ -26786,9 +25223,7 @@
#: ../vector/v.overlay/main.c:299
#, fuzzy, c-format
msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-"%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. "
-"Vérifiez le paramètre 'type'"
+msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.overlay/main.c:348
#, fuzzy
@@ -26844,14 +25279,8 @@
#: ../vector/v.kernel/main.c:112
#, fuzzy
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
-msgstr ""
-"Génère une couche de densité raster à partir de données vecteurs points en "
-"utilisantun noyau Gaussien isotropique mobile 2D et génère de façon "
-"optionnelle une carte vectorielle de densitésur le réseau vectoriel avec un "
-"noyau 1D"
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+msgstr "Génère une couche de densité raster à partir de données vecteurs points en utilisantun noyau Gaussien isotropique mobile 2D et génère de façon optionnelle une carte vectorielle de densitésur le réseau vectoriel avec un noyau 1D"
#: ../vector/v.kernel/main.c:116
#, fuzzy
@@ -26928,23 +25357,15 @@
msgstr "Type inconnu"
#: ../vector/v.kernel/main.c:197
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Tente de calculer un écart-type optimal avec 'stddeviation' comme maximum "
-"'expérimental'"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Tente de calculer un écart-type optimal avec 'stddeviation' comme maximum 'expérimental'"
#: ../vector/v.kernel/main.c:202
msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Calculer seulement l'écart-type optimal et quitte (aucune couche n'est "
-"écrite)"
+msgstr "Calculer seulement l'écart-type optimal et quitte (aucune couche n'est écrite)"
#: ../vector/v.kernel/main.c:207
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
msgstr ""
#: ../vector/v.kernel/main.c:213
@@ -26973,15 +25394,11 @@
#: ../vector/v.kernel/main.c:276
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
msgstr ""
#: ../vector/v.kernel/main.c:280
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
msgstr ""
#: ../vector/v.kernel/main.c:297
@@ -27002,12 +25419,8 @@
#: ../vector/v.kernel/main.c:358
#, fuzzy, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Choix automatique du paramètre de lissage (écart-type), maximumvaleur "
-"possible de l'écart type si elle était fixée à %f"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Choix automatique du paramètre de lissage (écart-type), maximumvaleur possible de l'écart type si elle était fixée à %f"
# c-format
#: ../vector/v.kernel/main.c:365
@@ -27028,12 +25441,8 @@
#: ../vector/v.kernel/main.c:383
#, fuzzy, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"distances entre tous les points en-dessous de %e (4 * écart-type), "
-"impossiblede calculer la valeur optimale."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "distances entre tous les points en-dessous de %e (4 * écart-type), impossiblede calculer la valeur optimale."
#: ../vector/v.kernel/main.c:394
#, c-format
@@ -27093,9 +25502,7 @@
#: ../vector/v.in.ogr/main.c:142
#, fuzzy
msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Couche vectorielle cible, si elle n'est pas indiquée, les couches "
-"disponibles seront seulement affichées"
+msgstr "Couche vectorielle cible, si elle n'est pas indiquée, les couches disponibles seront seulement affichées"
#: ../vector/v.in.ogr/main.c:144
#, fuzzy
@@ -27116,9 +25523,7 @@
#: ../vector/v.in.ogr/main.c:161 ../vector/v.in.lidar/main.c:173
#, fuzzy
msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
-msgstr ""
-"Importer la sous-région seulement (xmin,ymin,xmax,ymax - habituellement O,S,"
-"E,N)"
+msgstr "Importer la sous-région seulement (xmin,ymin,xmax,ymax - habituellement O,S,E,N)"
#: ../vector/v.in.ogr/main.c:172
msgid "Minimum size of area to be imported (square units)"
@@ -27127,10 +25532,7 @@
#: ../vector/v.in.ogr/main.c:174
#, fuzzy
msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Taille minimale des entités surfaciques à importer (en unités au carré). Les "
-"entités plus petites et les îles sont ignorées. Elle doit être supérieure à "
-"snap^2"
+msgstr "Taille minimale des entités surfaciques à importer (en unités au carré). Les entités plus petites et les îles sont ignorées. Elle doit être supérieure à snap^2"
#: ../vector/v.in.ogr/main.c:180
#, fuzzy
@@ -27163,12 +25565,8 @@
msgstr ""
#: ../vector/v.in.ogr/main.c:212
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Liste de noms de colonnes à utiliser à la place des noms originaux, le "
-"premier correspondà la colonne de catégorie"
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Liste de noms de colonnes à utiliser à la place des noms originaux, le premier correspondà la colonne de catégorie"
#: ../vector/v.in.ogr/main.c:221
#, fuzzy
@@ -27212,9 +25610,7 @@
msgstr ""
#: ../vector/v.in.ogr/main.c:279
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
msgstr ""
#: ../vector/v.in.ogr/main.c:298
@@ -27250,9 +25646,7 @@
#: ../vector/v.in.ogr/main.c:435
#, fuzzy, c-format
msgid "All available OGR layers will be imported into vector map <%s>"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
#: ../vector/v.in.ogr/main.c:486 ../vector/v.in.lidar/main.c:281
msgid "Select either the current region flag or the spatial option, not both"
@@ -27276,8 +25670,7 @@
msgstr "4 paramètres sont requis pour le paramètre 'spatial'"
#: ../vector/v.in.ogr/main.c:553
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
msgstr ""
#: ../vector/v.in.ogr/main.c:587
@@ -27309,25 +25702,17 @@
#: ../vector/v.in.ogr/main.c:908
#, fuzzy, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible "
-"troncature des données)"
+msgstr "Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible troncature des données)"
#: ../vector/v.in.ogr/main.c:931
#, fuzzy, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes "
-"risquent d'être tronquées"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes risquent d'être tronquées"
#: ../vector/v.in.ogr/main.c:943
#, fuzzy, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
# c-format
#: ../vector/v.in.ogr/main.c:947
@@ -27400,7 +25785,7 @@
msgstr "Suppression des centroïdes en doublons..."
#: ../vector/v.in.ogr/main.c:1208 ../vector/v.delaunay/main.c:171
-#: ../vector/v.category/main.c:326
+#: ../vector/v.category/main.c:357
#, fuzzy
msgid "Unable to calculate area centroid"
msgstr "Impossible de calculer le centroïde de la surface"
@@ -27412,15 +25797,8 @@
#: ../vector/v.in.ogr/main.c:1291
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"les entités surfaciques %d comprennent des objets se recouvrant, étant donné "
-"que les polygones se recouvrent dans les couches en entrée. De telles "
-"entités sont liées à plus d'un tuple de la table attributaire. Le nombre "
-"d'objets de ces entités est stocké comme une catégorie de la couche %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "les entités surfaciques %d comprennent des objets se recouvrant, étant donné que les polygones se recouvrent dans les couches en entrée. De telles entités sont liées à plus d'un tuple de la table attributaire. Le nombre d'objets de ces entités est stocké comme une catégorie de la couche %d"
#: ../vector/v.in.ogr/main.c:1301
#, fuzzy, c-format
@@ -27470,13 +25848,8 @@
#: ../vector/v.in.ogr/main.c:1376
#, fuzzy
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
-msgstr ""
-"Les données en entrée contiennent des objets 3D. Les objets vecteurs créés "
-"sont uniquement 2D utilisez le drapeau -z pour importer des objets "
-"vectoriels 3D"
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
+msgstr "Les données en entrée contiennent des objets 3D. Les objets vecteurs créés sont uniquement 2D utilisez le drapeau -z pour importer des objets vectoriels 3D"
# c-format
#: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
@@ -27557,8 +25930,7 @@
msgstr ""
#: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
+msgid "connect still unconnected points to vector network by inserting new line(s)"
msgstr ""
#: ../vector/v.net/args.c:44
@@ -27566,14 +25938,11 @@
msgstr ""
#: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
+msgid "print to standard output {line_category start_point_category end_point_category}"
msgstr ""
#: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
+msgid "print to standard output {point_category line_category[,line_category...]}"
msgstr ""
#: ../vector/v.net/args.c:72
@@ -27593,8 +25962,7 @@
#: ../vector/v.net/args.c:83
#, fuzzy
msgid "Assign unique categories to new points"
-msgstr ""
-"Assignation de catégories uniques aux nouveaux points (opération=noeuds)"
+msgstr "Assignation de catégories uniques aux nouveaux points (opération=noeuds)"
#: ../vector/v.net/args.c:84
#, fuzzy
@@ -27607,9 +25975,7 @@
msgstr "couche vecteur des points d'arrivée"
#: ../vector/v.net/args.c:91
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
msgstr ""
#: ../vector/v.net/args.c:113
@@ -27698,9 +26064,7 @@
#: ../vector/v.proj/main.c:69
#, fuzzy
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-projeter une couche raster depuis un Secteur (location) vers le Secteur "
-"courant."
+msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
#: ../vector/v.proj/main.c:75
#, fuzzy
@@ -27866,9 +26230,7 @@
#: ../vector/v.label/main.c:137
msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Espacement entre caractères pour les étiquettes courbes (en unités de la "
-"carte)"
+msgstr "Espacement entre caractères pour les étiquettes courbes (en unités de la carte)"
#: ../vector/v.label/main.c:144
msgid "Label size (in points)"
@@ -27877,8 +26239,7 @@
#: ../vector/v.label/main.c:156
#, fuzzy
msgid "Rotation angle (degrees counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../vector/v.label/main.c:166
#, fuzzy
@@ -27896,15 +26257,11 @@
#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Vecteurs opaques (pertinent seulement si la couleur de fond est sélectionnée)"
+msgstr "Vecteurs opaques (pertinent seulement si la couleur de fond est sélectionnée)"
#: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"les options de taille et d'espace sont très mal assorties, le résultat "
-"risque d'être mauvais"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "les options de taille et d'espace sont très mal assorties, le résultat risque d'être mauvais"
#: ../vector/v.label/main.c:259
msgid "Too many parameters for <reference>"
@@ -27927,17 +26284,12 @@
#: ../vector/v.univar/main.c:94
#, fuzzy
msgid "Calculates univariate statistics for attribute."
-msgstr ""
-"Calcule des statistiques univariées à partir d'une couche raster GRASS basée "
-"sur des objets vecteurs"
+msgstr "Calcule des statistiques univariées à partir d'une couche raster GRASS basée sur des objets vecteurs"
#: ../vector/v.univar/main.c:95
#, fuzzy
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
-msgstr ""
-"Calcule des statistiques univariées pour un attribut. La variance et l'écart-"
-"type sont calculés uniquement pour les points si cela est spécifié."
+msgid "Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcule des statistiques univariées pour un attribut. La variance et l'écart-type sont calculés uniquement pour les points si cela est spécifié."
#: ../vector/v.univar/main.c:130
#, fuzzy
@@ -27945,12 +26297,8 @@
msgstr "%s va stocker ces valeurs à la place de la zone.\n"
#: ../vector/v.univar/main.c:161
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Type de vecteur spécifié incompatible, seuls le nombre d'objet, le minimum, "
-"le maximum et l'intervalle de valeur peuvent être calculés"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Type de vecteur spécifié incompatible, seuls le nombre d'objet, le minimum, le maximum et l'intervalle de valeur peuvent être calculés"
#: ../vector/v.univar/main.c:166
#, fuzzy
@@ -27969,8 +26317,7 @@
#: ../vector/v.univar/main.c:290
#, fuzzy, c-format
msgid " Database connection not defined for layer <%s>"
-msgstr ""
#: ../vector/v.univar/main.c:307 ../vector/v.sample/main.c:239
#: ../vector/v.buffer/main.c:421 ../vector/v.class/main.c:128
@@ -27991,15 +26338,11 @@
msgstr ""
#: ../vector/v.net.distance/main.c:67
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
msgstr ""
#: ../vector/v.net.distance/main.c:70
-msgid ""
-"Finds the shortest paths from a point 'from' to every feature 'to' and "
-"various information about this relation are uploaded to the attribute table."
+msgid "Finds the shortest paths from a point 'from' to every feature 'to' and various information about this relation are uploaded to the attribute table."
msgstr ""
#: ../vector/v.net.distance/main.c:97
@@ -28010,6 +26353,7 @@
#: ../vector/v.net.distance/main.c:98 ../vector/v.net.distance/main.c:103
#: ../vector/v.net.distance/main.c:109 ../vector/v.distance/main.c:97
#: ../vector/v.distance/main.c:102 ../vector/v.distance/main.c:109
+#: ../vector/v.distance/main.c:188
#, fuzzy
msgid "From"
msgstr "Type de donnée vectorielle"
@@ -28089,9 +26433,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:74
#, fuzzy
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
msgstr "Créer des points le long des lignes en entrée."
#: ../vector/v.lrs/v.lrs.segment/main.c:78
@@ -28141,9 +26483,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:113
#, fuzzy
msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
#: ../vector/v.lrs/v.lrs.segment/main.c:152
#: ../vector/v.lrs/v.lrs.where/main.c:145
@@ -28269,9 +26609,7 @@
msgstr "%d points écrits vers la couche cible\n"
#: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
msgstr ""
#: ../vector/v.lrs/v.lrs.where/main.c:70
@@ -28346,8 +26684,7 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -28382,9 +26719,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:281
#, fuzzy
msgid "Cannot get layer info for points"
-msgstr ""
-"vectorielle"
# c-format
#: ../vector/v.lrs/v.lrs.create/main.c:316
@@ -28548,8 +26883,7 @@
#: ../vector/v.lrs/v.lrs.label/main.c:248
#, fuzzy
msgid "Only relevant if background color is selected"
-msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:339
#, fuzzy, c-format
@@ -28568,16 +26902,12 @@
#: ../vector/v.out.ascii/args.c:30
#, fuzzy
msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-"
-"o' est défini"
+msgstr "Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-o' est défini"
#: ../vector/v.out.ascii/args.c:32
#, fuzzy
msgid "'-' for standard output"
-msgstr ""
#: ../vector/v.out.ascii/args.c:36
#, fuzzy
@@ -28631,8 +26961,7 @@
#: ../vector/v.out.ascii/main.c:51
#, fuzzy
msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr ""
-"Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
+msgstr "Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
#: ../vector/v.out.ascii/main.c:58
#, fuzzy
@@ -28650,9 +26979,7 @@
#: ../vector/v.out.ascii/main.c:78
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
#: ../vector/v.out.ascii/main.c:105
@@ -28782,12 +27109,10 @@
#: ../vector/v.support/main.c:110
#, fuzzy
msgid "Text to append to the comment line of the map's metadata file"
-msgstr ""
-"Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
+msgstr "Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
msgstr ""
#: ../vector/v.support/main.c:122
@@ -28812,9 +27137,7 @@
#: ../vector/v.outlier/main.c:76 ../vector/v.lidar.edgedetection/main.c:82
#: ../vector/v.lidar.correction/main.c:77 ../vector/v.surf.bspline/main.c:106
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
msgstr ""
#: ../vector/v.outlier/main.c:88
@@ -28969,8 +27292,7 @@
#: ../vector/v.build/main.c:49
#, fuzzy
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
+msgid "Name for output vector map where erroneous vector features are written to"
msgstr "Nom de la couche en sortie où les erreurs seront écrites"
#: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
@@ -29017,9 +27339,7 @@
#: ../vector/v.build/main.c:106
#, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
msgstr ""
#: ../vector/v.build/main.c:111
@@ -29132,9 +27452,7 @@
#: ../vector/v.edit/args.c:89
#, fuzzy
msgid "\"-\" reads from standard input"
-msgstr ""
#: ../vector/v.edit/args.c:99
msgid "Difference in x,y,z direction for moving feature or vertex"
@@ -29187,9 +27505,7 @@
msgstr "Nom de la couche vecteur"
#: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
msgstr ""
#: ../vector/v.edit/args.c:182
@@ -29265,9 +27581,7 @@
msgstr "Existant"
#: ../vector/v.edit/main.c:58
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
msgstr ""
#: ../vector/v.edit/main.c:67
@@ -29282,16 +27596,12 @@
#: ../vector/v.edit/main.c:137
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
#: ../vector/v.edit/main.c:157
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
#: ../vector/v.edit/main.c:168
@@ -29314,9 +27624,7 @@
#: ../vector/v.edit/main.c:231
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
msgstr ""
# c-format
@@ -29391,9 +27699,7 @@
#: ../vector/v.edit/main.c:358
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
msgstr ""
# c-format
@@ -29476,8 +27782,7 @@
#: ../vector/v.in.dwg/main.c:102
msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-"Inverser la sélection de couches (ne pas importer les couches dans la liste)"
+msgstr "Inverser la sélection de couches (ne pas importer les couches dans la liste)"
#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:145
#, fuzzy
@@ -29602,15 +27907,11 @@
msgstr ""
#: ../vector/v.net.alloc/main.c:66
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
msgstr ""
#: ../vector/v.net.alloc/main.c:111
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
msgstr ""
# c-format
@@ -29656,7 +27957,8 @@
msgid "Use drand48() (ignored)"
msgstr "Utilise la fonction drand48() (par défaut=rand() )"
-#: ../vector/v.kcv/main.c:119
+#: ../vector/v.kcv/main.c:119 ../vector/v.category/main.c:181
+#: ../vector/v.category/main.c:243 ../vector/v.category/main.c:251
#, fuzzy, c-format
msgid "Unable to open vector map <%s> at topological level %d"
@@ -29669,9 +27971,7 @@
#: ../vector/v.kcv/main.c:155
#, fuzzy, c-format
msgid "Unable to get layer info for vector map <%s>"
-msgstr ""
-"vectorielle"
# c-format
#: ../vector/v.kcv/main.c:179
@@ -29697,9 +27997,7 @@
#: ../vector/v.extract/extract.c:225
#, fuzzy
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
#: ../vector/v.extract/copy_tab.c:86
@@ -29727,9 +28025,7 @@
msgstr "Importation vecteur complète"
#: ../vector/v.extract/main.c:80
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
msgstr ""
#: ../vector/v.extract/main.c:85
@@ -29755,9 +28051,7 @@
#: ../vector/v.extract/main.c:121
#, fuzzy
msgid "If '-' given reads from standard input"
-msgstr ""
#: ../vector/v.extract/main.c:129
msgid "Number of random categories matching vector objects to extract"
@@ -29777,12 +28071,8 @@
#: ../vector/v.extract/main.c:158
#, fuzzy, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
-"one of them."
-msgstr ""
-"qu'un seul."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
#: ../vector/v.extract/main.c:203
#, fuzzy, c-format
@@ -29823,9 +28113,7 @@
msgstr "%d catégories chargées depuis la table"
#: ../vector/v.extract/main.c:279
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
msgstr ""
#: ../vector/v.extract/main.c:286
@@ -29835,22 +28123,16 @@
#: ../vector/v.extract/main.c:290
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
msgstr ""
#: ../vector/v.extract/main.c:313
#, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count "
-"%d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
msgstr ""
#: ../vector/v.extract/main.c:318
-msgid ""
-"There are more categories than random number generator can reach. Report "
-"this as a GRASS bug."
