[GRASS-SVN] r54498 - grass/trunk/gui/wxpython/iclass
Wed Jan 2 08:22:57 PST 2013
Author: martinl
Date: 2013-01-02 08:22:56 -0800 (Wed, 02 Jan 2013)
New Revision: 54498
   grass/trunk/gui/wxpython/iclass/frame.py
wxGUI/iclass: fix bug introduced in r54496
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2013-01-02 16:22:10 UTC (rev 54497)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2013-01-02 16:22:56 UTC (rev 54498)
@@ -512,13 +512,6 @@
         wx.BeginBusyCursor()
         wx.Yield()
-        if 0 != RunCommand('g.copy',
-                           vect = [vector, self.trainingAreaVector],
-                           overwrite = True, quiet = True,
-                           parent = self):
-            wx.EndBusyCursor()
-            return False
         mapLayer = self.toolbars['vdigit'].mapLayer
         # set mapLayer temporarily to None
         # to avoid 'save changes' code in vdigit.toolbars
@@ -528,6 +521,13 @@
         if not ret:
             wx.EndBusyCursor()
             return False
+        if 0 != RunCommand('g.copy',
+                           vect = [vector, self.trainingAreaVector],
+                           overwrite = True, quiet = True,
+                           parent = self):
+            wx.EndBusyCursor()
+            return False
         ret = self.toolbars['vdigit'].StartEditing(mapLayer)
         if not ret:
@@ -569,7 +569,7 @@
             RunCommand('v.db.droptable',
                        flags = 'f',
                        map = self.trainingAreaVector)
         # we use first layer with table, TODO: user should choose
         layer = None
         for key in dbInfo.layers.keys():
