[GRASS-SVN] r54517 - in grass/trunk/gui/wxpython: docs mapdisp vnet
svn_grass at osgeo.org
Thu Jan 3 10:02:12 PST 2013
Author: martinl
Date: 2013-01-03 10:02:08 -0800 (Thu, 03 Jan 2013)
New Revision: 54517
grass/trunk/gui/wxpython/docs/wxGUI.Components.html
grass/trunk/gui/wxpython/docs/wxGUI.vnet.html
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/vnet/toolbars.py
wxGUI/vnet: update manual
various minor fixes
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Components.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Components.html 2013-01-03 17:47:06 UTC (rev 54516)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Components.html 2013-01-03 18:02:08 UTC (rev 54517)
@@ -18,6 +18,7 @@
available also as a command line tool <em><a href="g.gui.iclass.html">g.gui.iclass</a></em></li>
<li><a href="wxGUI.vdigit.html">Vector Digitizer</a>
available also as a command line tool <em><a href="g.gui.vdigit.html">g.gui.vdigit</a></em></li>
+ <li><a href="wxGUI.vnet.html">Vector Network Analysis Tool</a></li>
</ul>
<p>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.vnet.html
--- grass/trunk/gui/wxpython/docs/wxGUI.vnet.html 2013-01-03 17:47:06 UTC (rev 54516)
+++ grass/trunk/gui/wxpython/docs/wxGUI.vnet.html 2013-01-03 18:02:08 UTC (rev 54517)
@@ -6,17 +6,11 @@
<em>Vector Network Analysis Tool</em> is graphical front-end
for <tt>v.net*</tt> modules. It allows perform network analysis
directly in <em><a href="wxGUI.html">wxGUI</a></em> without need to
-use command line. The tool is available from GRASS AddOns repository
-and needs to be installed to GRASS GIS by command:
+use command line. The tool can be launched from Layer Manager
+menu <i>Vector → Network analysis → Vector network analysis
+tool</i> or from Map Display toolbar <i>Analyse map → Vector
+network analysis tool</i> <img src="icons/line-split.png" alt="icon">.
-<div class="code"><pre>
-g.extension -s extension=wx.vnet
-</pre></div>
-The tool can be launched from Map Display toolbar submenu
-of <em>Analyze Map</em> button where is <em>Vector network analysis
-(experimental, GSoC 2012)</em> item.
<p>
<em>Vector Network Analysis Tool</em> currently allows to:
@@ -47,36 +41,39 @@
The tool is split into tabs. Every tab represents some functionality:
-<ul>
- <li> <tt>Parameters</tt> tab - It is used for setting vector map and
- it's layer on which analysis will be done. Also it is possible to
- set columns with cost values from attribute table connected
- to particular layer.</li>
- <li> <tt>Points</tt> tab - It manages points, which are used for
- analysis.</li>
- <li> <tt>Output</tt> tab - There is a output console, which shows
- information about running analysis. </li>
- <li> <tt>Input tables</tt> tab - When existing vector map and it's
- existing layers are set in <tt>Parameters</tt> tab, this tab is
- dynamically added. It shows attribute tables of node and arc layers,
- which were chosen for analysis. It is also possible to compute cost
- values in this tab. This can be done by right mouse button click on
- column label. Then from pop-up menu choose <tt>Add column</tt>,
- where new column for cost values can be created. After that by right
- mouse button click on the added column label can be chosen
- item <tt>Field calculator</tt>. This tool allows to compute cost
- values.</li>
- <li> <tt>Result tables</tt> tab - Result of vector network analysis
- is always vector map. Some vector network analysis results can also
- include attribute tables. If such a table is connected to result
- map, this tab is showed and allows to browse these data.</li>
-</ul>
+<dl>
+ <dt><b>Parameters</b> tab</dt>
+ <dd>It is used for setting vector map and
+ it's layer on which analysis will be done. Also it is possible to
+ set columns with cost values from attribute table connected
+ to particular layer.</dd>
+ <dt><b>Points</b> tab</dt>
+ <dd>It manages points, which are used for analysis.</dd>
+ <dt><b>Output</b> tab</dt>
+ <dd>There is a output console, which shows information about running
+ analysis.</dd>
+ <dt><b>Input tables</b> tab</dt>
+ <dd>When existing vector map and it's existing layers are set
+ in <em>Parameters</em> tab, this tab is dynamically added. It shows
+ attribute tables of node and arc layers, which were chosen for
+ analysis. It is also possible to compute cost values in this
+ tab. This can be done by right mouse button click on column
+ label. Then from pop-up menu choose <em>Add column</em>, where new
+ column for cost values can be created. After that by right mouse
+ button click on the added column label can be chosen item <em>Field
+ calculator</em>. This tool allows to compute cost values.</dd>
+ <dt><b>Result tables</b> tab</dt>
+ <dd>Result of vector network analysis is always vector map. Some
+ vector network analysis results can also include attribute
+ tables. If such a table is connected to result map, this tab is
+ showed and allows to browse these data.</dd>
+</dl>
<h2>KNOWN ISSUES</h2>
When some change is done in layer tree of Map Display, temporary
-vector map representing result of analysis is not rendered
-(use <tt>Show result</tt> button in toolbar to render it again).
+vector map representing result of analysis is not rendered
+(use <em>Show result</em> button in toolbar to render it again).
<h2>SEE ALSO</h2>
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-01-03 17:47:06 UTC (rev 54516)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-01-03 18:02:08 UTC (rev 54517)
@@ -1339,6 +1339,7 @@
"""!Dialog for v.net* modules
if self.dialogs['vnet']:
+ self.dialogs['vnet'].Raise()
return
from vnet.dialogs import VNETDialog
Modified: grass/trunk/gui/wxpython/vnet/toolbars.py
--- grass/trunk/gui/wxpython/vnet/toolbars.py 2013-01-03 17:47:06 UTC (rev 54516)
+++ grass/trunk/gui/wxpython/vnet/toolbars.py 2013-01-03 18:02:08 UTC (rev 54517)
@@ -139,7 +139,7 @@
def OnHelp(self, event) :
RunCommand('g.manual',
- entry = 'wxGUI.VNet')
+ entry = 'wxGUI.vnet')
class AnalysisToolbar(BaseToolbar):
"""!Main toolbar
@@ -173,4 +173,4 @@
icons = {}
- return self._getToolbarData(())
\ No newline at end of file
+ return self._getToolbarData(())