+msgid "There are more categories than random number generator can reach. Report this as a GRASS bug."
msgstr ""
# c-format
@@ -29888,16 +28170,11 @@
#: ../vector/v.out.postgis/options.c:37
#, fuzzy
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
-msgstr ""
-"Convertit une couche vecteur binaire GRASS en la combinant avec d'autres "
-"couches vectorielles binaires."
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
+msgstr "Convertit une couche vecteur binaire GRASS en la combinant avec d'autres couches vectorielles binaires."
#: ../vector/v.out.postgis/options.c:39
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
msgstr ""
#: ../vector/v.out.postgis/options.c:45
@@ -29977,21 +28254,16 @@
#: ../vector/v.out.postgis/table.c:27
#, fuzzy, c-format
msgid "No database connection for layer <%s>"
-msgstr ""
#: ../vector/v.out.postgis/table.c:50
#, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
msgstr ""
#: ../vector/v.out.postgis/table.c:57
#, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
msgstr ""
#: ../vector/v.db.connect/main.c:52 ../vector/v.distance/main.c:90
@@ -30057,9 +28329,7 @@
#: ../vector/v.db.connect/main.c:55
#, fuzzy
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Affiche/configure la connexion à la base de données de la couche vecteur "
-"vers une table attributaire"
+msgstr "Affiche/configure la connexion à la base de données de la couche vecteur vers une table attributaire"
#: ../vector/v.db.connect/main.c:77
msgid "Format: layer number[/layer name]"
@@ -30086,9 +28356,7 @@
#: ../vector/v.db.connect/main.c:99
msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Affiche les types/noms des colonnes de la table pour une couche spécifiée et "
-"quitte"
+msgstr "Affiche les types/noms des colonnes de la table pour une couche spécifiée et quitte"
#: ../vector/v.db.connect/main.c:106
msgid "Overwrite connection parameter for certain layer"
@@ -30119,14 +28387,12 @@
#: ../vector/v.db.connect/main.c:195
#, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
#: ../vector/v.db.connect/main.c:201
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
#: ../vector/v.db.connect/main.c:264
@@ -30153,12 +28419,8 @@
#: ../vector/v.db.connect/main.c:300 ../vector/v.db.connect/main.c:318
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La table <%s> fait à présent partie de la couche vectorielle <%s> et risque "
-"d'être effacée ou écrasée par les modules GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La table <%s> fait à présent partie de la couche vectorielle <%s> et risque d'être effacée ou écrasée par les modules GRASS"
#: ../vector/v.db.connect/main.c:339
#, c-format
@@ -30170,19 +28432,13 @@
msgstr "Des droits de sélection ont été accordés sur cette table"
#: ../vector/v.db.connect/main.c:349
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Pour définir une nouvelle connexion vous devez spécifier ces paramètres : "
-"pilote, base de données, table [, clef [, couche]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Pour définir une nouvelle connexion vous devez spécifier ces paramètres : pilote, base de données, table [, clef [, couche]]"
#: ../vector/v.in.ascii/main.c:52
#, fuzzy
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
#: ../vector/v.in.ascii/main.c:70
msgid "simple x,y[,z] list"
@@ -30206,9 +28462,7 @@
#: ../vector/v.in.ascii/main.c:87
#, fuzzy
msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Nombre de lignes d'en-tête à sauter au début du fichier source (écrit dans "
-"l'historique de la carte)"
+msgstr "Nombre de lignes d'en-tête à sauter au début du fichier source (écrit dans l'historique de la carte)"
#: ../vector/v.in.ascii/main.c:96
msgid "Column definition in SQL style (points mode)"
@@ -30216,9 +28470,7 @@
#: ../vector/v.in.ascii/main.c:97
#, fuzzy
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
msgstr ""
"Définition des colonnes en mode points en SQL, par exemple:\n"
"'x double précision, y double précision, cat int, name varchar(10)'"
@@ -30230,40 +28482,27 @@
#: ../vector/v.in.ascii/main.c:118
#, fuzzy
msgid "Number of column used as y coordinate (points mode)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) en mode points"
#: ../vector/v.in.ascii/main.c:128
#, fuzzy
msgid "Number of column used as z coordinate (points mode)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
#: ../vector/v.in.ascii/main.c:129
#, fuzzy
msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-"en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
#: ../vector/v.in.ascii/main.c:139
#, fuzzy
msgid "Number of column used as category (points mode)"
-msgstr ""
-"en mode points"
#: ../vector/v.in.ascii/main.c:141
#, fuzzy
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"Nombre de colonne utilisé comme catégorie (la première colonne est 1) en "
-"mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque "
-"ligne et écrit dans la nouvelle colonne 'cat'."
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "Nombre de colonne utilisé comme catégorie (la première colonne est 1) en mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque ligne et écrit dans la nouvelle colonne 'cat'."
#: ../vector/v.in.ascii/main.c:150
#, fuzzy
@@ -30349,16 +28588,14 @@
#: ../vector/v.in.ascii/main.c:280
#, fuzzy
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"numéro de colonne z > numéro de dernière colonne\n"
"(séparateur de champ erroné?)"
#: ../vector/v.in.ascii/main.c:285
#, fuzzy
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
"numéro de colonne cat > numéro de dernière colonne\n"
@@ -30385,24 +28622,18 @@
#: ../vector/v.in.ascii/main.c:426
#, fuzzy, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
-"Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)"
-"de la source."
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr "Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)de la source."
#: ../vector/v.in.ascii/main.c:454
#, fuzzy, c-format
msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"La colonne %d définie comme double ne contient que des valeurs entières"
+msgstr "La colonne %d définie comme double ne contient que des valeurs entières"
#: ../vector/v.in.ascii/main.c:459
#, fuzzy, c-format
msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"La colonne %d définie comme chaîne de caractères ne contient que des valeurs "
-"entières"
+msgstr "La colonne %d définie comme chaîne de caractères ne contient que des valeurs entières"
#: ../vector/v.in.ascii/main.c:467
#, fuzzy, c-format
@@ -30427,9 +28658,7 @@
#: ../vector/v.in.ascii/main.c:492
#, fuzzy, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"La longeur de la colonne %d (%d) est inférieure à la longueur de la plus "
-"grande valeur (%d)"
+msgstr "La longeur de la colonne %d (%d) est inférieure à la longueur de la plus grande valeur (%d)"
#: ../vector/v.in.ascii/main.c:532
#, fuzzy
@@ -30437,9 +28666,7 @@
msgstr "Rotation des données ... "
#: ../vector/v.in.ascii/main.c:538
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
msgstr ""
#: ../vector/v.in.ascii/points.c:83
@@ -30487,9 +28714,7 @@
#: ../vector/v.colors/make_colors.c:14
#, fuzzy, c-format
msgid "Color table '%s' is not supported for floating point attributes"
-msgstr ""
-"Impossible de construire une table de couleurs aléatoire pour les couches en "
-"valeurs flottantes"
+msgstr "Impossible de construire une table de couleurs aléatoire pour les couches en valeurs flottantes"
#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
#, fuzzy, c-format
@@ -30509,16 +28734,12 @@
#: ../vector/v.colors/scan_attr.c:78 ../vector/v.colors/scan_cats.c:43
#, fuzzy, c-format
msgid "Min value (%d) is out of range %d,%d"
-msgstr ""
-"** attention: la(es) valeur(s) R:V:B est(sont) en dehors des limites "
-"[0..255]: %d:%d:%d **\n"
+msgstr "** attention: la(es) valeur(s) R:V:B est(sont) en dehors des limites [0..255]: %d:%d:%d **\n"
#: ../vector/v.colors/scan_attr.c:84 ../vector/v.colors/scan_cats.c:49
#, fuzzy, c-format
msgid "Max value (%d) is out of range %d,%d"
-msgstr ""
# c-format
#: ../vector/v.colors/write_rgb.c:36
@@ -30606,15 +28827,12 @@
#: ../vector/v.colors/main.c:169
#, fuzzy, c-format
msgid "Options <%s> and <%s> are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../vector/v.colors/main.c:179
#, fuzzy, c-format
msgid "One of -%c, -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
-"L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
+msgstr "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
# c-format
#: ../vector/v.colors/main.c:193
@@ -30684,9 +28902,7 @@
#: ../vector/v.sample/main.c:89
#, fuzzy
msgid "Name of attribute column to use for comparison"
-msgstr ""
-"Nom du champ attributaire de la couche vectorielle à utiliser pour la "
-"comparaison"
+msgstr "Nom du champ attributaire de la couche vectorielle à utiliser pour la comparaison"
#: ../vector/v.sample/main.c:92
#, fuzzy
@@ -30706,16 +28922,13 @@
#: ../vector/v.sample/main.c:114
#, fuzzy
msgid "Sampled values will be multiplied by this factor"
-msgstr ""
-"Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les "
-"valeurs échantillonnées seront multipliées par ce facteur"
+msgstr "Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les valeurs échantillonnées seront multipliées par ce facteur"
#: ../vector/v.sample/main.c:140 ../vector/v.reclass/main.c:125
#: ../vector/v.surf.idw/read_sites.c:36
#, fuzzy, c-format
msgid "Database connection not defined for layer %s"
-msgstr ""
# c-format
#: ../vector/v.sample/main.c:154
@@ -30742,9 +28955,7 @@
msgstr "Lecture du fichier %s..."
#: ../vector/v.distance/main.c:92
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
msgstr ""
#: ../vector/v.distance/main.c:96
@@ -30818,14 +29029,11 @@
msgstr "Coordonnée X d'un point sur le plan."
#: ../vector/v.distance/main.c:169
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
msgstr ""
#: ../vector/v.distance/main.c:171
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
msgstr ""
#: ../vector/v.distance/main.c:174
@@ -30833,14 +29041,9 @@
msgstr ""
#: ../vector/v.distance/main.c:187
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
-#: ../vector/v.distance/main.c:188
-msgid "From_map"
-msgstr ""
#: ../vector/v.distance/main.c:193
msgid "Column name of nearest feature (used with upload=to_attr)"
msgstr ""
@@ -30863,9 +29066,7 @@
msgstr ""
#: ../vector/v.distance/main.c:213
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
msgstr ""
#: ../vector/v.distance/main.c:268
@@ -31009,9 +29210,7 @@
#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
#, fuzzy, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>. "
-"Utilisez d'abord v.db.connect."
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>. Utilisez d'abord v.db.connect."
# c-format
#: ../vector/v.to.db/query.c:93
@@ -31021,9 +29220,7 @@
#: ../vector/v.to.db/query.c:108
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
msgstr ""
#: ../vector/v.to.db/query.c:145
@@ -31076,9 +29273,7 @@
#: ../vector/v.to.db/parse.c:43
#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Type d'éléments (pour les coord point/centroïde valide, pour la longueur "
-"ligne/contour valide)"
+msgstr "Type d'éléments (pour les coord point/centroïde valide, pour la longueur ligne/contour valide)"
#: ../vector/v.to.db/parse.c:54
msgid "Value to upload"
@@ -31118,9 +29313,7 @@
#: ../vector/v.to.db/parse.c:80
#, fuzzy
msgid "number of features for each category"
-msgstr ""
-"vectorielle"
#: ../vector/v.to.db/parse.c:81
#, fuzzy
@@ -31136,15 +29329,11 @@
msgstr ""
#: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, 'qlayer' is "
-"used for area category"
+msgid "categories of areas on the left and right side of the boundary, 'qlayer' is used for area category"
msgstr ""
#: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'qlayer' option"
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'qlayer' option"
msgstr ""
#: ../vector/v.to.db/parse.c:88
@@ -31153,14 +29342,11 @@
msgstr "Couche de sortie : facteur d'escarpement (S) pour USLE "
#: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
+msgid "line sinuousity, calculated as line length / distance between end points"
msgstr ""
#: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
msgstr ""
#: ../vector/v.to.db/parse.c:94
@@ -31181,9 +29367,7 @@
#: ../vector/v.to.db/parse.c:110
#, fuzzy
msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
-msgstr ""
-"Lancer une requête sur la colonne par l'option 'query'. Par exemple, 'cat', "
-"'count(*)', 'sum(val)'"
+msgstr "Lancer une requête sur la colonne par l'option 'query'. Par exemple, 'cat', 'count(*)', 'sum(val)'"
#: ../vector/v.to.db/parse.c:115
#, fuzzy
@@ -31203,8 +29387,7 @@
#: ../vector/v.to.db/parse.c:132
#, fuzzy
msgid "Print also totals for option length, area, or count"
-msgstr ""
-"En mode affichage, affiche les totaux des options : longueur, aire, comptage"
+msgstr "En mode affichage, affiche les totaux des options : longueur, aire, comptage"
#: ../vector/v.to.db/parse.c:178
msgid "This option requires one column"
@@ -31347,8 +29530,7 @@
#: ../vector/v.mkgrid/main.c:122
#, fuzzy
msgid "Angle of rotation (in degrees counter-clockwise)"
-msgstr ""
# c-format
#: ../vector/v.mkgrid/main.c:130
@@ -31453,8 +29635,7 @@
#: ../vector/v.build.polylines/main.c:132
#, fuzzy
msgid "Assign multiple category numbers to polyline"
-msgstr ""
# c-format
#: ../vector/v.build.polylines/main.c:226
@@ -31481,12 +29662,8 @@
#: ../vector/v.delaunay/main.c:88
#, fuzzy
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"au hasard."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
#, fuzzy
@@ -31534,9 +29711,7 @@
#: ../vector/v.qcount/main.c:71
#, fuzzy
-msgid ""
-"Name for output quadrant centres map (number of points is written as "
-"category)"
+msgid "Name for output quadrant centres map (number of points is written as category)"
msgstr ""
"#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
"Nom de la couche raster cible\n"
@@ -31567,185 +29742,180 @@
msgid "Counting points quadrats..."
msgstr "Recherche des classes d'apprentissage..."
-#: ../vector/v.category/main.c:77
+#: ../vector/v.category/main.c:78
msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:90
msgid "Feature ids (by default all features are processed)"
msgstr ""
-#: ../vector/v.category/main.c:101
+#: ../vector/v.category/main.c:102
#, fuzzy
msgid "Action to be done"
msgstr "Icone à supprimer"
-#: ../vector/v.category/main.c:111
+#: ../vector/v.category/main.c:113
#, fuzzy
msgid "add a new category"
msgstr ""
"couche: %d\n"
"catégorie: %d\n"
-#: ../vector/v.category/main.c:112
+#: ../vector/v.category/main.c:114
msgid "delete category (-1 to delete all categories of given layer)"
msgstr ""
-#: ../vector/v.category/main.c:113
+#: ../vector/v.category/main.c:115
msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
msgstr ""
-#: ../vector/v.category/main.c:114
+#: ../vector/v.category/main.c:116
msgid "add the value specified by cat option to the current category value"
msgstr ""
-#: ../vector/v.category/main.c:115
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+#: ../vector/v.category/main.c:117
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
msgstr ""
-#: ../vector/v.category/main.c:116
+#: ../vector/v.category/main.c:118
msgid "print report (statistics), in shell style: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:117
+#: ../vector/v.category/main.c:119
msgid "print category values, more cats in the same layer are separated by '/'"
msgstr ""
-#: ../vector/v.category/main.c:129
+#: ../vector/v.category/main.c:120
+#, fuzzy
+msgid "print only layer numbers"
+msgstr "Ne pas afficher les codes de catégories"
+#: ../vector/v.category/main.c:132
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
msgid "Category increment"
msgstr ""
-#: ../vector/v.category/main.c:133
+#: ../vector/v.category/main.c:136
msgid "Shell script style, currently only for report"
msgstr ""
-#: ../vector/v.category/main.c:134
+#: ../vector/v.category/main.c:137
msgid "Format: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:152
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+#: ../vector/v.category/main.c:155
+msgid "Database connection and attribute tables for concerned layers are not changed"
msgstr ""
-#: ../vector/v.category/main.c:173
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+#: ../vector/v.category/main.c:203
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
msgstr ""
-#: ../vector/v.category/main.c:182
+#: ../vector/v.category/main.c:212
#, fuzzy, c-format
msgid "%d errors in id option"
msgstr "%d erreurs dans l'option cat"
-#: ../vector/v.category/main.c:191
+#: ../vector/v.category/main.c:221
#, fuzzy
msgid "Output vector wasn't entered"
msgstr "La couche de vecteur en sortie n'a pas été saisie."
-#: ../vector/v.category/main.c:212 ../vector/v.category/main.c:220
-#, fuzzy, c-format
-msgid "Can not open vector <%s> on level %d"
-msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#: ../vector/v.category/main.c:237
+#: ../vector/v.category/main.c:268
msgid "Too many layers for this operation"
msgstr "Trop de couches pour cette opération"
-#: ../vector/v.category/main.c:240 ../vector/v.category/main.c:243
+#: ../vector/v.category/main.c:271 ../vector/v.category/main.c:274
msgid "2 layers must be specified"
msgstr "2 couches doivent être spécifiées"
# c-format
-#: ../vector/v.category/main.c:251
+#: ../vector/v.category/main.c:282
#, fuzzy, c-format
msgid "Categories already exist in layer %d"
-#: ../vector/v.category/main.c:294 ../vector/v.select/select.c:40
+#: ../vector/v.category/main.c:325 ../vector/v.select/select.c:40
#, fuzzy
msgid "Processing features..."
msgstr "Traitement des entités surfaciques ainput..."
