[GRASS-SVN] r55252 - grass/trunk/vector/v.transform
svn_grass at osgeo.org
Thu Feb 28 00:30:35 PST 2013
Author: mmetz
Date: 2013-02-28 00:30:35 -0800 (Thu, 28 Feb 2013)
New Revision: 55252
grass/trunk/vector/v.transform/main.c
v.transform: remove refs to GCP and unused flag
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c 2013-02-27 20:58:48 UTC (rev 55251)
+++ grass/trunk/vector/v.transform/main.c 2013-02-28 08:30:35 UTC (rev 55252)
@@ -47,7 +47,7 @@
struct Option *vold, *vnew, *xshift, *yshift, *zshift,
*xscale, *yscale, *zscale, *zrot, *columns, *field_opt;
- struct Flag *tozero_flag, *print_mat_flag, *swap_flag, *no_topo;
+ struct Flag *tozero_flag, *swap_flag, *no_topo;
char mon[4], date[40], buf[1000];
struct Map_info Old, New;
@@ -70,18 +70,13 @@
G_add_keyword(_("vector"));
G_add_keyword(_("transformation"));
module->description =
- _("Performs an affine transformation (shift, scale and rotate, "
- "or GPCs) on vector map.");
+ _("Performs an affine transformation (shift, scale and rotate) "
+ "on vector map.");
tozero_flag = G_define_flag();
tozero_flag->key = 't';
tozero_flag->description = _("Shift all z values to bottom=0");
- print_mat_flag = G_define_flag();
- print_mat_flag->key = 'm';
- print_mat_flag->description =
- _("Print the transformation matrix to stdout");
swap_flag = G_define_flag();
swap_flag->key = 'w';
swap_flag->description =
