[GRASS-SVN] r54481 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Tue Jan 1 12:14:56 PST 2013
Author: martinl
Date: 2013-01-01 12:14:55 -0800 (Tue, 01 Jan 2013)
New Revision: 54481
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: SigantureSelect implemented
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-01-01 18:54:19 UTC (rev 54480)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-01-01 20:14:55 UTC (rev 54481)
@@ -287,6 +287,25 @@
elif name == 'SubGroupSelect':
self.data[win.Insert] = { 'group' : p.get('value', '')}
+ elif name == 'SignatureSelect':
+ if p.get('prompt', 'group') == 'group':
+ group = p.get('value', '')
+ pSubGroup = self.task.get_param('subgroup', element = 'prompt', raiseError = False)
+ if pSubGroup:
+ subgroup = pSubGroup.get('value', '')
+ else:
+ subgroup = None
+ else:
+ subgroup = p.get('value', '')
+ pGroup = self.task.get_param('group', element = 'prompt', raiseError = False)
+ if pGroup:
+ group = pGroup.get('value', '')
+ else:
+ group = None
+ self.data[win.Insert] = { 'group' : group,
+ 'subgroup' : subgroup}
elif name == 'LocationSelect':
pDbase = self.task.get_param('dbase', element = 'element', raiseError = False)
@@ -1106,6 +1125,7 @@
if p.get('prompt','') not in ('color',
'color_none',
'subgroup',
+ 'sigfile',
'dbdriver',
'dbname',
'dbtable',
@@ -1222,12 +1242,21 @@
elif prompt == 'subgroup':
selection = gselect.SubGroupSelect(parent = which_panel)
p['wxId'] = [ selection.GetId() ]
- selection.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
- selection.Bind(wx.EVT_TEXT, self.OnSetValue)
+ selection.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ selection.Bind(wx.EVT_TEXT, self.OnSetValue)
which_sizer.Add(item = selection, proportion = 0,
flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
border = 5)
+ # sigrature file
+ elif prompt == 'sigfile':
+ selection = gselect.SignatureSelect(parent = which_panel)
+ p['wxId'] = [ selection.GetId() ]
+ which_sizer.Add(item = selection, proportion = 0,
+ flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
# layer, dbdriver, dbname, dbcolumn, dbtable entry
elif prompt in ('dbdriver',
'dbname',
@@ -1553,6 +1582,8 @@
pGroup = p
pSubGroup = p
+ pSigFile = p
elif prompt == 'dbase':
pDbase = p
elif prompt == 'location':
@@ -1587,8 +1618,11 @@
pTable['wxId-bind'] = pColumnIds
if pGroup and pSubGroup:
- pGroup['wxId-bind'] = pSubGroup['wxId']
+ if pSigFile:
+ pGroup['wxId-bind'] = copy.copy(pSigFile['wxId'])
+ pSubGroup['wxId-bind'] = pSigFile['wxId']
+ pGroup['wxId-bind'] += pSubGroup['wxId']
if pDbase and pLocation:
pDbase['wxId-bind'] = pLocation['wxId']
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2013-01-01 18:54:19 UTC (rev 54480)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2013-01-01 20:14:55 UTC (rev 54481)
@@ -23,6 +23,7 @@
- gselect::ElementSelect
- gselect::OgrTypeSelect
- gselect::CoordinatesSelect
+ - gselect::SignatureSelect
(C) 2007-2012 by the GRASS Development Team
@@ -2074,3 +2075,42 @@
def GetTextWin(self):
"""!Get TextCtrl widget"""
return self.coordsField
+class SignatureSelect(wx.ComboBox):
+ """!Widget for selecting signatures"""
+ def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+ **kwargs):
+ super(SignatureSelect, self).__init__(parent, id, size = size,
+ **kwargs)
+ self.SetName("SignatureSelect")
+ def Insert(self, group, subgroup = None):
+ """!Insert signatures for defined group/subgroup
+ @param group group name (can be fully-qualified)
+ @param subgroup non fully-qualified name of subgroup
+ if not group:
+ return
+ gisenv = grass.gisenv()
+ try:
+ name, mapset = group.split('@', 1)
+ except ValueError:
+ name = group
+ mapset = gisenv['MAPSET']
+ path = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'], mapset,
+ 'group', name)
+ if subgroup:
+ path = os.path.join(path, 'subgroup', subgroup)
+ try:
+ items = list()
+ for element in os.listdir(path):
+ if element in ('subgroup', 'REF'):
+ continue
+ items.append(element)
+ self.SetItems(items)
+ except OSError:
+ self.SetItems([])
+ self.SetValue('')