-#: ../vector/v.category/main.c:340
+#: ../vector/v.category/main.c:371
#, fuzzy, c-format
msgid "%d new centroids placed in output map"
msgstr "%-5d centroïdes écrits dans le fichier de sortie.\n"
-#: ../vector/v.category/main.c:629
+#: ../vector/v.category/main.c:660
#, fuzzy
msgid "Layer/table"
msgstr "La couche '%s' n'est pas disponible"
-#: ../vector/v.category/main.c:633
+#: ../vector/v.category/main.c:664
#, fuzzy
msgid "Layer"
msgstr "couche %d"
-#: ../vector/v.category/main.c:635
+#: ../vector/v.category/main.c:666
#, fuzzy, c-format
msgid "type count min max\n"
msgstr ""
" VÃRIFICATION DES RÃSIDUS DE LA COUCHE\n"
"\n"
-#: ../vector/v.category/main.c:636
+#: ../vector/v.category/main.c:667
#, fuzzy
msgid "point"
msgstr "Afficher"
-#: ../vector/v.category/main.c:640
+#: ../vector/v.category/main.c:671
msgid "line"
msgstr ""
-#: ../vector/v.category/main.c:644
+#: ../vector/v.category/main.c:675
#, fuzzy
msgid "boundary"
msgstr "Limites"
-#: ../vector/v.category/main.c:648
+#: ../vector/v.category/main.c:679
#: ../locale/scriptstrings/v.centroids_to_translate.c:3
#, fuzzy
msgid "centroid"
msgstr "%-5d centroïdes lus\n"
-#: ../vector/v.category/main.c:652
+#: ../vector/v.category/main.c:683
#: ../locale/scriptstrings/v.centroids_to_translate.c:4
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
#, fuzzy
msgid "area"
msgstr "Entité surfacique\n"
-#: ../vector/v.category/main.c:656
+#: ../vector/v.category/main.c:687
#, fuzzy
msgid "face"
msgstr "Variance de la somme"
-#: ../vector/v.category/main.c:660
+#: ../vector/v.category/main.c:691
msgid "kernel"
msgstr ""
-#: ../vector/v.category/main.c:664
+#: ../vector/v.category/main.c:695
msgid "all"
msgstr ""
-#: ../vector/v.category/main.c:717 ../vector/v.rectify/main.c:283
+#: ../vector/v.category/main.c:748 ../vector/v.rectify/main.c:283
#, fuzzy
msgid "Copying attribute table(s)..."
msgstr "Ne pas créer de table attributaire"
# c-format
-#: ../vector/v.category/main.c:725
+#: ../vector/v.category/main.c:756
#, fuzzy, c-format
msgid "Categories copied from layer %d to layer %d"
# c-format
-#: ../vector/v.category/main.c:727
+#: ../vector/v.category/main.c:758
#, fuzzy, c-format
msgid "%d features modified."
msgstr "%d points écrits dans la couche vecteur"
@@ -31863,9 +30033,7 @@
#: ../vector/v.buffer/main.c:227
#, fuzzy
msgid "Creates a buffer around vector features of given type."
-msgstr ""
-"crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques "
-"doivent contenir un centroïde)."
+msgstr "crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques doivent contenir un centroïde)."
#: ../vector/v.buffer/main.c:252
#, fuzzy
@@ -31894,12 +30062,8 @@
msgstr "Facteur d'échelle pour les valeurs de colonnes attributaires"
#: ../vector/v.buffer/main.c:291
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Distance maximale entre l'arc de cercle théorique et les segments de "
-"polygones comme multiples du buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Distance maximale entre l'arc de cercle théorique et les segments de polygones comme multiples du buffer"
#: ../vector/v.buffer/main.c:296
msgid "Make outside corners straight"
@@ -31920,9 +30084,7 @@
#: ../vector/v.buffer/main.c:338
#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
msgstr ""
#: ../vector/v.buffer/main.c:349
@@ -31962,15 +30124,11 @@
msgstr "Impossible de sélectionner des données dans la table"
#: ../vector/v.buffer/main.c:451
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
msgstr ""
#: ../vector/v.buffer/main.c:467
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
msgstr ""
# c-format
@@ -32052,20 +30210,11 @@
#: ../vector/v.surf.rst/main.c:146
#, fuzzy
msgid "Performs surface interpolation from vector points map by splines."
-msgstr ""
-"Interpolation de surface à partir de données vecteur point par pondération "
-"de la distance inverse au carré (IDSW)."
+msgstr "Interpolation de surface à partir de données vecteur point par pondération de la distance inverse au carré (IDSW)."
#: ../vector/v.surf.rst/main.c:148
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Ré-interpole de façon approchée et fait une analyse topographique depuis une "
-"couche vecteur de points ou d'isolignes vers une nouvelle couche raster (en "
-"valeurs flottantes) en utilisant des splines régularisées avec tension et "
-"lissage."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Ré-interpole de façon approchée et fait une analyse topographique depuis une couche vecteur de points ou d'isolignes vers une nouvelle couche raster (en valeurs flottantes) en utilisant des splines régularisées avec tension et lissage."
#: ../vector/v.surf.rst/main.c:155
msgid "Perform cross-validation procedure without raster approximation"
@@ -32078,14 +30227,10 @@
#: ../vector/v.surf.rst/main.c:179
#, fuzzy
msgid "Name of the attribute column with values to be used for approximation"
-msgstr ""
-"Nom de la colonne attributaire où prendre les valeurs à utiliser pour "
-"calculer les valeurs approchées(si couche>0)"
+msgstr "Nom de la colonne attributaire où prendre les valeurs à utiliser pour calculer les valeurs approchées(si couche>0)"
#: ../vector/v.surf.rst/main.c:180
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
msgstr ""
#: ../vector/v.surf.rst/main.c:190
@@ -32110,8 +30255,7 @@
#: ../vector/v.surf.rst/main.c:233
#, fuzzy
msgid "Name for output cross-validation errors vector point map"
-msgstr ""
-"Fichier en sortie de validation croisée des erreurs sur vecteurs points"
+msgstr "Fichier en sortie de validation croisée des erreurs sur vecteurs points"
#: ../vector/v.surf.rst/main.c:240
#, fuzzy
@@ -32150,16 +30294,11 @@
#: ../vector/v.surf.rst/main.c:301 ../vector/v.vol.rst/main.c:339
msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-"Distance minimum entre les points en unités carte (pour supprimer les points "
-"quasi-identiques)"
+msgstr "Distance minimum entre les points en unités carte (pour supprimer les points quasi-identiques)"
#: ../vector/v.surf.rst/main.c:309
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Distance maximum entre les points des courbes de niveau en unités carte "
-"(pour insérer des points supplémentaires)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Distance maximum entre les points des courbes de niveau en unités carte (pour insérer des points supplémentaires)"
#: ../vector/v.surf.rst/main.c:318
msgid "Conversion factor for values used for approximation"
@@ -32167,9 +30306,7 @@
#: ../vector/v.surf.rst/main.c:326
msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr ""
-"Angle d'anisotropie (en degrés, sens inverse des aiguilles d'une montre en "
-"partant de l'Est)"
+msgstr "Angle d'anisotropie (en degrés, sens inverse des aiguilles d'une montre en partant de l'Est)"
#: ../vector/v.surf.rst/main.c:389 ../vector/v.surf.rst/main.c:394
#: ../vector/v.surf.rst/main.c:399 ../vector/v.surf.rst/main.c:404
@@ -32183,20 +30320,12 @@
msgstr "Vous ne fabriquez aucun fichier raster ou vecteur en sortie"
#: ../vector/v.surf.rst/main.c:426
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Vous devez spécifier les deux options de validation croisée (drapeau -c et "
-"sortie vecteur cvdev)"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Vous devez spécifier les deux options de validation croisée (drapeau -c et sortie vecteur cvdev)"
#: ../vector/v.surf.rst/main.c:429
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"La validation croisée ne peut être calculée simultanément avec la sortie "
-"raster ou la sortie du fichier devi"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "La validation croisée ne peut être calculée simultanément avec la sortie raster ou la sortie du fichier devi"
#: ../vector/v.surf.rst/main.c:447
msgid "Using anisotropy - both theta and scalex have to be specified"
@@ -32204,15 +30333,11 @@
#: ../vector/v.surf.rst/main.c:455
msgid "Both smatt and smooth options specified - using constant"
-msgstr ""
-"Les options smatt et smooth sont toutes deux spécifiées - utilisation de "
-"constante"
+msgstr "Les options smatt et smooth sont toutes deux spécifiées - utilisation de constante"
#: ../vector/v.surf.rst/main.c:465
msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-"Le calcul risque de durer trop longtemps - nous vous suggérons de choisir "
-"une npmin plus basse"
+msgstr "Le calcul risque de durer trop longtemps - nous vous suggérons de choisir une npmin plus basse"
#: ../vector/v.surf.rst/main.c:483
msgid "Not enough memory for az"
@@ -32255,9 +30380,7 @@
msgstr "Impossible de créer l'information d'arborescence"
#: ../vector/v.surf.rst/main.c:542
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
msgstr ""
#: ../vector/v.surf.rst/main.c:544
@@ -32276,9 +30399,7 @@
#: ../vector/v.surf.rst/main.c:662
#, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for "
-"temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
msgstr ""
#: ../vector/v.surf.rst/main.c:682
@@ -32293,14 +30414,10 @@
#: ../vector/v.surf.rst/main.c:706
#, fuzzy
msgid "Unable to write raster maps - try to increase resolution"
-msgstr ""
-"Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la "
-"résolution"
+msgstr "Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la résolution"
#: ../vector/v.transform/main.c:73
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
msgstr ""
#: ../vector/v.transform/main.c:78
@@ -32355,9 +30472,7 @@
#: ../vector/v.transform/main.c:161
msgid "Rotation around z axis in degrees counterclockwise"
-msgstr ""
-"Angle de rotation autour de l'axe z en degrés (dans le sens inverse des "
-"aiguilles d'une montre)"
+msgstr "Angle de rotation autour de l'axe z en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../vector/v.transform/main.c:167
#, fuzzy
@@ -32416,16 +30531,13 @@
#: ../vector/v.transform/trans_digit.c:112
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
msgstr ""
#: ../vector/v.transform/trans_digit.c:123
#, fuzzy
msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Vérifier l'information de datum et afficher les paramètres de transformation"
+msgstr "Vérifier l'information de datum et afficher les paramètres de transformation"
#: ../vector/v.reclass/main.c:69
#, fuzzy
@@ -32433,9 +30545,7 @@
msgstr "Colonne(s) attributaire(s)"
#: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
msgstr ""
#: ../vector/v.reclass/main.c:88
@@ -32549,14 +30659,8 @@
#: ../vector/v.neighbors/main.c:55
#, fuzzy
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
-msgstr ""
-"Calcule pour chaque cellule une fonction des valeurs des cellules "
-"adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche "
-"raster de sortie."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr "Calcule pour chaque cellule une fonction des valeurs des cellules adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche raster de sortie."
#: ../vector/v.neighbors/main.c:77
#, fuzzy
@@ -32806,32 +30910,20 @@
#: ../vector/v.external/list.c:291
#, fuzzy, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
-msgstr ""
-"Impossible de convertir la projection de la couche en entrée au format "
-"GRASS ; impossible de créer le nouveau Secteur"
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
+msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
#: ../vector/v.external/main.c:54
#, fuzzy
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
-msgstr ""
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
#: ../vector/v.external/main.c:73 ../vector/v.external.out/link.c:46
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
msgstr ""
#: ../vector/v.external/main.c:78 ../vector/v.external.out/link.c:53
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
msgstr ""
# c-format
@@ -33048,9 +31140,7 @@
#: ../vector/v.lidar.edgedetection/main.c:392
#, fuzzy
msgid "Allocating memory for bilinear interpolation"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../vector/v.lidar.edgedetection/main.c:425
#, fuzzy
@@ -33080,9 +31170,7 @@
#: ../vector/v.out.ogr/args.c:17
#, fuzzy
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
msgstr "Le mélange de types n'est pas géré par tous les formats."
#: ../vector/v.out.ogr/args.c:28
@@ -33126,9 +31214,7 @@
#: ../vector/v.out.ogr/args.c:73
#, fuzzy
msgid "Open an existing datasource for update"
-msgstr ""
-"Nettoyer les données existantes qui se trouvent dans le répertoire de "
-"téléchargement"
+msgstr "Nettoyer les données existantes qui se trouvent dans le répertoire de téléchargement"
#: ../vector/v.out.ogr/args.c:77
msgid "Append to existing layer instead of creating new if it exists"
@@ -33140,26 +31226,18 @@
#: ../vector/v.out.ogr/args.c:88
#, fuzzy
-msgid ""
-"Also export features without category (not labeled). Otherwise only features "
-"with category are exported."
-msgstr ""
-"Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les "
-"objets sontexportés"
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
+msgstr "Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les objets sontexportés"
#: ../vector/v.out.ogr/args.c:94
#, fuzzy
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Utiliser le format de fichier .prj de style ESRI (ne s'applique qu'aux "
-"sorties sous forme de SHAPE)"
+msgstr "Utiliser le format de fichier .prj de style ESRI (ne s'applique qu'aux sorties sous forme de SHAPE)"
#: ../vector/v.out.ogr/args.c:100
#, fuzzy
msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
#: ../vector/v.out.ogr/args.c:106
msgid "Export lines as polygons"
@@ -33167,9 +31245,7 @@
#: ../vector/v.out.ogr/args.c:112
#, fuzzy
-msgid ""
-"Create a new empty OGR layer in defined OGR datasource and exit. Nothing is "
-"read from input."
+msgid "Create a new empty OGR layer in defined OGR datasource and exit. Nothing is read from input."
msgstr "Crée une nouvelle couche vide et quitte. Rien n'est lu en entrée."
#: ../vector/v.out.ogr/create.c:20
@@ -33199,9 +31275,7 @@
#: ../vector/v.out.ogr/main.c:97 ../vector/v.external.out/link.c:26
#, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
-"\" given)"
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
msgstr ""
#: ../vector/v.out.ogr/main.c:162
@@ -33225,135 +31299,83 @@
msgstr ""
#: ../vector/v.out.ogr/main.c:272
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
msgstr ""
#: ../vector/v.out.ogr/main.c:278
#, fuzzy, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:283
#, fuzzy, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:289
#, fuzzy, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:295
#, fuzzy, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:300
#, fuzzy, c-format
-msgid ""
-"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. "
-"Vérifiez le paramètre 'type'"
+msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:304
#, fuzzy, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:309
#, fuzzy, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"paramètre 'type'"
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:315
#, fuzzy
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"paramètre 'type'"
+msgid "No points found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:324
#, fuzzy
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"paramètre 'type'"
+msgid "No lines found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:334
#, fuzzy
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"paramètre 'type'"
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:343
#, fuzzy
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No areas found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:353
#, fuzzy
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"paramètre 'type'"
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:362
#, fuzzy
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No faces found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:371
#, fuzzy
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:380
#, fuzzy
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"paramètre 'type'"
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:391
#, fuzzy
@@ -33368,9 +31390,7 @@
#: ../vector/v.out.ogr/main.c:415
#, c-format
-msgid ""
-"Append existing layer requires opening data source in update mode, forcing '-"
-"%c' flag"
+msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
msgstr ""
# c-format
@@ -33400,23 +31420,17 @@
#: ../vector/v.out.ogr/main.c:500
#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
msgstr ""
#: ../vector/v.out.ogr/main.c:512
#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
msgstr ""
#: ../vector/v.out.ogr/main.c:519
#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)."
msgstr ""
#: ../vector/v.out.ogr/main.c:536 ../db/drivers/ogr/execute.c:56
@@ -33431,9 +31445,7 @@
#: ../vector/v.out.ogr/main.c:550
msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"Aucune table attributaire trouvée -> on utilise les identifiants de "
-"catégories comme attributs"
+msgstr "Aucune table attributaire trouvée -> on utilise les identifiants de catégories comme attributs"
#: ../vector/v.out.ogr/main.c:554
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -33519,20 +31531,15 @@
#: ../vector/v.patch/main.c:70
#, fuzzy
msgid "Creates a new vector map by combining other vector maps."
-msgstr ""
#: ../vector/v.patch/main.c:81
#, fuzzy
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
#: ../vector/v.patch/main.c:85
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
msgstr ""
#: ../vector/v.patch/main.c:90
@@ -33543,9 +31550,7 @@
#: ../vector/v.patch/main.c:92
#, fuzzy
msgid "Only the table of layer 1 is currently supported"
-msgstr ""
-"Copie égalment la table attributaire. Seule la table de la couche 1 est "
-"prise en compte pour le moment"
+msgstr "Copie égalment la table attributaire. Seule la table de la couche 1 est prise en compte pour le moment"
#: ../vector/v.patch/main.c:192
msgid "Missing table"
@@ -33595,9 +31600,7 @@
#: ../vector/v.patch/main.c:326
#, fuzzy, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Erreur de lecture du fichier '%s'. Certaines données ne seront pas "
-"correctes\n"
+msgstr "Erreur de lecture du fichier '%s'. Certaines données ne seront pas correctes\n"
#: ../vector/v.patch/main.c:369
#, fuzzy, c-format
@@ -33607,16 +31610,12 @@
#: ../vector/v.patch/main.c:375
#, fuzzy
msgid "Intersections at borders will have to be snapped"
-msgstr ""
-"Les intersections aux limites doivent faire l'objet d'une opération de "
-"capture."
+msgstr "Les intersections aux limites doivent faire l'objet d'une opération de capture."
#: ../vector/v.patch/main.c:376
#, fuzzy
msgid "Lines common between files will have to be edited"
-msgstr ""
-"Les lignes communes aux deux fichiers devront faire l'objet d'une session "
-"d'édition."
+msgstr "Les lignes communes aux deux fichiers devront faire l'objet d'une session d'édition."
#: ../vector/v.patch/main.c:377
#, fuzzy
@@ -33679,9 +31678,7 @@
msgstr "Réhausser les valeurs de coordonnées z"
#: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
msgstr ""
#: ../vector/v.out.pov/main.c:82
@@ -33727,15 +31724,9 @@
#: ../vector/v.select/args.c:49
#, fuzzy
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
msgstr ""
-"Opérateur qui définit la relation requise entre objets. Un objet est écrit "
-"dansla couche de sortie si le résultat de l'opération 'ainput opérateur "
-"binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de "
-"la couche est définie.\n"
+"Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
"\t recouvrement : les objets se recouvrent totalement ou partiellement"
#: ../vector/v.select/args.c:57 ../vector/v.select/args.c:73
@@ -33775,9 +31766,7 @@
msgstr ""
#: ../vector/v.select/args.c:82
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
msgstr ""
#: ../vector/v.select/args.c:92
@@ -33803,8 +31792,7 @@
#: ../vector/v.select/main.c:51
#, fuzzy
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
msgstr "Sélectionne les objets de ainput à partir des objets de binput"
#: ../vector/v.select/main.c:93
@@ -33836,9 +31824,7 @@
#: ../vector/v.select/select.c:63
#, fuzzy, c-format
msgid "Unable to read line id %d from vector map <%s>"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
# c-format
#: ../vector/v.select/select.c:189
@@ -33849,8 +31835,7 @@
#: ../vector/v.convert/att.c:37
#, fuzzy
msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"Aucune étiquette de catégorie (dig_cats) trouvée, aucune table créée.\n"
+msgstr "Aucune étiquette de catégorie (dig_cats) trouvée, aucune table créée.\n"
# c-format
#: ../vector/v.convert/att.c:42
@@ -33928,13 +31913,8 @@
#: ../vector/v.convert/read.c:99
#, fuzzy
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"ATTENTION: Le format de fichier d'entrée n'est pas supporté. Nous allons "
-"essayer de le convertir quand même mais la conversion peut échouer. Veuillez "
-"lire le manuel pour plus d'informations."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "ATTENTION: Le format de fichier d'entrée n'est pas supporté. Nous allons essayer de le convertir quand même mais la conversion peut échouer. Veuillez lire le manuel pour plus d'informations."
