[GRASS-SVN] r55254 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu Feb 28 02:43:12 PST 2013
Author: wenzeslaus
Date: 2013-02-28 02:43:12 -0800 (Thu, 28 Feb 2013)
New Revision: 55254
grass/trunk/lib/gis/gislib.dox
dox: removing markdown incompatible syntax
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox 2013-02-28 08:30:57 UTC (rev 55253)
+++ grass/trunk/lib/gis/gislib.dox 2013-02-28 10:43:12 UTC (rev 55254)
@@ -1143,12 +1143,13 @@
The parser routines behave in one of three ways:
- # If no command line arguments are entered by the user, the parser
+<ul>
+<li> If no command line arguments are entered by the user, the parser
searches for a completely interactive version of the command. If the
interactive version is found, control is passed over to this
-version.
+version.
- # If command line arguments are entered but they are a subset of the
+<li> If command line arguments are entered but they are a subset of the
options and flags that the programmer has defined as required
arguments, three things happen. The parser will pass an error message
to the user indicating which required options and/or flags were
@@ -1156,9 +1157,10 @@
usage message for that command, and finally the parser cancels
execution of the command.
- # If all necessary options and flags are entered on the command line
+<li> If all necessary options and flags are entered on the command line
by the user, the parser executes the command with the given options
and flags.
+</ul>
\subsection Structures Structures
