[GRASS-SVN] r54484 - grass/trunk/imagery/i.maxlik
svn_grass at osgeo.org
Tue Jan 1 12:36:20 PST 2013
Author: martinl
Date: 2013-01-01 12:36:19 -0800 (Tue, 01 Jan 2013)
New Revision: 54484
grass/trunk/imagery/i.maxlik/main.c
i.maxlik: sync params with other modules
sigfile renamed to signaturefile
class renamed to output
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c 2013-01-01 20:34:36 UTC (rev 54483)
+++ grass/trunk/imagery/i.maxlik/main.c 2013-01-01 20:36:19 UTC (rev 54484)
@@ -72,23 +72,23 @@
parm.subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
parm.sigfile = G_define_option();
- parm.sigfile->key = "sigfile";
+ parm.sigfile->key = "signaturefile";
parm.sigfile->required = YES;
parm.sigfile->type = TYPE_STRING;
+ parm.sigfile->gisprompt = "old,file,sigfile";
parm.sigfile->key_desc = "name";
- parm.sigfile->label = _("Name of file containing signatures");
- parm.sigfile->description = _("Generated by either i.cluster, i.class, or i.gensig");
+ parm.sigfile->label = _("Name of input file containing signatures");
+ parm.sigfile->description = _("Generated by either i.cluster, g.gui.iclass, or i.gensig");
parm.class = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.class->key = "class";
parm.class->required = YES;
- parm.class->description = _("Name for raster map holding classification results");
+ parm.class->description = _("Name for output raster map holding classification results");
parm.reject = G_define_standard_option(G_OPT_R_OUTPUT);
parm.reject->key = "reject";
parm.reject->required = NO;
parm.reject->description =
- _("Name for raster map holding reject threshold results");
+ _("Name for output raster map holding reject threshold results");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