#: ../vector/v.convert/read.c:185
#, fuzzy, c-format
@@ -34064,16 +32044,13 @@
#: ../vector/v.what.rast3/main.c:71
#, fuzzy
msgid "Uploads 3d raster values at positions of vector points to the table."
-msgstr ""
-"Charge les valeurs raster dans la table aux positions des points vecteurs"
+msgstr "Charge les valeurs raster dans la table aux positions des points vecteurs"
#: ../vector/v.what.rast3/main.c:75 ../vector/v.what.rast/main.c:80
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
#, fuzzy
msgid "Name of vector points map for which to edit attributes"
-msgstr ""
-"Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la "
-"table attributaire"
+msgstr "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la table attributaire"
#: ../vector/v.what.rast3/main.c:81
#, fuzzy
@@ -34154,9 +32131,7 @@
#: ../vector/v.in.sites/main.c:61
#, fuzzy
msgid "Converts a GRASS site_lists file into a vector map."
-msgstr ""
-"Convertit le fichier GRASS ascii ou le fichier points en couche vectorielle "
-"binaire"
+msgstr "Convertit le fichier GRASS ascii ou le fichier points en couche vectorielle binaire"
#: ../vector/v.in.sites/main.c:85
#, fuzzy, c-format
@@ -34217,8 +32192,7 @@
#: ../vector/v.clean/prune.c:215
#, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
msgstr ""
#: ../vector/v.clean/prune.c:219
@@ -34252,9 +32226,7 @@
msgstr ""
#: ../vector/v.clean/main.c:97
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
msgstr ""
#: ../vector/v.clean/main.c:99
@@ -34262,9 +32234,7 @@
msgstr ""
#: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
msgstr ""
# c-format
@@ -34279,17 +32249,11 @@
msgstr "Suppression des centroïdes en doublons..."
#: ../vector/v.clean/main.c:104
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
msgstr ""
#: ../vector/v.clean/main.c:107
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachement of "
-"centroid), first and last segment of the boundary is never changed"
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed"
msgstr ""
#: ../vector/v.clean/main.c:111
@@ -34309,9 +32273,7 @@
#: ../vector/v.clean/main.c:121
#, fuzzy
msgid "Threshold in map units, one value for each tool"
-msgstr ""
-"Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : "
-"0.0[,0.0,...])"
+msgstr "Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : 0.0[,0.0,...])"
#: ../vector/v.clean/main.c:122
msgid "Default: 0.0[,0.0,...])"
@@ -34567,9 +32529,7 @@
#: ../vector/v.perturb/main.c:66
#, fuzzy
msgid "Random location perturbations of vector points."
-msgstr ""
-"Génère des perturbations aléatoires sur la position de points vectoriels "
-"GRASS"
+msgstr "Génère des perturbations aléatoires sur la position de points vectoriels GRASS"
#: ../vector/v.perturb/main.c:80
msgid "Distribution of perturbation"
@@ -34582,14 +32542,8 @@
#: ../vector/v.perturb/main.c:88
#, fuzzy
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
-msgstr ""
-"Paramètre(s) de distribution. Si la distribution est uniforme, seul un "
-"paramètre, le maximum, est nécessaire. Pour une distribution normale, deux "
-"paramètres, la moyenne et l'écart-type, sont nécessaires."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Paramètre(s) de distribution. Si la distribution est uniforme, seul un paramètre, le maximum, est nécessaire. Pour une distribution normale, deux paramètres, la moyenne et l'écart-type, sont nécessaires."
#: ../vector/v.perturb/main.c:98
msgid "Minimum deviation in map units"
@@ -34605,13 +32559,11 @@
#: ../vector/v.perturb/main.c:129
msgid "Maximum of uniform distribution must be >= zero"
-msgstr ""
-"Le maximum d'une distribution uniforme doit être supérieure ou égale à zéro"
+msgstr "Le maximum d'une distribution uniforme doit être supérieure ou égale à zéro"
#: ../vector/v.perturb/main.c:136
msgid "Standard deviation of normal distribution must be >= zero"
-msgstr ""
-"L'écart-type d'une distribution normale doit être supérieur ou égal à zéro"
+msgstr "L'écart-type d'une distribution normale doit être supérieur ou égal à zéro"
#: ../vector/v.perturb/main.c:238
msgid "Cannot get db link info"
@@ -34624,9 +32576,7 @@
#: ../vector/v.vect.stats/main.c:131
#, fuzzy
msgid "Count points in areas, calculate statistics from point attributes."
-msgstr ""
-"Calcule des statistiques univariées à partir d'une couche raster GRASS basée "
-"sur des objets vecteurs"
+msgstr "Calcule des statistiques univariées à partir d'une couche raster GRASS basée sur des objets vecteurs"
#: ../vector/v.vect.stats/main.c:135
#, fuzzy
@@ -34646,7 +32596,7 @@
#: ../vector/v.vect.stats/main.c:156
#, fuzzy
msgid "Layer number for area map"
-msgstr "Code de couche"
+msgstr "Nom du nouveau fichier vecteur binaire"
#: ../vector/v.vect.stats/main.c:172
#, fuzzy
@@ -34669,9 +32619,7 @@
msgstr "Les noms de colonne sont différents."
#: ../vector/v.vect.stats/main.c:189
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:196
@@ -34680,9 +32628,7 @@
#: ../vector/v.vect.stats/main.c:198
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:205
@@ -34731,11 +32677,10 @@
msgid "scolumn must be of type double"
msgstr "Les colonnes x/y/z doivent être des entiers ou des doubles"
-# c-format
#: ../vector/v.vect.stats/main.c:374
#, fuzzy
msgid "collecting attributes from points vector..."
-msgstr "Impossible de sélectionner des attributs pour l'entité surfacique #%d"
+msgstr "Calcul des moyennes de classes..."
#: ../vector/v.vect.stats/main.c:406
#, fuzzy
@@ -34751,7 +32696,7 @@
#: ../vector/v.vect.stats/main.c:576
#, fuzzy, c-format
msgid "could not find area category %d"
-msgstr "Impossible de trouver la couche vecteur %s"
+msgstr "Aucun enregistrement pour la catégorie (cat = %d)"
# c-format
#: ../vector/v.vect.stats/main.c:704
@@ -34778,10 +32723,7 @@
#: ../vector/v.class/main.c:171
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
msgstr ""
#: ../vector/v.class/main.c:200
@@ -34844,9 +32786,7 @@
#: ../vector/v.info/main.c:45
#, fuzzy
msgid "Outputs basic information about a vector map."
-msgstr ""
-"Afficher des informations générales à propos d'une couche vecteur spécifiée "
-"par l'utilisateur."
+msgstr "Afficher des informations générales à propos d'une couche vecteur spécifiée par l'utilisateur."
#: ../vector/v.info/parse.c:24
#, fuzzy
@@ -34855,12 +32795,8 @@
#: ../vector/v.info/parse.c:30
#, fuzzy
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
-"Afficher les types/noms des colonnes de la table pour une couche spécifiée à "
-"la place des informations"
+msgid "Print types/names of table columns for specified layer instead of info and exit"
+msgstr "Afficher les types/noms des colonnes de la table pour une couche spécifiée à la place des informations"
#: ../vector/v.info/parse.c:35
#, fuzzy
@@ -34880,9 +32816,7 @@
#: ../vector/v.info/print.c:130
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"La connexion à la base de données pour la couche <%s> n'a pas été définie "
-"dans le fichier Base de données"
+msgstr "La connexion à la base de données pour la couche <%s> n'a pas été définie dans le fichier Base de données"
#: ../vector/v.info/print.c:134
#, c-format
@@ -35118,9 +33052,7 @@
msgstr "Nom d'un élément"
#: ../vector/v.lidar.correction/main.c:71
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
msgstr ""
#: ../vector/v.lidar.correction/main.c:81
@@ -35240,9 +33172,7 @@
#: ../vector/v.to.3d/trans2.c:118
#, fuzzy, c-format
msgid "Unable to get height for feature category %d"
-msgstr ""
-"vectorielle"
#: ../vector/v.to.3d/main.c:41
#, fuzzy
@@ -35309,8 +33239,7 @@
msgstr "Indicateur de valeur vide ('null')"
#: ../vector/v.db.select/main.c:91
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
msgstr ""
#: ../vector/v.db.select/main.c:92
@@ -35328,9 +33257,7 @@
#: ../vector/v.db.select/main.c:137
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
# c-format
@@ -35370,9 +33297,7 @@
#: ../vector/v.in.dxf/main.c:68
#, fuzzy
msgid "Converts file in DXF format to GRASS vector map."
-msgstr ""
-"Convertir les fichiers au formats DXF vers le format de fichier vectoriel "
-"GRASS"
+msgstr "Convertir les fichiers au formats DXF vers le format de fichier vectoriel GRASS"
#: ../vector/v.in.dxf/main.c:72
msgid "Ignore the map extent of DXF file"
@@ -35396,8 +33321,7 @@
#: ../vector/v.in.dxf/main.c:91
#, fuzzy
msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr ""
-"Inverser la sélection de couches (ne pas importer les couches dans la liste)"
+msgstr "Inverser la sélection de couches (ne pas importer les couches dans la liste)"
#: ../vector/v.in.dxf/main.c:96
msgid "Import all objects into one layer"
@@ -35464,9 +33388,7 @@
#: ../vector/v.in.dxf/write_vect.c:245
#, fuzzy, c-format
msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-"vectorielle"
#: ../vector/v.split/main.c:55
msgid "Splits vector lines to shorter segments."
@@ -35506,9 +33428,7 @@
#: ../vector/v.split/main.c:132
#, fuzzy
msgid "Can not get projection units"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
# c-format
#: ../vector/v.split/main.c:139
@@ -35535,8 +33455,7 @@
#: ../vector/v.what.rast/main.c:76
#, fuzzy
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
#: ../vector/v.what.rast/main.c:86
msgid "Name of existing raster map to be queried"
@@ -35548,9 +33467,7 @@
#: ../vector/v.what.rast/main.c:151
msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Le type de raster est flottant et le type de colonne est entier, des données "
-"vont être perdues!!"
+msgstr "Le type de raster est flottant et le type de colonne est entier, des données vont être perdues!!"
#: ../vector/v.net.salesman/main.c:128
msgid "salesman"
@@ -35561,9 +33478,7 @@
msgstr ""
#: ../vector/v.net.salesman/main.c:132
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
msgstr ""
#: ../vector/v.net.salesman/main.c:150
@@ -35680,8 +33595,7 @@
#: ../vector/v.extrude/main.c:73
#, fuzzy
msgid "Extrudes flat vector features to 3D with defined height."
-msgstr ""
-"Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
+msgstr "Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
#: ../vector/v.extrude/main.c:77
msgid "Trace elevation"
@@ -35949,9 +33863,7 @@
#: ../vector/v.what/main.c:76
#, fuzzy
msgid "\"-\" to read from standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../vector/v.what/main.c:83
msgid "Query threshold distance"
@@ -35974,9 +33886,7 @@
#: ../vector/v.what/main.c:158
#, fuzzy, c-format
msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr ""
-"de la source."
#: ../vector/v.what/main.c:167
#, fuzzy, c-format
@@ -36208,8 +34118,7 @@
#: ../vector/v.generalize/main.c:526
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
msgstr ""
#: ../vector/v.generalize/main.c:529
@@ -36235,9 +34144,7 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:244
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
msgstr ""
#: ../vector/v.vol.rst/main.c:249
@@ -36268,8 +34175,7 @@
#: ../vector/v.vol.rst/main.c:299
#, fuzzy
msgid "Name for output cross-validation vector map"
-msgstr ""
#: ../vector/v.vol.rst/main.c:305
#, fuzzy
@@ -36283,8 +34189,7 @@
#: ../vector/v.vol.rst/main.c:348
msgid "Conversion factor for w-values used for interpolation"
-msgstr ""
-"Facteur de conversion pour les valeurs w utilisées dans l'interpolation"
+msgstr "Facteur de conversion pour les valeurs w utilisées dans l'interpolation"
#: ../vector/v.vol.rst/main.c:356
msgid "Conversion factor for z-values"
@@ -36352,8 +34257,7 @@
#: ../vector/v.vol.rst/main.c:411
msgid "Perform a cross-validation procedure without volume interpolation"
-msgstr ""
-"Effectue une procédure de validation croisée sans interpolation de volume"
+msgstr "Effectue une procédure de validation croisée sans interpolation de volume"
#: ../vector/v.vol.rst/main.c:474
msgid "Smoothing must be a positive value"
@@ -36362,8 +34266,7 @@
#: ../vector/v.vol.rst/main.c:480
#, fuzzy, c-format
msgid "Both crossvalidation options (-%c, %s) must be specified"
-msgstr ""
-"Vous devez spécifier les deux options de validation croisée (-c, cvdev)"
+msgstr "Vous devez spécifier les deux options de validation croisée (-c, cvdev)"
#: ../vector/v.vol.rst/main.c:483
#, fuzzy
@@ -36420,16 +34323,13 @@
# c-format
#: ../vector/v.vol.rst/user1.c:128
#, fuzzy
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
msgstr "Type de colonne (%s) non géré"
#: ../vector/v.to.rast3/main.c:51
#, fuzzy
msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-"Convertit une couche vecteur GRASS binaire (points seulement) en couche "
-"raster 3D GRASS"
+msgstr "Convertit une couche vecteur GRASS binaire (points seulement) en couche raster 3D GRASS"
#: ../vector/v.to.rast3/main.c:62
#, fuzzy
@@ -36518,11 +34418,8 @@
#: ../vector/v.in.db/main.c:58
#, fuzzy
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Créer de nouveaux objets vecteurs (points) à partir de la table de la base "
-"de données contenant les coordonnées."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Créer de nouveaux objets vecteurs (points) à partir de la table de la base de données contenant les coordonnées."
#: ../vector/v.in.db/main.c:62
msgid "Input table name"
@@ -36567,14 +34464,11 @@
#: ../vector/v.in.db/main.c:101
#, fuzzy
msgid "Use imported table as attribute table for new map"
-msgstr ""
-"nom de la table attributaire existante (par défaut : nom de la couche "
-"vecteur)"
+msgstr "nom de la table attributaire existante (par défaut : nom de la couche vecteur)"
#: ../vector/v.in.db/main.c:141
#, fuzzy, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
msgstr "La table vectorielle cible <'%s'> existe déjà ."
#: ../vector/v.in.db/main.c:191
@@ -36597,19 +34491,13 @@
#: ../vector/v.surf.idw/main.c:90
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
#: ../vector/v.surf.idw/main.c:99
#, fuzzy
msgid "Name of attribute column with values to interpolate"
-msgstr ""
-"Colonne de la table attributaire avec les valeurs à interpoler (si la "
-"couche>0)"
+msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
#: ../vector/v.surf.idw/main.c:100 ../vector/v.surf.idw/main.c:124
#, fuzzy
@@ -36623,12 +34511,8 @@
#: ../vector/v.surf.idw/main.c:116
#, fuzzy
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Ne pas indexer les points par cellule raster (plus lent, mais utilise moins "
-"de mémoireet inclue les points extérieurs à la région dans l'interpolation)"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Ne pas indexer les points par cellule raster (plus lent, mais utilise moins de mémoireet inclue les points extérieurs à la région dans l'interpolation)"
#: ../vector/v.surf.idw/main.c:123 ../vector/v.surf.bspline/main.c:110
#, fuzzy
@@ -36729,9 +34613,7 @@
#: ../vector/v.out.dxf/write_dxf.c:23
#, fuzzy, c-format
msgid "The file '%s' already exists and will be overwritten."
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà . Ce fichier va être "
-"écrasé!\n"
+msgstr "Couche raster %i le nom de fichier %s existe déjà . Ce fichier va être écrasé!\n"
#: ../vector/v.out.dxf/write_dxf.c:27
#, fuzzy, c-format
@@ -36741,9 +34623,7 @@
#: ../vector/v.drape/main.c:147
#, fuzzy
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Convertit une couche vecteur 2D en couche vecteur 3D en rééchantillonnant le "
-"raster d'altitude.Par défaut, en rééchantillonnant au plus proche voisin"
+msgstr "Convertit une couche vecteur 2D en couche vecteur 3D en rééchantillonnant le raster d'altitude.Par défaut, en rééchantillonnant au plus proche voisin"
#: ../vector/v.drape/main.c:158
#, fuzzy
@@ -36793,8 +34673,7 @@
msgstr ""
#: ../vector/v.drape/main.c:389
-msgid ""
-"No features drapped. Check your computational region and input vector map."
+msgid "No features drapped. Check your computational region and input vector map."
msgstr ""
# c-format
@@ -36842,11 +34721,8 @@
#: ../vector/v.net.path/main.c:66
#, fuzzy
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../vector/v.net.path/main.c:93
#, fuzzy
@@ -36854,10 +34730,7 @@
msgstr "Distance maximale du point au réseau"
#: ../vector/v.net.path/main.c:94
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
msgstr ""
#: ../vector/v.net.path/main.c:107
@@ -36866,12 +34739,8 @@
#: ../vector/v.rectify/main.c:73
#, fuzzy
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../vector/v.rectify/main.c:88
#, fuzzy
@@ -36949,16 +34818,12 @@
#: ../vector/v.timestamp/main.c:38
#, fuzzy
msgid "Modifies a timestamp for a vector map."
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster"
#: ../vector/v.timestamp/main.c:39
#, fuzzy
msgid "Print/add/remove a timestamp for a vector map."
