[GRASS-SVN] r55264 - grass/trunk/vector/v.transform
svn_grass at osgeo.org
Thu Feb 28 09:56:48 PST 2013
Author: neteler
Date: 2013-02-28 09:56:47 -0800 (Thu, 28 Feb 2013)
New Revision: 55264
grass/trunk/vector/v.transform/v.transform.html
mention m.transform
Modified: grass/trunk/vector/v.transform/v.transform.html
--- grass/trunk/vector/v.transform/v.transform.html 2013-02-28 17:26:16 UTC (rev 55263)
+++ grass/trunk/vector/v.transform/v.transform.html 2013-02-28 17:56:47 UTC (rev 55264)
@@ -16,7 +16,10 @@
etc.) can be fetched from attribute table connected to the vector
map. In this case vector objects can be transformed with different
parameters based on their category number. If the parameter cannot be
-fetched from the table, default value is used instead.<p>
+fetched from the table, default value is used instead.
+<p>
+Note that the transformation matrix can be printed by
+<em><a href="m.transform.html">m.transform</a></em>.
<h2>EXAMPLE</h2>
@@ -74,8 +77,11 @@
<h2>SEE ALSO</h2>
-<em><a href="v.rectify.html">v.rectify</a></em>,
-<em><a href="v.in.ogr.html">v.in.ogr</a></em>
+<em>
+<a href="m.transform.html">m.transform</a>,
+<a href="v.rectify.html">v.rectify</a>,
+<a href="v.in.ogr.html">v.in.ogr</a>
+</em>
<h2>AUTHOR</h2>