-msgstr ""
-"couche raster"
#: ../vector/v.timestamp/main.c:65
#, fuzzy, c-format
@@ -37037,9 +34902,7 @@
#: ../vector/v.surf.bspline/main.c:176
#, fuzzy
msgid "Name of attribute column with values to approximate"
-msgstr ""
-"couche>0)"
#: ../vector/v.surf.bspline/main.c:192
msgid "Maximum memory to be used for raster output (in MB)"
@@ -37107,9 +34970,7 @@
#: ../vector/v.surf.bspline/main.c:324
#, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
msgstr ""
#: ../vector/v.surf.bspline/main.c:347
@@ -37185,9 +35046,7 @@
msgstr ""
#: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
msgstr ""
#: ../vector/v.surf.bspline/crosscorr.c:119
@@ -37228,9 +35087,7 @@
msgstr ""
#: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
msgstr ""
#: ../vector/v.lidar.growing/main.c:83
@@ -37296,9 +35153,7 @@
#: ../vector/v.to.rast/support.c:176
#, fuzzy, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), entité surfacique %d "
-"avec la catégorie %d: code couleur [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d: code couleur [%s]"
#: ../vector/v.to.rast/support.c:179
msgid "Color set to [200:200:200]"
@@ -37307,9 +35162,7 @@
#: ../vector/v.to.rast/support.c:184
#, fuzzy, c-format
msgid "Error in color definition column (%s), with cat %d"
-msgstr ""
-"avec la catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
#: ../vector/v.to.rast/support.c:273
msgid "Label column was not specified, no labels will be written"
@@ -37440,9 +35293,7 @@
#: ../vector/v.to.rast/main.c:92
#, fuzzy
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../vector/v.to.rast/main.c:98
#, fuzzy
@@ -37460,9 +35311,7 @@
#: ../vector/v.to.rast/main.c:132
msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"Le paramètre de colonne ne peut pas être combiner avec l'option de valeurs "
-"de catégories"
+msgstr "Le paramètre de colonne ne peut pas être combiner avec l'option de valeurs de catégories"
#: ../vector/v.to.rast/main.c:137
msgid "Column parameter cannot be combined with use of value option"
@@ -37470,9 +35319,7 @@
#: ../vector/v.to.rast/main.c:142
msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"Le paramètre de colonne ne peut être combiné avec l'utilisation de "
-"coordonnées z"
+msgstr "Le paramètre de colonne ne peut être combiné avec l'utilisation de coordonnées z"
#: ../vector/v.to.rast/main.c:148
#, fuzzy, c-format
@@ -37512,8 +35359,7 @@
msgstr "%d points sans catégorie"
#: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
#: ../vector/v.out.vtk/writeVTK.c:632
@@ -37570,9 +35416,7 @@
#: ../vector/v.out.vtk/main.c:185
#, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
msgstr ""
#: ../vector/v.net.visibility/main.c:48
@@ -37637,9 +35481,7 @@
msgstr "Afficher l'historique du raster à la place des infos générales"
#: ../vector/v.in.lidar/main.c:217
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
msgstr ""
#: ../vector/v.in.lidar/main.c:276
@@ -37764,12 +35606,8 @@
#: ../db/drivers/ogr/describe.c:192
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"colonne '%s', de type 'string': largeur inconnue -> enregistrée comme varchar"
-"(250) des données peuvent être tronquées"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "colonne '%s', de type 'string': largeur inconnue -> enregistrée comme varchar(250) des données peuvent être tronquées"
#: ../db/drivers/ogr/select.c:50
#, fuzzy
@@ -37872,15 +35710,11 @@
#: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:59
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'utilisateur'('user') n'est pas géré dans la définition des bases de "
-"données, utiliser db.login"
+msgstr "'utilisateur'('user') n'est pas géré dans la définition des bases de données, utiliser db.login"
#: ../db/drivers/mysql/parse.c:76 ../db/drivers/postgres/parse.c:63
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'mot de passe'('password') n'est pas géré dans la définition des bases de "
+msgstr "'mot de passe'('password') n'est pas géré dans la définition des bases de données, utiliser db.login"
#: ../db/drivers/mysql/parse.c:81
#, fuzzy
@@ -37937,12 +35771,8 @@
#: ../db/drivers/mysql/describe.c:127
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"colonne '%s' : type BIGINT (entier large) enregistré comme entier (4 octets) "
-"des données peuvent avoir été endommagées"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonne '%s' : type BIGINT (entier large) enregistré comme entier (4 octets) des données peuvent avoir été endommagées"
#: ../db/drivers/mysql/select.c:42
#, fuzzy
@@ -38073,30 +35903,18 @@
#: ../db/drivers/postgres/describe.c:130
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"colonne '%s' : type int8 (entier large) enregistré comme entier (4 octets) "
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonne '%s' : type int8 (entier large) enregistré comme entier (4 octets) des données peuvent avoir été endommagées"
#: ../db/drivers/postgres/describe.c:134
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"colonne '%s' : type character varying enregistré comme varchar(250) des "
-"données peuvent être tronquées"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "colonne '%s' : type character varying enregistré comme varchar(250) des données peuvent être tronquées"
#: ../db/drivers/postgres/describe.c:140
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"colonne '%s' : type bool (booléen) enregistré comme char(1) avec '0' (faux) "
-"ou '1' (vrai)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "colonne '%s' : type bool (booléen) enregistré comme char(1) avec '0' (faux) ou '1' (vrai)"
#: ../db/drivers/postgres/select.c:31
msgid "Unable set DATESTYLE"
@@ -38177,8 +35995,7 @@
msgstr "Impossible de scanner l'étiquette date&heure: "
#: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
msgstr ""
#: ../db/drivers/sqlite/fetch.c:223
@@ -38508,8 +36325,7 @@
#: ../db/db.connect/main.c:48
#, fuzzy
msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Affiche/configure la connexion à la base de données du jeu de données courant"
+msgstr "Affiche/configure la connexion à la base de données du jeu de données courant"
#: ../db/db.connect/main.c:52
#, fuzzy
@@ -38539,9 +36355,7 @@
#: ../db/db.connect/main.c:91
#, fuzzy
msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Groupe d'utilisateurs par défaut de la base de données qui ont le privilège "
-"SELECT."
+msgstr "Groupe d'utilisateurs par défaut de la base de données qui ont le privilège SELECT."
#: ../db/db.connect/main.c:126 ../db/db.connect/main.c:144
#, fuzzy
@@ -38589,9 +36403,7 @@
#: ../db/db.databases/main.c:97
#, fuzzy
msgid "Lists all databases for a given driver and location."
-msgstr ""
-"Lister toutes les bases de données pour un pilote et un Secteur (location) "
-"donnés."
+msgstr "Lister toutes les bases de données pour un pilote et un Secteur (location) donnés."
#: ../db/db.copy/main.c:38
#, fuzzy
@@ -38600,13 +36412,8 @@
#: ../db/db.copy/main.c:40
#, fuzzy
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Copier une table. Vous pouvez soit utiliser 'from_table' (avec une clause "
-"'where' optionnelle)ou l'option 'select', mais pas simultanément "
-"'from_table' et 'select'."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Copier une table. Vous pouvez soit utiliser 'from_table' (avec une clause 'where' optionnelle)ou l'option 'select', mais pas simultanément 'from_table' et 'select'."
#: ../db/db.copy/main.c:46
msgid "Input driver name"
@@ -38636,8 +36443,7 @@
#, fuzzy
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
msgstr ""
-"Clause \"select\" complète (seulement si from_table et where n'ont pas été "
-"utilisés), ex:\n"
+"Clause \"select\" complète (seulement si from_table et where n'ont pas été utilisés), ex:\n"
"\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'"
#: ../db/db.copy/main.c:88
@@ -38663,8 +36469,7 @@
#: ../db/db.login/main.c:42
#, fuzzy
msgid "Sets user/password for DB driver/database."
-msgstr ""
-"Définir utilisateurs/mot de passe pour le pilote de la base de données."
+msgstr "Définir utilisateurs/mot de passe pour le pilote de la base de données."
#: ../db/db.login/main.c:58
#, fuzzy
@@ -38757,8 +36562,7 @@
#: ../db/db.describe/main.c:103
#, fuzzy
msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"afficher uniquement le nom des colonnes, au lieu de la description complète"
+msgstr "afficher uniquement le nom des colonnes, au lieu de la description complète"
#: ../db/db.describe/main.c:108
#, fuzzy
@@ -38782,12 +36586,8 @@
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
#, fuzzy
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche "
-"de points vectoriels GRASS"
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche de points vectoriels GRASS"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -38863,9 +36663,7 @@
#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"Create a new location and import the data into it. Please do not run this "
-"module in parallel or interrupt it when a new location should be created."
+msgid "Create a new location and import the data into it. Please do not run this module in parallel or interrupt it when a new location should be created."
msgstr ""
#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
@@ -38879,9 +36677,7 @@
msgstr "Ãtendre le Secteur actuel en fonction des données importés"
#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
-msgid ""
-"import the space time raster datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
msgstr ""
#: ../locale/scriptstrings/g.manual_to_translate.c:1
@@ -38920,12 +36716,8 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygon "
-"map and uploads statistics to new attribute columns."
-msgstr ""
+msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
#, fuzzy
@@ -39026,9 +36818,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:1
#, fuzzy
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mèle les composantes de couleurs de deux couches rasters en fonction d'un "
-"ratio donné"
+msgstr "Mèle les composantes de couleurs de deux couches rasters en fonction d'un ratio donné"
#: ../locale/scriptstrings/r.blend_to_translate.c:4
msgid "Name of first raster map for blending"
@@ -39042,8 +36832,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:6
#, fuzzy
msgid "Prefix for red, green and blue output raster maps containing"
-msgstr ""
-"Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
+msgstr "Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
#: ../locale/scriptstrings/r.blend_to_translate.c:7
msgid "Percentage weight of first map for color blending"
@@ -39054,9 +36843,7 @@
msgstr ""
#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
msgstr ""
#: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -39096,9 +36883,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
#, fuzzy
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Colonne attributaire à utiliser pour l'affichage thématique (doit être "
-"numérique)"
+msgstr "Colonne attributaire à utiliser pour l'affichage thématique (doit être numérique)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
msgid "Type of thematic display"
@@ -39120,16 +36905,12 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
#, fuzzy
msgid "Break points for custom breaks option"
-msgstr ""
-"Points de rupture pour l'option de rupture personnalisée. Valeurs séparées "
-"par des espaces (0 10 20 30 ...)"
+msgstr "Points de rupture pour l'option de rupture personnalisée. Valeurs séparées par des espaces (0 10 20 30 ...)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
#, fuzzy
msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
msgid "Vector point icon for point data"
@@ -39143,13 +36924,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
#, fuzzy
msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
+msgstr "Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
msgid "Number of classes for interval theme (integer)"
@@ -39163,9 +36942,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
#, fuzzy
msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
-"Schéma de couleur pour la cartographie en couleurs graduelles (choisissez "
-"'couleur simple' pour l'affichage point gradué/ligne)"
+msgstr "Schéma de couleur pour la cartographie en couleurs graduelles (choisissez 'couleur simple' pour l'affichage point gradué/ligne)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
#, fuzzy
@@ -39175,10 +36952,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
#, fuzzy
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"Couleur pour les lignes graduées ou les contours de points/entités "
-"surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de "
-"couleur pour couleur simple."
+msgstr "Couleur pour les lignes graduées ou les contours de points/entités surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de couleur pour couleur simple."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
#, fuzzy
@@ -39188,32 +36962,23 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
#, fuzzy
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
#, fuzzy
msgid "Beginning color for custom color gradient"
-msgstr ""
-"Couleur de départ pour le gardient de couleur personnalisé. Doit être "
-"exprimé sous forme de triplet R:G:B."
+msgstr "Couleur de départ pour le gardient de couleur personnalisé. Doit être exprimé sous forme de triplet R:G:B."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
#, fuzzy
msgid "Must be expressed as R:G:B triplet"
-msgstr ""
-"Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé "
-"sous forme de triplet R:G:B."
+msgstr "Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé sous forme de triplet R:G:B."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
#, fuzzy
msgid "Ending color for custom color gradient"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
#, fuzzy
@@ -39235,29 +37000,21 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Sauvegarder les commandes de cartographie thématique dans le fichier de "
-"groupe dans le Gestionnaire SIG"
+msgstr "Sauvegarder les commandes de cartographie thématique dans le fichier de groupe dans le Gestionnaire SIG"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
#, fuzzy
msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Racine du nom du fichier d'instruction psmat dans le répertoire courant (si "
-"non indiqué, aucun fichier d'instruction psmap ne sera créé)"
+msgstr "Racine du nom du fichier d'instruction psmat dans le répertoire courant (si non indiqué, aucun fichier d'instruction psmap ne sera créé)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Nom du fichier de groupe où les commandes de cartographie thématique seront "
-"sauvegardées"
+msgstr "Nom du fichier de groupe où les commandes de cartographie thématique seront sauvegardées"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
#, fuzzy
@@ -39266,15 +37023,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Only draw fills (no outlines) for areas and points"
-msgstr ""
-"Ne dessiner que le remplissage (sans contours) pour les entités surfaciques "
-"et les points"
+msgstr "Ne dessiner que le remplissage (sans contours) pour les entités surfaciques et les points"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
msgid "Update color values to GRASSRGB column in attribute table"
-msgstr ""
-"Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table "
-"attributaire"
+msgstr "Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table attributaire"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
msgid "Output legend for GIS Manager (for scripting use only)"
@@ -39299,8 +37052,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
+msgstr "Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
@@ -39310,17 +37062,13 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
#, fuzzy
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Fixer le facteur d'échelle (s'applique au Secteur en lat./long. seulement)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr "Fixer le facteur d'échelle (s'applique au Secteur en lat./long. seulement)"
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
#, fuzzy
msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-"Affiche/configure la connexion à la base de données de la couche vecteur "
-"vers une table attributaire"
+msgstr "Affiche/configure la connexion à la base de données de la couche vecteur vers une table attributaire"
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
#, fuzzy
@@ -39344,9 +37092,7 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
msgstr "Lister les couches raster de l'emplacement source et quitter"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -39385,11 +37131,8 @@
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
#, fuzzy
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"ajouter une ou plusieurs colonnes à la table attributaire connectée à une "
-"couche vecteur donnée"
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "ajouter une ou plusieurs colonnes à la table attributaire connectée à une couche vecteur donnée"
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
msgid "Old and new name of the column (old,new)"
@@ -39400,9 +37143,7 @@
msgstr ""
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
msgstr ""
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
@@ -39411,9 +37152,7 @@
msgstr "Nom de la couche raster d'aspect à afficher"
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
-msgid ""
-"Name of the vector column to be created and to store sampled raster values, "
-"otherwise the space time raster name is used as column name"
+msgid "Name of the vector column to be created and to store sampled raster values, otherwise the space time raster name is used as column name"
msgstr ""
#: ../locale/scriptstrings/t.create_to_translate.c:1
@@ -39471,9 +37210,7 @@
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
#, fuzzy
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"importer aussi la couche de qualité (couche du statut SM) et couche filtre "
-"NDVI"
+msgstr "importer aussi la couche de qualité (couche du statut SM) et couche filtre NDVI"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
#, fuzzy
@@ -39482,9 +37219,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Trace un diagramme polaire angulaire pour l'aspect (exposition) ou les "
-"directions du courant"
+msgstr "Trace un diagramme polaire angulaire pour l'aspect (exposition) ou les directions du courant"
#: ../locale/scriptstrings/d.polar_to_translate.c:3
#: ../locale/scriptstrings/d.correlate_to_translate.c:5
@@ -39511,23 +37246,17 @@
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
#, fuzzy
-msgid ""
-"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
-"space time raster datasets."
+msgid "Perform spatio-temporal mapcalc expressions on temporal sampled maps of space time raster datasets."
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
#, fuzzy
msgid "Spatio-temporal mapcalc expression"
-msgstr ""
-"r.mapcalculator - calcule une nouvelle couche raster à partir d'une "
-"expression r.mapcalc"
+msgstr "r.mapcalculator - calcule une nouvelle couche raster à partir d'une expression r.mapcalc"
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
#, fuzzy
-msgid ""
-"Base name of the new created raster maps. This name will be extended with a "
-"numerical prefix"
+msgid "Base name of the new created raster maps. This name will be extended with a numerical prefix"
msgstr "Titre du fichier raster de sortie"
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
@@ -39573,24 +37302,18 @@
msgstr "Compression des fichiers PNG (0=aucun, 1=rapide, 9=maximale)"
#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
-msgid ""
-"The export format of a single raster map. Supported are GeoTIFF via r.out."
-"gdal and the GRASS package format of r.pack."
+msgid "The export format of a single raster map. Supported are GeoTIFF via r.out.gdal and the GRASS package format of r.pack."
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
#, fuzzy
msgid "Vector map to which to join other table"
-msgstr ""
-"Nom de la couche de points vecteurs en entrée pour laquelle éditer la table "
-"attributaire"
+msgstr "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table attributaire"
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
msgid "layer,column"
@@ -39684,12 +37407,8 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Calcule des statistiques univariées sur la colonne sélectionnée dans une "
-"table de couche vecteur."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Calcule des statistiques univariées sur la colonne sélectionnée dans une table de couche vecteur."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
#, fuzzy
@@ -39703,25 +37422,18 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
#, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr ""
-"Nom de la colonne sur laquelle calculée les statistiques (le type doit être "
-"numérique)"
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr "Nom de la colonne sur laquelle calculée les statistiques (le type doit être numérique)"
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
msgstr "Creer/Modifier la table de couleurs associée à une couche raster."
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
#, fuzzy
msgid "Name of color table (see r.color help)"
-msgstr ""
-"a)"
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
#, fuzzy
@@ -39748,9 +37460,7 @@
msgstr "Valeur à calculer"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
msgstr ""
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
@@ -39798,9 +37508,7 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
#, fuzzy
msgid "Create a 3D line from 3 column data"
-msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
#, fuzzy
@@ -39819,19 +37527,13 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
#, fuzzy
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasser une couche raster plus grande ou plus petite que la taille "
-"spécifiée par l'utilisateur (en hectares)"
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reclasser une couche raster plus grande ou plus petite que la taille spécifiée par l'utilisateur (en hectares)"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
#, fuzzy
msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-"option valeur 'plus petite que' <= pour la taille limite de surface "
-"[hectares]"
+msgstr "option valeur 'plus petite que' <= pour la taille limite de surface [hectares]"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
@@ -39842,17 +37544,12 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
#, fuzzy
msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-"option valeur 'plus grande que' >= pour la taille limite de surface "
-"[hectares]"
+msgstr "option valeur 'plus grande que' >= pour la taille limite de surface [hectares]"
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
+msgid "Drops a column from the attribute table connected to a given vector map."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
#, fuzzy
@@ -39862,9 +37559,7 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
#, fuzzy
msgid "Imports attribute tables in various formats."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
#, fuzzy
@@ -39888,12 +37583,8 @@
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
#, fuzzy
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
#, fuzzy
@@ -39906,12 +37597,8 @@
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
#, fuzzy
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de "
-"données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
#: ../locale/scriptstrings/v.pack_to_translate.c:1
msgid "Packs up a vector map and support files for copying."
@@ -39982,8 +37669,7 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-"Préserver les nuances de couleurs relatives, ajuster seulement la luminosité"
+msgstr "Préserver les nuances de couleurs relatives, ajuster seulement la luminosité"
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:13
msgid "Reset to standard color range"
@@ -39996,11 +37682,8 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
#, fuzzy
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"afficher la réponse spectrale à des emplacements précisés par l'utilisateur "
-"dans un groupe ou dans des images"
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "afficher la réponse spectrale à des emplacements précisés par l'utilisateur dans un groupe ou dans des images"
#: ../locale/scriptstrings/i.spectral_to_translate.c:5
#, fuzzy
@@ -40028,18 +37711,13 @@
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Créer une couche plane raster en fonction de l'angle (inclinaison), de "
-"l'aspect/exposition (azimut), et un point"
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Créer une couche plane raster en fonction de l'angle (inclinaison), de l'aspect/exposition (azimut), et un point"
#: ../locale/scriptstrings/r.plane_to_translate.c:4
#, fuzzy
@@ -40083,9 +37761,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
#, fuzzy
@@ -40095,16 +37771,12 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur "
-"stdout)"
+msgstr "Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur stdout)"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
msgid "Imports geonames.org country files into a vector points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
#, fuzzy
@@ -40122,9 +37794,7 @@
msgstr "Nom du nouveau fichier raster"
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
msgstr ""
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
@@ -40134,12 +37804,8 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-"r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et "
-"de MNT en utilisant gdalwarp"
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr "r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et de MNT en utilisant gdalwarp"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
#, fuzzy
@@ -40148,28 +37814,21 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-"Type de traitement d'image ASTER (niveau 1A, niveau 1B, ou MNT relatif)"
+msgstr "Type de traitement d'image ASTER (niveau 1A, niveau 1B, ou MNT relatif)"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
#, fuzzy
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
-msgstr ""
-"canal L1A ou L1B Ã traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire "
-"qu'un seul canal"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+msgstr "canal L1A ou L1B Ã traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire qu'un seul canal"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
#, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
#, fuzzy
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -40247,22 +37906,16 @@
msgstr "couche raster source"
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
#, fuzzy
-msgid ""
-"Temporally aggregates the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Temporally aggregates the maps of a space time raster dataset by a user defined granularity."
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
@@ -40321,12 +37974,8 @@
#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
-msgstr ""
-"Calcule des statistiques univariées à partir des cellules non vides d'une "
-"couche raster."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+msgstr "Calcule des statistiques univariées à partir des cellules non vides d'une couche raster."
#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
#, fuzzy
@@ -40335,18 +37984,13 @@
#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
#, fuzzy
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output "
-"map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
msgstr "Convertit des couches rasters 3D en couches rasters 2D"
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
#, fuzzy
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"permet d'affecter une nouvelle valeur à la colonne de la table attributaire "
-"connectée à la table"
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "permet d'affecter une nouvelle valeur à la colonne de la table attributaire connectée à la table"
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
#, fuzzy
@@ -40355,11 +37999,8 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
#, fuzzy
-msgid ""
-"Value to update the column with, can be (combination of) other column(s)"
-msgstr ""
-"nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être "
-"entre simples guillemets, par exemple : 'grass')"
+msgid "Value to update the column with, can be (combination of) other column(s)"
+msgstr "nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être entre simples guillemets, par exemple : 'grass')"
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
#, fuzzy
@@ -40369,9 +38010,7 @@
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
#, fuzzy
msgid "Exports attribute tables into various formats."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
#, fuzzy
@@ -40390,15 +38029,12 @@
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
#, fuzzy
-msgid ""
-"Replace gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replace gaps in a space time raster dataset with interpolated raster maps."
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
#, fuzzy
-msgid ""
-"Base name of the interpolated raster maps. This name will be extended with a "
-"numerical prefix"
+msgid "Base name of the interpolated raster maps. This name will be extended with a numerical prefix"
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
@@ -40407,24 +38043,18 @@
msgstr "Nombre de points d'interpolation"
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
msgstr ""
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"convertit toutes les anciennes couches vectorielles GRASS (versions "
-"antérieures à 5.7) du jeu de données courant au format récent"
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "convertit toutes les anciennes couches vectorielles GRASS (versions antérieures à 5.7) du jeu de données courant au format récent"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
#, fuzzy
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Remplir les zones sans données des couches rasters en utilisant "
-"l'interpolation par splines v.surf.rst"
+msgstr "Remplir les zones sans données des couches rasters en utilisant l'interpolation par splines v.surf.rst"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
msgid "Spline tension parameter"
@@ -40457,15 +38087,11 @@
msgstr "Valeur raster"
#: ../locale/scriptstrings/t.register_to_translate.c:9
-msgid ""
-"Input file with map names, one per line. Additionally the start time and the "
-"end time can be specified per line"
+msgid "Input file with map names, one per line. Additionally the start time and the end time can be specified per line"
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid ""
-"Valid start date and time of the first map. Format absolute time: \"yyyy-mm-"
-"dd HH:MM:SS +HHMM\", relative time is of type integer)."
+msgid "Valid start date and time of the first map. Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:12
@@ -40477,9 +38103,7 @@
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid ""
-"Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:"
-"SS +HHMM\", relative time is of type integer)."
+msgid "Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -40487,10 +38111,7 @@
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative is integer: 5)"
+msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5)"
msgstr ""
#: ../locale/scriptstrings/t.register_to_translate.c:19
@@ -40499,8 +38120,7 @@
msgstr "Caractère de séparation de champs (en mode 'terse' seulement)"
#: ../locale/scriptstrings/t.register_to_translate.c:21
-msgid ""
-"Create an interval (start and end time) in case an increment is provided"
+msgid "Create an interval (start and end time) in case an increment is provided"
msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
@@ -40520,17 +38140,12 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"crée et ajoute une nouvelle table attributaire à une couche donnée vecteur "
-"existante"
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "crée et ajoute une nouvelle table attributaire à une couche donnée vecteur existante"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"Nom de la nouvelle table attributaire (par défaut: nouvelle couche vecteur)"
+msgstr "Nom de la nouvelle table attributaire (par défaut: nouvelle couche vecteur)"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
@@ -40551,12 +38166,8 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
#, fuzzy
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: \"label varchar(250), type integer\""
-msgstr ""
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: \"label varchar(250), type integer\""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
#, fuzzy
@@ -40580,8 +38191,7 @@
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities file"
+msgid "The given code must be supported by the server, consult the capabilities file"
msgstr ""
# c-format
@@ -40603,9 +38213,7 @@
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -40614,12 +38222,8 @@
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
#, fuzzy
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
-msgstr ""
-"Transformée de Brovey pour fusionner les canaux multispectraux et "
-"panchromatique à haute résolution"
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+msgstr "Transformée de Brovey pour fusionner les canaux multispectraux et panchromatique à haute résolution"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
msgid "fusion"
@@ -40659,9 +38263,7 @@
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
#, fuzzy
msgid "Input raster map for high resolution panchromatic channel"
-msgstr ""
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
msgid "Serial processing rather than parallel processing"
@@ -40674,8 +38276,7 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Charge les valeurs vecteurs dans la table aux positions des points vecteurs"
+msgstr "Charge les valeurs vecteurs dans la table aux positions des points vecteurs"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
#, fuzzy
@@ -40694,9 +38295,7 @@
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time raster3d datasets."
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
@@ -40705,9 +38304,7 @@
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
#, fuzzy
-msgid ""
-"Base name of the new created 3d raster maps. This name will be extended with "
-"a numerical prefix"
+msgid "Base name of the new created 3d raster maps. This name will be extended with a numerical prefix"
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
@@ -40756,9 +38353,7 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Tester le pilote de base de données, la base de données doit exister et "
-"connectée par db.connect"
+msgstr "Tester le pilote de base de données, la base de données doit exister et connectée par db.connect"
#: ../locale/scriptstrings/db.test_to_translate.c:4
msgid "Test name"
@@ -40766,20 +38361,15 @@
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:1
msgid "Rebuilds all locally installed GRASS Addons extensions."
msgstr ""
#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
msgstr ""
#: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:4
@@ -40834,8 +38424,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:1
#, fuzzy
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
+msgstr "Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
#: ../locale/scriptstrings/m.proj_to_translate.c:4
#, fuzzy
@@ -40884,22 +38473,16 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:15
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
+msgstr "Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
#: ../locale/scriptstrings/m.proj_to_translate.c:17
msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-"Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
+msgstr "Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
#: ../locale/scriptstrings/m.proj_to_translate.c:19
#, fuzzy
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Sortie long/lat en degrés décimaux et les autres projections avec beaucoup "
-"de décimales"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Sortie long/lat en degrés décimaux et les autres projections avec beaucoup de décimales"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
#, fuzzy
@@ -40913,8 +38496,7 @@
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Calcule la table Facteur-Index-Optimum pour les canaux 1-5, & 7 de LANDSAT TM"
+msgstr "Calcule la table Facteur-Index-Optimum pour les canaux 1-5, & 7 de LANDSAT TM"
#: ../locale/scriptstrings/i.oif_to_translate.c:5
msgid "LANDSAT TM band 1."
@@ -40956,17 +38538,13 @@
msgstr "Nom d'une couche raster"
#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-msgid ""
-"The export format of a single raster map. Supported are GML via v.out.ogr "
-"and the GRASS package format of v.pack."
+msgid "The export format of a single raster map. Supported are GML via v.out.ogr and the GRASS package format of v.pack."
msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
@@ -40975,8 +38553,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
#, fuzzy
msgid "Table name (default: vector map name)"
-msgstr ""
#: ../locale/scriptstrings/r.grow_to_translate.c:3
#, fuzzy
@@ -40989,19 +38566,13 @@
#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-msgid ""
-"import the space time vector datasets."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
msgstr ""
#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster3d map of a space time raster3d dataset."
-msgstr ""
-"couche raster."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset."
#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
@@ -41021,8 +38592,7 @@
#: ../locale/scriptstrings/t.list_to_translate.c:8
#: ../locale/scriptstrings/t.list_to_translate.c:11
-msgid ""
-"Columns number_of_maps and granularity only available for space time datasets"
+msgid "Columns number_of_maps and granularity only available for space time datasets"
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:9
@@ -41049,8 +38619,7 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
#, fuzzy
msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr ""
-"Affiche un graphe de corrélation entre les couches de données (par paires)"
+msgstr "Affiche un graphe de corrélation entre les couches de données (par paires)"
#: ../locale/scriptstrings/d.correlate_to_translate.c:6
#, fuzzy
@@ -41060,9 +38629,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
#, fuzzy
msgid "Mosaics several images and extends colormap."
-msgstr ""
-"Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de "
-"couleurs; créer une couche *.mosaic"
+msgstr "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de couleurs; créer une couche *.mosaic"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
msgid "mosaicking"
@@ -41070,8 +38637,7 @@
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
#, fuzzy
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
msgstr "Exporte un raster GRASS vers un tableau binaire."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
@@ -41110,17 +38676,12 @@
#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
#, fuzzy
-msgid ""
-"Separator character between the output columns, default is tabular \"\t\""
+msgid "Separator character between the output columns, default is tabular \"\t\""
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produit des tuiles de la projection source pour l'utilisation dans la région "
-"et la projection cible."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produit des tuiles de la projection source pour l'utilisation dans la région et la projection cible."
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
msgid "Produces shell script output"
@@ -41131,11 +38692,8 @@
msgstr "Produit une requête vers un serveur cartographique en sortie"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Nom de la région à utiliser à la place de la région courante pour l'emprise "
-"et la résolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Nom de la région à utiliser à la place de la région courante pour l'emprise et la résolution"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
#, fuzzy
@@ -41208,9 +38766,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
#, fuzzy
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Région désignée pour laquelle demander les données. La région courante est "
-"utilisée si rien d'autre n'est précisée."
+msgstr "Région désignée pour laquelle demander les données. La région courante est utilisée si rien d'autre n'est précisée."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
msgid "WMS standard"
@@ -41275,10 +38831,7 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
@@ -41292,8 +38845,7 @@
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
msgstr "Tranformation Tasseled Cap (Kauth Thomas) pour les données LANDSAT-TM"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
@@ -41347,15 +38899,11 @@
msgstr "Ne pas créer de table attributaire"
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:1
-msgid ""
-"Aggregated data of an existing space time raster dataset using the temporal "
-"topology of a second space time dataset."
+msgid "Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset."
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are "
-"used for aggregation computation"
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
@@ -41388,9 +38936,7 @@
#: ../locale/scriptstrings/t.sample_to_translate.c:1
#, fuzzy
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
msgstr "Nom de la nouvelle couche raster"
#: ../locale/scriptstrings/t.sample_to_translate.c:4
@@ -41404,10 +38950,7 @@
msgstr "Nom de la nouvelle base de données"
#: ../locale/scriptstrings/t.sample_to_translate.c:8
-msgid ""
-"Separator character between the output columns, default is tabular \" | \". "
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "Separator character between the output columns, default is tabular \" | \". Do not use \",\" as this char is reserved to list several map ids in a sample granule"
msgstr ""
#: ../locale/scriptstrings/t.sample_to_translate.c:10
@@ -41417,23 +38960,16 @@
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
#, fuzzy
-msgid ""
-"Store raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
-msgstr ""
-"Charge les valeurs raster dans la table aux positions des points vecteurs"
+msgid "Store raster map values at spatial and temporal positions of vector points as vector attributes."
+msgstr "Charge les valeurs raster dans la table aux positions des points vecteurs"
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
#, fuzzy
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
msgstr "Nom du champ attributaire à utiliser pour les étiquettes"
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:1
@@ -41441,9 +38977,7 @@
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:6
@@ -41466,16 +39000,12 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:12
#, fuzzy
-msgid ""
-"List available extensions in the GRASS Addons SVN repository including "
-"module description"
+msgid "List available extensions in the GRASS Addons SVN repository including module description"
msgstr "Lister les couches disponibles et quitter"
#: ../locale/scriptstrings/g.extension_to_translate.c:14
#, fuzzy
-msgid ""
-"List available extensions in the GRASS Addons SVN repository (shell script "
-"style)"
+msgid "List available extensions in the GRASS Addons SVN repository (shell script style)"
#: ../locale/scriptstrings/g.extension_to_translate.c:16
@@ -41512,12 +39042,8 @@
#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr ""
-"couche raster."
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
#, fuzzy
@@ -41529,9 +39055,7 @@
msgstr ""
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
-msgid ""
-"The base name of the new created raster maps. This name will be extended "
-"with a numerical prefix"
+msgid "The base name of the new created raster maps. This name will be extended with a numerical prefix"
msgstr ""
#: ../locale/scriptstrings/v.unpack_to_translate.c:1
@@ -41565,25 +39089,17 @@
#: ../locale/scriptstrings/t.support_to_translate.c:9
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the grass spatial database. Check for removed maps and delete them from the "
-"temporal database and all effected space time datasets."
+msgid "Update the metadata information and spatial extent of registered maps from the grass spatial database. Check for removed maps and delete them from the temporal database and all effected space time datasets."
msgstr ""
#: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid ""
-"Update metadata information, temporal and spatial extent from registered maps"
+msgid "Update metadata information, temporal and spatial extent from registered maps"
msgstr ""
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
#, fuzzy
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Aucune table attributaire trouvée -> on utilise les identifiants de "
-"catégories comme attributs"
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Aucune table attributaire trouvée -> on utilise les identifiants de catégories comme attributs"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
msgid "dissolve"
@@ -41601,12 +39117,8 @@
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
#, fuzzy
-msgid ""
-"raster map of a space time raster dataset."
-msgstr ""
-"couche raster."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
#, fuzzy
@@ -41628,691 +39140,668 @@
msgid "Percent to brighten"
msgstr "Pourcentage de convergence"
-#~ msgid "nviz - Visualization and animation tool for GRASS data."
-#~ msgstr "nviz - Outil de visualisation et d'animation des données GRASS."
+#, fuzzy
+msgid "Can not open vector <%s> on level %d"
+msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#~ msgid "Name of raster map(s) for Elevation"
-#~ msgstr "Nom de la carte raster pour l'altitude"
+#, fuzzy
+msgid "Please provide three G3D vector maps [x,y,z]"
+msgstr "Veuillez indiquer trois couches vecteurs g3d [x,y,z]"
#, fuzzy
-#~ msgid "Name of raster map(s) for Color"
-#~ msgstr "Nom de la couche raster"
+msgid "output map with walking costs"
+msgstr "couche de sortie"
+msgid "Starting points raster map"
+msgstr "couche vecteur des points de départ"
#, fuzzy
-#~ msgid "Name of vector points overlay file(s)"
-#~ msgstr "couche vecteur des points de départ"
+msgid "No %s map specified"
+msgstr "Aucune couche de données spécifiée"
-#~ msgid "Name of existing 3d raster map"
-#~ msgstr "Nom de la couche raster 3D existante"
+#, fuzzy
+msgid "Use RASTER3D mask (if exists) with output map"
+msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
-#~ msgid "Quickstart - Do not load any data"
-#~ msgstr "Démarrage rapide - ne charger aucune donnée"
+msgid "Use RASTER3D mask (if exists) with input map"
-#~ msgid "Exit after completing script launched from the command line"
-#~ msgstr "Sortir à la fin du script lancé à la ligne de commande"
+#, fuzzy
+msgid "Error writing RASTER3D double data"
+msgstr "Erreur de lecture des cellules de données"
-#~ msgid "Start in Demo mode (skip the \"please wait\" message)"
-#~ msgstr "Démarrer en mode Démo (sauter le message \"merci de patienter\")"
+#, fuzzy
+msgid "Name of the input map"
+msgstr ""
+"#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
+"Nom du fichier raster source\n"
+"Nom de la couche raster source"
-#~ msgid "Execute script file at startup"
-#~ msgstr "Exécuter un script au démarrage"
+#, fuzzy
+msgid "viname"
+msgstr "nom =%s\n"
-#~ msgid "Load previously saved state file"
-#~ msgstr "Charger le fichier d'état enregistré précédemment"
+#, fuzzy
+msgid "Name of the chan7 channel surface reflectance map"
+msgstr "Nom du nouveau fichier raster"
-#~ msgid "Number of elevation files does not match number of colors files"
-#~ msgstr ""
-#~ "Le nombre de fichiers d'altitudes ne correspond pas au nombre de fichiers "
-#~ "de couleur"
+#, fuzzy
+msgid "Illegal value of iterations (%s>)"
+msgstr ""
+"\n"
+"<%s> -- valeur d'itérations illégale"
-#~ msgid "Loading data failed"
-#~ msgstr "Chargement des données échoué"
+#, fuzzy
+msgid "version"
+msgstr "Projection source"
#, fuzzy
-#~ msgid "Image file"
-#~ msgstr "Groupe de fichiers image"
+msgid "Name of mask files"
+msgstr "Nom du fichier d'étiquettes"
+# c-format
#, fuzzy
-#~ msgid "Please provide three G3D vector maps [x,y,z]"
-#~ msgstr "Veuillez indiquer trois couches vecteurs g3d [x,y,z]"
+msgid "unable to open input file %s"
+msgstr "impossible d'ouvrir le fichier en entrée <%s>"
#, fuzzy
-#~ msgid "ASCII raster map to be imported"
-#~ msgstr "Fichier raster ASCII Ã importer"
+msgid "unable to allocate PNG structure"
+msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
#, fuzzy
-#~ msgid "Name of vector map(s) containing starting point(s)"
-#~ msgstr "Couches vectorielles contenant le(s) point(s) de départ"
+msgid "unable to open output file %s"
+msgstr "Impossible d'ouvrir le fichier de sortie"
#, fuzzy
-#~ msgid "Outputting a vector path"
-#~ msgstr "Fichier vecteur de sortie pour les courants"
+msgid "List available OGR layers including feature types in data source and exit"
+msgstr "Lister les couches disponibles dans l'emplacement source et quitter"
#, fuzzy
-#~ msgid "Map grid coordinates of a starting point (E,N)"
-#~ msgstr "Coordonnées est et nord d'un point de départ (E,N)"
+msgid "PostGIS output datasource name"
+msgstr "nom de la base de donnée"
#, fuzzy
-#~ msgid "Map grid coordinates of a stopping point (E,N)"
-#~ msgstr "Coordonnées est et nord d'un point d'arrivée (E,N)"
+msgid "Name for output surface raster map (elevation)"
+msgstr "Fichier raster de relief Z (altitude) à créer"
-#~ msgid "Elevation raster map"
-#~ msgstr "Couche raster d'altitude"
+#, fuzzy
+msgid "db_driver_list_databases() is not implemented"
+msgstr "région <%s> non trouvée"
-#~ msgid ""
-#~ "Creates a raster map layer showing buffer zones surrounding cells that "
-#~ "contain non-NULL category values."
-#~ msgstr ""
-#~ "Créer une couche raster montrant des zones tampons entourant les cellules "
-#~ "qui contiennent des valeurs de catégorie non NULL"
+#, fuzzy
+msgid "Old database schema"
+msgstr "Nom de la base de données"
-#~ msgid "Name of elevation input raster map"
-#~ msgstr "Nom de la couche raster d'altitude en entrée"
+#, fuzzy
+msgid "Name of point vector map containing sample data"
+msgstr "Couche en entrée contenant les lignes"
#, fuzzy
-#~ msgid "output map with walking costs"
-#~ msgstr "couche de sortie"
+msgid "Name of attribute column with numerical value to be interpolated"
+msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
-#~ msgid "Starting points vector map"
-#~ msgstr "couche vecteur des points de départs"
+#, fuzzy
+msgid "Range value"
+msgstr "Valeur raster"
-#~ msgid "Starting points raster map"
+#, fuzzy
+msgid "Nugget value"
+msgstr "Valeur de la chaîne de bit"
-#~ msgid "The map E and N grid coordinates of a starting point (E,N)"
+#, fuzzy
+msgid "Sill value"
-#~ msgid "The map E and N grid coordinates of a stopping point (E,N)"
+#, fuzzy
+msgid "Table name to drop"
+msgstr "impossible de poursuivre"
-#~ msgid "An optional maximum cumulative cost"
-#~ msgstr "Coût maximum cumulé (optionnel)"
+#, fuzzy
+msgid "Name of an existing space time or map dataset"
+msgstr "Nom de la couche raster existante"
+# c-format
+msgid "Open 3d raster map <%s>"
+msgstr "Ouvrir la couche g3d <%s>"
#, fuzzy
-#~ msgid "No %s map specified"
-#~ msgstr "Aucune couche de données spécifiée"
+msgid "Print 3D raster tile number and size information only"
+msgstr "Afficher seulement la région de la couche raster 3D"
#, fuzzy
-#~ msgid "Use RASTER3D mask (if exists) with output map"
-#~ msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
+msgid "groundwater"
+msgstr "Limites"
#, fuzzy
-#~ msgid "Name for new TIFF file"
-#~ msgstr "Nom du nouveau fichier TIFF"
+msgid "numeric"
+msgstr "Métrique"
-#~ msgid ""
-#~ "GRASS module to produce a raster map layer of gaussian deviates whose "
-#~ "mean and standard deviation can be expressed by the user. It uses a "
-#~ "gaussian random number generator."
-#~ msgstr ""
-#~ "Module GRASS pour produire une couche raster de données gaussiennes dont "
-#~ "la moyenne et l'écart-type peuvent être donnés par l'utilisateur. Utilise "
-#~ "un générateur de nombres aléatoires gaussiens."
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
+msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d"
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
+msgstr "Nombre d'attributs incohérent (<%s> %d: <%s> %d"
#, fuzzy
-#~ msgid "Name of the output random surface"
-#~ msgstr ""
-#~ "#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
-#~ "Nom de la nouvelle couche raster\n"
-#~ "Nom de la couche raster de sortie"
+msgid "Raster map to use for masking"
+msgstr "couche raster à utiliser comme MASK"
#, fuzzy
-#~ msgid "Name for new VRML file"
-#~ msgstr "Nom du nouveau fichier d'icones"
+msgid "DN"
+msgstr "D :"
-#~ msgid "Use RASTER3D mask (if exists) with input map"
+#, fuzzy
+msgid "QC"
+msgstr "C :"
#, fuzzy
-#~ msgid "Error writing RASTER3D double data"
-#~ msgstr "Erreur de lecture des cellules de données"
+msgid "Surface Reflectance"
+msgstr "Altitude minimale de l'iso-surface"
#, fuzzy
-#~ msgid "Calculating maps ..."
-#~ msgstr "Calcul des moyennes de classes..."
+msgid "Modis"
+msgstr "Métrique"
#, fuzzy
-#~ msgid "Reading input files: elevation"
-#~ msgstr "impossible de lire les lignes de la couche d'altitude"
+msgid "Name of the Surface temperature map [degree Kelvin]"
+msgstr ""
+"Nom de la couche raster cible\n"
+"Nom de la couche raster de sortie"
# c-format
-#, fuzzy
-#~ msgid "Reading input files: aspect"
-#~ msgstr "\rLecture du fichier '%s'"
+msgid "rows: %d"
+msgstr "lignes: %d"
-#, fuzzy
-#~ msgid "Writing density file"
-#~ msgstr "Ãcriture du nouveau fichier...\n"
+msgid "columns: %d"
+msgstr "colonnes: %d"
+msgid "Aborting."
+msgstr "Abandon."
# c-format
#, fuzzy
-#~ msgid "Unable to find file %s"
-#~ msgstr "Impossible de trouver le fichier [%s]"
+msgid "Unable to build topology for <%s>"
+msgstr "Vecteur d'arrivée introuvable %s"
#, fuzzy
-#~ msgid "Name of the input map"
-#~ msgstr ""
-#~ "Nom du fichier raster source\n"
-#~ "Nom de la couche raster source"
+msgid "Name of input OGR layer"
+msgstr "Nom de la couche source"
#, fuzzy
-#~ msgid "viname"
-#~ msgstr "nom =%s\n"
+msgid "List available OGR layers including feature types in datatsource and exit"
#, fuzzy
-#~ msgid "Name of the chan7 channel surface reflectance map"
-#~ msgstr "Nom du nouveau fichier raster"
+msgid "Supported OGR formats for reading:"
+msgstr "Lister les formats gérés et quitter"
#, fuzzy
-#~ msgid "Illegal value of iterations (%s>)"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- valeur d'itérations illégale"
+msgid "Do not build topology for output vector"
+msgstr "Ne construit pas de topologie en mode points"
-#~ msgid "Sets the legend's text color"
-#~ msgstr "Fixe la couleur du texte de la légende"
-#~ msgid "Don't know the color %s"
-#~ msgstr "Couleur %s inconnue"
#, fuzzy
-#~ msgid "Name of output file"
-#~ msgstr "Nom du fichier de sortie"
+msgid "Supported Formats:"
+msgstr "Lister les formats gérés en sor"
#, fuzzy
-#~ msgid "version"
-#~ msgstr "Projection source"
+msgid "Unable to open OGR file"
+msgstr "Impossible de créer le texte"
#, fuzzy
-#~ msgid "Name of mask files"
-#~ msgstr "Nom du fichier d'étiquettes"
+msgid "dsn: %s\n"
+msgstr "Masque: %s\n"
-# c-format
#, fuzzy
-#~ msgid "unable to open input file %s"
-#~ msgstr "impossible d'ouvrir le fichier en entrée <%s>"
+msgid "not set (default 'ogr')"
+msgstr "Bande à sélectionner (par défaut : tout sélectionner)"
#, fuzzy
-#~ msgid "unable to allocate PNG structure"
-#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
+msgid "format: %s\n"
+msgstr "format OGR"
#, fuzzy
-#~ msgid "unable to open output file %s"
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
+msgid "not set (default ESRI_Shapefile)"
#, fuzzy
-#~ msgid "Name(s) of existing mapset(s)"
-#~ msgstr "Nom des couches raster existantes"
+msgid "<none>"
+msgstr "Terminé"
#, fuzzy
-#~ msgid "Attaching centroids..."
-#~ msgstr "Rattachement des catégories...\n"
+msgid "Unable to create OGR file"
#, fuzzy
-#~ msgid "Building partial topology..."
-#~ msgstr "Construction de l'index spatial ..."
+msgid "Error writing OGR file"
+msgstr "Erreur lors de la lecture du fichier dbmscap\n"
-#~ msgid "Input vector with training points"
-#~ msgstr "couche vecteur en entrée contenant les points d'apprentissage"
+msgid "Error trying to read dbmscap file\n"
-#~ msgid "Input network vector map"
-#~ msgstr "Couche vectorielle de réseau en entrée"
+#, fuzzy
+msgid "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
+msgstr "Pilote pg: colonne '%s', type de donnée %d non géré"
#, fuzzy
-#~ msgid "Output raster/vector map"
-#~ msgstr "couche raster/vecteur à créer"
+msgid "Name of file with SQL select statement(s)"
+msgstr "nom du fichier contenant une commande SQL"
+# c-format
#, fuzzy
-#~ msgid "Standard deviation in map units"
-#~ msgstr "Ecart type en unités carte"
+msgid ""
+"Unable to open file <%s> for reading.\n"
+"Details: %s"
+msgstr "Impossible d'ouvrir le fichier [%s] en lecture"
#, fuzzy
-#~ msgid ""
-#~ "List available OGR layers including feature types in data source and exit"
-#~ msgstr "Lister les couches disponibles dans l'emplacement source et quitter"
+msgid "'-' to read from standard input"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
-#~ msgid "Column name changed: '%s' -> '%s'"
-#~ msgstr "Nom de colonne modifié : '%s' -> '%s'"
+#, fuzzy
+msgid "dataset"
#, fuzzy
-#~ msgid "Cleaning polygons, result is not guaranteed!"
-#~ msgstr "Nettoyage des polygones, le résultat n'est pas garanti!\n"
+msgid "spacetime"
+msgstr "Faire pivoter le cartouche de légende"
#, fuzzy
-#~ msgid "PostGIS output datasource name"
-#~ msgstr "nom de la base de donnée"
+msgid "Name of a space time vector dataset"
+msgstr "Nom d'une couche raster"
#, fuzzy
-#~ msgid "Database schema"
-#~ msgstr "Nom de la base de données"
+msgid "Name(s) of existing raster, raster3d or vector map(s)"
+msgstr "Nom des couches raster existantes"
#, fuzzy
-#~ msgid "Finding nearest areas..."
-#~ msgstr "Recherche des classes d'apprentissage..."
+msgid "Input map type"
+msgstr "couche source"
#, fuzzy
-#~ msgid "Name for output surface raster map (elevation)"
-#~ msgstr "Fichier raster de relief Z (altitude) à créer"
+msgid "Type of the space time dataset, default is space time raster dataset (strds)"
+msgstr "Nom de la nouvelle couche raster"
#, fuzzy
-#~ msgid "'%s' must be > 0 for '%s'"
-#~ msgstr "'layer' doit être >0 pour 'cats'."
+msgid "Unregister vector map(s) from a specific or from all space time vector dataset in which it is registered"
+msgstr "Lister les couches raster de l'emplacement source et quitter"
#, fuzzy
-#~ msgid "Unable to load data from database"
-#~ msgstr "Impossible de sélectionner des données dans la table"
+msgid "spacetime vector dataset"
+msgstr "Nom de la couche raster à partir de laquelle calculer les statistiques"
#, fuzzy
-#~ msgid "Problem loading category values"
-#~ msgstr "Problème de lecture du fichier d'intervalle de valeurs"
+msgid "Name(s) of existing vector map(s) to unregister"
+msgstr "Nom de la couche vectorielle existante"
-#~ msgid "Name of the vector map with input x,y,z,w"
-#~ msgstr "Nom du fichier vecteur avec l'entrée x,y,z,w"
+#, fuzzy
+msgid "spacetime raster dataset"
-#~ msgid "Output deviations vector point file"
-#~ msgstr "Fichier en sortie de déviations de vecteurs points"
+#, fuzzy
+msgid "Name of a space time raster dataset"
-#~ msgid "Output cross-validation vector map"
-#~ msgstr "Fichier vecteur de sortie pour la validation croisée"
+#, fuzzy
+msgid "verride projection (use location's projection)"
+msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
-#~ msgid "Output cross-section raster map"
-#~ msgstr "Nom de fichier de sortie pour la section croisée"
+#, fuzzy
+msgid "Name of the new space time dataset"
+msgstr "Nom de la nouvelle base de données"
-#~ msgid "Output elevation g3d-file"
-#~ msgstr "Couche d'altitude g3d en sortie"
+#, fuzzy
+msgid "Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets"
-#~ msgid "Output gradient magnitude g3d-file"
-#~ msgstr "Couche de magnitude du gradient g3d en sortie"
+#, fuzzy
+msgid "space time vector dataset"
-#~ msgid "Output gradient horizontal angle g3d-file"
-#~ msgstr "Couche d'angle horizontal de gradient g3d en sortie"
+#, fuzzy
+msgid "space time raster dataset"
-#~ msgid "Output gradient vertical angle g3d-file"
-#~ msgstr "Couche d'angle vertical de gradient g3d en sortie"
+#, fuzzy
+msgid "The space time raster dataset to use"
-#~ msgid "Output change of gradient g3d-file"
-#~ msgstr "Couche de changement de gradient g3d en sortie"
+#, fuzzy
+msgid "Name of an existing space time vector dataset"
-#~ msgid "Output gaussian curvature g3d-file"
-#~ msgstr "Couche g3d de courbure gaussienne en sortie"
+#, fuzzy
+msgid "Name(s) of existing vector map(s)"
-#~ msgid "Output mean curvature g3d-file"
-#~ msgstr "Couche g3d de courbure moyenne en sortie"
+#, fuzzy
+msgid "spacetime raster3d dataset"
-#~ msgid "Cannot create table: %s"
-#~ msgstr "Impossible de créer la table : %s"
+#, fuzzy
+msgid "Name of an existing space time raster3d dataset"
+msgstr "Nom d'une couche raster GRASS existante"
#, fuzzy
-#~ msgid "Use all vector points (do not limit to current region)"
-#~ msgstr ""
-#~ "La couche vectorielle de départ %s ne contient aucun point dans la région "
-#~ "courante"
+msgid "Name(s) of existing raster3d map(s)"
-# c-format
#, fuzzy
-#~ msgid "Unable to process areas from vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
+msgid "edit"
+msgstr "Existant"
#, fuzzy
-#~ msgid "Path to resulting VTK file"
-#~ msgstr "Chemin du fichier VTK en sortie"
+msgid "Name(s) of existing raster map(s) to unregister"
+msgstr "Nom de(s) la couche(s) raster à requêter"
#, fuzzy
-#~ msgid "db_driver_list_databases() is not implemented"
-#~ msgstr "région <%s> non trouvée"
+msgid "Name of an existing space time raster dataset"
-# c-format
#, fuzzy
-#~ msgid "Location name"
-#~ msgstr "Secteur : %s\n"
+msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
+msgstr "Répertoire dans lequel sauvegarder les données téléchargées"
#, fuzzy
-#~ msgid "Reconnects vectors to a new database."
-#~ msgstr "Reconnecter les vecteurs à une nouvelle base de données"
+msgid "Name(s) of existing raster map(s)"
#, fuzzy
-#~ msgid "Old database schema"
+msgid "sample"
+msgstr "couche raster à échantillonner"
#, fuzzy
-#~ msgid "Name of point vector map containing sample data"
-#~ msgstr "Couche en entrée contenant les lignes"
+msgid "Name of a space time dataset"
#, fuzzy
-#~ msgid "Name of attribute column with numerical value to be interpolated"
-#~ msgstr ""
-#~ "Colonne de la table attributaire avec les valeurs à interpoler (si la "
-#~ "couche>0)"
+msgid "The method to be used for sampling"
+msgstr "Texte à utiliser pour le nouveau titre de la couche"
#, fuzzy
-#~ msgid "Range value"
-#~ msgstr "Valeur raster"
+msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2"
+msgstr "Couche raster en entrée (Proche Infra Rouge: tm4 | qbird_nir | spot2)"
#, fuzzy
-#~ msgid "Nugget value"
-#~ msgstr "Valeur de la chaîne de bit"
+msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3"
+msgstr "Couche raster en entrée (Moyen Infra Rouge: tm5 | qbird_red | spot3)"
#, fuzzy
-#~ msgid "Sill value"
+msgid "Name of a space time raster3d dataset"
#, fuzzy
-#~ msgid "Table name to drop"
-#~ msgstr "impossible de poursuivre"
+msgid "Name of the output space time raster3d dataset"
#, fuzzy
-#~ msgid "Name of an existing space time or map dataset"
-#~ msgstr "Nom de la couche raster existante"
+msgid "Name of the space time dataset"
-# c-format
-#~ msgid "Open 3d raster map <%s>"
-#~ msgstr "Ouvrir la couche g3d <%s>"
#, fuzzy
-#~ msgid "Print 3D raster tile number and size information only"
-#~ msgstr "Afficher seulement la région de la couche raster 3D"
+msgid "Unknown column type '%s' values lost"
+msgstr "Type de colonne inconnu"
#, fuzzy
-#~ msgid "groundwater"
-#~ msgstr "Limites"
+#~ msgid "Input_maps"
+#~ msgstr "couche source"
#, fuzzy
-#~ msgid "numeric"
-#~ msgstr "Métrique"
+#~ msgid "Output_maps"
+#~ msgstr "couche de sortie"
-#~ msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
-#~ msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d"
+#~ msgid "nviz - Visualization and animation tool for GRASS data."
+#~ msgstr "nviz - Outil de visualisation et d'animation des données GRASS."
-#~ msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
-#~ msgstr "Nombre d'attributs incohérent (<%s> %d: <%s> %d"
+#~ msgid "Name of raster map(s) for Elevation"
+#~ msgstr "Nom de la carte raster pour l'altitude"
#, fuzzy
-#~ msgid "Raster map to use for masking"
-#~ msgstr "couche raster à utiliser comme MASK"
+#~ msgid "Name of raster map(s) for Color"
+#~ msgstr "Nom de la couche raster"
#, fuzzy
-#~ msgid "DN"
-#~ msgstr "D :"
+#~ msgid "Name of vector points overlay file(s)"
+#~ msgstr "couche vecteur des points de départ"
-#, fuzzy
-#~ msgid "QC"
-#~ msgstr "C :"
+#~ msgid "Name of existing 3d raster map"
+#~ msgstr "Nom de la couche raster 3D existante"
-#, fuzzy
-#~ msgid "Surface Reflectance"
-#~ msgstr "Altitude minimale de l'iso-surface"
+#~ msgid "Quickstart - Do not load any data"
+#~ msgstr "Démarrage rapide - ne charger aucune donnée"
-#, fuzzy
-#~ msgid "Modis"
+#~ msgid "Exit after completing script launched from the command line"
+#~ msgstr "Sortir à la fin du script lancé à la ligne de commande"
-#, fuzzy
-#~ msgid "Name of the Surface temperature map [degree Kelvin]"
-#~ msgstr ""
-#~ "Nom de la couche raster cible\n"
+#~ msgid "Start in Demo mode (skip the \"please wait\" message)"
+#~ msgstr "Démarrer en mode Démo (sauter le message \"merci de patienter\")"
-# c-format
-#~ msgid "rows: %d"
-#~ msgstr "lignes: %d"
+#~ msgid "Execute script file at startup"
+#~ msgstr "Exécuter un script au démarrage"
-#~ msgid "columns: %d"
-#~ msgstr "colonnes: %d"
+#~ msgid "Load previously saved state file"
+#~ msgstr "Charger le fichier d'état enregistré précédemment"
-#~ msgid "Aborting."
-#~ msgstr "Abandon."
+#~ msgid "Number of elevation files does not match number of colors files"
+#~ msgstr "Le nombre de fichiers d'altitudes ne correspond pas au nombre de fichiers de couleur"
-# c-format
-#, fuzzy
-#~ msgid "Unable to build topology for <%s>"
-#~ msgstr "Vecteur d'arrivée introuvable %s"
+#~ msgid "Loading data failed"
+#~ msgstr "Chargement des données échoué"
#, fuzzy
-#~ msgid "Name of input OGR layer"
-#~ msgstr "Nom de la couche source"
+#~ msgid "Image file"
+#~ msgstr "Groupe de fichiers image"
#, fuzzy
-#~ msgid ""
-#~ "List available OGR layers including feature types in datatsource and exit"
+#~ msgid "ASCII raster map to be imported"
+#~ msgstr "Fichier raster ASCII Ã importer"
#, fuzzy
-#~ msgid "Supported OGR formats for reading:"
-#~ msgstr "Lister les formats gérés et quitter"
+#~ msgid "Name of vector map(s) containing starting point(s)"
+#~ msgstr "Couches vectorielles contenant le(s) point(s) de départ"
#, fuzzy
-#~ msgid "Do not build topology for output vector"
-#~ msgstr "Ne construit pas de topologie en mode points"
+#~ msgid "Outputting a vector path"
+#~ msgstr "Fichier vecteur de sortie pour les courants"
#, fuzzy
-#~ msgid "Supported Formats:"
-#~ msgstr "Lister les formats gérés en sor"
+#~ msgid "Map grid coordinates of a starting point (E,N)"
+#~ msgstr "Coordonnées est et nord d'un point de départ (E,N)"
#, fuzzy
-#~ msgid "Unable to open OGR file"
-#~ msgstr "Impossible de créer le texte"
+#~ msgid "Map grid coordinates of a stopping point (E,N)"
+#~ msgstr "Coordonnées est et nord d'un point d'arrivée (E,N)"
-#, fuzzy
-#~ msgid "dsn: %s\n"
-#~ msgstr "Masque: %s\n"
+#~ msgid "Elevation raster map"
+#~ msgstr "Couche raster d'altitude"
-#, fuzzy
-#~ msgid "not set (default 'ogr')"
-#~ msgstr "Bande à sélectionner (par défaut : tout sélectionner)"
+#~ msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+#~ msgstr "Créer une couche raster montrant des zones tampons entourant les cellules qui contiennent des valeurs de catégorie non NULL"
-#, fuzzy
-#~ msgid "format: %s\n"
-#~ msgstr "format OGR"
+#~ msgid "Name of elevation input raster map"
+#~ msgstr "Nom de la couche raster d'altitude en entrée"
-#, fuzzy
-#~ msgid "not set (default ESRI_Shapefile)"
+#~ msgid "Starting points vector map"
+#~ msgstr "couche vecteur des points de départs"
+#~ msgid "The map E and N grid coordinates of a starting point (E,N)"
+#~ msgid "The map E and N grid coordinates of a stopping point (E,N)"
+#~ msgid "An optional maximum cumulative cost"
+#~ msgstr "Coût maximum cumulé (optionnel)"
#, fuzzy
-#~ msgid "<none>"
-#~ msgstr "Terminé"
+#~ msgid "Name for new TIFF file"
+#~ msgstr "Nom du nouveau fichier TIFF"
+#~ msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+#~ msgstr "Module GRASS pour produire une couche raster de données gaussiennes dont la moyenne et l'écart-type peuvent être donnés par l'utilisateur. Utilise un générateur de nombres aléatoires gaussiens."
#, fuzzy
-#~ msgid "Unable to create OGR file"
+#~ msgid "Name of the output random surface"
+#~ msgstr ""
+#~ "#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
+#~ "Nom de la nouvelle couche raster\n"
+#~ "Nom de la couche raster de sortie"
#, fuzzy
-#~ msgid "Error writing OGR file"
-#~ msgstr "Erreur lors de la lecture du fichier dbmscap\n"
+#~ msgid "Name for new VRML file"
+#~ msgstr "Nom du nouveau fichier d'icones"
-#~ msgid "Error trying to read dbmscap file\n"
#, fuzzy
-#~ msgid ""
-#~ "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be "
-#~ "converted"
-#~ msgstr "Pilote pg: colonne '%s', type de donnée %d non géré"
+#~ msgid "Calculating maps ..."
+#~ msgstr "Calcul des moyennes de classes..."
#, fuzzy
-#~ msgid "Name of file with SQL select statement(s)"
-#~ msgstr "nom du fichier contenant une commande SQL"
+#~ msgid "Reading input files: elevation"
+#~ msgstr "impossible de lire les lignes de la couche d'altitude"
# c-format
#, fuzzy
-#~ msgid ""
-#~ "Unable to open file <%s> for reading.\n"
-#~ "Details: %s"
-#~ msgstr "Impossible d'ouvrir le fichier [%s] en lecture"
+#~ msgid "Reading input files: aspect"
+#~ msgstr "\rLecture du fichier '%s'"
#, fuzzy
-#~ msgid "'-' to read from standard input"
-#~ msgstr ""
-#~ "Fichier ASCII Ã convertir en fichier vecteur binaire, si rien n'est "
-#~ "indiqué prendreles paramètres saisis en ligne de commande"
+#~ msgid "Writing density file"
+#~ msgstr "Ãcriture du nouveau fichier...\n"
+# c-format
#, fuzzy
-#~ msgid "dataset"
+#~ msgid "Unable to find file %s"
+#~ msgstr "Impossible de trouver le fichier [%s]"
-#, fuzzy
-#~ msgid "spacetime"
-#~ msgstr "Faire pivoter le cartouche de légende"
+#~ msgid "Sets the legend's text color"
+#~ msgstr "Fixe la couleur du texte de la légende"
+#~ msgid "Don't know the color %s"
+#~ msgstr "Couleur %s inconnue"
#, fuzzy
-#~ msgid "Name of a space time vector dataset"
-#~ msgstr "Nom d'une couche raster"
+#~ msgid "Name of output file"
+#~ msgstr "Nom du fichier de sortie"
#, fuzzy
-#~ msgid "Name(s) of existing raster, raster3d or vector map(s)"
+#~ msgid "Name(s) of existing mapset(s)"
#, fuzzy
-#~ msgid "Input map type"
-#~ msgstr "couche source"
+#~ msgid "Attaching centroids..."
+#~ msgstr "Rattachement des catégories...\n"
#, fuzzy
-#~ msgid ""
-#~ "Type of the space time dataset, default is space time raster dataset "
-#~ "(strds)"
-#~ msgstr "Nom de la nouvelle couche raster"
+#~ msgid "Building partial topology..."
+#~ msgstr "Construction de l'index spatial ..."
-#, fuzzy
-#~ msgid ""
-#~ "Unregister vector map(s) from a specific or from all space time vector "
-#~ "dataset in which it is registered"
-#~ msgstr "Lister les couches raster de l'emplacement source et quitter"
+#~ msgid "Input vector with training points"
+#~ msgstr "couche vecteur en entrée contenant les points d'apprentissage"
-#, fuzzy
-#~ msgid "spacetime vector dataset"
-#~ msgstr ""
-#~ "Nom de la couche raster à partir de laquelle calculer les statistiques"
+#~ msgid "Input network vector map"
+#~ msgstr "Couche vectorielle de réseau en entrée"
#, fuzzy
-#~ msgid "Name(s) of existing vector map(s) to unregister"
-#~ msgstr "Nom de la couche vectorielle existante"
+#~ msgid "Output raster/vector map"
+#~ msgstr "couche raster/vecteur à créer"
#, fuzzy
-#~ msgid "spacetime raster dataset"
-#~ msgstr ""
+#~ msgid "Standard deviation in map units"
+#~ msgstr "Ecart type en unités carte"
-#, fuzzy
-#~ msgid "Name of a space time raster dataset"
+#~ msgid "Column name changed: '%s' -> '%s'"
+#~ msgstr "Nom de colonne modifié : '%s' -> '%s'"
#, fuzzy
-#~ msgid "verride projection (use location's projection)"
-#~ msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
+#~ msgid "Cleaning polygons, result is not guaranteed!"
+#~ msgstr "Nettoyage des polygones, le résultat n'est pas garanti!\n"
#, fuzzy
-#~ msgid "Name of the new space time dataset"
-#~ msgstr "Nom de la nouvelle base de données"
+#~ msgid "Database schema"
+#~ msgstr "Nom de la base de données"
#, fuzzy
-#~ msgid ""
-#~ "Uploads raster map values at spatial and temporal positions of vector "
-#~ "points to the tables. The maps are registered in space time datasets"
-#~ msgstr ""
-#~ "Charge les valeurs raster dans la table aux positions des points vecteurs"
+#~ msgid "Finding nearest areas..."
+#~ msgstr "Recherche des classes d'apprentissage..."
#, fuzzy
-#~ msgid "space time vector dataset"
-#~ msgstr ""
+#~ msgid "'%s' must be > 0 for '%s'"
+#~ msgstr "'layer' doit être >0 pour 'cats'."
#, fuzzy
-#~ msgid "space time raster dataset"
-#~ msgstr ""
+#~ msgid "Unable to load data from database"
+#~ msgstr "Impossible de sélectionner des données dans la table"
#, fuzzy
-#~ msgid "The space time raster dataset to use"
-#~ msgstr ""
+#~ msgid "Problem loading category values"
+#~ msgstr "Problème de lecture du fichier d'intervalle de valeurs"
-#, fuzzy
-#~ msgid "Name of an existing space time vector dataset"
+#~ msgid "Name of the vector map with input x,y,z,w"
+#~ msgstr "Nom du fichier vecteur avec l'entrée x,y,z,w"
-#, fuzzy
-#~ msgid "Name(s) of existing vector map(s)"
+#~ msgid "Output deviations vector point file"
+#~ msgstr "Fichier en sortie de déviations de vecteurs points"
-#, fuzzy
-#~ msgid "spacetime raster3d dataset"
-#~ msgstr ""
+#~ msgid "Output cross-validation vector map"
+#~ msgstr "Fichier vecteur de sortie pour la validation croisée"
-#, fuzzy
-#~ msgid "Name of an existing space time raster3d dataset"
-#~ msgstr "Nom d'une couche raster GRASS existante"
+#~ msgid "Output cross-section raster map"
+#~ msgstr "Nom de fichier de sortie pour la section croisée"
-#, fuzzy
-#~ msgid "Name(s) of existing raster3d map(s)"
+#~ msgid "Output elevation g3d-file"
+#~ msgstr "Couche d'altitude g3d en sortie"
-#, fuzzy
-#~ msgid "edit"
-#~ msgstr "Existant"
+#~ msgid "Output gradient magnitude g3d-file"
+#~ msgstr "Couche de magnitude du gradient g3d en sortie"
-#, fuzzy
-#~ msgid "Name(s) of existing raster map(s) to unregister"
-#~ msgstr "Nom de(s) la couche(s) raster à requêter"
+#~ msgid "Output gradient horizontal angle g3d-file"
+#~ msgstr "Couche d'angle horizontal de gradient g3d en sortie"
-#, fuzzy
-#~ msgid "Name of an existing space time raster dataset"
+#~ msgid "Output gradient vertical angle g3d-file"
+#~ msgstr "Couche d'angle vertical de gradient g3d en sortie"
-#, fuzzy
-#~ msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
-#~ msgstr "Répertoire dans lequel sauvegarder les données téléchargées"
+#~ msgid "Output change of gradient g3d-file"
+#~ msgstr "Couche de changement de gradient g3d en sortie"
-#, fuzzy
-#~ msgid "Name(s) of existing raster map(s)"
+#~ msgid "Output gaussian curvature g3d-file"
+#~ msgstr "Couche g3d de courbure gaussienne en sortie"
-#, fuzzy
-#~ msgid "sample"
-#~ msgstr "couche raster à échantillonner"
+#~ msgid "Output mean curvature g3d-file"
+#~ msgstr "Couche g3d de courbure moyenne en sortie"
-#, fuzzy
-#~ msgid "Name of a space time dataset"
+#~ msgid "Cannot create table: %s"
+#~ msgstr "Impossible de créer la table : %s"
#, fuzzy
-#~ msgid "The method to be used for sampling"
-#~ msgstr "Texte à utiliser pour le nouveau titre de la couche"
+#~ msgid "Use all vector points (do not limit to current region)"
+#~ msgstr "La couche vectorielle de départ %s ne contient aucun point dans la région courante"
+# c-format
#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2"
-#~ msgstr ""
-#~ "Couche raster en entrée (Proche Infra Rouge: tm4 | qbird_nir | spot2)"
+#~ msgid "Unable to process areas from vector map <%s>"
+#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3"
-#~ msgstr ""
-#~ "Couche raster en entrée (Moyen Infra Rouge: tm5 | qbird_red | spot3)"
+#~ msgid "Path to resulting VTK file"
+#~ msgstr "Chemin du fichier VTK en sortie"
+# c-format
#, fuzzy
-#~ msgid "Name of a space time raster3d dataset"
+#~ msgid "Location name"
+#~ msgstr "Secteur : %s\n"
#, fuzzy
-#~ msgid "Name of the output space time raster3d dataset"
+#~ msgid "Reconnects vectors to a new database."
+#~ msgstr "Reconnecter les vecteurs à une nouvelle base de données"
-#, fuzzy
-#~ msgid "Name of the space time dataset"
#~ msgid "Name of input 3D raster map"
#~ msgstr "Nom de la couche raster 3D source"
#~ msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-#~ msgstr ""
-#~ "Ãcrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, "
-#~ "Haut-Bas-res)"
+#~ msgstr "Ãcrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-Bas-res)"
#~ msgid "Print 3D raster map type (float/double) only"
#~ msgstr "Ãcrire uniquement le type de couche raster 3D (float/double)"
@@ -42324,36 +39813,22 @@
#~ msgid "Print 3D raster history instead of info"
#~ msgstr "Afficher l'historique du raster à la place des infos générales"
-#~ msgid ""
-#~ "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr ""
-#~ "Afficher seulement l'étiquette date&heure du raster 3D (sous la forme "
-#~ "jour.mois.année heure:minute:secondes)"
+#~ msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
+#~ msgstr "Afficher seulement l'étiquette date&heure du raster 3D (sous la forme jour.mois.année heure:minute:secondes)"
-#~ msgid ""
-#~ "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East "
-#~ "edge"
-#~ msgstr ""
-#~ "no ; bordure Nord-Ouest ; ne ; bordure Nord-Est ; so ; bordure Sud-"
-#~ "Ouest ; se ; bordure Sud-Est"
+#~ msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+#~ msgstr "no ; bordure Nord-Ouest ; ne ; bordure Nord-Est ; so ; bordure Sud-Ouest ; se ; bordure Sud-Est"
#, fuzzy
-#~ msgid ""
-#~ "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;"
-#~ "percent cover"
-#~ msgstr ""
-#~ "mi(les), me(tres), k(ilomètres), a(cres), h(ectares), c(ellules_nombre), p"
-#~ "(ourcentage_couverture)"
+#~ msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+#~ msgstr "mi(les), me(tres), k(ilomètres), a(cres), h(ectares), c(ellules_nombre), p(ourcentage_couverture)"
#~ msgid "Lake depth from %f to %f"
#~ msgstr "Profondeur du lac de %f à %f"
#, fuzzy
-#~ msgid ""
-#~ "ASCII raster file to be imported. If not given reads from standard input"
-#~ msgstr ""
+#~ msgid "ASCII raster file to be imported. If not given reads from standard input"
+#~ msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#, fuzzy
#~ msgid "Integer values are imported"
@@ -42385,10 +39860,7 @@
#, fuzzy
-#~ msgid ""
-#~ "point;import area centroids as points;line;import area boundaries as "
-#~ "lines;boundary;import lines as area boundaries;centroid;import points as "
-#~ "centroids"
+#~ msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
#~ msgstr ""
#~ "Option de modification du type en entrée par défaut:\n"
#~ "\t point -> importe les centroïdes d'entités surfaciques comme points\n"
@@ -42412,10 +39884,7 @@
#~ msgstr "Ne pas créer de table attributaire"
#, fuzzy
-#~ msgid ""
-#~ "attr;read values from attribute table;cat;use category values;val;use "
-#~ "value specified by value option;z;use z coordinate (points or contours "
-#~ "only);dir;output as flow direction (lines only)"
+#~ msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
#~ msgstr ""
#~ "Valeurs raster en entrée :\n"
#~ "\t\tattr - valeur de la table attributaire en lecture\n"
@@ -42426,23 +39895,17 @@
#, fuzzy
#~ msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-#~ msgstr ""
-#~ "Clause SQL 'select', par exemple: 'select * from rybniky where kapri = "
-#~ "'hodne''"
+#~ msgstr "Clause SQL 'select', par exemple: 'select * from rybniky where kapri = 'hodne''"
#~ msgid "Skip to downloading (to resume downloads faster)"
-#~ msgstr ""
-#~ "Passer directement au téléchargement (pour finir le téléchargement plus "
-#~ "vite)"
+#~ msgstr "Passer directement au téléchargement (pour finir le téléchargement plus vite)"
#~ msgid "Download"
#~ msgstr "Télécharger"
#, fuzzy
#~ msgid "Clean existing data out of download directory"
-#~ msgstr ""
-#~ "Nettoyer les données existantes qui se trouvent dans le répertoire de "
-#~ "téléchargement"
+#~ msgstr "Nettoyer les données existantes qui se trouvent dans le répertoire de téléchargement"
#~ msgid "Import"
#~ msgstr "Importer"
@@ -42481,12 +39944,8 @@
#~ msgid "Verbose mod
